[Swift-commit] r5639 - in SwiftApps/SciColSim: . bin docs old
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Thu Feb 16 14:59:48 CST 2012
Author: jonmon
Date: 2012-02-16 14:59:48 -0600 (Thu, 16 Feb 2012)
New Revision: 5639
Added:
   SwiftApps/SciColSim/bin/
   SwiftApps/SciColSim/bin/convertbest.sh
   SwiftApps/SciColSim/bin/extract4plots
   SwiftApps/SciColSim/bin/getallparams.sh
   SwiftApps/SciColSim/bin/getparamtrace.sh
   SwiftApps/SciColSim/bin/paramtraceall.sh
   SwiftApps/SciColSim/bin/showbest.sh
   SwiftApps/SciColSim/colortext.swift
   SwiftApps/SciColSim/docs/
   SwiftApps/SciColSim/docs/EMAIL
   SwiftApps/SciColSim/docs/TimingEstimation.txt
   SwiftApps/SciColSim/docs/atomic_times.png
   SwiftApps/SciColSim/docs/atomic_times.txt
   SwiftApps/SciColSim/docs/plot_active.txt
   SwiftApps/SciColSim/docs/plot_cumulative.txt
   SwiftApps/SciColSim/docs/plot_ready_jobs.txt
   SwiftApps/SciColSim/docs/plotit
   SwiftApps/SciColSim/docs/sample.swift.output
   SwiftApps/SciColSim/docs/sample.testopt.py.output
   SwiftApps/SciColSim/old/
   SwiftApps/SciColSim/old/RunSwift.sh
   SwiftApps/SciColSim/old/annealing.open-issues.swift
   SwiftApps/SciColSim/old/beagle.xml
   SwiftApps/SciColSim/old/mathtest.swift
   SwiftApps/SciColSim/old/optimizer.protomods.cpp
   SwiftApps/SciColSim/old/optirun.swift
   SwiftApps/SciColSim/old/original.2011.1014/
   SwiftApps/SciColSim/old/sites.beagle.quick.xml
   SwiftApps/SciColSim/old/sites.beagle.xml
   SwiftApps/SciColSim/old/snapshots.2012.0123/
   SwiftApps/SciColSim/old/t1.py
   SwiftApps/SciColSim/old/t2.py
   SwiftApps/SciColSim/old/t3.py
   SwiftApps/SciColSim/old/tc
   SwiftApps/SciColSim/old/test-orig.sh
   SwiftApps/SciColSim/old/test-swift.sh
   SwiftApps/SciColSim/optimizer.orig-mac.cpp
Removed:
   SwiftApps/SciColSim/EMAIL
   SwiftApps/SciColSim/RunSwift.sh
   SwiftApps/SciColSim/TimingEstimation.txt
   SwiftApps/SciColSim/annealing.open-issues.swift
   SwiftApps/SciColSim/atomic_times.png
   SwiftApps/SciColSim/atomic_times.txt
   SwiftApps/SciColSim/basiclocal.xml
   SwiftApps/SciColSim/beagle.xml
   SwiftApps/SciColSim/cf
   SwiftApps/SciColSim/convertbest.sh
   SwiftApps/SciColSim/extract4plots
   SwiftApps/SciColSim/getallparams.sh
   SwiftApps/SciColSim/getparamtrace.sh
   SwiftApps/SciColSim/local.xml
   SwiftApps/SciColSim/mathtest.swift
   SwiftApps/SciColSim/optimizer.protomods.cpp
   SwiftApps/SciColSim/optirun.swift
   SwiftApps/SciColSim/original.2011.1014/
   SwiftApps/SciColSim/pads.similar.beagle.xml
   SwiftApps/SciColSim/paramtraceall.sh
   SwiftApps/SciColSim/plot_active.txt
   SwiftApps/SciColSim/plot_cumulative.txt
   SwiftApps/SciColSim/plot_ready_jobs.txt
   SwiftApps/SciColSim/plotit
   SwiftApps/SciColSim/sample.swift.output
   SwiftApps/SciColSim/sample.testopt.py.output
   SwiftApps/SciColSim/showbest.sh
   SwiftApps/SciColSim/sites.beagle.quick.xml
   SwiftApps/SciColSim/sites.beagle.xml
   SwiftApps/SciColSim/snapshots.2012.0123/
   SwiftApps/SciColSim/t1.py
   SwiftApps/SciColSim/t2.py
   SwiftApps/SciColSim/t3.py
   SwiftApps/SciColSim/tc
   SwiftApps/SciColSim/test-orig.sh
   SwiftApps/SciColSim/test-swift.sh
Modified:
   SwiftApps/SciColSim/optimizer.cpp
Log:
reorganization of the SciColSim directory
Deleted: SwiftApps/SciColSim/EMAIL
--- SwiftApps/SciColSim/EMAIL	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/EMAIL	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,474 +0,0 @@
-==== Email trail (cronological order):
-On 10/15/11 8:30 PM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
-> Hi Andrey,
-> I've got a basic serial version of optimizer.cpp running on Beagle (on a login
-> node).  Now Im trying to parallelize it there, and have some questions:
-> 1) You set NWorkers to a constant, 24. In multi_loss, you have this code:
->     for(int i=0; i<Nworkers; i++){
->         for(int j=0; j<5; j++){
->             un[i]->set_parameter(params[j],j);
->             dispatch_group_async(group, CustomQueues[i], ^{
->                 un[i]->evolve_to_target_and_save(istart, iend, Results,
-> Counters);
->             istart += step;
->             iend = min(istart+step,N);
-> Can you explain the intention here? I think the innermost loop is clear: run
-> evolve() 24 times in parallel, partitioning the istart..iend range among the
-> 24 workers.  But I dont understand the outermost loop, which seems to do the
-> entire inner loop 24 (NWorkers) times. I can understand the idea of doing the
-> entire inner loop some number of times. But from the above, I presume that
-> evolve would be run NWorkers^2 times, or 24*24 times.  Was that the intention?
-> 2) If you had many processors available (as you do on Beagle) would you want
-> to run set NWorkers higher? I think you mentioned something in out discussion
-> Friday about "a thousand" workers being useful. Ie, NWorkers for the innermost
-> loop could be 1000.  Was that really what you meant? What would be a
-> mathematically/scientifically useful value for the NWorkers in the innermost
-> loop?
-> Further: if you do want an NWorkers >> 24, would you still do the evolve
-> NWorkers^2 times?  I dont think you'd really want 1000*1000 = 1M evolve calls,
-> given how many outer loops you have at higher levels of the code, including in
-> the Python wrapper.
-> 3) We'll need to discuss what values make sense for the outer loops
-> (multi_annealing and the .py wrapper) once I have this working in parallel.
-> 4) Can you give me a sentence or two about what this code is doing?  I think I
-> understand the outer annealing logic, but I have not dug into the code within
-> evolve...() at all. I think you might have explained it once back in January
-> (before you recoded in C) but I dont recall. If you have a paper or a web page
-> on what youre computing here, that would be interesting for me to read, and to
-> help write a slide on this for the Beagle review.
-Re: Status and questions on optimizer code
-From :	 andrey rzhetsky <arzhetsk at medicine.bsd.uchicago.edu>
-Subject :	Re: Status and questions on optimizer code
-To :	 Michael Wilde <wilde at mcs.anl.gov>
-Sun, Oct 16, 2011 08:28 AM
-Hi Mike,
-1. I think, you just uncovered a stupid bug on my part -- thank you!  There
-should be only one loop (the outer one).
-2. Yes, of course -- 1000, or even 10000 (I can increase the number of
-repeats then).
-3. OK
-4. The code simulates exploration of a chemical network by a research
-community.  The five major parameters determine the strategy of exploration,
-"target" is the number of new interactions discovered and the loss is the
-number of experiments per one new positive finding.  I can provide you with
-figures and slides, if that would help.
-Thank you!
-With kind regards,
-Andrey
-On 10/16/11 9:13 AM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
-> Hi Andrey,
-> Looking deeper, I think the bug was simply that the first for() statement
-> should have enclosed just the parameter setting loop.  In other words, the top
-> of multi_loss should start with:
-> Then the real work is done by the next loop:
->     for(i=0; i<Nworkers; i++){
-> Can you confirm that this looks correct to you?
-> I made that change, and the code now seems to run as I would expect. I will
-> send you some output as soon as I clean up my debugging output.
-> Next, I made the code run with 24-way parallelism on a Beagle login node using
-> "OpenMP", simply by adding one "pragma" statement in front of the main worker
-> loop above. So that part of the code now looks like this:
->     int i;
->     #pragma omp parallel for private (i)
-> and each call to evolve...() is now done in parallel (with all the Mac
-> dispatch statements commented out).  I will test, but I *think* that the same
-> code will run just as well in parallel on your multicore Macs, perhaps just a
-> *tiny* bit slower than under Grand Central Dispatch (likely not a noticeable
-> difference).
-> Now, we have 2 choices:
-> 1) I can simply replace the Python driver script with a Swift script, to do
-> many runs of the optimizer in parallel.  That would give you the ability to
-> run *many* 24-core optimization runs in parallel, each using 24 cores.  So for
-> example, in your current Python script you do this:
-> for target in range(58,1009,50):
->   for i in range(15):
-> So thats about 20 x 15 = 300 invocations of optimizer. I *think* that each of
-> these runs is totally independent and can run in parallel, correct?
-> So A simple Swift script not much longer than the Python script, along with a
-> few beagle-specific configuration files, will enable all 300 jobs to run in
-> parallel, giving you 300 x 24 (=7200) cores running in parallel. Of course,
-> you can seldom *get* that many cores because the machine is heavily loaded.
-> But you may be able to get 10-30 nodes on a daily basis.  We'll need to
-> experiment with this.
-> As a *next* step after, we should consider the benefits of changing the value
-> of NWorkers to > 24.  24 is the "easy" limit on Beagle because we can get
-> 24-way parallelism on each node with just that one "pragma" statement.  We can
-> get much greater parallelism with Swift in the inner loop, but for that we
-> need to break up the program a bit more, to have Swift run the inner loop as a
-> separate program, and then return the aggregated results in a file. Even for
-> this option, there are two alternative methods:
-> - we make optimizer call Swift once for each round of parallel annealing. This
-> is fairly easy. It is somewhat limiting to overall parallelism, in that only
-> one round at a time can run. But It may be very adequate.
-> - we break the program up further into parallelizable chunks, in which case
-> you have a lot of flexibility and the work always gets done in a near-optimal
-> manner regardless of the shape of a given optimization run (in terms of the
-> various nested loop sizes and evolve() execution times.
-> I think we'll need to discuss this in person over a whiteboard, but I think I
-> have enough knowledge of the program to at least show you a few alternatives.
-> The main question at the moment, I think, is simply to understand the
-> math/science benefits of extending NWorkers beyond the "low hanging fruit"
-> limit of 24.  What is your assessment of that benefit, Andrey?
------ Forwarded Message -----
-From: "andrey rzhetsky" <arzhetsk at medicine.bsd.uchicago.edu>
-To: "Michael Wilde" <wilde at mcs.anl.gov>
-Sent: Sunday, October 16, 2011 12:08:25 PM
-Subject: Re: Status and questions on optimizer code
-Mike,
-It would be fantastic to have 1000 or 10000 workers (with larger number of
-re-runs -- it would improve precision of my analysis drastically!).
-All the very best,
-Andrey
-On 10/17/11 8:29 AM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
-> Hi Andrey,
-> Can we meet today to discuss the optimizer? I'd like to show you what Ive done
-> and discuss with you next steps towards getting you running on Beagle. I can
-> meet any time from 10:30 to 3:00.
-> Do you already have a CI and Beagle login and a project set up for Beagle use?
-> If not, we should get that started.
-> On the technical side, I have a question about the the typical shape of your
-> optimization runs.
-> With the sample Python script you gave me, I think we have the following
-> nested iterations in the code:
-> 20 targets (parallel)
->   15 repeats (parallel)
->     100 Annealing_cycles (serial)
->        6 repeats (serial)
->          1000 to 10000 annealing_repeats (parallel)   # NOTE (1/29 mw): should this be called "reruns"?
->            evolve()
-> The main question I have at this point is regarding the strategy for
-> increasing the innermost annealing repeats (currently 1,000 divided among 24
-> workers; desired to increase to 10,000).
-> The outermost loops in my Swift tests are done in parallel. Thus we can have a
-> 300 optimizations going in parallel and 24 annealings in parallel for a total
-> of 7,200 parallel tasks.
-> The question is: if you will always have a sizeable number of parallel
-> iterations in the outer loops, we dont need to change anything in the inner
-> loop to get more parallelism. In other words, we already have more parallelism
-> than we have CPUs available.
-> 7200 CPUs is about 42% of the overall Beagle system.  It will be very rare
-> that we we could get that many cores all at once.  But  think we can regularly
-> get say 500 to 2000 cores on a daily basis.
-> On the other hand, if you expect to regularly run tests of *single* annealing
-> cycles and want to speed those up, then indeed it may be worth changing the
-> code structure.
-> When me meet I'll try to give you an idea of whats involved. Basically we need
-> to change the structure of the annealing loop to create a function
-> "multi_loss_setup" as a separate executable which defines the annealing
-> parameters and writes them to a file; make multi_loss a separate executable;
-> create another executable "multi_loss_summarize" which reduces the results.
-> We can probably combine multi_loss_summarize into multi_loss_setup.
-> This is not very hard to do, but still sounds to me like a week of programming
-> to get all all restructured and tested.  Before investing that effort, we
-> should discuss if it will give you any additional performance gains over just
-> running many optimizations in parallel.
-> I need to run timings on the annealing cycles to see how that change across
-> the parameter space, to see if we can just increase the repeats to 10,000 with
-> no changes to the code. I think the feasibility of doing this the "easy way"
-> is based on how long the longest annealings take at the high end of the
-> parameter space.
-> Regards,
-> - Mike
-From: "Andrey Rzhetsky" <arzhetsk at medicine.bsd.uchicago.edu>
-Sent: Monday, October 17, 2011 8:40:17 AM
-Subject: Re: Meet today to discuss optimizer?
-Hi Mike,
-The 6 (or more) annealing repeats can be run in parallel too.
-Unfortunately, around 10:15 I have to rush to Evanston to CBC meeting for
-the rest of the day (we can chat before, if you have a minute, I am in my
-office).
-I don't have Beagle login, unfortunately.
-Typically, I will have a sizeable outer loop, so, probably, the current
-24-worker setup is fine.
-Thank you very much for helping me out!
-All the best,
-Andrey
-On 10/18/11 1:52 PM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
-> Hi Andrey,
-> Here's a quick update:
-> - I am now running the optimizer on Beagle compute nodes under Swift.
-> I attach a few tar files of sample runs at reduced parameter values (to shrink
-> the run time for debugging and learning the code's behavior);
-> Now Im trying to run some subset of the full-length parameters you gave me in
-> the python file.  Ive got 3 Beagle compute nodes allocated at the moment (72
-> cores total) and Im seeing these times from multi_loss with N=1000 repeats:
-> sandbox$ grep multi_  ./jobs/*/*/output/*.out
-> ./jobs/0/optimizer-01p7lhhk/output/T408.R1.out:multi_loss(N=1000) elapsed
-> time: 122.742 seconds 2.04571 minutes
-> time: 123.979 seconds 2.06631 minutes
-> time: 123.624 seconds 2.0604 minutes
-> ./jobs/t/optimizer-t0p7lhhk/output/T958.R1.out:multi_loss(N=1000) elapsed
-> time: 1431.09 seconds 23.8514 minutes
-> ./jobs/x/optimizer-x0p7lhhk/output/T708.R1.out:multi_loss(N=1000) elapsed
-> time: 627.074 seconds 10.4512 minutes
-> time: 790.652 seconds 13.1775 minutes
-> Each run of optimizer is going to a file name T(target).R(repeat).out
-> So we're seeing 23.8 mins for 1000 repeats at target=958 and 10-13 mins at
-> target=708. The 1000 repeats are spread over 24 cores each.
-> Whats your time availability later in the week to discuss this further, and to
-> see if either (a) I can show you how to run this version or (b) we can get a
-> set of production run descriptions from you and you can run them yourself?
-> In the compressed tar file at http://www.ci.uchicago.edu/~wilde/AR.snap.01.tgz
-> you will find:
-> - the swift script that I use instead of the Python driver to run the
-> optimizer in parallel (along beagle.xml that specifies scheduler parameters
-> for Beagle like time, cores, queue name and project ID)
-> - the slightly modified version of optimizer (changes in multi_loss() to
-> correct the loops, changes to use OpenMP instead of Grand Central Dispatch,
-> and a few changes in output logging).
-> - a few run directories of runs with shortened parameter settings.
-> If we continue working together on this, we should set up a way to share code
-> using a repository like Subversion (svn).  Thats pretty easy once you master a
-> few basic commands.
-> Regards,
-> - Mike
-Sent: Tuesday, October 18, 2011 3:57:36 PM
-Mike,
-Thank you!  Are you around now?  I would be also happy to carve some time
-tomorrow, if this works for you.
-With kind regards,
-Andrey
-On 10/19/11 12:10 PM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
-> Hi Andrey,
-> Im in meetings today till about 3PM. Are you available at say 3:30 or later?
-> I did a larger run last night. Only one smaller optimizer run *fully*
-> finished, but many others made significant progress.  The results are at:
->   http://www.ci.uchicago.edu/~wilde/AR.optimizer.out.2010.1018.tgz
-> If you have time, could you take a look at that run and see if the
-> optimizations look like they have been running as expected? Ive made only a
-> few cosmetic changes to your debug output.
-> I submitted the run at 21:20; it started running at about 21:27; by about
-> 23:10 it had acquired 12 nodes (x 24 cores each). It ended about 23:18 when
-> the first job exceeded its time limit of 5 hours. Im still trying to calibrate
-> how much time each optimizer invocation needs, and whether some of the
-> internal iterations can be further spread out.  Also how to organize the run
-> so that optimizations that time out  can be re-run with the smallest
-> reasonable failure unit.
-Sent: Wednesday, October 26, 2011 8:40:21 PM
-Subject: Re: Question on inner annealing loop
-Mike,
-> Im confused on 3 points here:
-> - the inner loop would always be done between 1 and 5 times, right?
-Correct.
-> - could each of those times really be done in parallel? (I'll try to determine
-> this by inspection).
-Not really -- the acceptance of parameter changes depends on the loss in
-between.
-> - when we last met in your office, I *thought* you indicated that this inner
-> loop could be done just *once*.  Was that what you meant?  And if so, for
-> which of the 5 vars?
-Nope, has to be repeated over and over.
-All the very best,
-Andrey
-On 10/26/11 10:42 PM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
-> OK, all that makes sense, Andrey. But then do you recall what you suggested
-> when we met?
-> Lets label the loops as follows:
-> a) 20 targets (parallel)
-> b)   15 repeats (parallel)
-> c)     100 Annealing_cycles (serial)
-> d)        6 repeats (serial)
-> e)         1000 to 10000 annealing_repeats (parallel)
-> f)            evolve()
-> What I recalled from our last discussion was that I should reduce loop (c)
-> from 100 to 50 or 25, and loop (d) to 1.  But since reducing loop (d) doesn't
-> make sense, do you recall suggesting any other reduction?
-> If not, no problem, I think I know how to proceed.
-> Thanks,
-> - Mike
-Sent: Thursday, October 27, 2011 2:54:06 AM
-Hi Mike,
-I suggested reducing (b) to 1.
-With kind regards,
-Andrey
Deleted: SwiftApps/SciColSim/RunSwift.sh
--- SwiftApps/SciColSim/RunSwift.sh	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/RunSwift.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,49 +0,0 @@
-#!/bin/bash
-# ./Runswift local to run on sandbox
-# ./Runswift clustersmall to run on beagle pbs cluster at small scale
-# ./Runswift clusterquick to run on beagle pbs cluster at large scale
-escapecode=$(echo -n -e '\033')
-count=$(head -1 counter.txt);
-expr $count + 1 > counter.txt
-mkdir run$count
-cp /home/ketan/SciColSim/*.swift run$count/
-cp /home/ketan/SciColSim/sites.beagle.xml run$count/
-cp /home/ketan/SciColSim/sites.beagle.quick.xml run$count/
-cp local.xml run$count/
-cp /home/ketan/SciColSim/tc run$count/
-cp /home/ketan/SciColSim/movie_graph.txt run$count/
-cp /home/ketan/SciColSim/cf run$count/
-cd run$count
-if [ $1 = "local" ]
-then
- #SWIFT_HEAP_MAX=7000M swift -tc.file tc -sites.file local.xml -config cf annealing.swift -e33="$escapecode" -nworkers=36 >& swift.out
- #Total jobs = 6 * 1 * 120/20 * 3 * 100 = 10,800
- SWIFT_HEAP_MAX=7000M swift -tc.file tc -sites.file local.xml -config cf annealing.swift -e33="$escapecode" -nworkers=6 -minrange=58 -maxrange=64 -rangeinc=1 -evoreruns=120 -nreps=1 -alphai=0 -alpham=0 -beta=4.0 -gamma=50.0 -delta=-1 -annealingcycles=100 -rerunsperapp=20  >& swift.out
-elif [ $1 = "clusterbig" ]
-then
- SWIFT_HEAP_MAX=7000M swift -tc.file tc -sites.file sites.beagle.xml -config cf annealing.swift -e33="$escapecode" -nworkers=24 -rangeinc=50 -evoreruns=960 -startingjump=2.3 -alphai=0 -alpham=0 -beta=4.0 -gamma=50.0 -delta=-1 -annealingcycles=100 -rerunsperapp=192  >& swift.out
-elif [ $1 = "clustersmall" ]
-then
- SWIFT_HEAP_MAX=7000M swift -tc.file tc -sites.file sites.beagle.xml -config cf annealing.swift \-e33="$escapecode" \
-      >& swift.out
-elif [ $1 = "clusterquick" ]
-then
-#target_innovation=(1009-58)/50=~20
-#repeats=nreps=1
-# 3 repeats constant (serial)
-#annealing_cycles=100 (serial)
-#rerunsperapp=192
-#evoreruns=960
-#J=evoreruns/rerunsperapp=960/192=5
-#Total parallel jobs = (maxrange-minrange)/rangeinc * nreps * (evoreruns/rerunsperapp) = (1009-58)/50 * 1 * 960/192 = 20*5 = 100 Jobs = 2400 openmp jobs in parallel
- SWIFT_HEAP_MAX=7000M swift -tc.file tc -sites.file sites.beagle.quick.xml -config cf annealing.swift -e33="$escapecode" -nworkers=24 -minrange=58 -maxrange=1009 -rangeinc=50 -evoreruns=960 -nreps=1 -alphai=0 -alpham=0 -beta=4.0 -gamma=50.0 -delta=-1 -annealingcycles=100 -rerunsperapp=192  >& swift.out
-fi
Deleted: SwiftApps/SciColSim/TimingEstimation.txt
--- SwiftApps/SciColSim/TimingEstimation.txt	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/TimingEstimation.txt	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,95 +0,0 @@
-SciColSim on Beagle
-Loop Structure
-Following is the loop structure for the SciColSim application at 'full-scale' values:
-~20 target innovation values
- ~15 repeats
-  100 annealing cycles (serial)
-     3 non-fixed vars    (serial)
-       1,000 reruns (=>evolve_reruns/reruns_per_app))
-         call evolve (1 to 50 seconds per rerun)
-Total number of jobs are given by the following expression:
-Number_of_jobs = target_innovation_values x repeats x fixed_reps x annealing_cycles x evolve_reruns/reruns_per_app x num_workers
-               = ceil((max_range - min_range)/range_inc) x repeats x fixed_reps x annealing_cycles x evolve_reruns/reruns_per_app x num_workers
-               = ceil((1009 - 58)/50) x 15 x 3 x 100 x 960/192 x 24
-               = 20 x 15 x 3 x 100 x 5 x 24
-               = 10,800,000
-               = 20 x 15 x 3 x 100 x 1000 x 10 = total core-seconds
-               = 900M core seconds
-               = 900M / 1000 = 900,000 seconds on 1000 cores
-               = 250 hours = 10 days
-Estimated Runtime on a small scale (2 laptops or 24 cores)
-         =10,800,000/24 x (1 to 50 sec)
-         =450,000 to 22,500,000 seconds
-         =5.2 hours to 260 days
-Estimated Runtime on medium scale (40 Beagle nodes or 960 cores)
-         =10,800,000/960 x (1 to 50 sec)
-         =11,250 to 562,500 seconds
-         =3.12 hours to 6.5 days
-Atomic job times of application
-multi_loss(N=1, target=58) elapsed time: 0.116707 seconds 0.00194512 minutes
-multi_loss(N=1, target=108) elapsed time: 0.26613 seconds 0.0044355 minutes
-multi_loss(N=1, target=158) elapsed time: 0.379991 seconds 0.00633318 minutes
-multi_loss(N=1, target=208) elapsed time: 0.576198 seconds 0.0096033 minutes
-multi_loss(N=1, target=258) elapsed time: 1.50121 seconds 0.0250203 minutes
-multi_loss(N=1, target=308) elapsed time: 1.09665 seconds 0.0182775 minutes
-multi_loss(N=1, target=358) elapsed time: 1.49523 seconds 0.0249205 minutes
-multi_loss(N=1, target=408) elapsed time: 2.3056 seconds 0.0384267 minutes
-multi_loss(N=1, target=458) elapsed time: 3.54418 seconds 0.0590697 minutes
-multi_loss(N=1, target=508) elapsed time: 5.10912 seconds 0.085152 minutes
-multi_loss(N=1, target=558) elapsed time: 6.88611 seconds 0.114768 minutes
-multi_loss(N=1, target=608) elapsed time: 8.7683 seconds 0.146138 minutes
-multi_loss(N=1, target=658) elapsed time: 10.0665 seconds 0.167775 minutes
-multi_loss(N=1, target=708) elapsed time: 12.7259 seconds 0.212098 minutes
-multi_loss(N=1, target=758) elapsed time: 14.8005 seconds 0.246675 minutes
-multi_loss(N=1, target=808) elapsed time: 16.8803 seconds 0.281338 minutes
-multi_loss(N=1, target=858) elapsed time: 19.7864 seconds 0.329774 minutes
-multi_loss(N=1, target=908) elapsed time: 23.4506 seconds 0.390843 minutes
-multi_loss(N=1, target=958) elapsed time: 28.7667 seconds 0.479445 minutes
-multi_loss(N=1, target=1008) elapsed time: 49.0841 seconds 0.818069 minutes
Deleted: SwiftApps/SciColSim/annealing.open-issues.swift
--- SwiftApps/SciColSim/annealing.open-issues.swift	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/annealing.open-issues.swift	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,379 +0,0 @@
-import "math";
-import "colortext";
-type file;
-type Res
-    float loss;
-    float sdev;
-global boolean FIX_VARIABLES = true;
-global int var_fixed[] = [1,1,0,0,0];
-global int Nworkers = @toint(@arg("nworkers","4"));
-global int rerunsPerApp;
-(float nx) newx(float x, float dx)
-    float r = (random()) ; // / (pow(2.0,31.0)-1.0);
-    if (r > 0.5)
-        nx = x + (random())*dx; // /(pow(2.0,31.0)-1.0);
-    else
-        nx = x - (random())*dx; // /(pow(2.0,31.0)-1.0);
-    // tracef("newx(%f,%f)=%f\n",x,dx,nx);
-app (file outfile, file loss) evolve (string args[], file graph)
-    evolve @loss args stdout=@outfile ;  // graph is passed implicitly
-app (file x) sumloss(file loss[])
-    sumloss @filenames(loss) stdout=@x;
-  Program structure:
-  main
-  optimizer_sweep() - formerly, python script
-  multi_annealing()
-  multi_loss()
-  evolve()
-  sumloss()
-(file bestfile, file maxfile) multi_annealing (
-    float T_start,
-    float T_end,
-    float Target_rejection,
-    int evolve_reruns,
-    float starting_jump,
-    float params0[],
-    float target_innov,
-    int annealing_cycles)
-    int cycle=10;     // const
-    int NEVOPARAMS=5; // const - 5 params, alpha 1,m through delta, does not include target_innovation
-    float rejection[][];  // [i][j] where i is cycle and j is evolve-parameter (alpha_i, alpha_m, beta, gamma, delta)
-    float x[][], dx[][], curr_loss[], curr_sdev[];
-    Res mlres[][];
-    mlres[0][0] = multi_loss( 0, 0, params0, target_innov, evolve_reruns ); // FIXME: serves for all evolve-params ???
-    tracef("multi_annealing: AR: initial: %f +- %f\n",mlres[0][0].loss,mlres[0][0].sdev);
-    foreach j in [0:NEVOPARAMS-1]
-        x[0][j]=params0[j];
-        dx[0][j] = starting_jump;
-        rejection[0][j] = 0.0;
-        curr_loss[j] = mlres[0][0].loss;
-        curr_sdev[j] = mlres[0][0].sdev;
-    iterate iter_i
-    {    // foreach i in [1:annealing_cycles]
-        int i = iter_i + 1;
-        // set new temperature, rejection threshold, and dx values for this cycle
-        float temperature = T_start*exp( @tofloat(i-1)*(jlog(T_end)-jlog(T_start))/@tofloat(annealing_cycles));
-        tracef(@strcat("multi_annealing: AR: i=%i ....T = ",color(3,"%f"),"\n"), i, temperature);
-        // On each new "major" cycle within the annealing_cycles (other than the first) set new rejection and dx values
-        if ( i %% cycle == 1 && i > 1 )
-            tracef("multi_annealing: new cycle at i=%i\n",i);
-            tracef(color(Pink, "multi_annealing: AR: New cycle at %i: prev dx[0-4]=[%f %f %f %f %f]\n"),i,dx[i-1][0],dx[i-1][1],dx[i-1][2],dx[i-1][3],dx[i-1][4]);
-            foreach  k in [0:NEVOPARAMS-1]
-                float newrejection = rejection[i-1][k] / @tofloat(cycle);
-                if (newrejection > 0.0)
-                    dx[i][k] = dx[i-1][k] / (newrejection / Target_rejection);
-                    // FIXME: re-enable: rejection[i][k]=0.0;
-                else
-                    dx[i][k] = dx[i-1][k] * 2.0;
-                    // FIXME: re-enable: rejection[i][k]=rejection[i-1][k];
-                // FIXME: HANGS? : tracef(color(Red,"Recomputed rejection: i=%d k=%d dx[i][k]=%f\n"), i, k, dx[i][k]);
-            tracef(color(Blue, "multi_annealing: AR: New cycle at %i: dx[0-4]=[%f %f %f %f %f]\n"),i,dx[i][0],dx[i][1],dx[i][2],dx[i][3],dx[i][4]);
-        else
-        { // If not new cycle, set dx[i][*] from previous dx ([i-1]). rejection[i]j] is set later.
-                dx[i][k] = dx[i-1][k];
-        //foreach j in [0:NEVOPARAMS-1] { // Try a new value for each non-fixed param; then write results and accept or reject
-        iterate j
-        {  // Try a new value for each non-fixed param; then write results and accept or reject
-            // float try_x[];
-            int curr = (i * NEVOPARAMS) + j;
-            int prev = curr-1;
-            // tracef("in multi_annealing: i=%i j=%i curr=%i prev=%i\n", i, j, curr, prev);
-            if ( /*(!FIX_VARIABLES) || */ (var_fixed[j]==0) ) {  // Adjustable vars
-                // fixed=1,1,0,0,0: FIXME: FIX_VARIABLES flag has faulty logic but OK when TRUE
-                float try_x[];
-                { // Select the evolve params to try
-                    if ( k < j )
-                        try_x[k] = x[i][k]; // already set x[i][k]
-                    else
-                        if ( k == j )
-                            try_x[k] = newx(x[i-1][j],dx[i-1][j]); // permute x[i-1][j]
-                        else
-                        { // k > j
-                            try_x[k] = x[i-1][k]; // use x[i-1][k] (from prior cycle)
-                tracef(@strcat("multi_annealing: AR: ", color(10,"%f"), " ", color(9,"%i"),"\n"), try_x[j],j);
-                // Up to here, x[] and dx[] are only set for previous i
-                mlres[i][j] = multi_loss(i,j,try_x, target_innov, evolve_reruns); // do the N evolve()'s, N=evolve_reruns
-                tracef("multi_annealing: AR: %f +- %f\n", mlres[i][j].loss, mlres[i][j].sdev);
-                // Beyond this point, x[] and dx[] are being set for this i,j
-                float ALOT=100000000000.0; // 100,000,000,000. = 10^11
-                if (mlres[i][j].loss < ALOT)
-                    tracef("multi_annealing: AF: best_opt_some.txt: %f,%f,%f,%f,%f,%f,%f,%f\n",
-                           target_innov,mlres[i][j].loss,try_x[0],try_x[1],try_x[2],try_x[3],try_x[4],mlres[i][j].sdev);
-                    tracef(color(Red,"multi_annealing: AF: max_dist.txt - tbd\n")); // FIXME: max_dist is global set in evolve()
-                else
-                {  // does this ever occur? if so did we want to still do the ratio computation above???
-                    tracef("multi_annealing: Loss %f > ALOT at [i][j] = [%d][%d]\n", mlres[i][j].loss, i ,j);
-                float ratio = min(1.0, exp( -(mlres[i][j].loss-curr_loss[prev]) / temperature));
-                float r = (random()) ; // / (pow(2.0,31.0)-1.0);  // FIXME: AR: why all the 2^31's ???
-                tracef("multi_annealing: AR: %f vs %f\n", r, ratio);
-                if (r > ratio)
-                {  // Reject new parameter
-                    x[i][j] = x[i-1][j];
-                    rejection[i][j] = rejection[i-1][j] + 1.0;  // FIXME: AR: Is this correct? incr rejection?
-                    curr_loss[curr] = curr_loss[prev];
-                    curr_sdev[curr] = curr_sdev[prev];
-                    // FIXME: AR: the following prints seem to replicate values in the .cpp version - please clarify.
-                    tracef("multi_annealing: AR: %i,%i %i Did not accept: %f (%i)\n", i, j, i, try_x[j], j);
-                    tracef("multi_annealing: AR: %f %f %f %f %f\n", try_x[0],try_x[1],try_x[2],try_x[3],try_x[4]);
-                else
-                {           // Accept new parameter
-                    tracef("multi_annealing: Accepting try_x[j], i=%i j=%i\n",i,j);
-                    x[i][j] = try_x[j];
-                    rejection[i][j] = rejection[i-1][j];  // FIXME: AR: Is this correct? no incr of rejection?
-                    tracef("multi_annealing: Accepting try_x[j], i=%i j=%i try_x[j]=%f\n",i,j,try_x[j]);
-                    curr_loss[curr] = mlres[i][j].loss;
-                    curr_sdev[curr] = mlres[i][j].sdev;
-                    float rj[];
-                    {  // FIXME!!!
-                        if (k <= j)
-                            rj[k] = rejection[i][k]; // Was either set from previous j or just set for this j
-                        else
-                            rj[k] = rejection[i-1][k]; // Not yet set, use previous
-                    tracef(@strcat("multi_annealing: AR: [%i][%i] ", color(8,"Rejection counts: "),
-                                   color(1,"%f"), " ", color(7,"%f"), " ", color(5,"%f"), " ", color(9,"%f"), " ", color(6,"%f"), "\n\n"),
-                           i, j, rj[0], rj[1], rj[2], rj[3], rj[4]);
-                    tracef(@strcat("multi_annealing: AR: %i ", color(8,"***** Did accept! "),
-                           i, try_x[0], try_x[1], try_x[2], try_x[3], try_x[4]);
-            else
-            { // Fixed Vars
-                // dx[i][j] not set for fixed vars
-        } until(j == NEVOPARAMS-1);
-    } until(iter_i == (annealing_cycles-1));
-(Res r) multi_loss( int ci, int cj, float x[], float target_innov, int evolve_reruns )
-// (Res r, Stats s) multi_loss( int ci, int cj, float x[], float target_innov, int evolve_reruns ) FIXME: To obtain stats
-    file rfile[];
-    file ofile[]; // FIXME: to obtain timings and otehr stats
-    tracef("multi_loss: entered: ci=%i cj=%i target_innov=%f evolve_reruns=%i x=%q\n",ci, cj, target_innov,evolve_reruns,x);
-    int appCalls = @toint(@tofloat(evolve_reruns) / @tofloat(rerunsPerApp));  // FIXME: handle fractional issues and rounding etc. For now must divide evenly
-    tracef("multi_loss appCalls=%i\n", appCalls);
-    foreach i in [1:appCalls] {  // repeats of the evolove() - same as n_reruns
-        file outfile; // FIXME: map and save in future
-        string args[] = [ // FIXME: move this to a setargs() function
-            //    alpha_i        alpha_m        beta           gamma          delta          target_innov
-            @strcat(x[0]), @strcat(x[1]), @strcat(x[2]), @strcat(x[3]), @strcat(x[4]), @strcat(target_innov),
-            //     n_epochs n_steps evolve_reruns           range
-            //    "40000",  "20",   @strcat(evolve_reruns), "2",
-            "40000",  "20",   @strcat(rerunsPerApp),  "2",
-            //    verbose_level
-            "1",
-            //    T_start T_end   Annealing_steps Target_rejection Starting_jump
-            "2.",   "0.01", "2",            "0.3",           "2.3",
-            //    FREEZE: alpha_i alpha_m beta gamma delta
-            "1",    "1",    "0", "0",  "0",
-            //   operation-code:(m,a) Nworkers           seed
-            "m",                 @strcat(Nworkers), "1234567" ];
-        file graph <"movie_graph.txt">;
-        (outfile, rfile[i]) = evolve(args,graph);
-        // (ofile[i], rfile[i]) = evolve(args,graph);
-        tracef("multi_loss: i=%i calling evolve, args=%q\n", i, args);
-        // tracef("multi_loss: after evolve: i=%i %k %k\n", i, outfile, rfile[i]);
-    file sumfile = sumloss(rfile);
-    r = readData(sumfile);
-    tracef("multi_loss: returning: ci=%i cj=%i r.loss=%f r.sdev=%f\n",ci,cj,r.loss,r.sdev);
-    // file statfile = sumstats(ofile);  FIXME: to obtain timings and otehr stats
-    // s = readStat(statsfile);          FIXME: to obtain timings and otehr stats
-optimizer_sweep() // Implements logic of python driver script
-    int minrange=58;
-    int maxrange=59;
-    int rangeinc=50;
-    //int maxrange=1009;
-    //int maxrange=209;
-    // FIXME: add provision for random priming and random param values when x[i] == -100 (see optimizer.cpp main())
-    int nreps=1; // 15
-//    file bestfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".best_opt_some")>;
-//    file maxfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".max_dist")>;
-    foreach target_innov in [minrange:maxrange:rangeinc]
-        foreach rep in [1:nreps]
-            file outfile;  // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".out")>;
-            file lossfile; // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".loss_data")>;
-  (outfile,lossfile) = multi_annealing(
-  T_start          = 2.0,
-  T_end            = 0.01,
-  Target_rejection = 0.3,
-  evolve_reruns    = 10,
-  starting_jump    = 2.3,
-  params0[]        = [0.0, 0.0, 4.0, 50.0, -1.0],
-  @tofloat(target_innov),
-  annealing_cycles = 2);
-                2.0,
-                0.01,
-                0.3,
-                100,
-                2.3,
-                [0.0, 0.0, 4.0, 50.0, -1.0],
-                30);
-rerunsPerApp = 100;
-main()
-    optimizer_sweep();
-main();
-  main
-  optimizer_sweep()
-  multi_annealing()
-  multi_loss()
-  evolve()
-  sumloss()
-  Example parameter sets:
-  for target in range(58,59,50):
-  for i in range(1):
-  args="./toptimizer 0 0 4 50 -1 "+target+" 40000 20 75    2 1 2. 0.01 2 0.3 2.3 1 1 1 0 0 m // > out.T"+str(target)+".i"+str(i)
-  os.system(args);
-  string fastargs1[] = [
-  "0", "0", "4", "50", "-1", @strcat(target),
-  "40000", "20", "1000", "2",
-  "1",
-  "2.", "0.01", "100", "0.3", "2.3",
-  "1", "1", "0", "0", "0"];
-  string fastargs2[] = [
-  "1",
-  "2.", "0.01",  "5", "0.3", "2.3",
-  "1", "1", "0", "0", "0", "m"];
-  string fastargs3[] = [
-  "40000", "20", @strcat(repeats), "2",
-  "1",
-(string args[]) setargs()
-    // string longargs[] = @strcat("0 0 4 50 -1 ",target," 40000 20 1000 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0 m");
-    //  [alpha_i alpha_m beta gamma delta target_innov
-    //  [n_epochs n_steps n_reruns] [range]
-    //  [verbose_level]
-    //  [T_start T_end Annealing_steps Target_rejection Starting_jump]
-    //  [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta] [operation-code:(m,a) Nworkers]
-////////////////// HOLD JUNK
-//                    tracef(@strcat("multi_annealing: AR: %i ", color(8,"Rejection counts: "),
-//                                   color( /* 2 */ 1," %f"), "\n\n"),
-//                                   i, rejection[i][j] ); // , rejection[i][1], rejection[i][2], rejection[i][3], rejection[i][4]);
-// FIXME: determine correct rejection[] values to avoid hanging:
-//                                   color( /* 2 */ 1," %f"), color(7," %f"), color(5," %f"), color(9," %f"), color(6," %f"), "\n\n"),
-//                                   rejection[i][0], rejection[i][1], rejection[i][2], rejection[i][3], rejection[i][4]);
-// END FIXME
Deleted: SwiftApps/SciColSim/atomic_times.png
(Binary files differ)
Deleted: SwiftApps/SciColSim/atomic_times.txt
--- SwiftApps/SciColSim/atomic_times.txt	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/atomic_times.txt	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,21 +0,0 @@
- 58  0.116707
-108  0.26613
-158  0.379991
-208  0.576198
-258  1.50121
-308  1.09665
-358  1.49523
-408  2.3056
-458  3.54418
-508  5.10912
-558  6.88611
-608  8.7683
-658 10.0665
-708 12.7259
-758 14.8005
-808 16.8803
-858 19.7864
-908 23.4506
-958 28.7667
-1008 49.0841
Deleted: SwiftApps/SciColSim/basiclocal.xml
--- SwiftApps/SciColSim/basiclocal.xml	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/basiclocal.xml	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,10 +0,0 @@
-<config>
-   <pool handle="localhost">
-     <execution provider="local" url="none" />
-     <filesystem provider="local"/>
-     <workdirectory>/home/wilde/swift/lab/swiftwork</workdirectory>
-     <profile namespace="karajan" key="jobThrottle">0</profile>
-   </pool>
-</config>
Deleted: SwiftApps/SciColSim/beagle.xml
--- SwiftApps/SciColSim/beagle.xml	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/beagle.xml	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,60 +0,0 @@
-<config>
-<!-- From Glen: used w/ "Swift svn swift-r4813 (swift modified locally) cog-r3175" -->
-  <pool handle="beagle">
-    <execution provider="coaster" jobmanager="local:pbs" url="none"/>
-    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
-    <profile key="jobsPerNode" namespace="globus">1</profile>
-    <profile namespace="env" key="OMP_NUM_THREADS">24</profile>
-    <profile namespace="globus" key="maxwalltime">02:00:00</profile>
-    <profile namespace="globus" key="maxTime">14400</profile>
-    <profile namespace="globus" key="slots">20</profile>
-    <profile namespace="globus" key="nodeGranularity">1</profile>
-    <profile namespace="globus" key="maxNodes">1</profile>
-    <profile namespace="globus" key="lowOverAllocation">100</profile>
-    <profile namespace="globus" key="highOverAllocation">100</profile>
-    <profile namespace="karajan" key="jobThrottle">.15</profile>
-    <profile namespace="karajan" key="initialScore">10000</profile>
-    <profile namespace="globus" key="project">CI-MCB000119</profile>
-    <profile namespace="globus" key="queue">route</profile>
-    <workdirectory >/lustre/beagle/wilde/swiftwork</workdirectory>
-  </pool>
-<!-- From Justin's swift-devel page:
-<import file="sys.xml"/>
-<set name="wdir" value="/lustre/beagle/{user.name}/work"/>
-<echo message="setting workDirectory to: {wdir}"/>
-<pool handle="beagle-pbs">
-  <execution jobmanager="local:pbs" provider="coaster" url="none"/>
-  <profile namespace="globus" key="maxWallTime">1</profile>
-  <profile namespace="globus" key="maxTime">7200</profile>
-    pbs.aprun;pbs.mpp;depth=24
-  </profile>
-  <profile key="jobsPerNode" namespace="globus">24</profile>
-  <profile key="slots" namespace="globus">1</profile>
-  <profile key="nodeGranularity" namespace="globus">1</profile>
-  <profile key="maxNodes" namespace="globus">1</profile>
-  <profile key="queue" namespace="globus">batch</profile>
-  <profile key="jobThrottle" namespace="karajan">5.99</profile>
-  <profile key="initialScore" namespace="karajan">10000</profile>
-  <profile namespace="globus" key="project">_PROJECT_</profile>
-  <profile namespace="globus" key="project">_QUEUE_</profile>
-  <filesystem provider="local" url="none" />
-  <workdirectory>{wdir}</workdirectory>
-</pool>
-</config>
Copied: SwiftApps/SciColSim/bin/convertbest.sh (from rev 5635, SwiftApps/SciColSim/convertbest.sh)
--- SwiftApps/SciColSim/bin/convertbest.sh	                        (rev 0)
+++ SwiftApps/SciColSim/bin/convertbest.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,6 @@
+#! /bin/sh
+for f in best*.txt; do
+  out=$(basename $f .txt).fmt
+  ../showbest.sh <$f >$out
+done
Added: SwiftApps/SciColSim/bin/extract4plots
--- SwiftApps/SciColSim/bin/extract4plots	                        (rev 0)
+++ SwiftApps/SciColSim/bin/extract4plots	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,42 @@
+#!/bin/bash
+#usage: ./swiftoutput2plot <swift.outfile>
+SWIFTOUTFILE=$1
+#extract start time
+TMPDATE=`grep -i progress $SWIFTOUTFILE | head -n 1 | cut -f4-9 -d ' '`
+START_TIME=`date +%s -d "$TMPDATE"`
+#extract end time
+TMPDATE=`grep -i progress $SWIFTOUTFILE | tail -n 1 | cut -f4-9 -d ' '`
+END_TIME=`date +%s -d "$TMPDATE"`
+#duration
+DIFFTIME=$((END_TIME - START_TIME))
+#extract active runs in a file
+grep -o -i "Active:[0-9]*" $SWIFTOUTFILE | awk -F: '{print $2}' > active.txt
+#extract successful completions in a file
+grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE | awk -F: '{print $2}' > cumulative.txt
+#prepare tics
+activelines=`wc -l active.txt | awk '{print $1}'`
+cumulines=`wc -l cumulative.txt | awk '{print $1}'`
+activelinespertic=`echo "scale=5 ; $DIFFTIME / $activelines" | bc`
+seq 0 $activelinespertic $DIFFTIME > activetics.txt
+cumulinespertic=`echo "scale=5 ; $DIFFTIME / $cumulines" | bc`
+seq 0 $cumulinespertic $DIFFTIME > cumultics.txt
+#final plot data
+paste activetics.txt active.txt > plot_active.txt
+paste cumultics.txt cumulative.txt > plot_cumulative.txt
+grep  "T =" $SWIFTOUTFILE | awk '{print $6}' | cut -c8- | sed 's/....$//' > T.data
+grep multi_annealing $SWIFTOUTFILE | grep "1;30" | awk '{print $3}' | cut -c11- | sed 's/....$//' > anneal.data
+grep returning $SWIFTOUTFILE | awk '{print $3, $4, $5, $6}' | sed -e 's/'ci='//' -e 's/'cj='//' -e 's/'r.loss='//' -e 's/'r.sdev='//' | sort -t' ' -k 1,2n > multiloss.txt
Property changes on: SwiftApps/SciColSim/bin/extract4plots
___________________________________________________________________
Added: svn:executable
Copied: SwiftApps/SciColSim/bin/getallparams.sh (from rev 5635, SwiftApps/SciColSim/getallparams.sh)
--- SwiftApps/SciColSim/bin/getallparams.sh	                        (rev 0)
+++ SwiftApps/SciColSim/bin/getallparams.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,10 @@
+#! /bin/sh
+# targetinno=${1:-58}
+grep 'calling evolve' swift.out | # grep ,$targetinno, |
+  sed -e 's/^.*\[//' \
+      -e 's/\]$//' \
+      -e 's/,/ /g' \
+      -e 's/\(\......\)[0-9]* /\1 /g' |
+  awk '{print $3, $4, $5}' | uniq
Added: SwiftApps/SciColSim/bin/getparamtrace.sh
--- SwiftApps/SciColSim/bin/getparamtrace.sh	                        (rev 0)
+++ SwiftApps/SciColSim/bin/getparamtrace.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,9 @@
+#! /bin/sh
+targetinno=${1:-58}
+grep 'calling evolve' swift.out | grep ,$targetinno, |
+      -e 's/\]$//' \
+      -e 's/,/ /g' \
Property changes on: SwiftApps/SciColSim/bin/getparamtrace.sh
Copied: SwiftApps/SciColSim/bin/paramtraceall.sh (from rev 5634, SwiftApps/SciColSim/paramtraceall.sh)
--- SwiftApps/SciColSim/bin/paramtraceall.sh	                        (rev 0)
+++ SwiftApps/SciColSim/bin/paramtraceall.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,7 @@
+for ti in $(seq 58 70); do
+  echo
+  echo "=======" $ti ; /home/wilde/AndreysOptimizer/src/getparamtrace.sh $ti
+  echo
+done
Copied: SwiftApps/SciColSim/bin/showbest.sh (from rev 5634, SwiftApps/SciColSim/showbest.sh)
--- SwiftApps/SciColSim/bin/showbest.sh	                        (rev 0)
+++ SwiftApps/SciColSim/bin/showbest.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,8 @@
+#! /bin/sh
+awk '{
+  printf( "N %2d %2d %10.5f %5.2f | %5.2f %10.5f [ %5.2f %5.2f %10.5f %10.5f %10.5f ] %10.5f\n",
+  $2, $3, $4, $5, $7, $8, $10, $11, $12, $13, $14, $16);
Deleted: SwiftApps/SciColSim/cf
--- SwiftApps/SciColSim/cf	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/cf	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,7 +0,0 @@
-wrapperlog.always.transfer=true
-sitedir.keep=true
-execution.retries=3
-lazy.errors=true
-status.mode=provider
-use.provider.staging=false
-provider.staging.pin.swiftfiles=false
Deleted: SwiftApps/SciColSim/colortext.swift
--- SwiftApps/SciColSim/colortext.swift	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/colortext.swift	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,90 +0,0 @@
-global string e33; // = @sprintf("\\e") or  @arg("e33");
-if( @arg("e33","null") == "null" ) {
-  e33 = @sprintf("\\e");
-else {
-  e33 = @arg("e33");
-global string endEscape = "[0m";
-// Color codes used in Andrey's cpp optimizer:
-global int Black = 0;
-global int Blue = 1;
-global int BlackOnBlue = 2;
-global int Pink = 3;
-global int GoldOnBlue = 4;
-global int BlueOnGray = 5;
-global int Red = 6;
-global int Gold = 7;
-global int BlueOnGold = 8;
-global int Gray = 9;
-global int BlackOnGray = 10;
-# Black = 0;
-# Blue = 1;
-# BlackOnBlue = 2;
-# Pink = 3;
-# GoldOnBlue = 4;
-# BlueOnGray = 5;
-# Red = 6;
-# Gold = 7;
-# BlueOnGold = 8;
-# Gray = 9;
-# BlackOnGray = 10;
-global string colorCode[] = [
- "[1;29m",      # Black = 0;
- "[1;34m",	# Blue = 1;
- "[1;44m",	# BlackOnBlue = 2;
- "[1;35m",	# Pink = 3;
- "[1;33;44m",	# GoldOnBlue = 4;
- "[1;47;34m",	# BlueOnGray = 5;
- "[1;1;31m",	# Red = 6;
- "[1;1;33m",	# Gold = 7;
- "[1;1;43;34m",	# BlueOnGold = 8;
- "[1;1;37m",	# Gray = 9;
- "[1;30;47m",	# BlackOnGray = 10;
-(string s) color(int c, string ins)
-  s = @strcat(e33,colorCode[c],ins,e33,endEscape);
-(string s) ncolor(int c, string ins) // Can use this version if \\e handling is available in current Swift
-  s = @sprintf(@strcat("\\e",colorCode[c],ins,"\\e",endEscape));  // sprintf applies \\e escape processing
-(string s) OLDcolor(int c, string ins)
-    switch(c){
-        case 0:
-            s = @strcat(e33,"[1;29m",ins,e33,"[0m");
-        case 1:
-            s = @strcat(e33,"[1;34m",ins,e33,"[0m");
-        case 2:
-            s = @strcat(e33,"[1;44m",ins,e33,"[0m");
-        case 3:
-            s = @strcat(e33,"[1;35m",ins,e33,"[0m");
-        case 4:
-            s = @strcat(e33,"[1;33;44m",ins,e33,"[0m");
-        case 5:
-            s = @strcat(e33,"[1;47;34m",ins,e33,"[0m");
-        case 6:
-            s = @strcat(e33,"[1;1;31m",ins,e33,"[0m");
-        case 7:
-            s = @strcat(e33,"[1;1;33m",ins,e33,"[0m");
-        case 8:
-            s = @strcat(e33,"[1;1;43;34m",ins,e33,"[0m");
-        case 9:
-            s = @strcat(e33,"[1;1;37m",ins,e33,"[0m");
-        case 10:
-            s = @strcat(e33,"[1;30;47m",ins,e33,"[0m");
-        default:
-            s = ins;
Copied: SwiftApps/SciColSim/colortext.swift (from rev 5634, SwiftApps/SciColSim/colortext.swift)
--- SwiftApps/SciColSim/colortext.swift	                        (rev 0)
@@ -0,0 +1,90 @@
+global string e33; // = @sprintf("\\e") or  @arg("e33");
+if( @arg("e33","null") == "null" ) {
+  e33 = @sprintf("\\e");
+else {
+  e33 = @arg("e33");
+global string endEscape = "[0m";
+// Color codes used in Andrey's cpp optimizer:
+global int Black = 0;
+global int Blue = 1;
+global int BlackOnBlue = 2;
+global int Pink = 3;
+global int GoldOnBlue = 4;
+global int BlueOnGray = 5;
+global int Red = 6;
+global int Gold = 7;
+global int BlueOnGold = 8;
+global int Gray = 9;
+global int BlackOnGray = 10;
+# Black = 0;
+# Blue = 1;
+# BlackOnBlue = 2;
+# Pink = 3;
+# GoldOnBlue = 4;
+# BlueOnGray = 5;
+# Red = 6;
+# Gold = 7;
+# BlueOnGold = 8;
+# Gray = 9;
+# BlackOnGray = 10;
+global string colorCode[] = [
+ "[1;29m",      # Black = 0;
+ "[1;34m",	# Blue = 1;
+ "[1;44m",	# BlackOnBlue = 2;
+ "[1;35m",	# Pink = 3;
+ "[1;33;44m",	# GoldOnBlue = 4;
+ "[1;47;34m",	# BlueOnGray = 5;
+ "[1;1;31m",	# Red = 6;
+ "[1;1;33m",	# Gold = 7;
+ "[1;1;43;34m",	# BlueOnGold = 8;
+ "[1;1;37m",	# Gray = 9;
+ "[1;30;47m",	# BlackOnGray = 10;
+(string s) color(int c, string ins)
+  s = @strcat(e33,colorCode[c],ins,e33,endEscape);
+(string s) ncolor(int c, string ins) // Can use this version if \\e handling is available in current Swift
+  s = @sprintf(@strcat("\\e",colorCode[c],ins,"\\e",endEscape));  // sprintf applies \\e escape processing
+(string s) OLDcolor(int c, string ins)
+    switch(c){
+        case 0:
+            s = @strcat(e33,"[1;29m",ins,e33,"[0m");
+        case 1:
+            s = @strcat(e33,"[1;34m",ins,e33,"[0m");
+        case 2:
+            s = @strcat(e33,"[1;44m",ins,e33,"[0m");
+        case 3:
+            s = @strcat(e33,"[1;35m",ins,e33,"[0m");
+        case 4:
+            s = @strcat(e33,"[1;33;44m",ins,e33,"[0m");
+        case 5:
+            s = @strcat(e33,"[1;47;34m",ins,e33,"[0m");
+        case 6:
+            s = @strcat(e33,"[1;1;31m",ins,e33,"[0m");
+        case 7:
+            s = @strcat(e33,"[1;1;33m",ins,e33,"[0m");
+        case 8:
+            s = @strcat(e33,"[1;1;43;34m",ins,e33,"[0m");
+        case 9:
+            s = @strcat(e33,"[1;1;37m",ins,e33,"[0m");
+        case 10:
+            s = @strcat(e33,"[1;30;47m",ins,e33,"[0m");
+        default:
+            s = ins;
Deleted: SwiftApps/SciColSim/convertbest.sh
--- SwiftApps/SciColSim/convertbest.sh	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/convertbest.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,6 +0,0 @@
-#! /bin/sh
-for f in best*.txt; do
-  out=$(basename $f .txt).fmt
-  ../showbest.sh <$f >$out
-done
Copied: SwiftApps/SciColSim/docs/EMAIL (from rev 5634, SwiftApps/SciColSim/EMAIL)
--- SwiftApps/SciColSim/docs/EMAIL	                        (rev 0)
+++ SwiftApps/SciColSim/docs/EMAIL	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,474 @@
+==== Email trail (cronological order):
+On 10/15/11 8:30 PM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
+> Hi Andrey,
+> I've got a basic serial version of optimizer.cpp running on Beagle (on a login
+> node).  Now Im trying to parallelize it there, and have some questions:
+> 1) You set NWorkers to a constant, 24. In multi_loss, you have this code:
+>     for(int i=0; i<Nworkers; i++){
+>         for(int j=0; j<5; j++){
+>             un[i]->set_parameter(params[j],j);
+>             dispatch_group_async(group, CustomQueues[i], ^{
+>                 un[i]->evolve_to_target_and_save(istart, iend, Results,
+> Counters);
+>             istart += step;
+>             iend = min(istart+step,N);
+> Can you explain the intention here? I think the innermost loop is clear: run
+> evolve() 24 times in parallel, partitioning the istart..iend range among the
+> 24 workers.  But I dont understand the outermost loop, which seems to do the
+> entire inner loop 24 (NWorkers) times. I can understand the idea of doing the
+> entire inner loop some number of times. But from the above, I presume that
+> evolve would be run NWorkers^2 times, or 24*24 times.  Was that the intention?
