[Swift-commit] Cog update
swift at ci.uchicago.edu swift at ci.uchicago.edu
Wed Jan 11 12:50:06 CST 2012
r3344 | jmwozniak | 2012-01-11 12:49:37 -0600 (Wed, 11 Jan 2012) | 2 lines
Restore localscheduler call to validate()
Index: modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/cobalt/CobaltExecutor.java
--- modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/cobalt/CobaltExecutor.java	(revision 3343)
+++ modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/cobalt/CobaltExecutor.java	(working copy)
@@ -23,7 +23,6 @@
 import org.globus.cog.abstraction.impl.scheduler.common.AbstractProperties;
 import org.globus.cog.abstraction.impl.scheduler.common.AbstractQueuePoller;
 import org.globus.cog.abstraction.impl.scheduler.common.Job;
-import org.globus.cog.abstraction.impl.scheduler.common.ProcessException;
 import org.globus.cog.abstraction.impl.scheduler.common.ProcessListener;
 import org.globus.cog.abstraction.interfaces.FileLocation;
 import org.globus.cog.abstraction.interfaces.JobSpecification;
@@ -32,8 +31,8 @@
 public class CobaltExecutor extends AbstractExecutor {
 	public static final Logger logger = Logger.getLogger(CobaltExecutor.class);
-	private String cqsub;
-	private Pattern exitcodeRegexp;
+	private final String cqsub;
+	private final Pattern exitcodeRegexp;
 	private static final String[] EMPTY_STRING_ARRAY = new String[0];
@@ -45,7 +44,7 @@
 	@Override
-    protected void validate(Task task) throws ProcessException {
+    protected void validate(Task task) {
 	    JobSpecification spec = (JobSpecification) task.getSpecification();
 	    if (spec.getAttribute("alcfbgpnat") != null) {
             spec.addEnvironmentVariable("ZOID_ENABLE_NAT", "true");
@@ -53,24 +52,32 @@
         super.validate(task);
-    protected Job createJob(String jobid, String stdout,
-			FileLocation stdOutputLocation, String stderr,
-			FileLocation stdErrorLocation, String exitcode,
-			AbstractExecutor executor) {
-		return new CobaltJob(jobid, stdout, stderr, getSpec().getStdOutput(), stdOutputLocation,
-				getSpec().getStdError(), stdErrorLocation, exitcodeRegexp, this);
+    @Override
+	protected Job createJob(String jobid,
+                            String stdout,
+                            FileLocation stdOutputLocation,
+                            String stderr,
+                            FileLocation stdErrorLocation,
+                            String exitcode,
+                            AbstractExecutor executor) {
+		return new CobaltJob(jobid, stdout, stderr,
+		                     getSpec().getStdOutput(),
+		                     stdOutputLocation,
+		                     getSpec().getStdError(),
+		                     stdErrorLocation, exitcodeRegexp, this);
+	@Override
 	protected String getName() {
 		return "Cobalt";
+	@Override
 	protected AbstractProperties getProperties() {
 		return Properties.getProperties();
+	@Override
 	protected void writeScript(Writer wr, String exitcode, String stdout,
 			String stderr) throws IOException {
@@ -112,6 +119,7 @@
+	@Override
 	protected String[] buildCommandLine(File jobdir, File script,
 			String exitcode, String stdout, String stderr) throws IOException {
 		List<String> result = new ArrayList<String>();
@@ -157,6 +165,7 @@
 		return result.toArray(EMPTY_STRING_ARRAY);
+	@Override
 	protected String quote(String s) {
 		boolean quotes = false;
 		if (s.indexOf(' ') != -1) {
@@ -180,6 +189,7 @@
 		return sb.toString();
+	@Override
 	protected void cleanup() {
 		super.cleanup();
 		new File(getStdout()).delete();
@@ -188,6 +198,7 @@
 	private static AbstractQueuePoller poller;
+	@Override
 	protected AbstractQueuePoller getQueuePoller() {
 		synchronized(CobaltExecutor.class) {
 			if (poller == null) {
Index: modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/common/AbstractExecutor.java
--- modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/common/AbstractExecutor.java	(revision 3343)
+++ modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/common/AbstractExecutor.java	(working copy)
@@ -26,7 +26,6 @@
 import org.globus.cog.abstraction.interfaces.Task;
 import org.globus.gsi.gssapi.auth.AuthorizationException;
-import org.ietf.jgss.GSSException;
  *   Set log level to DEBUG to not delete generated submit script
@@ -59,11 +58,12 @@
         this.task = task;
         this.spec = (JobSpecification) task.getSpecification();
         this.listener = listener;
+        validate(task);
-    public void start()
-    throws AuthorizationException, IOException, ProcessException {
+    public void start()
+    throws AuthorizationException, IOException, ProcessException {
     	File scriptdir = new File(System.getProperty("user.home")
                 + File.separatorChar + ".globus" + File.separatorChar
                 + "scripts");
@@ -163,9 +163,9 @@
-            String exitcode, String stdout, String stderr)
+            String exitcode, String stdout, String stderr)
         writeScript(new BufferedWriter(new FileWriter(script)), exitcode,
             stdout, stderr);
         if (logger.isDebugEnabled()) {
@@ -216,8 +216,12 @@
             throw new TaskSubmissionException("Failed to cancel task", e);
+       Overriding methods may perform miscellaneous Task
+       processing here
     protected abstract AbstractProperties getProperties();
@@ -259,7 +263,7 @@
     protected abstract void writeScript(Writer wr, String exitcode,
-                                        String stdout, String stderr)
+                                        String stdout, String stderr)
     throws IOException;
     protected JobSpecification getSpec() {
@@ -283,39 +287,45 @@
-    public void processCompleted(int exitCode) {
+    @Override
+	public void processCompleted(int exitCode) {
         cleanup();
         if (listener != null) {
             listener.processCompleted(exitCode);
-    public void processFailed(String message) {
+    @Override
+	public void processFailed(String message) {
         cleanup();
             listener.processFailed(message);
-    public void statusChanged(int status) {
+    @Override
+	public void statusChanged(int status) {
             listener.statusChanged(status);
-    public void stderrUpdated(String stderr) {
+    @Override
+	public void stderrUpdated(String stderr) {
             listener.stderrUpdated(stderr);
-    public void stdoutUpdated(String stdout) {
+    @Override
+	public void stdoutUpdated(String stdout) {
             listener.stdoutUpdated(stdout);
-    public void processFailed(Exception e) {
+    @Override
+	public void processFailed(Exception e) {
         cleanup();
             listener.processFailed(e);
