[Swift-commit] r6027 - trunk/bin
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Sun Nov 11 14:39:25 CST 2012
Author: wilde
Date: 2012-11-11 14:39:24 -0600 (Sun, 11 Nov 2012)
New Revision: 6027
Added:
   trunk/bin/slurm-qsub-emulator
Modified:
Log:
Make slurm-qsub call a swift-modified copy of the SLURM qsub emulator command, which sets --exclusive on all requests to supress node sharing.  This should be changed to allow the user to request shared or exclusive. Exclusive is a reasonable default.
Modified: trunk/bin/slurm-qsub
--- trunk/bin/slurm-qsub	2012-11-11 01:53:55 UTC (rev 6026)
+++ trunk/bin/slurm-qsub	2012-11-11 20:39:24 UTC (rev 6027)
@@ -3,7 +3,7 @@
 now=$(date "+%Y.%m%d.%H:%M:%S")
 echo $now $0: $* >> $HOME/pbslog
-slurmqsub=$( which qsub )
+slurmqsub=$( which slurm-qsub-emulator )
 script=$1.slurm
 echo '#! /bin/sh' >$script
 # echo 'export PBS_NODELIST=SLURM_NODELIST'' >>$script  # FIXME: convert SLURM_NODELIST to PBS_NODEFILE here...
Added: trunk/bin/slurm-qsub-emulator
--- trunk/bin/slurm-qsub-emulator	                        (rev 0)
+++ trunk/bin/slurm-qsub-emulator	2012-11-11 20:39:24 UTC (rev 6027)
@@ -0,0 +1,432 @@
+#! /usr/bin/perl -w
+# qsub - submit a batch job in familar pbs format.
+#  Copyright (C) 2007 The Regents of the University of California.
+#  Produced at Lawrence Livermore National Laboratory (cf, DISCLAIMER).
+#  Written by Danny Auble <auble1 at llnl.gov>.
+#  CODE-OCEC-09-009. All rights reserved.
+#  This file is part of SLURM, a resource management program.
+#  For details, see <http://www.schedmd.com/slurmdocs/>.
+#  Please also read the included file: DISCLAIMER.
+#  SLURM is free software; you can redistribute it and/or modify it under
+#  the terms of the GNU General Public License as published by the Free
+#  Software Foundation; either version 2 of the License, or (at your option)
+#  any later version.
+#  In addition, as a special exception, the copyright holders give permission
+#  to link the code of portions of this program with the OpenSSL library under
+#  certain conditions as described in each individual source file, and
+#  distribute linked combinations including the two. You must obey the GNU
+#  General Public License in all respects for all of the code used other than
+#  OpenSSL. If you modify file(s) with this exception, you may extend this
+#  exception to your version of the file(s), but you are not obligated to do
+#  so. If you do not wish to do so, delete this exception statement from your
+#  version.  If you delete this exception statement from all source files in
+#  the program, then also delete it here.
+#  SLURM is distributed in the hope that it will be useful, but WITHOUT ANY
+#  WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
+#  FOR A PARTICULAR PURPOSE.  See the GNU General Public License for more
+#  details.
+#  You should have received a copy of the GNU General Public License along
+#  with SLURM; if not, write to the Free Software Foundation, Inc.,
+#  51 Franklin Street, Fifth Floor, Boston, MA 02110-1301  USA.
+use strict;
+use FindBin;
+use Getopt::Long 2.24 qw(:config no_ignore_case require_order);
+use lib qw(/software/slurm-2.4-el6-x86_64/lib64/perl5);
+use autouse 'Pod::Usage' => qw(pod2usage);
+use Slurm ':all';
+use Switch;
+my ($start_time,
+    $account,
+ #   $checkpoint_interval,
+    $directive_prefix,
+    $err_path,
+    $interactive,
+    $hold,
+#    $join,
+#    $keep,
+    $resource_list,
+    $mail_options,
+    $mail_user_list,
+    $job_name,
+    $out_path,
+    $priority,
+    $destination,
+#    $rerunable,
+#    $script_path,
+#    $running_user_list,
+#    $variable_list,
+#    $all_env,
+    $additional_attributes,
+#    $no_std,
+    $help,
+    $man);
+# my $sbatch = "${FindBin::Bin}/sbatch";
+# my $salloc = "${FindBin::Bin}/salloc";
+# my $srun = "${FindBin::Bin}/srun";
+my $sbatch = "sbatch";
+my $salloc = "salloc";
+my $srun = "$srun";
+GetOptions('a=s'      => \$start_time,
+	   'A=s'      => \$account,
+#	   'c=i'      => \$checkpoint_interval,
+	   'C=s'      => \$directive_prefix,
+	   'e=s'      => \$err_path,
+	   'h'        => \$hold,
+	   'I'        => \$interactive,
+	   'j:s'      => sub { warn "option -j is the default, " .
