[Swift-commit] r5483 - branches/release-0.93/docs/siteguide
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Tue Jan 3 16:19:15 CST 2012
Author: davidk
Date: 2012-01-03 16:19:14 -0600 (Tue, 03 Jan 2012)
New Revision: 5483
Added:
   branches/release-0.93/docs/siteguide/bag_of_workstations
Log:
Add siteguide entry for bag of workstations configuration
Added: branches/release-0.93/docs/siteguide/bag_of_workstations
--- branches/release-0.93/docs/siteguide/bag_of_workstations	                        (rev 0)
+++ branches/release-0.93/docs/siteguide/bag_of_workstations	2012-01-03 22:19:14 UTC (rev 5483)
@@ -0,0 +1,109 @@
+Bag of Workstations
+"Bag of workstations" refers to a collection of machines that are not connected
+together as part of a cluster or supercomputer.
+Prerequisites
+In order to run Swift on a bag of workstations, the following prerequisites must
+be met:
+- The machines must be running Linux
+- The machines must have Perl available
+- A user account must be created on each machine (the username you create must be the same on each machine)
+- You must be able to SSH into the accounts without being prompted for a password. This usually involves creating an SSH key and setting up your authorized_keys. More information on how to do this can be found at http://www.openssh.org.
+Create a coaster-service.conf
+To begin, copy the text below and paste it into the directory
+where your swift script is located. Name this file coaster-service.conf.
+include::../../etc/coaster-service.conf[]
+Modify coaster-service.conf
+The coaster-service.conf file contains information about your setup.
+There are a few settings you must customize.
+The first is the name of the machines which will be used as workers. Modify
+the line below to reflect the names of the machines you want to use.
+export WORKER_HOSTS="myhost1.mydomain myhost2.mydomain"
+Update the value for JOBS_PER_NODE to reflect the number of CPUs available per node.
+The JOB_THROTTLE setting determines the maximum number of active jobs. Use the formula
+to determine the ideal value:
+jobs per node * number of nodes - 0.1 / 100
+Example: Suppose you have 10 machines each with 8 cores
+8 jobs per node * 10 cores = 80
+80 - 0.1 = 79.9
+79.9 / 100 = 0.799
+In this example, you would set the job throttle to 0.799
+export JOB_THROTTLE=0.799
+By default, this setup assumes there are no firewall rescrictions. If there
+is a firewall rescricting SSH access, set tunneling to true with this command
+export SSH_TUNNELING=yes
+This setup also assumes that these machines are not using a shared filesystem (NFS/AFS/CIFS, etc).
+If these systems are all sharing a common filesystem, add the setting below.
+export SHARED_FILESYSTEM=no
+Starting the Coaster Service
+Change directories to the location where you would like to run a
+Swift script and start the coaster service with this
+command:
+start-coaster-service
+This will create a configuration file that Swift needs
+called sites.xml.
+WARNING: Any existing sites.xml files in this directory
+will be overwritten. Be sure to make a copy of any
+custom configuration files you may have.
+Run Swift
+Next, run Swift. If you do not have a particular script
+in mind, you can test Swift by using a Swift script in
+the examples/ directory.
+Run the following command to run the script:
+swift -sites.file sites.xml -tc.file tc.data yourscript.swift
+Stopping the Coaster Service
+The coaster service will run indefinitely. The stop-coaster-service
+script will terminate the coaster service.
+$ stop-coaster-service
+This will kill the coaster service and kill the worker scripts on remote systems.
