[Swift-commit] r5810 - trunk/tests/functions
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon Jun 11 12:43:58 CDT 2012
Author: davidk
Date: 2012-06-11 12:43:58 -0500 (Mon, 11 Jun 2012)
New Revision: 5810
Removed:
   trunk/tests/functions/swift.properties
Log:
use default swift.properties for swift function tests
Deleted: trunk/tests/functions/swift.properties
--- trunk/tests/functions/swift.properties	2012-06-10 05:10:52 UTC (rev 5809)
+++ trunk/tests/functions/swift.properties	2012-06-11 17:43:58 UTC (rev 5810)
@@ -1,353 +0,0 @@
-sites.file=${swift.home}/etc/sites.xml
-tc.file=${swift.home}/etc/tc.data
-# The host name of the submit machine is used by GRAM as a callback
-# address to report the status of submitted jobs. In general, Swift
-# can automatically detect the host name of the local machine.
-# However, if the machine host name is improperly configured or if
-# it does not represent a valid DNS entry, certain services (such as
-# GRAM) will not be able to send job status notifications back to
-# the client. The value of this property can be an IP address.
-# Format:
-#    hostname=string
-#hostname=localhost
-# A TCP port range can be specified to restrict the ports on which GRAM
-# callback services are started. This is likely needed if your submit
-# host is behind a firewall, in which case the firewall should be
-# configured to allow incoming connections on ports in the range.
-# Format:
-#     tcp.port.range=start,end
-#tcp.port.range=50000,50100
-# false	- means an error will be immediately reported and cause the
-# 		workflow to abort. At this time remote jobs that are already
-#		running will not be canceled
-# true	- means that Swift will try to do as much work as possible and
-#		report all errors encountered at the end. However, "errors"
-#		here only applies to job execution errors. Certain errors
-#		that are related to the Swift implementation (should such
-#		errors occur) will still be reported eagerly.
-# Default: false
-lazy.errors=false
-# What algorithm to use for caching of remote files. LRU (as in what
-# files to purge) is the only implementation right now. One can set
-# a target size (in bytes) for a host by using the swift:storagesize
-# profile for a host in sites.xml
-# Default: LRU
-caching.algorithm=LRU
-# true       - generate a provenance graph in .dot format (Swift will
-#			 choose a random file name)
-# false      - do not generate a provenance graph
-# <filename> - generate a provenange graph in the give file name
-# Default: false
-pgraph=false
-# graph properties for the provenance graph (.dot specific)
-# Default: splines="compound", rankdir="TB"
-pgraph.graph.options=splines="compound", rankdir="TB"
-# node properties for the provenance graph (.dot specific)
-# Default: color="seagreen", style="filled"
-pgraph.node.options=color="seagreen", style="filled"
-# true	- clustering of small jobs is enabled. Clustering works in the
-#       following way: If a job is clusterable (meaning that it has the
-#       GLOBUS::maxwalltime profile specified in tc.data and its value
-#       is less than the value of the "clustering.min.time" property) it will
-#       be put in a clustering queue. The queue is processed at intervals
-#       specified by the "clustering.queue.delay" property. The processing
-#       of the clustering queue consists of selecting compatible jobs and
-#		grouping them in clusters whose max wall time does not exceed twice
-#       the value of the "clustering.min.time" property. Two or more jobs are
-#       considered compatible if they share the same site and do not have
-#       conflicting profiles (e.g. different values for the same environment
-#       variable).
-# false	- clustering of small jobs is disabled.
-# Default: false
-clustering.enabled=false
-# <seconds>	- the intervals at which the clustering queue is processed
-# Default: 4
-clustering.queue.delay=4
-# <seconds>	- the threshold time for clustering
-# Default: 60
-clustering.min.time=60
-# Kickstart is a useful tool that can be used to gather various information
-# about a remote process. Before it can be used it must be installed on the
-# remote site and the corresponding entry be set in the sites file.
-# This option allows controlling of how Swift uses Kickstart. The following
-# values are possible:
-# false - do not use Kickstart
-# true  - use Kickstart. If a job is scheduled on a site that does not have
-#       Kickstart installed, that job will fail.
-# maybe - Use Kickstart if installed (i.e. the entry is present in the sites
-#       file)
-# Default: maybe
-kickstart.enabled=maybe
-# Indicates when Kickstart records should be fetched from the remote site:
-# true	- always transfer Kickstart records if Kickstart was used (see
-#		kickstart.enabled)
-# false	- only transfer Kickstart records if the job fails
-# Default: false
-kickstart.always.transfer=false
-# Indicates when wrapper logs should be fetched from the remote site:
-# true	- always transfer wrapper logs
-# false	- only transfer wrapper logs if the job fails
-# Default: false
-wrapperlog.always.transfer=false
-#                          Throttling options                             #
-# For the throttling parameters, valid values are either a positive integer
-# or "off" (without the quotes).
-# Limits the number of concurrent submissions for a workflow instance. This
-# throttle only limits the number of concurrent tasks (jobs) that are being
-# sent to sites, not the total number of concurrent jobs that can be run.
-# The submission stage in GRAM is one of the most CPU expensive stages (due
-# mostly to the mutual authentication and delegation). Having too many
-# concurrent submissions can overload either or both the submit host CPU
-# and the remote host/head node causing degraded performance.
