[Swift-commit] r5517 - provenancedb
lgadelha at ci.uchicago.edu lgadelha at ci.uchicago.edu
Tue Jan 24 12:38:35 CST 2012
Author: lgadelha
Date: 2012-01-24 12:38:35 -0600 (Tue, 24 Jan 2012)
New Revision: 5517
Added:
   provenancedb/SPQL.g
Modified:
   provenancedb/prov-init.sql
Log:
Minor changes
Added: provenancedb/SPQL.g
--- provenancedb/SPQL.g	                        (rev 0)
+++ provenancedb/SPQL.g	2012-01-24 18:38:35 UTC (rev 5517)
@@ -0,0 +1,743 @@
+grammar ProvSQL;
+ at header {
+	import java.util.HashSet;
+	import java.util.HashMap;
+	import java.util.Iterator;
+	import org.jgrapht.*;
+	import org.jgrapht.alg.DijkstraShortestPath;
+	import org.jgrapht.graph.*;
+ at members {
+	String selectClause = new String();
+	String fromClause = new String();
+	String whereClauseJoinExpressions = new String();
+	String whereClause = new String();
+	boolean hasWhereJoinExpression;
+	boolean hasWhereExpression = false;
+	static boolean hasCompareRunCall = false;
+	HashSet<String> relations = new HashSet<String>();
+	UndirectedGraph<String,DefaultEdge> schemaGraph;
+	HashSet<DefaultEdge> joinEdges;
+	static HashSet<String> compareRunParams = new HashSet<String>();;
+	// Ideally it could receive a DB schema in SQL and build the graph automatically
+	public static UndirectedGraph<String,DefaultEdge> buildGraph() {
+		UndirectedGraph<String,DefaultEdge> schemaGraph = new Multigraph<String,DefaultEdge>(DefaultEdge.class);
+		schemaGraph.addVertex("annotation");
+		schemaGraph.addVertex("script_run");
+		schemaGraph.addVertex("function_call");
+		schemaGraph.addVertex("variable");
+		schemaGraph.addVertex("application_execution");
+		schemaGraph.addVertex("runtime_info");
+		schemaGraph.addVertex("contains");
+		schemaGraph.addVertex("produces");
+		schemaGraph.addVertex("consumes");
+		schemaGraph.addVertex("compare_run");
+		schemaGraph.addEdge("annotation", "script_run");
+		schemaGraph.addEdge("annotation", "function_call");
+		schemaGraph.addEdge("annotation", "variable");
+		schemaGraph.addEdge("script_run", "function_call");
+		schemaGraph.addEdge("function_call", "consumes");
+		schemaGraph.addEdge("function_call", "produces");
+		schemaGraph.addEdge("function_call", "application_execution");
+		schemaGraph.addEdge("application_execution", "runtime_info");
+		schemaGraph.addEdge("variable", "variable_containment");
+		schemaGraph.addEdge("variable", "consumes");
+		schemaGraph.addEdge("variable", "produces");
+		return schemaGraph;
+	private static HashSet<DefaultEdge> computeJoinEdges(
+			UndirectedGraph<String, DefaultEdge> schemaGraph,
+			HashSet<String> relations) {
+		HashSet<DefaultEdge> jEdges = new HashSet<DefaultEdge>();
+		Iterator<String> i = relations.iterator();
+		String first = new String();
+		if(i.hasNext())
+			first += i.next();
+		while(i.hasNext()) {
+			DijkstraShortestPath<String, DefaultEdge> sP = new DijkstraShortestPath<String, DefaultEdge>(schemaGraph, first, i.next());
+			Iterator<DefaultEdge> j = (sP.getPathEdgeList()).iterator();
+			while(j.hasNext())
+				jEdges.add(j.next());
+		return jEdges;
+	public static String computeFrom(UndirectedGraph<String,DefaultEdge> schemaGraph, HashSet<DefaultEdge> joinEdges, HashSet<String> qrels) {
+		HashSet<String> fromRels = new HashSet<String>();
+		String fromq = " FROM ";
+		Iterator<DefaultEdge> i = joinEdges.iterator();
+		Iterator<String> k = qrels.iterator();
+		if(qrels.size() == 1)
+			fromRels.add(k.next());
+		else
+				DefaultEdge aux = i.next();
+				// If ds_in or ds_out were not in the original select clause's relations and they are on the the joinEdges
+				// then one has to make sure that both consumed and produced datasets are considered in the join so there
+				// is no loss of information. One alternative, implemented here, is to replace these occurrences by the ds
+				// view, which is an union of ds_in and ds_out.
