[Swift-commit] r5496 - in trunk/tests/sites: . ibicluster
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Tue Jan 10 11:01:34 CST 2012
Author: davidk
Date: 2012-01-10 11:01:34 -0600 (Tue, 10 Jan 2012)
New Revision: 5496
Added:
   trunk/tests/sites/ibicluster/
   trunk/tests/sites/ibicluster/catsn.0001.out.expected
   trunk/tests/sites/ibicluster/catsn.0002.out.expected
   trunk/tests/sites/ibicluster/catsn.0003.out.expected
   trunk/tests/sites/ibicluster/catsn.0004.out.expected
   trunk/tests/sites/ibicluster/catsn.0005.out.expected
   trunk/tests/sites/ibicluster/catsn.0006.out.expected
   trunk/tests/sites/ibicluster/catsn.0007.out.expected
   trunk/tests/sites/ibicluster/catsn.0008.out.expected
   trunk/tests/sites/ibicluster/catsn.0009.out.expected
   trunk/tests/sites/ibicluster/catsn.0010.out.expected
   trunk/tests/sites/ibicluster/catsn.check.sh
   trunk/tests/sites/ibicluster/catsn.setup.sh
   trunk/tests/sites/ibicluster/catsn.swift
   trunk/tests/sites/ibicluster/catsn.timeout
   trunk/tests/sites/ibicluster/data.txt
   trunk/tests/sites/ibicluster/sites.template.xml
   trunk/tests/sites/ibicluster/tc.template.data
   trunk/tests/sites/ibicluster/title.txt
Log:
Add site test for ibicluster
Added: trunk/tests/sites/ibicluster/catsn.0001.out.expected
--- trunk/tests/sites/ibicluster/catsn.0001.out.expected	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.0001.out.expected	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+blah blah
Added: trunk/tests/sites/ibicluster/catsn.0002.out.expected
--- trunk/tests/sites/ibicluster/catsn.0002.out.expected	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.0002.out.expected	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+blah blah
Added: trunk/tests/sites/ibicluster/catsn.0003.out.expected
--- trunk/tests/sites/ibicluster/catsn.0003.out.expected	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.0003.out.expected	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+blah blah
Added: trunk/tests/sites/ibicluster/catsn.0004.out.expected
--- trunk/tests/sites/ibicluster/catsn.0004.out.expected	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.0004.out.expected	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+blah blah
Added: trunk/tests/sites/ibicluster/catsn.0005.out.expected
--- trunk/tests/sites/ibicluster/catsn.0005.out.expected	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.0005.out.expected	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+blah blah
Added: trunk/tests/sites/ibicluster/catsn.0006.out.expected
--- trunk/tests/sites/ibicluster/catsn.0006.out.expected	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.0006.out.expected	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+blah blah
Added: trunk/tests/sites/ibicluster/catsn.0007.out.expected
--- trunk/tests/sites/ibicluster/catsn.0007.out.expected	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.0007.out.expected	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+blah blah
Added: trunk/tests/sites/ibicluster/catsn.0008.out.expected
--- trunk/tests/sites/ibicluster/catsn.0008.out.expected	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.0008.out.expected	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+blah blah
Added: trunk/tests/sites/ibicluster/catsn.0009.out.expected
--- trunk/tests/sites/ibicluster/catsn.0009.out.expected	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.0009.out.expected	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+blah blah
Added: trunk/tests/sites/ibicluster/catsn.0010.out.expected
--- trunk/tests/sites/ibicluster/catsn.0010.out.expected	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.0010.out.expected	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+blah blah
Added: trunk/tests/sites/ibicluster/catsn.check.sh
--- trunk/tests/sites/ibicluster/catsn.check.sh	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.check.sh	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1,12 @@
+#!/bin/bash
+set -x
+for count in `seq --format "%04.f" 1 1 10`
+do
+	[ -f catsn.$count.out ] || exit 1
+	CONTENTS1=$( cat catsn.$count.out.expected )
+	CONTENTS2=$( cat catsn.$count.out )
+	[[ $CONTENTS1 == $CONTENTS2 ]] || exit 1
+done
+exit 0
Property changes on: trunk/tests/sites/ibicluster/catsn.check.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/sites/ibicluster/catsn.setup.sh
--- trunk/tests/sites/ibicluster/catsn.setup.sh	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.setup.sh	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1,7 @@
+#!/bin/bash
+cp -v $GROUP/data.txt . || exit 1
+cp -v $GROUP/*expected . || exit 1
+export QUEUE=normal
Property changes on: trunk/tests/sites/ibicluster/catsn.setup.sh
Added: trunk/tests/sites/ibicluster/catsn.swift
--- trunk/tests/sites/ibicluster/catsn.swift	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.swift	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1,12 @@
+type file;
+app (file o) cat (file i)
+  cat @i stdout=@o;
+file out[]<simple_mapper; location=".", prefix="catsn.",suffix=".out">;
+foreach j in [1:@toint(@arg("n","10"))] {
+  file data<"data.txt">;
+  out[j] = cat(data);
Added: trunk/tests/sites/ibicluster/catsn.timeout
--- trunk/tests/sites/ibicluster/catsn.timeout	                        (rev 0)
+++ trunk/tests/sites/ibicluster/catsn.timeout	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+1800
Added: trunk/tests/sites/ibicluster/data.txt
--- trunk/tests/sites/ibicluster/data.txt	                        (rev 0)
+++ trunk/tests/sites/ibicluster/data.txt	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+blah blah
Added: trunk/tests/sites/ibicluster/sites.template.xml
--- trunk/tests/sites/ibicluster/sites.template.xml	                        (rev 0)
+++ trunk/tests/sites/ibicluster/sites.template.xml	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1,14 @@
+<config>
+ <pool handle="ibicluster">
+  <execution provider="coaster" url="none" jobmanager="local:sge"/>
+  <profile namespace="globus" key="pe">threaded</profile>
+  <profile namespace="globus" key="queue">all.q</profile>
+  <profile namespace="globus" key="jobsPerNode">8</profile>
+  <profile namespace="globus" key="nodeGranularity">1</profile>
+  <profile namespace="globus" key="maxnodes">2</profile>
+  <profile namespace="karajan" key="jobThrottle">0.159</profile>
+  <profile namespace="karajan" key="initialScore">10000</profile>
+  <filesystem provider="local" url="none"/>
+  <workdirectory>_WORK_</workdirectory>
+ </pool>
+</config>
Added: trunk/tests/sites/ibicluster/tc.template.data
--- trunk/tests/sites/ibicluster/tc.template.data	                        (rev 0)
+++ trunk/tests/sites/ibicluster/tc.template.data	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1,8 @@
+ibicluster 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX
+ibicluster 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX
+ibicluster 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX
+ibicluster 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX
+ibicluster 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX
+ibicluster 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX
+ibicluster	wc		/usr/bin/wc	INSTALLED	INTEL32::LINUX
Added: trunk/tests/sites/ibicluster/title.txt
--- trunk/tests/sites/ibicluster/title.txt	                        (rev 0)
+++ trunk/tests/sites/ibicluster/title.txt	2012-01-10 17:01:34 UTC (rev 5496)
@@ -0,0 +1 @@
+IBICluster SGE Test
