[Swift-commit] r5507 - SwiftApps/SciColSim
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Sun Jan 22 19:50:27 CST 2012
Author: wilde
Date: 2012-01-22 19:50:27 -0600 (Sun, 22 Jan 2012)
New Revision: 5507
Modified:
   SwiftApps/SciColSim/annealing.swift
   SwiftApps/SciColSim/math.swift
   SwiftApps/SciColSim/tc
Log:
Initial working version of basic swift annealing loop.
Modified: SwiftApps/SciColSim/annealing.swift
--- SwiftApps/SciColSim/annealing.swift	2012-01-22 03:29:59 UTC (rev 5506)
+++ SwiftApps/SciColSim/annealing.swift	2012-01-23 01:50:27 UTC (rev 5507)
@@ -19,6 +19,7 @@
     } else {
         nx = x - (random())*dx/(pow(2.0,31.0)-1.0);
+    tracef("newx(%f,%f)=%f\n",x,dx,nx);
 app (file outfile, file loss) evolve (string args[], file graph)
@@ -40,7 +41,7 @@
       multi_annealing()
         multi_loss()
           evolve()
-        sumloass()
+        sumloss()
 (file bestfile, file maxfile) multi_annealing (
@@ -61,7 +62,8 @@
     float x[][], dx[][], curr_loss[], curr_sdev[];
     Res mlres[][];
-    mlres[0][0] = multi_loss( params0, target_innov, evolve_reruns ); // Only done once, not 5x; serves for all evolve-params ???
+    mlres[0][0] = multi_loss( 0, 0, params0, target_innov, evolve_reruns ); // Only done once, not 5x; serves for all evolve-params ???
+tracef("in multi_annealing: i=%i j=%i ret vals from iniital multi_loss=(%f,%f)\n",0,0,mlres[0][0].loss,mlres[0][0].sdev);
     foreach j in [0:NEVOPARAMS-1] {
         x[0][j]=params0[j];
@@ -74,9 +76,10 @@
     foreach i in [1:annealing_cycles] {
         // set new temperature, rejection threshold, and dx values for this cycle
         float temperature = T_start*exp( @tofloat(i)*(jlog(T_end)-jlog(T_start))/@tofloat(annealing_cycles));
-        tracef("....T =%f\n", temperature);
+        tracef("in multi_annealing: i=%i T=%f\n", i, temperature);
 	// On each new "major" cycle within the annealing_cycles (other than the first) set new rejection and dx values
         if ( i %% cycle == 1 && i > 1 ){
+            tracef("multi_annealing: new cycle at i=%i\n",i);
             foreach  k in [0:NEVOPARAMS-1] {
                 float newrejection = rejection[i-1][k] / @tofloat(cycle);
                 if (newrejection > 0.0){
@@ -90,47 +93,61 @@
                 trace ("Recomputed rejection: i=%d k=%d dx[i][k]=%f\n", i, k, dx[i][k]);
+        else { # If not new cycle, set dx from previous dx (i-1)
+            foreach  k in [0:NEVOPARAMS-1] {
+                dx[i][k] = dx[i-1][k];
         foreach j in [0:NEVOPARAMS-1] { // Try a new value for each non-fixed param; then write results and accept or reject
-            float try_x[];
+            // float try_x[];
             int curr = (i * NEVOPARAMS) + j;
             int prev = curr-1;
-            if ( FIX_VARIABLES || var_fixed[j]==0) {
-                foreach k in [0:NEVOPARAMS] { // Select the evolve params to try
+tracef("in multi_annealing: i=%i j=%i curr=%i prev=%i\n", i, j, curr, prev);
+            if ( /*(!FIX_VARIABLES) || */ (var_fixed[j]==0) ) {  # fixed=1,1,0,0,0: FIXME: FIX_VARIABLES flag has faulty logic but OK when TRUE
+                float try_x[];
+                foreach k in [0:NEVOPARAMS-1] { // Select the evolve params to try
                     if ( k < j ) {
                         try_x[k] = x[i][k]; // already set x[i][k]
                     else {
                         if ( k == j ) {
-                            try_x[k] = newx(x[i][j],dx[i][j]); // permute x[i][j]
+                            try_x[k] = newx(x[i-1][j],dx[i-1][j]); // permute x[i-1][j]
-                        else {
+                        else { // k > j
                             try_x[k] = x[i-1][k]; // use x[i-1][k] (from prior cycle)
+                    tracef("in multi_annealing: i=%i j=%i k=%i try_x=%f\n", i, j, k, try_x[k]);
+                    tracef("in multi_annealing: i=%i j=%i k=%i\n", i, j, k);
-                mlres[i][j] = multi_loss(try_x, target_innov, evolve_reruns);
+                // Up to here, x[] and dx[] are only set for previous i
+tracef("in multi_annealing: i=%i j=%i calling multi_loss\n",i,j);
+#tracef("in multi_annealing: i=%i j=%i calling multi_loss try_x=%q\n",i,j,try_x);
+                mlres[i][j] = multi_loss(i,j,try_x, target_innov, evolve_reruns); # do the N evolve()'s, N=evolve_reruns
+tracef("in multi_annealing: i=%i j=%i ret vals from multi_loss=(%f,%f)\n",i,j,mlres[i][j].loss,mlres[i][j].sdev);
+                // Beyond this point, x[] and dx[] are being set for this i,j
                 float ratio = min(1.0, exp( -(mlres[i][j].loss-curr_loss[prev]) /temperature));
                 float r = (random()) / (pow(2.0,31.0)-1.0);  // why all the 2^31's ???
