[Swift-commit] cog r3423
swift at ci.uchicago.edu swift at ci.uchicago.edu
Wed Jun 13 11:55:03 CDT 2012
r3423 | hategan | 2012-06-13 11:54:00 -0500 (Wed, 13 Jun 2012) | 1 line
fixed deadlock (some unnecessary sync) and re-added logging statements to log site scores (used by the TUI)
Index: modules/karajan/src/org/globus/cog/karajan/scheduler/WeightedHostSet.java
--- modules/karajan/src/org/globus/cog/karajan/scheduler/WeightedHostSet.java	(revision 3422)
+++ modules/karajan/src/org/globus/cog/karajan/scheduler/WeightedHostSet.java	(working copy)
@@ -61,6 +61,24 @@
 			checkOverloaded(wh);
+	public double factorScore(WeightedHost wh, double factor) {
+		synchronized (scores) {
+			scores.remove(wh);
+			sum -= wh.getTScore();
+			double newScore = factor(wh.getScore(), factor);
+			wh.setScore(newScore);
+			weightedHosts.put(wh.getHost(), wh);
+			scores.add(wh);
+			sum += wh.getTScore();
+			checkOverloaded(wh);
+			return newScore;
+	protected final double factor(double score, double factor) {
+		return score + factor;
 	public void changeLoad(WeightedHost wh, int dl) {
 		wh.changeLoad(dl);
Index: modules/karajan/src/org/globus/cog/karajan/scheduler/WeightedHostScoreScheduler.java
--- modules/karajan/src/org/globus/cog/karajan/scheduler/WeightedHostScoreScheduler.java	(revision 3422)
+++ modules/karajan/src/org/globus/cog/karajan/scheduler/WeightedHostScoreScheduler.java	(working copy)
@@ -140,13 +140,12 @@
 	    return sorted;
-	protected synchronized void factorScore(WeightedHost wh, double factor) {
-		double score = wh.getScore();
+	protected void factorScore(WeightedHost wh, double factor) {
 		if (logger.isDebugEnabled()) {
 			logger.debug("multiplyScore(" + wh + ", " + factor + ")");
-		double ns = factor(score, factor);
-		sorted.changeScore(wh, ns);
+		double score = wh.getScore();
+		double ns = sorted.factorScore(wh, factor);
 			logger.debug("Old score: " + WeightedHost.D4.format(score) + ", new score: "
 					+ WeightedHost.D4.format(ns));
@@ -160,10 +159,6 @@
 		wh.setDelayedDelta(wh.getDelayedDelta() + factor);
-	protected final double factor(double score, double factor) {
-		return score + factor;
 	protected synchronized BoundContact getNextContact(TaskConstraints t)
 			throws NoFreeResourceException {
 		checkGlobalLoadConditions();
@@ -204,14 +199,17 @@
 			throw new NoFreeResourceException();
 		else if (s.size() == 1) {
-			selected = (WeightedHost) s.iterator().next();
+			selected = s.iterator().next();
+			if (logger.isInfoEnabled()) {
+				logger.info("Sorted: " + s);
 		else {
 			double sum = s.getSum();
 			if (policy == POLICY_WEIGHTED_RANDOM) {
 				double rand = Math.random() * sum;
-				if (logger.isDebugEnabled() && !s.isEmpty()) {
-					logger.debug("Sorted: " + s);
+				if (logger.isInfoEnabled() && !s.isEmpty()) {
 					logger.debug("Rand: " + rand + ", sum: " + sum);
