[Swift-commit] r6025 - in trunk/src/org/griphyn/vdl: karajan/lib karajan/lib/swiftscript mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Nov 10 14:23:24 CST 2012
Author: hategan
Date: 2012-11-10 14:23:23 -0600 (Sat, 10 Nov 2012)
New Revision: 6025
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java
   trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java
   trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
   trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
Log:
rename main thread to "main" instead of an empty string when tracing; formalized messages according to bug867
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java	2012-11-10 05:56:59 UTC (rev 6024)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java	2012-11-10 20:23:23 UTC (rev 6025)
@@ -76,9 +76,6 @@
                     for (Path p : fp) {
                         AbstractDataNode n = (AbstractDataNode) var.getField(p);
                     	n.waitFor();
-                    	if (tracer.isEnabled()) {
-                    	    tracer.trace(stack, procName + " available " + Tracer.getVarName(n));
                 catch (DependentException e) {
@@ -90,7 +87,7 @@
             catch (FutureFault f) {
-                    tracer.trace(stack, procName + " wait " + Tracer.getFutureName(f.getFuture()));
+                    tracer.trace(stack, procName + " WAIT " + Tracer.getFutureName(f.getFuture()));
                 throw f;
@@ -115,7 +112,7 @@
                     var.waitFor();
-                    tracer.trace(stack, procName + " waiting for " + Tracer.getFutureName(f.getFuture()));
                     throw f;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java	2012-11-10 05:56:59 UTC (rev 6024)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java	2012-11-10 20:23:23 UTC (rev 6025)
@@ -134,11 +134,11 @@
     public void trace(VariableStack stack, Object msg) throws VariableNotFoundException {
-        trace(ThreadingContext.get(stack).toString(), msg);
+        trace(threadName(stack), msg);
     public void trace(String thread, Object msg) {
-        String str = source + ", thread " + thread + ", " + msg;
+        String str = source + ", thread " + threadName(thread) + ", " + msg;
         logger.info(str);
@@ -146,7 +146,7 @@
         if (line == null) {
             return;
-        String str = name + ", line " + line + ", thread " + thread + ", "+ msg;
+        String str = name + ", line " + line + ", thread " + threadName(thread) + ", "+ msg;
         logger.info(str);
@@ -154,14 +154,27 @@
         if (line == null) {
             return;
-        String str = source + ", line " + line + ", thread " + thread + ", " + msg;
+        String str = source + ", line " + line + ", thread " + threadName(thread) + ", " + msg;
         logger.info(str);
     public void trace(String thread) {
-        logger.info(source + ", thread " + thread);
+        logger.info(source + ", thread " + threadName(thread));
+    private String threadName(String thread) {
+        if (thread.isEmpty()) {
+            return "main";
+        else {
+            return thread;
+    private String threadName(VariableStack stack) throws VariableNotFoundException {
+        return threadName(ThreadingContext.get(stack).toString());
     private static Tracer disabledTracer, enabledTracer;
     public static Tracer getTracer(FlowNode fe) {
@@ -245,8 +258,8 @@
     public static Object unwrapHandle(Object o) {
-        if (o instanceof DSHandle) {
-            DSHandle h = (DSHandle) o;
+        if (o instanceof AbstractDataNode) {
+            AbstractDataNode h = (AbstractDataNode) o;
             if (h.isClosed()) {
                 if (h.getType().isPrimitive()) {
                     if (Types.STRING.equals(h.getType())) {
@@ -260,8 +273,7 @@
                     return getVarName(h);
                 else {
-                    Mapper m = h.getMapper();
-                    return "<" + m.map(h.getPathFromRoot()) + ">";
+                    return fileName(h);
             else {
@@ -274,17 +286,12 @@
     public static Object fileName(AbstractDataNode n) {
