[Swift-commit] r6062 - in SwiftApps/SciColSim/benchmarks: . conf
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon Nov 19 14:16:26 CST 2012
Author: davidk
Date: 2012-11-19 14:16:26 -0600 (Mon, 19 Nov 2012)
New Revision: 6062
Added:
   SwiftApps/SciColSim/benchmarks/conf/raven.cf
   SwiftApps/SciColSim/benchmarks/conf/raven.xml
Modified:
   SwiftApps/SciColSim/benchmarks/benchmark.sh
   SwiftApps/SciColSim/benchmarks/benchmark.swift
   SwiftApps/SciColSim/benchmarks/start-benchmark.sh
Log:
Pass start, stop, step, and timeout values from command line
Modified: SwiftApps/SciColSim/benchmarks/benchmark.sh
--- SwiftApps/SciColSim/benchmarks/benchmark.sh	2012-11-19 19:26:06 UTC (rev 6061)
+++ SwiftApps/SciColSim/benchmarks/benchmark.sh	2012-11-19 20:16:26 UTC (rev 6062)
@@ -5,7 +5,7 @@
 TIME_OUTPUT=$ORIGDIR/$3
 MEM_OUTPUT=$ORIGDIR/$4
-cd $HOME/SciColSim
+cd $6
 # Clean any previous run
 if [ -f "bestdb.txt" ]; then
Modified: SwiftApps/SciColSim/benchmarks/benchmark.swift
--- SwiftApps/SciColSim/benchmarks/benchmark.swift	2012-11-19 19:26:06 UTC (rev 6061)
+++ SwiftApps/SciColSim/benchmarks/benchmark.swift	2012-11-19 20:16:26 UTC (rev 6062)
@@ -1,9 +1,9 @@
 type file;
 # Perform a single benchmark
-app (file timef, file memf, file errorf) benchmark (int target_innovation, int tl)
+app (file timef, file memf, file errorf) benchmark (int target_innovation, int tl, string scidir)
-  benchmark target_innovation tl @filename(timef) @filename(memf) stderr=@errorf;
+  benchmark target_innovation tl @filename(timef) @filename(memf) scidir stderr=@errorf;
 # Create a plot from an array of result files
@@ -12,15 +12,14 @@
    plot @filename(png);
-int target_innovation_start=1;
-int target_innovation_stop=12000;
-int step=1000;
-int time_limit=86300;
+int target_innovation_start=@toInt(@arg("start"));
+int target_innovation_stop=@toInt(@arg("stop"));
+int step=@toInt(@arg("step"));
+int time_limit=@toInt(@arg("limit", "86300"));
+string scicoldir=@arg("scicoldir");
 # Run benchmark
-#file graphs[] <filesys_mapper; location="graph", pattern="*">;
 file graph <"movie-graph.txt">;
 file timeresults[];
 file memresults[];
Added: SwiftApps/SciColSim/benchmarks/conf/raven.cf
--- SwiftApps/SciColSim/benchmarks/conf/raven.cf	                        (rev 0)
+++ SwiftApps/SciColSim/benchmarks/conf/raven.cf	2012-11-19 20:16:26 UTC (rev 6062)
@@ -0,0 +1,10 @@
+wrapperlog.always.transfer=true
+sitedir.keep=true
+execution.retries=5
+lazy.errors=true
+status.mode=provider
+use.provider.staging=false
+provider.staging.pin.swiftfiles=false
+#app raven benchmark=$PWD/benchmark.sh
+#app localhost plot=$PWD/plot.sh
Added: SwiftApps/SciColSim/benchmarks/conf/raven.xml
--- SwiftApps/SciColSim/benchmarks/conf/raven.xml	                        (rev 0)
+++ SwiftApps/SciColSim/benchmarks/conf/raven.xml	2012-11-19 20:16:26 UTC (rev 6062)
@@ -0,0 +1,24 @@
+<config>
+  <pool handle="raven">
+    <execution provider="pbs" jobmanager="local:pbs"/>
+    <profile namespace="globus" key="project">CI-SES000031</profile>
+    <profile namespace="globus" key="jobsPerNode">1</profile>
+    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
+    <profile namespace="globus" key="maxWallTime">24:00:00</profile>
+    <profile namespace="globus" key="queue">long</profile>
+    <profile namespace="karajan" key="jobThrottle">60.99</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <filesystem provider="local"/>
+    <workdirectory>_WORK_</workdirectory>
+  </pool>
+  <pool handle="localhost" >
+    <execution provider="local" url="none" />
+    <profile namespace="karajan" key="jobThrottle">0.09</profile>
+  </pool>
+</config>
Modified: SwiftApps/SciColSim/benchmarks/start-benchmark.sh
--- SwiftApps/SciColSim/benchmarks/start-benchmark.sh	2012-11-19 19:26:06 UTC (rev 6061)
+++ SwiftApps/SciColSim/benchmarks/start-benchmark.sh	2012-11-19 20:16:26 UTC (rev 6062)
@@ -1,22 +1,40 @@
 #!/bin/bash
+# Report error and exit
+crash()
+   MSG=$1
+   echo ${MSG} >&2
+   exit 1
+# Provide usage info
+usage="Usage: $0 -site sitename -start startval -stop stopval -step stepval [-limit limitval]"
 # Process command line arguments
 while [ $# -gt 0 ]; do
   case $1 in
-    -p) paramfile=$2; shift 2;;
-    -s) execsite=$2; shift 2;;
+    -site) execsite=$2; shift 2;;
+    -start) start=$2; shift 2;;
+    -stop) stop=$2; shift 2;;
+    -step) step=$2; shift 2;;
+    -limit) limit=$2; shift 2;;
     *) echo $usage 1>&2
        exit 1;;
   esac
 done
+if [ -z "$execsite" ] || [ -z "$start" ] || [ -z "$stop" ] || [ -z "$step" ]; then
+   crash "$usage"
+fi
 # Create run directory
 rundir=$( echo run??? | sed -e 's/^.*run//' | awk '{ printf("run%03d\n", $1+1)}' )
 if [ -d $rundir ];
 then
-    echo "$rundir already exists! exiting." >&2
-    exit 2
+    crash "$rundir already exists! exiting." >&2
 else
     mkdir $rundir
 fi
@@ -38,4 +56,9 @@
 fi
 # Run swift
-swift -sites.file sites.xml -tc.file tc.data benchmark.swift
+scicoldir=$PWD/..
+command="swift -sites.file sites.xml -tc.file tc.data benchmark.swift -scicoldir=$scicoldir -start=$start -stop=$stop -step=$step"
+if [ -n "$limit" ]; then
+   command="$command -limit=$limit"
+fi
+$( echo $command )
