[Swift-commit] Cog update
swift at ci.uchicago.edu swift at ci.uchicago.edu
Sat Mar 17 03:01:54 CDT 2012
r3363 | davidkelly999 | 2012-03-07 17:40:35 -0600 (Wed, 07 Mar 2012) | 2 lines
Fix to start the correct number of workers
Index: modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/sge/SGEExecutor.java
--- modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/sge/SGEExecutor.java	(revision 3362)
+++ modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/sge/SGEExecutor.java	(working copy)
@@ -315,7 +315,7 @@
     protected void writeMultiJobPreamble(Writer wr, String exitcodefile)
             throws IOException {
-        wr.write("NODES=`cat $PE_HOSTFILE | awk '{ for(i=0;i<$2;i++){print $1} }'`\n");
+        wr.write("NODES=`cat $PE_HOSTFILE | awk '{print $1}'`\n");
         wr.write("ECF=" + exitcodefile + "\n");
         wr.write("INDEX=0\n");
         wr.write("for NODE in $NODES; do\n");