+				if(qrels.contains("produces") || qrels.contains("consumes")) {
+					fromRels.add(schemaGraph.getEdgeSource(aux));
+					fromRels.add(schemaGraph.getEdgeTarget(aux));
+				else {
+					if(aux.equals(schemaGraph.getEdge("consumes","function_call")) ||
+							aux.equals(schemaGraph.getEdge("consumes","variable")) ||
+							aux.equals(schemaGraph.getEdge("produces","function_call")) ||
+							aux.equals(schemaGraph.getEdge("produces","variable"))) {
+						fromRels.add("variable");
+						fromRels.add("ds_use");
+						fromRels.add("function_call");
+					else {
+		Iterator<String> j = fromRels.iterator();
+		if(j.hasNext())
+			fromq += j.next();
+			fromq += "," + j.next();
+		if(hasCompareRunCall) {
+			if(fromRels.size() > 0)
+				fromq += ",";
+			fromq += "(" + computeCompareRunQuery(compareRunParams) + ") AS compare_run";
+		return fromq;
+	public static String computeJoinExpressions(UndirectedGraph<String,DefaultEdge> schemaGraph, HashSet<DefaultEdge> jEdges, HashSet<String> qrels) {
+		HashMap<DefaultEdge,String> joinExpressions = new HashMap<DefaultEdge, String>();
+		String joinExpressionsString = new String();
+		joinExpressions.put(schemaGraph.getEdge("annotation", "script_run"), "annotation.script_run_id=script_run.id");
+		joinExpressions.put(schemaGraph.getEdge("script_run", "function_call"), "script_run.id=function_call.script_run_id");
+		joinExpressions.put(schemaGraph.getEdge("function_call", "annotation"), "function_call.id=annotation.function_call_id");
+		joinExpressions.put(schemaGraph.getEdge("function_call", "produces"), "function_call.id=produces.function_call_id");
+		joinExpressions.put(schemaGraph.getEdge("function_call", "consumes"), "function_call.id=consumes.function_call_id");
+		joinExpressions.put(schemaGraph.getEdge("application_execution", "rt_info"), "application_execution.id=rt_info.application_execution_id");
+		joinExpressions.put(schemaGraph.getEdge("variable", "consumes"), "variable.id=consumes.variable_id");
+		joinExpressions.put(schemaGraph.getEdge("variable", "produces"), "variable.id=produces.variable_id");
+		joinExpressions.put(schemaGraph.getEdge("variable", "annotation"), "variable.id=annotation.variable_id");
+		joinExpressions.put(schemaGraph.getEdge("variable", "file"), "variable.id=file.id");
+		joinExpressions.put(schemaGraph.getEdge("variable", "in_mem"), "variable.id=in_mem.id");
+		joinExpressions.put(schemaGraph.getEdge("variable", "containment"), "variable.id=containment.containee");
+		joinExpressions.put(schemaGraph.getEdge("variable", "containment"), "variable.id=containment.container");
+		Iterator<DefaultEdge> i = jEdges.iterator();
+		if(i.hasNext()) {
+			if(qrels.contains("consumes") || qrels.contains("produces")) {
+				joinExpressionsString = joinExpressions.get(aux);
+			else {
+				if(aux.equals(schemaGraph.getEdge("consumes","function_call")) || aux.equals(schemaGraph.getEdge("produces","function_call")))