+> 2) If you had many processors available (as you do on Beagle) would you want
+> to run set NWorkers higher? I think you mentioned something in out discussion
+> Friday about "a thousand" workers being useful. Ie, NWorkers for the innermost
+> loop could be 1000.  Was that really what you meant? What would be a
+> mathematically/scientifically useful value for the NWorkers in the innermost
+> loop?
+> Further: if you do want an NWorkers >> 24, would you still do the evolve
+> NWorkers^2 times?  I dont think you'd really want 1000*1000 = 1M evolve calls,
+> given how many outer loops you have at higher levels of the code, including in
+> the Python wrapper.
+> 3) We'll need to discuss what values make sense for the outer loops
+> (multi_annealing and the .py wrapper) once I have this working in parallel.
+> 4) Can you give me a sentence or two about what this code is doing?  I think I
+> understand the outer annealing logic, but I have not dug into the code within
+> evolve...() at all. I think you might have explained it once back in January
+> (before you recoded in C) but I dont recall. If you have a paper or a web page
+> on what youre computing here, that would be interesting for me to read, and to
+> help write a slide on this for the Beagle review.
+Re: Status and questions on optimizer code
+From :	 andrey rzhetsky <arzhetsk at medicine.bsd.uchicago.edu>
+Subject :	Re: Status and questions on optimizer code
+To :	 Michael Wilde <wilde at mcs.anl.gov>
+Sun, Oct 16, 2011 08:28 AM
+Hi Mike,
+1. I think, you just uncovered a stupid bug on my part -- thank you!  There
+should be only one loop (the outer one).
+2. Yes, of course -- 1000, or even 10000 (I can increase the number of
+repeats then).
+3. OK
+4. The code simulates exploration of a chemical network by a research
+community.  The five major parameters determine the strategy of exploration,
+"target" is the number of new interactions discovered and the loss is the
+number of experiments per one new positive finding.  I can provide you with
+figures and slides, if that would help.
+Thank you!
+With kind regards,
+Andrey
+On 10/16/11 9:13 AM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
+> Hi Andrey,
+> Looking deeper, I think the bug was simply that the first for() statement
+> should have enclosed just the parameter setting loop.  In other words, the top
+> of multi_loss should start with:
+> Then the real work is done by the next loop:
+>     for(i=0; i<Nworkers; i++){
+> Can you confirm that this looks correct to you?
+> I made that change, and the code now seems to run as I would expect. I will
+> send you some output as soon as I clean up my debugging output.
+> Next, I made the code run with 24-way parallelism on a Beagle login node using
+> "OpenMP", simply by adding one "pragma" statement in front of the main worker
+> loop above. So that part of the code now looks like this:
+>     int i;
+>     #pragma omp parallel for private (i)
+> and each call to evolve...() is now done in parallel (with all the Mac
+> dispatch statements commented out).  I will test, but I *think* that the same
+> code will run just as well in parallel on your multicore Macs, perhaps just a
+> *tiny* bit slower than under Grand Central Dispatch (likely not a noticeable
+> difference).
+> Now, we have 2 choices:
+> 1) I can simply replace the Python driver script with a Swift script, to do
+> many runs of the optimizer in parallel.  That would give you the ability to
+> run *many* 24-core optimization runs in parallel, each using 24 cores.  So for
+> example, in your current Python script you do this:
+> for target in range(58,1009,50):
+>   for i in range(15):
+> So thats about 20 x 15 = 300 invocations of optimizer. I *think* that each of
+> these runs is totally independent and can run in parallel, correct?
+> So A simple Swift script not much longer than the Python script, along with a
+> few beagle-specific configuration files, will enable all 300 jobs to run in
+> parallel, giving you 300 x 24 (=7200) cores running in parallel. Of course,
+> you can seldom *get* that many cores because the machine is heavily loaded.
+> But you may be able to get 10-30 nodes on a daily basis.  We'll need to
+> experiment with this.
+> As a *next* step after, we should consider the benefits of changing the value
+> of NWorkers to > 24.  24 is the "easy" limit on Beagle because we can get
+> 24-way parallelism on each node with just that one "pragma" statement.  We can
+> get much greater parallelism with Swift in the inner loop, but for that we
+> need to break up the program a bit more, to have Swift run the inner loop as a
+> separate program, and then return the aggregated results in a file. Even for
+> this option, there are two alternative methods:
+> - we make optimizer call Swift once for each round of parallel annealing. This
+> is fairly easy. It is somewhat limiting to overall parallelism, in that only
+> one round at a time can run. But It may be very adequate.
+> - we break the program up further into parallelizable chunks, in which case
+> you have a lot of flexibility and the work always gets done in a near-optimal
+> manner regardless of the shape of a given optimization run (in terms of the
+> various nested loop sizes and evolve() execution times.
+> I think we'll need to discuss this in person over a whiteboard, but I think I
+> have enough knowledge of the program to at least show you a few alternatives.
+> The main question at the moment, I think, is simply to understand the
+> math/science benefits of extending NWorkers beyond the "low hanging fruit"
+> limit of 24.  What is your assessment of that benefit, Andrey?
+----- Forwarded Message -----
+From: "andrey rzhetsky" <arzhetsk at medicine.bsd.uchicago.edu>
+To: "Michael Wilde" <wilde at mcs.anl.gov>
+Sent: Sunday, October 16, 2011 12:08:25 PM
+Subject: Re: Status and questions on optimizer code
+Mike,
+It would be fantastic to have 1000 or 10000 workers (with larger number of
+re-runs -- it would improve precision of my analysis drastically!).
+All the very best,
+Andrey
+On 10/17/11 8:29 AM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
+> Hi Andrey,
+> Can we meet today to discuss the optimizer? I'd like to show you what Ive done
+> and discuss with you next steps towards getting you running on Beagle. I can
+> meet any time from 10:30 to 3:00.
+> Do you already have a CI and Beagle login and a project set up for Beagle use?
+> If not, we should get that started.
+> On the technical side, I have a question about the the typical shape of your
+> optimization runs.
+> With the sample Python script you gave me, I think we have the following
+> nested iterations in the code:
+> 20 targets (parallel)
+>   15 repeats (parallel)
+>     100 Annealing_cycles (serial)
+>        6 repeats (serial)
+>          1000 to 10000 annealing_repeats (parallel)   # NOTE (1/29 mw): should this be called "reruns"?
+>            evolve()
+> The main question I have at this point is regarding the strategy for
+> increasing the innermost annealing repeats (currently 1,000 divided among 24
+> workers; desired to increase to 10,000).
+> The outermost loops in my Swift tests are done in parallel. Thus we can have a
+> 300 optimizations going in parallel and 24 annealings in parallel for a total
+> of 7,200 parallel tasks.
+> The question is: if you will always have a sizeable number of parallel
+> iterations in the outer loops, we dont need to change anything in the inner
+> loop to get more parallelism. In other words, we already have more parallelism
+> than we have CPUs available.
+> 7200 CPUs is about 42% of the overall Beagle system.  It will be very rare
+> that we we could get that many cores all at once.  But  think we can regularly
+> get say 500 to 2000 cores on a daily basis.
+> On the other hand, if you expect to regularly run tests of *single* annealing
+> cycles and want to speed those up, then indeed it may be worth changing the
+> code structure.
+> When me meet I'll try to give you an idea of whats involved. Basically we need
+> to change the structure of the annealing loop to create a function
+> "multi_loss_setup" as a separate executable which defines the annealing
+> parameters and writes them to a file; make multi_loss a separate executable;
+> create another executable "multi_loss_summarize" which reduces the results.
+> We can probably combine multi_loss_summarize into multi_loss_setup.
+> This is not very hard to do, but still sounds to me like a week of programming
+> to get all all restructured and tested.  Before investing that effort, we
+> should discuss if it will give you any additional performance gains over just
+> running many optimizations in parallel.
+> I need to run timings on the annealing cycles to see how that change across
+> the parameter space, to see if we can just increase the repeats to 10,000 with
+> no changes to the code. I think the feasibility of doing this the "easy way"
+> is based on how long the longest annealings take at the high end of the
+> parameter space.
+> Regards,
+> - Mike
+From: "Andrey Rzhetsky" <arzhetsk at medicine.bsd.uchicago.edu>
+Sent: Monday, October 17, 2011 8:40:17 AM
+Subject: Re: Meet today to discuss optimizer?
+Hi Mike,
+The 6 (or more) annealing repeats can be run in parallel too.
+Unfortunately, around 10:15 I have to rush to Evanston to CBC meeting for
+the rest of the day (we can chat before, if you have a minute, I am in my
+office).
+I don't have Beagle login, unfortunately.
+Typically, I will have a sizeable outer loop, so, probably, the current
+24-worker setup is fine.
+Thank you very much for helping me out!
+All the best,
+Andrey
+On 10/18/11 1:52 PM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
+> Hi Andrey,
+> Here's a quick update:
+> - I am now running the optimizer on Beagle compute nodes under Swift.
+> I attach a few tar files of sample runs at reduced parameter values (to shrink
+> the run time for debugging and learning the code's behavior);
+> Now Im trying to run some subset of the full-length parameters you gave me in
+> the python file.  Ive got 3 Beagle compute nodes allocated at the moment (72
+> cores total) and Im seeing these times from multi_loss with N=1000 repeats:
+> sandbox$ grep multi_  ./jobs/*/*/output/*.out
+> ./jobs/0/optimizer-01p7lhhk/output/T408.R1.out:multi_loss(N=1000) elapsed
+> time: 122.742 seconds 2.04571 minutes
+> time: 123.979 seconds 2.06631 minutes
+> time: 123.624 seconds 2.0604 minutes
+> ./jobs/t/optimizer-t0p7lhhk/output/T958.R1.out:multi_loss(N=1000) elapsed
+> time: 1431.09 seconds 23.8514 minutes
+> ./jobs/x/optimizer-x0p7lhhk/output/T708.R1.out:multi_loss(N=1000) elapsed
+> time: 627.074 seconds 10.4512 minutes
+> time: 790.652 seconds 13.1775 minutes
+> Each run of optimizer is going to a file name T(target).R(repeat).out
+> So we're seeing 23.8 mins for 1000 repeats at target=958 and 10-13 mins at
+> target=708. The 1000 repeats are spread over 24 cores each.
+> Whats your time availability later in the week to discuss this further, and to
+> see if either (a) I can show you how to run this version or (b) we can get a
+> set of production run descriptions from you and you can run them yourself?
+> In the compressed tar file at http://www.ci.uchicago.edu/~wilde/AR.snap.01.tgz
+> you will find:
+> - the swift script that I use instead of the Python driver to run the
+> optimizer in parallel (along beagle.xml that specifies scheduler parameters
+> for Beagle like time, cores, queue name and project ID)
+> - the slightly modified version of optimizer (changes in multi_loss() to
+> correct the loops, changes to use OpenMP instead of Grand Central Dispatch,
+> and a few changes in output logging).
+> - a few run directories of runs with shortened parameter settings.
+> If we continue working together on this, we should set up a way to share code
+> using a repository like Subversion (svn).  Thats pretty easy once you master a
+> few basic commands.
+> Regards,
+> - Mike
+Sent: Tuesday, October 18, 2011 3:57:36 PM
+Mike,
+Thank you!  Are you around now?  I would be also happy to carve some time
+tomorrow, if this works for you.
+With kind regards,
+Andrey
+On 10/19/11 12:10 PM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
+> Hi Andrey,
+> Im in meetings today till about 3PM. Are you available at say 3:30 or later?
+> I did a larger run last night. Only one smaller optimizer run *fully*
+> finished, but many others made significant progress.  The results are at:
+>   http://www.ci.uchicago.edu/~wilde/AR.optimizer.out.2010.1018.tgz
+> If you have time, could you take a look at that run and see if the
+> optimizations look like they have been running as expected? Ive made only a
+> few cosmetic changes to your debug output.
+> I submitted the run at 21:20; it started running at about 21:27; by about
+> 23:10 it had acquired 12 nodes (x 24 cores each). It ended about 23:18 when
+> the first job exceeded its time limit of 5 hours. Im still trying to calibrate
+> how much time each optimizer invocation needs, and whether some of the
+> internal iterations can be further spread out.  Also how to organize the run
+> so that optimizations that time out  can be re-run with the smallest
+> reasonable failure unit.
+Sent: Wednesday, October 26, 2011 8:40:21 PM
+Subject: Re: Question on inner annealing loop
+Mike,
+> Im confused on 3 points here:
+> - the inner loop would always be done between 1 and 5 times, right?
+Correct.
+> - could each of those times really be done in parallel? (I'll try to determine
+> this by inspection).
+Not really -- the acceptance of parameter changes depends on the loss in
+between.
+> - when we last met in your office, I *thought* you indicated that this inner
+> loop could be done just *once*.  Was that what you meant?  And if so, for
+> which of the 5 vars?
+Nope, has to be repeated over and over.
+All the very best,
+Andrey
+On 10/26/11 10:42 PM, "Michael Wilde" <wilde at mcs.anl.gov> wrote:
+> OK, all that makes sense, Andrey. But then do you recall what you suggested
+> when we met?
+> Lets label the loops as follows:
+> a) 20 targets (parallel)
+> b)   15 repeats (parallel)
+> c)     100 Annealing_cycles (serial)
+> d)        6 repeats (serial)
+> e)         1000 to 10000 annealing_repeats (parallel)
+> f)            evolve()
+> What I recalled from our last discussion was that I should reduce loop (c)
+> from 100 to 50 or 25, and loop (d) to 1.  But since reducing loop (d) doesn't
+> make sense, do you recall suggesting any other reduction?
+> If not, no problem, I think I know how to proceed.
+> Thanks,
+> - Mike
+Sent: Thursday, October 27, 2011 2:54:06 AM
+Hi Mike,
+I suggested reducing (b) to 1.
+With kind regards,
+Andrey
Copied: SwiftApps/SciColSim/docs/TimingEstimation.txt (from rev 5634, SwiftApps/SciColSim/TimingEstimation.txt)
--- SwiftApps/SciColSim/docs/TimingEstimation.txt	                        (rev 0)
+++ SwiftApps/SciColSim/docs/TimingEstimation.txt	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,95 @@
+SciColSim on Beagle
+Loop Structure
+Following is the loop structure for the SciColSim application at 'full-scale' values:
+~20 target innovation values
+ ~15 repeats
+  100 annealing cycles (serial)
+     3 non-fixed vars    (serial)
+       1,000 reruns (=>evolve_reruns/reruns_per_app))
+         call evolve (1 to 50 seconds per rerun)
+Total number of jobs are given by the following expression:
+Number_of_jobs = target_innovation_values x repeats x fixed_reps x annealing_cycles x evolve_reruns/reruns_per_app x num_workers
+               = ceil((max_range - min_range)/range_inc) x repeats x fixed_reps x annealing_cycles x evolve_reruns/reruns_per_app x num_workers
+               = ceil((1009 - 58)/50) x 15 x 3 x 100 x 960/192 x 24
+               = 20 x 15 x 3 x 100 x 5 x 24
+               = 10,800,000
+               = 20 x 15 x 3 x 100 x 1000 x 10 = total core-seconds
+               = 900M core seconds
+               = 900M / 1000 = 900,000 seconds on 1000 cores
+               = 250 hours = 10 days
+Estimated Runtime on a small scale (2 laptops or 24 cores)
+         =10,800,000/24 x (1 to 50 sec)
+         =450,000 to 22,500,000 seconds
+         =5.2 hours to 260 days
+Estimated Runtime on medium scale (40 Beagle nodes or 960 cores)
+         =10,800,000/960 x (1 to 50 sec)
+         =11,250 to 562,500 seconds
+         =3.12 hours to 6.5 days
+Atomic job times of application
+multi_loss(N=1, target=58) elapsed time: 0.116707 seconds 0.00194512 minutes
+multi_loss(N=1, target=108) elapsed time: 0.26613 seconds 0.0044355 minutes
+multi_loss(N=1, target=158) elapsed time: 0.379991 seconds 0.00633318 minutes
+multi_loss(N=1, target=208) elapsed time: 0.576198 seconds 0.0096033 minutes
+multi_loss(N=1, target=258) elapsed time: 1.50121 seconds 0.0250203 minutes
+multi_loss(N=1, target=308) elapsed time: 1.09665 seconds 0.0182775 minutes
+multi_loss(N=1, target=358) elapsed time: 1.49523 seconds 0.0249205 minutes
+multi_loss(N=1, target=408) elapsed time: 2.3056 seconds 0.0384267 minutes
+multi_loss(N=1, target=458) elapsed time: 3.54418 seconds 0.0590697 minutes
+multi_loss(N=1, target=508) elapsed time: 5.10912 seconds 0.085152 minutes
+multi_loss(N=1, target=558) elapsed time: 6.88611 seconds 0.114768 minutes
+multi_loss(N=1, target=608) elapsed time: 8.7683 seconds 0.146138 minutes
+multi_loss(N=1, target=658) elapsed time: 10.0665 seconds 0.167775 minutes
+multi_loss(N=1, target=708) elapsed time: 12.7259 seconds 0.212098 minutes
+multi_loss(N=1, target=758) elapsed time: 14.8005 seconds 0.246675 minutes
+multi_loss(N=1, target=808) elapsed time: 16.8803 seconds 0.281338 minutes
+multi_loss(N=1, target=858) elapsed time: 19.7864 seconds 0.329774 minutes
+multi_loss(N=1, target=908) elapsed time: 23.4506 seconds 0.390843 minutes
+multi_loss(N=1, target=958) elapsed time: 28.7667 seconds 0.479445 minutes
+multi_loss(N=1, target=1008) elapsed time: 49.0841 seconds 0.818069 minutes
Copied: SwiftApps/SciColSim/docs/atomic_times.png (from rev 5634, SwiftApps/SciColSim/atomic_times.png)
Copied: SwiftApps/SciColSim/docs/atomic_times.txt (from rev 5634, SwiftApps/SciColSim/atomic_times.txt)
--- SwiftApps/SciColSim/docs/atomic_times.txt	                        (rev 0)
+++ SwiftApps/SciColSim/docs/atomic_times.txt	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,21 @@
+ 58  0.116707
+108  0.26613
+158  0.379991
+208  0.576198
+258  1.50121
+308  1.09665
+358  1.49523
+408  2.3056
+458  3.54418
+508  5.10912
+558  6.88611
+608  8.7683
+658 10.0665
+708 12.7259
+758 14.8005
+808 16.8803
+858 19.7864
+908 23.4506
+958 28.7667
+1008 49.0841
Copied: SwiftApps/SciColSim/docs/plot_active.txt (from rev 5634, SwiftApps/SciColSim/plot_active.txt)
--- SwiftApps/SciColSim/docs/plot_active.txt	                        (rev 0)
+++ SwiftApps/SciColSim/docs/plot_active.txt	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,7767 @@
+0	1
+10.9679	3
+21.9359	3
+32.9038	4
+43.8717	3
+54.8397	3
+65.8076	3
+76.7755	3
+87.7434	3
+98.7114	3
+109.679	3
+120.647	3
+131.615	3
+142.583	3
+153.551	3
+164.519	3
+175.487	3
+186.455	4
+197.423	3
+208.391	4
+219.359	3
+230.327	3
+241.294	3
+252.262	3
+263.23	3
+274.198	3
+285.166	3
+296.134	4
+307.102	4
+318.07	3
+329.038	4
+340.006	4
+350.974	3
+361.942	4
+372.91	4
+383.878	4
+394.845	3
+405.813	3
+416.781	4
+427.749	3
+438.717	3
+449.685	3
+460.653	3
+471.621	3
+482.589	3
+493.557	4
+504.525	3
+515.493	4
+526.461	3
+537.429	4
+548.397	3
+559.364	3
+570.332	3
+581.3	3
+592.268	4
+603.236	3
+614.204	3
+625.172	4
+636.14	4
+647.108	3
+658.076	4
+669.044	3
+680.012	3
+690.98	3
+701.948	3
+712.915	4
+723.883	3
+734.851	4
+745.819	4
+756.787	4
+767.755	3
+778.723	3
+789.691	3
+800.659	3
+811.627	3
+822.595	3
+833.563	4
+844.531	4
+855.499	3
+866.466	4
+877.434	3
+888.402	4
+899.37	4
+910.338	3
+921.306	3
+932.274	3
+943.242	4
+954.21	3
+965.178	4
+976.146	3
+987.114	4
+998.082	3
+1009.05	3
+1020.02	3
+1030.99	3
+1041.95	3
+1052.92	3
+1063.89	3
+1074.86	4
+1085.83	4
+1096.79	3
+1107.76	4
+1118.73	3
+1129.7	3
+1140.66	3
+1151.63	4
+1162.6	4
+1173.57	3
+1184.54	4
+1195.5	3
+1206.47	4
+1217.44	3
+1228.41	4
+1239.38	4
+1250.34	3
+1261.31	3
+1272.28	3
+1283.25	3
+1294.22	3
+1305.18	4
+1316.15	3
+1327.12	4
+1338.09	4
+1349.06	3
+1360.02	3
+1370.99	4
+1381.96	3
+1392.93	3
+1403.9	3
+1414.86	3
+1425.83	4
+1436.8	3
+1447.77	3
+1458.73	4
+1469.7	3
+1480.67	4
+1491.64	3
+1502.61	4
+1513.57	4
+1524.54	3
+1535.51	3
+1546.48	3
+1557.45	3
+1568.41	4
+1579.38	4
+1590.35	3
+1601.32	3
+1612.29	3
+1623.25	4
+1634.22	4
+1645.19	3
+1656.16	4
+1667.13	4
+1678.09	3
+1689.06	3
+1700.03	3
+1711	3
+1721.97	4
+1732.93	3
+1743.9	4
+1754.87	4
+1765.84	3
+1776.8	3
+1787.77	3
+1798.74	4
+1809.71	3
+1820.68	4
+1831.64	3
+1842.61	4
+1853.58	4
+1864.55	3
+1875.52	3
+1886.48	4
+1897.45	3
+1908.42	3
+1919.39	4
+1930.36	4
+1941.32	3
+1952.29	4
+1963.26	3
+1974.23	3
+1985.2	3
+1996.16	4
+2007.13	3
+2018.1	4
+2029.07	3
+2040.03	4
+2051	3
+2061.97	4
+2072.94	3
+2083.91	3
+2094.87	3
+2105.84	3
+2116.81	4
+2127.78	3
+2138.75	3
+2149.71	3
+2160.68	4
+2171.65	3
+2182.62	3
+2193.59	3
+2204.55	3
+2215.52	4
+2226.49	4
+2237.46	2
+2248.43	3
+2259.39	3
+2270.36	4
+2281.33	3
+2292.3	3
+2303.27	3
+2314.23	3
+2325.2	3
+2336.17	4
+2347.14	3
+2358.1	3
+2369.07	4
+2380.04	3
+2391.01	3
+2401.98	3
+2412.94	4
+2423.91	3
+2434.88	4
+2445.85	3
+2456.82	4
+2467.78	3
+2478.75	4
+2489.72	3
+2500.69	4
+2511.66	3
+2522.62	4
+2533.59	3
+2544.56	4
+2555.53	4
+2566.5	3
+2577.46	4
+2588.43	3
+2599.4	4
+2610.37	3
+2621.34	3
+2632.3	4
+2643.27	4
+2654.24	4
+2665.21	4
+2676.17	3
+2687.14	3
+2698.11	4
+2709.08	4
+2720.05	2
+2731.01	3
+2741.98	3
+2752.95	3
+2763.92	3
+2774.89	4
+2785.85	4
+2796.82	3
+2807.79	3
+2818.76	3
+2829.73	3
+2840.69	3
+2851.66	3
+2862.63	4
+2873.6	4
+2884.57	4
+2895.53	3
+2906.5	3
+2917.47	3
+2928.44	3
+2939.41	3
+2950.37	3
+2961.34	4
+2972.31	3
+2983.28	3
+2994.24	3
+3005.21	4
+3016.18	4
+3027.15	3
+3038.12	4
+3049.08	3
+3060.05	3
+3071.02	4
+3081.99	3
+3092.96	3
+3103.92	3
+3114.89	4
+3125.86	3
+3136.83	4
+3147.8	3
+3158.76	3
+3169.73	3
+3180.7	4
+3191.67	4
+3202.64	4
+3213.6	4
+3224.57	3
+3235.54	4
+3246.51	4
+3257.48	4
+3268.44	4
+3279.41	4
+3290.38	3
+3301.35	4
+3312.31	4
+3323.28	4
+3334.25	3
+3345.22	3
+3356.19	4
+3367.15	3
+3378.12	3
+3389.09	4
+3400.06	3
+3411.03	4
+3421.99	3
+3432.96	4
+3443.93	3
+3454.9	3
+3465.87	3
+3476.83	4
+3487.8	3
+3498.77	4
+3509.74	3
+3520.71	3
+3531.67	3
+3542.64	3
+3553.61	3
+3564.58	4
+3575.55	4
+3586.51	3
+3597.48	3
+3608.45	4
+3619.42	4
+3630.38	4
+3641.35	3
+3652.32	4
+3663.29	3
+3674.26	4
+3685.22	3
+3696.19	3
+3707.16	4
+3718.13	3
+3729.1	3
+3740.06	3
+3751.03	4
+3762	3
+3772.97	4
+3783.94	3
+3794.9	3
+3805.87	3
+3816.84	3
+3827.81	4
+3838.78	3
+3849.74	3
+3860.71	3
+3871.68	3
+3882.65	4
+3893.62	3
+3904.58	3
+3915.55	3
+3926.52	4
+3937.49	4
+3948.45	3
+3959.42	3
+3970.39	4
+3981.36	4
+3992.33	4
+4003.29	4
+4014.26	3
+4025.23	3
+4036.2	3
+4047.17	4
+4058.13	3
+4069.1	4
+4080.07	3
+4091.04	4
+4102.01	3
+4112.97	4
+4123.94	3
+4134.91	4
+4145.88	3
+4156.85	4
+4167.81	4
+4178.78	3
+4189.75	4
+4200.72	3
+4211.69	4
+4222.65	4
+4233.62	3
+4244.59	3
+4255.56	3
+4266.52	4
+4277.49	3
+4288.46	3
+4299.43	3
+4310.4	4
+4321.36	3
+4332.33	4
+4343.3	3
+4354.27	3
+4365.24	3
+4376.2	4
+4387.17	3
+4398.14	4
+4409.11	3
+4420.08	4
+4431.04	3
+4442.01	3
+4452.98	3
+4463.95	3
+4474.92	3
+4485.88	4
+4496.85	3
+4507.82	3
+4518.79	3
+4529.76	3
+4540.72	3
+4551.69	4
+4562.66	3
+4573.63	4
+4584.59	3
+4595.56	4
+4606.53	3
+4617.5	3
+4628.47	4
+4639.43	3
+4650.4	4
+4661.37	3
+4672.34	3
+4683.31	3
+4694.27	4
+4705.24	3
+4716.21	3
+4727.18	4
+4738.15	4
+4749.11	4
+4760.08	3
+4771.05	3
+4782.02	4
+4792.99	3
+4803.95	3
+4814.92	4
+4825.89	3
+4836.86	4
+4847.83	3
+4858.79	4
+4869.76	3
+4880.73	3
+4891.7	3
+4902.66	3
+4913.63	3
+4924.6	3
+4935.57	4
+4946.54	3
+4957.5	3
+4968.47	4
+4979.44	3
+4990.41	3
+5001.38	3
+5012.34	3
+5023.31	3
+5034.28	3
+5045.25	4
+5056.22	3
+5067.18	4
+5078.15	3
+5089.12	3
+5100.09	3
+5111.06	4
+5122.02	4
+5132.99	3
+5143.96	3
+5154.93	3
+5165.9	4
+5176.86	3
+5187.83	4
+5198.8	3
+5209.77	3
+5220.73	3
+5231.7	3
+5242.67	4
+5253.64	3
+5264.61	3
+5275.57	3
+5286.54	3
+5297.51	3
+5308.48	3
+5319.45	4
+5330.41	4
+5341.38	3
+5352.35	4
+5363.32	3
+5374.29	3
+5385.25	4
+5396.22	3
+5407.19	3
+5418.16	4
+5429.13	3
+5440.09	3
+5451.06	4
+5462.03	3
+5473	3
+5483.97	3
+5494.93	3
+5505.9	3
+5516.87	4
+5527.84	3
+5538.8	4
+5549.77	3
+5560.74	3
+5571.71	4
+5582.68	3
+5593.64	4
+5604.61	3
+5615.58	3
+5626.55	3
+5637.52	3
+5648.48	3
+5659.45	4
+5670.42	3
+5681.39	4
+5692.36	3
+5703.32	3
+5714.29	3
+5725.26	3
+5736.23	3
+5747.2	3
+5758.16	4
+5769.13	3
+5780.1	4
+5791.07	3
+5802.03	4
+5813	4
+5823.97	3
+5834.94	4
+5845.91	4
+5856.87	3
+5867.84	3
+5878.81	3
+5889.78	4
+5900.75	3
+5911.71	3
+5922.68	3
+5933.65	4
+5944.62	3
+5955.59	4
+5966.55	4
+5977.52	3
+5988.49	3
+5999.46	3
+6010.43	3
+6021.39	4
+6032.36	4
+6043.33	3
+6054.3	4
+6065.27	4
+6076.23	4
+6087.2	3
+6098.17	3
+6109.14	3
+6120.1	3
+6131.07	3
+6142.04	3
+6153.01	4
+6163.98	4
+6174.94	4
+6185.91	3
+6196.88	3
+6207.85	4
+6218.82	3
+6229.78	3
+6240.75	4
+6251.72	4
+6262.69	3
+6273.66	3
+6284.62	4
+6295.59	3
+6306.56	4
+6317.53	4
+6328.5	3
+6339.46	4
+6350.43	3
+6361.4	3
+6372.37	3
+6383.34	3
+6394.3	3
+6405.27	3
+6416.24	3
+6427.21	4
+6438.17	3
+6449.14	3
+6460.11	3
+6471.08	3
+6482.05	3
+6493.01	3
+6503.98	4
+6514.95	4
+6525.92	3
+6536.89	3
+6547.85	4
+6558.82	4
+6569.79	4
+6580.76	4
+6591.73	4
+6602.69	4
+6613.66	3
+6624.63	3
+6635.6	4
+6646.57	4
+6657.53	3
+6668.5	4
+6679.47	4
+6690.44	3
+6701.41	3
+6712.37	3
+6723.34	3
+6734.31	3
+6745.28	3
+6756.24	3
+6767.21	3
+6778.18	3
+6789.15	3
+6800.12	2
+6811.08	3
+6822.05	3
+6833.02	3
+6843.99	3
+6854.96	4
+6865.92	3
+6876.89	4
+6887.86	4
+6898.83	4
+6909.8	3
+6920.76	4
+6931.73	3
+6942.7	3
+6953.67	3
+6964.64	4
+6975.6	3
+6986.57	3
+6997.54	3
+7008.51	3
+7019.48	3
+7030.44	3
+7041.41	3
+7052.38	4
+7063.35	3
+7074.31	4
+7085.28	3
+7096.25	4
+7107.22	4
+7118.19	3
+7129.15	3
+7140.12	3
+7151.09	4
+7162.06	3
+7173.03	4
+7183.99	3
+7194.96	3
+7205.93	4
+7216.9	4
+7227.87	3
+7238.83	3
+7249.8	3
+7260.77	3
+7271.74	3
+7282.71	4
+7293.67	3
+7304.64	3
+7315.61	3
+7326.58	3
+7337.55	3
+7348.51	3
+7359.48	3
+7370.45	4
+7381.42	3
+7392.38	4
+7403.35	4
+7414.32	3
+7425.29	3
+7436.26	4
+7447.22	3
+7458.19	3
+7469.16	4
+7480.13	3
+7491.1	4
+7502.06	3
+7513.03	4
+7524	3
+7534.97	3
+7545.94	3
+7556.9	3
+7567.87	3
+7578.84	4
+7589.81	3
+7600.78	4
+7611.74	3
+7622.71	4
+7633.68	3
+7644.65	3
+7655.62	3
+7666.58	3
+7677.55	4
+7688.52	3
+7699.49	3
+7710.45	4
+7721.42	4
+7732.39	4
+7743.36	4
+7754.33	4
+7765.29	3
+7776.26	3
+7787.23	3
+7798.2	3
+7809.17	3
+7820.13	3
+7831.1	3
+7842.07	3
+7853.04	3
+7864.01	3
+7874.97	3
+7885.94	3
+7896.91	3
+7907.88	3
+7918.85	3
+7929.81	3
+7940.78	3
+7951.75	3
+7962.72	4
+7973.69	4
+7984.65	4
+7995.62	3
+8006.59	3
+8017.56	3
+8028.52	3
+8039.49	4
+8050.46	3
+8061.43	3
+8072.4	3
+8083.36	3
+8094.33	3
+8105.3	3
+8116.27	4
+8127.24	3
+8138.2	3
+8149.17	4
+8160.14	3
+8171.11	3
+8182.08	3
+8193.04	4
+8204.01	3
+8214.98	3
+8225.95	3
+8236.92	4
+8247.88	3
+8258.85	3
+8269.82	4
+8280.79	3
+8291.76	3
+8302.72	3
+8313.69	3
+8324.66	4
+8335.63	4
+8346.59	4
+8357.56	3
+8368.53	3
+8379.5	3
+8390.47	3
+8401.43	4
+8412.4	4
+8423.37	3
+8434.34	4
+8445.31	4
+8456.27	3
+8467.24	3
+8478.21	3
+8489.18	3
+8500.15	4
+8511.11	3
+8522.08	3
+8533.05	3
+8544.02	3
+8554.99	3
+8565.95	3
+8576.92	3
+8587.89	3
+8598.86	4
+8609.83	3
+8620.79	3
+8631.76	4
+8642.73	4
+8653.7	4
+8664.66	3
+8675.63	4
+8686.6	3
+8697.57	3
+8708.54	3
+8719.5	3
+8730.47	3
+8741.44	3
+8752.41	3
+8763.38	3
+8774.34	3
+8785.31	3
+8796.28	3
+8807.25	3
+8818.22	3
+8829.18	3
+8840.15	3
+8851.12	4
+8862.09	3
+8873.06	4
+8884.02	3
+8894.99	4
+8905.96	3
+8916.93	3
+8927.9	3
+8938.86	4
+8949.83	3
+8960.8	4
+8971.77	3
+8982.73	4
+8993.7	3
+9004.67	4
+9015.64	3
+9026.61	3
+9037.57	4
+9048.54	3
+9059.51	4
+9070.48	3
+9081.45	4
+9092.41	3
+9103.38	3
+9114.35	3
+9125.32	4
+9136.29	3
+9147.25	3
+9158.22	3
+9169.19	3
+9180.16	3
+9191.13	3
+9202.09	3
+9213.06	3
+9224.03	3
+9235	3
+9245.96	3
+9256.93	3
+9267.9	3
+9278.87	3
+9289.84	3
+9300.8	4
+9311.77	4
+9322.74	4
+9333.71	3
+9344.68	3
+9355.64	3
+9366.61	4
+9377.58	3
+9388.55	3
+9399.52	4
+9410.48	3
+9421.45	4
+9432.42	3
+9443.39	4
+9454.36	4
+9465.32	3
+9476.29	3
+9487.26	3
+9498.23	3
+9509.2	3
+9520.16	3
+9531.13	3
+9542.1	3
+9553.07	3
+9564.03	3
+9575	3
+9585.97	3
+9596.94	4
+9607.91	4
+9618.87	4
+9629.84	3
+9640.81	3
+9651.78	3
+9662.75	3
+9673.71	3
+9684.68	4
+9695.65	3
+9706.62	4
+9717.59	3
+9728.55	3
+9739.52	3
+9750.49	3
+9761.46	3
+9772.43	4
+9783.39	3
+9794.36	4
+9805.33	3
+9816.3	4
+9827.27	3
+9838.23	4
+9849.2	3
+9860.17	3
+9871.14	3
+9882.1	4
+9893.07	4
+9904.04	3
+9915.01	4
+9925.98	4
+9936.94	3
+9947.91	3
+9958.88	3
+9969.85	4
+9980.82	3
+9991.78	4
+10002.8	3
+10013.7	3
+10024.7	3
+10035.7	3
+10046.6	3
+10057.6	4
+10068.6	3
+10079.5	4
+10090.5	3
+10101.5	4
+10112.4	3
+10123.4	4
+10134.4	3
+10145.3	4
+10156.3	3
+10167.3	3
+10178.2	3
+10189.2	4
+10200.2	4
+10211.1	3
+10222.1	4
+10233.1	3
+10244	4
+10255	3
+10266	3
+10277	4
+10287.9	4
+10298.9	4
+10309.9	3
+10320.8	3
+10331.8	4
+10342.8	4
+10353.7	3
+10364.7	3
+10375.7	3
+10386.6	3
+10397.6	3
+10408.6	4
+10419.5	3
+10430.5	3
+10441.5	4
+10452.4	3
+10463.4	4
+10474.4	3
+10485.3	4
+10496.3	3
+10507.3	3
+10518.2	3
+10529.2	3
+10540.2	4
+10551.1	3
+10562.1	4
+10573.1	3
+10584.1	3
+10595	3
+10606	3
+10617	4
+10627.9	4
+10638.9	3
+10649.9	3
+10660.8	3
+10671.8	3
+10682.8	3
+10693.7	4
+10704.7	4
+10715.7	4
+10726.6	3
+10737.6	3
+10748.6	3
+10759.5	4
+10770.5	3
+10781.5	3
+10792.4	3
+10803.4	4
+10814.4	3
+10825.3	3
+10836.3	3
+10847.3	3
+10858.3	3
+10869.2	4
+10880.2	4
+10891.2	3
+10902.1	3
+10913.1	3
+10924.1	3
+10935	3
+10946	4
+10957	3
+10967.9	4
+10978.9	3
+10989.9	3
+11000.8	3
+11011.8	4
+11022.8	3
+11033.7	3
+11044.7	3
+11055.7	3
+11066.6	3
+11077.6	3
+11088.6	3
+11099.5	4
+11110.5	4
+11121.5	3
+11132.4	3
+11143.4	3
+11154.4	3
+11165.4	3
+11176.3	3
+11187.3	4
+11198.3	3
+11209.2	4
+11220.2	3
+11231.2	3
+11242.1	4
+11253.1	3
+11264.1	4
+11275	3
+11286	3
+11297	3
+11307.9	3
+11318.9	4
+11329.9	4
+11340.8	3
+11351.8	3
+11362.8	4
+11373.7	3
+11384.7	3
+11395.7	4
+11406.6	4
+11417.6	3
+11428.6	4
+11439.6	3
+11450.5	3
+11461.5	3
+11472.5	3
+11483.4	3
+11494.4	4
+11505.4	3
+11516.3	3
+11527.3	3
+11538.3	3
+11549.2	3
+11560.2	4
+11571.2	3
+11582.1	3
+11593.1	3
+11604.1	3
+11615	3
+11626	3
+11637	3
+11647.9	3
+11658.9	3
+11669.9	2
+11680.8	3
+11691.8	3
+11702.8	3
+11713.7	3
+11724.7	4
+11735.7	3
+11746.7	3
+11757.6	3
+11768.6	4
+11779.6	3
+11790.5	3
+11801.5	4
+11812.5	4
+11823.4	4
+11834.4	3
+11845.4	4
+11856.3	4
+11867.3	3
+11878.3	3
+11889.2	3
+11900.2	4
+11911.2	3
+11922.1	4
+11933.1	3
+11944.1	3
+11955	3
+11966	3
+11977	4
+11987.9	3
+11998.9	3
+12009.9	3
+12020.9	3
+12031.8	3
+12042.8	3
+12053.8	4
+12064.7	4
+12075.7	3
+12086.7	3
+12097.6	3
+12108.6	3
+12119.6	4
+12130.5	3
+12141.5	3
+12152.5	4
+12163.4	4
+12174.4	3
+12185.4	3
+12196.3	3
+12207.3	4
+12218.3	3
+12229.2	3
+12240.2	4
+12251.2	3
+12262.1	3
+12273.1	4
+12284.1	3
+12295	3
+12306	3
+12317	4
+12328	3
+12338.9	3
+12349.9	3
+12360.9	4
+12371.8	4
+12382.8	3
+12393.8	4
+12404.7	3
+12415.7	4
+12426.7	3
+12437.6	3
+12448.6	3
+12459.6	3
+12470.5	4
+12481.5	3
+12492.5	3
+12503.4	3
+12514.4	3
+12525.4	4
+12536.3	4
+12547.3	3
+12558.3	3
+12569.2	3
+12580.2	3
+12591.2	3
+12602.2	3
+12613.1	4
+12624.1	3
+12635.1	4
+12646	3
+12657	3
+12668	3
+12678.9	3
+12689.9	3
+12700.9	3
+12711.8	4
+12722.8	4
+12733.8	3
+12744.7	4
+12755.7	3
+12766.7	3
+12777.6	3
+12788.6	4
+12799.6	3
+12810.5	3
+12821.5	3
+12832.5	4
+12843.4	3
+12854.4	3
+12865.4	3
+12876.3	4
+12887.3	3
+12898.3	4
+12909.3	3
+12920.2	4
+12931.2	3
+12942.2	3
+12953.1	4
+12964.1	4
+12975.1	3
+12986	4
+12997	3
+13008	3
+13018.9	3
+13029.9	3
+13040.9	3
+13051.8	2
+13062.8	4
+13073.8	3
+13084.7	3
+13095.7	4
+13106.7	3
+13117.6	4
+13128.6	4
+13139.6	4
+13150.5	3
+13161.5	3
+13172.5	4
+13183.5	3
+13194.4	3
+13205.4	3
+13216.4	4
+13227.3	3
+13238.3	4
+13249.3	4
+13260.2	3
+13271.2	4
+13282.2	3
+13293.1	3
+13304.1	3
+13315.1	3
+13326	3
+13337	3
+13348	3
+13358.9	4
+13369.9	4
+13380.9	3
+13391.8	3
+13402.8	3
+13413.8	3
+13424.7	4
+13435.7	3
+13446.7	4
+13457.7	3
+13468.6	4
+13479.6	3
+13490.6	4
+13501.5	3
+13512.5	4
+13523.5	3
+13534.4	4
+13545.4	4
+13556.4	4
+13567.3	3
+13578.3	4
+13589.3	4
+13600.2	4
+13611.2	3
+13622.2	4
+13633.1	3
+13644.1	3
+13655.1	3
+13666	3
+13677	3
+13688	3
+13698.9	3
+13709.9	4
+13720.9	3
+13731.8	3
+13742.8	3
+13753.8	3
+13764.8	3
+13775.7	3
+13786.7	4
+13797.7	3
+13808.6	3
+13819.6	4
+13830.6	3
+13841.5	3
+13852.5	4
+13863.5	3
+13874.4	4
+13885.4	3
+13896.4	4
+13907.3	3
+13918.3	3
+13929.3	3
+13940.2	3
+13951.2	3
+13962.2	3
+13973.1	3
+13984.1	3
+13995.1	3
+14006	4
+14017	4
+14028	4
+14039	4
+14049.9	4
+14060.9	3
+14071.9	3
+14082.8	4
+14093.8	4
+14104.8	3
+14115.7	3
+14126.7	3
+14137.7	3
+14148.6	3
+14159.6	3
+14170.6	3
+14181.5	3
+14192.5	3
+14203.5	4
+14214.4	3
+14225.4	3
+14236.4	4
+14247.3	3
+14258.3	4
+14269.3	4
+14280.2	3
+14291.2	4
+14302.2	3
+14313.1	3
+14324.1	3
+14335.1	3
+14346.1	3
+14357	3
+14368	4
+14379	3
+14389.9	3
+14400.9	3
+14411.9	4
+14422.8	3
+14433.8	4
+14444.8	4
+14455.7	3
+14466.7	3
+14477.7	4
+14488.6	3
+14499.6	3
+14510.6	3
+14521.5	3
+14532.5	3
+14543.5	4
