[Swift-commit] r5651 - SwiftApps/Cybershake/swiftscripts
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Sat Feb 18 09:06:17 CST 2012
Author: ketan
Date: 2012-02-18 09:06:16 -0600 (Sat, 18 Feb 2012)
New Revision: 5651
Added:
   SwiftApps/Cybershake/swiftscripts/presgt.swift
Log:
added presgt.swift
Added: SwiftApps/Cybershake/swiftscripts/presgt.swift
--- SwiftApps/Cybershake/swiftscripts/presgt.swift	                        (rev 0)
+++ SwiftApps/Cybershake/swiftscripts/presgt.swift	2012-02-18 15:06:16 UTC (rev 5651)
@@ -0,0 +1,128 @@
+type datafile;
+type outfile;
+type cvmfile;
+type e3dfile;
+/* Following are the output files from the precvm process */
+datafile coord<"processed/coords_GC_TEST">;
+datafile gridfiletest<"processed/gridfile_TEST">;
+datafile gridout<"processed/gridout_TEST">;
+datafile model<"processed/model">;
+datafile modelparam<"processed/model_params_GC_TEST">;
+datafile modelbox_file<"processed/TEST.modelbox">;
+/*Following file is the input to preSGT and vmeshgen, do not know the source of this file*/
+datafile model_coord<"data/model_coords_GC_TEST">;
+datafile modelbound<"processed/model_bounds_GC_TEST">;
+/* Following are the outputs from preSGT*/
+datafile fdloc<"processed/TEST.fdloc">;
+datafile faultlist<"processed/TEST.faultlist">;
+datafile radiusfile<"processed/TEST.radiusfile">;
+datafile cordfile<"processed/TEST.cordfile">;
+/* Following are the outputs from the vmeshmerge but are represented as strings in the commandline */
+datafile sgt_p<"processed/v4_sgt-TEST.p">;
+datafile sgt_s<"processed/v4_sgt-TEST.s">;
+datafile sgt_d<"processed/v4_sgt-TEST.d">;
+datafile gridout2<"processed/gridout">;
+/* These files are created by genmod aka vmeshgen */
+datafile zdepths<"processed/zdepths.meter">;
+cvmfile cvms[] <simple_mapper; location="processed", prefix="v4_sgt-", suffix=".cvm">;
+/* These files are produced as a result of simsgt */
+e3dfile e3dsx[] <simple_mapper; location="processed", prefix="TEST-fx_sgt-", suffix=".e3d">;
+e3dfile e3dsy[] <simple_mapper; location="processed", prefix="TEST-fy_sgt-", suffix=".e3d">;
+/* Final outputs */
+datafile merged_sgt_fx<"TEST_fx_816.sgt">;
+datafile merged_sgt_fy<"TEST_fy_816.sgt">;
+/* Standard outputs */
+outfile outvmeshgen<"stdout/vmeshgen.std.out">;
+outfile outprecvm<"stdout/precvm.std.out">;
+outfile outpresgt<"stdout/presgt.std.out">;
+outfile outvmeshmerge<"stdout/vmeshmerge.std.out">;
+outfile outsimsgtx<"stdout/simsgtx.std.out">;
+outfile outsimsgty<"stdout/simsgty.std.out">;
+outfile outsgtmergex<"stdout/sgtmergex.std.out">;
+outfile outsgtmergey<"stdout/sgtmergey.std.out">;
+app (outfile o, datafile modelbox, datafile gridfile_TEST, datafile gridout_TEST, datafile model_coords_GC_TEST, datafile model_params_GC_TEST, datafile model_bounds_GC_TEST) precvm (string region, int count){
+  precvm region count @modelbox
+         @gridfile_TEST @gridout_TEST
+         @model_coords_GC_TEST @model_params_GC_TEST
+         @model_bounds_GC_TEST stdout=@o;
