[Swift-commit] r5701 - branches/release-0.93/docs/userguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Mar 1 11:37:45 CST 2012
Author: ketan
Date: 2012-03-01 11:37:45 -0600 (Thu, 01 Mar 2012)
New Revision: 5701
Modified:
   branches/release-0.93/docs/userguide/faq
Log:
answered faq
Modified: branches/release-0.93/docs/userguide/faq
--- branches/release-0.93/docs/userguide/faq	2012-03-01 17:22:06 UTC (rev 5700)
+++ branches/release-0.93/docs/userguide/faq	2012-03-01 17:37:45 UTC (rev 5701)
@@ -2,21 +2,37 @@
 Q1. What is Swift?
+A1. It is a parallel scripting framework for HPC and distributed computing.
-Q2. Does it have nested foreach?
+Q2. Does Swift have nested foreach?
+A2. Yes.
 Q3. What is the learning curve like?
+A3. If you can read/write basic C/C++ and some UNIX, the curve is on the better side of hikeable.
 Q4. What if my execution fails?
+A4. You could get an idea of what went wrong from the Swift stdout/stderr or from the Swift log. If all else fails, write to swift team.
 Q5. What if the remote node on which I am running fails?
+A5. Depending upon your retry settings the failed jobs from that failed node will be rescheduled on other working nodes.
 Q6. How do I know if my service is running?
+A6. ps -u `whoami` | grep coaster
 Q7. What if I submit a Swift run from my laptop and shut down the laptop?
+A7. The run will stop. You may resume this run from the point it stopped upon restart. A better option would be to run swift from a node expected to be up. For example a login node or a cluster node.
-Q8. How do I run parallell and serial jobs together?
+Q8. How do I run parallel and serial jobs together?
+A8. By designating separate site pools for each of them.
 Q9. What kind of data movements are allowed?
+A9. Any kind of data movement that could be done via local, ssh, tcp, http or gridftp protocols are allowed.
 Q10. Can Swift run interactive programs?
+A10. No, per se. The interactive inputs could be loaded on a file and fed to swift from commandline or using a wrapper script around your application.
+Q11. How can you run two statements in sequence when there is a data dependency between them? I do not see a wait() statement in between?
+A11. Write once future variables enable asynchronous execution.
+Q12. What are coasters?
+A12. Coasters are pilot-job like mechanism available with Swift. Essentially a client server mechanism for many-task coordination.