+14554.4	4
+14565.4	3
+14576.4	3
+14587.3	3
+14598.3	3
+14609.3	3
+14620.3	3
+14631.2	4
+14642.2	3
+14653.2	3
+14664.1	3
+14675.1	3
+14686.1	4
+14697	3
+14708	3
+14719	3
+14729.9	4
+14740.9	3
+14751.9	3
+14762.8	3
+14773.8	4
+14784.8	3
+14795.7	3
+14806.7	3
+14817.7	3
+14828.6	3
+14839.6	4
+14850.6	3
+14861.5	4
+14872.5	3
+14883.5	4
+14894.4	3
+14905.4	4
+14916.4	4
+14927.4	3
+14938.3	4
+14949.3	3
+14960.3	3
+14971.2	4
+14982.2	3
+14993.2	3
+15004.1	3
+15015.1	3
+15026.1	3
+15037	4
+15048	4
+15059	3
+15069.9	3
+15080.9	4
+15091.9	4
+15102.8	3
+15113.8	3
+15124.8	3
+15135.7	3
+15146.7	3
+15157.7	3
+15168.6	4
+15179.6	4
+15190.6	4
+15201.6	3
+15212.5	4
+15223.5	3
+15234.5	3
+15245.4	4
+15256.4	4
+15267.4	3
+15278.3	4
+15289.3	4
+15300.3	3
+15311.2	3
+15322.2	3
+15333.2	3
+15344.1	4
+15355.1	4
+15366.1	3
+15377	3
+15388	3
+15399	3
+15409.9	3
+15420.9	4
+15431.9	3
+15442.8	4
+15453.8	3
+15464.8	3
+15475.7	3
+15486.7	3
+15497.7	3
+15508.7	3
+15519.6	3
+15530.6	3
+15541.6	3
+15552.5	3
+15563.5	3
+15574.5	3
+15585.4	3
+15596.4	3
+15607.4	3
+15618.3	3
+15629.3	3
+15640.3	4
+15651.2	3
+15662.2	3
+15673.2	3
+15684.1	3
+15695.1	4
+15706.1	3
+15717	3
+15728	3
+15739	4
+15749.9	4
+15760.9	3
+15771.9	3
+15782.9	3
+15793.8	4
+15804.8	3
+15815.8	4
+15826.7	3
+15837.7	3
+15848.7	3
+15859.6	4
+15870.6	3
+15881.6	3
+15892.5	4
+15903.5	3
+15914.5	3
+15925.4	4
+15936.4	3
+15947.4	3
+15958.3	3
+15969.3	4
+15980.3	4
+15991.2	3
+16002.2	3
+16013.2	3
+16024.1	3
+16035.1	4
+16046.1	3
+16057	3
+16068	3
+16079	4
+16090	4
+16100.9	3
+16111.9	3
+16122.9	4
+16133.8	4
+16144.8	4
+16155.8	4
+16166.7	4
+16177.7	4
+16188.7	4
+16199.6	4
+16210.6	4
+16221.6	4
+16232.5	4
+16243.5	4
+16254.5	4
+16265.4	4
+16276.4	4
+16287.4	4
+16298.3	4
+16309.3	4
+16320.3	4
+16331.2	5
+16342.2	5
+16353.2	5
+16364.2	5
+16375.1	5
+16386.1	5
+16397.1	6
+16408	5
+16419	5
+16430	6
+16440.9	5
+16451.9	5
+16462.9	5
+16473.8	6
+16484.8	5
+16495.8	5
+16506.7	5
+16517.7	5
+16528.7	5
+16539.6	5
+16550.6	5
+16561.6	5
+16572.5	5
+16583.5	5
+16594.5	5
+16605.4	5
+16616.4	5
+16627.4	5
+16638.3	5
+16649.3	6
+16660.3	5
+16671.3	5
+16682.2	6
+16693.2	5
+16704.2	6
+16715.1	5
+16726.1	5
+16737.1	5
+16748	5
+16759	5
+16770	5
+16780.9	5
+16791.9	5
+16802.9	5
+16813.8	5
+16824.8	5
+16835.8	5
+16846.7	5
+16857.7	5
+16868.7	5
+16879.6	5
+16890.6	5
+16901.6	5
+16912.5	6
+16923.5	5
+16934.5	5
+16945.5	5
+16956.4	5
+16967.4	5
+16978.4	5
+16989.3	5
+17000.3	5
+17011.3	5
+17022.2	5
+17033.2	5
+17044.2	5
+17055.1	5
+17066.1	5
+17077.1	5
+17088	5
+17099	5
+17110	5
+17120.9	5
+17131.9	6
+17142.9	5
+17153.8	5
+17164.8	6
+17175.8	5
+17186.7	6
+17197.7	5
+17208.7	5
+17219.7	5
+17230.6	5
+17241.6	5
+17252.6	5
+17263.5	6
+17274.5	5
+17285.5	5
+17296.4	5
+17307.4	5
+17318.4	5
+17329.3	5
+17340.3	5
+17351.3	5
+17362.2	5
+17373.2	6
+17384.2	6
+17395.1	5
+17406.1	5
+17417.1	6
+17428	5
+17439	6
+17450	5
+17460.9	5
+17471.9	5
+17482.9	5
+17493.8	5
+17504.8	6
+17515.8	5
+17526.8	6
+17537.7	6
+17548.7	5
+17559.7	5
+17570.6	6
+17581.6	6
+17592.6	6
+17603.5	6
+17614.5	6
+17625.5	5
+17636.4	6
+17647.4	6
+17658.4	6
+17669.3	6
+17680.3	6
+17691.3	5
+17702.2	6
+17713.2	6
+17724.2	6
+17735.1	6
+17746.1	6
+17757.1	6
+17768	5
+17779	6
+17790	6
+17801	6
+17811.9	6
+17822.9	6
+17833.9	5
+17844.8	6
+17855.8	6
+17866.8	6
+17877.7	6
+17888.7	6
+17899.7	6
+17910.6	9
+17921.6	8
+17932.6	10
+17943.5	9
+17954.5	9
+17965.5	9
+17976.4	9
+17987.4	10
+17998.4	9
+18009.3	10
+18020.3	9
+18031.3	9
+18042.2	10
+18053.2	9
+18064.2	9
+18075.1	9
+18086.1	9
+18097.1	9
+18108.1	10
+18119	10
+18130	9
+18141	9
+18151.9	8
+18162.9	9
+18173.9	9
+18184.8	9
+18195.8	9
+18206.8	9
+18217.7	9
+18228.7	9
+18239.7	9
+18250.6	9
+18261.6	9
+18272.6	10
+18283.5	10
+18294.5	9
+18305.5	10
+18316.4	10
+18327.4	9
+18338.4	9
+18349.3	9
+18360.3	10
+18371.3	10
+18382.3	9
+18393.2	10
+18404.2	9
+18415.2	10
+18426.1	10
+18437.1	9
+18448.1	10
+18459	10
+18470	9
+18481	10
+18491.9	10
+18502.9	9
+18513.9	9
+18524.8	9
+18535.8	9
+18546.8	10
+18557.7	10
+18568.7	9
+18579.7	10
+18590.6	10
+18601.6	9
+18612.6	9
+18623.5	9
+18634.5	10
+18645.5	10
+18656.4	10
+18667.4	10
+18678.4	10
+18689.4	10
+18700.3	10
+18711.3	10
+18722.3	10
+18733.2	10
+18744.2	10
+18755.2	10
+18766.1	10
+18777.1	10
+18788.1	10
+18799	10
+18810	10
+18821	10
+18831.9	10
+18842.9	10
+18853.9	10
+18864.8	9
+18875.8	9
+18886.8	10
+18897.7	9
+18908.7	9
+18919.7	10
+18930.6	10
+18941.6	10
+18952.6	10
+18963.6	10
+18974.5	10
+18985.5	10
+18996.5	10
+19007.4	10
+19018.4	10
+19029.4	10
+19040.3	10
+19051.3	10
+19062.3	10
+19073.2	10
+19084.2	10
+19095.2	10
+19106.1	10
+19117.1	10
+19128.1	10
+19139	10
+19150	10
+19161	10
+19171.9	10
+19182.9	10
+19193.9	10
+19204.8	10
+19215.8	10
+19226.8	10
+19237.7	10
+19248.7	10
+19259.7	10
+19270.7	10
+19281.6	10
+19292.6	10
+19303.6	10
+19314.5	10
+19325.5	10
+19336.5	10
+19347.4	10
+19358.4	10
+19369.4	10
+19380.3	10
+19391.3	10
+19402.3	10
+19413.2	10
+19424.2	10
+19435.2	10
+19446.1	10
+19457.1	10
+19468.1	10
+19479	10
+19490	10
+19501	10
+19511.9	10
+19522.9	10
+19533.9	10
+19544.9	10
+19555.8	10
+19566.8	10
+19577.8	10
+19588.7	11
+19599.7	11
+19610.7	11
+19621.6	11
+19632.6	11
+19643.6	11
+19654.5	12
+19665.5	11
+19676.5	11
+19687.4	11
+19698.4	11
+19709.4	11
+19720.3	11
+19731.3	11
+19742.3	11
+19753.2	11
+19764.2	11
+19775.2	11
+19786.1	12
+19797.1	11
+19808.1	11
+19819	12
+19830	12
+19841	11
+19852	11
+19862.9	11
+19873.9	11
+19884.9	11
+19895.8	11
+19906.8	11
+19917.8	11
+19928.7	11
+19939.7	11
+19950.7	11
+19961.6	11
+19972.6	11
+19983.6	11
+19994.5	11
+20005.5	11
+20016.5	11
+20027.4	11
+20038.4	11
+20049.4	11
+20060.3	11
+20071.3	12
+20082.3	11
+20093.2	12
+20104.2	11
+20115.2	11
+20126.2	11
+20137.1	12
+20148.1	11
+20159.1	11
+20170	11
+20181	11
+20192	11
+20202.9	11
+20213.9	11
+20224.9	11
+20235.8	11
+20246.8	11
+20257.8	11
+20268.7	11
+20279.7	11
+20290.7	11
+20301.6	11
+20312.6	11
+20323.6	11
+20334.5	11
+20345.5	11
+20356.5	11
+20367.4	12
+20378.4	12
+20389.4	11
+20400.3	12
+20411.3	11
+20422.3	11
+20433.3	11
+20444.2	11
+20455.2	11
+20466.2	11
+20477.1	11
+20488.1	11
+20499.1	11
+20510	11
+20521	11
+20532	11
+20542.9	11
+20553.9	11
+20564.9	11
+20575.8	11
+20586.8	12
+20597.8	11
+20608.7	11
+20619.7	11
+20630.7	11
+20641.6	11
+20652.6	11
+20663.6	12
+20674.5	12
+20685.5	12
+20696.5	11
+20707.5	11
+20718.4	11
+20729.4	11
+20740.4	12
+20751.3	11
+20762.3	11
+20773.3	11
+20784.2	11
+20795.2	11
+20806.2	11
+20817.1	11
+20828.1	11
+20839.1	12
+20850	12
+20861	11
+20872	12
+20882.9	11
+20893.9	12
+20904.9	12
+20915.8	11
+20926.8	12
+20937.8	12
+20948.7	12
+20959.7	11
+20970.7	11
+20981.7	11
+20992.6	11
+21003.6	11
+21014.6	11
+21025.5	12
+21036.5	11
+21047.5	11
+21058.4	11
+21069.4	11
+21080.4	11
+21091.3	11
+21102.3	11
+21113.3	11
+21124.2	11
+21135.2	11
+21146.2	11
+21157.1	11
+21168.1	11
+21179.1	11
+21190	11
+21201	11
+21212	12
+21222.9	12
+21233.9	12
+21244.9	12
+21255.8	11
+21266.8	11
+21277.8	11
+21288.8	12
+21299.7	11
+21310.7	11
+21321.7	11
+21332.6	12
+21343.6	12
+21354.6	12
+21365.5	11
+21376.5	11
+21387.5	11
+21398.4	11
+21409.4	11
+21420.4	11
+21431.3	11
+21442.3	11
+21453.3	11
+21464.2	11
+21475.2	12
+21486.2	11
+21497.1	11
+21508.1	11
+21519.1	11
+21530	11
+21541	11
+21552	11
+21563	11
+21573.9	11
+21584.9	12
+21595.9	11
+21606.8	12
+21617.8	11
+21628.8	12
+21639.7	11
+21650.7	12
+21661.7	12
+21672.6	12
+21683.6	12
+21694.6	11
+21705.5	11
+21716.5	11
+21727.5	11
+21738.4	12
+21749.4	11
+21760.4	11
+21771.3	11
+21782.3	11
+21793.3	11
+21804.2	11
+21815.2	11
+21826.2	11
+21837.1	11
+21848.1	12
+21859.1	11
+21870.1	11
+21881	11
+21892	11
+21903	11
+21913.9	12
+21924.9	11
+21935.9	11
+21946.8	11
+21957.8	12
+21968.8	11
+21979.7	11
+21990.7	11
+22001.7	11
+22012.6	11
+22023.6	11
+22034.6	12
+22045.5	11
+22056.5	11
+22067.5	11
+22078.4	11
+22089.4	11
+22100.4	11
+22111.3	12
+22122.3	12
+22133.3	12
+22144.3	12
+22155.2	11
+22166.2	11
+22177.2	11
+22188.1	12
+22199.1	11
+22210.1	11
+22221	11
+22232	12
+22243	12
+22253.9	11
+22264.9	11
+22275.9	11
+22286.8	12
+22297.8	11
+22308.8	12
+22319.7	11
+22330.7	11
+22341.7	11
+22352.6	11
+22363.6	11
+22374.6	11
+22385.5	11
+22396.5	11
+22407.5	11
+22418.4	11
+22429.4	11
+22440.4	11
+22451.4	11
+22462.3	11
+22473.3	11
+22484.3	11
+22495.2	11
+22506.2	11
+22517.2	11
+22528.1	11
+22539.1	11
+22550.1	11
+22561	11
+22572	11
+22583	11
+22593.9	12
+22604.9	11
+22615.9	11
+22626.8	12
+22637.8	11
+22648.8	11
+22659.7	11
+22670.7	11
+22681.7	12
+22692.6	11
+22703.6	11
+22714.6	12
+22725.6	11
+22736.5	11
+22747.5	12
+22758.5	11
+22769.4	11
+22780.4	11
+22791.4	12
+22802.3	11
+22813.3	11
+22824.3	11
+22835.2	11
+22846.2	11
+22857.2	11
+22868.1	12
+22879.1	11
+22890.1	12
+22901	12
+22912	12
+22923	12
+22933.9	13
+22944.9	14
+22955.9	13
+22966.8	13
+22977.8	14
+22988.8	14
+22999.7	13
+23010.7	13
+23021.7	13
+23032.7	13
+23043.6	13
+23054.6	13
+23065.6	13
+23076.5	13
+23087.5	13
+23098.5	14
+23109.4	14
+23120.4	13
+23131.4	13
+23142.3	13
+23153.3	13
+23164.3	13
+23175.2	13
+23186.2	14
+23197.2	13
+23208.1	13
+23219.1	13
+23230.1	14
+23241	14
+23252	13
+23263	14
+23273.9	13
+23284.9	13
+23295.9	13
+23306.9	13
+23317.8	13
+23328.8	14
+23339.8	13
+23350.7	13
+23361.7	13
+23372.7	14
+23383.6	13
+23394.6	13
+23405.6	13
+23416.5	13
+23427.5	14
+23438.5	13
+23449.4	13
+23460.4	13
+23471.4	13
+23482.3	13
+23493.3	13
+23504.3	13
+23515.2	13
+23526.2	13
+23537.2	13
+23548.1	13
+23559.1	14
+23570.1	13
+23581	14
+23592	14
+23603	14
+23614	14
+23624.9	14
+23635.9	13
+23646.9	13
+23657.8	14
+23668.8	13
+23679.8	13
+23690.7	13
+23701.7	13
+23712.7	13
+23723.6	13
+23734.6	13
+23745.6	13
+23756.5	13
+23767.5	14
+23778.5	14
+23789.4	14
+23800.4	14
+23811.4	13
+23822.3	13
+23833.3	14
+23844.3	13
+23855.2	13
+23866.2	14
+23877.2	13
+23888.2	14
+23899.1	13
+23910.1	14
+23921.1	14
+23932	13
+23943	14
+23954	13
+23964.9	13
+23975.9	13
+23986.9	14
+23997.8	14
+24008.8	13
+24019.8	14
+24030.7	13
+24041.7	14
+24052.7	13
+24063.6	13
+24074.6	13
+24085.6	13
+24096.5	14
+24107.5	14
+24118.5	13
+24129.4	14
+24140.4	14
+24151.4	14
+24162.3	14
+24173.3	13
+24184.3	14
+24195.3	14
+24206.2	14
+24217.2	14
+24228.2	14
+24239.1	14
+24250.1	14
+24261.1	14
+24272	14
+24283	14
+24294	14
+24304.9	14
+24315.9	14
+24326.9	14
+24337.8	14
+24348.8	14
+24359.8	14
+24370.7	14
+24381.7	14
+24392.7	14
+24403.6	14
+24414.6	14
+24425.6	14
+24436.5	14
+24447.5	14
+24458.5	14
+24469.5	14
+24480.4	14
+24491.4	14
+24502.4	14
+24513.3	14
+24524.3	14
+24535.3	14
+24546.2	14
+24557.2	14
+24568.2	14
+24579.1	14
+24590.1	14
+24601.1	14
+24612	14
+24623	14
+24634	14
+24644.9	14
+24655.9	14
+24666.9	14
+24677.8	12
+24688.8	10
+24699.8	10
+24710.7	11
+24721.7	12
+24732.7	11
+24743.7	11
+24754.6	11
+24765.6	11
+24776.6	11
+24787.5	11
+24798.5	11
+24809.5	11
+24820.4	11
+24831.4	11
+24842.4	11
+24853.3	11
+24864.3	12
+24875.3	12
+24886.2	12
+24897.2	12
+24908.2	12
+24919.1	12
+24930.1	12
+24941.1	12
+24952	12
+24963	12
+24974	12
+24984.9	12
+24995.9	12
+25006.9	12
+25017.8	12
+25028.8	12
+25039.8	12
+25050.8	12
+25061.7	12
+25072.7	12
+25083.7	12
+25094.6	12
+25105.6	12
+25116.6	12
+25127.5	12
+25138.5	12
+25149.5	12
+25160.4	12
+25171.4	12
+25182.4	12
+25193.3	12
+25204.3	12
+25215.3	12
+25226.2	12
+25237.2	12
+25248.2	12
+25259.1	12
+25270.1	12
+25281.1	12
+25292	12
+25303	12
+25314	12
+25325	12
+25335.9	12
+25346.9	12
+25357.9	12
+25368.8	12
+25379.8	12
+25390.8	12
+25401.7	12
+25412.7	12
+25423.7	12
+25434.6	12
+25445.6	12
+25456.6	12
+25467.5	12
+25478.5	12
+25489.5	12
+25500.4	12
+25511.4	12
+25522.4	12
+25533.3	12
+25544.3	12
+25555.3	12
+25566.2	12
+25577.2	12
+25588.2	12
+25599.1	12
+25610.1	12
+25621.1	13
+25632.1	14
+25643	14
+25654	14
+25665	14
+25675.9	14
+25686.9	15
+25697.9	15
+25708.8	15
+25719.8	15
+25730.8	15
+25741.7	15
+25752.7	16
+25763.7	15
+25774.6	15
+25785.6	15
+25796.6	15
+25807.5	15
+25818.5	15
+25829.5	15
+25840.4	15
+25851.4	15
+25862.4	16
+25873.3	15
+25884.3	15
+25895.3	15
+25906.3	15
+25917.2	15
+25928.2	15
+25939.2	15
+25950.1	15
+25961.1	15
+25972.1	16
+25983	15
+25994	15
+26005	15
+26015.9	15
+26026.9	15
+26037.9	15
+26048.8	15
+26059.8	15
+26070.8	15
+26081.7	15
+26092.7	15
+26103.7	15
+26114.6	15
+26125.6	15
+26136.6	15
+26147.5	15
+26158.5	15
+26169.5	15
+26180.4	16
+26191.4	15
+26202.4	15
+26213.4	15
+26224.3	15
+26235.3	15
+26246.3	15
+26257.2	15
+26268.2	15
+26279.2	15
+26290.1	15
+26301.1	15
+26312.1	15
+26323	15
+26334	15
+26345	15
+26355.9	15
+26366.9	15
+26377.9	15
+26388.8	15
+26399.8	15
+26410.8	15
+26421.7	15
+26432.7	15
+26443.7	15
+26454.6	15
+26465.6	15
+26476.6	15
+26487.6	15
+26498.5	15
+26509.5	15
+26520.5	15
+26531.4	15
+26542.4	15
+26553.4	15
+26564.3	15
+26575.3	15
+26586.3	15
+26597.2	15
+26608.2	15
+26619.2	15
+26630.1	15
+26641.1	15
+26652.1	15
+26663	15
+26674	15
+26685	15
+26695.9	15
+26706.9	16
+26717.9	15
+26728.8	15
+26739.8	15
+26750.8	15
+26761.7	16
+26772.7	16
+26783.7	15
+26794.7	15
+26805.6	15
+26816.6	15
+26827.6	15
+26838.5	16
+26849.5	15
+26860.5	15
+26871.4	15
+26882.4	15
+26893.4	15
+26904.3	16
+26915.3	15
+26926.3	15
+26937.2	16
+26948.2	15
+26959.2	15
+26970.1	15
+26981.1	15
+26992.1	15
+27003	15
+27014	15
+27025	16
+27035.9	16
+27046.9	15
+27057.9	15
+27068.9	15
+27079.8	15
+27090.8	15
+27101.8	15
+27112.7	15
+27123.7	15
+27134.7	15
+27145.6	15
+27156.6	15
+27167.6	15
+27178.5	15
+27189.5	15
+27200.5	15
+27211.4	15
+27222.4	15
+27233.4	15
+27244.3	15
+27255.3	15
+27266.3	15
+27277.2	15
+27288.2	15
+27299.2	15
+27310.1	15
+27321.1	15
+27332.1	15
+27343	15
+27354	15
+27365	15
+27376	15
+27386.9	16
+27397.9	16
+27408.9	16
+27419.8	16
+27430.8	16
+27441.8	16
+27452.7	14
+27463.7	14
+27474.7	15
+27485.6	16
+27496.6	16
+27507.6	16
+27518.5	16
+27529.5	16
+27540.5	16
+27551.4	17
+27562.4	18
+27573.4	18
+27584.3	18
+27595.3	18
+27606.3	18
+27617.2	18
+27628.2	18
+27639.2	18
+27650.2	18
+27661.1	18
+27672.1	18
+27683.1	18
+27694	18
+27705	18
+27716	18
+27726.9	18
+27737.9	18
+27748.9	18
+27759.8	18
+27770.8	18
+27781.8	18
+27792.7	18
+27803.7	18
+27814.7	18
+27825.6	18
+27836.6	18
+27847.6	18
+27858.5	18
+27869.5	18
+27880.5	18
+27891.4	18
+27902.4	18
+27913.4	14
+27924.3	14
+27935.3	14
+27946.3	14
+27957.3	13
+27968.2	13
+27979.2	13
+27990.2	13
+28001.1	13
+28012.1	13
+28023.1	13
+28034	14
+28045	14
+28056	13
+28066.9	14
+28077.9	13
+28088.9	13
+28099.8	13
+28110.8	13
+28121.8	14
+28132.7	14
+28143.7	14
+28154.7	14
+28165.6	14
+28176.6	13
+28187.6	13
+28198.5	14
+28209.5	14
+28220.5	14
+28231.5	13
+28242.4	14
+28253.4	14
+28264.4	14
+28275.3	14
+28286.3	14
+28297.3	14
+28308.2	14
+28319.2	14
+28330.2	14
+28341.1	14
+28352.1	14
+28363.1	14
+28374	14
+28385	14
+28396	14
+28406.9	14
+28417.9	14
+28428.9	14
+28439.8	14
+28450.8	14
+28461.8	14
+28472.7	14
+28483.7	14
+28494.7	14
+28505.7	14
+28516.6	14
+28527.6	14
+28538.6	14
+28549.5	14
+28560.5	14
+28571.5	14
+28582.4	14
+28593.4	14
+28604.4	14
+28615.3	14
+28626.3	14
+28637.3	14
+28648.2	14
+28659.2	14
+28670.2	14
+28681.1	14
+28692.1	14
+28703.1	14
+28714	14
+28725	14
+28736	14
+28746.9	14
+28757.9	14
+28768.9	14
+28779.8	14
+28790.8	15
+28801.8	17
+28812.8	18
+28823.7	17
+28834.7	17
+28845.7	17
+28856.6	17
+28867.6	17
+28878.6	18
+28889.5	17
+28900.5	17
+28911.5	17
+28922.4	17
+28933.4	17
+28944.4	18
+28955.3	17
+28966.3	17
+28977.3	17
+28988.2	17
+28999.2	18
+29010.2	18
+29021.1	17
+29032.1	18
+29043.1	17
+29054	17
+29065	17
+29076	18
+29087	18
+29097.9	17
+29108.9	18
+29119.9	18
+29130.8	17
+29141.8	17
+29152.8	18
+29163.7	17
+29174.7	18
+29185.7	18
+29196.6	18
+29207.6	17
+29218.6	17
+29229.5	18
+29240.5	18
+29251.5	17
+29262.4	17
+29273.4	17
+29284.4	17
+29295.3	18
+29306.3	17
+29317.3	18
+29328.2	17
+29339.2	17
+29350.2	18
+29361.1	17
+29372.1	17
+29383.1	17
+29394.1	17
+29405	17
+29416	17
+29427	18
+29437.9	17
+29448.9	17
+29459.9	18
+29470.8	18
+29481.8	17
+29492.8	18
+29503.7	17
+29514.7	18
+29525.7	16
+29536.6	17
+29547.6	18
+29558.6	17
+29569.5	17
+29580.5	17
+29591.5	17
+29602.4	18
+29613.4	17
+29624.4	17
+29635.3	18
+29646.3	18
+29657.3	17
+29668.3	17
+29679.2	17
+29690.2	18
+29701.2	17
+29712.1	18
+29723.1	17
+29734.1	18
+29745	17
+29756	17
+29767	17
+29777.9	18
+29788.9	17
+29799.9	18
+29810.8	17
+29821.8	18
+29832.8	18
+29843.7	17
+29854.7	17
+29865.7	17
+29876.6	17
+29887.6	16
+29898.6	18
+29909.5	17
+29920.5	17
+29931.5	18
+29942.4	17
+29953.4	17
+29964.4	17
+29975.4	18
+29986.3	18
+29997.3	17
+30008.3	17
+30019.2	17
+30030.2	17
+30041.2	18
+30052.1	17
+30063.1	18
+30074.1	17
+30085	17
+30096	18
+30107	18
+30117.9	17
+30128.9	18
+30139.9	17
+30150.8	18
+30161.8	17
+30172.8	18
+30183.7	17
+30194.7	18
+30205.7	17
+30216.6	17
+30227.6	17
+30238.6	18
+30249.6	17
+30260.5	17
+30271.5	17
+30282.5	18
+30293.4	17
+30304.4	18
+30315.4	18
+30326.3	18
+30337.3	18
+30348.3	17
+30359.2	18
+30370.2	18
+30381.2	17
+30392.1	17
+30403.1	17
+30414.1	17
+30425	17
+30436	18
+30447	17
+30457.9	17
+30468.9	18
+30479.9	17
+30490.8	18
+30501.8	18
+30512.8	17
+30523.7	17
+30534.7	17
+30545.7	17
+30556.7	17
+30567.6	17
+30578.6	17
+30589.6	17
+30600.5	18
+30611.5	17
+30622.5	17
+30633.4	17
+30644.4	17
+30655.4	18
+30666.3	17
+30677.3	17
+30688.3	18
+30699.2	17
+30710.2	17
+30721.2	17
+30732.1	18
+30743.1	17
+30754.1	18
+30765	18
+30776	18
+30787	17
+30797.9	17
+30808.9	17
+30819.9	18
+30830.9	17
+30841.8	18
+30852.8	18
+30863.8	18
+30874.7	17
+30885.7	18
+30896.7	17
+30907.6	18
+30918.6	17
+30929.6	17
+30940.5	17
+30951.5	17
+30962.5	18
+30973.4	18
+30984.4	17
+30995.4	18
+31006.3	17
+31017.3	17
+31028.3	18
+31039.2	17
+31050.2	17
+31061.2	17
+31072.1	17
+31083.1	18
+31094.1	17
+31105	17
+31116	18
+31127	17
+31138	17
+31148.9	17
+31159.9	17
+31170.9	18
+31181.8	17
+31192.8	18
+31203.8	17
+31214.7	18
+31225.7	17
+31236.7	17
+31247.6	17
+31258.6	18
+31269.6	18
+31280.5	18
+31291.5	18
+31302.5	17
+31313.4	17
+31324.4	17
+31335.4	17
+31346.3	17
+31357.3	17
+31368.3	17
+31379.2	18
+31390.2	17
+31401.2	17
+31412.2	17
+31423.1	17
+31434.1	18
+31445.1	17
+31456	17
+31467	18
+31478	17
+31488.9	17
+31499.9	18
+31510.9	17
+31521.8	18
+31532.8	17
+31543.8	18
+31554.7	17
+31565.7	18
+31576.7	17
+31587.6	18
+31598.6	18
+31609.6	18
+31620.5	18
+31631.5	18
+31642.5	17
+31653.4	18
+31664.4	18
+31675.4	17
+31686.3	17
+31697.3	18
+31708.3	17
+31719.3	17
+31730.2	17
+31741.2	17
+31752.2	17
+31763.1	18
+31774.1	18
+31785.1	18
+31796	18
+31807	17
+31818	17
+31828.9	17
+31839.9	17
+31850.9	17
+31861.8	17
+31872.8	17
+31883.8	18
+31894.7	17
+31905.7	17
+31916.7	17
+31927.6	18
+31938.6	18
+31949.6	18
+31960.5	18
+31971.5	18
+31982.5	18
+31993.5	17
+32004.4	16
+32015.4	16
+32026.4	16
+32037.3	16
+32048.3	16
+32059.3	16
+32070.2	16
+32081.2	16
+32092.2	16
+32103.1	16
+32114.1	16
+32125.1	16
+32136	16
+32147	16
+32158	16
+32168.9	16
+32179.9	16
+32190.9	16
+32201.8	16
+32212.8	16
+32223.8	16
+32234.7	16
+32245.7	16
+32256.7	16
+32267.7	16
+32278.6	16
+32289.6	16
+32300.6	16
+32311.5	16
+32322.5	15
+32333.5	16
+32344.4	16
+32355.4	15
+32366.4	16
+32377.3	16
+32388.3	16
+32399.3	15
+32410.2	15
+32421.2	16
+32432.2	15
+32443.1	16
+32454.1	15
+32465.1	15
+32476	15
+32487	15
+32498	16
+32508.9	15
+32519.9	15
+32530.9	15
+32541.8	15
+32552.8	15
+32563.8	16
+32574.8	16
+32585.7	16
+32596.7	16
+32607.7	16
+32618.6	16
+32629.6	16
+32640.6	16
+32651.5	16
+32662.5	16
+32673.5	16
+32684.4	16
+32695.4	14
+32706.4	14
+32717.3	14
+32728.3	14
+32739.3	14
+32750.2	14
+32761.2	14
+32772.2	14
+32783.1	14
+32794.1	14
+32805.1	14
+32816	14
+32827	14
+32838	14
+32849	14
+32859.9	14
+32870.9	14
+32881.9	14
+32892.8	14
+32903.8	13
+32914.8	14
+32925.7	14
+32936.7	14
+32947.7	13
+32958.6	13
+32969.6	13
+32980.6	14
+32991.5	13
+33002.5	13
+33013.5	13
+33024.4	13
+33035.4	14
+33046.4	13
+33057.3	13
+33068.3	14
+33079.3	13
+33090.2	13
+33101.2	13
+33112.2	14
+33123.1	14
+33134.1	13
+33145.1	14
+33156.1	13
+33167	13
+33178	13
+33189	14
+33199.9	13
+33210.9	13
+33221.9	13
+33232.8	13
+33243.8	13
+33254.8	13
+33265.7	13
+33276.7	13
+33287.7	13
+33298.6	14
+33309.6	13
+33320.6	14
+33331.5	14
+33342.5	14
+33353.5	14
+33364.4	13
+33375.4	14
+33386.4	13
+33397.3	14
+33408.3	13
+33419.3	13
+33430.3	13
+33441.2	14
+33452.2	13
+33463.2	14
+33474.1	13
+33485.1	13
+33496.1	14
+33507	14
+33518	14
+33529	14
+33539.9	14
+33550.9	14
+33561.9	14
+33572.8	14
+33583.8	14
+33594.8	14
+33605.7	14
+33616.7	14
+33627.7	14
+33638.6	14
+33649.6	14
+33660.6	14
+33671.5	14
+33682.5	14
+33693.5	14
+33704.4	14
+33715.4	14
+33726.4	14
+33737.4	14
+33748.3	14
+33759.3	14
+33770.3	14
+33781.2	14
+33792.2	14
+33803.2	14
+33814.1	14
+33825.1	14
+33836.1	14
+33847	14
+33858	14
+33869	14
+33879.9	14
+33890.9	14
+33901.9	13
+33912.8	12
+33923.8	12
+33934.8	12
+33945.7	12
+33956.7	12
+33967.7	12
+33978.6	12
+33989.6	12
+34000.6	12
+34011.6	12
+34022.5	12
+34033.5	12
+34044.5	12
+34055.4	12
+34066.4	12
+34077.4	12
+34088.3	12
+34099.3	12
+34110.3	12
+34121.2	12
+34132.2	12
+34143.2	12
+34154.1	12
+34165.1	12
+34176.1	12
+34187	12
+34198	12
+34209	12
+34219.9	12
+34230.9	12
+34241.9	12
+34252.8	12
+34263.8	12
+34274.8	12
+34285.7	12
+34296.7	12
+34307.7	12
+34318.7	12
+34329.6	12
+34340.6	12
+34351.6	12
+34362.5	12
+34373.5	12
+34384.5	12
+34395.4	12
+34406.4	12
+34417.4	12
+34428.3	12
+34439.3	12
+34450.3	12
+34461.2	12
+34472.2	12
+34483.2	12
+34494.1	12
+34505.1	12
+34516.1	12
+34527	12
+34538	12
+34549	12
+34559.9	12
+34570.9	12
+34581.9	12
+34592.9	12
+34603.8	12
+34614.8	12
+34625.8	12
+34636.7	12
+34647.7	12
+34658.7	12
+34669.6	11
+34680.6	10
+34691.6	10
+34702.5	10
+34713.5	10
+34724.5	9
+34735.4	8
+34746.4	8
+34757.4	8
+34768.3	8
+34779.3	8
+34790.3	8
+34801.2	8
+34812.2	8
+34823.2	8
+34834.1	8
+34845.1	8
+34856.1	8
+34867	8
+34878	8
+34889	8
+34900	8
+34910.9	8
+34921.9	8
+34932.9	8
+34943.8	8
+34954.8	8
+34965.8	8
+34976.7	8
+34987.7	8
+34998.7	7
+35009.6	6
+35020.6	6
+35031.6	6
+35042.5	6
+35053.5	6
+35064.5	5
+35075.4	4
+35086.4	4
+35097.4	4
+35108.3	4
+35119.3	4
+35130.3	4
+35141.2	4
+35152.2	4
+35163.2	4
+35174.2	4
+35185.1	4
+35196.1	4
+35207.1	4
+35218	4
+35229	4
+35240	4
+35250.9	4
+35261.9	4
+35272.9	4
+35283.8	4
+35294.8	4
+35305.8	4
+35316.7	4
+35327.7	4
+35338.7	4
+35349.6	4
+35360.6	4
+35371.6	4
+35382.5	4
+35393.5	4
+35404.5	4
+35415.4	4
+35426.4	4
+35437.4	4
+35448.3	4
+35459.3	4
+35470.3	4
+35481.3	4
+35492.2	4
+35503.2	4
+35514.2	4
+35525.1	4
+35536.1	4
+35547.1	4
+35558	4
+35569	4
+35580	4
+35590.9	4
+35601.9	4
+35612.9	4
+35623.8	4
+35634.8	4
+35645.8	4
+35656.7	4
+35667.7	4
+35678.7	4
+35689.6	4
+35700.6	4
+35711.6	4
+35722.5	4
+35733.5	4
+35744.5	4
+35755.5	4
+35766.4	4
+35777.4	4
+35788.4	4
+35799.3	4
+35810.3	4
+35821.3	4
+35832.2	4
+35843.2	4
+35854.2	4
+35865.1	4
+35876.1	4
+35887.1	4
+35898	4
+35909	4
+35920	4
+35930.9	4
+35941.9	4
+35952.9	4
+35963.8	4
+35974.8	4
+35985.8	4
+35996.7	4
+36007.7	4
+36018.7	4
+36029.7	4
+36040.6	4
+36051.6	4
+36062.6	4
+36073.5	4
+36084.5	4
+36095.5	4
+36106.4	3
+36117.4	1
+36128.4	1
+36139.3	7
+36150.3	11
+36161.3	13
+36172.2	20
+36183.2	23
+36194.2	23
+36205.1	23
+36216.1	24
+36227.1	23
+36238	24
+36249	23
+36260	23
+36270.9	23
+36281.9	23
+36292.9	23
+36303.8	25
+36314.8	25
+36325.8	25
+36336.8	25
+36347.7	25
+36358.7	25
+36369.7	26
+36380.6	26
+36391.6	25
+36402.6	26
+36413.5	25
+36424.5	25
+36435.5	26
+36446.4	26
+36457.4	25
+36468.4	26
+36479.3	25
+36490.3	26
+36501.3	26
+36512.2	25
+36523.2	25
+36534.2	25
+36545.1	25
+36556.1	25
+36567.1	26
+36578	25
+36589	25
+36600	25
+36611	25
+36621.9	25
+36632.9	25
+36643.9	25
+36654.8	25
+36665.8	26
+36676.8	26
+36687.7	25
+36698.7	25
+36709.7	25
+36720.6	25
+36731.6	25
+36742.6	25
+36753.5	25
+36764.5	25
+36775.5	25
+36786.4	26
+36797.4	26
+36808.4	25
+36819.3	25
+36830.3	25
+36841.3	25
+36852.2	25
+36863.2	25
+36874.2	25
+36885.1	25
+36896.1	25
+36907.1	25
+36918.1	25
+36929	25
+36940	26
+36951	25
+36961.9	25
+36972.9	25
+36983.9	26
+36994.8	25
+37005.8	25
+37016.8	26
+37027.7	25
+37038.7	25
+37049.7	26
+37060.6	26
+37071.6	26
+37082.6	25
+37093.5	26
+37104.5	25
+37115.5	25
+37126.4	25
+37137.4	26
+37148.4	26
+37159.3	25
+37170.3	25
+37181.3	26
+37192.3	26
+37203.2	26
+37214.2	25
+37225.2	25
+37236.1	26
+37247.1	25
+37258.1	25
+37269	25
+37280	26
+37291	25
+37301.9	25
+37312.9	25
+37323.9	26
+37334.8	26
+37345.8	26
+37356.8	26
+37367.7	25
+37378.7	26
+37389.7	26
+37400.6	25
+37411.6	26
+37422.6	25
+37433.5	25
+37444.5	26
+37455.5	25
+37466.4	26
+37477.4	25
+37488.4	26
+37499.4	26
+37510.3	25
+37521.3	26
+37532.3	25
+37543.2	25
+37554.2	25
+37565.2	25
+37576.1	26
+37587.1	26
+37598.1	25
+37609	26
+37620	25
+37631	26
+37641.9	26
+37652.9	25
+37663.9	25
+37674.8	26
+37685.8	25
+37696.8	25
+37707.7	25
+37718.7	25
+37729.7	25
+37740.6	26
+37751.6	25
+37762.6	26
+37773.6	26
+37784.5	26
+37795.5	25
+37806.5	25
+37817.4	26
+37828.4	25
+37839.4	25
+37850.3	26
+37861.3	25
+37872.3	25
+37883.2	25
+37894.2	25
+37905.2	25
+37916.1	26
+37927.1	25
+37938.1	25
+37949	25
+37960	26
+37971	25
+37981.9	26
+37992.9	26
+38003.9	26
+38014.8	26
+38025.8	25
+38036.8	26
+38047.7	25
+38058.7	25
+38069.7	25
+38080.7	26
+38091.6	25
+38102.6	25
+38113.6	26
+38124.5	26
+38135.5	25
+38146.5	25
+38157.4	26
+38168.4	25
+38179.4	26
+38190.3	25
+38201.3	25
+38212.3	26
+38223.2	26
+38234.2	25
+38245.2	26
+38256.1	26
+38267.1	25
+38278.1	26
+38289	25
+38300	25
+38311	26
+38321.9	25
+38332.9	26
+38343.9	25
+38354.9	26
+38365.8	26
+38376.8	26
+38387.8	25
+38398.7	25
+38409.7	26
+38420.7	26
+38431.6	26
+38442.6	26
+38453.6	26
+38464.5	25
+38475.5	26
+38486.5	25
+38497.4	25
+38508.4	25
+38519.4	25
+38530.3	26
+38541.3	25
+38552.3	26
+38563.2	25
+38574.2	25
+38585.2	26
+38596.1	25
+38607.1	25
+38618.1	26
+38629	26
+38640	26
+38651	25
+38662	25
+38672.9	25
+38683.9	25
+38694.9	25
+38705.8	26
+38716.8	25
+38727.8	26
+38738.7	26
+38749.7	25
+38760.7	26
+38771.6	26
+38782.6	25
+38793.6	26
+38804.5	25
+38815.5	25
+38826.5	25
+38837.4	25
+38848.4	26
+38859.4	25
+38870.3	25
+38881.3	24
+38892.3	25
+38903.2	26
+38914.2	26
+38925.2	25
+38936.2	26
+38947.1	25
+38958.1	25
+38969.1	25
+38980	26
+38991	26
+39002	25
+39012.9	25
+39023.9	25
+39034.9	25
+39045.8	25
+39056.8	25
+39067.8	25
+39078.7	25
+39089.7	25
+39100.7	25
+39111.6	25
+39122.6	25
+39133.6	25
+39144.5	26
+39155.5	26
+39166.5	25
+39177.4	26
+39188.4	25
+39199.4	25
+39210.3	25
+39221.3	26
+39232.3	25
+39243.3	25
+39254.2	25
+39265.2	25
+39276.2	25
+39287.1	26
+39298.1	26
+39309.1	25
+39320	26
+39331	26
+39342	26
+39352.9	26
+39363.9	25
+39374.9	25
+39385.8	25
+39396.8	26
+39407.8	26
+39418.7	26
+39429.7	25
+39440.7	25
+39451.6	25
+39462.6	25
+39473.6	25
+39484.5	25
+39495.5	25
+39506.5	26
+39517.5	25
+39528.4	26
+39539.4	25
+39550.4	25
+39561.3	25
+39572.3	26
+39583.3	25
+39594.2	25
+39605.2	26
+39616.2	25
+39627.1	25
+39638.1	25
+39649.1	25
+39660	26
+39671	25
+39682	26
+39692.9	25
+39703.9	25
+39714.9	25
+39725.8	26
+39736.8	26
+39747.8	25
+39758.7	25
+39769.7	25
+39780.7	26
+39791.7	26
+39802.6	25
+39813.6	24
+39824.6	25
+39835.5	26
+39846.5	26
+39857.5	25
+39868.4	26
+39879.4	26
+39890.4	26
+39901.3	25
+39912.3	26
+39923.3	25
+39934.2	25
+39945.2	25
+39956.2	26
+39967.1	25
+39978.1	25
+39989.1	25
+40000	24
+40011	26
+40022	25
+40032.9	26
+40043.9	25
+40054.9	25
+40065.8	25
+40076.8	26
+40087.8	26
+40098.8	25
+40109.7	25
+40120.7	25
+40131.7	26
+40142.6	25
+40153.6	25
+40164.6	26
+40175.5	26
+40186.5	25
+40197.5	26
+40208.4	26
+40219.4	25
+40230.4	26
+40241.3	26
+40252.3	26
+40263.3	25
+40274.2	25
+40285.2	26
+40296.2	26
+40307.1	25
+40318.1	26
+40329.1	26
+40340	25
+40351	26
+40362	26
+40373	26
+40383.9	25
+40394.9	25
+40405.9	25
+40416.8	25
+40427.8	26
+40438.8	25
+40449.7	25
+40460.7	25
+40471.7	26
+40482.6	25
+40493.6	26
+40504.6	26
+40515.5	26
+40526.5	25
+40537.5	26
+40548.4	26
+40559.4	25
+40570.4	25
+40581.3	25
+40592.3	25
+40603.3	25
+40614.2	25
+40625.2	25
+40636.2	25
+40647.1	25
+40658.1	26
+40669.1	24
+40680.1	25
+40691	25
+40702	25
+40713	25
+40723.9	25
+40734.9	26
+40745.9	25
+40756.8	25
+40767.8	26
+40778.8	25
+40789.7	25
+40800.7	26
+40811.7	25
+40822.6	25
+40833.6	25
+40844.6	25
+40855.5	25
+40866.5	25
+40877.5	25
+40888.4	26
+40899.4	25
+40910.4	25
+40921.3	25
+40932.3	25
+40943.3	25
+40954.3	24
+40965.2	26
+40976.2	25
+40987.2	25
+40998.1	25
+41009.1	25
+41020.1	25
+41031	25
+41042	26
+41053	26
+41063.9	26
+41074.9	26
+41085.9	26
+41096.8	25
+41107.8	25
+41118.8	26
+41129.7	26
+41140.7	25
+41151.7	26
+41162.6	25
+41173.6	25
+41184.6	26
+41195.5	25
+41206.5	25
+41217.5	26
+41228.4	25
+41239.4	26
+41250.4	26
+41261.4	25
+41272.3	26
+41283.3	25
+41294.3	25
+41305.2	25
+41316.2	26
+41327.2	25
+41338.1	25
+41349.1	25
+41360.1	25
+41371	25
+41382	26
+41393	25
+41403.9	25
+41414.9	26
+41425.9	25
+41436.8	25
+41447.8	26
+41458.8	25
+41469.7	25
+41480.7	26
+41491.7	26
+41502.6	25
+41513.6	25
+41524.6	25
+41535.6	25
+41546.5	26
+41557.5	26
+41568.5	25
+41579.4	25
+41590.4	25
+41601.4	26
+41612.3	25
+41623.3	25
+41634.3	26
+41645.2	25
+41656.2	26
+41667.2	26
+41678.1	25
+41689.1	26
+41700.1	26
+41711	26
+41722	25
+41733	25
+41743.9	25
+41754.9	26
+41765.9	26
+41776.8	25
+41787.8	26
+41798.8	25
+41809.7	26
+41820.7	25
+41831.7	25
+41842.7	26
+41853.6	25
+41864.6	25
+41875.6	26
+41886.5	25
+41897.5	26
+41908.5	26
+41919.4	25
+41930.4	26
+41941.4	25
+41952.3	26
+41963.3	25
+41974.3	26
+41985.2	25
+41996.2	25
+42007.2	25
+42018.1	25
+42029.1	26
+42040.1	25
+42051	26
+42062	25
+42073	25
+42083.9	26
+42094.9	25
+42105.9	26
+42116.9	26
+42127.8	25
+42138.8	26
+42149.8	25
+42160.7	25
+42171.7	25
+42182.7	26
+42193.6	25
+42204.6	25
+42215.6	26
+42226.5	25
+42237.5	26
+42248.5	26
+42259.4	25
+42270.4	25
+42281.4	25
+42292.3	25
+42303.3	24
+42314.3	25
+42325.2	25
+42336.2	26
+42347.2	25
+42358.1	25
+42369.1	26
+42380.1	25
+42391	25
+42402	26
+42413	25
+42424	26
+42434.9	25
+42445.9	26
+42456.9	25
+42467.8	26
+42478.8	26
+42489.8	26
+42500.7	26
+42511.7	25
+42522.7	26
+42533.6	25
+42544.6	26
+42555.6	25
+42566.5	26
+42577.5	25
+42588.5	25
+42599.4	26
+42610.4	25
+42621.4	26
+42632.3	25
+42643.3	25
+42654.3	25
+42665.2	26
+42676.2	25
+42687.2	26
+42698.2	25
+42709.1	26
+42720.1	26
+42731.1	26
+42742	26
+42753	25
+42764	25
+42774.9	26
+42785.9	25
+42796.9	26
+42807.8	25
+42818.8	26
+42829.8	25
+42840.7	26
+42851.7	25
+42862.7	26
+42873.6	25
+42884.6	26
+42895.6	25
+42906.5	25
+42917.5	26
+42928.5	26
+42939.4	25
+42950.4	26
+42961.4	26
+42972.3	25
+42983.3	25
+42994.3	26
+43005.3	26
+43016.2	25
+43027.2	25
+43038.2	26
+43049.1	25
+43060.1	25
+43071.1	25
+43082	26
+43093	26
+43104	25
+43114.9	25
+43125.9	26
+43136.9	25
+43147.8	26
+43158.8	25
+43169.8	26
+43180.7	26
+43191.7	26
+43202.7	25
+43213.6	25
+43224.6	25
+43235.6	26
+43246.5	26
+43257.5	25
+43268.5	25
+43279.5	25
+43290.4	26
+43301.4	26
+43312.4	25
+43323.3	26
+43334.3	26
+43345.3	26
+43356.2	25
+43367.2	25
+43378.2	25
+43389.1	26
+43400.1	25
+43411.1	26
+43422	25
+43433	25
+43444	25
+43454.9	25
+43465.9	25
+43476.9	26
+43487.8	25
+43498.8	25
+43509.8	25
+43520.7	25
+43531.7	26
+43542.7	25
+43553.7	26
+43564.6	25
+43575.6	24
+43586.6	25
+43597.5	26
+43608.5	25
+43619.5	26
+43630.4	26
+43641.4	25
+43652.4	26
+43663.3	26
+43674.3	25
+43685.3	25
+43696.2	25
+43707.2	26
+43718.2	26
+43729.1	25
+43740.1	25
+43751.1	25
+43762	26
+43773	25
+43784	25
+43794.9	26
+43805.9	26
+43816.9	25
+43827.8	25
+43838.8	25
+43849.8	25
+43860.8	25
+43871.7	26
+43882.7	25
+43893.7	26
+43904.6	25
+43915.6	26
+43926.6	25
+43937.5	26
+43948.5	25
+43959.5	25
+43970.4	25
+43981.4	26
+43992.4	25
+44003.3	26
+44014.3	25
+44025.3	25
+44036.2	25
+44047.2	25
+44058.2	25
+44069.1	26
+44080.1	25
+44091.1	25
+44102	25
+44113	25
+44124	25
+44135	25
+44145.9	25
+44156.9	25
+44167.9	26
+44178.8	25
+44189.8	25
+44200.8	25
+44211.7	25
+44222.7	25
+44233.7	26
+44244.6	25
+44255.6	26
+44266.6	26
+44277.5	26
+44288.5	25
+44299.5	26
+44310.4	26
+44321.4	25
+44332.4	25
+44343.3	25
+44354.3	25
+44365.3	26
+44376.2	25
+44387.2	26
+44398.2	26
+44409.1	25
+44420.1	25
+44431.1	25
+44442.1	25
+44453	25
+44464	26
+44475	25
+44485.9	25
+44496.9	26
+44507.9	26
+44518.8	25
+44529.8	26
+44540.8	25
+44551.7	26
+44562.7	26
+44573.7	25
+44584.6	25
+44595.6	25
+44606.6	25
+44617.5	25
+44628.5	25
+44639.5	25
+44650.4	25
+44661.4	25
+44672.4	26
+44683.3	26
+44694.3	25
+44705.3	26
+44716.3	26
+44727.2	26
+44738.2	25
+44749.2	26
+44760.1	25
+44771.1	25
+44782.1	26
+44793	25
+44804	26
+44815	26
+44825.9	25
+44836.9	26
+44847.9	25
+44858.8	26
+44869.8	25
+44880.8	25
+44891.7	26
+44902.7	26
+44913.7	25
+44924.6	26
+44935.6	25
+44946.6	25
+44957.5	25
+44968.5	25
+44979.5	25
+44990.4	25
+45001.4	26
+45012.4	25
+45023.4	26
+45034.3	25
+45045.3	25
+45056.3	25
+45067.2	25
+45078.2	26
+45089.2	25
+45100.1	26
+45111.1	25
+45122.1	26
+45133	25
+45144	26
+45155	26
+45165.9	25
+45176.9	25
+45187.9	26
+45198.8	25
+45209.8	26
+45220.8	25
+45231.7	25
+45242.7	26
+45253.7	25
+45264.6	25
+45275.6	26
+45286.6	25
+45297.6	25
+45308.5	25
+45319.5	26
+45330.5	26
+45341.4	26
+45352.4	25
+45363.4	26
+45374.3	26
+45385.3	25
+45396.3	25
+45407.2	26
+45418.2	25
+45429.2	25
+45440.1	25
+45451.1	25
+45462.1	25
+45473	25
+45484	25
+45495	25
+45505.9	26
+45516.9	25
+45527.9	25
+45538.8	25
+45549.8	25
+45560.8	25
+45571.7	26
+45582.7	26
+45593.7	25
+45604.7	25
+45615.6	25
+45626.6	25
+45637.6	25
+45648.5	25
+45659.5	26
+45670.5	25
+45681.4	25
+45692.4	25
+45703.4	25
+45714.3	26
+45725.3	25
+45736.3	25
+45747.2	25
+45758.2	26
+45769.2	25
+45780.1	25
+45791.1	25
+45802.1	25
+45813	25
+45824	26
+45835	25
+45845.9	25
+45856.9	26
+45867.9	25
+45878.9	25
+45889.8	25
+45900.8	25
+45911.8	25
+45922.7	26
+45933.7	25
+45944.7	25
+45955.6	25
+45966.6	25
+45977.6	26
+45988.5	25
+45999.5	26
+46010.5	26
