[Swift-commit] r5705 - SwiftApps/SciColSim
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Wed Mar 7 10:06:18 CST 2012
Author: jonmon
Date: 2012-03-07 10:06:17 -0600 (Wed, 07 Mar 2012)
New Revision: 5705
Modified:
   SwiftApps/SciColSim/optimizer.cpp
Log:
o added loss limiting code in the optimizer for the SciColSim app.  Needs larger scale testing.
Modified: SwiftApps/SciColSim/optimizer.cpp
--- SwiftApps/SciColSim/optimizer.cpp	2012-03-02 00:46:25 UTC (rev 5704)
+++ SwiftApps/SciColSim/optimizer.cpp	2012-03-07 16:06:17 UTC (rev 5705)
@@ -22,7 +22,7 @@
 #include <iostream>
 #include <stdio.h>
 #include <time.h>
-#include <ctime>
+#include <ctime>
 #include <algorithm>
 #include <string>
@@ -69,6 +69,8 @@
 #define FIX_VARIABLES 1
+#define MAX_LOSS 160
 using namespace boost;
 using namespace std;
 using namespace boost::numeric::ublas;
@@ -114,10 +116,10 @@
         GaussNum += ((double)rand()/(double)RAND_MAX - 0.5);
     GaussNum = GaussNum*sqrt((double)12/(double)NumInSum);
     return GaussNum;
@@ -133,27 +135,27 @@
 double get_new_x(double x, double dx){
     double new_x;
     // boost::variate_generator<base_generator_type&, boost::uniform_real<> > uni(generator, uni_dist);
     double r = rand()/(double)(pow(2.,31)-1.);
-    if (r > 0.5){
+    if (r > 0.5){
         new_x = x + rand()*dx/(double)(pow(2.,31)-1.);
-    } else {
+    } else {
         new_x = x - rand()*dx/(double)(pow(2.,31)-1.);
     return new_x;
 string string_wrap(string ins, int mode){
     std::ostringstream s;
     switch(mode){
         case 0:
             s << "\033[1;29m" << ins << "\033[0m";
@@ -191,143 +193,143 @@
         default:
             s << ins;
     return s.str();
 string wrap_double(double val, int mode){
     s << string_wrap(strDouble(val),mode);
     return s.str();
-const
+const
 string i2string(int i){
-    s << "worker"
+    s << "worker"
     << lexical_cast<std::string>(i);
     return s.str();
 char* i2char(int i){
-    s << "worker"
+    s << "worker"
     char* a=new char[s.str().size()+1];
     memcpy(a,s.str().c_str(), s.str().size());
     return a;
 class Universe {
 private:
 	double alpha_i;
 	double alpha_m;
 	double beta;
 	double gamma;
 	double delta;
     double TargetNovelty;
     double CumulativeRelativeLoss;
     double CRLsquare;
     string id;
 	int N_nodes;
 	int M_edges;
 	int N_epochs;
 	int N_steps;
 	int N_repeats;
 	int current_epoch;
 	double current_loss;
 	int current_repeat;
     double current_novelty;
 	int mode_identify_failed;
     int verbose_level; // 0 is silent, higher is more
 	double k_max;
 	graph_t Full_g;
 	double **Prob;
 	double **Tried;
 	double **Dist;
 	double **Final;
     double **EdgeIndex;
 	double *Rank;
-    base_generator_type generator;
+    base_generator_type generator;
     boost::uniform_real<> uni_dist;
     boost::geometric_distribution<double> geo;
 public:
 	//======  Constructor ======
 	Universe(const std::string FileToOpen, int Epochs, int Steps, int Repeats, int identify_failed, double target, const std::string idd)
 		//typedef array_type2::index index2;
 		std::ifstream inFile;
         //string line;
         base_generator_type gene(42u);
         generator = gene;
         generator.seed(static_cast<unsigned int>(std::time(0)));
         boost::uniform_real<> uni_d(0,1);
         uni_dist = uni_d;
 		int i, k;
         int x, y;
 		Edge* edge_array_mine;
 		int num_arcs_mine, num_nodes_mine;
 		int* weights_mine;
         TargetNovelty = target;
         CumulativeRelativeLoss = 0.;
         CRLsquare = 0.;
 		N_epochs  = Epochs;
 		N_steps   = Steps;
 		N_repeats = Repeats;
 		current_epoch = 0;
 		current_loss = 0.;
 		current_repeat = 0;
         id = idd;
         verbose_level = 1;
 		mode_identify_failed = identify_failed;
 		// The first pass though file with the graph
 		inFile.open(FileToOpen.c_str());
@@ -335,57 +337,57 @@
 			cout << "Unable to open file";
 			exit(1); // terminate with error
 		}else {
             if (verbose_level > 2){
                 std::cout <<  " Opened <" << FileToOpen << ">"<<std::endl;
 		i=0;
         std::string line;
 		//while (! inFile.eof() && ! inFile.fail()) {
         while (1==1) {
             inFile >> x;
             inFile >> y;
                 std::cout << " x: " << x;
                 std::cout << " y: " << y << std::endl;
 			if (i==0){
 				N_nodes=x;
-				M_edges=y;
+				M_edges=y;
                 break;
 			i++;
 		inFile.close();
         if (verbose_level == 2){
             std::cout << N_nodes <<  " nodes, " << M_edges << " edges"<<std::endl;
 		// k_max is the longest distance possible
         //k_max = M_edges;
 		k_max = 70;
 		// Get memory allocated for all class members
 		Prob = allocate_2Dmatrix(N_nodes, N_nodes);
 		Tried = allocate_2Dmatrix(N_nodes, N_nodes);
 		Dist = allocate_2Dmatrix(N_nodes, N_nodes);
 		Final = allocate_2Dmatrix(N_nodes, N_nodes);
         EdgeIndex = allocate_2Dmatrix(N_nodes, N_nodes);
 		Rank = allocate_1Dmatrix(N_nodes);
         //The second pass through file with the graph
 		for(int i = 0; i < N_nodes; ++i) {
 			Rank[i]=0.;
 			for(int j = 0; j < N_nodes; ++j) {
@@ -396,41 +398,41 @@
                 EdgeIndex[i][j]=-1;
 		// Fill in the final graph -- and we are ready to go!
