[Swift-commit] r6079 - trunk/tests/language-behaviour/arrays
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Nov 23 03:00:47 CST 2012
Author: hategan
Date: 2012-11-23 03:00:46 -0600 (Fri, 23 Nov 2012)
New Revision: 6079
Added:
   trunk/tests/language-behaviour/arrays/201-closing-if-in-foreach.swift
   trunk/tests/language-behaviour/arrays/202-closing-if-in-if-1.swift
   trunk/tests/language-behaviour/arrays/203-closing-foreach-in-if.swift
   trunk/tests/language-behaviour/arrays/205-closing-if-in-if-2.swift
   trunk/tests/language-behaviour/arrays/206-closing-one-writer.swift
   trunk/tests/language-behaviour/arrays/207-closing-no-writers.swift
   trunk/tests/language-behaviour/arrays/208-closing-self-closing.swift
   trunk/tests/language-behaviour/arrays/209-closing-return-array.swift
   trunk/tests/language-behaviour/arrays/bug-696.swift
Log:
added various tests for new reference counting code
Added: trunk/tests/language-behaviour/arrays/201-closing-if-in-foreach.swift
--- trunk/tests/language-behaviour/arrays/201-closing-if-in-foreach.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/201-closing-if-in-foreach.swift	2012-11-23 09:00:46 UTC (rev 6079)
@@ -0,0 +1,20 @@
+(int r) f(int[] b) {
+	foreach i in b {
+		trace(i);
+	r = 1;
+int a[];
+int[] r;
+foreach i in [0:10] {
+	if (true) {
+		a[i] = 1;
+	else {
+		a[i] = 2;
+	r[i] = f(a);
Added: trunk/tests/language-behaviour/arrays/202-closing-if-in-if-1.swift
--- trunk/tests/language-behaviour/arrays/202-closing-if-in-if-1.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/202-closing-if-in-if-1.swift	2012-11-23 09:00:46 UTC (rev 6079)
@@ -0,0 +1,18 @@
+	foreach i in b {
+		trace(i);
+	r = 1;
+int[] a;
+int r;
+if (true) {
+	if (false) {
+		a[0] = 1;
+	r = f(a);
Added: trunk/tests/language-behaviour/arrays/203-closing-foreach-in-if.swift
--- trunk/tests/language-behaviour/arrays/203-closing-foreach-in-if.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/203-closing-foreach-in-if.swift	2012-11-23 09:00:46 UTC (rev 6079)
@@ -0,0 +1,20 @@
+	foreach i in b {
+		trace(i);
+	r = 1;
+int[] a;
+int r;
+if (true) {
+	foreach j in [0:10] {
+		if (true) {
+			a[j] = 1;
+	r = f(a);
Added: trunk/tests/language-behaviour/arrays/205-closing-if-in-if-2.swift
--- trunk/tests/language-behaviour/arrays/205-closing-if-in-if-2.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/205-closing-if-in-if-2.swift	2012-11-23 09:00:46 UTC (rev 6079)
@@ -0,0 +1,21 @@
+	foreach i in b {
+		trace(i);
+	r = 1;
+int[] a;
+int r;
+if (true) {
+	if (true) {
+		a[0] = 1;
+	r = f(a);
+else {
+	a[1] = 1;
Added: trunk/tests/language-behaviour/arrays/206-closing-one-writer.swift
--- trunk/tests/language-behaviour/arrays/206-closing-one-writer.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/206-closing-one-writer.swift	2012-11-23 09:00:46 UTC (rev 6079)
@@ -0,0 +1,6 @@
+int[] a;
+a[0] = 1;
+foreach i in a {
+	trace(i);
\ No newline at end of file
Added: trunk/tests/language-behaviour/arrays/207-closing-no-writers.swift
--- trunk/tests/language-behaviour/arrays/207-closing-no-writers.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/207-closing-no-writers.swift	2012-11-23 09:00:46 UTC (rev 6079)
@@ -0,0 +1,5 @@
+int[] a;
+foreach i in a {
+	trace(i);
Added: trunk/tests/language-behaviour/arrays/208-closing-self-closing.swift
--- trunk/tests/language-behaviour/arrays/208-closing-self-closing.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/208-closing-self-closing.swift	2012-11-23 09:00:46 UTC (rev 6079)
@@ -0,0 +1,15 @@
+int[] a;
+a[3] = 1;
+int[][] b;
+foreach v, k in a {
+	if (k < 100) {
+		a[k + 10] = 1;
+	trace(k);
+foreach i in [0:2] {
+	a[i] = 1;
+	b[0][i] = 2;
Added: trunk/tests/language-behaviour/arrays/209-closing-return-array.swift
--- trunk/tests/language-behaviour/arrays/209-closing-return-array.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/209-closing-return-array.swift	2012-11-23 09:00:46 UTC (rev 6079)
@@ -0,0 +1,14 @@
+int[] a;
+(int[] r) f() {
+	foreach i in [0:9] {
+		r[i] = i;
+		r[i + 10] = i + 10;
+a = f();
+foreach v in a {
+	trace(v);
Added: trunk/tests/language-behaviour/arrays/bug-696.swift
--- trunk/tests/language-behaviour/arrays/bug-696.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/bug-696.swift	2012-11-23 09:00:46 UTC (rev 6079)
@@ -0,0 +1,25 @@
+main()
+  foreach i in [0:0] {
+    int ia[];
+    if(true) {
+      foreach j in [0:1] {
+        if (j==0) {
+          ia[j] = 100;
+        else {
+          ia[j] = 101;
+      sub(ia);
+sub(int iap[])
+  tracef("in sub: entered\n");
+  tracef("in sub: iap=%q\n",iap);
+main();