+46021.4	27
+46032.4	27
+46043.4	27
+46054.3	27
+46065.3	27
+46076.3	28
+46087.2	28
+46098.2	27
+46109.2	28
+46120.1	28
+46131.1	27
+46142.1	27
+46153	27
+46164	27
+46175	29
+46186	29
+46196.9	29
+46207.9	29
+46218.9	29
+46229.8	29
+46240.8	29
+46251.8	30
+46262.7	30
+46273.7	29
+46284.7	29
+46295.6	29
+46306.6	29
+46317.6	29
+46328.5	29
+46339.5	29
+46350.5	29
+46361.4	30
+46372.4	29
+46383.4	29
+46394.3	29
+46405.3	29
+46416.3	29
+46427.2	29
+46438.2	29
+46449.2	30
+46460.2	29
+46471.1	28
+46482.1	29
+46493.1	29
+46504	29
+46515	29
+46526	29
+46536.9	29
+46547.9	29
+46558.9	30
+46569.8	30
+46580.8	28
+46591.8	30
+46602.7	29
+46613.7	30
+46624.7	29
+46635.6	29
+46646.6	29
+46657.6	30
+46668.5	30
+46679.5	30
+46690.5	29
+46701.4	29
+46712.4	30
+46723.4	29
+46734.3	29
+46745.3	30
+46756.3	29
+46767.3	30
+46778.2	30
+46789.2	29
+46800.2	29
+46811.1	29
+46822.1	30
+46833.1	30
+46844	29
+46855	30
+46866	29
+46876.9	29
+46887.9	29
+46898.9	30
+46909.8	30
+46920.8	30
+46931.8	29
+46942.7	30
+46953.7	30
+46964.7	29
+46975.6	29
+46986.6	29
+46997.6	30
+47008.5	29
+47019.5	29
+47030.5	30
+47041.5	30
+47052.4	28
+47063.4	30
+47074.4	30
+47085.3	29
+47096.3	30
+47107.3	29
+47118.2	30
+47129.2	30
+47140.2	30
+47151.1	29
+47162.1	30
+47173.1	29
+47184	30
+47195	29
+47206	30
+47216.9	29
+47227.9	29
+47238.9	29
+47249.8	29
+47260.8	30
+47271.8	29
+47282.7	30
+47293.7	30
+47304.7	30
+47315.7	30
+47326.6	30
+47337.6	30
+47348.6	29
+47359.5	29
+47370.5	30
+47381.5	29
+47392.4	29
+47403.4	29
+47414.4	30
+47425.3	29
+47436.3	29
+47447.3	30
+47458.2	30
+47469.2	30
+47480.2	30
+47491.1	29
+47502.1	29
+47513.1	29
+47524	29
+47535	29
+47546	29
+47556.9	29
+47567.9	30
+47578.9	30
+47589.8	29
+47600.8	29
+47611.8	30
+47622.8	29
+47633.7	29
+47644.7	29
+47655.7	30
+47666.6	29
+47677.6	30
+47688.6	30
+47699.5	29
+47710.5	30
+47721.5	30
+47732.4	29
+47743.4	29
+47754.4	30
+47765.3	30
+47776.3	29
+47787.3	30
+47798.2	30
+47809.2	30
+47820.2	29
+47831.1	30
+47842.1	29
+47853.1	29
+47864	29
+47875	29
+47886	29
+47897	30
+47907.9	29
+47918.9	29
+47929.9	30
+47940.8	29
+47951.8	30
+47962.8	29
+47973.7	29
+47984.7	30
+47995.7	29
+48006.6	29
+48017.6	30
+48028.6	29
+48039.5	29
+48050.5	30
+48061.5	29
+48072.4	29
+48083.4	30
+48094.4	29
+48105.3	29
+48116.3	30
+48127.3	29
+48138.2	30
+48149.2	30
+48160.2	29
+48171.1	29
+48182.1	29
+48193.1	30
+48204.1	29
+48215	29
+48226	29
+48237	29
+48247.9	29
+48258.9	29
+48269.9	30
+48280.8	30
+48291.8	29
+48302.8	30
+48313.7	30
+48324.7	29
+48335.7	29
+48346.6	30
+48357.6	29
+48368.6	29
+48379.5	30
+48390.5	29
+48401.5	29
+48412.4	30
+48423.4	29
+48434.4	29
+48445.3	29
+48456.3	30
+48467.3	30
+48478.3	29
+48489.2	30
+48500.2	29
+48511.2	30
+48522.1	30
+48533.1	29
+48544.1	28
+48555	29
+48566	30
+48577	30
+48587.9	30
+48598.9	30
+48609.9	30
+48620.8	30
+48631.8	30
+48642.8	29
+48653.7	30
+48664.7	30
+48675.7	29
+48686.6	29
+48697.6	29
+48708.6	29
+48719.5	29
+48730.5	29
+48741.5	29
+48752.4	30
+48763.4	30
+48774.4	31
+48785.4	35
+48796.3	35
+48807.3	35
+48818.3	35
+48829.2	35
+48840.2	35
+48851.2	36
+48862.1	35
+48873.1	34
+48884.1	36
+48895	36
+48906	36
+48917	36
+48927.9	36
+48938.9	36
+48949.9	35
+48960.8	36
+48971.8	36
+48982.8	35
+48993.7	35
+49004.7	36
+49015.7	35
+49026.6	36
+49037.6	36
+49048.6	36
+49059.6	36
+49070.5	36
+49081.5	34
+49092.5	35
+49103.4	35
+49114.4	34
+49125.4	36
+49136.3	36
+49147.3	35
+49158.3	36
+49169.2	35
+49180.2	36
+49191.2	36
+49202.1	35
+49213.1	35
+49224.1	36
+49235	35
+49246	35
+49257	35
+49267.9	36
+49278.9	35
+49289.9	36
+49300.8	35
+49311.8	36
+49322.8	36
+49333.7	36
+49344.7	35
+49355.7	35
+49366.7	36
+49377.6	35
+49388.6	35
+49399.6	35
+49410.5	36
+49421.5	35
+49432.5	35
+49443.4	35
+49454.4	36
+49465.4	35
+49476.3	36
+49487.3	35
+49498.3	36
+49509.2	35
+49520.2	35
+49531.2	35
+49542.1	36
+49553.1	35
+49564.1	36
+49575	36
+49586	35
+49597	36
+49607.9	36
+49618.9	36
+49629.9	36
+49640.9	35
+49651.8	36
+49662.8	35
+49673.8	36
+49684.7	36
+49695.7	35
+49706.7	35
+49717.6	36
+49728.6	35
+49739.6	33
+49750.5	35
+49761.5	36
+49772.5	34
+49783.4	35
+49794.4	35
+49805.4	35
+49816.3	35
+49827.3	36
+49838.3	36
+49849.2	36
+49860.2	35
+49871.2	35
+49882.1	36
+49893.1	36
+49904.1	35
+49915	35
+49926	30
+49937	34
+49948	32
+49958.9	35
+49969.9	36
+49980.9	31
+49991.8	35
+50002.8	31
+50013.8	32
+50024.7	35
+50035.7	36
+50046.7	36
+50057.6	35
+50068.6	36
+50079.6	35
+50090.5	36
+50101.5	35
+50112.5	35
+50123.4	36
+50134.4	35
+50145.4	36
+50156.3	35
+50167.3	35
+50178.3	35
+50189.2	34
+50200.2	35
+50211.2	36
+50222.2	32
+50233.1	35
+50244.1	36
+50255.1	36
+50266	35
+50277	36
+50288	36
+50298.9	35
+50309.9	36
+50320.9	35
+50331.8	36
+50342.8	35
+50353.8	36
+50364.7	36
+50375.7	35
+50386.7	35
+50397.6	37
+50408.6	38
+50419.6	38
+50430.5	37
+50441.5	37
+50452.5	38
+50463.4	37
+50474.4	37
+50485.4	37
+50496.3	37
+50507.3	38
+50518.3	37
+50529.3	37
+50540.2	37
+50551.2	38
+50562.2	38
+50573.1	40
+50584.1	39
+50595.1	35
+50606	34
+50617	29
+50628	33
+50638.9	39
+50649.9	39
+50660.9	39
+50671.8	38
+50682.8	40
+50693.8	39
+50704.7	39
+50715.7	39
+50726.7	39
+50737.6	39
+50748.6	40
+50759.6	39
+50770.5	39
+50781.5	39
+50792.5	39
+50803.5	40
+50814.4	40
+50825.4	39
+50836.4	40
+50847.3	40
+50858.3	40
+50869.3	39
+50880.2	39
+50891.2	40
+50902.2	40
+50913.1	40
+50924.1	37
+50935.1	40
+50946	39
+50957	39
+50968	40
+50978.9	40
+50989.9	39
+51000.9	39
+51011.8	39
+51022.8	39
+51033.8	40
+51044.7	39
+51055.7	39
+51066.7	39
+51077.7	39
+51088.6	40
+51099.6	40
+51110.6	37
+51121.5	38
+51132.5	40
+51143.5	38
+51154.4	31
+51165.4	37
+51176.4	40
+51187.3	40
+51198.3	39
+51209.3	40
+51220.2	37
+51231.2	40
+51242.2	39
+51253.1	40
+51264.1	40
+51275.1	39
+51286	39
+51297	39
+51308	40
+51318.9	40
+51329.9	39
+51340.9	39
+51351.8	39
+51362.8	39
+51373.8	39
+51384.8	39
+51395.7	40
+51406.7	39
+51417.7	40
+51428.6	40
+51439.6	40
+51450.6	40
+51461.5	39
+51472.5	38
+51483.5	37
+51494.4	37
+51505.4	39
+51516.4	39
+51527.3	40
+51538.3	40
+51549.3	40
+51560.2	40
+51571.2	40
+51582.2	39
+51593.1	40
+51604.1	40
+51615.1	40
+51626	39
+51637	40
+51648	40
+51659	39
+51669.9	40
+51680.9	38
+51691.9	39
+51702.8	40
+51713.8	40
+51724.8	40
+51735.7	39
+51746.7	39
+51757.7	40
+51768.6	40
+51779.6	39
+51790.6	40
+51801.5	40
+51812.5	39
+51823.5	35
+51834.4	40
+51845.4	39
+51856.4	39
+51867.3	40
+51878.3	39
+51889.3	39
+51900.2	40
+51911.2	39
+51922.2	39
+51933.1	40
+51944.1	39
+51955.1	39
+51966.1	40
+51977	39
+51988	40
+51999	40
+52009.9	40
+52020.9	40
+52031.9	39
+52042.8	38
+52053.8	39
+52064.8	39
+52075.7	40
+52086.7	40
+52097.7	39
+52108.6	40
+52119.6	39
+52130.6	40
+52141.5	40
+52152.5	40
+52163.5	39
+52174.4	39
+52185.4	39
+52196.4	40
+52207.3	39
+52218.3	40
+52229.3	39
+52240.3	40
+52251.2	39
+52262.2	40
+52273.2	40
+52284.1	39
+52295.1	40
+52306.1	40
+52317	39
+52328	39
+52339	39
+52349.9	40
+52360.9	39
+52371.9	40
+52382.8	35
+52393.8	36
+52404.8	38
+52415.7	39
+52426.7	39
+52437.7	40
+52448.6	40
+52459.6	40
+52470.6	35
+52481.5	39
+52492.5	40
+52503.5	39
+52514.4	40
+52525.4	39
+52536.4	39
+52547.4	40
+52558.3	40
+52569.3	39
+52580.3	39
+52591.2	40
+52602.2	39
+52613.2	34
+52624.1	39
+52635.1	40
+52646.1	39
+52657	39
+52668	39
+52679	40
+52689.9	39
+52700.9	39
+52711.9	39
+52722.8	39
+52733.8	40
+52744.8	39
+52755.7	39
+52766.7	40
+52777.7	40
+52788.6	39
+52799.6	40
+52810.6	39
+52821.6	40
+52832.5	40
+52843.5	39
+52854.5	40
+52865.4	40
+52876.4	40
+52887.4	40
+52898.3	39
+52909.3	33
+52920.3	30
+52931.2	28
+52942.2	39
+52953.2	40
+52964.1	39
+52975.1	40
+52986.1	39
+52997	40
+53008	38
+53019	38
+53029.9	39
+53040.9	40
+53051.9	40
+53062.8	40
+53073.8	39
+53084.8	39
+53095.7	40
+53106.7	39
+53117.7	39
+53128.7	39
+53139.6	39
+53150.6	39
+53161.6	39
+53172.5	39
+53183.5	40
+53194.5	40
+53205.4	40
+53216.4	39
+53227.4	39
+53238.3	33
+53249.3	40
+53260.3	40
+53271.2	40
+53282.2	39
+53293.2	39
+53304.1	39
+53315.1	40
+53326.1	40
+53337	39
+53348	39
+53359	33
+53369.9	39
+53380.9	39
+53391.9	40
+53402.9	39
+53413.8	40
+53424.8	40
+53435.8	40
+53446.7	40
+53457.7	39
+53468.7	39
+53479.6	40
+53490.6	39
+53501.6	40
+53512.5	38
+53523.5	40
+53534.5	40
+53545.4	40
+53556.4	39
+53567.4	39
+53578.3	40
+53589.3	39
+53600.3	39
+53611.2	39
+53622.2	40
+53633.2	37
+53644.1	39
+53655.1	38
+53666.1	39
+53677	40
+53688	33
+53699	40
+53710	39
+53720.9	40
+53731.9	39
+53742.9	39
+53753.8	39
+53764.8	38
+53775.8	40
+53786.7	39
+53797.7	39
+53808.7	40
+53819.6	39
+53830.6	33
+53841.6	39
+53852.5	39
+53863.5	39
+53874.5	39
+53885.4	40
+53896.4	40
+53907.4	39
+53918.3	40
+53929.3	40
+53940.3	40
+53951.2	38
+53962.2	38
+53973.2	39
+53984.2	40
+53995.1	39
+54006.1	39
+54017.1	40
+54028	39
+54039	39
+54050	39
+54060.9	37
+54071.9	40
+54082.9	40
+54093.8	39
+54104.8	40
+54115.8	39
+54126.7	40
+54137.7	40
+54148.7	40
+54159.6	38
+54170.6	39
+54181.6	39
+54192.5	40
+54203.5	40
+54214.5	39
+54225.4	39
+54236.4	40
+54247.4	39
+54258.3	40
+54269.3	39
+54280.3	39
+54291.3	39
+54302.2	40
+54313.2	39
+54324.2	39
+54335.1	39
+54346.1	39
+54357.1	39
+54368	32
+54379	39
+54390	40
+54400.9	40
+54411.9	38
+54422.9	39
+54433.8	36
+54444.8	40
+54455.8	40
+54466.7	39
+54477.7	40
+54488.7	40
+54499.6	39
+54510.6	39
+54521.6	40
+54532.5	40
+54543.5	40
+54554.5	39
+54565.5	36
+54576.4	26
+54587.4	40
+54598.4	40
+54609.3	40
+54620.3	40
+54631.3	40
+54642.2	39
+54653.2	39
+54664.2	40
+54675.1	38
+54686.1	39
+54697.1	39
+54708	38
+54719	40
+54730	39
+54740.9	39
+54751.9	39
+54762.9	39
+54773.8	39
+54784.8	39
+54795.8	39
+54806.7	39
+54817.7	40
+54828.7	39
+54839.7	39
+54850.6	40
+54861.6	40
+54872.6	39
+54883.5	40
+54894.5	40
+54905.5	40
+54916.4	39
+54927.4	39
+54938.4	40
+54949.3	40
+54960.3	40
+54971.3	39
+54982.2	40
+54993.2	40
+55004.2	40
+55015.1	39
+55026.1	39
+55037.1	40
+55048	40
+55059	39
+55070	39
+55080.9	40
+55091.9	39
+55102.9	39
+55113.8	38
+55124.8	38
+55135.8	38
+55146.8	38
+55157.7	39
+55168.7	40
+55179.7	39
+55190.6	39
+55201.6	40
+55212.6	39
+55223.5	36
+55234.5	39
+55245.5	39
+55256.4	39
+55267.4	40
+55278.4	39
+55289.3	39
+55300.3	39
+55311.3	38
+55322.2	40
+55333.2	39
+55344.2	38
+55355.1	39
+55366.1	40
+55377.1	40
+55388	40
+55399	40
+55410	39
+55421	39
+55431.9	39
+55442.9	40
+55453.9	39
+55464.8	40
+55475.8	40
+55486.8	39
+55497.7	40
+55508.7	39
+55519.7	40
+55530.6	39
+55541.6	39
+55552.6	40
+55563.5	40
+55574.5	39
+55585.5	34
+55596.4	40
+55607.4	38
+55618.4	40
+55629.3	39
+55640.3	39
+55651.3	39
+55662.2	40
+55673.2	40
+55684.2	39
+55695.1	39
+55706.1	39
+55717.1	36
+55728.1	33
+55739	31
+55750	39
+55761	39
+55771.9	40
+55782.9	39
+55793.9	39
+55804.8	39
+55815.8	40
+55826.8	40
+55837.7	39
+55848.7	40
+55859.7	40
+55870.6	40
+55881.6	39
+55892.6	40
+55903.5	38
+55914.5	39
+55925.5	38
+55936.4	40
+55947.4	39
+55958.4	39
+55969.3	39
+55980.3	39
+55991.3	40
+56002.3	40
+56013.2	40
+56024.2	36
+56035.2	40
+56046.1	39
+56057.1	40
+56068.1	39
+56079	40
+56090	39
+56101	40
+56111.9	39
+56122.9	40
+56133.9	40
+56144.8	39
+56155.8	38
+56166.8	36
+56177.7	38
+56188.7	40
+56199.7	39
+56210.6	38
+56221.6	40
+56232.6	40
+56243.5	39
+56254.5	40
+56265.5	38
+56276.4	39
+56287.4	39
+56298.4	39
+56309.4	39
+56320.3	40
+56331.3	40
+56342.3	39
+56353.2	39
+56364.2	40
+56375.2	40
+56386.1	39
+56397.1	40
+56408.1	39
+56419	40
+56430	40
+56441	39
+56451.9	39
+56462.9	39
+56473.9	39
+56484.8	38
+56495.8	39
+56506.8	40
+56517.7	40
+56528.7	39
+56539.7	39
+56550.6	40
+56561.6	39
+56572.6	39
+56583.6	40
+56594.5	39
+56605.5	39
+56616.5	36
+56627.4	28
+56638.4	32
+56649.4	29
+56660.3	35
+56671.3	35
+56682.3	35
+56693.2	32
+56704.2	35
+56715.2	30
+56726.1	39
+56737.1	40
+56748.1	40
+56759	39
+56770	39
+56781	33
+56791.9	38
+56802.9	40
+56813.9	39
+56824.8	40
+56835.8	40
+56846.8	39
+56857.7	40
+56868.7	39
+56879.7	40
+56890.7	39
+56901.6	40
+56912.6	40
+56923.6	40
+56934.5	39
+56945.5	39
+56956.5	40
+56967.4	39
+56978.4	39
+56989.4	39
+57000.3	40
+57011.3	40
+57022.3	39
+57033.2	39
+57044.2	39
+57055.2	40
+57066.1	39
+57077.1	39
+57088.1	36
+57099	40
+57110	40
+57121	40
+57131.9	39
+57142.9	40
+57153.9	40
+57164.9	40
+57175.8	40
+57186.8	39
+57197.8	38
+57208.7	40
+57219.7	39
+57230.7	40
+57241.6	35
+57252.6	31
+57263.6	39
+57274.5	40
+57285.5	40
+57296.5	38
+57307.4	39
+57318.4	39
+57329.4	39
+57340.3	39
+57351.3	39
+57362.3	40
+57373.2	40
+57384.2	39
+57395.2	40
+57406.1	40
+57417.1	39
+57428.1	39
+57439	40
+57450	40
+57461	39
+57472	39
+57482.9	38
+57493.9	38
+57504.9	39
+57515.8	40
+57526.8	40
+57537.8	36
+57548.7	36
+57559.7	40
+57570.7	40
+57581.6	39
+57592.6	39
+57603.6	32
+57614.5	39
+57625.5	39
+57636.5	40
+57647.4	39
+57658.4	40
+57669.4	40
+57680.3	37
+57691.3	40
+57702.3	40
+57713.2	39
+57724.2	39
+57735.2	40
+57746.2	40
+57757.1	39
+57768.1	39
+57779.1	39
+57790	40
+57801	39
+57812	40
+57822.9	40
+57833.9	39
+57844.9	39
+57855.8	40
+57866.8	40
+57877.8	36
+57888.7	40
+57899.7	40
+57910.7	39
+57921.6	40
+57932.6	39
+57943.6	40
+57954.5	40
+57965.5	40
+57976.5	39
+57987.4	39
+57998.4	39
+58009.4	39
+58020.3	40
+58031.3	40
+58042.3	40
+58053.3	40
+58064.2	38
+58075.2	31
+58086.2	39
+58097.1	39
+58108.1	39
+58119.1	39
+58130	40
+58141	39
+58152	39
+58162.9	40
+58173.9	39
+58184.9	39
+58195.8	40
+58206.8	40
+58217.8	40
+58228.7	35
+58239.7	38
+58250.7	39
+58261.6	39
+58272.6	39
+58283.6	39
+58294.5	40
+58305.5	39
+58316.5	40
+58327.5	39
+58338.4	40
+58349.4	39
+58360.4	39
+58371.3	40
+58382.3	40
+58393.3	40
+58404.2	39
+58415.2	40
+58426.2	39
+58437.1	40
+58448.1	39
+58459.1	39
+58470	40
+58481	40
+58492	40
+58502.9	40
+58513.9	40
+58524.9	39
+58535.8	39
+58546.8	39
+58557.8	40
+58568.7	39
+58579.7	39
+58590.7	40
+58601.6	39
+58612.6	40
+58623.6	39
+58634.6	39
+58645.5	40
+58656.5	40
+58667.5	40
+58678.4	39
+58689.4	32
+58700.4	35
+58711.3	37
+58722.3	40
+58733.3	40
+58744.2	40
+58755.2	39
+58766.2	40
+58777.1	40
+58788.1	40
+58799.1	39
+58810	39
+58821	39
+58832	40
+58842.9	40
+58853.9	39
+58864.9	40
+58875.8	40
+58886.8	40
+58897.8	40
+58908.8	39
+58919.7	40
+58930.7	39
+58941.7	40
+58952.6	38
+58963.6	39
+58974.6	40
+58985.5	39
+58996.5	40
+59007.5	39
+59018.4	38
+59029.4	30
+59040.4	37
+59051.3	38
+59062.3	39
+59073.3	40
+59084.2	39
+59095.2	40
+59106.2	39
+59117.1	38
+59128.1	39
+59139.1	40
+59150	39
+59161	40
+59172	40
+59183	39
+59193.9	39
+59204.9	39
+59215.9	39
+59226.8	39
+59237.8	40
+59248.8	39
+59259.7	39
+59270.7	39
+59281.7	40
+59292.6	39
+59303.6	39
+59314.6	40
+59325.5	40
+59336.5	40
+59347.5	39
+59358.4	40
+59369.4	39
+59380.4	40
+59391.3	40
+59402.3	39
+59413.3	35
+59424.2	28
+59435.2	40
+59446.2	39
+59457.1	39
+59468.1	40
+59479.1	39
+59490.1	39
+59501	39
+59512	39
+59523	39
+59533.9	40
+59544.9	39
+59555.9	36
+59566.8	32
+59577.8	38
+59588.8	39
+59599.7	40
+59610.7	40
+59621.7	39
+59632.6	39
+59643.6	40
+59654.6	40
+59665.5	40
+59676.5	38
+59687.5	33
+59698.4	34
+59709.4	36
+59720.4	35
+59731.3	39
+59742.3	39
+59753.3	39
+59764.3	39
+59775.2	40
+59786.2	40
+59797.2	39
+59808.1	38
+59819.1	40
+59830.1	40
+59841	39
+59852	39
+59863	40
+59873.9	40
+59884.9	39
+59895.9	40
+59906.8	39
+59917.8	40
+59928.8	39
+59939.7	39
+59950.7	39
+59961.7	40
+59972.6	40
+59983.6	39
+59994.6	39
+60005.5	39
+60016.5	39
+60027.5	39
+60038.4	40
+60049.4	39
+60060.4	40
+60071.4	40
+60082.3	40
+60093.3	40
+60104.3	40
+60115.2	39
+60126.2	40
+60137.2	39
+60148.1	38
+60159.1	36
+60170.1	39
+60181	38
+60192	40
+60203	40
+60213.9	40
+60224.9	39
+60235.9	35
+60246.8	40
+60257.8	39
+60268.8	40
+60279.7	38
+60290.7	32
+60301.7	39
+60312.6	39
+60323.6	39
+60334.6	40
+60345.6	39
+60356.5	39
+60367.5	39
+60378.5	40
+60389.4	40
+60400.4	40
+60411.4	40
+60422.3	40
+60433.3	40
+60444.3	40
+60455.2	39
+60466.2	40
+60477.2	40
+60488.1	39
+60499.1	40
+60510.1	39
+60521	40
+60532	39
+60543	40
+60553.9	39
+60564.9	40
+60575.9	39
+60586.8	39
+60597.8	39
+60608.8	38
+60619.7	39
+60630.7	38
+60641.7	39
+60652.7	40
+60663.6	40
+60674.6	39
+60685.6	40
+60696.5	39
+60707.5	40
+60718.5	39
+60729.4	39
+60740.4	40
+60751.4	40
+60762.3	40
+60773.3	40
+60784.3	39
+60795.2	40
+60806.2	40
+60817.2	39
+60828.1	40
+60839.1	39
+60850.1	39
+60861	40
+60872	40
+60883	39
+60893.9	39
+60904.9	40
+60915.9	40
+60926.9	39
+60937.8	39
+60948.8	39
+60959.8	40
+60970.7	40
+60981.7	39
+60992.7	39
+61003.6	39
+61014.6	39
+61025.6	40
+61036.5	38
+61047.5	39
+61058.5	38
+61069.4	40
+61080.4	40
+61091.4	39
+61102.3	38
+61113.3	35
+61124.3	39
+61135.2	39
+61146.2	40
+61157.2	39
+61168.1	39
+61179.1	40
+61190.1	39
+61201	39
+61212	39
+61223	40
+61234	40
+61244.9	39
+61255.9	40
+61266.9	39
+61277.8	40
+61288.8	33
+61299.8	39
+61310.7	40
+61321.7	39
+61332.7	39
+61343.6	39
+61354.6	40
+61365.6	40
+61376.5	39
+61387.5	33
+61398.5	28
+61409.4	39
+61420.4	39
+61431.4	39
+61442.3	40
+61453.3	39
+61464.3	39
+61475.2	39
+61486.2	39
+61497.2	40
+61508.2	39
+61519.1	40
+61530.1	40
+61541.1	39
+61552	40
+61563	39
+61574	40
+61584.9	38
+61595.9	39
+61606.9	39
+61617.8	39
+61628.8	38
+61639.8	39
+61650.7	40
+61661.7	38
+61672.7	39
+61683.6	40
+61694.6	40
+61705.6	39
+61716.5	39
+61727.5	39
+61738.5	39
+61749.4	40
+61760.4	39
+61771.4	39
+61782.3	39
+61793.3	39
+61804.3	40
+61815.3	37
+61826.2	39
+61837.2	40
+61848.2	39
+61859.1	39
+61870.1	40
+61881.1	39
+61892	40
+61903	40
+61914	40
+61924.9	39
+61935.9	40
+61946.9	40
+61957.8	40
+61968.8	39
+61979.8	40
+61990.7	39
+62001.7	40
+62012.7	40
+62023.6	40
+62034.6	40
+62045.6	38
+62056.5	40
+62067.5	40
+62078.5	40
+62089.5	38
+62100.4	39
+62111.4	39
+62122.4	40
+62133.3	40
+62144.3	40
+62155.3	39
+62166.2	40
+62177.2	40
+62188.2	39
+62199.1	39
+62210.1	39
+62221.1	39
+62232	40
+62243	40
+62254	40
+62264.9	39
+62275.9	40
+62286.9	39
+62297.8	40
+62308.8	40
+62319.8	40
+62330.7	40
+62341.7	39
+62352.7	39
+62363.6	39
+62374.6	39
+62385.6	40
+62396.6	40
+62407.5	39
+62418.5	39
+62429.5	39
+62440.4	39
+62451.4	40
+62462.4	40
+62473.3	39
+62484.3	40
+62495.3	39
+62506.2	40
+62517.2	39
+62528.2	39
+62539.1	40
+62550.1	39
+62561.1	40
+62572	40
+62583	38
+62594	39
+62604.9	39
+62615.9	40
+62626.9	39
+62637.8	39
+62648.8	40
+62659.8	39
+62670.8	39
+62681.7	40
+62692.7	40
+62703.7	40
+62714.6	39
+62725.6	40
+62736.6	40
+62747.5	39
+62758.5	39
+62769.5	39
+62780.4	39
+62791.4	40
+62802.4	39
+62813.3	40
+62824.3	39
+62835.3	39
+62846.2	39
+62857.2	39
+62868.2	39
+62879.1	39
+62890.1	40
+62901.1	40
+62912	39
+62923	39
+62934	39
+62945	40
+62955.9	40
+62966.9	40
+62977.9	39
+62988.8	38
+62999.8	38
+63010.8	39
+63021.7	39
+63032.7	40
+63043.7	39
+63054.6	40
+63065.6	40
+63076.6	39
+63087.5	40
+63098.5	39
+63109.5	39
+63120.4	39
+63131.4	39
+63142.4	39
+63153.3	39
+63164.3	39
+63175.3	39
+63186.2	39
+63197.2	40
+63208.2	40
+63219.1	40
+63230.1	39
+63241.1	39
+63252.1	40
+63263	40
+63274	40
+63285	39
+63295.9	39
+63306.9	40
+63317.9	39
+63328.8	39
+63339.8	39
+63350.8	39
+63361.7	39
+63372.7	40
+63383.7	39
+63394.6	40
+63405.6	40
+63416.6	40
+63427.5	40
+63438.5	39
+63449.5	39
+63460.4	39
+63471.4	38
+63482.4	39
+63493.3	40
+63504.3	39
+63515.3	39
+63526.3	39
+63537.2	39
+63548.2	40
+63559.2	38
+63570.1	40
+63581.1	40
+63592.1	39
+63603	39
+63614	40
+63625	39
+63635.9	39
+63646.9	40
+63657.9	40
+63668.8	39
+63679.8	39
+63690.8	40
+63701.7	39
+63712.7	40
+63723.7	39
+63734.6	39
+63745.6	40
+63756.6	33
+63767.5	24
+63778.5	39
+63789.5	40
+63800.4	40
+63811.4	39
+63822.4	40
+63833.4	39
+63844.3	39
+63855.3	39
+63866.3	39
+63877.2	40
+63888.2	39
+63899.2	38
+63910.1	39
+63921.1	39
+63932.1	39
+63943	40
+63954	39
+63965	39
+63975.9	39
+63986.9	40
+63997.9	39
+64008.8	39
+64019.8	39
+64030.8	39
+64041.7	37
+64052.7	39
+64063.7	39
+64074.6	39
+64085.6	38
+64096.6	40
+64107.6	39
+64118.5	40
+64129.5	39
+64140.5	39
+64151.4	39
+64162.4	39
+64173.4	40
+64184.3	39
+64195.3	39
+64206.3	40
+64217.2	40
+64228.2	38
+64239.2	40
+64250.1	39
+64261.1	39
+64272.1	39
+64283	39
+64294	39
+64305	39
+64315.9	39
+64326.9	38
+64337.9	39
+64348.8	40
+64359.8	40
+64370.8	38
+64381.7	39
+64392.7	40
+64403.7	39
+64414.7	39
+64425.6	39
+64436.6	39
+64447.6	39
+64458.5	40
+64469.5	39
+64480.5	37
+64491.4	39
+64502.4	39
+64513.4	40
+64524.3	40
+64535.3	39
+64546.3	39
+64557.2	39
+64568.2	40
+64579.2	40
+64590.1	40
+64601.1	39
+64612.1	39
+64623	39
+64634	39
+64645	39
+64655.9	39
+64666.9	40
+64677.9	40
+64688.9	38
+64699.8	40
+64710.8	40
+64721.8	39
+64732.7	38
+64743.7	39
+64754.7	40
+64765.6	39
+64776.6	39
+64787.6	40
+64798.5	40
+64809.5	39
+64820.5	39
+64831.4	39
+64842.4	39
+64853.4	40
+64864.3	40
+64875.3	39
+64886.3	39
+64897.2	40
+64908.2	36
+64919.2	40
+64930.1	40
+64941.1	40
+64952.1	39
+64963	39
+64974	40
+64985	39
+64996	40
+65006.9	38
+65017.9	40
+65028.9	40
+65039.8	40
+65050.8	39
+65061.8	40
+65072.7	40
+65083.7	40
+65094.7	40
+65105.6	39
+65116.6	39
+65127.6	39
+65138.5	39
+65149.5	39
+65160.5	39
+65171.4	40
+65182.4	39
+65193.4	39
+65204.3	40
+65215.3	38
+65226.3	38
+65237.2	40
+65248.2	39
+65259.2	39
+65270.2	40
+65281.1	40
+65292.1	39
+65303.1	38
+65314	39
+65325	40
+65336	40
+65346.9	39
+65357.9	39
+65368.9	40
+65379.8	40
+65390.8	40
+65401.8	40
+65412.7	40
+65423.7	39
+65434.7	39
+65445.6	39
+65456.6	37
+65467.6	39
+65478.5	40
+65489.5	39
+65500.5	39
+65511.4	39
+65522.4	39
+65533.4	39
+65544.3	40
+65555.3	39
+65566.3	39
+65577.3	39
+65588.2	40
+65599.2	40
+65610.2	39
+65621.1	31
+65632.1	40
+65643.1	39
+65654	39
+65665	39
+65676	38
+65686.9	40
+65697.9	40
+65708.9	40
+65719.8	40
+65730.8	39
+65741.8	40
+65752.7	40
+65763.7	40
+65774.7	39
+65785.6	40
+65796.6	40
+65807.6	40
+65818.5	40
+65829.5	40
+65840.5	39
+65851.5	38
+65862.4	40
+65873.4	39
+65884.4	40
+65895.3	38
+65906.3	39
+65917.3	39
+65928.2	40
+65939.2	39
+65950.2	39
+65961.1	38
+65972.1	40
+65983.1	39
+65994	40
+66005	39
+66016	40
+66026.9	39
+66037.9	37
+66048.9	39
+66059.8	40
+66070.8	39
+66081.8	39
+66092.7	39
+66103.7	39
+66114.7	39
+66125.6	36
+66136.6	39
+66147.6	39
+66158.6	40
+66169.5	40
+66180.5	39
+66191.5	39
+66202.4	38
+66213.4	40
+66224.4	38
+66235.3	38
+66246.3	40
+66257.3	40
+66268.2	39
+66279.2	39
+66290.2	40
+66301.1	40
+66312.1	39
+66323.1	40
+66334	39
+66345	40
+66356	40
+66366.9	40
+66377.9	40
+66388.9	39
+66399.8	39
+66410.8	39
+66421.8	40
+66432.8	40
+66443.7	39
+66454.7	40
+66465.7	38
+66476.6	39
+66487.6	39
+66498.6	40
+66509.5	39
+66520.5	36
+66531.5	39
+66542.4	39
+66553.4	39
+66564.4	39
+66575.3	40
+66586.3	40
+66597.3	35
+66608.2	39
+66619.2	40
+66630.2	39
+66641.1	39
+66652.1	38
+66663.1	39
+66674	31
+66685	39
+66696	39
+66707	39
+66717.9	39
+66728.9	39
+66739.9	35
+66750.8	36
+66761.8	39
+66772.8	39
+66783.7	40
+66794.7	32
+66805.7	37
+66816.6	39
+66827.6	36
+66838.6	32
+66849.5	39
+66860.5	38
+66871.5	36
+66882.4	36
+66893.4	35
+66904.4	36
+66915.3	39
+66926.3	31
+66937.3	36
+66948.2	34
+66959.2	29
+66970.2	31
+66981.1	32
+66992.1	31
+67003.1	30
+67014.1	35
+67025	29
+67036	30
+67047	25
+67057.9	29
+67068.9	25
+67079.9	27
+67090.8	25
+67101.8	24
+67112.8	20
+67123.7	24
+67134.7	20
+67145.7	20
+67156.6	24
+67167.6	20
+67178.6	25
+67189.5	20
+67200.5	24
+67211.5	20
+67222.4	24
+67233.4	20
+67244.4	24
+67255.3	20
+67266.3	24
+67277.3	20
+67288.3	24
+67299.2	20
+67310.2	24
+67321.2	20
+67332.1	24
+67343.1	20
+67354.1	24
+67365	20
+67376	24
+67387	20
+67397.9	24
+67408.9	21
+67419.9	20
+67430.8	20
+67441.8	20
+67452.8	20
+67463.7	20
+67474.7	20
+67485.7	20
+67496.6	20
+67507.6	20
+67518.6	20
+67529.5	20
+67540.5	19
+67551.5	19
+67562.4	18
+67573.4	18
+67584.4	18
+67595.4	18
+67606.3	17
+67617.3	16
+67628.3	16
+67639.2	15
+67650.2	17
+67661.2	17
+67672.1	16
+67683.1	15
+67694.1	18
+67705	19
+67716	20
+67727	20
+67737.9	20
+67748.9	20
+67759.9	20
+67770.8	20
+67781.8	20
+67792.8	19
+67803.7	18
+67814.7	18
+67825.7	17
+67836.6	16
+67847.6	16
+67858.6	15
+67869.6	18
+67880.5	19
+67891.5	20
+67902.5	19
+67913.4	17
+67924.4	17
+67935.4	16
+67946.3	15
+67957.3	17
+67968.3	16
+67979.2	16
+67990.2	17
+68001.2	16
+68012.1	15
+68023.1	18
+68034.1	19
+68045	19
+68056	17
+68067	16
+68077.9	15
+68088.9	17
+68099.9	17
+68110.8	16
+68121.8	15
+68132.8	17
+68143.7	16
+68154.7	15
+68165.7	17
+68176.7	17
+68187.6	16
+68198.6	15
+68209.6	17
+68220.5	16
+68231.5	15
+68242.5	17
+68253.4	16
+68264.4	15
+68275.4	17
+68286.3	15
+68297.3	15
+68308.3	15
+68319.2	15
+68330.2	15
+68341.2	16
+68352.1	16
+68363.1	15
+68374.1	16
+68385	16
+68396	15
+68407	15
+68417.9	17
+68428.9	16
+68439.9	16
+68450.9	15
+68461.8	15
+68472.8	17
+68483.8	18
+68494.7	19
+68505.7	19
+68516.7	19
+68527.6	19
+68538.6	19
+68549.6	19
+68560.5	19
+68571.5	19
+68582.5	19
+68593.4	19
+68604.4	19
+68615.4	19
+68626.3	19
+68637.3	19
+68648.3	19
+68659.2	19
+68670.2	19
+68681.2	19
+68692.1	19
+68703.1	19
+68714.1	19
+68725	19
+68736	19
+68747	19
+68758	19
+68768.9	19
+68779.9	19
+68790.9	19
+68801.8	19
+68812.8	19
+68823.8	19
+68834.7	19
+68845.7	19
+68856.7	19
+68867.6	19
+68878.6	19
+68889.6	19
+68900.5	19
+68911.5	19
+68922.5	19
+68933.4	19
+68944.4	19
+68955.4	19
+68966.3	19
+68977.3	19
+68988.3	19
+68999.2	19
+69010.2	19
+69021.2	19
+69032.2	19
+69043.1	19
+69054.1	19
+69065.1	19
+69076	19
+69087	19
+69098	19
+69108.9	19
+69119.9	19
+69130.9	19
+69141.8	19
+69152.8	19
+69163.8	19
+69174.7	19
+69185.7	19
+69196.7	19
+69207.6	19
+69218.6	19
+69229.6	19
+69240.5	19
+69251.5	19
+69262.5	19
+69273.4	19
+69284.4	19
+69295.4	19
+69306.3	19
+69317.3	19
+69328.3	19
+69339.3	19
+69350.2	19
+69361.2	19
+69372.2	19
+69383.1	19
+69394.1	19
+69405.1	19
+69416	19
+69427	19
+69438	19
+69448.9	19
+69459.9	19
+69470.9	19
+69481.8	19
+69492.8	19
+69503.8	19
+69514.7	19
+69525.7	19
+69536.7	19
+69547.6	19
+69558.6	19
+69569.6	19
+69580.5	19
+69591.5	19
+69602.5	19
+69613.5	19
+69624.4	19
+69635.4	19
+69646.4	19
+69657.3	19
+69668.3	19
+69679.3	19
+69690.2	19
+69701.2	19
+69712.2	19
+69723.1	19
+69734.1	19
+69745.1	19
+69756	19
+69767	19
+69778	19
+69788.9	19
+69799.9	19
+69810.9	19
+69821.8	19
+69832.8	19
+69843.8	19
+69854.7	19
+69865.7	19
+69876.7	19
+69887.6	19
+69898.6	19
+69909.6	19
+69920.6	19
+69931.5	19
+69942.5	19
+69953.5	19
+69964.4	19
+69975.4	19
+69986.4	19
+69997.3	19
+70008.3	19
+70019.3	19
+70030.2	19
+70041.2	19
+70052.2	19
+70063.1	19
+70074.1	19
+70085.1	19
+70096	19
+70107	19
+70118	19
+70128.9	19
+70139.9	19
+70150.9	19
+70161.8	19
+70172.8	19
+70183.8	19
+70194.8	19
+70205.7	19
+70216.7	19
+70227.7	19
+70238.6	19
+70249.6	19
+70260.6	19
+70271.5	19
+70282.5	19
+70293.5	19
+70304.4	19
+70315.4	19
+70326.4	19
+70337.3	19
+70348.3	19
+70359.3	19
+70370.2	19
+70381.2	18
+70392.2	12
+70403.1	4
+70414.1	5
+70425.1	11
+70436	17
+70447	20
+70458	20
+70469	20
+70479.9	20
+70490.9	20
+70501.9	20
+70512.8	20
+70523.8	20
+70534.8	20
+70545.7	20
+70556.7	20
+70567.7	20
+70578.6	20
+70589.6	20
+70600.6	20
+70611.5	20
+70622.5	20
+70633.5	20
+70644.4	20
+70655.4	20
+70666.4	20
+70677.3	20
+70688.3	20
+70699.3	20
+70710.2	20
+70721.2	20
+70732.2	20
+70743.1	20
+70754.1	20
+70765.1	20
+70776.1	20
+70787	20
+70798	20
+70809	20
+70819.9	20
+70830.9	20
+70841.9	20
+70852.8	20
+70863.8	20
+70874.8	20
+70885.7	20
+70896.7	20
+70907.7	20
+70918.6	20
+70929.6	20
+70940.6	20
+70951.5	20
+70962.5	20
+70973.5	20
+70984.4	20
+70995.4	20
+71006.4	20
+71017.3	20
+71028.3	20
+71039.3	20
+71050.3	20
+71061.2	20
+71072.2	20
+71083.2	20
+71094.1	20
+71105.1	20
+71116.1	20
+71127	20
+71138	20
+71149	20
+71159.9	20
+71170.9	20
+71181.9	20
+71192.8	20
+71203.8	20
+71214.8	20
+71225.7	20
+71236.7	20
+71247.7	20
+71258.6	20
+71269.6	20
+71280.6	20
+71291.5	20
+71302.5	20
+71313.5	20
+71324.4	20
+71335.4	20
+71346.4	20
+71357.4	20
+71368.3	20
+71379.3	20
+71390.3	20
+71401.2	20
+71412.2	20
+71423.2	20
+71434.1	20
+71445.1	20
+71456.1	20
+71467	20
+71478	20
+71489	20
+71499.9	20
+71510.9	20
+71521.9	20
+71532.8	20
+71543.8	20
+71554.8	20
+71565.7	20
+71576.7	20
+71587.7	20
+71598.6	20
+71609.6	20
+71620.6	20
+71631.6	20
+71642.5	20
+71653.5	20
+71664.5	20
+71675.4	20
+71686.4	20
+71697.4	20
+71708.3	20
+71719.3	20
+71730.3	20
+71741.2	20
+71752.2	20
+71763.2	20
+71774.1	20
+71785.1	20
+71796.1	20
+71807	20
+71818	20
+71829	20
+71839.9	20
+71850.9	20
+71861.9	20
+71872.8	20
+71883.8	20
+71894.8	20
+71905.7	20
+71916.7	20
+71927.7	20
+71938.7	20
+71949.6	20
+71960.6	20
+71971.6	20
+71982.5	20
+71993.5	20
+72004.5	20
+72015.4	20
+72026.4	20
+72037.4	20
+72048.3	20
+72059.3	20
+72070.3	20
+72081.2	20
+72092.2	20
+72103.2	20
+72114.1	20
+72125.1	20
+72136.1	20
+72147	20
+72158	18
+72169	18
+72179.9	18
+72190.9	17
+72201.9	16
+72212.9	17
+72223.8	20
+72234.8	20
+72245.8	20
+72256.7	20
+72267.7	20
+72278.7	20
+72289.6	20
+72300.6	20
+72311.6	20
+72322.5	20
+72333.5	20
+72344.5	20
+72355.4	20
+72366.4	20
+72377.4	20
+72388.3	20
+72399.3	20
+72410.3	20
+72421.2	20
+72432.2	20
+72443.2	20
+72454.1	20
+72465.1	20
+72476.1	20
+72487	20
+72498	20
+72509	20
+72520	20
+72530.9	20
+72541.9	20
+72552.9	20
+72563.8	20
+72574.8	20
+72585.8	20
+72596.7	20
+72607.7	20
+72618.7	20
+72629.6	20
+72640.6	20
+72651.6	20
+72662.5	20
+72673.5	20
+72684.5	20
+72695.4	20
+72706.4	20
+72717.4	20
+72728.3	20
+72739.3	20
+72750.3	20
+72761.2	20
+72772.2	20
+72783.2	20
+72794.2	20
+72805.1	20
+72816.1	20
+72827.1	20
+72838	20
+72849	20
+72860	20
+72870.9	20
+72881.9	20
+72892.9	20
+72903.8	20
+72914.8	20
+72925.8	20
+72936.7	20
+72947.7	20
+72958.7	20
+72969.6	20
+72980.6	20
+72991.6	20
+73002.5	20
+73013.5	20
+73024.5	20
+73035.4	20
+73046.4	20
+73057.4	20
+73068.3	20
+73079.3	20
+73090.3	20
+73101.3	20
+73112.2	20
+73123.2	20
+73134.2	20
+73145.1	20
+73156.1	20
+73167.1	20
+73178	20
+73189	20
+73200	20
+73210.9	20
+73221.9	20
+73232.9	20
+73243.8	20
+73254.8	20
+73265.8	20
+73276.7	20
+73287.7	20
+73298.7	20
+73309.6	20
+73320.6	20
+73331.6	20
+73342.5	20
+73353.5	20
+73364.5	20
+73375.5	20
+73386.4	20
+73397.4	20
+73408.4	20
+73419.3	20
+73430.3	20
+73441.3	20
+73452.2	20
+73463.2	20
+73474.2	20
+73485.1	20
+73496.1	20
+73507.1	20
+73518	20
+73529	20
+73540	20
+73550.9	20
+73561.9	20
+73572.9	20
+73583.8	20
+73594.8	20
+73605.8	20
+73616.7	20
+73627.7	20
+73638.7	20
+73649.6	20
+73660.6	20
+73671.6	20
+73682.6	20
+73693.5	20
+73704.5	20
+73715.5	20
+73726.4	20
+73737.4	20
+73748.4	20
+73759.3	20
+73770.3	20
+73781.3	20
+73792.2	20
+73803.2	20
+73814.2	20
+73825.1	20
+73836.1	20
+73847.1	20
+73858	20
+73869	20
+73880	20
+73890.9	20
+73901.9	20
+73912.9	20
+73923.8	20
+73934.8	20
+73945.8	20
+73956.8	20
+73967.7	20
+73978.7	20
+73989.7	20
+74000.6	20
+74011.6	20
+74022.6	20
+74033.5	20
+74044.5	20
+74055.5	20
+74066.4	20
+74077.4	20
+74088.4	20
+74099.3	20
+74110.3	20
+74121.3	4
+74132.2	5
+74143.2	7
+74154.2	7
+74165.1	7
+74176.1	7
+74187.1	7
+74198	7
+74209	7
+74220	7
+74231	7
+74241.9	7
+74252.9	7
+74263.9	7
+74274.8	7
+74285.8	7
+74296.8	7
+74307.7	7
+74318.7	7
+74329.7	7
+74340.6	7
+74351.6	7
+74362.6	7
+74373.5	7
+74384.5	7
+74395.5	7
+74406.4	7
+74417.4	7
+74428.4	7
+74439.3	7
+74450.3	7
+74461.3	7
+74472.2	7
+74483.2	7
+74494.2	7
+74505.1	7
+74516.1	7
+74527.1	7
+74538.1	7
+74549	7
+74560	7
+74571	7
+74581.9	7
+74592.9	7
+74603.9	7
+74614.8	7
+74625.8	7
+74636.8	7
+74647.7	7
+74658.7	7
+74669.7	7
+74680.6	7
+74691.6	7
+74702.6	7
+74713.5	7
+74724.5	7
+74735.5	7
+74746.4	7
+74757.4	7
+74768.4	7
+74779.3	7
+74790.3	7
+74801.3	7
+74812.3	7
+74823.2	7
+74834.2	7
+74845.2	7
+74856.1	7
+74867.1	7
+74878.1	7
+74889	7
+74900	7
+74911	7
+74921.9	7
+74932.9	7
+74943.9	7
+74954.8	7
+74965.8	7
+74976.8	7
+74987.7	7
+74998.7	7
+75009.7	7
+75020.6	7
+75031.6	7
+75042.6	7
+75053.5	7
+75064.5	7
+75075.5	7
+75086.4	7
+75097.4	7
+75108.4	7
+75119.4	7
+75130.3	7
+75141.3	7
+75152.3	7
+75163.2	7
+75174.2	7
+75185.2	7
+75196.1	7
+75207.1	7
+75218.1	7
+75229	7
+75240	7
+75251	7
+75261.9	7
+75272.9	7
+75283.9	7
+75294.8	7
+75305.8	7
+75316.8	7
+75327.7	7
+75338.7	7
+75349.7	7
+75360.6	7
+75371.6	7
+75382.6	7
+75393.6	7
+75404.5	7
+75415.5	7
+75426.5	7
+75437.4	7
+75448.4	7
+75459.4	7
+75470.3	7
+75481.3	7
+75492.3	7
+75503.2	7
+75514.2	7
+75525.2	7
+75536.1	7
+75547.1	7
+75558.1	7
+75569	7
+75580	7
+75591	7
+75601.9	7
+75612.9	7
+75623.9	7
+75634.8	7
+75645.8	7
+75656.8	7
+75667.7	7
+75678.7	7
+75689.7	7
+75700.7	7
+75711.6	7
+75722.6	7
+75733.6	7
+75744.5	7
+75755.5	7
+75766.5	7
+75777.4	7
+75788.4	7
+75799.4	7
+75810.3	7
+75821.3	7
+75832.3	7
+75843.2	7
+75854.2	7
+75865.2	7
+75876.1	3
+75887.1	4
+75898.1	6
+75909	7
+75920	7
+75931	7
+75941.9	7
+75952.9	7
+75963.9	7
+75974.9	7
+75985.8	7
+75996.8	7
+76007.8	7
+76018.7	7
+76029.7	7
+76040.7	7
+76051.6	7
+76062.6	7
+76073.6	7
+76084.5	7
+76095.5	7
+76106.5	7
+76117.4	7
+76128.4	7
+76139.4	7
+76150.3	7
+76161.3	7
+76172.3	7
+76183.2	7
+76194.2	7
+76205.2	7
+76216.1	7
+76227.1	7
+76238.1	7
+76249	7
+76260	7
+76271	7
+76282	7
+76292.9	7
+76303.9	7
+76314.9	7
+76325.8	7
+76336.8	7
+76347.8	7
+76358.7	7
+76369.7	7
+76380.7	7
+76391.6	7
+76402.6	7
+76413.6	7
+76424.5	7
+76435.5	7
+76446.5	7
+76457.4	7
+76468.4	7
+76479.4	7
+76490.3	7
+76501.3	7
+76512.3	7
+76523.2	7
+76534.2	7
+76545.2	7
+76556.2	7
+76567.1	7
+76578.1	7
+76589.1	7
+76600	7
+76611	7
+76622	7
+76632.9	7
+76643.9	7
+76654.9	7
+76665.8	7
+76676.8	7
+76687.8	7
+76698.7	7
+76709.7	7
+76720.7	7
+76731.6	7
+76742.6	7
+76753.6	7
+76764.5	7
+76775.5	7
+76786.5	7
+76797.4	7
+76808.4	7
+76819.4	7
+76830.3	7
+76841.3	7
+76852.3	7
+76863.3	7
+76874.2	7
+76885.2	7
+76896.2	7
+76907.1	7
+76918.1	7
+76929.1	7
+76940	7
+76951	7
+76962	7
+76972.9	7
+76983.9	7
+76994.9	7
+77005.8	7
+77016.8	7
+77027.8	7
+77038.7	7
+77049.7	7
+77060.7	7
+77071.6	7
+77082.6	7
+77093.6	7
+77104.5	7
+77115.5	7
+77126.5	7
+77137.5	7
+77148.4	7
+77159.4	7
+77170.4	7
+77181.3	7
+77192.3	7
+77203.3	7
+77214.2	7
+77225.2	7
+77236.2	7
+77247.1	7
+77258.1	7
+77269.1	7
+77280	7
+77291	7
+77302	7
+77312.9	7