+					joinExpressionsString = "ds_use.function_call_id=function_call.id";
+				else if(aux.equals(schemaGraph.getEdge("consumes","variable")) || aux.equals(schemaGraph.getEdge("produces","variable")))
+					joinExpressionsString = "ds_use.variable_id=variable.id";
+				else {
+				joinExpressionsString += " AND " + joinExpressions.get(aux);
+			else {
+					joinExpressionsString += " AND " + "ds_use.function_call_id=function_call.id";
+					joinExpressionsString += " AND " + "ds_use.variable_id=variable.id";
+				else {
+		return joinExpressionsString;
+	public static String computeCompareRunQuery(HashSet<String> atoms) {
+		String compareRunSelectClause = "SELECT script_run_id";
+		String compareRunFromClause = "FROM";
+		Iterator<String> i = atoms.iterator();
+		int nId = 0;
+		for(String arg: atoms) {
+			String[] argTokens = arg.split("=");
+			if(argTokens[0].equals("key_numeric") ||
+			   argTokens[0].equals("key_text")    ||
+			   argTokens[0].equals("parameter"))
+				String key = argTokens[1].split("'")[1];
+				nId++;
+				String sId = "j" + nId;
+				compareRunSelectClause+=", " + sId + ".value as " + key;
+				if(nId>1)
+					compareRunFromClause += " INNER JOIN";
+				compareRunFromClause += " compare_run_by_" + argTokens[0] + "(\'" + key + "\') as " + sId;
+				if(nId>1)
+					compareRunFromClause += " USING (script_run_id)";
+		String compareRunQuery = compareRunSelectClause + " " + compareRunFromClause;
+		return compareRunQuery;
+query	:	squery (
+		UNION { System.out.println(" UNION "); }
+		INTERSECT { System.out.println(" INTERSECT "); }
+		EXCEPT { System.out.println(" EXCEPT "); }
+		ALL { System.out.println(" ALL "); }
+		squery
+		SEMICOLON
+			System.out.print(";");
+squery	:	SELECT
+			System.out.print("SELECT ");
+		DISTINCT
+			System.out.print("DISTINCT ");
+		selectExpression
+			System.out.print(selectClause);
+		(WHERE whereExpression
+						hasWhereExpression=true;
+			schemaGraph = buildGraph();
+			joinEdges = computeJoinEdges(schemaGraph, relations);
+			hasWhereJoinExpression=false;
+			fromClause += computeFrom(schemaGraph, joinEdges, relations);
+			System.out.print(fromClause);
+			whereClauseJoinExpressions += computeJoinExpressions(schemaGraph, joinEdges, relations);
+			if(!whereClauseJoinExpressions.isEmpty()) {
+				hasWhereJoinExpression=true;
+				System.out.print(" WHERE " + whereClauseJoinExpressions);
+			if(hasWhereExpression) {
+				if(hasWhereJoinExpression)
+					System.out.print(" AND ");
+				else
+					System.out.print(" WHERE ");
+				System.out.print(whereClause);
+ 		GROUP BY
+ 			System.out.print(" GROUP BY ");
+ 		a=entityAndAttribute
+ 			System.out.print($a.text);
+ 		COLON
+ 		b=entityAndAttribute
+ 			System.out.print(",");
+ 			System.out.print($b.text);
+ 		HAVING { System.out.print(" HAVING "); }
+ 		havingExpression
+ 		ORDER BY
+ 			System.out.print(" ORDER BY ");
+ 		c=entityAndAttribute
+ 			System.out.print($c.text);
