[Swift-commit] r5834 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Jul 14 19:01:19 CDT 2012
Author: hategan
Date: 2012-07-14 19:01:19 -0500 (Sat, 14 Jul 2012)
New Revision: 5834
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
   trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
Log:
nicer toString (in particular for traces)
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java	2012-07-15 00:00:00 UTC (rev 5833)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java	2012-07-15 00:01:19 UTC (rev 5834)
@@ -44,6 +44,8 @@
 	static {
 		setArguments(SetFieldValue.class, new Arg[] { OA_PATH, PA_VAR, PA_VALUE });
+	private String src, dest;
 	public Object function(VariableStack stack) throws ExecutionException {
 		DSHandle var = (DSHandle) PA_VAR.getValue(stack);
@@ -52,6 +54,11 @@
 			DSHandle leaf = var.getField(path);
 			AbstractDataNode value = (AbstractDataNode) PA_VALUE.getValue(stack);
+			if (src == null) {
+			    dest = getVarName(var);
+			    src = getVarName(value);
 			log(leaf, value);
             // TODO want to do a type check here, for runtime type checking
@@ -72,7 +79,17 @@
-	@SuppressWarnings("unchecked")
+	private String getVarName(DSHandle var) {
+	    String name = var.getRoot().getParam("dbgname");
+        if (var == var.getRoot()) {
+            return name;
+        else {
+            return name + var.getPathFromRoot();
+    @SuppressWarnings("unchecked")
     private void log(DSHandle leaf, DSHandle value) {
 	    if (logger.isDebugEnabled()) {
 	        logger.debug("Setting " + leaf + " to " + value);
@@ -194,4 +211,12 @@
+    @Override
+    public String getTextualName() {
+            return "assignment";
+        else {
+            return dest + " = " + src;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2012-07-15 00:00:00 UTC (rev 5833)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2012-07-15 00:01:19 UTC (rev 5834)
@@ -182,8 +182,13 @@
 			throws VariableNotFoundException {
 		return (ThreadCount) stack.getVar(THREAD_COUNT);
+	@Override
+        return "foreach";
-	private static class ThreadCount implements FutureIterator {
+    private static class ThreadCount implements FutureIterator {
 		private int maxThreadCount;
 		private int crt;
 		private boolean selfClose, closed;