+77323.9	7
+77334.9	7
+77345.8	7
+77356.8	7
+77367.8	7
+77378.7	7
+77389.7	7
+77400.7	7
+77411.6	7
+77422.6	7
+77433.6	7
+77444.6	7
+77455.5	7
+77466.5	7
+77477.5	7
+77488.4	7
+77499.4	7
+77510.4	7
+77521.3	7
+77532.3	7
+77543.3	7
+77554.2	7
+77565.2	7
+77576.2	7
+77587.1	7
+77598.1	7
+77609.1	7
+77620	7
+77631	7
+77642	7
+77652.9	7
+77663.9	7
+77674.9	7
+77685.8	7
+77696.8	7
+77707.8	7
+77718.8	7
+77729.7	7
+77740.7	7
+77751.7	7
+77762.6	7
+77773.6	7
+77784.6	7
+77795.5	7
+77806.5	4
+77817.5	4
+77828.4	5
+77839.4	5
+77850.4	5
+77861.3	5
+77872.3	5
+77883.3	5
+77894.2	5
+77905.2	5
+77916.2	5
+77927.1	5
+77938.1	5
+77949.1	5
+77960	5
+77971	5
+77982	5
+77993	5
+78003.9	5
+78014.9	5
+78025.9	5
+78036.8	5
+78047.8	5
+78058.8	5
+78069.7	5
+78080.7	5
+78091.7	5
+78102.6	5
+78113.6	5
+78124.6	5
+78135.5	5
+78146.5	5
+78157.5	5
+78168.4	5
+78179.4	5
+78190.4	5
+78201.3	5
+78212.3	5
+78223.3	5
+78234.2	5
+78245.2	5
+78256.2	5
+78267.1	5
+78278.1	5
+78289.1	5
+78300.1	5
+78311	5
+78322	5
+78333	5
+78343.9	5
+78354.9	5
+78365.9	5
+78376.8	5
+78387.8	5
+78398.8	5
+78409.7	5
+78420.7	5
+78431.7	5
+78442.6	5
+78453.6	5
+78464.6	5
+78475.5	5
+78486.5	5
+78497.5	5
+78508.4	5
+78519.4	5
+78530.4	5
+78541.3	5
+78552.3	5
+78563.3	5
+78574.3	5
+78585.2	5
+78596.2	5
+78607.2	5
+78618.1	5
+78629.1	5
+78640.1	5
+78651	5
+78662	5
+78673	5
+78683.9	5
+78694.9	5
+78705.9	5
+78716.8	5
+78727.8	5
+78738.8	5
+78749.7	5
+78760.7	5
+78771.7	5
+78782.6	5
+78793.6	5
+78804.6	5
+78815.5	5
+78826.5	5
+78837.5	5
+78848.4	5
+78859.4	5
+78870.4	5
+78881.4	5
+78892.3	5
+78903.3	5
+78914.3	5
+78925.2	5
+78936.2	5
+78947.2	5
+78958.1	5
+78969.1	5
+78980.1	5
+78991	5
+79002	5
+79013	5
+79023.9	5
+79034.9	5
+79045.9	5
+79056.8	5
+79067.8	5
+79078.8	5
+79089.7	5
+79100.7	5
+79111.7	5
+79122.6	5
+79133.6	5
+79144.6	5
+79155.6	5
+79166.5	5
+79177.5	5
+79188.5	5
+79199.4	5
+79210.4	5
+79221.4	5
+79232.3	5
+79243.3	5
+79254.3	5
+79265.2	5
+79276.2	5
+79287.2	5
+79298.1	5
+79309.1	5
+79320.1	5
+79331	5
+79342	5
+79353	5
+79363.9	5
+79374.9	5
+79385.9	5
+79396.8	5
+79407.8	5
+79418.8	5
+79429.7	5
+79440.7	5
+79451.7	5
+79462.7	5
+79473.6	5
+79484.6	5
+79495.6	5
+79506.5	5
+79517.5	5
+79528.5	5
+79539.4	5
+79550.4	5
+79561.4	5
+79572.3	3
+79583.3	2
+79594.3	5
+79605.2	5
+79616.2	5
+79627.2	5
+79638.1	5
+79649.1	5
+79660.1	5
+79671	5
+79682	5
+79693	5
+79703.9	5
+79714.9	5
+79725.9	5
+79736.9	5
+79747.8	5
+79758.8	5
+79769.8	5
+79780.7	5
+79791.7	5
+79802.7	5
+79813.6	5
+79824.6	5
+79835.6	5
+79846.5	5
+79857.5	5
+79868.5	5
+79879.4	5
+79890.4	5
+79901.4	5
+79912.3	5
+79923.3	5
+79934.3	5
+79945.2	5
+79956.2	5
+79967.2	5
+79978.1	5
+79989.1	5
+80000.1	5
+80011	5
+80022	5
+80033	5
+80044	5
+80054.9	5
+80065.9	5
+80076.9	5
+80087.8	5
+80098.8	5
+80109.8	5
+80120.7	5
+80131.7	5
+80142.7	5
+80153.6	5
+80164.6	5
+80175.6	5
+80186.5	5
+80197.5	5
+80208.5	5
+80219.4	5
+80230.4	5
+80241.4	5
+80252.3	5
+80263.3	5
+80274.3	5
+80285.2	5
+80296.2	5
+80307.2	5
+80318.2	5
+80329.1	5
+80340.1	5
+80351.1	5
+80362	5
+80373	5
+80384	5
+80394.9	5
+80405.9	5
+80416.9	5
+80427.8	5
+80438.8	5
+80449.8	5
+80460.7	5
+80471.7	5
+80482.7	5
+80493.6	5
+80504.6	5
+80515.6	5
+80526.5	5
+80537.5	5
+80548.5	5
+80559.4	5
+80570.4	5
+80581.4	5
+80592.3	5
+80603.3	5
+80614.3	5
+80625.3	5
+80636.2	5
+80647.2	5
+80658.2	5
+80669.1	5
+80680.1	5
+80691.1	5
+80702	5
+80713	5
+80724	5
+80734.9	5
+80745.9	5
+80756.9	5
+80767.8	5
+80778.8	5
+80789.8	5
+80800.7	5
+80811.7	5
+80822.7	5
+80833.6	5
+80844.6	5
+80855.6	5
+80866.5	5
+80877.5	5
+80888.5	5
+80899.5	5
+80910.4	5
+80921.4	5
+80932.4	5
+80943.3	5
+80954.3	5
+80965.3	5
+80976.2	5
+80987.2	5
+80998.2	5
+81009.1	5
+81020.1	5
+81031.1	5
+81042	5
+81053	5
+81064	5
+81074.9	5
+81085.9	5
+81096.9	5
+81107.8	5
+81118.8	5
+81129.8	5
+81140.7	5
+81151.7	5
+81162.7	5
+81173.6	5
+81184.6	5
+81195.6	5
+81206.6	5
+81217.5	5
+81228.5	5
+81239.5	5
+81250.4	5
+81261.4	5
+81272.4	5
+81283.3	5
+81294.3	5
+81305.3	5
+81316.2	5
+81327.2	5
+81338.2	5
+81349.1	5
+81360.1	5
+81371.1	5
+81382	5
+81393	5
+81404	5
+81414.9	5
+81425.9	5
+81436.9	5
+81447.8	5
+81458.8	5
+81469.8	5
+81480.8	5
+81491.7	4
+81502.7	4
+81513.7	5
+81524.6	5
+81535.6	5
+81546.6	5
+81557.5	5
+81568.5	5
+81579.5	5
+81590.4	5
+81601.4	5
+81612.4	5
+81623.3	5
+81634.3	5
+81645.3	5
+81656.2	5
+81667.2	5
+81678.2	5
+81689.1	5
+81700.1	5
+81711.1	5
+81722	5
+81733	5
+81744	5
+81755	5
+81765.9	5
+81776.9	5
+81787.9	5
+81798.8	5
+81809.8	5
+81820.8	5
+81831.7	5
+81842.7	5
+81853.7	5
+81864.6	5
+81875.6	5
+81886.6	5
+81897.5	5
+81908.5	5
+81919.5	5
+81930.4	5
+81941.4	5
+81952.4	5
+81963.3	5
+81974.3	5
+81985.3	5
+81996.2	5
+82007.2	5
+82018.2	5
+82029.1	5
+82040.1	5
+82051.1	5
+82062.1	5
+82073	5
+82084	5
+82095	5
+82105.9	5
+82116.9	5
+82127.9	5
+82138.8	5
+82149.8	5
+82160.8	5
+82171.7	5
+82182.7	5
+82193.7	5
+82204.6	5
+82215.6	5
+82226.6	5
+82237.5	5
+82248.5	5
+82259.5	5
+82270.4	5
+82281.4	5
+82292.4	5
+82303.3	5
+82314.3	5
+82325.3	5
+82336.3	5
+82347.2	5
+82358.2	5
+82369.2	5
+82380.1	5
+82391.1	5
+82402.1	5
+82413	5
+82424	5
+82435	5
+82445.9	5
+82456.9	5
+82467.9	5
+82478.8	5
+82489.8	5
+82500.8	5
+82511.7	5
+82522.7	5
+82533.7	5
+82544.6	5
+82555.6	5
+82566.6	5
+82577.5	5
+82588.5	5
+82599.5	5
+82610.4	5
+82621.4	5
+82632.4	5
+82643.4	5
+82654.3	5
+82665.3	5
+82676.3	5
+82687.2	5
+82698.2	5
+82709.2	5
+82720.1	5
+82731.1	5
+82742.1	5
+82753	5
+82764	5
+82775	5
+82785.9	5
+82796.9	5
+82807.9	5
+82818.8	5
+82829.8	5
+82840.8	5
+82851.7	5
+82862.7	5
+82873.7	5
+82884.6	5
+82895.6	5
+82906.6	5
+82917.6	5
+82928.5	5
+82939.5	5
+82950.5	5
+82961.4	5
+82972.4	5
+82983.4	5
+82994.3	5
+83005.3	5
+83016.3	5
+83027.2	5
+83038.2	5
+83049.2	5
+83060.1	5
+83071.1	5
+83082.1	5
+83093	5
+83104	5
+83115	5
+83125.9	5
+83136.9	5
+83147.9	5
+83158.8	5
+83169.8	5
+83180.8	5
+83191.7	5
+83202.7	5
+83213.7	5
+83224.7	5
+83235.6	5
+83246.6	2
+83257.6	1
+83268.5	1
+83279.5	1
+83290.5	1
+83301.4	1
+83312.4	1
+83323.4	1
+83334.3	1
+83345.3	1
+83356.3	1
+83367.2	1
+83378.2	1
+83389.2	1
+83400.1	1
+83411.1	1
+83422.1	1
+83433	1
+83444	1
+83455	1
+83465.9	1
+83476.9	1
+83487.9	1
+83498.9	1
+83509.8	1
+83520.8	1
+83531.8	1
+83542.7	1
+83553.7	1
+83564.7	1
+83575.6	1
+83586.6	1
+83597.6	1
+83608.5	1
+83619.5	1
+83630.5	1
+83641.4	1
+83652.4	1
+83663.4	1
+83674.3	1
+83685.3	1
+83696.3	1
+83707.2	1
+83718.2	1
+83729.2	1
+83740.1	1
+83751.1	1
+83762.1	1
+83773	1
+83784	1
+83795	1
+83806	1
+83816.9	1
+83827.9	1
+83838.9	1
+83849.8	1
+83860.8	1
+83871.8	1
+83882.7	1
+83893.7	1
+83904.7	1
+83915.6	1
+83926.6	1
+83937.6	1
+83948.5	1
+83959.5	1
+83970.5	1
+83981.4	1
+83992.4	1
+84003.4	1
+84014.3	1
+84025.3	1
+84036.3	1
+84047.2	1
+84058.2	1
+84069.2	1
+84080.2	1
+84091.1	1
+84102.1	1
+84113.1	1
+84124	1
+84135	1
+84146	1
+84156.9	1
+84167.9	1
+84178.9	1
+84189.8	1
+84200.8	1
+84211.8	1
+84222.7	1
+84233.7	1
+84244.7	1
+84255.6	1
+84266.6	1
+84277.6	1
+84288.5	1
+84299.5	1
+84310.5	1
+84321.4	1
+84332.4	1
+84343.4	1
+84354.3	1
+84365.3	1
+84376.3	1
+84387.3	1
+84398.2	1
+84409.2	1
+84420.2	1
+84431.1	1
+84442.1	1
+84453.1	1
+84464	1
+84475	1
+84486	1
+84496.9	1
+84507.9	1
+84518.9	1
+84529.8	1
+84540.8	1
+84551.8	1
+84562.7	1
+84573.7	1
+84584.7	1
+84595.6	1
+84606.6	1
+84617.6	1
+84628.5	1
+84639.5	1
+84650.5	1
+84661.5	1
+84672.4	1
+84683.4	1
+84694.4	1
+84705.3	1
+84716.3	1
+84727.3	1
+84738.2	1
+84749.2	1
+84760.2	1
+84771.1	1
+84782.1	1
+84793.1	1
+84804	1
+84815	1
+84826	1
+84836.9	1
+84847.9	1
+84858.9	1
+84869.8	1
+84880.8	1
+84891.8	1
+84902.7	1
+84913.7	1
+84924.7	1
+84935.6	1
+84946.6	1
+84957.6	1
+84968.6	1
+84979.5	1
+84990.5	1
+85001.5	1
+85012.4	1
+85023.4	1
+85034.4	1
+85045.3	1
+85056.3	1
+85067.3	1
+85078.2	1
+85089.2	1
+85100.2	1
+85111.1	1
+85122.1	1
+85133.1	1
+85144	1
+85155	1
+85166	1
+85176.9
Copied: SwiftApps/SciColSim/docs/plot_cumulative.txt (from rev 5634, SwiftApps/SciColSim/plot_cumulative.txt)
--- SwiftApps/SciColSim/docs/plot_cumulative.txt	                        (rev 0)
+++ SwiftApps/SciColSim/docs/plot_cumulative.txt	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,7989 @@
+0	4
+10.6631	8
+21.3262	8
+31.9893	12
+42.6524	13
+53.3156	16
+63.9787	17
+74.6418	20
+85.3049	21
+95.968	24
+106.631	24
+117.294	28
+127.957	29
+138.62	32
+149.284	33
+159.947	35
+170.61	37
+181.273	40
+191.936	41
+202.599	43
+213.262	45
+223.925	47
+234.588	49
+245.252	51
+255.915	53
+266.578	55
+277.241	57
+287.904	57
+298.567	58
+309.23	61
+319.893	61
+330.556	63
+341.22	67
+351.883	74
+362.546	75
+373.209	79
+383.872	81
+394.535	83
+405.198	85
+415.861	89
+426.524	90
+437.188	93
+447.851	94
+458.514	98
+469.177	98
+479.84	101
+490.503	102
+501.166	103
+511.829	106
+522.492	107
+533.155	110
+543.819	114
+554.482	118
+565.145	118
+575.808	121
+586.471	122
+597.134	122
+607.797	125
+618.46	127
+629.123	127
+639.787	129
+650.45	132
+661.113	134
+671.776	136
+682.439	136
+693.102	139
+703.765	143
+714.428	147
+725.091	148
+735.755	150
+746.418	152
+757.081	153
+767.744	156
+778.407	160
+789.07	162
+799.733	164
+810.396	164
+821.059	164
+831.723	168
+842.386	169
+853.049	175
+863.712	175
+874.375	176
+885.038	179
+895.701	182
+906.364	186
+917.027	190
+927.691	190
+938.354	194
+949.017	195
+959.68	198
+970.343	199
+981.006	202
+991.669	203
+1002.33	206
+1013	207
+1023.66	210
+1034.32	210
+1044.98	211
+1055.65	213
+1066.31	215
+1076.97	217
+1087.64	219
+1098.3	222
+1108.96	224
+1119.63	224
+1130.29	227
+1140.95	228
+1151.62	231
+1162.28	233
+1172.94	236
+1183.61	241
+1194.27	242
+1204.93	243
+1215.59	246
+1226.26	247
+1236.92	250
+1247.58	252
+1258.25	254
+1268.91	256
+1279.57	259
+1290.24	260
+1300.9	263
+1311.56	264
+1322.23	266
+1332.89	267
+1343.55	269
+1354.21	271
+1364.88	273
+1375.54	275
+1386.2	276
+1396.87	278
+1407.53	281
+1418.19	285
+1428.86	285
+1439.52	288
+1450.18	290
+1460.85	290
+1471.51	291
+1482.17	294
+1492.84	297
+1503.5	298
+1514.16	301
+1524.82	302
+1535.49	306
+1546.15	307
+1556.81	310
+1567.48	312
+1578.14	313
+1588.8	315
+1599.47	317
+1610.13	317
+1620.79	319
+1631.46	321
+1642.12	324
+1652.78	327
+1663.45	328
+1674.11	331
+1684.77	333
+1695.43	333
+1706.1	335
+1716.76	338
+1727.42	340
+1738.09	342
+1748.75	344
+1759.41	346
+1770.08	347
+1780.74	351
+1791.4	351
+1802.07	352
+1812.73	355
+1823.39	355
+1834.05	356
+1844.72	361
+1855.38	362
+1866.04	362
+1876.71	365
+1887.37	366
+1898.03	370
+1908.7	371
+1919.36	373
+1930.02	375
+1940.69	376
+1951.35	379
+1962.01	380
+1972.68	383
+1983.34	386
+1994	387
+2004.66	389
+2015.33	391
+2025.99	393
+2036.65	396
+2047.32	398
+2057.98	401
+2068.64	402
+2079.31	405
+2089.97	405
+2100.63	407
+2111.3	409
+2121.96	411
+2132.62	413
+2143.29	415
+2153.95	415
+2164.61	417
+2175.27	419
+2185.94	421
+2196.6	424
+2207.26	425
+2217.93	427
+2228.59	428
+2239.25	430
+2249.92	432
+2260.58	433
+2271.24	435
+2281.91	439
+2292.57	443
+2303.23	444
+2313.89	445
+2324.56	448
+2335.22	449
+2345.88	453
+2356.55	453
+2367.21	456
+2377.87	457
+2388.54	461
+2399.2	461
+2409.86	464
+2420.53	465
+2431.19	468
+2441.85	470
+2452.52	472
+2463.18	474
+2473.84	474
+2484.5	477
+2495.17	479
+2505.83	481
+2516.49	484
+2527.16	486
+2537.82	488
+2548.48	490
+2559.15	492
+2569.81	493
+2580.47	496
+2591.14	497
+2601.8	500
+2612.46	501
+2623.13	501
+2633.79	504
+2644.45	505
+2655.11	508
+2665.78	509
+2676.44	512
+2687.1	513
+2697.77	514
+2708.43	516
+2719.09	518
+2729.76	520
+2740.42	522
+2751.08	524
+2761.75	526
+2772.41	526
+2783.07	529
+2793.73	531
+2804.4	534
+2815.06	536
+2825.72	538
+2836.39	540
+2847.05	542
+2857.71	545
+2868.38	545
+2879.04	545
+2889.7	549
+2900.37	551
+2911.03	553
+2921.69	553
+2932.36	558
+2943.02	560
+2953.68	563
+2964.34	567
+2975.01	568
+2985.67	569
+2996.33	571
+3007	572
+3017.66	575
+3028.32	576
+3038.99	576
+3049.65	579
+3060.31	581
+3070.98	583
+3081.64	585
+3092.3	586
+3102.97	586
+3113.63	589
+3124.29	590
+3134.95	594
+3145.62	595
+3156.28	597
+3166.94	598
+3177.61	599
+3188.27	602
+3198.93	605
+3209.6	606
+3220.26	607
+3230.92	609
+3241.59	612
+3252.25	613
+3262.91	615
+3273.57	617
+3284.24	618
+3294.9	622
+3305.56	622
+3316.23	625
+3326.89	626
+3337.55	630
+3348.22	634
+3358.88	638
+3369.54	639
+3380.21	642
+3390.87	643
+3401.53	646
+3412.2	647
+3422.86	650
+3433.52	652
+3444.18	653
+3454.85	658
+3465.51	661
+3476.17	665
+3486.84	668
+3497.5	672
+3508.16	673
+3518.83	673
+3529.49	676
+3540.15	677
+3550.82	679
+3561.48	680
+3572.14	681
+3582.8	684
+3593.47	685
+3604.13	688
+3614.79	689
+3625.46	693
+3636.12	694
+3646.78	696
+3657.45	697
+3668.11	698
+3678.77	701
+3689.44	702
+3700.1	706
+3710.76	706
+3721.43	709
+3732.09	710
+3742.75	712
+3753.41	714
+3764.08	715
+3774.74	717
+3785.4	719
+3796.07	722
+3806.73	722
+3817.39	724
+3828.06	726
+3838.72	729
+3849.38	732
+3860.05	736
+3870.71	737
+3881.37	737
+3892.04	739
+3902.7	741
+3913.36	744
+3924.02	745
+3934.69	749
+3945.35	749
+3956.01	752
+3966.68	753
+3977.34	756
+3988	757
+3998.67	760
+4009.33	762
+4019.99	764
+4030.66	768
+4041.32	768
+4051.98	770
+4062.64	771
+4073.31	776
+4083.97	778
+4094.63	778
+4105.3	780
+4115.96	782
+4126.62	784
+4137.29	784
+4147.95	787
+4158.61	788
+4169.28	790
+4179.94	792
+4190.6	795
+4201.27	796
+4211.93	797
+4222.59	800
+4233.25	804
+4243.92	804
+4254.58	806
+4265.24	808
+4275.91	810
+4286.57	813
+4297.23	815
+4307.9	817
+4318.56	818
+4329.22	820
+4339.89	824
+4350.55	824
+4361.21	829
+4371.88	834
+4382.54	838
+4393.2	842
+4403.86	846
+4414.53	846
+4425.19	848
+4435.85	850
+4446.52	852
+4457.18	856
+4467.84	858
+4478.51	861
+4489.17	863
+4499.83	865
+4510.5	867
+4521.16	868
+4531.82	869
+4542.48	871
+4553.15	872
+4563.81	873
+4574.47	876
+4585.14	877
+4595.8	878
+4606.46	880
+4617.13	880
+4627.79	884
+4638.45	884
+4649.12	886
+4659.78	889
+4670.44	889
+4681.11	891
+4691.77	893
+4702.43	895
+4713.09	898
+4723.76	900
+4734.42	902
+4745.08	904
+4755.75	906
+4766.41	908
+4777.07	912
+4787.74	913
+4798.4	914
+4809.06	918
+4819.73	920
+4830.39	922
+4841.05	924
+4851.72	926
+4862.38	928
+4873.04	930
+4883.7	933
+4894.37	935
+4905.03	938
+4915.69	940
+4926.36	942
+4937.02	944
+4947.68	946
+4958.35	948
+4969.01	951
+4979.67	953
+4990.34	955
+5001	957
+5011.66	957
+5022.32	960
+5032.99	962
+5043.65	963
+5054.31	966
+5064.98	968
+5075.64	971
+5086.3	971
+5096.97	973
+5107.63	975
+5118.29	977
+5128.96	979
+5139.62	981
+5150.28	983
+5160.95	984
+5171.61	984
+5182.27	987
+5192.93	987
+5203.6	991
+5214.26	996
+5224.92	997
+5235.59	1001
+5246.25	1005
+5256.91	1008
+5267.58	1010
+5278.24	1012
+5288.9	1014
+5299.57	1016
+5310.23	1018
+5320.89	1020
+5331.55	1022
+5342.22	1024
+5352.88	1026
+5363.54	1028
+5374.21	1028
+5384.87	1030
+5395.53	1032
+5406.2	1032
+5416.86	1035
+5427.52	1036
+5438.19	1040
+5448.85	1043
+5459.51	1047
+5470.18	1051
+5480.84	1054
+5491.5	1055
+5502.16	1058
+5512.83	1061
+5523.49	1065
+5534.15	1069
+5544.82	1073
+5555.48	1077
+5566.14	1079
+5576.81	1082
+5587.47	1084
+5598.13	1087
+5608.8	1088
+5619.46	1090
+5630.12	1092
+5640.79	1092
+5651.45	1095
+5662.11	1098
+5672.77	1099
+5683.44	1101
+5694.1	1103
+5704.76	1105
+5715.43	1107
+5726.09	1109
+5736.75	1111
+5747.42	1115
+5758.08	1117
+5768.74	1119
+5779.41	1121
+5790.07	1123
+5800.73	1124
+5811.39	1127
+5822.06	1128
+5832.72	1132
+5843.38	1134
+5854.05	1134
+5864.71	1136
+5875.37	1138
+5886.04	1138
+5896.7	1140
+5907.36	1141
+5918.03	1143
+5928.69	1144
+5939.35	1146
+5950.02	1148
+5960.68	1151
+5971.34	1153
+5982	1154
+5992.67	1155
+6003.33	1157
+6013.99	1160
+6024.66	1162
+6035.32	1164
+6045.98	1166
+6056.65	1166
+6067.31	1169
+6077.97	1171
+6088.64	1173
+6099.3	1175
+6109.96	1177
+6120.63	1179
+6131.29	1179
+6141.95	1182
+6152.61	1184
+6163.28	1186
+6173.94	1188
+6184.6	1191
+6195.27	1194
+6205.93	1195
+6216.59	1199
+6227.26	1203
+6237.92	1205
+6248.58	1207
+6259.25	1209
+6269.91	1212
+6280.57	1214
+6291.23	1216
+6301.9	1219
+6312.56	1221
+6323.22	1222
+6333.89	1223
+6344.55	1226
+6355.21	1227
+6365.88	1227
+6376.54	1230
+6387.2	1231
+6397.87	1231
+6408.53	1234
+6419.19	1235
+6429.86	1238
+6440.52	1239
+6451.18	1240
+6461.84	1243
+6472.51	1244
+6483.17	1245
+6493.83	1248
+6504.5	1249
+6515.16	1252
+6525.82	1256
+6536.49	1259
+6547.15	1260
+6557.81	1263
+6568.48	1264
+6579.14	1267
+6589.8	1268
+6600.47	1271
+6611.13	1272
+6621.79	1275
+6632.45	1276
+6643.12	1280
+6653.78	1280
+6664.44	1283
+6675.11	1285
+6685.77	1288
+6696.43	1289
+6707.1	1293
+6717.76	1294
+6728.42	1298
+6739.09	1299
+6749.75	1301
+6760.41	1306
+6771.07	1307
+6781.74	1308
+6792.4	1311
+6803.06	1313
+6813.73	1316
+6824.39	1317
+6835.05	1320
+6845.72	1321
+6856.38	1324
+6867.04	1325
+6877.71	1328
+6888.37	1329
+6899.03	1329
+6909.7	1332
+6920.36	1336
+6931.02	1338
+6941.68	1339
+6952.35	1342
+6963.01	1342
+6973.67	1343
+6984.34	1346
+6995	1347
+7005.66	1347
+7016.33	1350
+7026.99	1351
+7037.65	1353
+7048.32	1354
+7058.98	1356
+7069.64	1357
+7080.31	1358
+7090.97	1359
+7101.63	1362
+7112.29	1363
+7122.96	1366
+7133.62	1367
+7144.28	1370
+7154.95	1371
+7165.61	1374
+7176.27	1377
+7186.94	1378
+7197.6	1380
+7208.26	1385
+7218.93	1387
+7229.59	1391
+7240.25	1394
+7250.91	1395
+7261.58	1400
+7272.24	1400
+7282.9	1402
+7293.57	1404
+7304.23	1406
+7314.89	1408
+7325.56	1410
+7336.22	1412
+7346.88	1414
+7357.55	1418
+7368.21	1421
+7378.87	1422
+7389.54	1424
+7400.2	1426
+7410.86	1428
+7421.52	1430
+7432.19	1431
+7442.85	1436
+7453.51	1437
+7464.18	1439
+7474.84	1441
+7485.5	1441
+7496.17	1444
+7506.83	1449
+7517.49	1450
+7528.16	1450
+7538.82	1452
+7549.48	1454
+7560.14	1458
+7570.81	1461
+7581.47	1462
+7592.13	1465
+7602.8	1466
+7613.46	1469
+7624.12	1470
+7634.79	1473
+7645.45	1474
+7656.11	1477
+7666.78	1478
+7677.44	1481
+7688.1	1482
+7698.77	1485
+7709.43	1487
+7720.09	1490
+7730.75	1491
+7741.42	1492
+7752.08	1494
+7762.74	1495
+7773.41	1498
+7784.07	1499
+7794.73	1502
+7805.4	1502
+7816.06	1503
+7826.72	1506
+7837.39	1508
+7848.05	1515
+7858.71	1516
+7869.38	1520
+7880.04	1520
+7890.7	1524
+7901.36	1528
+7912.03	1529
+7922.69	1532
+7933.35	1533
+7944.02	1537
+7954.68	1541
+7965.34	1542
+7976.01	1545
+7986.67	1547
+7997.33	1550
+8008	1551
+8018.66	1553
+8029.32	1553
+8039.98	1555
+8050.65	1557
+8061.31	1559
+8071.97	1561
+8082.64	1562
+8093.3	1564
+8103.96	1565
+8114.63	1567
+8125.29	1569
+8135.95	1571
+8146.62	1573
+8157.28	1575
+8167.94	1575
+8178.61	1576
+8189.27	1579
+8199.93	1581
+8210.59	1583
+8221.26	1585
+8231.92	1587
+8242.58	1590
+8253.25	1593
+8263.91	1595
+8274.57	1597
+8285.24	1599
+8295.9	1601
+8306.56	1604
+8317.23	1606
+8327.89	1608
+8338.55	1610
+8349.22	1612
+8359.88	1614
+8370.54	1615
+8381.2	1617
+8391.87	1618
+8402.53	1621
+8413.19	1623
+8423.86	1623
+8434.52	1626
+8445.18	1629
+8455.85	1631
+8466.51	1633
+8477.17	1636
+8487.84	1638
+8498.5	1640
+8509.16	1643
+8519.82	1645
+8530.49	1647
+8541.15	1649
+8551.81	1651
+8562.48	1653
+8573.14	1655
+8583.8	1657
+8594.47	1657
+8605.13	1661
+8615.79	1661
+8626.46	1664
+8637.12	1665
+8647.78	1668
+8658.45	1669
+8669.11	1673
+8679.77	1673
+8690.43	1677
+8701.1	1678
+8711.76	1681
+8722.42	1682
+8733.09	1685
+8743.75	1690
+8754.41	1694
+8765.08	1698
+8775.74	1701
+8786.4	1704
+8797.07	1705
+8807.73	1709
+8818.39	1709
+8829.06	1713
+8839.72	1717
+8850.38	1721
+8861.04	1721
+8871.71	1725
+8882.37	1729
+8893.03	1731
+8903.7	1733
+8914.36	1735
+8925.02	1737
+8935.69	1739
+8946.35	1741
+8957.01	1743
+8967.68	1745
+8978.34	1747
+8989	1749
+8999.66	1751
+9010.33	1753
+9020.99	1757
+9031.65	1762
+9042.32	1768
+9052.98	1769
+9063.64	1772
+9074.31	1773
+9084.97	1777
+9095.63	1777
+9106.3	1781
+9116.96	1785
+9127.62	1785
+9138.29	1787
+9148.95	1789
+9159.61	1790
+9170.27	1793
+9180.94	1793
+9191.6	1794
+9202.26	1797
+9212.93	1798
+9223.59	1801
+9234.25	1802
+9244.92	1805
+9255.58	1806
+9266.24	1809
+9276.91	1811
+9287.57	1813
+9298.23	1815
+9308.9	1817
+9319.56	1819
+9330.22	1820
+9340.88	1822
+9351.55	1823
+9362.21	1825
+9372.87	1828
+9383.54	1831
+9394.2	1837
+9404.86	1837
+9415.53	1841
+9426.19	1841
+9436.85	1845
+9447.52	1849
+9458.18	1853
+9468.84	1857
+9479.5	1861
+9490.17	1861
+9500.83	1866
+9511.49	1866
+9522.16	1869
+9532.82	1870
+9543.48	1871
+9554.15	1874
+9564.81	1875
+9575.47	1879
+9586.14	1884
+9596.8	1888
+9607.46	1889
+9618.13	1892
+9628.79	1893
+9639.45	1893
+9650.11	1896
+9660.78	1897
+9671.44	1900
+9682.1	1901
+9692.77	1904
+9703.43	1905
+9714.09	1907
+9724.76	1909
+9735.42	1910
+9746.08	1913
+9756.75	1917
+9767.41	1918
+9778.07	1921
+9788.73	1923
+9799.4	1927
+9810.06	1927
+9820.72	1930
+9831.39	1932
+9842.05	1936
+9852.71	1937
+9863.38	1939
+9874.04	1941
+9884.7	1945
+9895.37	1948
+9906.03	1948
+9916.69	1950
+9927.36	1952
+9938.02	1954
+9948.68	1957
+9959.34	1958
+9970.01	1961
+9980.67	1962
+9991.33	1962
+10002	1965
+10012.7	1966
+10023.3	1969
+10034	1969
+10044.6	1970
+10055.3	1973
+10066	1974
+10076.6	1977
+10087.3	1978
+10098	1982
+10108.6	1983
+10119.3	1985
+10130	1988
+10140.6	1988
+10151.3	1991
+10161.9	1993
+10172.6	1997
+10183.3	1997
+10193.9	1998
+10204.6	2001
+10215.3	2004
+10225.9	2006
+10236.6	2008
+10247.2	2013
+10257.9	2014
+10268.6	2016
+10279.2	2018
+10289.9	2020
+10300.6	2022
+10311.2	2026
+10321.9	2026
+10332.6	2027
+10343.2	2029
+10353.9	2030
+10364.5	2031
+10375.2	2034
+10385.9	2035
+10396.5	2037
+10407.2	2040
+10417.9	2043
+10428.5	2046
+10439.2	2049
+10449.8	2050
+10460.5	2052
+10471.2	2054
+10481.8	2058
+10492.5	2059
+10503.2	2063
+10513.8	2067
+10524.5	2068
+10535.2	2070
+10545.8	2073
+10556.5	2073
+10567.1	2075
+10577.8	2077
+10588.5	2079
+10599.1	2081
+10609.8	2083
+10620.5	2086
+10631.1	2087
+10641.8	2089
+10652.4	2092
+10663.1	2094
+10673.8	2096
+10684.4	2098
+10695.1	2103
+10705.8	2104
+10716.4	2107
+10727.1	2108
+10737.8	2110
+10748.4	2112
+10759.1	2113
+10769.7	2116
+10780.4	2117
+10791.1	2118
+10801.7	2120
+10812.4	2122
+10823.1	2124
+10833.7	2126
+10844.4	2128
+10855	2130
+10865.7	2131
+10876.4	2133
+10887	2134
+10897.7	2136
+10908.4	2138
+10919	2139
+10929.7	2142
+10940.4	2144
+10951	2147
+10961.7	2149
+10972.3	2151
+10983	2153
+10993.7	2153
+11004.3	2154
+11015	2156
+11025.7	2160
+11036.3	2161
+11047	2162
+11057.6	2165
+11068.3	2167
+11079	2167
+11089.6	2171
+11100.3	2172
+11111	2175
+11121.6	2177
+11132.3	2180
+11142.9	2181
+11153.6	2183
+11164.3	2185
+11174.9	2188
+11185.6	2190
+11196.3	2192
+11206.9	2195
+11217.6	2198
+11228.3	2199
+11238.9	2201
+11249.6	2203
+11260.2	2205
+11270.9	2208
+11281.6	2210
+11292.2	2212
+11302.9	2215
+11313.6	2217
+11324.2	2219
+11334.9	2224
+11345.5	2225
+11356.2	2228
+11366.9	2229
+11377.5	2233
+11388.2	2235
+11398.9	2238
+11409.5	2239
+11420.2	2243
+11430.9	2243
+11441.5	2246
+11452.2	2251
+11462.8	2252
+11473.5	2254
+11484.2	2255
+11494.8	2257
+11505.5	2258
+11516.2	2259
+11526.8	2262
+11537.5	2264
+11548.1	2267
+11558.8	2268
+11569.5	2272
+11580.1	2272
+11590.8	2273
+11601.5	2276
+11612.1	2278
+11622.8	2281
+11633.5	2282
+11644.1	2285
+11654.8	2286
+11665.4	2290
+11676.1	2291
+11686.8	2294
+11697.4	2296
+11708.1	2298
+11718.8	2302
+11729.4	2307
+11740.1	2311
+11750.7	2315
+11761.4	2318
+11772.1	2319
+11782.7	2322
+11793.4	2324
+11804.1	2328
+11814.7	2330
+11825.4	2332
+11836.1	2333
+11846.7	2335
+11857.4	2336
+11868	2337
+11878.7	2339
+11889.4	2340
+11900	2341
+11910.7	2343
+11921.4	2344
+11932	2346
+11942.7	2349
+11953.3	2351
+11964	2353
+11974.7	2355
+11985.3	2357
+11996	2358
+12006.7	2362
+12017.3	2364
+12028	2367
+12038.7	2370
+12049.3	2371
+12060	2375
+12070.6	2376
+12081.3	2379
+12092	2380
+12102.6	2385
+12113.3	2385
+12124	2386
+12134.6	2389
+12145.3	2390
+12155.9	2393
+12166.6	2398
+12177.3	2398
+12187.9	2400
+12198.6	2402
+12209.3	2404
+12219.9	2406
+12230.6	2407
+12241.3	2409
+12251.9	2410
+12262.6	2411
+12273.2	2414
+12283.9	2418
+12294.6	2422
+12305.2	2426
+12315.9	2431
+12326.6	2433
+12337.2	2435
+12347.9	2437
+12358.5	2438
+12369.2	2441
+12379.9	2442
+12390.5	2445
+12401.2	2446
+12411.9	2450
+12422.5	2450
+12433.2	2454
+12443.8	2458
+12454.5	2462
+12465.2	2465
+12475.8	2467
+12486.5	2469
+12497.2	2472
+12507.8	2474
+12518.5	2476
+12529.2	2478
+12539.8	2480
+12550.5	2482
+12561.1	2483
+12571.8	2484
+12582.5	2487
+12593.1	2488
+12603.8	2492
+12614.5	2496
+12625.1	2500
+12635.8	2504
+12646.4	2507
+12657.1	2508
+12667.8	2512
+12678.4	2517
+12689.1	2517
+12699.8	2519
+12710.4	2521
+12721.1	2521
+12731.8	2523
+12742.4	2526
+12753.1	2526
+12763.7	2528
+12774.4	2530
+12785.1	2532
+12795.7	2534
+12806.4	2536
+12817.1	2538
+12827.7	2540
+12838.4	2542
+12849	2544
+12859.7	2547
+12870.4	2547
+12881	2549
+12891.7	2550
+12902.4	2552
+12913	2554
+12923.7	2555
+12934.4	2557
+12945	2559
+12955.7	2561
+12966.3	2564
+12977	2565
+12987.7	2567
+12998.3	2571
+13009	2572
+13019.7	2573
+13030.3	2577
+13041	2578
+13051.6	2580
+13062.3	2582
+13073	2584
+13083.6	2586
+13094.3	2588
+13105	2590
+13115.6	2592
+13126.3	2594
+13137	2596
+13147.6	2598
+13158.3	2601
+13168.9	2601
+13179.6	2604
+13190.3	2605
+13200.9	2607
+13211.6	2608
+13222.3	2610
+13232.9	2612
+13243.6	2615
+13254.2	2617
+13264.9	2620
+13275.6	2622
+13286.2	2624
+13296.9	2625
+13307.6	2628
+13318.2	2629
+13328.9	2632
+13339.6	2633
+13350.2	2636
+13360.9	2638
+13371.5	2639
+13382.2	2643
+13392.9	2643
+13403.5	2644
+13414.2	2647
+13424.9	2647
+13435.5	2649
+13446.2	2652
+13456.8	2652
+13467.5	2655
+13478.2	2658
+13488.8	2662
+13499.5	2663
+13510.2	2665
+13520.8	2667
+13531.5	2669
+13542.1	2671
+13552.8	2673
+13563.5	2675
+13574.1	2677
+13584.8	2679
+13595.5	2681
+13606.1	2681
+13616.8	2681
+13627.5	2681
+13638.1	2681
+13648.8	2681
+13659.4	2682
+13670.1	2685
+13680.8	2685
+13691.4	2685
+13702.1	2687
+13712.8	2689
+13723.4	2691
+13734.1	2694
+13744.7	2697
+13755.4	2700
+13766.1	2702
+13776.7	2705
+13787.4	2708
+13798.1	2710
+13808.7	2711
+13819.4	2713
+13830.1	2714
+13840.7	2718
+13851.4	2721
+13862	2721
+13872.7	2724
+13883.4	2724
+13894	2726
+13904.7	2728
+13915.4	2731
+13926	2732
+13936.7	2734
+13947.3	2735
+13958	2737
+13968.7	2738
+13979.3	2740
+13990	2742
+14000.7	2743
+14011.3	2745
+14022	2746
+14032.7	2746
+14043.3	2747
+14054	2750
+14064.6	2750
+14075.3	2751
+14086	2752
+14096.6	2754
+14107.3	2756
+14118	2758
+14128.6	2759
+14139.3	2760
+14149.9	2761
+14160.6	2763
+14171.3	2764
+14181.9	2766
+14192.6	2768
+14203.3	2772
+14213.9	2772
+14224.6	2776
+14235.3	2779
+14245.9	2782
+14256.6	2785
+14267.2	2786
+14277.9	2788
+14288.6	2790
+14299.2	2792
+14309.9	2794
+14320.6	2795
+14331.2	2797
+14341.9	2798
+14352.5	2800
+14363.2	2801
+14373.9	2803
+14384.5	2805
+14395.2	2806
+14405.9	2809
+14416.5	2810
+14427.2	2814
+14437.9	2814
+14448.5	2816
+14459.2	2818
+14469.8	2821
+14480.5	2823
+14491.2	2825
+14501.8	2828
+14512.5	2828
+14523.2	2831
+14533.8	2834
+14544.5	2835
+14555.1	2837
+14565.8	2840
+14576.5	2842
+14587.1	2844
+14597.8	2846
+14608.5	2848
+14619.1	2849
+14629.8	2851
+14640.5	2853
+14651.1	2854
+14661.8	2856
+14672.4	2858
+14683.1	2860
+14693.8	2862
+14704.4	2864
+14715.1	2866
+14725.8	2868
+14736.4	2870
+14747.1	2871
+14757.7	2873
+14768.4	2874
+14779.1	2875
+14789.7	2878
+14800.4	2880
+14811.1	2883
+14821.7	2884
+14832.4	2887
+14843	2890
+14853.7	2890
+14864.4	2891
+14875	2894
+14885.7	2895
+14896.4	2898
+14907	2899
+14917.7	2899
+14928.4	2902
+14939	2904
+14949.7	2909
+14960.3	2912
+14971	2914
+14981.7	2916
+14992.3	2920
+15003	2921
+15013.7	2923
+15024.3	2925
+15035	2927
+15045.6	2929
+15056.3	2931
+15067	2933
+15077.6	2935
+15088.3	2937
+15099	2939
+15109.6	2940
+15120.3	2941
+15131	2943
+15141.6	2944
+15152.3	2945
+15162.9	2948
+15173.6	2949
+15184.3	2951
+15194.9	2953
+15205.6	2955
+15216.3	2958
+15226.9	2961
+15237.6	2967
+15248.2	2968
+15258.9	2969
+15269.6	2972
+15280.2	2973
+15290.9	2973
+15301.6	2977
+15312.2	2981
+15322.9	2985
+15333.6	2990
+15344.2	2991
+15354.9	2996
+15365.5	2996
+15376.2	2998
+15386.9	3000
+15397.5	3001
+15408.2	3002
+15418.9	3005
+15429.5	3008
+15440.2	3008
+15450.8	3010
+15461.5	3012
+15472.2	3014
+15482.8	3015
+15493.5	3016
+15504.2	3018
+15514.8	3022
+15525.5	3023
+15536.2	3024
+15546.8	3027
+15557.5	3028
+15568.1	3031
+15578.8	3032
+15589.5	3033
+15600.1	3036
+15610.8	3039
+15621.5	3040
+15632.1	3040
+15642.8	3041
+15653.4	3042
+15664.1	3042
+15674.8	3042
+15685.4	3042
+15696.1	3042
+15706.8	3042
+15717.4	3042
+15728.1	3042
+15738.8	3042
+15749.4	3042
+15760.1	3042
+15770.7	3042
+15781.4	3042
+15792.1	3042
+15802.7	3042
+15813.4	3042
+15824.1	3042
+15834.7	3042
+15845.4	3042
+15856	3042
+15866.7	3042
+15877.4	3043
+15888	3044
+15898.7	3045
+15909.4	3046
+15920	3047
+15930.7	3047
+15941.3	3048
+15952	3049
+15962.7	3049
+15973.3	3050
+15984	3051
+15994.7	3052
+16005.3	3052
+16016	3053
+16026.7	3054
+16037.3	3055
+16048	3056
+16058.6	3058
+16069.3	3059
+16080	3060
+16090.6	3061
+16101.3	3062
+16112	3063
+16122.6	3064
+16133.3	3065
+16143.9	3066
+16154.6	3068
+16165.3	3070
+16175.9	3072
+16186.6	3073
+16197.3	3074
+16207.9	3074
+16218.6	3076
+16229.3	3078
+16239.9	3079
+16250.6	3080
+16261.2	3081
+16271.9	3082
+16282.6	3083
+16293.2	3084
+16303.9	3085
+16314.6	3086
+16325.2	3087
+16335.9	3088
+16346.5	3089
+16357.2	3090
+16367.9	3092
+16378.5	3093
+16389.2	3094
+16399.9	3095
+16410.5	3096
+16421.2	3097
+16431.9	3097
+16442.5	3098
+16453.2	3099
+16463.8	3100
+16474.5	3101
+16485.2	3102
+16495.8	3103
+16506.5	3104
+16517.2	3105
+16527.8	3106
+16538.5	3107
+16549.1	3108
+16559.8	3109
+16570.5	3110
+16581.1	3111
+16591.8	3112
+16602.5	3113
+16613.1	3114
+16623.8	3115
+16634.5	3116
+16645.1	3116
+16655.8	3117
+16666.4	3119
+16677.1	3121
+16687.8	3123
+16698.4	3123
+16709.1	3124
+16719.8	3125
+16730.4	3126
+16741.1	3127
+16751.7	3128
+16762.4	3129
+16773.1	3129
+16783.7	3130
+16794.4	3131
+16805.1	3132
+16815.7	3133
+16826.4	3134
+16837.1	3135
+16847.7	3136
+16858.4	3137
+16869	3138
+16879.7	3139
+16890.4	3139
+16901	3140
+16911.7	3142
+16922.4	3142
+16933	3144
+16943.7	3144
+16954.3	3145
+16965	3146
+16975.7	3147
+16986.3	3148
+16997	3150
+17007.7	3152
+17018.3	3155
+17029	3156
+17039.6	3156
+17050.3	3157
+17061	3158
+17071.6	3158
+17082.3	3158
+17093	3158
+17103.6	3158
+17114.3	3158
+17125	3159
+17135.6	3159
+17146.3	3159
+17156.9	3159
+17167.6	3159
+17178.3	3159
+17188.9	3160
+17199.6	3160
+17210.3	3160
+17220.9	3160
+17231.6	3160
+17242.2	3160
+17252.9	3160
+17263.6	3161
+17274.2	3161
+17284.9	3161
+17295.6	3161
+17306.2	3161
+17316.9	3161
+17327.6	3162
+17338.2	3162
+17348.9	3162
+17359.5	3162
+17370.2	3162
+17380.9	3162
+17391.5	3162
+17402.2	3163
+17412.9	3168
+17423.5	3168
+17434.2	3173
+17444.8	3177
+17455.5	3178
+17466.2	3181
+17476.8	3183
+17487.5	3186
+17498.2	3187
+17508.8	3188
+17519.5	3192
+17530.2	3194
+17540.8	3197
+17551.5	3199
+17562.1	3202
+17572.8	3204
+17583.5	3207
+17594.1	3213
+17604.8	3215
+17615.5	3217
+17626.1	3220
+17636.8	3222
+17647.4	3225
+17658.1	3227
+17668.8	3230
+17679.4	3232
+17690.1	3236
+17700.8	3238
+17711.4	3242
+17722.1	3244
+17732.8	3247
+17743.4	3250
+17754.1	3252
+17764.7	3253
+17775.4	3256
+17786.1	3259
+17796.7	3259
+17807.4	3262
+17818.1	3265
+17828.7	3268
+17839.4	3270
+17850	3270
+17860.7	3273
+17871.4	3276
+17882	3279
+17892.7	3282
+17903.4	3282
+17914	3284
+17924.7	3286
+17935.4	3287
+17946	3289
+17956.7	3292
+17967.3	3293
+17978	3294
+17988.7	3297
+17999.3	3299
+18010	3302
+18020.7	3304
+18031.3	3305
+18042	3308
+18052.6	3313
+18063.3	3314
+18074	3316
+18084.6	3317
+18095.3	3318
+18106	3318
+18116.6	3318
+18127.3	3318
+18138	3318
+18148.6	3318
+18159.3	3318
+18169.9	3318
+18180.6	3318
+18191.3	3318
+18201.9	3318
+18212.6	3318
+18223.3	3318
+18233.9	3318
+18244.6	3318
+18255.2	3318
+18265.9	3318
+18276.6	3318
+18287.2	3318
+18297.9	3318
+18308.6	3318
+18319.2	3318
+18329.9	3319
+18340.5	3320
+18351.2	3320
+18361.9	3321
+18372.5	3322
+18383.2	3322
+18393.9	3322
+18404.5	3322
+18415.2	3322
+18425.9	3322
+18436.5	3322
+18447.2	3322
+18457.8	3322
+18468.5	3322
+18479.2	3322
+18489.8	3322
+18500.5	3322
+18511.2	3322
+18521.8	3322
+18532.5	3322
+18543.1	3322
+18553.8	3322
+18564.5	3322
+18575.1	3322
+18585.8	3322
+18596.5	3322
+18607.1	3322
+18617.8	3322
+18628.5	3322
+18639.1	3322
+18649.8	3322
+18660.4	3322
+18671.1	3322
+18681.8	3322
+18692.4	3322
+18703.1	3322
+18713.8	3322
+18724.4	3322
+18735.1	3322
+18745.7	3322
+18756.4	3322
+18767.1	3322
+18777.7	3322
+18788.4	3322
+18799.1	3322
+18809.7	3322
+18820.4	3322
+18831.1	3322
+18841.7	3322
+18852.4	3322
+18863	3322
+18873.7	3322
+18884.4	3322
+18895	3322
+18905.7	3322
+18916.4	3322
+18927	3322
+18937.7	3322
+18948.3	3322
+18959	3322
+18969.7	3322
+18980.3	3322
+18991	3322
+19001.7	3322
+19012.3	3322
+19023	3322
+19033.7	3322
+19044.3	3324
+19055	3326
+19065.6	3328
+19076.3	3330
+19087	3333
+19097.6	3333
+19108.3	3334
+19119	3335
+19129.6	3336
+19140.3	3337
+19150.9	3339
+19161.6	3341
+19172.3	3342
+19182.9	3343
+19193.6	3344
+19204.3	3345
+19214.9	3347
+19225.6	3347
+19236.3	3348
+19246.9	3349
+19257.6	3350
+19268.2	3350
+19278.9	3351
+19289.6	3352
+19300.2	3353
+19310.9	3354
+19321.6	3355
+19332.2	3356
+19342.9	3357
+19353.5	3358
+19364.2	3359
+19374.9	3360
+19385.5	3361
+19396.2	3362
+19406.9	3363
+19417.5	3364
+19428.2	3365
+19438.8	3367
+19449.5	3368
+19460.2	3369
+19470.8	3370
+19481.5	3371
+19492.2	3372
+19502.8	3372
+19513.5	3375
+19524.2	3376
+19534.8	3377
+19545.5	3378
+19556.1	3380
+19566.8	3380
+19577.5	3382
+19588.1	3383
+19598.8	3384
+19609.5	3386
+19620.1	3387
+19630.8	3388
+19641.4	3389
+19652.1	3390
+19662.8	3391
+19673.4	3392
+19684.1	3393
+19694.8	3394
+19705.4	3395
+19716.1	3396
+19726.8	3397
+19737.4	3398
+19748.1	3399
+19758.7	3400
+19769.4	3401
+19780.1	3402
+19790.7	3403
+19801.4	3403
+19812.1	3404
+19822.7	3404
+19833.4	3405
+19844	3406
+19854.7	3407
+19865.4	3408
+19876	3409
+19886.7	3410
+19897.4	3411
+19908	3412
+19918.7	3413