+ 		COUNT { System.out.print(" COUNT "); }
+ 		e=AGGRFUN { System.out.print(" " + $e.text + " "); }
+ 		COLON { System.out.print(","); }
+ 		d=entityAndAttribute
+ 			System.out.print($d.text);
+ 		f=AGGRFUN { System.out.print(" " + $f.text + " "); }
+ 			DESC { System.out.print(" DESC "); }
+ 			ASC  { System.out.print(" ASC "); }
+		'(' { System.out.print("("); }
+		squery
+		')' { System.out.print(")"); }
+selectAtom
+	:	a=entityAttribute
+			selectClause += $a.text;
+			relations.add($a.text.split("\\.")[0]);
+			if($a.text.split("\\.").length == 1)
+				selectClause +=  ".*";
+		b=AGGRFUN
+			selectClause+=$b.text;
+		'(' 	{ selectClause+="("; }
+			selectClause += $c.text;
+			relations.add($c.text.split("\\.")[0]);
+			if($c.text.split("\\.").length == 1)
+		')' 	{ selectClause+=")"; }
+		d=COUNT
+			selectClause+=$d.text;
+		e=entityAttribute
+			selectClause += $e.text;
+			relations.add($e.text.split("\\.")[0]);
+			if($e.text.split("\\.").length == 1)
+		'*' { selectClause+="*"; }
+		builtInProcedureAttribute
+selectExpression
+			selectAtom
+		(COLON { selectClause+=","; }
+			selectAtom
+whereExpression
+	:	whereAtom
+			(AND
+				whereClause += " AND ";
+			| OR
+				whereClause += " OR ";
+			) whereAtom
+whereAtom
+	:	(a=entityAndAttribute
+			whereClause += $a.text;
+		j=COMPARERUN { whereClause+="comapare_run"; }
+		DOT
+		k=ID { whereClause+="."+$k.text; }
+		NOT
+			whereClause += " NOT ";
+	b=OP
+		whereClause += $b.text;
+	c=STRING
+		whereClause += $c.text;
+	d=INT
+		whereClause += $d.text;
+	e=FLOAT
+		whereClause += $e.text;
+	BETWEEN
+		whereClause += " BETWEEN ";
+	f=STRING
+		whereClause += $f.text;
+	AND
+	g=STRING
+		whereClause += $g.text;
+	LIKE
+		whereClause += " LIKE ";
+	h=STRING
+		whereClause += $h.text;
+	IN
+		whereClause += " IN ";
+		i=OP
+		whereClause += $i.text;
+		ALL
+			whereClause += " ALL ";
+		ANY
+			whereClause += " ANY ";
+		squery
+havingExpression
+	:	havingAtom
+			(AND
+			| OR
+				System.out.print(" OR ");
+			) havingAtom
+havingAtom
+	:	a=entityAndAttribute
+		NOT
+			System.out.print(" NOT ");
+	b=OP
+	c=STRING
+	d=INT
+	e=FLOAT
+		System.out.print($e.text);
+	BETWEEN
+		System.out.print(" BETWEEN ");
+	f=STRING
+		System.out.print($f.text);
+	AND
+	g=STRING
+		System.out.print($g.text);
+	LIKE
+	h=STRING
+		System.out.print($h.text);
+	IN
+		System.out.print(" IN ");
+		i=OP
+		System.out.print($i.text);
+		ALL
+			System.out.print(" ALL ");
+		ANY
+			System.out.print(" ANY ");
+		squery
+entityAttribute	:	ID (DOT ID)?;
+entityAndAttribute
+	:	ID DOT ID;
+builtInProcedureAttribute
+	:	COMPARERUN {
+			boolean hasAttribute = false;
+			hasCompareRunCall=true;
+		a=builtInAtom
+			compareRunParams.add($a.text);
+			if(relations.size() > 0)
+				relations.add("script_run");
+	 	(COLON
+	 	b=builtInAtom
+			compareRunParams.add($b.text);
+	 	DOT
+	 		hasAttribute = true;
+	 	c=ID
+	 		selectClause += "compare_run." + $c.text;
+	 	d=ID
