[Swift-commit] r5513 - SwiftApps/SciColSim
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Mon Jan 23 13:13:49 CST 2012
Author: wilde
Date: 2012-01-23 13:13:49 -0600 (Mon, 23 Jan 2012)
New Revision: 5513
Modified:
   SwiftApps/SciColSim/Makefile
   SwiftApps/SciColSim/optimizer.cpp
Log:
Fix bug in original optimizer which caused the inner loop of
multi_loss() to be executed way too many times - N^2 instead of N -
(per EMAIL circa Oct 16 2011):
> Looking deeper, I think the bug was simply that the first for() statement
> should have enclosed just the parameter setting loop.  In other words, the top
> of multi_loss should start with:
>     for(int i=0; i<Nworkers; i++){
>         for(int j=0; j<5; j++){
>             un[i]->set_parameter(params[j],j);
> Then the real work is done by the next loop:
>     for(i=0; i<Nworkers; i++){
Add make targets for raw Mac version.
Modified: SwiftApps/SciColSim/Makefile
--- SwiftApps/SciColSim/Makefile	2012-01-23 18:30:50 UTC (rev 5512)
+++ SwiftApps/SciColSim/Makefile	2012-01-23 19:13:49 UTC (rev 5513)
@@ -1,5 +1,10 @@
-all:	toptimizer optimizer Optimizer
+all:	macoptimizer
+macoptimizer: optimizer.cpp
+	g++  -I boost_1_47_0 -o optimizer optimizer.cpp
+protoall:	toptimizer optimizer Optimizer
 optimizer:	optimizer.snap01.cpp
 	g++ -static -fopenmp -I boost_1_47_0 -o optimizer optimizer.snap01.cpp
Modified: SwiftApps/SciColSim/optimizer.cpp
--- SwiftApps/SciColSim/optimizer.cpp	2012-01-23 18:30:50 UTC (rev 5512)
+++ SwiftApps/SciColSim/optimizer.cpp	2012-01-23 19:13:49 UTC (rev 5513)
@@ -1249,24 +1249,23 @@
     double Loss=0., LossSquare=0.;
+    for(int i=0; i<Nworkers; i++){
-        for(int i=0; i<Nworkers; i++){
-            dispatch_group_async(group, CustomQueues[i], ^{
+        dispatch_group_async(group, CustomQueues[i], ^{
-                un[i]->evolve_to_target_and_save(istart, iend, Results, Counters);
+            un[i]->evolve_to_target_and_save(istart, iend, Results, Counters);
-            istart += step;
-            iend = min(istart+step,N);
+        std::cout << "queued: i=" << i << " N=" << N << " istart=" << istart << " iend=" << iend << "\n";
+        istart += step;
+        iend = min(istart+step,N);
     dispatch_group_wait(group, DISPATCH_TIME_FOREVER);
     //dispatch_release(group);