 		if (!inFile) {
             std::cout << "Unable to open file";
 		else {
-		i=0;
+		i=0;
 		while (inFile >> x && inFile >>y) {
 			if (i > 0) {
 				Final[x][y]=1.;
 				Final[y][x]=1.;
                     std::cout << ".";
 			i++;
             std::cout << std::endl;
-		inFile.close();
+		inFile.close();
         k=0;
         for (int i=0; i<N_nodes-1; i++){
             for (int j=i+1;j<N_nodes; j++){
@@ -440,19 +442,19 @@
 		// create graph -- hopefully, we can keep it, just modifying edge weights
 		edge_array_mine = new Edge[2*M_edges];
 		num_arcs_mine = 2*M_edges;
 		num_nodes_mine = N_nodes;
 		weights_mine = new int[2*M_edges];
 		for (int i=0; i<2*M_edges; i++){ weights_mine[i]=1;}
 		k=0;
 		for(int i=0; i<N_nodes-1; i++){
 			for( int j=i+1; j<N_nodes; j++){
@@ -464,17 +466,17 @@
 		graph_t g(edge_array_mine, edge_array_mine + num_arcs_mine, weights_mine, num_nodes_mine);
 		Full_g = g;
 		delete edge_array_mine;
 		delete weights_mine;
 		std::vector<edge_descriptor> p(num_edges(Full_g));
 		std::vector<int> d(num_edges(Full_g));
 		edge_descriptor s;
 		boost::graph_traits<graph_t>::vertex_descriptor u, v;
 			for (int j=i+1; j<N_nodes; j++){
 				if (Final[i][j] > 0.){
@@ -482,103 +484,103 @@
 					v = vertex(j, Full_g);
 					remove_edge(u,v,Full_g);
 					remove_edge(v,u,Full_g);
 	int sample_failed_number(double pfail){
 		//boost::geometric_distribution<double> geo(pfail);
 		//boost::variate_generator<base_generator_type&, geometric_distribution<double> > geom(generator, geo);
 		double r, u, g;
         r=0.;
 		for(int i=0; i<N_steps; i++){
             u=(double)rand();
             u = 1.-u /(double)(pow(2.,31)-1.);
             g=(int)(ceil(log(u) / log(pfail)));
 			//r += geom();
             r+=g;
         if (verbose_level>=3){
             std::cout << id << " failed " << r << std::endl;
 	return (int) round(r);  // FIXME: Andrey: please verify that round() is correct.
     double get_target(void){
         return TargetNovelty;
     void set_target(double target){
         TargetNovelty=target;
 	int sample(){
         //boost::variate_generator<base_generator_type&, boost::uniform_real<> > uni(generator, uni_dist);
         // double r = uni(), Summa = 0.;
         double r = rand(), Summa = 0.;
         r /= (double)(pow(2.,31)-1.);
 		int result = 0;
 		int finished = 0;
         if (verbose_level==4){
             std::cout << id << " sampled " << r << std::endl;
-		for(int i=0; i<N_nodes-1 && finished==0; i++){
+		for(int i=0; i<N_nodes-1 && finished==0; i++){
 			for( int j=i+1; j<N_nodes && finished==0; j++){
 				Summa += Prob[i][j];
 				if (Summa > r){
 					Tried[i][j]+=1.;
 						result = 1;
-					finished = 1;
+					finished = 1;
 		return result;
 	void update_current_graph(void){
 		edge_descriptor s;
 		//property_map<graph_t, edge_weight_t>::type weightmap = get(edge_weight, Full_g);
 				if (Final[i][j] > 0. && Tried[i][j]>0){
-					//s = edge(i, j, Full_g);
+					//s = edge(i, j, Full_g);
 					boost::graph_traits<graph_t>::edge_descriptor e1,e2;
 					bool found1, found2;
 					u = vertex(i, Full_g);
@@ -589,64 +591,64 @@
 						add_edge(u,v,1,Full_g);
 					    add_edge(v,u,1,Full_g);
 	void update_distances(void){
 		// put shortest paths to the *Dist[][]
 		std::vector<vertex_descriptor> p(num_vertices(Full_g));
 		std::vector<int> d(num_vertices(Full_g));
 		vertex_descriptor s;
 		for (int j=0; j<num_vertices(Full_g); j++){
 			if(Rank[j] > 0.){
-				s = vertex(j, Full_g);
+				s = vertex(j, Full_g);
 				dijkstra_shortest_paths(Full_g, s, predecessor_map(&p[0]).distance_map(&d[0]));
 				//std::cout <<" Vertex "<< j << std::endl;
 				graph_traits < graph_t >::vertex_iterator vi, vend;
 				for (boost::tie(vi, vend) = vertices(Full_g); vi != vend; ++vi) {
 					if (p[*vi]!=*vi){
 						Dist[*vi][j]=d[*vi];
 						Dist[j][*vi]=d[*vi];
 						if ( (int)round(Dist[*vi][j]>max_dist)) {
 						  // FIXME: Andrey: please verify that (int) cast is correct. Do we need to round()?
