[Swift-commit] r5999 - trunk/tests
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon Oct 29 14:25:11 CDT 2012
Author: davidk
Date: 2012-10-29 14:25:10 -0500 (Mon, 29 Oct 2012)
New Revision: 5999
Modified:
   trunk/tests/suite.sh
Log:
Fix suite.sh to display the correct swift script name in standard output
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh	2012-10-29 18:53:23 UTC (rev 5998)
+++ trunk/tests/suite.sh	2012-10-29 19:25:10 UTC (rev 5999)
@@ -1079,15 +1079,6 @@
     (( SKIP_COUNTER++ < SKIP_TESTS )) && continue
-	echo
-	echo
-	echo "/--------------------------------------------------------------"
-    echo -e "|   Test case: $LGREEN$TESTNAME$GRAY"
-    echo "\--------------------------------------------------------------"
-    echo
-    TESTLINK=$TESTNAME
    # Use repeat.txt to determine number of test iterations
     SCRIPT_BASENAME=`basename $TESTNAME .swift`
     TESTLINK="$TESTNAMEDIR/$TESTNAME"
@@ -1102,9 +1093,16 @@
       TESTNAME=$( basename $TEST )
       TESTNAMEDIR=`basename $TESTNAME .swift`-$HOURMINSEC
+      echo
+      echo
+      echo    "+--------------------------------------------------------------"
+      echo -e "|   Test case: $LGREEN$TESTNAME$GRAY"
+      echo
       mkdir -p $TESTNAMEDIR
       pushd $TESTNAMEDIR > /dev/null 2>&1
       cp $TEST .
       group_swift_properties
       group_sites_xml