-# Default: 4
-throttle.submit=4
-#throttle.submit=off
-# Limits the number of concurrent submissions for any of the sites Swift will
-# try to send jobs to. In other words it guarantees that no more than the
-# value of this throttle jobs sent to any site will be concurrently in a state
-# of being submitted.
-# Default: 2
-throttle.host.submit=100
-#throttle.host.submit=off
-# The Swift scheduler has the ability to limit the number of concurrent jobs
-# allowed on a site based on the performance history of that site. Each site
-# is assigned a score (initially 1), which can increase or decrease based
-# on whether the site yields successful or faulty job runs. The score for a
-# site can take values in the (0.1, 100) interval. The number of allowed jobs
-# is calculated using the following formula:
-# 	2 + score*throttle.score.job.factor
-# This means a site will always be allowed at least two concurrent jobs and
-# at most 2 + 100*throttle.score.job.factor. With a default of 4 this means
-# at least 2 jobs and at most 402.
-# Default: 4
-throttle.score.job.factor=4
-#throttle.score.job.factor=off
-# Limits the total number of concurrent file transfers that can happen at any
-# given time. File transfers consume bandwidth. Too many concurrent transfers
-# can cause the network to be overloaded preventing various other signalling
-# traffic from flowing properly.
-# Default: 4
-throttle.transfers=4
-#throttle.transfers=off
-# Limits the total number of concurrent file operations that can happen at any
-# given time. File operations (like transfers) require an exclusive connection
-# to a site. These connections can be expensive to establish. A large number
-# of concurrent file operations may cause Swift to attempt to establish many
-# such expensive connections to various sites. Limiting the number of concurrent
-# file operations causes Swift to use a small number of cached connections and
-# achieve better overall performance.
-# Default: 8
-throttle.file.operations=8
-#throttle.file.operations=off
-# Indicates whether the working directory on the remote site should be
-# left intact even when the workflow completes successfully. This can be
-# used to inspect the site working directory for debugging purposes.
-# Default: false
-sitedir.keep=false
-# number of time a job will be retried if it fails (giving a maximum of
-# 1 + execution.retries attempts at execution)
-execution.retries=2
-# Enables/disables replication. Replication is used to deal with jobs sitting
-# in batch queues for abnormally large amounts of time. If replication is enabled
-# and certain conditions are met, Swift creates and submits replicas of jobs, and
-# allows multiple instances of a job to compete.
-replication.enabled=false
-# If replication is enabled, this value specifies the minimum time, in seconds,
-# a job needs to be queued in a batch queue in order to be considered for
-# replication
-replication.min.queue.time=60
-# The maximum number of replicas that Swift should attempt.
-replication.limit=3
-# WARNING: This option is deprecated. Please use the hostname option.
-# The IP address of the submit machine is used by GRAM as a callback
-# can automatically detect the IP address of the local machine.
-# However, if the machine has more than one network interface, Swift
-# will pick the first one, which may not be the right choice. It is
-# recommended that this property is set properly before attempting to
-# run jobs through GRAM.
-# Format:
-#    ip.address=x.y.z.w
-#ip.address=127.0.0.1
-# Controls how Swift will communicate the result code of running user programs
-# from workers to the submit side. In files mode, a file
-# indicating success or failure will be created on the site shared filesystem.
-# In provider mode, the execution provider job status will
-# be used. Notably, GRAM2 does not return job statuses correctly, and so
-# provider mode will not work with GRAM2. With other
-# providers, it can be used to reduce the amount of filesystem access compared
-# to files mode.
-# status.mode=files
-# Controls how swift will supply parameters to the remote wrapper script.
-# 'args' mode will pass parameters on the command line
-# 'files' mode will pass parameters through an additional input file
-# valid values: args, files
-# Default: files
-# wrapper.parameter.mode=args
-# Determines if Swift remote wrappers will be executed by specifying an
-# absolute path, or a path relative to the job initial working directory
-# valid values: absolute, relative
-# wrapper.invocation.mode=absolute
-# Limits the number of concurrent iterations that each foreach statement
-# can have at one time. This conserves memory for swift programs that
-# have large numbers of iterations (which would otherwise all be executed
-# in parallel).
-# Default: 1024
-foreach.max.threads=16384
-# controls whether the log file will contain provenance information
-# enabling this will increase the size of log files, sometimes
-# significantly.
-provenance.log=false
-# Controls whether file staging is done by swift or by the execution
-# provider. If set to false, the standard swift staging mechanism is
-# used. If set to true, swift does not stage files. Instead, the
-# execution provider is instructed to stage files in and out.
-# Provider staging is experimental.
-# When enabled, and when coasters are used as an execution provider,
-# a staging mechanism can be selected for each site
-# using the swift:stagingMethod site profile in sites.xml. The
-# following is a list of accepted mechanisms:
-# * file:  Staging is done from a filesystem accessible to the
-#          coaster service (typically running on the head node)
-# * proxy: Staging is done from a filesystem accessible to the
-#          client machine that swift is running on, and is proxied
-#          through the coaster service
-# * sfs:   (short for "shared filesystem") Staging is done by
-#          copying files to and from a filesystem accessible
-#          by the compute node (such as an NFS or GPFS mount).
-use.provider.staging=false
-provider.staging.pin.swiftfiles=false