-						  // also, the indent on this iff statement was way off -
+						  // also, the indent on this iff statement was way off -
 						  // perhaps due to space v. tab?
 						  max_dist=(int)round(Dist[*vi][j]);
 					} else {
 						Dist[*vi][j]=-1.;
 						Dist[j][*vi]=-1.;
 	void update_ranks(void){
 		for(int i=0; i<N_nodes; i++){
 			Rank[i]=0.;
 				if (Tried[i][j]>0. && Final[i][j] >0.){
@@ -655,30 +657,30 @@
 	void set_world(double a_i, double a_m, double b, double g, double d){
 		alpha_i=a_i;
 		alpha_m=a_m;
 		gamma=g;
 		beta=b;
 		delta=d;
 	void reset_world(){
 		edge_descriptor s;
 				if (Final[i][j] > 0. && Tried[i][j] > 0){
@@ -686,18 +688,18 @@
 		current_loss=0;
 		current_epoch=0;
 		current_repeat++;
         current_novelty=0;
 			Rank[i]=0.;
@@ -707,28 +709,28 @@
     void show_parameters(void){
-        std::cout << "Parameters: "
+        std::cout << "Parameters: "
         << alpha_i << " "
         << alpha_m << " | "
         << beta << " "
         << gamma << " | "
         << delta << std::endl;
     string file_name(){
-        s << "world_"
-        << lexical_cast<std::string>(alpha_i) << "_"
+        s << "world_"
+        << lexical_cast<std::string>(alpha_i) << "_"
         << lexical_cast<std::string>(alpha_m) << "_"
         << lexical_cast<std::string>(beta) << "_"
         << lexical_cast<std::string>(gamma) << "_"
@@ -736,228 +738,228 @@
         << lexical_cast<std::string>(N_epochs) << "_"
         << lexical_cast<std::string>(N_steps) << "_"
         << lexical_cast<std::string>(N_repeats) << ".txt";
         return s.str();
     void set_verbose(int verbose){
         verbose_level = verbose;
     void update_probabilities(void){
 		// Compute sampling probabilities
 		// first pass: \xi_i,j
 				double bg = 0.;
-				Prob[i][j] = alpha_i*log(min(Rank[i]+1.,Rank[j]+1.)) +
+				Prob[i][j] = alpha_i*log(min(Rank[i]+1.,Rank[j]+1.)) +
                 alpha_m*log(max(Rank[i]+1.,Rank[j]+1.));
                 if (Dist[i][j] > 0.){
                     double k = Dist[i][j];
                     if (k >= k_max){
                         k = k_max-1;
                     bg = beta * log(k/k_max) + gamma * log(1. - k/k_max);
                 } else {
                     bg = delta;
 				Prob[i][j] = exp(Prob[i][j] + bg);
 		// second pass: sum
 		double Summa = 0.;
 		// third pass: normalize
 				Prob[i][j] /= Summa;
 	// Now we are ready for simulations
 	void update_world(){
 		int failed = 0;
 		// Given current universe compute shortest paths
 		update_current_graph();
-		update_ranks();
+		update_ranks();
 		update_distances();
 		update_probabilities();
 		// sampling
 		int result;
 		double cost=0., novel=0.;
 		int publishable = 0;
 		if (mode_identify_failed == 1){
 			while(publishable < N_steps){
 		    	result = sample();
 			    publishable += result;
 			    failed += (1-result);
 					cost+=Tried[i][j];
 					if (Tried[i][j]>0. && Final[i][j]>0.){
 						novel+=1.;
 		else {
 			double pfail=0.;
 			int n_failed;
 			//, n_check = 0;
 					if (Final[i][j] == 0.){
 						pfail += Prob[i][j];
 						Prob[i][j] = 0.;
 					Prob[i][j] /= (1.-pfail);
 				//std::cout << std::endl;
 			n_failed = sample_failed_number(pfail);
 		    	result = sample();
-			    publishable += result;
+			    publishable += result;
 			current_loss += (n_failed + N_steps);
 			cost = current_loss;
 						novel+=1.;
         current_novelty = novel;
-            std::cout << (current_repeat+1) << "  epoch=" << (current_epoch+1)
-		    << "  cost=" << cost
-		    << " novel=" << novel