                 float ALOT=100000000000.0; // 100,000,000,000. = 10^11
-                if (mlres[i][j].loss < ALOT) {  // does this ever occur? if so did we want to still do the ratio computation above???
-                    trace("filestr.open (best_opt_some.txt, ofstream::app);");
+                if (mlres[i][j].loss < ALOT) {
+                    tracef("multi_annealing: Writing: filestr.open (best_opt_some.txt, ofstream::app);\n");
                     # un[0]->get_target() Res.loss un[0]->get_parameter[0:4] Res.error
                     # filestr.open ("max_dist.txt", ofstream::app);
-                else { tracef("Loss %f > ALOT at [i][j] = [%d][%d]\n", mlres[i][j].loss, i ,j); }
-                if (r > ratio) {  // Reject
+                else {  // does this ever occur? if so did we want to still do the ratio computation above???
+                    tracef("multi_annealing: Loss %f > ALOT at [i][j] = [%d][%d]\n", mlres[i][j].loss, i ,j);
+                if (r > ratio) {  // Reject new parameter
                     x[i][j] = x[i-1][j];
-                    rejection[i][j] = rejection[i][j] + 1.0;  // Is this correct? incr rejection?
+                    rejection[i][j] = rejection[i-1][j] + 1.0;  // Is this correct? incr rejection?
                     curr_loss[curr] = curr_loss[prev];
                     curr_sdev[curr] = curr_sdev[prev];
-                else {           // Accept
-trace("Accepting try_x[j],j=",j);
-                    x[i][j] = try_x[j];  # FIXME: is this right?  Just assign the j'th try_x, or the whole try_x param set?
-trace("Accepting try_x[j],x[i][j]=",x[i][j]);
+                else {           // Accept new parameter
+tracef("multi_annealing: Accepting try_x[j], i=%i j=%i\n",i,j);
+                    x[i][j] = try_x[j];
+tracef("multi_annealing: Accepting try_x[j], i=%i j=%i try_x[j]=%f\n",i,j,try_x[j]);
                     curr_loss[curr] = mlres[i][j].loss;
                     curr_sdev[curr] = mlres[i][j].sdev;
@@ -144,9 +161,16 @@
-(Res r) multi_loss( float x[], float target_innov, int evolve_reruns )
+(Res r) multi_loss( int ci, int cj, float x[], float target_innov, int evolve_reruns )
   file rfile[];
+  tracef("In multi_loss: entered: ci=%i cj=%i target_innov=%f evolve_reruns=%i x=%q\n",ci, cj, target_innov,evolve_reruns,x);
+  tracef("In multi_loss: entered: ci=%i cj=%i target_innov=%f evolve_reruns=%i\n",ci, cj, target_innov,evolve_reruns);
+/* This hangs:
+  foreach f,i in x {
+     tracef("In multi_loss: x[]: ci=%i cj=%i x[%i]=%f\n",ci, cj, i, f);
   foreach i in [1:evolve_reruns] {  // repeats of the evolove() - same as n_reruns
     file outfile; // FIXME: map and save in future
     string args[] = [ // FIXME: move this to a setargs() function
@@ -155,7 +179,7 @@
       //     n_epochs n_steps evolve_reruns           range
       //    "40000",  "20",   @strcat(evolve_reruns), "2",
-            "40000",  "20",   "1", "                   2",  # Set reruns to 1 for the cpp code; we do the re-runs in Swift for now.