+19929.4	3414
+19940	3415
+19950.7	3416
+19961.3	3417
+19972	3418
+19982.7	3419
+19993.3	3420
+20004	3420
+20014.7	3421
+20025.3	3422
+20036	3423
+20046.6	3424
+20057.3	3425
+20068	3427
+20078.6	3429
+20089.3	3432
+20100	3434
+20110.6	3435
+20121.3	3436
+20132	3437
+20142.6	3438
+20153.3	3438
+20163.9	3439
+20174.6	3440
+20185.3	3441
+20195.9	3442
+20206.6	3443
+20217.3	3444
+20227.9	3445
+20238.6	3446
+20249.2	3446
+20259.9	3446
+20270.6	3447
+20281.2	3447
+20291.9	3448
+20302.6	3448
+20313.2	3448
+20323.9	3449
+20334.6	3449
+20345.2	3450
+20355.9	3450
+20366.5	3451
+20377.2	3452
+20387.9	3453
+20398.5	3454
+20409.2	3455
+20419.9	3456
+20430.5	3457
+20441.2	3458
+20451.8	3459
+20462.5	3460
+20473.2	3461
+20483.8	3462
+20494.5	3463
+20505.2	3464
+20515.8	3465
+20526.5	3466
+20537.1	3467
+20547.8	3468
+20558.5	3469
+20569.1	3470
+20579.8	3471
+20590.5	3472
+20601.1	3473
+20611.8	3474
+20622.5	3475
+20633.1	3478
+20643.8	3478
+20654.4	3479
+20665.1	3480
+20675.8	3481
+20686.4	3481
+20697.1	3482
+20707.8	3483
+20718.4	3484
+20729.1	3487
+20739.7	3489
+20750.4	3489
+20761.1	3490
+20771.7	3491
+20782.4	3492
+20793.1	3493
+20803.7	3494
+20814.4	3495
+20825.1	3496
+20835.7	3497
+20846.4	3498
+20857	3499
+20867.7	3499
+20878.4	3501
+20889	3502
+20899.7	3504
+20910.4	3506
+20921	3508
+20931.7	3510
+20942.3	3512
+20953	3514
+20963.7	3515
+20974.3	3516
+20985	3517
+20995.7	3518
+21006.3	3520
+21017	3520
+21027.7	3522
+21038.3	3523
+21049	3523
+21059.6	3523
+21070.3	3523
+21081	3524
+21091.6	3526
+21102.3	3527
+21113	3528
+21123.6	3530
+21134.3	3531
+21144.9	3532
+21155.6	3533
+21166.3	3534
+21176.9	3535
+21187.6	3536
+21198.3	3537
+21208.9	3538
+21219.6	3539
+21230.3	3539
+21240.9	3540
+21251.6	3541
+21262.2	3542
+21272.9	3543
+21283.6	3544
+21294.2	3544
+21304.9	3545
+21315.6	3546
+21326.2	3548
+21336.9	3548
+21347.5	3549
+21358.2	3550
+21368.9	3551
+21379.5	3552
+21390.2	3553
+21400.9	3554
+21411.5	3554
+21422.2	3555
+21432.9	3556
+21443.5	3557
+21454.2	3558
+21464.8	3559
+21475.5	3561
+21486.2	3562
+21496.8	3562
+21507.5	3562
+21518.2	3562
+21528.8	3564
+21539.5	3565
+21550.1	3567
+21560.8	3567
+21571.5	3569
+21582.1	3572
+21592.8	3575
+21603.5	3577
+21614.1	3579
+21624.8	3580
+21635.5	3582
+21646.1	3584
+21656.8	3584
+21667.4	3586
+21678.1	3586
+21688.8	3588
+21699.4	3590
+21710.1	3592
+21720.8	3594
+21731.4	3596
+21742.1	3598
+21752.7	3600
+21763.4	3602
+21774.1	3604
+21784.7	3606
+21795.4	3608
+21806.1	3611
+21816.7	3613
+21827.4	3615
+21838	3616
+21848.7	3617
+21859.4	3618
+21870	3619
+21880.7	3621
+21891.4	3624
+21902	3626
+21912.7	3627
+21923.4	3628
+21934	3629
+21944.7	3631
+21955.3	3631
+21966	3633
+21976.7	3635
+21987.3	3635
+21998	3637
+22008.7	3639
+22019.3	3641
+22030	3643
+22040.6	3643
+22051.3	3645
+22062	3647
+22072.6	3647
+22083.3	3650
+22094	3652
+22104.6	3652
+22115.3	3654
+22126	3656
+22136.6	3658
+22147.3	3658
+22157.9	3659
+22168.6	3660
+22179.3	3661
+22189.9	3662
+22200.6	3663
+22211.3	3664
+22221.9	3664
+22232.6	3665
+22243.2	3665
+22253.9	3665
+22264.6	3665
+22275.2	3665
+22285.9	3665
+22296.6	3665
+22307.2	3666
+22317.9	3668
+22328.6	3669
+22339.2	3669
+22349.9	3670
+22360.5	3671
+22371.2	3672
+22381.9	3673
+22392.5	3674
+22403.2	3675
+22413.9	3676
+22424.5	3677
+22435.2	3679
+22445.8	3680
+22456.5	3680
+22467.2	3681
+22477.8	3682
+22488.5	3683
+22499.2	3684
+22509.8	3685
+22520.5	3688
+22531.2	3689
+22541.8	3690
+22552.5	3691
+22563.1	3692
+22573.8	3693
+22584.5	3693
+22595.1	3695
+22605.8	3696
+22616.5	3697
+22627.1	3698
+22637.8	3699
+22648.4	3700
+22659.1	3701
+22669.8	3701
+22680.4	3702
+22691.1	3703
+22701.8	3704
+22712.4	3704
+22723.1	3705
+22733.8	3707
+22744.4	3708
+22755.1	3709
+22765.7	3709
+22776.4	3710
+22787.1	3711
+22797.7	3712
+22808.4	3713
+22819.1	3715
+22829.7	3716
+22840.4	3717
+22851	3719
+22861.7	3721
+22872.4	3722
+22883	3724
+22893.7	3724
+22904.4	3725
+22915	3725
+22925.7	3725
+22936.3	3725
+22947	3725
+22957.7	3725
+22968.3	3726
+22979	3728
+22989.7	3729
+23000.3	3730
+23011	3731
+23021.7	3732
+23032.3	3733
+23043	3734
+23053.6	3735
+23064.3	3736
+23075	3737
+23085.6	3739
+23096.3	3741
+23107	3741
+23117.6	3743
+23128.3	3743
+23138.9	3745
+23149.6	3746
+23160.3	3749
+23170.9	3750
+23181.6	3750
+23192.3	3752
+23202.9	3753
+23213.6	3755
+23224.3	3756
+23234.9	3758
+23245.6	3759
+23256.2	3761
+23266.9	3762
+23277.6	3763
+23288.2	3764
+23298.9	3766
+23309.6	3768
+23320.2	3768
+23330.9	3770
+23341.5	3771
+23352.2	3773
+23362.9	3774
+23373.5	3775
+23384.2	3777
+23394.9	3778
+23405.5	3780
+23416.2	3781
+23426.9	3781
+23437.5	3783
+23448.2	3783
+23458.8	3783
+23469.5	3783
+23480.2	3783
+23490.8	3784
+23501.5	3784
+23512.2	3784
+23522.8	3784
+23533.5	3784
+23544.1	3784
+23554.8	3784
+23565.5	3784
+23576.1	3784
+23586.8	3784
+23597.5	3784
+23608.1	3784
+23618.8	3784
+23629.5	3784
+23640.1	3784
+23650.8	3784
+23661.4	3784
+23672.1	3784
+23682.8	3784
+23693.4	3784
+23704.1	3784
+23714.8	3784
+23725.4	3784
+23736.1	3784
+23746.7	3784
+23757.4	3784
+23768.1	3784
+23778.7	3784
+23789.4	3784
+23800.1	3784
+23810.7	3784
+23821.4	3784
+23832.1	3784
+23842.7	3784
+23853.4	3784
+23864	3784
+23874.7	3784
+23885.4	3784
+23896	3784
+23906.7	3784
+23917.4	3784
+23928	3784
+23938.7	3784
+23949.3	3784
+23960	3784
+23970.7	3784
+23981.3	3784
+23992	3784
+24002.7	3784
+24013.3	3785
+24024	3785
+24034.6	3786
+24045.3	3787
+24056	3788
+24066.6	3789
+24077.3	3791
+24088	3792
+24098.6	3793
+24109.3	3794
+24120	3795
+24130.6	3796
+24141.3	3798
+24151.9	3800
+24162.6	3802
+24173.3	3802
+24183.9	3802
+24194.6	3802
+24205.3	3802
+24215.9	3802
+24226.6	3802
+24237.2	3802
+24247.9	3802
+24258.6	3802
+24269.2	3802
+24279.9	3802
+24290.6	3802
+24301.2	3802
+24311.9	3802
+24322.6	3802
+24333.2	3802
+24343.9	3802
+24354.5	3802
+24365.2	3802
+24375.9	3802
+24386.5	3802
+24397.2	3802
+24407.9	3802
+24418.5	3802
+24429.2	3802
+24439.8	3802
+24450.5	3802
+24461.2	3802
+24471.8	3802
+24482.5	3802
+24493.2	3802
+24503.8	3802
+24514.5	3802
+24525.2	3802
+24535.8	3802
+24546.5	3802
+24557.1	3802
+24567.8	3802
+24578.5	3802
+24589.1	3802
+24599.8	3802
+24610.5	3802
+24621.1	3802
+24631.8	3802
+24642.4	3802
+24653.1	3802
+24663.8	3802
+24674.4	3802
+24685.1	3802
+24695.8	3802
+24706.4	3802
+24717.1	3802
+24727.8	3802
+24738.4	3802
+24749.1	3802
+24759.7	3802
+24770.4	3802
+24781.1	3802
+24791.7	3802
+24802.4	3802
+24813.1	3802
+24823.7	3802
+24834.4	3802
+24845	3802
+24855.7	3802
+24866.4	3802
+24877	3802
+24887.7	3802
+24898.4	3802
+24909	3802
+24919.7	3802
+24930.4	3802
+24941	3802
+24951.7	3802
+24962.3	3802
+24973	3803
+24983.7	3804
+24994.3	3805
+25005	3806
+25015.7	3808
+25026.3	3808
+25037	3809
+25047.6	3810
+25058.3	3811
+25069	3812
+25079.6	3813
+25090.3	3814
+25101	3815
+25111.6	3816
+25122.3	3817
+25133	3817
+25143.6	3819
+25154.3	3820
+25164.9	3821
+25175.6	3822
+25186.3	3823
+25196.9	3824
+25207.6	3825
+25218.3	3826
+25228.9	3827
+25239.6	3828
+25250.2	3829
+25260.9	3830
+25271.6	3831
+25282.2	3832
+25292.9	3833
+25303.6	3834
+25314.2	3835
+25324.9	3836
+25335.5	3837
+25346.2	3838
+25356.9	3839
+25367.5	3840
+25378.2	3841
+25388.9	3842
+25399.5	3843
+25410.2	3845
+25420.9	3846
+25431.5	3847
+25442.2	3847
+25452.8	3848
+25463.5	3849
+25474.2	3851
+25484.8	3852
+25495.5	3853
+25506.2	3854
+25516.8	3855
+25527.5	3857
+25538.1	3859
+25548.8	3861
+25559.5	3862
+25570.1	3863
+25580.8	3864
+25591.5	3865
+25602.1	3866
+25612.8	3868
+25623.5	3869
+25634.1	3870
+25644.8	3871
+25655.4	3872
+25666.1	3874
+25676.8	3875
+25687.4	3876
+25698.1	3877
+25708.8	3878
+25719.4	3879
+25730.1	3880
+25740.7	3881
+25751.4	3882
+25762.1	3883
+25772.7	3884
+25783.4	3885
+25794.1	3886
+25804.7	3887
+25815.4	3888
+25826.1	3889
+25836.7	3890
+25847.4	3891
+25858	3892
+25868.7	3893
+25879.4	3894
+25890	3895
+25900.7	3896
+25911.4	3897
+25922	3898
+25932.7	3899
+25943.3	3900
+25954	3900
+25964.7	3901
+25975.3	3902
+25986	3903
+25996.7	3905
+26007.3	3906
+26018	3906
+26028.7	3907
+26039.3	3908
+26050	3909
+26060.6	3911
+26071.3	3912
+26082	3912
+26092.6	3913
+26103.3	3914
+26114	3915
+26124.6	3917
+26135.3	3919
+26145.9	3920
+26156.6	3922
+26167.3	3923
+26177.9	3923
+26188.6	3924
+26199.3	3925
+26209.9	3926
+26220.6	3928
+26231.3	3929
+26241.9	3930
+26252.6	3931
+26263.2	3932
+26273.9	3932
+26284.6	3934
+26295.2	3935
+26305.9	3936
+26316.6	3937
+26327.2	3938
+26337.9	3939
+26348.5	3940
+26359.2	3941
+26369.9	3942
+26380.5	3943
+26391.2	3944
+26401.9	3945
+26412.5	3946
+26423.2	3947
+26433.8	3948
+26444.5	3949
+26455.2	3950
+26465.8	3951
+26476.5	3952
+26487.2	3953
+26497.8	3954
+26508.5	3955
+26519.2	3956
+26529.8	3957
+26540.5	3958
+26551.1	3959
+26561.8	3960
+26572.5	3961
+26583.1	3962
+26593.8	3963
+26604.5	3965
+26615.1	3965
+26625.8	3965
+26636.4	3965
+26647.1	3965
+26657.8	3965
+26668.4	3965
+26679.1	3965
+26689.8	3965
+26700.4	3965
+26711.1	3965
+26721.8	3965
+26732.4	3965
+26743.1	3965
+26753.7	3965
+26764.4	3965
+26775.1	3965
+26785.7	3965
+26796.4	3965
+26807.1	3965
+26817.7	3965
+26828.4	3965
+26839	3965
+26849.7	3965
+26860.4	3965
+26871	3965
+26881.7	3965
+26892.4	3965
+26903	3965
+26913.7	3965
+26924.4	3965
+26935	3965
+26945.7	3965
+26956.3	3965
+26967	3965
+26977.7	3965
+26988.3	3965
+26999	3965
+27009.7	3965
+27020.3	3965
+27031	3965
+27041.6	3965
+27052.3	3965
+27063	3965
+27073.6	3965
+27084.3	3965
+27095	3965
+27105.6	3965
+27116.3	3965
+27127	3965
+27137.6	3965
+27148.3	3965
+27158.9	3965
+27169.6	3967
+27180.3	3968
+27190.9	3969
+27201.6	3970
+27212.3	3971
+27222.9	3973
+27233.6	3975
+27244.2	3977
+27254.9	3978
+27265.6	3979
+27276.2	3979
+27286.9	3980
+27297.6	3981
+27308.2	3982
+27318.9	3983
+27329.6	3983
+27340.2	3983
+27350.9	3983
+27361.5	3983
+27372.2	3983
+27382.9	3984
+27393.5	3985
+27404.2	3985
+27414.9	3985
+27425.5	3986
+27436.2	3987
+27446.8	3987
+27457.5	3987
+27468.2	3987
+27478.8	3987
+27489.5	3987
+27500.2	3987
+27510.8	3987
+27521.5	3987
+27532.2	3987
+27542.8	3987
+27553.5	3987
+27564.1	3987
+27574.8	3987
+27585.5	3987
+27596.1	3987
+27606.8	3987
+27617.5	3987
+27628.1	3987
+27638.8	3987
+27649.4	3987
+27660.1	3987
+27670.8	3987
+27681.4	3987
+27692.1	3987
+27702.8	3987
+27713.4	3987
+27724.1	3987
+27734.7	3987
+27745.4	3987
+27756.1	3987
+27766.7	3987
+27777.4	3987
+27788.1	3987
+27798.7	3987
+27809.4	3987
+27820.1	3987
+27830.7	3987
+27841.4	3987
+27852	3987
+27862.7	3987
+27873.4	3987
+27884	3987
+27894.7	3987
+27905.4	3987
+27916	3987
+27926.7	3987
+27937.3	3987
+27948	3987
+27958.7	3987
+27969.3	3987
+27980	3987
+27990.7	3991
+28001.3	3991
+28012	3994
+28022.7	3997
+28033.3	4000
+28044	4003
+28054.6	4006
+28065.3	4006
+28076	4008
+28086.6	4009
+28097.3	4011
+28108	4012
+28118.6	4014
+28129.3	4014
+28139.9	4014
+28150.6	4016
+28161.3	4017
+28171.9	4018
+28182.6	4019
+28193.3	4019
+28203.9	4021
+28214.6	4022
+28225.3	4024
+28235.9	4025
+28246.6	4027
+28257.2	4028
+28267.9	4029
+28278.6	4032
+28289.2	4036
+28299.9	4036
+28310.6	4039
+28321.2	4041
+28331.9	4042
+28342.5	4045
+28353.2	4046
+28363.9	4047
+28374.5	4047
+28385.2	4048
+28395.9	4050
+28406.5	4051
+28417.2	4052
+28427.9	4053
+28438.5	4055
+28449.2	4057
+28459.8	4058
+28470.5	4060
+28481.2	4060
+28491.8	4063
+28502.5	4063
+28513.2	4066
+28523.8	4066
+28534.5	4067
+28545.1	4069
+28555.8	4070
+28566.5	4072
+28577.1	4072
+28587.8	4075
+28598.5	4075
+28609.1	4079
+28619.8	4083
+28630.5	4084
+28641.1	4084
+28651.8	4087
+28662.4	4087
+28673.1	4090
+28683.8	4093
+28694.4	4095
+28705.1	4096
+28715.8	4096
+28726.4	4097
+28737.1	4099
+28747.7	4099
+28758.4	4102
+28769.1	4102
+28779.7	4103
+28790.4	4104
+28801.1	4106
+28811.7	4107
+28822.4	4108
+28833	4111
+28843.7	4112
+28854.4	4113
+28865	4116
+28875.7	4117
+28886.4	4118
+28897	4120
+28907.7	4121
+28918.4	4122
+28929	4123
+28939.7	4125
+28950.3	4127
+28961	4128
+28971.7	4129
+28982.3	4131
+28993	4131
+29003.7	4132
+29014.3	4134
+29025	4137
+29035.6	4138
+29046.3	4139
+29057	4140
+29067.6	4142
+29078.3	4145
+29089	4148
+29099.6	4150
+29110.3	4151
+29121	4153
+29131.6	4154
+29142.3	4155
+29152.9	4156
+29163.6	4158
+29174.3	4159
+29184.9	4161
+29195.6	4162
+29206.3	4163
+29216.9	4165
+29227.6	4166
+29238.2	4169
+29248.9	4169
+29259.6	4172
+29270.2	4173
+29280.9	4175
+29291.6	4178
+29302.2	4178
+29312.9	4181
+29323.6	4181
+29334.2	4182
+29344.9	4184
+29355.5	4185
+29366.2	4187
+29376.9	4189
+29387.5	4191
+29398.2	4191
+29408.9	4194
+29419.5	4197
+29430.2	4200
+29440.8	4204
+29451.5	4204
+29462.2	4204
+29472.8	4204
+29483.5	4204
+29494.2	4206
+29504.8	4208
+29515.5	4208
+29526.2	4209
+29536.8	4210
+29547.5	4211
+29558.1	4212
+29568.8	4213
+29579.5	4213
+29590.1	4214
+29600.8	4215
+29611.5	4215
+29622.1	4216
+29632.8	4217
+29643.4	4217
+29654.1	4219
+29664.8	4220
+29675.4	4221
+29686.1	4222
+29696.8	4223
+29707.4	4224
+29718.1	4225
+29728.8	4226
+29739.4	4226
+29750.1	4227
+29760.7	4228
+29771.4	4229
+29782.1	4230
+29792.7	4230
+29803.4	4231
+29814.1	4232
+29824.7	4232
+29835.4	4233
+29846	4236
+29856.7	4239
+29867.4	4239
+29878	4242
+29888.7	4242
+29899.4	4243
+29910	4245
+29920.7	4246
+29931.3	4248
+29942	4250
+29952.7	4252
+29963.3	4253
+29974	4254
+29984.7	4256
+29995.3	4258
+30006	4261
+30016.7	4264
+30027.3	4266
+30038	4267
+30048.6	4268
+30059.3	4270
+30070	4271
+30080.6	4274
+30091.3	4275
+30102	4275
+30112.6	4277
+30123.3	4278
+30133.9	4279
+30144.6	4281
+30155.3	4281
+30165.9	4282
+30176.6	4284
+30187.3	4284
+30197.9	4287
+30208.6	4287
+30219.3	4288
+30229.9	4290
+30240.6	4290
+30251.2	4292
+30261.9	4293
+30272.6	4296
+30283.2	4299
+30293.9	4299
+30304.6	4302
+30315.2	4302
+30325.9	4307
+30336.5	4307
+30347.2	4310
+30357.9	4312
+30368.5	4316
+30379.2	4317
+30389.9	4320
+30400.5	4322
+30411.2	4322
+30421.9	4323
+30432.5	4325
+30443.2	4326
+30453.8	4328
+30464.5	4329
+30475.2	4331
+30485.8	4332
+30496.5	4332
+30507.2	4333
+30517.8	4335
+30528.5	4336
+30539.1	4337
+30549.8	4340
+30560.5	4341
+30571.1	4342
+30581.8	4343
+30592.5	4346
+30603.1	4347
+30613.8	4349
+30624.5	4351
+30635.1	4353
+30645.8	4356
+30656.4	4356
+30667.1	4359
+30677.8	4359
+30688.4	4361
+30699.1	4362
+30709.8	4365
+30720.4	4368
+30731.1	4371
+30741.7	4372
+30752.4	4375
+30763.1	4377
+30773.7	4378
+30784.4	4379
+30795.1	4381
+30805.7	4381
+30816.4	4384
+30827.1	4385
+30837.7	4386
+30848.4	4388
+30859	4389
+30869.7	4390
+30880.4	4393
+30891	4394
+30901.7	4394
+30912.4	4395
+30923	4397
+30933.7	4399
+30944.3	4400
+30955	4401
+30965.7	4402
+30976.3	4403
+30987	4404
+30997.7	4406
+31008.3	4407
+31019	4409
+31029.7	4409
+31040.3	4409
+31051	4409
+31061.6	4409
+31072.3	4409
+31083	4409
+31093.6	4409
+31104.3	4409
+31115	4409
+31125.6	4409
+31136.3	4409
+31146.9	4409
+31157.6	4409
+31168.3	4409
+31178.9	4409
+31189.6	4409
+31200.3	4409
+31210.9	4409
+31221.6	4409
+31232.2	4409
+31242.9	4409
+31253.6	4409
+31264.2	4409
+31274.9	4409
+31285.6	4409
+31296.2	4409
+31306.9	4409
+31317.6	4409
+31328.2	4409
+31338.9	4409
+31349.5	4409
+31360.2	4409
+31370.9	4409
+31381.5	4409
+31392.2	4409
+31402.9	4409
+31413.5	4410
+31424.2	4410
+31434.8	4410
+31445.5	4411
+31456.2	4411
+31466.8	4412
+31477.5	4412
+31488.2	4413
+31498.8	4414
+31509.5	4414
+31520.2	4415
+31530.8	4415
+31541.5	4416
+31552.1	4417
+31562.8	4418
+31573.5	4419
+31584.1	4419
+31594.8	4420
+31605.5	4421
+31616.1	4422
+31626.8	4426
+31637.4	4429
+31648.1	4429
+31658.8	4429
+31669.4	4429
+31680.1	4429
+31690.8	4429
+31701.4	4429
+31712.1	4429
+31722.8	4429
+31733.4	4429
+31744.1	4429
+31754.7	4429
+31765.4	4429
+31776.1	4429
+31786.7	4429
+31797.4	4429
+31808.1	4429
+31818.7	4429
+31829.4	4429
+31840	4429
+31850.7	4429
+31861.4	4429
+31872	4429
+31882.7	4429
+31893.4	4429
+31904	4429
+31914.7	4429
+31925.4	4429
+31936	4429
+31946.7	4429
+31957.3	4429
+31968	4429
+31978.7	4430
+31989.3	4430
+32000	4430
+32010.7	4430
+32021.3	4432
+32032	4433
+32042.6	4434
+32053.3	4434
+32064	4435
+32074.6	4436
+32085.3	4438
+32096	4439
+32106.6	4439
+32117.3	4440
+32128	4441
+32138.6	4441
+32149.3	4442
+32159.9	4443
+32170.6	4444
+32181.3	4445
+32191.9	4445
+32202.6	4446
+32213.3	4446
+32223.9	4447
+32234.6	4448
+32245.2	4449
+32255.9	4449
+32266.6	4450
+32277.2	4451
+32287.9	4452
+32298.6	4453
+32309.2	4454
+32319.9	4455
+32330.5	4456
+32341.2	4457
+32351.9	4458
+32362.5	4458
+32373.2	4459
+32383.9	4459
+32394.5	4460
+32405.2	4460
+32415.9	4460
+32426.5	4461
+32437.2	4461
+32447.8	4462
+32458.5	4462
+32469.2	4463
+32479.8	4464
+32490.5	4465
+32501.2	4465
+32511.8	4466
+32522.5	4466
+32533.1	4466
+32543.8	4468
+32554.5	4468
+32565.1	4468
+32575.8	4468
+32586.5	4468
+32597.1	4468
+32607.8	4468
+32618.5	4468
+32629.1	4468
+32639.8	4468
+32650.4	4468
+32661.1	4468
+32671.8	4468
+32682.4	4468
+32693.1	4468
+32703.8	4468
+32714.4	4468
+32725.1	4468
+32735.7	4468
+32746.4	4468
+32757.1	4468
+32767.7	4468
+32778.4	4468
+32789.1	4468
+32799.7	4468
+32810.4	4468
+32821.1	4468
+32831.7	4468
+32842.4	4468
+32853	4468
+32863.7	4468
+32874.4	4468
+32885	4468
+32895.7	4468
+32906.4	4468
+32917	4468
+32927.7	4468
+32938.3	4468
+32949	4468
+32959.7	4468
+32970.3	4468
+32981	4468
+32991.7	4468
+33002.3	4468
+33013	4468
+33023.7	4468
+33034.3	4468
+33045	4468
+33055.6	4468
+33066.3	4468
+33077	4468
+33087.6	4468
+33098.3	4468
+33109	4468
+33119.6	4468
+33130.3	4468
+33140.9	4468
+33151.6	4468
+33162.3	4468
+33172.9	4468
+33183.6	4468
+33194.3	4468
+33204.9	4468
+33215.6	4468
+33226.3	4468
+33236.9	4468
+33247.6	4468
+33258.2	4468
+33268.9	4468
+33279.6	4468
+33290.2	4468
+33300.9	4468
+33311.6	4468
+33322.2	4468
+33332.9	4468
+33343.5	4468
+33354.2	4468
+33364.9	4468
+33375.5	4468
+33386.2	4468
+33396.9	4468
+33407.5	4468
+33418.2	4468
+33428.8	4468
+33439.5	4468
+33450.2	4468
+33460.8	4468
+33471.5	4468
+33482.2	4468
+33492.8	4468
+33503.5	4468
+33514.2	4468
+33524.8	4468
+33535.5	4468
+33546.1	4468
+33556.8	4468
+33567.5	4468
+33578.1	4468
+33588.8	4468
+33599.5	4468
+33610.1	4468
+33620.8	4468
+33631.4	4468
+33642.1	4468
+33652.8	4468
+33663.4	4468
+33674.1	4468
+33684.8	4468
+33695.4	4468
+33706.1	4468
+33716.8	4468
+33727.4	4468
+33738.1	4468
+33748.7	4468
+33759.4	4468
+33770.1	4468
+33780.7	4468
+33791.4	4468
+33802.1	4468
+33812.7	4468
+33823.4	4468
+33834	4468
+33844.7	4468
+33855.4	4468
+33866	4468
+33876.7	4468
+33887.4	4468
+33898	4468
+33908.7	4468
+33919.4	4468
+33930	4468
+33940.7	4468
+33951.3	4468
+33962	4468
+33972.7	4468
+33983.3	4468
+33994	4468
+34004.7	4468
+34015.3	4468
+34026	4468
+34036.6	4468
+34047.3	4468
+34058	4468
+34068.6	4468
+34079.3	4468
+34090	4468
+34100.6	4468
+34111.3	4468
+34122	4468
+34132.6	4468
+34143.3	4468
+34153.9	4468
+34164.6	4468
+34175.3	4468
+34185.9	4468
+34196.6	4468
+34207.3	4468
+34217.9	4468
+34228.6	4468
+34239.2	4468
+34249.9	4468
+34260.6	4468
+34271.2	4468
+34281.9	4468
+34292.6	4468
+34303.2	4468
+34313.9	4468
+34324.6	4468
+34335.2	4468
+34345.9	4468
+34356.5	4468
+34367.2	4468
+34377.9	4468
+34388.5	4468
+34399.2	4468
+34409.9	4468
+34420.5	4468
+34431.2	4468
+34441.8	4468
+34452.5	4468
+34463.2	4468
+34473.8	4468
+34484.5	4468
+34495.2	4468
+34505.8	4468
+34516.5	4468
+34527.2	4468
+34537.8	4468
+34548.5	4468
+34559.1	4468
+34569.8	4468
+34580.5	4468
+34591.1	4468
+34601.8	4468
+34612.5	4468
+34623.1	4468
+34633.8	4468
+34644.4	4468
+34655.1	4468
+34665.8	4468
+34676.4	4468
+34687.1	4468
+34697.8	4468
+34708.4	4468
+34719.1	4468
+34729.7	4468
+34740.4	4468
+34751.1	4468
+34761.7	4468
+34772.4	4468
+34783.1	4468
+34793.7	4468
+34804.4	4468
+34815.1	4468
+34825.7	4468
+34836.4	4468
+34847	4468
+34857.7	4468
+34868.4	4468
+34879	4468
+34889.7	4468
+34900.4	4468
+34911	4468
+34921.7	4468
+34932.3	4468
+34943	4468
+34953.7	4468
+34964.3	4468
+34975	4468
+34985.7	4468
+34996.3	4468
+35007	4468
+35017.7	4468
+35028.3	4468
+35039	4468
+35049.6	4468
+35060.3	4468
+35071	4468
+35081.6	4468
+35092.3	4468
+35103	4468
+35113.6	4468
+35124.3	4468
+35134.9	4469
+35145.6	4471
+35156.3	4480
+35166.9	4481
+35177.6	4483
+35188.3	4484
+35198.9	4490
+35209.6	4490
+35220.3	4492
+35230.9	4495
+35241.6	4497
+35252.2	4499
+35262.9	4501
+35273.6	4502
+35284.2	4505
+35294.9	4507
+35305.6	4509
+35316.2	4513
+35326.9	4514
+35337.5	4515
+35348.2	4521
+35358.9	4522
+35369.5	4522
+35380.2	4529
+35390.9	4533
+35401.5	4535
+35412.2	4539
+35422.9	4541
+35433.5	4541
+35444.2	4545
+35454.8	4546
+35465.5	4549
+35476.2	4551
+35486.8	4552
+35497.5	4555
+35508.2	4557
+35518.8	4560
+35529.5	4561
+35540.1	4563
+35550.8	4565
+35561.5	4566
+35572.1	4570
+35582.8	4572
+35593.5	4574
+35604.1	4575
+35614.8	4576
+35625.5	4577
+35636.1	4578
+35646.8	4579
+35657.4	4579
+35668.1	4580
+35678.8	4581
+35689.4	4582
+35700.1	4583
+35710.8	4584
+35721.4	4586
+35732.1	4588
+35742.7	4589
+35753.4	4590
+35764.1	4591
+35774.7	4591
+35785.4	4592
+35796.1	4593
+35806.7	4594
+35817.4	4595
+35828	4596
+35838.7	4597
+35849.4	4598
+35860	4600
+35870.7	4602
+35881.4	4604
+35892	4605
+35902.7	4607
+35913.4	4608
+35924	4612
+35934.7	4615
+35945.3	4618
+35956	4620
+35966.7	4621
+35977.3	4624
+35988	4626
+35998.7	4627
+36009.3	4633
+36020	4634
+36030.6	4635
+36041.3	4639
+36052	4644
+36062.6	4644
+36073.3	4648
+36084	4651
+36094.6	4652
+36105.3	4658
+36116	4658
+36126.6	4660
+36137.3	4666
+36147.9	4667
+36158.6	4667
+36169.3	4672
+36179.9	4674
+36190.6	4679
+36201.3	4680
+36211.9	4685
+36222.6	4686
+36233.2	4692
+36243.9	4693
+36254.6	4695
+36265.2	4698
+36275.9	4702
+36286.6	4704
+36297.2	4706
+36307.9	4709
+36318.6	4710
+36329.2	4712
+36339.9	4716
+36350.5	4720
+36361.2	4722
+36371.9	4723
+36382.5	4727
+36393.2	4728
+36403.9	4730
+36414.5	4733
+36425.2	4733
+36435.8	4737
+36446.5	4739
+36457.2	4741
+36467.8	4742
+36478.5	4745
+36489.2	4749
+36499.8	4750
+36510.5	4752
+36521.2	4755
+36531.8	4761
+36542.5	4761
+36553.1	4764
+36563.8	4764
+36574.5	4765
+36585.1	4769
+36595.8	4769
+36606.5	4771
+36617.1	4775
+36627.8	4775
+36638.4	4778
+36649.1	4780
+36659.8	4784
+36670.4	4786
+36681.1	4788
+36691.8	4792
+36702.4	4795
+36713.1	4798
+36723.8	4801
+36734.4	4801
+36745.1	4803
+36755.7	4808
+36766.4	4811
+36777.1	4813
+36787.7	4817
+36798.4	4819
+36809.1	4822
+36819.7	4824
+36830.4	4828
+36841	4830
+36851.7	4834
+36862.4	4836
+36873	4838
+36883.7	4839
+36894.4	4844
+36905	4847
+36915.7	4848
+36926.3	4850
+36937	4853
+36947.7	4854
+36958.3	4856
+36969	4859
+36979.7	4862
+36990.3	4864
+37001	4868
+37011.7	4870
+37022.3	4872
+37033	4875
+37043.6	4879
+37054.3	4880
+37065	4882
+37075.6	4885
+37086.3	4887
+37097	4889
+37107.6	4893
+37118.3	4896
+37128.9	4898
+37139.6	4902
+37150.3	4903
+37160.9	4903
+37171.6	4906
+37182.3	4909
+37192.9	4910
+37203.6	4914
+37214.3	4918
+37224.9	4921
+37235.6	4923
+37246.2	4924
+37256.9	4928
+37267.6	4930
+37278.2	4933
+37288.9	4936
+37299.6	4939
+37310.2	4940
+37320.9	4943
+37331.5	4947
+37342.2	4947
+37352.9	4949
+37363.5	4953
+37374.2	4955
+37384.9	4955
+37395.5	4960
+37406.2	4961
+37416.9	4964
+37427.5	4968
+37438.2	4969
+37448.8	4973
+37459.5	4975
+37470.2	4978
+37480.8	4981
+37491.5	4983
+37502.2	4986
+37512.8	4988
+37523.5	4989
+37534.1	4993
+37544.8	4995
+37555.5	4998
+37566.1	5000
+37576.8	5001
+37587.5	5003
+37598.1	5006
+37608.8	5007
+37619.5	5011
+37630.1	5013
+37640.8	5018
+37651.4	5020
+37662.1	5022
+37672.8	5025
+37683.4	5026
+37694.1	5028
+37704.8	5031
+37715.4	5031
+37726.1	5032
+37736.7	5036
+37747.4	5038
+37758.1	5039
+37768.7	5042
+37779.4	5044
+37790.1	5047
+37800.7	5053
+37811.4	5055
+37822.1	5056
+37832.7	5058
+37843.4	5061
+37854	5062
+37864.7	5067
+37875.4	5069
+37886	5073
+37896.7	5074
+37907.4	5078
+37918	5080
+37928.7	5081
+37939.3	5084
+37950	5086
+37960.7	5088
+37971.3	5092
+37982	5096
+37992.7	5098
+38003.3	5102
+38014	5104
+38024.7	5109
+38035.3	5112
+38046	5114
+38056.6	5116
+38067.3	5119
+38078	5123
+38088.6	5126
+38099.3	5128
+38110	5132
+38120.6	5134
+38131.3	5134
+38141.9	5139
+38152.6	5141
+38163.3	5146
+38173.9	5147
+38184.6	5149
+38195.3	5153
+38205.9	5155
+38216.6	5158
+38227.2	5163
+38237.9	5166
+38248.6	5166
+38259.2	5167
+38269.9	5169
+38280.6	5170
+38291.2	5171
+38301.9	5172
+38312.6	5173
+38323.2	5174
+38333.9	5178
+38344.5	5180
+38355.2	5182
+38365.9	5185
+38376.5	5187
+38387.2	5191
+38397.9	5193
+38408.5	5196
+38419.2	5198
+38429.8	5203
+38440.5	5205
+38451.2	5206
+38461.8	5210
+38472.5	5212
+38483.2	5213
+38493.8	5215
+38504.5	5218
+38515.2	5219
+38525.8	5222
+38536.5	5227
+38547.1	5229
+38557.8	5231
+38568.5	5234
+38579.1	5234
+38589.8	5237
+38600.5	5241
+38611.1	5244
+38621.8	5247
+38632.4	5247
+38643.1	5250
+38653.8	5252
+38664.4	5255
+38675.1	5257
+38685.8	5258
+38696.4	5262
+38707.1	5265
+38717.8	5267
+38728.4	5269
+38739.1	5273
+38749.7	5276
+38760.4	5278
+38771.1	5281
+38781.7	5282
+38792.4	5286
+38803.1	5288
+38813.7	5290
+38824.4	5292
+38835	5295
+38845.7	5297
+38856.4	5299
+38867	5303
+38877.7	5305
+38888.4	5309
+38899	5312
+38909.7	5313
+38920.4	5315
+38931	5318
+38941.7	5321
+38952.3	5323
+38963	5327
+38973.7	5329
+38984.3	5331
+38995	5332
+39005.7	5335
+39016.3	5337
+39027	5339
+39037.6	5340
+39048.3	5344
+39059	5345
+39069.6	5347
+39080.3	5351
+39091	5351
+39101.6	5352
+39112.3	5357
+39123	5359
+39133.6	5359
+39144.3	5362
+39154.9	5366
+39165.6	5371
+39176.3	5372
+39186.9	5377
+39197.6	5380
+39208.3	5381
+39218.9	5386
+39229.6	5387
+39240.2	5388
+39250.9	5391
+39261.6	5393
+39272.2	5394
+39282.9	5397
+39293.6	5399
+39304.2	5400
+39314.9	5404
+39325.5	5405
+39336.2	5406
+39346.9	5408
+39357.5	5412
+39368.2	5417
+39378.9	5419
+39389.5	5420
+39400.2	5424
+39410.9	5425
+39421.5	5426
+39432.2	5431
+39442.8	5434
+39453.5	5435
+39464.2	5436
+39474.8	5441
+39485.5	5442
+39496.2	5443
+39506.8	5447
+39517.5	5450
+39528.1	5452
+39538.8	5454
+39549.5	5455
+39560.1	5458
+39570.8	5460
+39581.5	5462
+39592.1	5465
+39602.8	5469
+39613.5	5472
+39624.1	5476
+39634.8	5477
+39645.4	5478
+39656.1	5484
+39666.8	5485
+39677.4	5488
+39688.1	5491
+39698.8	5494
+39709.4	5498
+39720.1	5500
+39730.7	5504
+39741.4	5506
+39752.1	5509
+39762.7	5511
+39773.4	5513
+39784.1	5517
+39794.7	5518
+39805.4	5519
+39816.1	5525
+39826.7	5527
+39837.4	5529
+39848	5533
+39858.7	5534
+39869.4	5535
+39880	5539
+39890.7	5542
+39901.4	5544
+39912	5545
+39922.7	5548
+39933.3	5552
+39944	5552
+39954.7	5555
+39965.3	5559
+39976	5562
+39986.7	5563
+39997.3	5568
+40008	5569
+40018.7	5570
+40029.3	5576
+40040	5578
+40050.6	5579
+40061.3	5582
+40072	5585
+40082.6	5587
+40093.3	5593
+40104	5593
+40114.6	5598
+40125.3	5600
+40135.9	5601
+40146.6	5605
+40157.3	5608
+40167.9	5608
+40178.6	5611
+40189.3	5614
+40199.9	5615
+40210.6	5620
+40221.3	5623
+40231.9	5623
+40242.6	5625
+40253.2	5630
+40263.9	5632
+40274.6	5634
+40285.2	5638
+40295.9	5638
+40306.6	5640
+40317.2	5645
+40327.9	5645
+40338.5	5647
+40349.2	5651
+40359.9	5655
+40370.5	5658
+40381.2	5661
+40391.9	5662
+40402.5	5664
+40413.2	5668
+40423.9	5669
+40434.5	5673
+40445.2	5675
+40455.8	5677
+40466.5	5681
+40477.2	5683
+40487.8	5685
+40498.5	5690
+40509.2	5690
+40519.8	5693
+40530.5	5697
+40541.1	5697
+40551.8	5699
+40562.5	5704
+40573.1	5705
+40583.8	5710
+40594.5	5711
+40605.1	5712
+40615.8	5715
+40626.4	5719
+40637.1	5723
+40647.8	5727
+40658.4	5729
+40669.1	5733
+40679.8	5734
+40690.4	5736
+40701.1	5739
+40711.8	5740
+40722.4	5743
+40733.1	5747
+40743.7	5749
+40754.4	5752
+40765.1	5753
+40775.7	5756
+40786.4	5758
+40797.1	5761
+40807.7	5764
+40818.4	5765
+40829	5768
+40839.7	5768
+40850.4	5775
+40861	5779
+40871.7	5781
+40882.4	5782
+40893	5786
+40903.7	5788
+40914.4	5788
+40925	5793
+40935.7	5796
+40946.3	5797
+40957	5801
+40967.7	5802
+40978.3	5803
+40989	5805
+40999.7	5810
+41010.3	5810
+41021	5812
+41031.6	5817
+41042.3	5817
+41053	5819
+41063.6	5822
+41074.3	5824
+41085	5825
+41095.6	5828
+41106.3	5829
+41117	5832
+41127.6	5835
+41138.3	5837
+41148.9	5840
+41159.6	5843
+41170.3	5844
+41180.9	5847
+41191.6	5849
+41202.3	5853
+41212.9	5856
+41223.6	5860
+41234.2	5865
+41244.9	5866
+41255.6	5870
+41266.2	5872
+41276.9	5875
+41287.6	5879
+41298.2	5880
+41308.9	5883
+41319.6	5886
+41330.2	5891
+41340.9	5892
+41351.5	5898
+41362.2	5898
+41372.9	5903
+41383.5	5904
+41394.2	5907
+41404.9	5909
+41415.5	5911
+41426.2	5915
+41436.8	5917
+41447.5	5923
+41458.2	5925
+41468.8	5928
+41479.5	5931
+41490.2	5933
+41500.8	5938
+41511.5	5940
+41522.2	5942
+41532.8	5945
+41543.5	5947
+41554.1	5948
+41564.8	5955
+41575.5	5960
+41586.1	5962
+41596.8	5968
+41607.5	5970
+41618.1	5974
+41628.8	5977
+41639.4	5981
+41650.1	5983
+41660.8	5988
+41671.4	5990
+41682.1	5992
+41692.8	5995
+41703.4	5998
+41714.1	6000
+41724.7	6005
+41735.4	6006
+41746.1	6008
+41756.7	6009
+41767.4	6010
+41778.1	6012
+41788.7	6014
+41799.4	6017
+41810.1	6018
+41820.7	6020
+41831.4	6024
+41842	6026
+41852.7	6029
+41863.4	6031
+41874	6034
+41884.7	6037
+41895.4	6039
+41906	6041
+41916.7	6045
+41927.3	6045
+41938	6048
+41948.7	6052
+41959.3	6055
+41970	6058
+41980.7	6059
+41991.3	6062
+42002	6065
+42012.7	6068
+42023.3	6073
+42034	6075
+42044.6	6077
+42055.3	6080
+42066	6081
+42076.6	6084
+42087.3	6086
+42098	6087
+42108.6	6089
+42119.3	6093
+42129.9	6096
+42140.6	6097
+42151.3	6099
+42161.9	6103
+42172.6	6105
+42183.3	6106
+42193.9	6111
+42204.6	6113
+42215.3	6117
+42225.9	6119
+42236.6	6124
+42247.2	6126
+42257.9	6130
+42268.6	6132
+42279.2	6135
+42289.9	6136
+42300.6	6141
+42311.2	6143
+42321.9	6147
+42332.5	6151
+42343.2	6154
+42353.9	6156
+42364.5	6160
+42375.2	6162
+42385.9	6165
+42396.5	6168
+42407.2	6171
+42417.9	6171
+42428.5	6175
+42439.2	6178
+42449.8	6178
+42460.5	6182
+42471.2	6185
+42481.8	6188
+42492.5	6191
+42503.2	6193
+42513.8	6197
+42524.5	6200
+42535.1	6204
+42545.8	6205
+42556.5	6207
+42567.1	6214
+42577.8	6216
+42588.5	6216
+42599.1	6220
+42609.8	6222
+42620.5	6226
+42631.1	6228
+42641.8	6231
+42652.4	6234
+42663.1	6235
+42673.8	6236
+42684.4	6243
+42695.1	6244
+42705.8	6249
+42716.4	6250
+42727.1	6254
+42737.7	6256
+42748.4	6260
+42759.1	6264
+42769.7	6267
+42780.4	6270
+42791.1	6271
+42801.7	6275
+42812.4	6276
+42823	6278
+42833.7	6282
+42844.4	6282
+42855	6284
+42865.7	6288
+42876.4	6291
+42887	6295
+42897.7	6300
+42908.4	6301
+42919	6304
+42929.7	6306
+42940.3	6307
+42951	6310
+42961.7	6313
+42972.3	6317
+42983	6319
+42993.7	6323
+43004.3	6328
+43015	6331
+43025.6	6334
+43036.3	6336
+43047	6336
+43057.6	6339
+43068.3	6341
+43079	6341
+43089.6	6342
+43100.3	6344
+43111	6349
+43121.6	6352
+43132.3	6352
+43142.9	6355
+43153.6	6359
+43164.3	6360
+43174.9	6360
+43185.6	6367
+43196.3	6369
+43206.9	6374
+43217.6	6376
+43228.2	6376
+43238.9	6381
+43249.6	6383
+43260.2	6385
+43270.9	6388
+43281.6	6390
+43292.2	6394
+43302.9	6395
+43313.6	6398
+43324.2	6400
+43334.9	6402
+43345.5	6404
+43356.2	6408
+43366.9	6411
+43377.5	6414
+43388.2	6416
+43398.9	6419
+43409.5	6420
+43420.2	6425
+43430.8	6429
+43441.5	6431
+43452.2	6435
+43462.8	6437
+43473.5	6437
+43484.2	6438
+43494.8	6443
+43505.5	6443
+43516.2	6444
+43526.8	6448
+43537.5	6448
+43548.1	6454
+43558.8	6455
+43569.5	6456
+43580.1	6458
+43590.8	6461
+43601.5	6463
+43612.1	6467
+43622.8	6469
+43633.4	6472
+43644.1	6477
+43654.8	6477
+43665.4	6480
+43676.1	6484
+43686.8	6487
+43697.4	6490
+43708.1	6493
+43718.8	6497
+43729.4	6500
+43740.1	6503
+43750.7	6504
+43761.4	6507
+43772.1	6509
+43782.7	6512
+43793.4	6516
+43804.1	6518
+43814.7	6519
+43825.4	6524
+43836	6530
+43846.7	6530
+43857.4	6534
+43868	6536
+43878.7	6541
+43889.4	6546
+43900	6550
+43910.7	6551
+43921.4	6555
+43932	6556
+43942.7	6559
+43953.3	6561
+43964	6562
+43974.7	6565
+43985.3	6567
+43996	6568
+44006.7	6570
+44017.3	6574
+44028	6575
+44038.6	6576
+44049.3	6581
+44060	6582
+44070.6	6582
+44081.3	6587
+44092	6591
+44102.6	6593
+44113.3	6593
+44123.9	6597
+44134.6	6602
+44145.3	6603
+44155.9	6608
+44166.6	6613
+44177.3	6615
+44187.9	6619
+44198.6	6621
+44209.3	6625
+44219.9	6627
+44230.6	6634
+44241.2	6634
+44251.9	6640
+44262.6	6641
+44273.2	6645
+44283.9	6647
+44294.6	6651
+44305.2	6655
+44315.9	6656
+44326.5	6659
+44337.2	6660
+44347.9	6662
+44358.5	6663
+44369.2	6666
+44379.9	6668
+44390.5	6671
+44401.2	6672
+44411.9	6676
+44422.5	6679
+44433.2	6683
+44443.8	6685
+44454.5	6687
+44465.2	6690
+44475.8	6693
+44486.5	6693
+44497.2	6694
+44507.8	6697
+44518.5	6699
+44529.1	6701
+44539.8	6702
+44550.5	6707
+44561.1	6709
+44571.8	6713
+44582.5	6715
+44593.1	6722
+44603.8	6723
+44614.5	6726
+44625.1	6730
+44635.8	6734
+44646.4	6736
+44657.1	6740
+44667.8	6744
+44678.4	6745
+44689.1	6750
+44699.8	6750
+44710.4	6752
+44721.1	6757
+44731.7	6758
+44742.4	6761
+44753.1	6765
+44763.7	6766
+44774.4	6768
+44785.1	6771
+44795.7	6779
+44806.4	6780
+44817.1	6785
+44827.7	6788
+44838.4	6789
+44849	6796
+44859.7	6798
+44870.4	6803
+44881	6806
+44891.7	6808
+44902.4	6814
+44913	6817
+44923.7	6820
+44934.3	6827
+44945	6831
+44955.7	6837
+44966.3	6841
+44977	6841
+44987.7	6845
+44998.3	6850
+45009	6852
+45019.7	6854
+45030.3	6863
+45041	6865
+45051.6	6870
+45062.3	6874
+45073	6875
+45083.6	6878
+45094.3	6887
+45105	6891
+45115.6	6894
+45126.3	6896
+45136.9	6901
+45147.6	6903
+45158.3	6906
+45168.9	6908
+45179.6	6913
+45190.3	6918
+45200.9	6921
+45211.6	6926
+45222.2	6930
+45232.9	6933
+45243.6	6938
+45254.2	6941
+45264.9	6943
+45275.6	6948
+45286.2	6954
+45296.9	6955
+45307.6	6957
+45318.2	6963
+45328.9	6966
+45339.5	6968
+45350.2	6972
+45360.9	6979
+45371.5	6981
+45382.2	6983
+45392.9	6985
+45403.5	6990
+45414.2	6994
+45424.8	6996
+45435.5	7001
+45446.2	7006
+45456.8	7010
+45467.5	7011
+45478.2	7016
+45488.8	7021
+45499.5	7023
+45510.2	7027
+45520.8	7031
+45531.5	7033
+45542.1	7038
+45552.8	7040
+45563.5	7046
+45574.1	7051
+45584.8	7054
+45595.5	7058
+45606.1	7064
+45616.8	7065
+45627.4	7070
+45638.1	7076
+45648.8	7077
+45659.4	7079
+45670.1	7085
+45680.8	7090
+45691.4	7091
+45702.1	7093