+            std::cout << (current_repeat+1) << "  epoch=" << (current_epoch+1)
+		    << "  cost=" << cost
+		    << " novel=" << novel
 		    << " rel_loss=" << cost/novel
 		    << std::endl;
 		current_epoch++;
 	//======  Destructor ======
 	~Universe(){
 		delete_2Dmatrix(Final, N_nodes);
 		delete_2Dmatrix(Dist, N_nodes);
 		delete_2Dmatrix(Tried, N_nodes);
 		delete_2Dmatrix(Prob, N_nodes);
         delete_2Dmatrix(EdgeIndex, N_nodes);
-		delete_1Dmatrix(Rank);
+		delete_1Dmatrix(Rank);
     // Allocate memory
     double** allocate_2Dmatrix(int N, int M)
         double **pointer;
             std::cout<< "["<<N<<"|"<<M<<"]"<<std::endl;
         pointer = new double*[N];
         for (int i = 0; i < N; ++i)
-            pointer[i] = new double[M];
+            pointer[i] = new double[M];
         return pointer;
     double* allocate_1Dmatrix(int N)
         double *pointer;
         if(N > 0){
             pointer = new double[N];
         }else {
             pointer = NULL;
         return pointer;
     // De-Allocate memory to prevent memory leak
     void delete_2Dmatrix(double **pointer, int N){
         if (pointer != NULL){
             for (int i = 0; i < N; ++i){
                 delete [] pointer[i];
@@ -966,54 +968,98 @@
     void delete_1Dmatrix(double *pointer){
         delete [] pointer;
     double get_rel_loss(){
         return CumulativeRelativeLoss ;
     double get_rel_loss_err(){
         return CRLsquare ;
     void evolve_to_target_and_save(int istart, int iend, double* storage, int* counters){
-        double ALOT=100000000000.;
+        double ALOT=10000.;
+        int check = 0;
         reset_world();
         for (int k = istart; k < iend; k++){
+// Code for getting time to check
             for(int i=0; i< N_epochs &&  current_novelty < TargetNovelty; i++){
-                update_world();
+// Check the walltime limit
+                if(current_loss/current_novelty < max_loss_value((int)TargetNovelty)){
+                    update_world();
+                else{
+                    check=1;
+                    break;
-            storage[k]=current_loss/current_novelty;
+            if( check ){
+                storage[k]=ALOT;
+            else{
+                storage[k]=current_loss/current_novelty;
             counters[k]=1;
             reset_world();
+    double max_loss_value(int tn){
+        /* Poor check */
+        /* Do not check for equality, check for within some error */
+        if( tn == 58. )           return 128.286;
+        else if( tn == 108. )     return 131.866;
+        else if( tn == 158. )     return 135.551;
+        else if( tn == 208. )     return 139.694;
+        else if( tn == 258. )     return 144.163;
+        else if( tn == 308. )     return 148.967;
+        else if( tn == 358. )     return 154.201;
+        else if( tn == 408. )     return 159.962;
+        else if( tn == 458. )     return 166.441;
+        else if( tn == 508. )     return 173.655;
+        else if( tn == 558. )     return 181.921;
+        else if( tn == 608. )     return 191.246;
+        else if( tn == 658. )     return 202.150;
+        else if( tn == 708. )     return 215.197;
+        else if( tn == 758. )     return 202.150;  // Verify with Andrey. Same as TargetNovelty of 658
+        else if( tn == 808. )     return 251.698;
+        else if( tn == 858. )     return 279.201;
+        else if( tn == 908. )     return 320.112;
+        else if( tn == 958. )     return 394.774;
+        else if( tn == 1008. )    return 1052.38;  // Huge number here. Why?