+	 		selectClause += "compare_run." + $d.text;
+	 	(COLON
+	 	e=ID
+	 		selectClause += ", compare_run." + $e.text;
+	 		if(!hasAttribute)
+	 			selectClause += "compare_run.*";
+builtInAtom
+	:	('parameter' | 'key_numeric' | 'key_text') OP STRING;
+OP	:	'=' | '>' | '>=' | '<' | '<=';
+GROUP	:	'group';
+ORDER	:	'order';
+COMPARERUN
+	:	'compare_run';
+ANCESTOR:	'ancestor';
+BY	:	'by';
+AGGRFUN	:	'avg' | 'max' | 'min' | 'sum';
+COUNT	:	'count';
+SELECT 	:	'select';
+DESC	:	'desc';
+ASC	:	'asc';
+DISTINCT
+	:	'distinct';
+WHERE	:	'where';
+AND	:	'and';
+OR	:	'or';
+NOT	:	'not';
+IN	:	'in';
+ANY	:	'any';
+UNION	:	'union';
+INTERSECT
+	:	'intersect';
+EXCEPT	:	'except';
+ALL	:	'all';
+DOT	:	'.';
+COLON	:	',';
+BETWEEN	:	'between';
+HAVING	:	'having';
+LIKE 	:	'like';
+SEMICOLON	:	';';
+ID  :	('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'0'..'9'|'_'|'-')*
+INT :	'0'..'9'+
+FLOAT
+    :   ('0'..'9')+ '.' ('0'..'9')*
+    |   '.' ('0'..'9')+
+    |   ('0'..'9')+
+STRING
+    :  '\'' ( 'a'..'z' | 'A'..'Z' | '_' | '-' | '0'..'9' | '.' | '%')* '\''
+NEWLINE	:	'\r' ?	'\n';
+WS	:	(' ' |'\t' |'\n' |'\r' )+
+		skip();
Modified: provenancedb/prov-init.sql
--- provenancedb/prov-init.sql	2012-01-23 21:49:09 UTC (rev 5516)
+++ provenancedb/prov-init.sql	2012-01-24 18:38:35 UTC (rev 5517)
@@ -207,32 +207,36 @@
 -- continue renaming from here
-CREATE VIEW a_t AS
-    SELECT *
-    FROM a_run_t
-  UNION ALL
-    SELECT *
-    FROM a_ds_t
-  UNION ALL
-    SELECT *
-    FROM a_proc_t;
+create view a_t as
+    select *
+    from a_run_t
+  union all
+    select *
+    from a_ds_t
+  union all
+    select *
+    from a_proc_t;
-CREATE VIEW a_n AS
-    SELECT *
-    FROM a_run_n
-  UNION ALL
-    SELECT *
-    FROM a_ds_n
-  UNION ALL
-    SELECT *
-    FROM a_proc_n;
+create view a_n as
+    select *
+    from a_run_n
+  union all
+    select *
+    from a_ds_n
+  union all
+    select *
+    from a_proc_n;
 -- views used for queries based on the schema summary
 drop view function_call;
 create view function_call as
-    select proc.id, proc.type, proc.name, proc.run_id, app_inv.proc_name, to_timestamp(app_inv.start_time), app_inv.duration, app_inv.final_state, app_inv.scratch from proc natural join app_inv;
+    select proc.id, proc.type, proc.name, proc.run_id, app_inv.proc_name,
+           to_timestamp(app_inv.start_time), app_inv.duration, app_inv.final_state, app_inv.scratch
+    from proc
+    left outer join
+    app_inv on proc.id=app_inv.id;
 drop view variable;
@@ -261,7 +265,6 @@
          to_timestamp(start_time) as start_time, duration
   from   run;
 drop view application_execution;
 create view application_execution as
@@ -284,3 +287,9 @@
 create view consumes as
   select proc_id as function_call_id, ds_id as variable_id, param as parameter from ds_in;
+drop view variable_containment;
+create view variable_containment as
+  select out_id as container, in_id as containee
+  from   ds_cont;