+45712.8	7101
+45723.4	7104
+45734.1	7105
+45744.7	7112
+45755.4	7118
+45766.1	7118
+45776.7	7124
+45787.4	7129
+45798.1	7133
+45808.7	7139
+45819.4	7140
+45830	7142
+45840.7	7147
+45851.4	7151
+45862	7154
+45872.7	7160
+45883.4	7164
+45894	7167
+45904.7	7170
+45915.4	7174
+45926	7178
+45936.7	7181
+45947.3	7184
+45958	7187
+45968.7	7191
+45979.3	7195
+45990	7197
+46000.7	7199
+46011.3	7203
+46022	7209
+46032.6	7211
+46043.3	7213
+46054	7219
+46064.6	7220
+46075.3	7224
+46086	7230
+46096.6	7230
+46107.3	7236
+46118	7242
+46128.6	7246
+46139.3	7250
+46149.9	7255
+46160.6	7257
+46171.3	7260
+46181.9	7265
+46192.6	7267
+46203.3	7271
+46213.9	7280
+46224.6	7284
+46235.2	7291
+46245.9	7293
+46256.6	7294
+46267.2	7301
+46277.9	7305
+46288.6	7309
+46299.2	7313
+46309.9	7318
+46320.5	7322
+46331.2	7324
+46341.9	7329
+46352.5	7334
+46363.2	7337
+46373.9	7339
+46384.5	7343
+46395.2	7347
+46405.9	7349
+46416.5	7354
+46427.2	7359
+46437.8	7363
+46448.5	7369
+46459.2	7373
+46469.8	7376
+46480.5	7379
+46491.2	7385
+46501.8	7386
+46512.5	7390
+46523.1	7396
+46533.8	7402
+46544.5	7405
+46555.1	7409
+46565.8	7414
+46576.5	7417
+46587.1	7419
+46597.8	7424
+46608.5	7429
+46619.1	7430
+46629.8	7434
+46640.4	7436
+46651.1	7439
+46661.8	7443
+46672.4	7449
+46683.1	7450
+46693.8	7453
+46704.4	7459
+46715.1	7465
+46725.7	7472
+46736.4	7478
+46747.1	7478
+46757.7	7481
+46768.4	7490
+46779.1	7490
+46789.7	7492
+46800.4	7501
+46811.1	7502
+46821.7	7505
+46832.4	7508
+46843	7515
+46853.7	7516
+46864.4	7518
+46875	7523
+46885.7	7529
+46896.4	7531
+46907	7535
+46917.7	7540
+46928.3	7543
+46939	7545
+46949.7	7551
+46960.3	7554
+46971	7555
+46981.7	7564
+46992.3	7569
+47003	7570
+47013.7	7575
+47024.3	7582
+47035	7582
+47045.6	7587
+47056.3	7592
+47067	7597
+47077.6	7604
+47088.3	7608
+47099	7613
+47109.6	7623
+47120.3	7624
+47130.9	7628
+47141.6	7634
+47152.3	7638
+47162.9	7641
+47173.6	7642
+47184.3	7646
+47194.9	7650
+47205.6	7655
+47216.3	7656
+47226.9	7661
+47237.6	7667
+47248.2	7670
+47258.9	7672
+47269.6	7677
+47280.2	7679
+47290.9	7683
+47301.6	7686
+47312.2	7689
+47322.9	7694
+47333.5	7697
+47344.2	7700
+47354.9	7704
+47365.5	7709
+47376.2	7713
+47386.9	7719
+47397.5	7721
+47408.2	7724
+47418.9	7725
+47429.5	7732
+47440.2	7736
+47450.8	7740
+47461.5	7744
+47472.2	7744
+47482.8	7753
+47493.5	7763
+47504.2	7765
+47514.8	7772
+47525.5	7776
+47536.1	7778
+47546.8	7786
+47557.5	7791
+47568.1	7793
+47578.8	7800
+47589.5	7807
+47600.1	7811
+47610.8	7819
+47621.4	7824
+47632.1	7826
+47642.8	7832
+47653.4	7839
+47664.1	7842
+47674.8	7847
+47685.4	7852
+47696.1	7858
+47706.8	7858
+47717.4	7866
+47728.1	7877
+47738.7	7880
+47749.4	7885
+47760.1	7887
+47770.7	7895
+47781.4	7904
+47792.1	7906
+47802.7	7909
+47813.4	7919
+47824	7924
+47834.7	7925
+47845.4	7933
+47856	7938
+47866.7	7942
+47877.4	7950
+47888	7956
+47898.7	7959
+47909.4	7966
+47920	7970
+47930.7	7978
+47941.3	7983
+47952	7989
+47962.7	7995
+47973.3	7997
+47984	8000
+47994.7	8000
+48005.3	8006
+48016	8016
+48026.6	8020
+48037.3	8028
+48048	8030
+48058.6	8034
+48069.3	8045
+48080	8049
+48090.6	8051
+48101.3	8061
+48112	8069
+48122.6	8074
+48133.3	8078
+48143.9	8084
+48154.6	8090
+48165.3	8094
+48175.9	8103
+48186.6	8108
+48197.3	8114
+48207.9	8117
+48218.6	8125
+48229.2	8128
+48239.9	8133
+48250.6	8138
+48261.2	8148
+48271.9	8149
+48282.6	8153
+48293.2	8159
+48303.9	8164
+48314.6	8166
+48325.2	8176
+48335.9	8179
+48346.5	8186
+48357.2	8193
+48367.9	8196
+48378.5	8196
+48389.2	8205
+48399.9	8211
+48410.5	8214
+48421.2	8221
+48431.8	8226
+48442.5	8229
+48453.2	8232
+48463.8	8237
+48474.5	8244
+48485.2	8249
+48495.8	8254
+48506.5	8259
+48517.2	8265
+48527.8	8268
+48538.5	8275
+48549.1	8279
+48559.8	8284
+48570.5	8285
+48581.1	8290
+48591.8	8296
+48602.5	8302
+48613.1	8306
+48623.8	8306
+48634.4	8311
+48645.1	8318
+48655.8	8318
+48666.4	8324
+48677.1	8326
+48687.8	8338
+48698.4	8342
+48709.1	8344
+48719.7	8348
+48730.4	8356
+48741.1	8363
+48751.7	8369
+48762.4	8374
+48773.1	8380
+48783.7	8386
+48794.4	8391
+48805.1	8396
+48815.7	8404
+48826.4	8412
+48837	8415
+48847.7	8417
+48858.4	8422
+48869	8431
+48879.7	8433
+48890.4	8441
+48901	8449
+48911.7	8450
+48922.3	8454
+48933	8459
+48943.7	8462
+48954.3	8469
+48965	8475
+48975.7	8477
+48986.3	8486
+48997	8492
+49007.7	8494
+49018.3	8501
+49029	8505
+49039.6	8512
+49050.3	8517
+49061	8523
+49071.6	8528
+49082.3	8536
+49093	8540
+49103.6	8546
+49114.3	8553
+49124.9	8561
+49135.6	8564
+49146.3	8571
+49156.9	8574
+49167.6	8574
+49178.3	8578
+49188.9	8591
+49199.6	8594
+49210.3	8600
+49220.9	8602
+49231.6	8607
+49242.2	8609
+49252.9	8619
+49263.6	8627
+49274.2	8631
+49284.9	8637
+49295.6	8644
+49306.2	8650
+49316.9	8659
+49327.5	8663
+49338.2	8668
+49348.9	8677
+49359.5	8687
+49370.2	8688
+49380.9	8696
+49391.5	8702
+49402.2	8703
+49412.9	8708
+49423.5	8713
+49434.2	8721
+49444.8	8730
+49455.5	8733
+49466.2	8740
+49476.8	8745
+49487.5	8749
+49498.2	8755
+49508.8	8758
+49519.5	8763
+49530.1	8770
+49540.8	8777
+49551.5	8783
+49562.1	8788
+49572.8	8793
+49583.5	8799
+49594.1	8811
+49604.8	8814
+49615.5	8818
+49626.1	8825
+49636.8	8835
+49647.4	8839
+49658.1	8847
+49668.8	8852
+49679.4	8858
+49690.1	8867
+49700.8	8875
+49711.4	8878
+49722.1	8878
+49732.7	8888
+49743.4	8896
+49754.1	8899
+49764.7	8901
+49775.4	8904
+49786.1	8913
+49796.7	8924
+49807.4	8925
+49818	8932
+49828.7	8937
+49839.4	8943
+49850	8946
+49860.7	8952
+49871.4	8958
+49882	8964
+49892.7	8969
+49903.4	8974
+49914	8983
+49924.7	8991
+49935.3	8997
+49946	8999
+49956.7	9009
+49967.3	9019
+49978	9023
+49988.7	9028
+49999.3	9033
+50010	9043
+50020.6	9048
+50031.3	9055
+50042	9061
+50052.6	9068
+50063.3	9072
+50074	9074
+50084.6	9076
+50095.3	9085
+50106	9093
+50116.6	9099
+50127.3	9101
+50137.9	9103
+50148.6	9109
+50159.3	9122
+50169.9	9126
+50180.6	9134
+50191.3	9140
+50201.9	9146
+50212.6	9151
+50223.2	9159
+50233.9	9160
+50244.6	9170
+50255.2	9178
+50265.9	9182
+50276.6	9187
+50287.2	9190
+50297.9	9195
+50308.6	9206
+50319.2	9211
+50329.9	9218
+50340.5	9219
+50351.2	9225
+50361.9	9233
+50372.5	9235
+50383.2	9244
+50393.9	9249
+50404.5	9254
+50415.2	9258
+50425.8	9263
+50436.5	9265
+50447.2	9270
+50457.8	9279
+50468.5	9287
+50479.2	9290
+50489.8	9298
+50500.5	9302
+50511.2	9306
+50521.8	9311
+50532.5	9317
+50543.1	9323
+50553.8	9331
+50564.5	9334
+50575.1	9340
+50585.8	9344
+50596.5	9356
+50607.1	9361
+50617.8	9368
+50628.4	9377
+50639.1	9378
+50649.8	9386
+50660.4	9386
+50671.1	9390
+50681.8	9394
+50692.4	9403
+50703.1	9410
+50713.8	9413
+50724.4	9421
+50735.1	9424
+50745.7	9434
+50756.4	9441
+50767.1	9445
+50777.7	9455
+50788.4	9458
+50799.1	9462
+50809.7	9465
+50820.4	9468
+50831	9482
+50841.7	9488
+50852.4	9491
+50863	9497
+50873.7	9502
+50884.4	9513
+50895	9513
+50905.7	9517
+50916.4	9532
+50927	9533
+50937.7	9538
+50948.3	9545
+50959	9549
+50969.7	9551
+50980.3	9557
+50991	9568
+51001.7	9573
+51012.3	9580
+51023	9583
+51033.6	9591
+51044.3	9598
+51055	9606
+51065.6	9613
+51076.3	9616
+51087	9622
+51097.6	9623
+51108.3	9633
+51118.9	9641
+51129.6	9643
+51140.3	9647
+51150.9	9656
+51161.6	9664
+51172.3	9669
+51182.9	9671
+51193.6	9674
+51204.3	9676
+51214.9	9683
+51225.6	9687
+51236.2	9693
+51246.9	9699
+51257.6	9708
+51268.2	9714
+51278.9	9719
+51289.6	9720
+51300.2	9729
+51310.9	9735
+51321.5	9740
+51332.2	9749
+51342.9	9752
+51353.5	9764
+51364.2	9764
+51374.9	9768
+51385.5	9771
+51396.2	9774
+51406.9	9784
+51417.5	9790
+51428.2	9791
+51438.8	9795
+51449.5	9800
+51460.2	9814
+51470.8	9821
+51481.5	9825
+51492.2	9834
+51502.8	9840
+51513.5	9847
+51524.1	9853
+51534.8	9860
+51545.5	9864
+51556.1	9872
+51566.8	9873
+51577.5	9880
+51588.1	9887
+51598.8	9897
+51609.5	9902
+51620.1	9905
+51630.8	9909
+51641.4	9912
+51652.1	9920
+51662.8	9922
+51673.4	9922
+51684.1	9933
+51694.8	9944
+51705.4	9947
+51716.1	9953
+51726.7	9959
+51737.4	9966
+51748.1	9974
+51758.7	9980
+51769.4	9984
+51780.1	9993
+51790.7	9993
+51801.4	10002
+51812.1	10009
+51822.7	10012
+51833.4	10019
+51844	10022
+51854.7	10024
+51865.4	10030
+51876	10047
+51886.7	10053
+51897.4	10058
+51908	10062
+51918.7	10065
+51929.3	10074
+51940	10080
+51950.7	10084
+51961.3	10087
+51972	10103
+51982.7	10107
+51993.3	10109
+52004	10111
+52014.7	10124
+52025.3	10134
+52036	10137
+52046.6	10143
+52057.3	10150
+52068	10154
+52078.6	10158
+52089.3	10162
+52100	10165
+52110.6	10174
+52121.3	10181
+52131.9	10188
+52142.6	10196
+52153.3	10204
+52163.9	10209
+52174.6	10217
+52185.3	10225
+52195.9	10230
+52206.6	10237
+52217.2	10241
+52227.9	10246
+52238.6	10254
+52249.2	10261
+52259.9	10263
+52270.6	10268
+52281.2	10279
+52291.9	10284
+52302.6	10289
+52313.2	10294
+52323.9	10296
+52334.5	10311
+52345.2	10316
+52355.9	10318
+52366.5	10322
+52377.2	10331
+52387.9	10341
+52398.5	10345
+52409.2	10349
+52419.8	10353
+52430.5	10359
+52441.2	10364
+52451.8	10369
+52462.5	10379
+52473.2	10383
+52483.8	10387
+52494.5	10394
+52505.2	10396
+52515.8	10401
+52526.5	10409
+52537.1	10411
+52547.8	10416
+52558.5	10421
+52569.1	10433
+52579.8	10437
+52590.5	10442
+52601.1	10444
+52611.8	10450
+52622.4	10462
+52633.1	10465
+52643.8	10465
+52654.4	10471
+52665.1	10479
+52675.8	10488
+52686.4	10491
+52697.1	10494
+52707.8	10498
+52718.4	10515
+52729.1	10518
+52739.7	10527
+52750.4	10528
+52761.1	10534
+52771.7	10543
+52782.4	10551
+52793.1	10554
+52803.7	10558
+52814.4	10565
+52825	10574
+52835.7	10576
+52846.4	10576
+52857	10585
+52867.7	10598
+52878.4	10602
+52889	10603
+52899.7	10604
+52910.4	10613
+52921	10627
+52931.7	10630
+52942.3	10630
+52953	10631
+52963.7	10635
+52974.3	10645
+52985	10652
+52995.7	10656
+53006.3	10663
+53017	10667
+53027.6	10670
+53038.3	10674
+53049	10682
+53059.6	10697
+53070.3	10698
+53081	10701
+53091.6	10702
+53102.3	10708
+53113	10712
+53123.6	10713
+53134.3	10717
+53144.9	10730
+53155.6	10741
+53166.3	10749
+53176.9	10753
+53187.6	10759
+53198.3	10766
+53208.9	10771
+53219.6	10774
+53230.2	10780
+53240.9	10788
+53251.6	10794
+53262.2	10800
+53272.9	10808
+53283.6	10812
+53294.2	10821
+53304.9	10824
+53315.5	10830
+53326.2	10836
+53336.9	10844
+53347.5	10852
+53358.2	10860
+53368.9	10862
+53379.5	10865
+53390.2	10873
+53400.9	10881
+53411.5	10886
+53422.2	10889
+53432.8	10895
+53443.5	10902
+53454.2	10907
+53464.8	10913
+53475.5	10919
+53486.2	10927
+53496.8	10932
+53507.5	10935
+53518.1	10936
+53528.8	10941
+53539.5	10948
+53550.1	10956
+53560.8	10962
+53571.5	10969
+53582.1	10973
+53592.8	10979
+53603.5	10987
+53614.1	10989
+53624.8	10994
+53635.4	10997
+53646.1	11002
+53656.8	11009
+53667.4	11011
+53678.1	11011
+53688.8	11027
+53699.4	11035
+53710.1	11039
+53720.7	11043
+53731.4	11050
+53742.1	11054
+53752.7	11060
+53763.4	11067
+53774.1	11074
+53784.7	11078
+53795.4	11083
+53806.1	11085
+53816.7	11090
+53827.4	11096
+53838	11101
+53848.7	11108
+53859.4	11113
+53870	11115
+53880.7	11127
+53891.4	11133
+53902	11135
+53912.7	11139
+53923.3	11146
+53934	11151
+53944.7	11161
+53955.3	11162
+53966	11165
+53976.7	11170
+53987.3	11178
+53998	11181
+54008.7	11181
+54019.3	11186
+54030	11191
+54040.6	11205
+54051.3	11210
+54062	11217
+54072.6	11219
+54083.3	11227
+54094	11236
+54104.6	11239
+54115.3	11242
+54125.9	11243
+54136.6	11250
+54147.3	11263
+54157.9	11270
+54168.6	11272
+54179.3	11284
+54189.9	11289
+54200.6	11294
+54211.3	11301
+54221.9	11308
+54232.6	11315
+54243.2	11318
+54253.9	11324
+54264.6	11333
+54275.2	11341
+54285.9	11342
+54296.6	11345
+54307.2	11355
+54317.9	11359
+54328.5	11363
+54339.2	11369
+54349.9	11379
+54360.5	11385
+54371.2	11387
+54381.9	11390
+54392.5	11394
+54403.2	11398
+54413.9	11405
+54424.5	11410
+54435.2	11416
+54445.8	11420
+54456.5	11424
+54467.2	11441
+54477.8	11443
+54488.5	11449
+54499.2	11451
+54509.8	11459
+54520.5	11471
+54531.1	11476
+54541.8	11481
+54552.5	11491
+54563.1	11493
+54573.8	11498
+54584.5	11500
+54595.1	11506
+54605.8	11514
+54616.4	11523
+54627.1	11529
+54637.8	11531
+54648.4	11535
+54659.1	11548
+54669.8	11552
+54680.4	11554
+54691.1	11559
+54701.8	11570
+54712.4	11574
+54723.1	11579
+54733.7	11588
+54744.4	11592
+54755.1	11602
+54765.7	11605
+54776.4	11610
+54787.1	11617
+54797.7	11623
+54808.4	11626
+54819	11629
+54829.7	11631
+54840.4	11634
+54851	11645
+54861.7	11648
+54872.4	11651
+54883	11658
+54893.7	11661
+54904.4	11672
+54915	11676
+54925.7	11683
+54936.3	11689
+54947	11695
+54957.7	11700
+54968.3	11706
+54979	11708
+54989.7	11716
+55000.3	11724
+55011	11730
+55021.6	11734
+55032.3	11744
+55043	11745
+55053.6	11756
+55064.3	11756
+55075	11763
+55085.6	11768
+55096.3	11769
+55107	11778
+55117.6	11781
+55128.3	11782
+55138.9	11791
+55149.6	11794
+55160.3	11798
+55170.9	11799
+55181.6	11806
+55192.3	11815
+55202.9	11820
+55213.6	11828
+55224.2	11829
+55234.9	11835
+55245.6	11840
+55256.2	11844
+55266.9	11850
+55277.6	11855
+55288.2	11865
+55298.9	11868
+55309.6	11875
+55320.2	11880
+55330.9	11890
+55341.5	11892
+55352.2	11896
+55362.9	11900
+55373.5	11907
+55384.2	11911
+55394.9	11918
+55405.5	11922
+55416.2	11930
+55426.8	11941
+55437.5	11946
+55448.2	11952
+55458.8	11959
+55469.5	11968
+55480.2	11972
+55490.8	11973
+55501.5	11985
+55512.2	11988
+55522.8	11997
+55533.5	11999
+55544.1	12004
+55554.8	12011
+55565.5	12019
+55576.1	12023
+55586.8	12032
+55597.5	12035
+55608.1	12044
+55618.8	12051
+55629.4	12057
+55640.1	12062
+55650.8	12067
+55661.4	12077
+55672.1	12081
+55682.8	12086
+55693.4	12091
+55704.1	12099
+55714.7	12105
+55725.4	12108
+55736.1	12116
+55746.7	12119
+55757.4	12127
+55768.1	12133
+55778.7	12137
+55789.4	12142
+55800.1	12146
+55810.7	12151
+55821.4	12152
+55832	12160
+55842.7	12163
+55853.4	12170
+55864	12175
+55874.7	12182
+55885.4	12191
+55896	12199
+55906.7	12201
+55917.3	12204
+55928	12210
+55938.7	12222
+55949.3	12228
+55960	12231
+55970.7	12235
+55981.3	12235
+55992	12246
+56002.7	12261
+56013.3	12263
+56024	12268
+56034.6	12268
+56045.3	12278
+56056	12279
+56066.6	12282
+56077.3	12290
+56088	12297
+56098.6	12308
+56109.3	12313
+56119.9	12316
+56130.6	12323
+56141.3	12337
+56151.9	12338
+56162.6	12341
+56173.3	12351
+56183.9	12362
+56194.6	12365
+56205.3	12368
+56215.9	12371
+56226.6	12376
+56237.2	12382
+56247.9	12383
+56258.6	12386
+56269.2	12393
+56279.9	12399
+56290.6	12402
+56301.2	12409
+56311.9	12415
+56322.5	12423
+56333.2	12431
+56343.9	12436
+56354.5	12439
+56365.2	12444
+56375.9	12448
+56386.5	12458
+56397.2	12461
+56407.9	12470
+56418.5	12475
+56429.2	12478
+56439.8	12485
+56450.5	12497
+56461.2	12503
+56471.8	12507
+56482.5	12509
+56493.2	12518
+56503.8	12523
+56514.5	12529
+56525.1	12534
+56535.8	12539
+56546.5	12539
+56557.1	12541
+56567.8	12555
+56578.5	12560
+56589.1	12562
+56599.8	12565
+56610.5	12579
+56621.1	12584
+56631.8	12590
+56642.4	12596
+56653.1	12600
+56663.8	12607
+56674.4	12609
+56685.1	12615
+56695.8	12618
+56706.4	12629
+56717.1	12633
+56727.7	12639
+56738.4	12644
+56749.1	12652
+56759.7	12661
+56770.4	12661
+56781.1	12665
+56791.7	12672
+56802.4	12682
+56813.1	12687
+56823.7	12690
+56834.4	12694
+56845	12702
+56855.7	12712
+56866.4	12715
+56877	12720
+56887.7	12725
+56898.4	12734
+56909	12745
+56919.7	12749
+56930.3	12758
+56941	12763
+56951.7	12772
+56962.3	12775
+56973	12779
+56983.7	12786
+56994.3	12793
+57005	12799
+57015.6	12806
+57026.3	12813
+57037	12816
+57047.6	12816
+57058.3	12832
+57069	12840
+57079.6	12849
+57090.3	12852
+57101	12856
+57111.6	12858
+57122.3	12863
+57132.9	12867
+57143.6	12875
+57154.3	12881
+57164.9	12887
+57175.6	12893
+57186.3	12904
+57196.9	12908
+57207.6	12914
+57218.2	12916
+57228.9	12918
+57239.6	12923
+57250.2	12936
+57260.9	12938
+57271.6	12943
+57282.2	12947
+57292.9	12960
+57303.6	12966
+57314.2	12973
+57324.9	12981
+57335.5	12986
+57346.2	12995
+57356.9	12996
+57367.5	12999
+57378.2	13005
+57388.9	13013
+57399.5	13021
+57410.2	13026
+57420.8	13030
+57431.5	13032
+57442.2	13042
+57452.8	13051
+57463.5	13052
+57474.2	13060
+57484.8	13068
+57495.5	13076
+57506.2	13079
+57516.8	13084
+57527.5	13089
+57538.1	13099
+57548.8	13103
+57559.5	13105
+57570.1	13110
+57580.8	13114
+57591.5	13120
+57602.1	13125
+57612.8	13129
+57623.4	13133
+57634.1	13142
+57644.8	13147
+57655.4	13153
+57666.1	13160
+57676.8	13165
+57687.4	13170
+57698.1	13174
+57708.8	13174
+57719.4	13181
+57730.1	13193
+57740.7	13198
+57751.4	13201
+57762.1	13205
+57772.7	13217
+57783.4	13226
+57794.1	13228
+57804.7	13233
+57815.4	13236
+57826	13247
+57836.7	13252
+57847.4	13255
+57858	13256
+57868.7	13260
+57879.4	13272
+57890	13278
+57900.7	13283
+57911.4	13296
+57922	13299
+57932.7	13305
+57943.3	13307
+57954	13317
+57964.7	13320
+57975.3	13327
+57986	13330
+57996.7	13332
+58007.3	13345
+58018	13347
+58028.6	13351
+58039.3	13357
+58050	13364
+58060.6	13375
+58071.3	13379
+58082	13385
+58092.6	13388
+58103.3	13394
+58113.9	13399
+58124.6	13402
+58135.3	13406
+58145.9	13418
+58156.6	13419
+58167.3	13425
+58177.9	13428
+58188.6	13433
+58199.3	13445
+58209.9	13450
+58220.6	13455
+58231.2	13458
+58241.9	13466
+58252.6	13474
+58263.2	13479
+58273.9	13482
+58284.6	13488
+58295.2	13500
+58305.9	13503
+58316.5	13509
+58327.2	13516
+58337.9	13521
+58348.5	13532
+58359.2	13537
+58369.9	13544
+58380.5	13551
+58391.2	13555
+58401.9	13563
+58412.5	13570
+58423.2	13574
+58433.8	13581
+58444.5	13586
+58455.2	13592
+58465.8	13593
+58476.5	13597
+58487.2	13606
+58497.8	13607
+58508.5	13616
+58519.1	13619
+58529.8	13628
+58540.5	13630
+58551.1	13636
+58561.8	13643
+58572.5	13646
+58583.1	13652
+58593.8	13658
+58604.5	13666
+58615.1	13678
+58625.8	13679
+58636.4	13683
+58647.1	13684
+58657.8	13689
+58668.4	13695
+58679.1	13704
+58689.8	13710
+58700.4	13712
+58711.1	13715
+58721.7	13722
+58732.4	13729
+58743.1	13734
+58753.7	13737
+58764.4	13741
+58775.1	13742
+58785.7	13743
+58796.4	13745
+58807.1	13760
+58817.7	13765
+58828.4	13769
+58839	13774
+58849.7	13782
+58860.4	13789
+58871	13795
+58881.7	13804
+58892.4	13806
+58903	13814
+58913.7	13822
+58924.3	13827
+58935	13829
+58945.7	13840
+58956.3	13848
+58967	13857
+58977.7	13862
+58988.3	13864
+58999	13869
+59009.7	13882
+59020.3	13884
+59031	13891
+59041.6	13897
+59052.3	13898
+59063	13899
+59073.6	13909
+59084.3	13916
+59095	13922
+59105.6	13925
+59116.3	13929
+59126.9	13936
+59137.6	13948
+59148.3	13951
+59158.9	13960
+59169.6	13968
+59180.3	13970
+59190.9	13977
+59201.6	13982
+59212.2	13987
+59222.9	13993
+59233.6	13999
+59244.2	14007
+59254.9	14014
+59265.6	14024
+59276.2	14030
+59286.9	14036
+59297.6	14043
+59308.2	14047
+59318.9	14057
+59329.5	14058
+59340.2	14061
+59350.9	14064
+59361.5	14069
+59372.2	14076
+59382.9	14084
+59393.5	14085
+59404.2	14087
+59414.8	14104
+59425.5	14108
+59436.2	14113
+59446.8	14119
+59457.5	14125
+59468.2	14132
+59478.8	14137
+59489.5	14143
+59500.2	14150
+59510.8	14152
+59521.5	14162
+59532.1	14167
+59542.8	14174
+59553.5	14176
+59564.1	14180
+59574.8	14191
+59585.5	14203
+59596.1	14205
+59606.8	14208
+59617.4	14213
+59628.1	14218
+59638.8	14223
+59649.4	14225
+59660.1	14231
+59670.8	14234
+59681.4	14241
+59692.1	14257
+59702.8	14259
+59713.4	14260
+59724.1	14264
+59734.7	14280
+59745.4	14281
+59756.1	14288
+59766.7	14291
+59777.4	14306
+59788.1	14308
+59798.7	14317
+59809.4	14323
+59820	14331
+59830.7	14336
+59841.4	14343
+59852	14347
+59862.7	14358
+59873.4	14361
+59884	14366
+59894.7	14370
+59905.4	14378
+59916	14385
+59926.7	14391
+59937.3	14397
+59948	14399
+59958.7	14409
+59969.3	14413
+59980	14417
+59990.7	14425
+60001.3	14427
+60012	14437
+60022.6	14442
+60033.3	14449
+60044	14450
+60054.6	14453
+60065.3	14462
+60076	14465
+60086.6	14473
+60097.3	14479
+60108	14489
+60118.6	14495
+60129.3	14499
+60139.9	14509
+60150.6	14519
+60161.3	14522
+60171.9	14525
+60182.6	14529
+60193.3	14537
+60203.9	14545
+60214.6	14550
+60225.2	14557
+60235.9	14559
+60246.6	14570
+60257.2	14574
+60267.9	14576
+60278.6	14588
+60289.2	14595
+60299.9	14601
+60310.6	14601
+60321.2	14611
+60331.9	14618
+60342.5	14622
+60353.2	14631
+60363.9	14637
+60374.5	14642
+60385.2	14650
+60395.9	14659
+60406.5	14665
+60417.2	14667
+60427.8	14669
+60438.5	14670
+60449.2	14679
+60459.8	14687
+60470.5	14688
+60481.2	14695
+60491.8	14700
+60502.5	14706
+60513.1	14712
+60523.8	14714
+60534.5	14721
+60545.1	14731
+60555.8	14736
+60566.5	14740
+60577.1	14752
+60587.8	14757
+60598.5	14765
+60609.1	14770
+60619.8	14780
+60630.4	14786
+60641.1	14793
+60651.8	14796
+60662.4	14804
+60673.1	14809
+60683.8	14815
+60694.4	14821
+60705.1	14833
+60715.7	14840
+60726.4	14840
+60737.1	14849
+60747.7	14855
+60758.4	14861
+60769.1	14870
+60779.7	14875
+60790.4	14882
+60801.1	14884
+60811.7	14893
+60822.4	14899
+60833	14904
+60843.7	14912
+60854.4	14918
+60865	14922
+60875.7	14928
+60886.4	14935
+60897	14943
+60907.7	14948
+60918.3	14952
+60929	14962
+60939.7	14971
+60950.3	14973
+60961	14979
+60971.7	14985
+60982.3	14994
+60993	14998
+61003.7	15004
+61014.3	15010
+61025	15016
+61035.6	15022
+61046.3	15027
+61057	15032
+61067.6	15037
+61078.3	15043
+61089	15044
+61099.6	15050
+61110.3	15064
+61120.9	15066
+61131.6	15071
+61142.3	15082
+61152.9	15086
+61163.6	15092
+61174.3	15098
+61184.9	15107
+61195.6	15113
+61206.3	15119
+61216.9	15126
+61227.6	15132
+61238.2	15141
+61248.9	15148
+61259.6	15151
+61270.2	15155
+61280.9	15170
+61291.6	15174
+61302.2	15176
+61312.9	15177
+61323.5	15180
+61334.2	15184
+61344.9	15188
+61355.5	15198
+61366.2	15203
+61376.9	15204
+61387.5	15207
+61398.2	15214
+61408.9	15220
+61419.5	15228
+61430.2	15238
+61440.8	15240
+61451.5	15243
+61462.2	15250
+61472.8	15255
+61483.5	15265
+61494.2	15267
+61504.8	15274
+61515.5	15281
+61526.1	15287
+61536.8	15292
+61547.5	15298
+61558.1	15303
+61568.8	15309
+61579.5	15315
+61590.1	15318
+61600.8	15330
+61611.4	15335
+61622.1	15339
+61632.8	15342
+61643.4	15348
+61654.1	15359
+61664.8	15365
+61675.4	15368
+61686.1	15371
+61696.8	15377
+61707.4	15390
+61718.1	15394
+61728.7	15399
+61739.4	15405
+61750.1	15411
+61760.7	15419
+61771.4	15425
+61782.1	15431
+61792.7	15435
+61803.4	15439
+61814	15446
+61824.7	15450
+61835.4	15459
+61846	15466
+61856.7	15473
+61867.4	15476
+61878	15482
+61888.7	15482
+61899.4	15490
+61910	15494
+61920.7	15497
+61931.3	15503
+61942	15511
+61952.7	15518
+61963.3	15523
+61974	15527
+61984.7	15529
+61995.3	15547
+62006	15548
+62016.6	15550
+62027.3	15551
+62038	15561
+62048.6	15568
+62059.3	15572
+62070	15576
+62080.6	15584
+62091.3	15593
+62102	15599
+62112.6	15603
+62123.3	15612
+62133.9	15619
+62144.6	15624
+62155.3	15627
+62165.9	15635
+62176.6	15646
+62187.3	15648
+62197.9	15652
+62208.6	15654
+62219.2	15658
+62229.9	15659
+62240.6	15674
+62251.2	15679
+62261.9	15686
+62272.6	15692
+62283.2	15697
+62293.9	15700
+62304.6	15713
+62315.2	15717
+62325.9	15722
+62336.5	15723
+62347.2	15729
+62357.9	15733
+62368.5	15746
+62379.2	15752
+62389.9	15754
+62400.5	15759
+62411.2	15762
+62421.8	15771
+62432.5	15772
+62443.2	15783
+62453.8	15788
+62464.5	15792
+62475.2	15806
+62485.8	15807
+62496.5	15809
+62507.2	15815
+62517.8	15824
+62528.5	15832
+62539.1	15835
+62549.8	15841
+62560.5	15844
+62571.1	15853
+62581.8	15863
+62592.5	15864
+62603.1	15869
+62613.8	15886
+62624.4	15889
+62635.1	15895
+62645.8	15908
+62656.4	15912
+62667.1	15917
+62677.8	15920
+62688.4	15936
+62699.1	15938
+62709.7	15940
+62720.4	15941
+62731.1	15946
+62741.7	15952
+62752.4	15958
+62763.1	15963
+62773.7	15967
+62784.4	15977
+62795.1	15983
+62805.7	15987
+62816.4	15992
+62827	15996
+62837.7	16005
+62848.4	16007
+62859	16013
+62869.7	16017
+62880.4	16028
+62891	16035
+62901.7	16043
+62912.3	16047
+62923	16051
+62933.7	16058
+62944.3	16069
+62955	16074
+62965.7	16083
+62976.3	16092
+62987	16096
+62997.7	16099
+63008.3	16110
+63019	16116
+63029.6	16117
+63040.3	16119
+63051	16124
+63061.6	16130
+63072.3	16141
+63083	16148
+63093.6	16151
+63104.3	16160
+63114.9	16171
+63125.6	16173
+63136.3	16180
+63146.9	16187
+63157.6	16196
+63168.3	16200
+63178.9	16205
+63189.6	16208
+63200.3	16218
+63210.9	16225
+63221.6	16229
+63232.2	16232
+63242.9	16238
+63253.6	16242
+63264.2	16245
+63274.9	16254
+63285.6	16256
+63296.2	16259
+63306.9	16266
+63317.5	16269
+63328.2	16275
+63338.9	16279
+63349.5	16287
+63360.2	16299
+63370.9	16303
+63381.5	16310
+63392.2	16311
+63402.9	16326
+63413.5	16330
+63424.2	16337
+63434.8	16339
+63445.5	16340
+63456.2	16352
+63466.8	16360
+63477.5	16368
+63488.2	16376
+63498.8	16379
+63509.5	16389
+63520.1	16394
+63530.8	16400
+63541.5	16406
+63552.1	16415
+63562.8	16422
+63573.5	16427
+63584.1	16431
+63594.8	16433
+63605.5	16446
+63616.1	16449
+63626.8	16453
+63637.4	16457
+63648.1	16467
+63658.8	16472
+63669.4	16474
+63680.1	16477
+63690.8	16486
+63701.4	16494
+63712.1	16500
+63722.7	16503
+63733.4	16509
+63744.1	16517
+63754.7	16524
+63765.4	16528
+63776.1	16531
+63786.7	16539
+63797.4	16552
+63808.1	16556
+63818.7	16560
+63829.4	16564
+63840	16573
+63850.7	16577
+63861.4	16582
+63872	16585
+63882.7	16588
+63893.4	16599
+63904	16604
+63914.7	16609
+63925.3	16616
+63936	16621
+63946.7	16628
+63957.3	16638
+63968	16640
+63978.7	16650
+63989.3	16654
+64000	16661
+64010.6	16668
+64021.3	16672
+64032	16682
+64042.6	16689
+64053.3	16689
+64064	16695
+64074.6	16700
+64085.3	16710
+64096	16718
+64106.6	16723
+64117.3	16727
+64127.9	16738
+64138.6	16741
+64149.3	16747
+64159.9	16749
+64170.6	16754
+64181.3	16760
+64191.9	16764
+64202.6	16776
+64213.2	16781
+64223.9	16786
+64234.6	16792
+64245.2	16798
+64255.9	16806
+64266.6	16812
+64277.2	16818
+64287.9	16824
+64298.6	16830
+64309.2	16839
+64319.9	16847
+64330.5	16850
+64341.2	16857
+64351.9	16862
+64362.5	16872
+64373.2	16879
+64383.9	16882
+64394.5	16890
+64405.2	16899
+64415.8	16903
+64426.5	16909
+64437.2	16915
+64447.8	16918
+64458.5	16928
+64469.2	16934
+64479.8	16938
+64490.5	16945
+64501.2	16952
+64511.8	16958
+64522.5	16964
+64533.1	16971
+64543.8	16976
+64554.5	16981
+64565.1	16984
+64575.8	16991
+64586.5	16998
+64597.1	17001
+64607.8	17005
+64618.4	17014
+64629.1	17020
+64639.8	17025
+64650.4	17025
+64661.1	17033
+64671.8	17045
+64682.4	17050
+64693.1	17055
+64703.8	17061
+64714.4	17068
+64725.1	17073
+64735.7	17082
+64746.4	17088
+64757.1	17091
+64767.7	17092
+64778.4	17097
+64789.1	17104
+64799.7	17110
+64810.4	17120
+64821	17123
+64831.7	17124
+64842.4	17134
+64853	17139
+64863.7	17149
+64874.4	17153
+64885	17163
+64895.7	17164
+64906.4	17169
+64917	17174
+64927.7	17179
+64938.3	17188
+64949	17193
+64959.7	17200
+64970.3	17206
+64981	17210
+64991.7	17214
+65002.3	17218
+65013	17218
+65023.6	17229
+65034.3	17231
+65045	17237
+65055.6	17244
+65066.3	17248
+65077	17256
+65087.6	17260
+65098.3	17266
+65108.9	17270
+65119.6	17274
+65130.3	17279
+65140.9	17280
+65151.6	17285
+65162.3	17291
+65172.9	17297
+65183.6	17298
+65194.3	17304
+65204.9	17306
+65215.6	17310
+65226.2	17310
+65236.9	17315
+65247.6	17316
+65258.2	17321
+65268.9	17322
+65279.6	17322
+65290.2	17327
+65300.9	17328
+65311.5	17333
+65322.2	17334
+65332.9	17339
+65343.5	17340
+65354.2	17346
+65364.9	17346
+65375.5	17351
+65386.2	17352
+65396.9	17357
+65407.5	17358
+65418.2	17363
+65428.8	17364
+65439.5	17369
+65450.2	17370
+65460.8	17375
+65471.5	17376
+65482.2	17381
+65492.8	17382
+65503.5	17387
+65514.1	17388
+65524.8	17393
+65535.5	17394
+65546.1	17394
+65556.8	17394
+65567.5	17394
+65578.1	17394
+65588.8	17394
+65599.5	17394
+65610.1	17394
+65620.8	17394
+65631.4	17394
+65642.1	17394
+65652.8	17394
+65663.4	17395
+65674.1	17395
+65684.8	17396
+65695.4	17396
+65706.1	17396
+65716.7	17396
+65727.4	17397
+65738.1	17398
+65748.7	17398
+65759.4	17400
+65770.1	17403
+65780.7	17403
+65791.4	17405
+65802.1	17406
+65812.7	17406
+65823.4	17406
+65834	17406
+65844.7	17406
+65855.4	17406
+65866	17406
+65876.7	17406
+65887.4	17406
+65898	17406
+65908.7	17407
+65919.3	17408
+65930	17408
+65940.7	17409
+65951.3	17410
+65962	17410
+65972.7	17412
+65983.3	17412
+65994	17412
+66004.7	17412
+66015.3	17414
+66026	17415
+66036.6	17415
+66047.3	17416
+66058	17418
+66068.6	17421
+66079.3	17424
+66090	17424
+66100.6	17427
+66111.3	17429
+66121.9	17430
+66132.6	17430
+66143.3	17430
+66153.9	17432
+66164.6	17433
+66175.3	17435
+66185.9	17436
+66196.6	17439
+66207.2	17439
+66217.9	17441
+66228.6	17442
+66239.2	17445
+66249.9	17447
+66260.6	17448
+66271.2	17451
+66281.9	17451
+66292.6	17454
+66303.2	17454
+66313.9	17457
+66324.5	17460
+66335.2	17460
+66345.9	17463
+66356.5	17466
+66367.2	17466
+66377.9	17469
+66388.5	17469
+66399.2	17469
+66409.8	17469
+66420.5	17469
+66431.2	17469
+66441.8	17469
+66452.5	17472
+66463.2	17472
+66473.8	17474
+66484.5	17476
+66495.2	17478
+66505.8	17478
+66516.5	17478
+66527.1	17480
+66537.8	17482
+66548.5	17484
+66559.1	17484
+66569.8	17484
+66580.5	17484
+66591.1	17484
+66601.8	17484
+66612.4	17484
+66623.1	17484
+66633.8	17484
+66644.4	17484
+66655.1	17484
+66665.8	17484
+66676.4	17484
+66687.1	17484
+66697.8	17484
+66708.4	17484
+66719.1	17484
+66729.7	17484
+66740.4	17484
+66751.1	17484
+66761.7	17484
+66772.4	17484
+66783.1	17484
+66793.7	17484
+66804.4	17484
+66815	17484
+66825.7	17484
+66836.4	17484
+66847	17484
+66857.7	17484
+66868.4	17484
+66879	17484
+66889.7	17484
+66900.4	17484
+66911	17484
+66921.7	17484
+66932.3	17484
+66943	17484
+66953.7	17484
+66964.3	17484
+66975	17484
+66985.7	17484
+66996.3	17484
+67007	17484
+67017.6	17484
+67028.3	17484
+67039	17484
+67049.6	17484
+67060.3	17484
+67071	17484
+67081.6	17484
+67092.3	17484
+67103	17484
+67113.6	17484
+67124.3	17484
+67134.9	17484
+67145.6	17484
+67156.3	17484
+67166.9	17484
+67177.6	17484
+67188.3	17484
+67198.9	17484
+67209.6	17484
+67220.2	17484
+67230.9	17484
+67241.6	17484
+67252.2	17484
+67262.9	17484
+67273.6	17484
+67284.2	17484
+67294.9	17484
+67305.6	17484
+67316.2	17484
+67326.9	17484
+67337.5	17484
+67348.2	17484
+67358.9	17484
+67369.5	17484
+67380.2	17484
+67390.9	17484
+67401.5	17484
+67412.2	17484
+67422.8	17484
+67433.5	17484
+67444.2	17484
+67454.8	17484
+67465.5	17484
+67476.2	17484
+67486.8	17484
+67497.5	17484
+67508.1	17484
+67518.8	17484
+67529.5	17484
+67540.1	17484
+67550.8	17484
+67561.5	17484
+67572.1	17484
+67582.8	17484
+67593.5	17484
+67604.1	17484
+67614.8	17484
+67625.4	17484
+67636.1	17484
+67646.8	17484
+67657.4	17484
+67668.1	17484
+67678.8	17484
+67689.4	17484
+67700.1	17484
+67710.7	17484
+67721.4	17484
+67732.1	17484
+67742.7	17484
+67753.4	17484
+67764.1	17484
+67774.7	17484
+67785.4	17484
+67796.1	17484
+67806.7	17484
+67817.4	17484
+67828	17484
+67838.7	17484
+67849.4	17484
+67860	17484
+67870.7	17484
+67881.4	17484
+67892	17484
+67902.7	17484
+67913.3	17484
+67924	17484
+67934.7	17484
+67945.3	17484
+67956	17484
+67966.7	17484
+67977.3	17484
+67988	17484
+67998.7	17484
+68009.3	17484
+68020	17484
+68030.6	17484
+68041.3	17484
+68052	17484
+68062.6	17484
+68073.3	17484
+68084	17484
+68094.6	17484
+68105.3	17484
+68115.9	17484
+68126.6	17484
+68137.3	17484
+68147.9	17484
+68158.6	17484
+68169.3	17484
+68179.9	17484
+68190.6	17484
+68201.3	17484
+68211.9	17484
+68222.6	17484
+68233.2	17484
+68243.9	17484
+68254.6	17484
+68265.2	17484
+68275.9	17484
+68286.6	17484
+68297.2	17484
+68307.9	17484
+68318.5	17484
+68329.2	17484
+68339.9	17484
+68350.5	17484
+68361.2	17484
+68371.9	17484
+68382.5	17484
+68393.2	17484
+68403.9	17484
+68414.5	17484
+68425.2	17484
+68435.8	17484
+68446.5	17484
+68457.2	17484
+68467.8	17484
+68478.5	17484
+68489.2	17484
+68499.8	17484
+68510.5	17484
+68521.1	17484
+68531.8	17484
+68542.5	17484
+68553.1	17484
+68563.8	17484
+68574.5	17484
+68585.1	17484
+68595.8	17484
+68606.4	17484
+68617.1	17484
+68627.8	17484
+68638.4	17484
+68649.1	17484
+68659.8	17484
+68670.4	17484
+68681.1	17484
+68691.8	17484
+68702.4	17484
+68713.1	17484
+68723.7	17484
+68734.4	17484
+68745.1	17484
+68755.7	17484
+68766.4	17484
+68777.1	17484
+68787.7	17484
+68798.4	17484
+68809	17484
+68819.7	17484
+68830.4	17484
+68841	17484
+68851.7	17484
+68862.4	17484
+68873	17484
+68883.7	17484
+68894.4	17484
+68905	17484
+68915.7	17484
+68926.3	17484
+68937	17484
+68947.7	17484
+68958.3	17484
+68969	17484
+68979.7	17484
+68990.3	17484
+69001	17484
+69011.6	17484
+69022.3	17484
+69033	17484
+69043.6	17484
+69054.3	17484
+69065	17484
+69075.6	17484
+69086.3	17484
+69097	17484
+69107.6	17484
+69118.3	17484
+69128.9	17484
+69139.6	17484
+69150.3	17484
+69160.9	17484
+69171.6	17484
+69182.3	17484
+69192.9	17484
+69203.6	17484
+69214.2	17484
+69224.9	17484
+69235.6	17484
+69246.2	17484
+69256.9	17484
+69267.6	17484
+69278.2	17484
+69288.9	17484
+69299.6	17484
+69310.2	17484
+69320.9	17484
+69331.5	17484
+69342.2	17484
+69352.9	17484
+69363.5	17484
+69374.2	17484
+69384.9	17484
+69395.5	17484
+69406.2	17484
+69416.8	17484
+69427.5	17484
+69438.2	17484
+69448.8	17484
+69459.5	17484
+69470.2	17484
+69480.8	17484
+69491.5	17484
+69502.2	17484
+69512.8	17484
+69523.5	17484
+69534.1	17484
+69544.8	17484
+69555.5	17484
+69566.1	17484
+69576.8	17484
+69587.5	17484
+69598.1	17484
+69608.8	17484
+69619.4	17484
+69630.1	17484
+69640.8	17484
+69651.4	17484
+69662.1	17484
+69672.8	17484
+69683.4	17484
+69694.1	17484
+69704.8	17484
+69715.4	17484
+69726.1	17484
+69736.7	17484
+69747.4	17484
+69758.1	17484
+69768.7	17484
+69779.4	17484
+69790.1	17484
+69800.7	17484
+69811.4	17484
+69822	17484
+69832.7	17484
+69843.4	17484
+69854	17484
+69864.7	17484
+69875.4	17484
+69886	17484
+69896.7	17484
+69907.3	17484
+69918	17484
+69928.7	17484
+69939.3	17484
+69950	17484
+69960.7	17484
+69971.3	17484
+69982	17484
+69992.7	17484
+70003.3	17484
+70014	17484
+70024.6	17484
+70035.3	17484
+70046	17484
+70056.6	17484
+70067.3	17484
+70078	17484
+70088.6	17484
+70099.3	17484
+70109.9	17484
+70120.6	17484
+70131.3	17484
+70141.9	17484
+70152.6	17484