+        else                      return 10000.;   /* Pray that this does not occur. Ask Andrey what to do */
     int get_reruns(void){
         return N_repeats;
     double get_parameter(int i){
         switch(i){
             case 0:
                 return alpha_i;
@@ -1026,72 +1072,72 @@
             case 4:
                 return delta;
             default:
                 std::cout << "Erroneous parameter id!!!!\n\n\n";
                 return 0.;
     void evolve_to_target(){
         reset_world();
         if (beta < -1. || gamma < -1.){
             CumulativeRelativeLoss = 100000000000.;
             CRLsquare = 0.;
             return;
         for (int k=0; k< N_repeats; k++){
             for(int i=0; i<N_epochs &&  current_novelty < TargetNovelty; i++){
                 update_world();
             CumulativeRelativeLoss += current_loss/current_novelty;
             CRLsquare += (current_loss/current_novelty)*(current_loss/current_novelty);
             if(verbose_level==3){
                 std::cout <<  CumulativeRelativeLoss << " | " << CRLsquare << std::endl;
             if(verbose_level==1){
                 std::cout <<  "." ;
             else if(verbose_level==2){
                 std::cout <<  "**" << (k+1) <<  "**  curr loss " << current_loss << "; curr novelty " << current_novelty << std::endl;
             reset_world();
         CumulativeRelativeLoss /= double(N_repeats);
         CRLsquare /= double(N_repeats);
             std::cout <<  CumulativeRelativeLoss << " || " << CRLsquare << std::endl;
         CRLsquare = 2*sqrt((CRLsquare - CumulativeRelativeLoss*CumulativeRelativeLoss)/double(N_repeats));
     int set_parameter(double value, int position){
         if (position < 0 || position > 4) {return 0;}
         else {
             switch(position){
                 case 0:
                     alpha_i=value;
@@ -1109,17 +1155,17 @@
                     delta=value;
                     return 1;
         return 0;
-#ifdef notdef
+#ifdef notdef
-    void try_annealing(double starting_jump, int iterations,
+    void try_annealing(double starting_jump, int iterations,
                        double temp_start, double temp_end, double target_rejection){
         double dx[5]={0.,0.,0.,0.,0};
         double x[5]={0.,0.,0.,0.,0};
         double rejection[5]={0., 0., 0., 0., 0.};
@@ -1128,41 +1174,41 @@
         double ratio, r;
         int cycle=10;
         // set up parameter for annealing
         x[0]=alpha_i;
         x[1]=alpha_m;
         x[2]=beta;
         x[3]=gamma;
         x[4]=delta;
         for(int i=0;i<5;i++){
             dx[i] = starting_jump;
         // establish the current value
-        evolve_to_target();
+        evolve_to_target();
         std::cout << CumulativeRelativeLoss << " +- " << CRLsquare << std::endl;
         curr_x   = CumulativeRelativeLoss;
         curr_err = CRLsquare;
         CumulativeRelativeLoss = 0;
         CRLsquare = 0;
         // optimization cycle
         for(int i=0; i<iterations; i++){
             temperature = temp_start*exp( i*(log(temp_end)-log(temp_start))/(double)iterations);
             std::cout  << std::endl << "....T = " << wrap_double(temperature,3) << std::endl << std::endl;
             if (i % cycle == 0 && i > 0){
                 for (int k=0; k<5; k++){
                     rejection[k]/=(double)cycle;
                     if (rejection[k] > 0){
                         dx[k] = dx[k]/(rejection[k]/target_rejection);
@@ -1175,104 +1221,104 @@
             for (int j=0; j<5; j++){
                 // get new value of x[j]
                 x_tmp = get_new_x(x[j],dx[j]);
                 set_parameter(x_tmp, j);
                 std::cout  << std::endl << "......... " << std::endl;
                 std::cout << "Trying... " << CumulativeRelativeLoss << " +- " << CRLsquare << std::endl;
                 ratio = min(1.,exp(-(CumulativeRelativeLoss-curr_x)/temperature));
                 r = uni();
                 std::cout << r << " vs " << ratio << std::endl;
                 if (r > ratio){
-                    std::cout << string_wrap(id, 4) <<" "<< (i+1) << ","<< (j)
-                    <<" "<< (i+1) << " Did not accept "
+                    std::cout << string_wrap(id, 4) <<" "<< (i+1) << ","<< (j)
+                    <<" "<< (i+1) << " Did not accept "
                     << x_tmp << "(" << j << ")" << std::endl;
                     std::cout << alpha_i << " "<< alpha_m << " "
-                    << beta << " " << gamma << " "
+                    << beta << " " << gamma << " "
                     << delta << " " << std::endl;
                     set_parameter(x[j], j);
                     CRLsquare = 0;
                     rejection[j]+=1.;
                 else {
                     x[j] = x_tmp;
                     CRLsquare = 0;
-                    std::cout << (i+1) << string_wrap((string) " Rejection counts: ", 8)
-                    << wrap_double(rejection[0],2)