-        if (Types.STRING.equals(n.getType())) {
-            return unwrapHandle(n);
+        Mapper m = n.getActualMapper();
+        if (m == null) {
+            return "?" + getVarName(n);
         else {
-            Mapper m = n.getActualMapper();
-            if (m == null) {
-                return "?" + getVarName(n);
-            else {
-                return "<" + m.map(n.getPathFromRoot()) + ">";
+            return "<" + m.map(n.getPathFromRoot()) + ">";
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java	2012-11-10 05:56:59 UTC (rev 6024)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java	2012-11-10 20:23:23 UTC (rev 6025)
@@ -50,7 +50,7 @@
 	public static final Arg SRC = new Arg.Positional("src");
 	public static boolean warning;
-	public static Tracer tracer;
+	public Tracer tracer;
 	static {
 		setArguments(ReadData.class, new Arg[] { DEST, SRC });
@@ -59,14 +59,14 @@
 	@Override
     protected void initializeStatic() {
         super.initializeStatic();
-        tracer = Tracer.getTracer(this);
+        tracer = Tracer.getTracer(this, "SWIFTCALL");
     protected Object function(VariableStack stack) throws ExecutionException {
 		DSHandle dest = (DSHandle) DEST.getValue(stack);
 		AbstractDataNode src = (AbstractDataNode) SRC.getValue(stack);
-		    tracer.trace(stack, Tracer.fileName(src));
+		    tracer.trace(stack, "readData(" + Tracer.unwrapHandle(src) + ")");
 		src.waitFor();
 		if (src.getType().equals(Types.STRING)) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java	2012-11-10 05:56:59 UTC (rev 6024)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java	2012-11-10 20:23:23 UTC (rev 6025)
@@ -29,11 +29,11 @@
 import org.globus.cog.karajan.arguments.Arg;
 import org.globus.cog.karajan.stack.VariableStack;
 import org.globus.cog.karajan.workflow.ExecutionException;
+import org.griphyn.vdl.karajan.lib.Tracer;
 import org.griphyn.vdl.karajan.lib.VDLFunction;
 import org.griphyn.vdl.mapping.AbsFile;
 import org.griphyn.vdl.mapping.AbstractDataNode;
 import org.griphyn.vdl.mapping.DSHandle;
-import org.griphyn.vdl.mapping.HandleOpenException;
 import org.griphyn.vdl.mapping.Path;
 import org.griphyn.vdl.mapping.PhysicalFormat;
 import org.griphyn.vdl.type.Types;
@@ -48,10 +48,21 @@
 	static {
 		setArguments(ReadStructured.class, new Arg[] { DEST, SRC });
+	@Override
+    protected void initializeStatic() {
+        super.initializeStatic();
+		if (tracer.isEnabled()) {
+            tracer.trace(stack, "readData2(" + Tracer.unwrapHandle(src) + ")");
         src.waitFor();
 			readData(dest, (String) src.getValue());
Modified: trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java	2012-11-10 05:56:59 UTC (rev 6024)
+++ trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java	2012-11-10 20:23:23 UTC (rev 6025)
@@ -63,7 +63,7 @@
         if (waitingMapperParam != null) {
             waitingMapperParam.getFutureWrapper().addModificationAction(this, null);
-                tracer.trace(getThread(), getDeclarationLine(), getDisplayableName() + " wait "
+                tracer.trace(getThread(), getDeclarationLine(), getDisplayableName() + " WAIT "
                     + Tracer.getVarName(waitingMapperParam));
             return;
@@ -98,11 +98,7 @@
-	public void futureModified(Future f, VariableStack stack) {
-	        tracer.trace(getThread(), getDeclarationLine(), getDisplayableName() + " available "
-                    + Tracer.getFutureName(f));
+	public void futureModified(Future f, VariableStack stack) {
 	    innerInit();
@@ -150,7 +146,7 @@
         initialized = true;
         waitingMapperParam = null;
-            tracer.trace(getThread(), getDeclarationLine(), getDisplayableName() + " initialized");
+            tracer.trace(getThread(), getDeclarationLine(), getDisplayableName() + " INITIALIZED");
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2012-11-10 05:56:59 UTC (rev 6024)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2012-11-10 20:23:23 UTC (rev 6025)
@@ -67,7 +67,7 @@
             return;
@@ -109,10 +109,6 @@
 		innerInit();
@@ -251,7 +247,7 @@
 		initialized = true;