+            "40000",  "20",   "1",                    "2",  # Set reruns to 1 for the cpp code; we do the re-runs in Swift for now.
       //    verbose_level
             "1",
@@ -171,23 +195,26 @@
     file graph <"movie_graph.txt">;
     (outfile, rfile[i]) = evolve(args,graph);
+    tracef("in multi_loss: after evolve: i=%i %k %k\n", i, outfile, rfile[i]);
   file sumfile = sumloss(rfile);
   r = readData(sumfile);
+  tracef("in multi_loss: returning: ci=%i cj=%i r.loss=%f r.sdev=%f\n",ci,cj,r.loss,r.sdev);
 optimizer_sweep() // Implements logic of python driver script
   int minrange=58;
-  int maxrange=59;
+  int maxrange=209;
+  //int maxrange=59;
   //int maxrange=1009;
   //int maxrange=209;
   int rangeinc=50;
   // fixme: add provision for random priming and random param values when x[i] == -100 (see optimizer.cpp main())
-  int nreps=1; # 15
+  //int nreps=1; # 15
+  int nreps=3; # 15
 //    file bestfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".best_opt_some")>;
 //    file maxfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".max_dist")>;
@@ -204,8 +231,8 @@
          evolve_reruns    = 2,
          starting_jump    = 2.3,
          params0[]        = [0.0, 0.0, 4.0, 50.0, -1.0],
-         @tofloat(@strcat(target_innov)), // fixme: would @tofloat(int) work?
-         annealing_cycles = 1);   // fixme: clarify: annealing repeats, steps, and cycles
+         @tofloat(target_innov),
+         annealing_cycles = 1);
       (outfile,lossfile) = multi_annealing(
          2.0,
@@ -214,8 +241,8 @@
          2,
          2.3,
-         1);   // fixme: clarify: annealing repeats, steps, and cycles
+         1);
@@ -236,7 +263,7 @@
       multi_annealing()
         multi_loss()
           evolve()
-        sumloass()
+        sumloss()
 Example parameter sets:
Modified: SwiftApps/SciColSim/math.swift
--- SwiftApps/SciColSim/math.swift	2012-01-22 03:29:59 UTC (rev 5506)
+++ SwiftApps/SciColSim/math.swift	2012-01-23 01:50:27 UTC (rev 5507)
@@ -38,7 +38,7 @@
    else {
        result = b;
-   tracef("min: result=%f\n",result);
+   tracef("math/min: result=%f\n",result);
 (float result) pow (float x, float y)
Modified: SwiftApps/SciColSim/tc
--- SwiftApps/SciColSim/tc	2012-01-22 03:29:59 UTC (rev 5506)
+++ SwiftApps/SciColSim/tc	2012-01-23 01:50:27 UTC (rev 5507)
@@ -1,13 +1,15 @@
 localhost sh /bin/sh null null null
 localhost cat /bin/cat null null null
 pbs cat /bin/cat null null null
 mcs cat /bin/cat null null null
 localhost catnap /home/wilde/swift/lab/catnap.sh null null GLOBUS::maxwalltime="00:01:00"
 beagle optimizer /home/wilde/AndreysOptimizer/Optimizer null null GLOBUS::maxwalltime="01:00:00"
 beagle optimizersh /home/wilde/AndreysOptimizer/optimizer.sh null null GLOBUS::maxwalltime="02:00:00"
 beagle evolve /home/wilde/AndreysOptimizer/evolve.sh null null GLOBUS::maxwalltime="02:00:00"
-localhost evolve /home/wilde/AndreysOptimizer/evolve.sh null null GLOBUS::maxwalltime="02:00:00"
+localhost evolve /home/wilde/AndreysOptimizer/src/evolve.sh null null GLOBUS::maxwalltime="02:00:00"
 beagle sumloss /home/wilde/AndreysOptimizer/evolve.sh null null GLOBUS::maxwalltime="02:00:00"
-localhost sumloss /home/wilde/AndreysOptimizer/sumloss.sh null null GLOBUS::maxwalltime="02:00:00"
+localhost sumloss /home/wilde/AndreysOptimizer/src/sumloss.sh null null GLOBUS::maxwalltime="02:00:00"