+                    std::cout << (i+1) << string_wrap((string) " Rejection counts: ", 8)
+                    << wrap_double(rejection[0],2)
                     << " "<< wrap_double(rejection[1], 7) << " "
-                    << wrap_double(rejection[2],5) << " " << wrap_double(rejection[2],9) << " "
-                    << wrap_double(rejection[4],6) << " "
+                    << wrap_double(rejection[2],5) << " " << wrap_double(rejection[2],9) << " "
+                    << wrap_double(rejection[4],6) << " "
-                    std::cout << string_wrap(id, 4) <<" "<< (i+1) <<","<< (j)
+                    std::cout << string_wrap(id, 4) <<" "<< (i+1) <<","<< (j)
-                    << string_wrap((string) "***** Did accept! ", 3)
-                    << wrap_double(alpha_i,2)
+                    << string_wrap((string) "***** Did accept! ", 3)
+                    << wrap_double(alpha_i,2)
                     << " "<< wrap_double(alpha_m, 7) << " "
-                    << wrap_double(beta,5) << " "
-                    << wrap_double(gamma,9) << " "
-                    << wrap_double(delta,6) << " "
+                    << wrap_double(beta,5) << " "
+                    << wrap_double(gamma,9) << " "
+                    << wrap_double(delta,6) << " "
 #endif
 #ifdef P_DISPATCH
-std::pair<double,double> multi_loss(dispatch_group_t group,
-                                    Universe* un[],
+std::pair<double,double> multi_loss(dispatch_group_t group,
+                                    Universe* un[],
                                     dispatch_queue_t* CustomQueues,
                                     double* Results,
                                     int*    Counters,
                                     double* params){
 #else
-std::pair<double,double> multi_loss(Universe* un[],
+std::pair<double,double> multi_loss(Universe* un[],
                                     double* Results,
                                     int*    Counters,
                                     double* params){
 #endif
     int N = un[0]->get_reruns();
     int step = (int)floor((double)N/(double)(Nworkers)); // FIXME: Andrey: please check change in cast grouping and use of floor
     int istart=0;
     int iend = istart+step;
     double Loss=0., LossSquare=0.;
     timeval startTime, endTime;
     double elapsedTime;
     gettimeofday(&startTime, NULL);
@@ -1282,20 +1328,20 @@
             un[i]->set_parameter(params[j],j);
-#ifdef P_DISPATCH
+#ifdef P_DISPATCH
     for(int i=0; i<Nworkers; i++){
         dispatch_group_async(group, CustomQueues[i], ^{
             // un[i]->evolve_to_target_and_save(istart, iend, Results, Counters);
             un[i]->evolve_to_target_and_save(i*step, min((i+1)*step,N), Results, Counters);
         std::cout << "queued: i=" << i << " N=" << N << " istart=" << istart << " iend=" << iend << "\n";
         // istart += step;
         // iend = min(istart+step,N);
     dispatch_group_wait(group, DISPATCH_TIME_FOREVER);
     //dispatch_release(group);
@@ -1316,23 +1362,23 @@
 #endif
     for (int i=0; i<N; i++){
         Loss+=Results[i]/(double)N;
         LossSquare+=Results[i]*Results[i]/(double)N;
         // std::cout<<" " << Results[i];
     //std::cout<<" \n\n\n";
     double two_std = ((LossSquare - Loss*Loss)/(double)N);
     two_std = 2.*sqrt(two_std);
     std::pair<double,double> Res;
     Res.first=Loss;
     Res.second=two_std;
     gettimeofday(&endTime, NULL);
     elapsedTime = (endTime.tv_sec - startTime.tv_sec) * 1000.0;      // sec to ms
     elapsedTime += (endTime.tv_usec - startTime.tv_usec) / 1000.0;   // us to ms
@@ -1340,30 +1386,30 @@
     cout << "multi_loss(N=" << N << ", target=" << un[0]->get_target() << ") elapsed time: " << elapsedTime << " seconds " << elapsedTime/60. << " minutes\n\n";
     return Res;
 #ifdef P_DISPATCH
-void multi_annealing( dispatch_group_t group,
-                     Universe* un[],
-                     dispatch_queue_t* CustomQueues,
-                     double T_start, double T_end,
-                     double Target_rejection,
-                     int Annealing_repeats,
+void multi_annealing( dispatch_group_t group,
+                     Universe* un[],
+                     dispatch_queue_t* CustomQueues,
+                     double T_start, double T_end,
+                     double Target_rejection,
+                     int Annealing_repeats,
                      double* Results,
                      int*    Counters,
                      double* params0,
                      double annealing_cycles){
 #else
-void multi_annealing(Universe* un[],
+void multi_annealing(Universe* un[],
                      double* Results,
                      int*    Counters,
@@ -1372,7 +1418,7 @@
 #endif
     // re-implement annealing
@@ -1381,30 +1427,30 @@
     double ratio, r;
     int cycle=10;
     x[0]=params0[0];
     x[1]=params0[1];
     x[2]=params0[2];
     x[3]=params0[3];
     x[4]=params0[4];
     std::pair<double,double>Res;
-#ifdef P_DISPATCH
