[Swift-commit] r6016 - trunk/src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Nov 9 23:23:08 CST 2012
Author: hategan
Date: 2012-11-09 23:23:08 -0600 (Fri, 09 Nov 2012)
New Revision: 6016
Modified:
   trunk/src/org/griphyn/vdl/mapping/InvalidPathException.java
Log:
"Invalid path" is not very good wording. Changed exception to be specific. If an array index is invalid, then say so. If a struct field is invalid, then say so
Modified: trunk/src/org/griphyn/vdl/mapping/InvalidPathException.java
--- trunk/src/org/griphyn/vdl/mapping/InvalidPathException.java	2012-11-10 05:21:45 UTC (rev 6015)
+++ trunk/src/org/griphyn/vdl/mapping/InvalidPathException.java	2012-11-10 05:23:08 UTC (rev 6016)
@@ -20,16 +20,45 @@
 package org.griphyn.vdl.mapping;
 public class InvalidPathException extends Exception {
 	public InvalidPathException(String path, DSHandle source) {
-		super("Invalid path (" + path + ") for "
-			+ source.toString());
+		super(getMessage(path, source));
-	public InvalidPathException(Path path, DSHandle source) {
+	private static String getMessage(String path, DSHandle source) {
+		if (source.getType().isArray()) {
+			return "Array index '" + path + "' not found for " + getName(source) + " of size " + getSize(source);
+		else if (source.getType().isComposite()) {
+			return "Invalid field name '" + path + "' for " + getName(source) + " of type " + source.getType();
+		else {
+			return "Invalid path (" + path + ") for " + source.toString();
+    private static int getSize(DSHandle source) {
+        return source.getArrayValue().size();
+    private static String getName(DSHandle source) {
+        if (source instanceof AbstractDataNode) {
+        	return ((AbstractDataNode) source).getDisplayableName();
+        else {
+        	return source.toString();
+    public InvalidPathException(Path path, DSHandle source) {
 		this(path.toString(), source);
+    public InvalidPathException(Object path, DSHandle source) {
+        this(path.toString(), source);
     public InvalidPathException(String string) {
         super(string);
