[Swift-commit] r5703 - trunk/src/org/griphyn/vdl/engine
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Thu Mar 1 14:22:58 CST 2012
Author: jonmon
Date: 2012-03-01 14:22:58 -0600 (Thu, 01 Mar 2012)
New Revision: 5703
Modified:
   trunk/src/org/griphyn/vdl/engine/Karajan.java
Log:
o The deprecated function message is no longer printed, the code however marking functions as deprecated has been left in tact.
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java	2012-03-01 20:15:12 UTC (rev 5702)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java	2012-03-01 20:22:58 UTC (rev 5703)
@@ -31,7 +31,6 @@
 import java.util.List;
 import java.util.Map;
 import java.util.Set;
-import java.util.StringTokenizer;
 import javax.xml.namespace.QName;
@@ -670,7 +669,7 @@
 			ProcedureSignature proc = proceduresMap.get(procName);
 			if (proc.isDeprecated()) {
-			    warn(call, "Procedure " + procName + " is deprecated");
+			    /* warn(call, "Procedure " + procName + " is deprecated"); */
 			StringTemplate callST;