+				    "stdout/stderr go into the same file\n" },
+#	   'k=s'      => \$keep,
+	   'l=s'      => \$resource_list,
+	   'm=s'      => \$mail_options,
+	   'M=s'      => \$mail_user_list,
+	   'N=s'      => \$job_name,
+	   'o=s'      => \$out_path,
+	   'p=i'      => \$priority,
+	   'q=s'      => \$destination,
+#	   'r=s'      => \$rerunable,
+#	   'S=s'      => \$script_path,
+#	   'u=s'      => \$running_user_list,
+	   'v=s'      => sub { warn "option -v is not supported, " .
+				    "since the current environment " .
+				    "is exported by default\n" },
+	   'V'        => sub { warn "option -V is not necessary, " .
+	   'W'        => \$additional_attributes,
+#	   'z'        => \$no_std,
+	   'help|?'   => \$help,
+	   'man'      => \$man,
+	or pod2usage(2);
+# Display usage if necessary
+pod2usage(0) if $help;
+if ($man) {
+        if ($< == 0) {   # Cannot invoke perldoc as root
+		my $id = eval { getpwnam("nobody") };
+		$id = eval { getpwnam("nouser") } unless defined $id;
+		$id = -2                          unless defined $id;
+		$<  = $id;
+        $> = $<;                         # Disengage setuid
+        $ENV{PATH} = "/bin:/usr/bin";    # Untaint PATH
+        delete @ENV{'IFS', 'CDPATH', 'ENV', 'BASH_ENV'};
+        if ($0 =~ /^([-\/\w\.]+)$/) { $0 = $1; }    # Untaint $0
+        else { die "Illegal characters were found in \$0 ($0)\n"; }
+        pod2usage(-exitstatus => 0, -verbose => 2);
+# Use sole remaining argument as jobIds
+my $script;
+if ($ARGV[0]) {
+	foreach (@ARGV) {
+	        $script .= "$_ ";
+} else {
+        pod2usage(2);
+my %res_opts;
+my %node_opts;
+if($resource_list) {
+	%res_opts = %{parse_resource_list($resource_list)};
+# 	while((my $key, my $val) = each(%res_opts)) {
+# 		print "$key = ";
+# 		if($val) {
+# 			print "$val\n";
+# 		} else {
+# 			print "\n";
+	if($res_opts{nodes}) {
+		%node_opts =  %{parse_node_opts($res_opts{nodes})};
+my $command;
+if($interactive) {
+	$command = "$salloc";
+} else {
+	$command = "$sbatch";
+	$command .= " -D $directive_prefix" if $directive_prefix;
+	$command .= " -e $err_path" if $err_path;
+	$command .= " -o $out_path" if $out_path;
+$command .= " -N$node_opts{node_cnt}" if $node_opts{node_cnt};
+$command .= " -n$node_opts{task_cnt}" if $node_opts{task_cnt};
+$command .= " -w$node_opts{hostlist}" if $node_opts{hostlist};
+if($res_opts{walltime}) {
+	$command .= " -t$res_opts{walltime}";
+} elsif($res_opts{cput}) {
+	$command .= " -t$res_opts{cput}";
+} elsif($res_opts{pcput}) {
+	$command .= " -t$res_opts{pcput}";
+$command .= " --tmp=$res_opts{file}" if $res_opts{file};
+$command .= " --mem=$res_opts{mem}" if $res_opts{mem};
+$command .= " --nice=$res_opts{nice}" if $res_opts{nice};
+# Cray-specific options
+$command .= " -n$res_opts{mppwidth}"		    if $res_opts{mppwidth};
+$command .= " -w$res_opts{mppnodes}"		    if $res_opts{mppnodes};
+$command .= " --cpus-per-task=$res_opts{mppdepth}"  if $res_opts{mppdepth};
+$command .= " --ntasks-per-node=$res_opts{mppnppn}" if $res_opts{mppnppn};
+$command .= " --begin=$start_time" if $start_time;
+$command .= " --account=$account" if $account;
+$command .= " -H" if $hold;
+if($mail_options) {
+	$command .= " --mail-type=FAIL" if $mail_options =~ /a/;
+	$command .= " --mail-type=BEGIN" if $mail_options =~ /b/;
+	$command .= " --mail-type=END" if $mail_options =~ /e/;
+$command .= " --mail-user=$mail_user_list" if $mail_user_list;
+$command .= " -J $job_name" if $job_name;
+$command .= " --nice=$priority" if $priority;
+$command .= " -p $destination" if $destination;
+$command .= " -C $additional_attributes" if $additional_attributes;
+$command .= " --exclusive"; # MWilde: added for midway, which schedules by core.