+app (outfile o) PreSgt (string region, string count, datafile modelbox, datafile gridout_data, datafile model_coord_data, datafile fdloc_data, datafile _faultlist, datafile _radiusfile, datafile _cordfile, string nx, string ny, string nz, string h, string xsrc, string ysrc, string ixmin, string ixmax, string iymin, string iymax, string izstart, string izmax, string modellon, string modellat, string modelrot){
+  presgt region count
+       @modelbox @gridout_data
+       @model_coord_data @fdloc_data
+       @_faultlist @_radiusfile
+       @_cordfile
+       "cqsub"
+       "-q prod-devel -n 1 -t 60"
+       "/scratch/projects/tg/tera3d/CyberShake2007/software-9.2.0/PreSgt/bin/gen_sgtgrid"
+       @strcat("nx=", nx) @strcat("ny=", ny)
+       @strcat("nz=", nz) @strcat("h=", h)
+       @strcat("xsrc=", xsrc) @strcat("ysrc=", ysrc)
+       @strcat("ixmin=", ixmin) @strcat("ixmax=", ixmax)
+       @strcat("iymin=", iymin) @strcat("iymax=", iymax)
+       @strcat("izstart=", izstart)
+       @strcat("izmax=", izmax)
+       @strcat("radiusfile=", @filename(_radiusfile))
+       @strcat("outfile=", @filename(_cordfile))
+       @strcat("modellon=", modellon)
+       @strcat("modellat=", modellat)
+       @strcat("modelrot=", modelrot)
+       @strcat("faultlist=", @filename(_faultlist))
+       stdout=@o;
+app (outfile o) vmeshgen (string region, datafile gridout_data, datafile _model_coord){
+  genmod region @gridout_data @_model_coord stdout=@o;
+app (outfile o) vmeshmerge (string region, datafile gridfile_TEST, string _sgtp, string _sgts, string _sgtd, outfile _outvmeshgen){
+  mergecvm region @gridfile_TEST _sgtp _sgts _sgtd stdout=@o;
+app (outfile o) simsgt (string region, datafile gridout_test, datafile modelbox, datafile _fdloc, datafile _cordfile, string x_or_y, outfile _outvmeshmerge){
+simsgt region @gridout_test @modelbox @_fdloc @_cordfile x_or_y stdout=@o;
+app (outfile o) mergesgt (string region, string x_or_y, string outsgt, outfile _outsimsgt_x_or_y, string test_fx_or_fy_816){
+mergesgt region test_fx_or_fy_816 x_or_y outsgt stdout=@o;
+/* Execution starts here */
+//(outprecvm, modelbox_file, gridfiletest, gridout, coord, modelparam, modelbound) = precvm ("TEST", 35);
+/* This process implicitly also refers to rupture variations, this means the rupture variations location should also be unique!! */
+//outpresgt = PreSgt ("TEST", "35", modelbox_file, gridout, coord, fdloc, faultlist, radiusfile, cordfile, "800", "1550", "200", "0.200000", "510", "492", "20", "780", "20", "1530", "1", "180", "-117.921940", "33.566690", "-55.000000");
+//outvmeshgen = vmeshgen ("TEST", gridout, model_coord);
+/* The strings "v4_sgt-TEST.p", "v4_sgt-TEST.s", "v4_sgt-TEST.d" are the output files names generated by the app */
+//outvmeshmerge = vmeshmerge ("TEST", gridfiletest, "v4_sgt-TEST.p", "v4_sgt-TEST.s", "v4_sgt-TEST.d", outvmeshgen);
+outsimsgtx = simsgt ("TEST", gridout, modelbox_file, fdloc, cordfile, "x", outvmeshmerge);
+outsimsgty = simsgt ("TEST", gridout, modelbox_file, fdloc, cordfile, "y", outvmeshmerge);
+/* The inputs to these are TEST-f${COMPONENT}_sgt-<num>.e3d */
+//(outsgtmergex) = mergesgt ("TEST", "x", "/work/01739/ketan/scec/swift/SGT", outsimsgtx, "TEST_fx_816.sgt");
+//(outsgtmergey) = mergesgt ("TEST", "y", "/work/01739/ketan/scec/swift/SGT", outsimsgty, "TEST_fy_816.sgt");
