[Swift-commit] Cog update
swift at ci.uchicago.edu swift at ci.uchicago.edu
Sat Jan 21 20:00:04 CST 2012
r3352 | hategan | 2012-01-21 19:58:57 -0600 (Sat, 21 Jan 2012) | 1 line
use properties for figuring out what ssh executable to use
Index: modules/provider-ssh/src/org/globus/cog/abstraction/impl/sshcl/execution/JobSubmissionTaskHandler.java
--- modules/provider-ssh/src/org/globus/cog/abstraction/impl/sshcl/execution/JobSubmissionTaskHandler.java	(revision 3351)
+++ modules/provider-ssh/src/org/globus/cog/abstraction/impl/sshcl/execution/JobSubmissionTaskHandler.java	(working copy)
@@ -15,21 +15,37 @@
 import java.io.PrintStream;
 import java.util.ArrayList;
 import java.util.List;
+import java.util.Properties;
+import org.apache.log4j.Logger;
 import org.globus.cog.abstraction.impl.common.task.TaskSubmissionException;
 import org.globus.cog.abstraction.interfaces.JobSpecification;
 import org.globus.cog.abstraction.interfaces.Service;
 public class JobSubmissionTaskHandler extends org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler {
+    public static final Logger logger = Logger.getLogger(JobSubmissionTaskHandler.class);
+    private static Properties props;
+    private synchronized static Properties getProperties() {
+        if (props == null) {
+            props = new Properties();
+            try {
+                ClassLoader cl = JobSubmissionTaskHandler.class.getClassLoader();
+                props.load(cl.getResourceAsStream("provider-sshcl.properties"));
+            catch (Exception e) {
+                logger.warn("Failed to load properties", e);
+        return props;
     protected List<String> buildCmdArray(JobSpecification spec) {
         Service service = getTask().getService(0);
-        String ssh = (String) getTask().getAttribute("ssh");
-        if (ssh == null) {
-            ssh = "ssh";
+        String ssh = getProperties().getProperty("ssh", "ssh");
         List<String> cmdarray = new ArrayList<String>();
         cmdarray.add(ssh);
