[Swift-commit] cog r3521
swift at ci.uchicago.edu swift at ci.uchicago.edu
Mon Nov 26 14:05:19 CST 2012
r3521 | davidkelly999 | 2012-11-26 14:01:04 -0600 (Mon, 26 Nov 2012) | 2 lines
Avoid using duplicate ports with multiple coaster-service's running, bug #881
Index: modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterPersistentService.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterPersistentService.java	(revision 3520)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterPersistentService.java	(working copy)
@@ -108,7 +108,7 @@
                 cred = new GlobusGSSCredentialImpl(gc, GSSCredential.INITIATE_AND_ACCEPT);
-            int port = 1984;
+            int port = 0;
             if (ap.hasValue("port")) {
                 if (ap.hasValue("portfile")) {
                     throw new ArgumentParserException("-portfile (-S) and -port are mutually exclusive");
Index: modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/LocalTCPService.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/LocalTCPService.java	(revision 3520)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/LocalTCPService.java	(working copy)
@@ -96,22 +96,41 @@
     public ServiceContext getContext() {
         return context;
-    public void start() {
+    public boolean bindPort() {
         try {
-            channel = ServerSocketChannel.open();
-            channel.configureBlocking(true);
-            if(port == 0) {
-                PortRange portRange = PortRange.getTcpInstance();
-                if(portRange != null && portRange.isEnabled()) {
-                    synchronized(portRange) {
-                        port = portRange.getFreePort(port);
-                        portRange.setUsed(port);
+            channel.socket().bind(new InetSocketAddress(port));
+            return true;
+        catch (Exception e) {
+            return false;
+    public void start() throws IOException {
+        channel = ServerSocketChannel.open();
+        channel.configureBlocking(true);
+        /* When GLOBUS_TCP_PORT_RANGE is defined, find an acceptable port in that range */
+        String globusTCPPortRange = System.getenv("GLOBUS_TCP_PORT_RANGE");
+        String rangeValues[] = {"0", "0"};
+        if(globusTCPPortRange != null) {
+            rangeValues = globusTCPPortRange.split(",");
+        port = Integer.valueOf(rangeValues[0]);
+        while(!bindPort()) {
+            port++;
+            if(port > Integer.valueOf(rangeValues[1])) {
+                String msg = "Unable to find an available port";
+                    msg += " in the range of " + rangeValues[0] + " to " + rangeValues[1];
+                throw new IOException(msg);
-            channel.socket().bind(new InetSocketAddress(port));
+        try {
             if (serverThread == null) {
                 serverThread = new Thread(this);
                 serverThread.setDaemon(true);