+#ifdef P_DISPATCH
     Res = multi_loss(group, un, CustomQueues, Results, Counters, x);
 #else
     Res = multi_loss(       un,               Results, Counters, x);
 #endif
     std::cout << "Returned from initial multi_loss:" << std::endl;
     std::cout << Res.first << " +- " << Res.second << std::endl;
     if ( operation == 'm' ) {
       FILE *f;
@@ -1419,19 +1465,19 @@
     curr_x   = Res.first;
     curr_err = Res.second;
     for(int i=0; i<annealing_cycles; i++){
         temperature = T_start*exp( i*(log(T_end)-log(T_start))/(double)annealing_cycles);
                     dx[k] = dx[k]/(rejection[k]/Target_rejection);
                     rejection[k]=0.;
@@ -1443,143 +1489,143 @@
             if (FIX_VARIABLES==0 || var_fixed[j]==0){
                 double x_hold=x[j];
                 x[j]=x_tmp;
-                std::cout << wrap_double(x_tmp,10) << " " << wrap_double(j,9) << "\n\n";
+                std::cout << wrap_double(x_tmp,10) << " " << wrap_double(j,9) << "\n\n";
                 for(int w=0; w<Nworkers; w++){
                     un[w]->set_parameter(x_tmp, j);
-#ifdef P_DISPATCH
+#ifdef P_DISPATCH
 #else
 #endif
                 ratio = min(1.,exp(-(Res.first-curr_x)/temperature));
                 if (Res.first < ALOT)
                     ofstream filestr;
                     filestr.open ("best_opt_some.txt", ofstream::app);
                     // >> i/o operations here <<
                     filestr
 		    << "N, " << i << ", " << j << ", " << dx[j] << ", " << rejection[j] << ", |, " // FIXME: MW-DEBUGGING
-                    << un[0]->get_target() << ", "
-                    << Res.first
-                    << ", " << un[0]->get_parameter(0)
-                    << ", " << un[0]->get_parameter(1)
-                    << ", " << un[0]->get_parameter(2)
-                    << ", " << un[0]->get_parameter(3)
+                    << un[0]->get_target() << ", "
+                    << Res.first
+                    << ", " << un[0]->get_parameter(0)
+                    << ", " << un[0]->get_parameter(1)
+                    << ", " << un[0]->get_parameter(2)
+                    << ", " << un[0]->get_parameter(3)
                     << ", " << un[0]->get_parameter(4) << ", " << Res.second << ",\n";
                     filestr.close();
                     filestr.open ("max_dist.txt", ofstream::app);
                     filestr << max_dist << ",\n";
                     filestr.close();
                     FILE *bf;
                     bf = fopen("bestdb.txt","a");
                     fprintf(bf, "N %2d %2d %10.5f %5.2f | %5.2f %10.5f [ %5.2f %5.2f %10.5f %10.5f %10.5f ] %10.5f\n", i, j, dx[j], rejection[j],
 			    un[0]->get_target(),
-			    Res.first,
-			    un[0]->get_parameter(0),
-			    un[0]->get_parameter(1),
-			    un[0]->get_parameter(2),
+			    Res.first,
+			    un[0]->get_parameter(0),
+			    un[0]->get_parameter(1),
+			    un[0]->get_parameter(2),
 			    un[0]->get_parameter(3),
 			    un[0]->get_parameter(4),
 			    Res.second);
                     fclose(bf);
                 if (r > ratio){
-                    std::cout << " "<< (i+1) << ","<< (j)
+                    std::cout << " "<< (i+1) << ","<< (j)
-                    std::cout << un[0]->get_parameter(0)
-                    << " " << un[0]->get_parameter(1)
-                    << " " << un[0]->get_parameter(2)
-                    << " " << un[0]->get_parameter(3)
+                    std::cout << un[0]->get_parameter(0)
+                    << " " << un[0]->get_parameter(1)
+                    << " " << un[0]->get_parameter(2)
+                    << " " << un[0]->get_parameter(3)
                     << " " << un[0]->get_parameter(4) << " " << std::endl;
                     x[j]=x_hold;
                         un[w]->set_parameter(x[j], j);
-                    //set_parameter(x[j], j);
+                    //set_parameter(x[j], j);
                     rejection[j]+=1.;
                 else {
                     curr_x   = Res.first;
                     x[j] = x_tmp;
-                    << wrap_double(rejection[0],2) << " "
+                    << wrap_double(rejection[0],2) << " "
                     << wrap_double(rejection[1],7) << " "
-                    << wrap_double(rejection[3],9) << " "
+                    << wrap_double(rejection[3],9) << " "
-                    std::cout << " "<< (i+1) <<","<< (j)
+                    std::cout << " "<< (i+1) <<","<< (j)
                     << wrap_double(un[0]->get_parameter(0),2) << " "
                     << wrap_double(un[0]->get_parameter(1),7) << " "
-                    << wrap_double(un[0]->get_parameter(2),5) << " "
-                    << wrap_double(un[0]->get_parameter(3),9) << " "
-                    << wrap_double(un[0]->get_parameter(4),6) << " "
+                    << wrap_double(un[0]->get_parameter(2),5) << " "
+                    << wrap_double(un[0]->get_parameter(3),9) << " "
+                    << wrap_double(un[0]->get_parameter(4),6) << " "