+$command .= " $script";
+system("(echo; echo $command; echo) >> $HOME/pbslog");
+system($command);
+sub parse_resource_list {
+	my ($rl) = @_;
+	my %opt = ('arch' => "",
+		   'cput' => "",
+		   'file' => "",
+		   'host' => "",
+		   'mem' => "",
+		   'nice' => "",
+		   'nodes' => "",
+		   'opsys' => "",
+		   'other' => "",
+		   'pcput' => "",
+		   'pmem' => "",
+		   'pvmem' => "",
+		   'software' => "",
+		   'vmem' => "",
+		   # Cray-specific resources
+		   'mppwidth' => "",
+		   'mppdepth' => "",
+		   'mppnppn' => "",
+		   'mppmem' => "",
+		   'mppnodes' => "",
+		   'walltime' => ""
+	my @keys = keys(%opt);
+	foreach my $key (@keys) {
+		#print "$rl\n";
+		($opt{$key}) = $rl =~ m/$key=([\w:\+=+]+)/;
+	if($opt{cput}) {
+		$opt{cput} = get_minutes($opt{cput});
+	if($opt{mppmem}) {
+		$opt{mem} = convert_mb_format($opt{mppmem});
+	} elsif($opt{mem}) {
+		$opt{mem} = convert_mb_format($opt{mem});
+	if($opt{file}) {
+		$opt{file} = convert_mb_format($opt{file});
+	return \%opt;
+sub parse_node_opts {
+	my ($node_string) = @_;
+	my %opt = ('node_cnt' => 0,
+		   'hostlist' => "",
+		   'task_cnt' => 0
+	while($node_string =~ /ppn=(\d+)/g) {
+		$opt{task_cnt} += $1;
+	my $hl = Slurm::Hostlist::create("");
+	my @parts = split(/\+/, $node_string);
+	foreach my $part (@parts) {
+		my @sub_parts = split(/:/, $part);
+		foreach my $sub_part (@sub_parts) {
+			if($sub_part =~ /ppn=(\d+)/) {
+				next;
+			} elsif($sub_part =~ /^(\d+)/) {
+				$opt{node_cnt} += $1;
+			} else {
+				if(!Slurm::Hostlist::push($hl, $sub_part)) {
+					print "problem pushing host $sub_part onto hostlist\n";
+	$opt{hostlist} = Slurm::Hostlist::ranged_string($hl);
+	my $hl_cnt = Slurm::Hostlist::count($hl);
+	$opt{node_cnt} = $hl_cnt if $hl_cnt > $opt{node_cnt};
+	# we always want at least one here
+	if(!$opt{node_cnt}) {
+		$opt{node_cnt} = 1;
+	# figure out the amount of tasks based of the node cnt and the amount
+	# of ppn's in the request
+	if($opt{task_cnt}) {
+		$opt{task_cnt} *= $opt{node_cnt};
+	return \%opt;
+sub get_minutes {
+    my ($duration) = @_;
+    $duration = 0 unless $duration;
+    my $minutes = 0;
+    # Convert [[HH:]MM:]SS to duration in minutes
+    if ($duration =~ /^(?:(\d+):)?(\d*):(\d+)$/) {
+        my ($hh, $mm, $ss) = ($1 || 0, $2 || 0, $3);
+	$minutes += 1 if $ss > 0;
+        $minutes += $mm;
+        $minutes += $hh * 60;
+    } elsif ($duration =~ /^(\d+)$/) {  # Convert number in minutes to seconds
+	    my $mod = $duration % 60;
+	    $minutes = int($duration / 60);
+	    $minutes++ if $mod;
+    } else { # Unsupported format
+        die("Invalid time limit specified ($duration)\n");
+    return $minutes;
+sub convert_mb_format {
+	my ($value) = @_;
+	my ($amount, $suffix) = $value =~ /(\d+)($|[KMGT])/i;
+	return if !$amount;
+	$suffix = lc($suffix);
+	if (!$suffix) {
+		$amount /= 1048576;
+	} elsif ($suffix eq "k") {
+		$amount /= 1024;
+	} elsif ($suffix eq "m") {
+		#do nothing this is what we want.
+	} elsif ($suffix eq "g") {
+		$amount *= 1024;
+	} elsif ($suffix eq "t") {
+		$amount *= 1048576;
+	} else {
+		print "don't know what to do with suffix $suffix\n";
+		return;
+	$amount .= "M";
+	return $amount;
+__END__
+=head1 NAME
+B<qsub> - submit a batch job in a familiar pbs format
+=head1 SYNOPSIS
+qsub  [-a date_time]
+      [-A account_string]
+      [-b secs]
+      [-C directive_prefix]
+      [-e path]
+      [-I]
+      [-l resource_list]
+      [-m mail_options] [-M  user_list]
+      [-N name]
+      [-o path]
+      [-p priority]
+      [-q destination]
+      [-W additional_attributes]
+      [-h]
+      [script]
+=head1 DESCRIPTION
+The B<qsub> command displays information about nodes. It is aimed to be feature-compatible with PBS' qsub.
+=head1 OPTIONS
+=over 4
+=item B<-a>
+Display information for all nodes. This is the default if no node name is specified.
+=item B<-I>
+Interactive execution.
+=item B<-j> join
+It is not necessary (currently also not possible) since stderr/stdout are always joined.
+=item B<-v> [variable_list]
+Exporting single variables via -v is not supported, since the entire login environment
+is exported by the default.
+=item B<-V>
+The -V option to export the current environment is not required since it is done by default.
+=item B<-?> | B<--help>
+brief help message
+=item B<--man>
+full documentation
+=back
+=cut
Property changes on: trunk/bin/slurm-qsub-emulator
___________________________________________________________________
Added: svn:executable