@@ -1588,43 +1634,43 @@
 int
 main(int argc, char* argv[])
     double params0[6] = {0., 0., 0., 0., 0., 0.2}, target=50., range;
     string par_names0[6] = {"alpha_i", "alpha_m", "beta", "gamma", "delta", "target"};
     string par_names1[4] = {"n_epochs", "n_steps", "n_reruns", "range"};
     string par_names2[5] = {"T_start", "T_end", "Annealing_steps","Target_rejection","Starting_jump"};
-    string par_names3[5] = {"FREEZE_alpha_i", "FREEZE_alpha_m", "FREEZE_beta", "FREEZE_gamma", "FREEZE_delta"};
+    string par_names3[5] = {"FREEZE_alpha_i", "FREEZE_alpha_m", "FREEZE_beta", "FREEZE_gamma", "FREEZE_delta"};
     string par_names4[3] = {"Operation", "Nworkers", "initSeed"};
     int params1[4] = {300, 50, 1000, 10};
     int params3[5] = { 0, 0, 0, 0, 0};
     //          temperature_start,  temperature_end,  annealing_steps target_rejection  Starting_jump
     double params2[5] = {1,             0.001,               100,              0.3,           1.5};
     int verbose_level = 2;
     const std::string one="one", two="two";
     static Universe* un[MAXNworkers];
 #ifdef P_DISPATCH
     static dispatch_queue_t CustomQueues[MAXNworkers];
-#endif
+#endif
     static double* Results;
     static int*    Counters;
     timeval t1, t2;
     double elapsedTime;
     // start timer
     gettimeofday(&t1, NULL);
     if (argc < 8) {
-        std::cout << "Usage: super_optimizer alpha_i alpha_m beta gamma delta target_innov [n_epochs n_steps n_reruns] [range] [verbose_level]\n";
-        std::cout << "         [T_start T_end Annealing_steps Target_rejection Starting_jump]\n";
-        std::cout << "         [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta]\n";
+        std::cout << "Usage: super_optimizer alpha_i alpha_m beta gamma delta target_innov [n_epochs n_steps n_reruns] [range] [verbose_level]\n";
+        std::cout << "         [T_start T_end Annealing_steps Target_rejection Starting_jump]\n";
+        std::cout << "         [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta]\n";
         system("pwd");
         return(1);
     else {
@@ -1663,25 +1709,25 @@
                 initSeed = atoi(argv[nArg]);
                 std::cout << par_names4[2] << ": " << initSeed <<  std::endl;
         cout << j << " | " << var_fixed[j] << " (fixed) \n";
     target=params0[5];
     range = (double)params1[3];
 	int identify_failed = 0;
 	char* filename= (char *)"movie_graph.txt";
  	int n_ep=params1[0], n_st=params1[1], n_rep=params1[2];
         un[i] = new Universe((char *)filename,n_ep,n_st,
                              (int)n_rep,
@@ -1690,25 +1736,25 @@
         CustomQueues[i] = dispatch_queue_create(i2char(i), NULL);
 #endif
     if(n_rep > 0){
         Results = new double[n_rep];
         Counters = new int[n_rep];
     }else {
         Results =  NULL;
         Counters = NULL;
         std::cout << " Number of reruns should be positive! " <<  std::endl;
         return 0;
     //srand(time(0));
     //srandomdev();
     if ( initSeed != 0.0 ) {
       srand(initSeed);
@@ -1721,84 +1767,84 @@
         double r=0;
         for (int j=0; j<100; j++){
             std::cout << r << " ";
         std::cout << "\n";
   	//random initiation of starting parameters
     if (range > 0.){
         for (int i=0; i < 5; i++){
             if (params0[i]==-100.){
                 double r1 = (rand()/(double)(pow(2.,31)-1.));
                 double r2 = (rand()/(double)(pow(2.,31)-1.));
                 double sign = 1.;
                 if(r1 > 0.5){
                     sign=-1.;
                 params0[i] = sign*r2*range;
                 std::cout << par_names0[i] << ": " << params0[i] <<  std::endl;
     double T_start=params2[0], T_end=params2[1], Target_rejection=params2[3], starting_jump=params2[4];
     int Annealing_repeats = (int) params2[2];
-#ifdef P_DISPATCH
+#ifdef P_DISPATCH
     dispatch_group_t group = dispatch_group_create();
-    multi_annealing(group, un, CustomQueues, T_start, T_end, Target_rejection, Annealing_repeats,
+    multi_annealing(group, un, CustomQueues, T_start, T_end, Target_rejection, Annealing_repeats,
                     starting_jump, Results, Counters, params0, Annealing_repeats);
     //dispatch_group_wait(group, DISPATCH_TIME_FOREVER);
 #else
-    multi_annealing(       un,                T_start, T_end, Target_rejection, Annealing_repeats,
+    multi_annealing(       un,                T_start, T_end, Target_rejection, Annealing_repeats,
 #endif
     // stop timer
     gettimeofday(&t2, NULL);
     // compute and print the elapsed time in millisec
     elapsedTime = (t2.tv_sec - t1.tv_sec) * 1000.0;      // sec to ms
     elapsedTime += (t2.tv_usec - t1.tv_usec) / 1000.0;   // us to ms
     elapsedTime /= 1000.;
     cout << "\n*** optimizer completed, elapsed time=" << elapsedTime << " seconds " << elapsedTime/60. << " minutes)\n\n";
         delete un[i];
     if(n_rep > 0){
         delete [] Results;
         delete [] Counters;
     return 0;