+70163.3	17484
+70173.9	17484
+70184.6	17484
+70195.3	17484
+70205.9	17484
+70216.6	17484
+70227.2	17484
+70237.9	17484
+70248.6	17484
+70259.2	17484
+70269.9	17484
+70280.6	17484
+70291.2	17484
+70301.9	17484
+70312.5	17484
+70323.2	17484
+70333.9	17484
+70344.5	17484
+70355.2	17484
+70365.9	17484
+70376.5	17484
+70387.2	17484
+70397.9	17484
+70408.5	17484
+70419.2	17484
+70429.8	17484
+70440.5	17484
+70451.2	17484
+70461.8	17484
+70472.5	17484
+70483.2	17484
+70493.8	17484
+70504.5	17484
+70515.1	17484
+70525.8	17484
+70536.5	17484
+70547.1	17484
+70557.8	17484
+70568.5	17484
+70579.1	17484
+70589.8	17484
+70600.5	17484
+70611.1	17484
+70621.8	17484
+70632.4	17484
+70643.1	17484
+70653.8	17484
+70664.4	17484
+70675.1	17484
+70685.8	17484
+70696.4	17484
+70707.1	17484
+70717.7	17484
+70728.4	17484
+70739.1	17484
+70749.7	17484
+70760.4	17484
+70771.1	17484
+70781.7	17484
+70792.4	17484
+70803.1	17484
+70813.7	17484
+70824.4	17484
+70835	17484
+70845.7	17484
+70856.4	17484
+70867	17484
+70877.7	17484
+70888.4	17484
+70899	17484
+70909.7	17484
+70920.3	17484
+70931	17484
+70941.7	17484
+70952.3	17484
+70963	17484
+70973.7	17484
+70984.3	17484
+70995	17484
+71005.6	17484
+71016.3	17484
+71027	17484
+71037.6	17484
+71048.3	17484
+71059	17484
+71069.6	17484
+71080.3	17484
+71091	17484
+71101.6	17484
+71112.3	17484
+71122.9	17484
+71133.6	17484
+71144.3	17484
+71154.9	17484
+71165.6	17484
+71176.3	17484
+71186.9	17484
+71197.6	17484
+71208.2	17484
+71218.9	17484
+71229.6	17484
+71240.2	17484
+71250.9	17484
+71261.6	17484
+71272.2	17484
+71282.9	17484
+71293.6	17484
+71304.2	17484
+71314.9	17484
+71325.5	17484
+71336.2	17484
+71346.9	17484
+71357.5	17484
+71368.2	17484
+71378.9	17484
+71389.5	17484
+71400.2	17484
+71410.8	17484
+71421.5	17484
+71432.2	17484
+71442.8	17484
+71453.5	17484
+71464.2	17484
+71474.8	17484
+71485.5	17484
+71496.2	17484
+71506.8	17484
+71517.5	17484
+71528.1	17484
+71538.8	17484
+71549.5	17484
+71560.1	17484
+71570.8	17484
+71581.5	17484
+71592.1	17484
+71602.8	17484
+71613.4	17484
+71624.1	17484
+71634.8	17484
+71645.4	17484
+71656.1	17484
+71666.8	17484
+71677.4	17484
+71688.1	17484
+71698.8	17484
+71709.4	17484
+71720.1	17484
+71730.7	17484
+71741.4	17484
+71752.1	17484
+71762.7	17484
+71773.4	17484
+71784.1	17484
+71794.7	17484
+71805.4	17484
+71816	17484
+71826.7	17484
+71837.4	17484
+71848	17484
+71858.7	17484
+71869.4	17484
+71880	17484
+71890.7	17484
+71901.4	17484
+71912	17484
+71922.7	17484
+71933.3	17484
+71944	17484
+71954.7	17484
+71965.3	17484
+71976	17484
+71986.7	17484
+71997.3	17484
+72008	17484
+72018.6	17484
+72029.3	17484
+72040	17484
+72050.6	17484
+72061.3	17484
+72072	17484
+72082.6	17484
+72093.3	17484
+72103.9	17484
+72114.6	17484
+72125.3	17484
+72135.9	17484
+72146.6	17484
+72157.3	17484
+72167.9	17484
+72178.6	17484
+72189.3	17484
+72199.9	17484
+72210.6	17484
+72221.2	17484
+72231.9	17484
+72242.6	17484
+72253.2	17484
+72263.9	17484
+72274.6	17484
+72285.2	17484
+72295.9	17484
+72306.5	17484
+72317.2	17484
+72327.9	17484
+72338.5	17484
+72349.2	17484
+72359.9	17484
+72370.5	17484
+72381.2	17484
+72391.9	17484
+72402.5	17484
+72413.2	17484
+72423.8	17484
+72434.5	17484
+72445.2	17484
+72455.8	17484
+72466.5	17484
+72477.2	17484
+72487.8	17484
+72498.5	17484
+72509.1	17484
+72519.8	17484
+72530.5	17484
+72541.1	17484
+72551.8	17484
+72562.5	17484
+72573.1	17484
+72583.8	17484
+72594.5	17484
+72605.1	17484
+72615.8	17484
+72626.4	17484
+72637.1	17484
+72647.8	17484
+72658.4	17484
+72669.1	17484
+72679.8	17484
+72690.4	17484
+72701.1	17484
+72711.7	17484
+72722.4	17484
+72733.1	17484
+72743.7	17484
+72754.4	17484
+72765.1	17484
+72775.7	17484
+72786.4	17484
+72797.1	17484
+72807.7	17484
+72818.4	17484
+72829	17484
+72839.7	17484
+72850.4	17484
+72861	17484
+72871.7	17484
+72882.4	17484
+72893	17484
+72903.7	17484
+72914.3	17484
+72925	17484
+72935.7	17484
+72946.3	17484
+72957	17484
+72967.7	17484
+72978.3	17484
+72989	17484
+72999.7	17484
+73010.3	17484
+73021	17484
+73031.6	17484
+73042.3	17484
+73053	17484
+73063.6	17484
+73074.3	17484
+73085	17484
+73095.6	17484
+73106.3	17484
+73116.9	17484
+73127.6	17484
+73138.3	17484
+73148.9	17484
+73159.6	17484
+73170.3	17484
+73180.9	17484
+73191.6	17484
+73202.3	17484
+73212.9	17484
+73223.6	17484
+73234.2	17484
+73244.9	17484
+73255.6	17484
+73266.2	17484
+73276.9	17484
+73287.6	17484
+73298.2	17484
+73308.9	17484
+73319.5	17484
+73330.2	17484
+73340.9	17484
+73351.5	17484
+73362.2	17484
+73372.9	17484
+73383.5	17484
+73394.2	17484
+73404.8	17484
+73415.5	17484
+73426.2	17484
+73436.8	17484
+73447.5	17484
+73458.2	17484
+73468.8	17484
+73479.5	17484
+73490.2	17484
+73500.8	17484
+73511.5	17484
+73522.1	17484
+73532.8	17484
+73543.5	17484
+73554.1	17484
+73564.8	17484
+73575.5	17484
+73586.1	17484
+73596.8	17484
+73607.4	17484
+73618.1	17484
+73628.8	17484
+73639.4	17484
+73650.1	17484
+73660.8	17484
+73671.4	17484
+73682.1	17484
+73692.8	17484
+73703.4	17484
+73714.1	17484
+73724.7	17484
+73735.4	17484
+73746.1	17484
+73756.7	17484
+73767.4	17484
+73778.1	17484
+73788.7	17484
+73799.4	17484
+73810	17484
+73820.7	17484
+73831.4	17484
+73842	17484
+73852.7	17484
+73863.4	17484
+73874	17484
+73884.7	17484
+73895.4	17484
+73906	17484
+73916.7	17484
+73927.3	17484
+73938	17484
+73948.7	17484
+73959.3	17484
+73970	17484
+73980.7	17484
+73991.3	17484
+74002	17484
+74012.6	17484
+74023.3	17484
+74034	17484
+74044.6	17484
+74055.3	17484
+74066	17484
+74076.6	17484
+74087.3	17484
+74098	17484
+74108.6	17484
+74119.3	17484
+74129.9	17484
+74140.6	17484
+74151.3	17484
+74161.9	17484
+74172.6	17484
+74183.3	17484
+74193.9	17484
+74204.6	17484
+74215.2	17484
+74225.9	17484
+74236.6	17484
+74247.2	17484
+74257.9	17484
+74268.6	17484
+74279.2	17484
+74289.9	17484
+74300.6	17484
+74311.2	17484
+74321.9	17484
+74332.5	17484
+74343.2	17484
+74353.9	17484
+74364.5	17484
+74375.2	17484
+74385.9	17484
+74396.5	17484
+74407.2	17484
+74417.8	17484
+74428.5	17484
+74439.2	17484
+74449.8	17484
+74460.5	17484
+74471.2	17484
+74481.8	17484
+74492.5	17484
+74503.1	17484
+74513.8	17484
+74524.5	17484
+74535.1	17484
+74545.8	17484
+74556.5	17484
+74567.1	17484
+74577.8	17484
+74588.5	17484
+74599.1	17484
+74609.8	17484
+74620.4	17484
+74631.1	17484
+74641.8	17484
+74652.4	17484
+74663.1	17484
+74673.8	17484
+74684.4	17484
+74695.1	17484
+74705.7	17484
+74716.4	17484
+74727.1	17484
+74737.7	17484
+74748.4	17484
+74759.1	17484
+74769.7	17484
+74780.4	17484
+74791.1	17484
+74801.7	17484
+74812.4	17484
+74823	17484
+74833.7	17484
+74844.4	17484
+74855	17484
+74865.7	17484
+74876.4	17484
+74887	17484
+74897.7	17484
+74908.3	17484
+74919	17484
+74929.7	17484
+74940.3	17484
+74951	17484
+74961.7	17484
+74972.3	17484
+74983	17484
+74993.7	17484
+75004.3	17484
+75015	17484
+75025.6	17484
+75036.3	17484
+75047	17484
+75057.6	17484
+75068.3	17484
+75079	17484
+75089.6	17484
+75100.3	17484
+75110.9	17484
+75121.6	17484
+75132.3	17484
+75142.9	17484
+75153.6	17484
+75164.3	17484
+75174.9	17484
+75185.6	17484
+75196.3	17484
+75206.9	17484
+75217.6	17484
+75228.2	17484
+75238.9	17484
+75249.6	17484
+75260.2	17484
+75270.9	17484
+75281.6	17484
+75292.2	17484
+75302.9	17484
+75313.5	17484
+75324.2	17484
+75334.9	17484
+75345.5	17484
+75356.2	17484
+75366.9	17484
+75377.5	17484
+75388.2	17484
+75398.9	17484
+75409.5	17484
+75420.2	17484
+75430.8	17484
+75441.5	17484
+75452.2	17484
+75462.8	17484
+75473.5	17484
+75484.2	17484
+75494.8	17484
+75505.5	17484
+75516.1	17484
+75526.8	17484
+75537.5	17484
+75548.1	17484
+75558.8	17484
+75569.5	17484
+75580.1	17484
+75590.8	17484
+75601.4	17484
+75612.1	17484
+75622.8	17484
+75633.4	17484
+75644.1	17484
+75654.8	17484
+75665.4	17484
+75676.1	17484
+75686.8	17484
+75697.4	17484
+75708.1	17484
+75718.7	17484
+75729.4	17484
+75740.1	17484
+75750.7	17484
+75761.4	17484
+75772.1	17484
+75782.7	17484
+75793.4	17484
+75804	17484
+75814.7	17484
+75825.4	17484
+75836	17484
+75846.7	17484
+75857.4	17484
+75868	17484
+75878.7	17484
+75889.4	17484
+75900	17484
+75910.7	17484
+75921.3	17484
+75932	17484
+75942.7	17484
+75953.3	17484
+75964	17484
+75974.7	17484
+75985.3	17484
+75996	17484
+76006.6	17484
+76017.3	17484
+76028	17484
+76038.6	17484
+76049.3	17484
+76060	17484
+76070.6	17484
+76081.3	17484
+76092	17484
+76102.6	17484
+76113.3	17484
+76123.9	17484
+76134.6	17484
+76145.3	17484
+76155.9	17484
+76166.6	17484
+76177.3	17484
+76187.9	17484
+76198.6	17484
+76209.2	17484
+76219.9	17484
+76230.6	17484
+76241.2	17484
+76251.9	17484
+76262.6	17484
+76273.2	17484
+76283.9	17484
+76294.6	17484
+76305.2	17484
+76315.9	17484
+76326.5	17484
+76337.2	17484
+76347.9	17484
+76358.5	17484
+76369.2	17484
+76379.9	17484
+76390.5	17484
+76401.2	17484
+76411.8	17484
+76422.5	17484
+76433.2	17484
+76443.8	17484
+76454.5	17484
+76465.2	17484
+76475.8	17484
+76486.5	17484
+76497.2	17484
+76507.8	17484
+76518.5	17484
+76529.1	17484
+76539.8	17484
+76550.5	17484
+76561.1	17484
+76571.8	17484
+76582.5	17484
+76593.1	17484
+76603.8	17484
+76614.4	17484
+76625.1	17484
+76635.8	17484
+76646.4	17484
+76657.1	17484
+76667.8	17484
+76678.4	17484
+76689.1	17484
+76699.8	17484
+76710.4	17484
+76721.1	17484
+76731.7	17484
+76742.4	17484
+76753.1	17484
+76763.7	17484
+76774.4	17484
+76785.1	17484
+76795.7	17484
+76806.4	17484
+76817	17484
+76827.7	17484
+76838.4	17484
+76849	17484
+76859.7	17484
+76870.4	17484
+76881	17484
+76891.7	17484
+76902.3	17484
+76913	17484
+76923.7	17484
+76934.3	17484
+76945	17484
+76955.7	17484
+76966.3	17484
+76977	17484
+76987.7	17484
+76998.3	17484
+77009	17484
+77019.6	17484
+77030.3	17484
+77041	17484
+77051.6	17484
+77062.3	17484
+77073	17484
+77083.6	17484
+77094.3	17484
+77104.9	17484
+77115.6	17484
+77126.3	17484
+77136.9	17484
+77147.6	17484
+77158.3	17484
+77168.9	17484
+77179.6	17484
+77190.3	17484
+77200.9	17484
+77211.6	17484
+77222.2	17484
+77232.9	17484
+77243.6	17484
+77254.2	17484
+77264.9	17484
+77275.6	17484
+77286.2	17484
+77296.9	17484
+77307.5	17484
+77318.2	17484
+77328.9	17484
+77339.5	17484
+77350.2	17484
+77360.9	17484
+77371.5	17484
+77382.2	17484
+77392.9	17484
+77403.5	17484
+77414.2	17484
+77424.8	17484
+77435.5	17484
+77446.2	17484
+77456.8	17484
+77467.5	17484
+77478.2	17484
+77488.8	17484
+77499.5	17484
+77510.1	17484
+77520.8	17484
+77531.5	17484
+77542.1	17484
+77552.8	17484
+77563.5	17484
+77574.1	17484
+77584.8	17484
+77595.5	17484
+77606.1	17484
+77616.8	17484
+77627.4	17484
+77638.1	17484
+77648.8	17484
+77659.4	17484
+77670.1	17484
+77680.8	17484
+77691.4	17484
+77702.1	17484
+77712.7	17484
+77723.4	17484
+77734.1	17484
+77744.7	17484
+77755.4	17484
+77766.1	17484
+77776.7	17484
+77787.4	17484
+77798.1	17484
+77808.7	17484
+77819.4	17484
+77830	17484
+77840.7	17484
+77851.4	17484
+77862	17484
+77872.7	17484
+77883.4	17484
+77894	17484
+77904.7	17484
+77915.3	17484
+77926	17484
+77936.7	17484
+77947.3	17484
+77958	17484
+77968.7	17484
+77979.3	17484
+77990	17484
+78000.6	17484
+78011.3	17484
+78022	17484
+78032.6	17484
+78043.3	17484
+78054	17484
+78064.6	17484
+78075.3	17484
+78086	17484
+78096.6	17484
+78107.3	17484
+78117.9	17484
+78128.6	17484
+78139.3	17484
+78149.9	17484
+78160.6	17484
+78171.3	17484
+78181.9	17484
+78192.6	17484
+78203.2	17484
+78213.9	17484
+78224.6	17484
+78235.2	17484
+78245.9	17484
+78256.6	17484
+78267.2	17484
+78277.9	17484
+78288.6	17484
+78299.2	17484
+78309.9	17484
+78320.5	17484
+78331.2	17484
+78341.9	17484
+78352.5	17484
+78363.2	17484
+78373.9	17484
+78384.5	17484
+78395.2	17484
+78405.8	17484
+78416.5	17484
+78427.2	17484
+78437.8	17484
+78448.5	17484
+78459.2	17484
+78469.8	17484
+78480.5	17484
+78491.2	17484
+78501.8	17484
+78512.5	17484
+78523.1	17484
+78533.8	17484
+78544.5	17484
+78555.1	17484
+78565.8	17484
+78576.5	17484
+78587.1	17484
+78597.8	17484
+78608.4	17484
+78619.1	17484
+78629.8	17484
+78640.4	17484
+78651.1	17484
+78661.8	17484
+78672.4	17484
+78683.1	17484
+78693.8	17484
+78704.4	17484
+78715.1	17484
+78725.7	17484
+78736.4	17484
+78747.1	17484
+78757.7	17484
+78768.4	17484
+78779.1	17484
+78789.7	17484
+78800.4	17484
+78811	17484
+78821.7	17484
+78832.4	17484
+78843	17484
+78853.7	17484
+78864.4	17484
+78875	17484
+78885.7	17484
+78896.4	17484
+78907	17484
+78917.7	17484
+78928.3	17484
+78939	17484
+78949.7	17484
+78960.3	17484
+78971	17484
+78981.7	17484
+78992.3	17484
+79003	17484
+79013.6	17484
+79024.3	17484
+79035	17484
+79045.6	17484
+79056.3	17484
+79067	17484
+79077.6	17484
+79088.3	17484
+79098.9	17484
+79109.6	17484
+79120.3	17484
+79130.9	17484
+79141.6	17484
+79152.3	17484
+79162.9	17484
+79173.6	17484
+79184.3	17484
+79194.9	17484
+79205.6	17484
+79216.2	17484
+79226.9	17484
+79237.6	17484
+79248.2	17484
+79258.9	17484
+79269.6	17484
+79280.2	17484
+79290.9	17484
+79301.5	17484
+79312.2	17484
+79322.9	17484
+79333.5	17484
+79344.2	17484
+79354.9	17484
+79365.5	17484
+79376.2	17484
+79386.9	17484
+79397.5	17484
+79408.2	17484
+79418.8	17484
+79429.5	17484
+79440.2	17484
+79450.8	17484
+79461.5	17484
+79472.2	17484
+79482.8	17484
+79493.5	17484
+79504.1	17484
+79514.8	17484
+79525.5	17484
+79536.1	17484
+79546.8	17484
+79557.5	17484
+79568.1	17484
+79578.8	17484
+79589.5	17484
+79600.1	17484
+79610.8	17484
+79621.4	17484
+79632.1	17484
+79642.8	17484
+79653.4	17484
+79664.1	17484
+79674.8	17484
+79685.4	17484
+79696.1	17484
+79706.7	17484
+79717.4	17484
+79728.1	17484
+79738.7	17484
+79749.4	17484
+79760.1	17484
+79770.7	17484
+79781.4	17484
+79792.1	17484
+79802.7	17484
+79813.4	17484
+79824	17484
+79834.7	17484
+79845.4	17484
+79856	17484
+79866.7	17484
+79877.4	17484
+79888	17484
+79898.7	17484
+79909.3	17484
+79920	17484
+79930.7	17484
+79941.3	17484
+79952	17484
+79962.7	17484
+79973.3	17484
+79984	17484
+79994.7	17484
+80005.3	17484
+80016	17484
+80026.6	17484
+80037.3	17484
+80048	17484
+80058.6	17484
+80069.3	17484
+80080	17484
+80090.6	17484
+80101.3	17484
+80111.9	17484
+80122.6	17484
+80133.3	17484
+80143.9	17484
+80154.6	17484
+80165.3	17484
+80175.9	17484
+80186.6	17484
+80197.3	17484
+80207.9	17484
+80218.6	17484
+80229.2	17484
+80239.9	17484
+80250.6	17484
+80261.2	17484
+80271.9	17484
+80282.6	17484
+80293.2	17484
+80303.9	17484
+80314.5	17484
+80325.2	17484
+80335.9	17484
+80346.5	17484
+80357.2	17484
+80367.9	17484
+80378.5	17484
+80389.2	17484
+80399.8	17484
+80410.5	17484
+80421.2	17484
+80431.8	17484
+80442.5	17484
+80453.2	17484
+80463.8	17484
+80474.5	17484
+80485.2	17484
+80495.8	17484
+80506.5	17484
+80517.1	17484
+80527.8	17484
+80538.5	17484
+80549.1	17484
+80559.8	17484
+80570.5	17484
+80581.1	17484
+80591.8	17484
+80602.4	17484
+80613.1	17484
+80623.8	17484
+80634.4	17484
+80645.1	17484
+80655.8	17484
+80666.4	17484
+80677.1	17484
+80687.8	17484
+80698.4	17484
+80709.1	17484
+80719.7	17484
+80730.4	17484
+80741.1	17484
+80751.7	17484
+80762.4	17484
+80773.1	17484
+80783.7	17484
+80794.4	17484
+80805	17484
+80815.7	17484
+80826.4	17484
+80837	17484
+80847.7	17484
+80858.4	17484
+80869	17484
+80879.7	17484
+80890.4	17484
+80901	17484
+80911.7	17484
+80922.3	17484
+80933	17484
+80943.7	17484
+80954.3	17484
+80965	17484
+80975.7	17484
+80986.3	17484
+80997	17484
+81007.6	17484
+81018.3	17484
+81029	17484
+81039.6	17484
+81050.3	17484
+81061	17484
+81071.6	17484
+81082.3	17484
+81093	17484
+81103.6	17484
+81114.3	17484
+81124.9	17484
+81135.6	17484
+81146.3	17484
+81156.9	17484
+81167.6	17484
+81178.3	17484
+81188.9	17484
+81199.6	17484
+81210.2	17484
+81220.9	17484
+81231.6	17484
+81242.2	17484
+81252.9	17484
+81263.6	17484
+81274.2	17484
+81284.9	17484
+81295.6	17484
+81306.2	17484
+81316.9	17484
+81327.5	17484
+81338.2	17484
+81348.9	17484
+81359.5	17484
+81370.2	17484
+81380.9	17484
+81391.5	17484
+81402.2	17484
+81412.8	17484
+81423.5	17484
+81434.2	17484
+81444.8	17484
+81455.5	17484
+81466.2	17484
+81476.8	17484
+81487.5	17484
+81498.1	17484
+81508.8	17484
+81519.5	17484
+81530.1	17484
+81540.8	17484
+81551.5	17484
+81562.1	17484
+81572.8	17484
+81583.5	17484
+81594.1	17484
+81604.8	17484
+81615.4	17484
+81626.1	17484
+81636.8	17484
+81647.4	17484
+81658.1	17484
+81668.8	17484
+81679.4	17484
+81690.1	17484
+81700.7	17484
+81711.4	17484
+81722.1	17484
+81732.7	17484
+81743.4	17484
+81754.1	17484
+81764.7	17484
+81775.4	17484
+81786.1	17484
+81796.7	17484
+81807.4	17484
+81818	17484
+81828.7	17484
+81839.4	17484
+81850	17484
+81860.7	17484
+81871.4	17484
+81882	17484
+81892.7	17484
+81903.3	17484
+81914	17484
+81924.7	17484
+81935.3	17484
+81946	17484
+81956.7	17484
+81967.3	17484
+81978	17484
+81988.7	17484
+81999.3	17484
+82010	17484
+82020.6	17484
+82031.3	17484
+82042	17484
+82052.6	17484
+82063.3	17484
+82074	17484
+82084.6	17484
+82095.3	17484
+82105.9	17484
+82116.6	17484
+82127.3	17484
+82137.9	17484
+82148.6	17484
+82159.3	17484
+82169.9	17484
+82180.6	17484
+82191.3	17484
+82201.9	17484
+82212.6	17484
+82223.2	17484
+82233.9	17484
+82244.6	17484
+82255.2	17484
+82265.9	17484
+82276.6	17484
+82287.2	17484
+82297.9	17484
+82308.5	17484
+82319.2	17484
+82329.9	17484
+82340.5	17484
+82351.2	17484
+82361.9	17484
+82372.5	17484
+82383.2	17484
+82393.9	17484
+82404.5	17484
+82415.2	17484
+82425.8	17484
+82436.5	17484
+82447.2	17484
+82457.8	17484
+82468.5	17484
+82479.2	17484
+82489.8	17484
+82500.5	17484
+82511.1	17484
+82521.8	17484
+82532.5	17484
+82543.1	17484
+82553.8	17484
+82564.5	17484
+82575.1	17484
+82585.8	17484
+82596.5	17484
+82607.1	17484
+82617.8	17484
+82628.4	17484
+82639.1	17484
+82649.8	17484
+82660.4	17484
+82671.1	17484
+82681.8	17484
+82692.4	17484
+82703.1	17484
+82713.7	17484
+82724.4	17484
+82735.1	17484
+82745.7	17484
+82756.4	17484
+82767.1	17484
+82777.7	17484
+82788.4	17484
+82799	17484
+82809.7	17484
+82820.4	17484
+82831	17484
+82841.7	17484
+82852.4	17484
+82863	17484
+82873.7	17484
+82884.4	17484
+82895	17484
+82905.7	17484
+82916.3	17484
+82927	17484
+82937.7	17484
+82948.3	17484
+82959	17484
+82969.7	17484
+82980.3	17484
+82991	17484
+83001.6	17484
+83012.3	17484
+83023	17484
+83033.6	17484
+83044.3	17484
+83055	17484
+83065.6	17484
+83076.3	17484
+83087	17484
+83097.6	17484
+83108.3	17484
+83118.9	17484
+83129.6	17484
+83140.3	17484
+83150.9	17484
+83161.6	17484
+83172.3	17484
+83182.9	17484
+83193.6	17484
+83204.2	17484
+83214.9	17484
+83225.6	17484
+83236.2	17484
+83246.9	17484
+83257.6	17484
+83268.2	17484
+83278.9	17484
+83289.6	17484
+83300.2	17484
+83310.9	17484
+83321.5	17484
+83332.2	17484
+83342.9	17484
+83353.5	17484
+83364.2	17484
+83374.9	17484
+83385.5	17484
+83396.2	17484
+83406.8	17484
+83417.5	17484
+83428.2	17484
+83438.8	17484
+83449.5	17484
+83460.2	17484
+83470.8	17484
+83481.5	17484
+83492.2	17484
+83502.8	17484
+83513.5	17484
+83524.1	17484
+83534.8	17484
+83545.5	17484
+83556.1	17484
+83566.8	17484
+83577.5	17484
+83588.1	17484
+83598.8	17484
+83609.4	17484
+83620.1	17484
+83630.8	17484
+83641.4	17484
+83652.1	17484
+83662.8	17484
+83673.4	17484
+83684.1	17484
+83694.8	17484
+83705.4	17484
+83716.1	17484
+83726.7	17484
+83737.4	17484
+83748.1	17484
+83758.7	17484
+83769.4	17484
+83780.1	17484
+83790.7	17484
+83801.4	17484
+83812	17484
+83822.7	17484
+83833.4	17484
+83844	17484
+83854.7	17484
+83865.4	17484
+83876	17484
+83886.7	17484
+83897.3	17484
+83908	17484
+83918.7	17484
+83929.3	17484
+83940	17484
+83950.7	17484
+83961.3	17484
+83972	17484
+83982.7	17484
+83993.3	17484
+84004	17484
+84014.6	17484
+84025.3	17484
+84036	17484
+84046.6	17484
+84057.3	17484
+84068	17484
+84078.6	17484
+84089.3	17484
+84099.9	17484
+84110.6	17484
+84121.3	17484
+84131.9	17484
+84142.6	17484
+84153.3	17484
+84163.9	17484
+84174.6	17484
+84185.3	17484
+84195.9	17484
+84206.6	17484
+84217.2	17484
+84227.9	17484
+84238.6	17484
+84249.2	17484
+84259.9	17484
+84270.6	17484
+84281.2	17484
+84291.9	17484
+84302.5	17484
+84313.2	17484
+84323.9	17484
+84334.5	17484
+84345.2	17484
+84355.9	17484
+84366.5	17484
+84377.2	17484
+84387.9	17484
+84398.5	17484
+84409.2	17484
+84419.8	17484
+84430.5	17484
+84441.2	17484
+84451.8	17484
+84462.5	17484
+84473.2	17484
+84483.8	17484
+84494.5	17484
+84505.1	17484
+84515.8	17484
+84526.5	17484
+84537.1	17484
+84547.8	17484
+84558.5	17484
+84569.1	17484
+84579.8	17484
+84590.5	17484
+84601.1	17484
+84611.8	17484
+84622.4	17484
+84633.1	17484
+84643.8	17484
+84654.4	17484
+84665.1	17484
+84675.8	17484
+84686.4	17484
+84697.1	17484
+84707.7	17484
+84718.4	17484
+84729.1	17484
+84739.7	17484
+84750.4	17484
+84761.1	17484
+84771.7	17484
+84782.4	17484
+84793.1	17484
+84803.7	17484
+84814.4	17484
+84825	17484
+84835.7	17484
+84846.4	17484
+84857	17484
+84867.7	17484
+84878.4	17484
+84889	17484
+84899.7	17484
+84910.3	17484
+84921	17484
+84931.7	17484
+84942.3	17484
+84953	17484
+84963.7	17484
+84974.3	17484
+84985	17484
+84995.6	17484
+85006.3	17484
+85017	17484
+85027.6	17484
+85038.3	17484
+85049	17484
+85059.6	17484
+85070.3	17484
+85081	17484
+85091.6	17484
+85102.3	17484
+85112.9	17484
+85123.6	17484
+85134.3	17484
+85144.9	17484
+85155.6	17484
+85166.3	17484
+85176.9
Copied: SwiftApps/SciColSim/docs/plot_ready_jobs.txt (from rev 5634, SwiftApps/SciColSim/plot_ready_jobs.txt)
--- SwiftApps/SciColSim/docs/plot_ready_jobs.txt	                        (rev 0)
+++ SwiftApps/SciColSim/docs/plot_ready_jobs.txt	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,6239 @@
+11
+19
+14
+19
+17
+13
+19
+19
+10
+2
+18
+19
+16
+12
+13
+12
+11
+2
+11
+15
+16
+11
+19
+2
+17
+11
+19
+18
+2
+13
+10
+9
+19
+19
+11
+19
+18
+12
+17
+11
+18
+17
+11
+12
+12
+11
+12
+14
+19
+2
+10
+10
+11
+19
+11
+17
+11
+11
+13
+11
+19
+19
+12
+18
+19
+17
+19
+2
+11
+12
+13
+19
+19
+18
+11
+12
+19
+15
+19
+11
+2
+12
+19
+19
+19
+11
+11
+11
+11
+19
+18
+11
+11
+19
+11
+10
+18
+11
+19
+11
+14
+18
+2
+11
+10
+11
+18
+11
+12
+11
+19
+11
+11
+11
+11
+18
+11
+11
+11
+11
+2
+11
+19
+19
+11
+19
+11
+19
+11
+19
+18
+19
+12
+17
+19
+2
+16
+15
+11
+11
+19
+12
+12
+11
+19
+16
+11
+10
+19
+19
+18
+11
+18
+2
+12
+11
+12
+19
+19
+10
+19
+19
+18
+12
+12
+11
+18
+12
+2
+19
+18
+11
+11
+19
+19
+19
+11
+11
+17
+11
+12
+2
+19
+11
+12
+11
+11
+19
+18
+9
+11
+18
+19
+12
+19
+2
+11
+11
+12
+11
+2
+11
+10
+14
+11
+19
+19
+12
+18
+19
+19
+11
+2
+18
+19
+10
+17
+18
+11
+11
+11
+19
+19
+11
+17
+11
+12
+12
+13
+11
+18
+11
+19
+19
+19
+19
+11
+18
+19
+17
+12
+12
+11
+19
+11
+11
+19
+12
+11
+19
+19
+15
+11
+17
+2
+13
+13
+11
+19
+19
+11
+12
+18
+19
+11
+17
+2
+19
+13
+13
+11
+19
+12
+10
+10
+11
+19
+11
+12
+19
+12
+19
+11
+18
+12
+9
+19
+13
+11
+16
+11
+11
+17
+19
+2
+12
+19
+19
+11
+11
+11
+14
+11
+16
+19
+16
+18
+19
+19
+12
+19
+12
+19
+17
+10
+10
+2
+11
+12
+13
+19
+10
+10
+19
+19
+19
+12
+11
+19
+19
+10
+2
+17
+19
+10
+12
+12
+19
+2
+19
+11
+12
+19
+19
+13
+16
+19
+18
+12
+19
+12
+12
+19
+18
+11
+11
+11
+19
+19
+11
+12
+18
+2
+19
+15
+11
+11
+18
+12
+14
+10
+11
+9
+16
+17
+12
+18
+19
+19
+11
+11
+18
+2
+17
+16
+19
+12
+11
+12
+11
+19
+11
+12
+11
+11
+17
+11
+11
+17
+19
+2
+17
+11
+13
+2
+12
+11
+12
+19
+11
+10
+11
+19
+19
+12
+11
+11
+19
+13
+12
+10
+19
+19
+11
+19
+19
+19
+12
+18
+13
+11
+18
+10
+17
+16
+11
+17
+18
+10
+19
+17
+11
+17
+16
+2
+11
+11
+13
+19
+19
+11
+11
+11
+11
+12
+19
+19
+18
+12
+11
+19
+18
+13
+11
+2
+2
+11
+10
+11
+11
+11
+19
+12
+17
+19
+2
+11
+11
+19
+15
+11
+2
+19
+11
+11
+19
+10
+19
+13
+13
+11
+19
+19
+19
+11
+12
+2
+19
+18
+2
+11
+10
+10
+11
+18
+19
+2
+11
+17
+11
+11
+19
+12
+11
+12
+2
+11
+11
+21
+22
+19
+12
+12
+19
+2
+13
+18
+19
+19
+12
+19
+2
+11
+12
+12
+19
+10
+11
+19
+2
+11
+12
+17
+12
+12
+11
+2
+2
+11
+18
+19
+11
+11
+11
+11
+19
+12
+19
+2
+17
+11
+19
+16
+11
+11
+16
+18
+11
+11
+11
+19
+11
+19
+13
+19
+12
+10
+11
+12
+17
+14
+18
+18
+19
+10
+14
+18
+19
+19
+10
+12
+2
+19
+9
+11
+15
+19
+19
+18
+10
+11
+11
+13
+11
+9
+12
+11
+19
+11
+10
+19
+19
+9
+11
+13
+19
+19
+14
+12
+19
+11
+12
+11
+11
+19
+19
+12
+12
+12
+11
+19
+10
+13
+19
+19
+19
+10
+12
+11
+19
+19
+17
+19
+18
+11
+13
+18
+19
+12
+18
+2
+19
+19
+12
+12
+11
+2
+16
+17
+11
+11
+12
+2
+12
+18
+12
+19
+19
+17
+10
+10
+19
+18
+10
+11
+2
+10
+2
+11
+19
+11
+11
+11
+2
+17
+11
+18
+11
+17
+11
+11
+2
+11
+19
+11
+18
+19
+2
+11
+19
+19
+18
+19
+11
+11
+19
+19
+19
+11
+11
+19
+11
+19
+19
+17
+19
+11
+11
+19
+11
+9
+19
+11
+11
+19
+19
+19
+18
+19
+19
+18
+19
+11
+11
+2
+19
+11
+19
+19
+19
+17
+11
+19
+19
+2
+11
+11
+19
+12
+11
+19
+14
+19
+17
+19
+18
+11
+2
+19
+19
+19
+2
+19
+19
+19
+2
+19
+11
+2
+19
+11
+19
+19
+19
+18
+19
+19
+2
+2
+19
+2
+19
+11
+19
+11
+11
+19
+2
+2
+11
+19
+19
+11
+11
+18
+19
+19
+19
+19
+11
+11
+2
+19
+19
+19
+19
+19
+11
+11
+2
+2
+2
+19
+19
+11
+11
+19
+2
+18
+11
+19
+19
+19
+19
+19
+10
+2
+19
+11
+11
+19
+19
+18
+18
+19
+2
+16
+19
+2
+19
+2
+12
+11
+19
+11
+11
+19
+19
+11
+11
+19
+16
+19
+19
+17
+19
+2
+19
+19
+11
+19
+11
+19
+2
+14
+19
+11
+19
+19
+19
+11
+19
+11
+2
+19
+19
+19
+19
+19
+2
+19
+19
+19
+19
+2
+18
+19
+19
+18
+19
+11
+12
+19
+17
+2
+11
+19
+19
+10
+18
+19
+11
+19
+2
+11
+19
+10
+19
+11
+19
+19
+19
+2
+19
+10
+2
+19
+2
+13
+19
+19
+19
+19
+19
+11
+19
+2
+19
+2
+19
+19
+19
+19
+19
+2
+19
+2
+10
+19
+19
+18
+11
+19
+17
+18
+2
+11
+18
+11
+2
+19
+11
+2
+11
+2
+11
+11
+19
+19
+19
+19
+19
+19
+13
+19
+11
+19
+2
+18
+11
+18
+2
+2
+2
+11
+19
+19
+12
+11
+19
+11
+19
+2
+2
+19
+19
+19
+18
+19
+2
+2
+19
+19
+18
+11
+19
+11
+2
+19
+11
+11
+19
+19
+19
+2
+19
+9
+11
+19
+11
+18
+2
+19
+19
+10
+19
+19
+11
+19
+2
+11
+19
+19
+19
+19
+19
+19
+10
+19
+19
+19
+19
+2
+19
+2
+11
+19
+2
+11
+11
+11
+19
+19
+11
+2
+19
+19
+2
+19
+19
+19
+19
+2
+2
+19
+2
+19
+19
+19
+2
+11
+19
+11
+11
+19
+19
+19
+2
+19
+2
+2
+19
+19
+11
+19
+2
+19
+11
+10
+18
+19
+19
+18
+19
+19
+11
+19
+2
+19
+12
+19
+19
+11
+11
+19
+10
+19
+2
+11
+19
+11
+19
+2
+11
+11
+11
+2
+19
+11
+19
+18
+11
+11
+19
+11
+2
+19
+11
+2
+19
+19
+19
+2
+19
+2
+19
+18
+19
+17
+2
+18
+19
+2
+19
+11
+11
+11
+11
+19
+18
+11
+2
+19
+19
+2
+19
+19
+19
+11
+19
+11
+2
+2
+19
+10
+11
+19
+16
+11
+11
+2
+19
+19
+18
+19
+18
+2
+18
+17
+19
+11
+19
+12
+19
+12
+19
+12
+19
+9
+11
+12
+2
+19
+19
+19
+11
+19
+19
+11
+19
+2
+11
+11
+19
+19
+11
+19
+2
+18
+19
+16
+19
+2
+19
+11
+19
+19
+10
+11
+13
+11
+19
+11
+18
+11
+2
+19
+2
+19
+18
+11
+2
+2
+11
+19
+10
+19
+16
+19
+11
+19
+11
+19
+11
+19
+19
+12
+12
+11
+19
+18
+11
+19
+2
+2
+2
+19
+18
+19
+19
+11
+19
+19
+19
+2
+19
+11
+11
+2
+11
+19
+18
+19
+2
+19
+11
+11
+19
+2
+11
+11
+19
+19
+18
+2
+19
+2
+19
+11
+12
+19
+19
+2
+19
+19
+19
+2
+19
+18
+2
+11
+19
+2
+17
+11
+2
+18
+19
+2
+19
+11
+19
+19
+19
+19
+2
+11
+19
+19
+19
+19
+19
+19
+19
+11
+18
+19
+2
+17
+19
+2
+11
+19
+19
+11
+11
+2
+17
+18
+11
+19
+11
+19
+19
+17
+11
+19
+19
+11
+11
+19
+11
+18
+11
+19
+19
+11
+19
+19
+18
+19
+11
+19
+2
+18
+19
+2
+19
+11
+2
+19
+19
+11
+19
+2
+19
+18
+19
+19
+2
+2
+19
+19
+11
+19
+2
+19
+11
+2
+18
+19
+11
+11
+11
+18
+19
+19
+2
+11
+2
+2
+18
+2
+19
+2
+2
+11
+18
+19
+2
+2
+11
+19
+13
+11
+19
+11
+19
+19
+2
+11
+19
+11
+11
+19
+16
+19
+2
+19
+18
+19
+19
+12
+11
+11
+19
+17
+11
+2
+19
+11
+19
+11
+2
+19
+2
+11
+19
+19
+19
+11
+19
+17
+12
+19
+19
+18
+19
+2
+18
+19
+2
+19
+19
+11
+19
+18
+19
+11
+18
+19
+16
+2
+19
+11
+19
+11
+19
+11
+19
+2
+19
+19
+17
+19
+11
+11
+19
+19
+11
+19
+19
+12
+12
+19
+2
+19
+17
+10
+19
+19
+11
+19
+19
+19
+18
+19
+2
+11
+11
+19
+2
+10
+11
+2
+19
+11
+19
+19
+11
+19
+2
+11
+19
+19
+19
+18
+19
+2
+19
+12
+10
+12
+2
+19
+19
+11
+19
+19
+18
+2
+19
+18
+17
+18
+12
+2
+19
+11
+10
+11
+2
+11
+12
+19
+19
+14
+2
+19
+11
+11
+19
+19
+11
+18
+19
+12
+12
+19
+18
+18
+2
+11
+11
+2
+19
+19
+11
+19
+10
+18
+18
+11
+11
+19
+12
+11
+18
+11
+11
+11
+2
+2
+19
+11
+12
+18
+19
+19
+14
+12
+18
+19
+11
+12
+19
+11
+11
+2
+19
+18
+13
+19
+11
+19
+16
+11
+17
+11
+19
+11
+19
+11
+18
+10
+10
+11
+11
+19
+17
+19
+17
+11
+2
+19
+19
+2
+12
+11
+19
+19
+19
+18
+16
+19
+12
+11
+10
+11
+11
+11
+17
+11
+19
+13
+2
+19
+11
+11
+11
+2
+16
+2
+19
+19
+17
+2
+18
+11
+12
+19
+2
+17
+11
+11
+11
+11
+11
+12
+19
+11
+19
+18
+10
+19
+11
+19
+11
+19
+11
+19
+11
+17
+11
+17
+12
+17
+11
+11
+18
+19
+19
+9
+11
+2
+19
+19
+16
+2
+19
+11
+14
+19
+12
+19
+19
+17
+13
+15
+19
+19
+12
+19
+2
+2
+16
+19
+19
+11
+12
+18
+12
+12
+19
+15
+16
+11
+2
+11
+11
+16
+11
+11
+17
+11
+18
+17
+2
+10
+12
+11
+19
+19
+2
+2
+2
+19
+13
+19
+2
+14
+13
+19
+19
+10
+19
+11
+19
+11
+2
+19
+11
+11
+19
+19
+9
+11
+11
+19
+12
+12
+11
+19
+11
+15
+2
+2
+18
+11
+19
+17
+19
+19
+10
+11
+19
+11
+10
+12
+2
+15
+13
+17
+18
+11
+13
+2
+11
+19
+11
+11
+11
+16
+12
+2
+2
+11
+11
+12
+11
+19
+12
+11
+11
+12
+11
+19
+2
+12
+17
+11
+11
+11
+16
+19
+12
+11
+19
+19
+12
+19
+19
+11
+16
+19
+19
+19
+12
+19
+12
+11
+11
+11
+14
+11
+2
+19
+11
+11
+11
+10
+11
+16
+11
+2
+10
+11
+17
+10
+19
+10
+11
+11
+17
+16
+19
+16
+11
+11
+17
+11
+11
+19
+10
+19
+19
+19
+19
+11
+12
+18
+19
+10
+19
+19
+11
+19
+19
+11
+2
+19
+19
+11
+19
+19
+17
+18
+18
+2
+11
+11
+11
+19
+13
+11
+11
+18
+10
+12
+17
+18
+11
+18
+11
+11
+19
+9
+17
+2
+2
+11
+11
+17
+2
+11
+18
+11
+13
+19
+19
+11
+10
+13
+17
+19
+19
+19
+19
+11
+10
+11
+11
+11
+19
+13
+16
+19
+12
+12
+19
+19
+11
+19
+19
+16
+17
+14
+19
+19
+15
+19
+2
+19
+19
+19
+18
+19
+2
+19
+19
+2
+2
+2
+19
+11
+19
+19
+11
+19
+2
+11
+11
+19
+19
+18
+19
+2
+2
+19
+19
+16
+19
+19
+19
+19
+2
+19
+19
+11
+19
+19
+2
+19
+19
+12
+12
+19
+19
+17
+11
+19
+19
+19
+19
+19
+19
+19
+11
+11
+19
+11
+2
+19
+2
+19
+19
+11
+11
+11
+11
+19
+2
+19
+11
+11
+2
+19
+19
+19
+19
+19
+2
+19
+11
+11
+11
+19
+19
+19
+19
+19
+19
+19
+18
+2
+11
+12
+12
+2
+19
+18
+2
+19
+19
+11
+19
+19
+19
+19
+19
+11
+19
+19
+19
+19
+19
+11
+19
+19
+19
+11
+12
+11
+2
+19
+11
+2
+19
+17
+19
+11
+2
+19
+17
+19
+11
+18
+19
+12
+2
+19
+18
+12
+19
+11
+2
+16
+19
+11
+11
+19
+19
+19
+11
+2
+19
+18
+19
+19
+19
+2
+11
+19
+19
+18
+19
+19
+19
+11
+11
+11
+11
+19
+19
+11
+2
+18
+19
+18
+19
+19
+11
+19
+19
+19
+11
+2
+19
+11
+11
+12
+2
+11
+19
+19
+11
+19
+19
+11
+19
+18
+11
+2
+19
+11
+19
+19
+2
+19
+10
+11
+11
+11
+19
+11
+2
+19
+19
+19
+19
+19
+2
+19
+18
+19
+19
+11
+19
+19
+18
+19
+17
+11
+19
+19
+2
+11
+19
+19
+19
+18
+10
+2
+19
+19
+2
+11
+19
+11
+19
+19
+19
+19
+2
+19
+19
+2
+19
+19
+19
+2
+10
+18
+2
+11
+19
+19
+11
+19
+19
+19
+11
+2
+11
+19
+19
+19
+19
+19
+11
+19
+19
+2
+19
+2
+19
+19
+19
+19
+11
+2
+2
+2
+11
+11
+19
+11
+17
+2
+19
+19
+18
+19
+16
+19
+19
+11
+11
+19
+19
+11
+11
+19
+11
+19
+11
+19
+11
+19
+11
+2
+11
+19
+19
+11
+19
+19
+11
+2
+19
+11
+19
+14
+13
+18
+18
+18
+18
+18
+18
+18
+18
+18
+18
+20
+21
+4
+4
+4
+4
+13
+21
+21
+12
+11
+19
+18
+17
+12
+19
+11
+19
+19
+11
+13
+18
+19
+10
+18
+11
+19
+11
+10
+11
+11
+16
+18
+10
+2
+19
+2
+10
+19
+11
+11
+2
+19
+14
+16
+19
+12
+11
+19
+19
+11
+11
+11
+19
+19
+19
+2
+2
+12
+18
+2
+19
+12
+18
+11
+11
+11
+19
+11
+11
+18
+19
+18
+11
+11
+18
+19
+18
+2
+2
+11
+2
+19
+2
+10
+19
+11
+19
+17
+12
+18
+2
+10
+11
+11
+19
+19
+11
+17
+19
+19
+19
+11
+12
+19
+12
+11
+19
+19
+11
+10
+19
+19
+19
+15
+18
+19
+11
+10
+17
+11
+19
+9
+12
+19
+13
+9
+19
+19
+11
+18
+2
+19
+19
+10
+19
+2
+2
+17
+16
+11
+2
+19
+11
+11
+11
+2
+2
+19
+11
+18
+19
+19
+19
+11
+11
+2
+19
+10
+13
+11
+19
+11
+18
+12
+18
+19
+2
+19
+11
+19
+2
+2
+11
+11
+11
+11
+18
+11
+11
+11
+2
+10
+19
+18
+18
+12
+19
+19
+10
+18
+19
+11
+19
+11
+11
+11
+11
+19
+19
+18
+11
+18
+19
+11
+19
+2
+13
+19
+19
+11
+10
+19
+11
+11
+11
+12
+18
+11
+19
+19
+11
+11
+2
+11
+19
+10
+11
+17
+12
+11
+18
+2
+19
+11
+11
+11
+19
+11
+10
+2
+18
+17
+16
+2
+11
+19
+18
+14
+12
+11
+2
+19
+2
+11
+11
+18
+19
+11
+11
+19
+2
+12
+11
+2
+18
+11
+19
+11
+2
+18
+2
+19
+2
+18
+19
+2
+19
+13
+9
+2
+19
+11
+16
+11
+19
+19
+11
+19
+19
+11
+18
+11
+2
+2
+11
+19
+11
+12
+18
+11
+16
+2
+12
+18
+17
+16
+11
+18
+2
+11
+10
+2
+10
+18
+19
+11
+11
+18
+2
+19
+11
+10
+11
+19
+13
+17
+11
+2
+2
+19
+18
+14
+19
+19
+19
+16
+12
+19
+2
+13
+15
+19
+19
+17
+11
+2
+19
+19
+19
+18
+11
+11
+19
+11
+11
+18
+11
+11
+10
+2
+19
+16
+18
+19
+19
+19
+12
+19
+2
+2
+19
+11
+19
+19
+19
+17
+19
+19
+11
+12
+11
+2
+19
+11
+11
+11
+11
+19
+2
+11
+19
+18
+2
+11
+2
+11
+11
+12
+11
+19
+11
+18
+11
+11
+11
+2
+11
+11
+11
+19
+19
+10
+11
+2
+19
+12
+12
+18
+2
+17
+11
+11
+11
+19
+19
+19
+16
+18
+11
+19
+19
+11
+16
+12
+19
+19
+17
+18
+19
+19
+11
+11
+11
+11
+17
+11
+18
+19
+11
+11
+10
+2
+19
+17
+18
+11
+19
+11
+11
+19
+19
+19
+10
+19
+11
+19
+11
+11
+19
+11
+11
+11
+12
+2
+19
+10
+11
+11
+10
+11
+19
+19
+19
+2
+19
+17
+17
+11
+19
+12
+11
+2
+19
+19
+11
+2
+19
+11
+11
+19
+2
+19
+12
+11
+19
+10
+11
+19
+11
+11
+19
+11
+12
+11
+19
+19
+11
+19
+16
+11
+10
+2
+11
+19
+17
+2
+2
+11
+19
+19
+19
+11
+11
+12
+11
+12
+18
+11
+11
+19
+19
+15
+19
+2
+17
+18
+19
+11
+11
+11
+11
+11
+11
+18
+12
+18
+19
+11
+19
+11
+19
+11
+2
+12
+19
+16
+11
+11
+11
+11
+11
+11
+12
+11
+11
+2
+11
+19
+11
+11
+10
+16
+11
+10
+11
+2
+11
+18
+11
+11
+19
+19
+19
+17
+2
+10
+11
+19
+19
+11
+18
+14
+18
+19
+11
+19
+18
+19
+19
+16
+11
+18
+19
+11
+17
+19
+18
+11
+12
+11
+18
+19
+2
+19
+19
+2
+17
+11
+11
+18
+18
+14
+11
+11
+18
+11
+16
+19
+16
+19
+7
+2
+19
+11
+11
+19
+11
+19
+19
+15
+19
+11
+19
+9
+19
+12
+19
+18
+11
+15
+13
+11
+12
+19
+11
+18
+11
+11
+11
+19
+18
+12
+19
+11
+11
+12
+10
+11
+11
+11
+12
+17
+11
+10
+19
+11
+2
+12
+12
+19
+19
+18
+17
+11
+11
+18
+11
+11
+11
+11
+10
+11
+19
+11
+19
+19
+2
+11
+2
+19
+11
+11
+11
+18
+2
+19
+10
+11
+19
+19
+19
+17
+2
+19
+19
+12
+11
+12
+11
+17
+13
+19
+18
+10
+11
+2
+11
+11
+19
+12
+19
+17
+2
+19
+18
+18
+11
+2
+18
+19
+2
+19
+11
+11
+11
+19
+11
+11
+19
+19
+19
+19
+19
+18
+19
+2
+19
+19
+11
+10
+19
+19
+18
+11
+11
+18
+18
+19
+17
+18
+11
+19
+17
+19
+19
+11
+19
+11
+14
+12
+11
+19
+18
+11
+17
+19
+17
+10
+11
+10
+11
+10
+16
+19
+18
+12
+19
+2
+12
+11
+12
+12
+15
+19
+19
+19
+18
+19
+19
+19
+19
+19
+19
+13
+13
+13
+18
+19
+18
+17
+11
+18
+19
+10
+19
+16
+19
+11
+12
+19
+19
+10
+19
+19
+17
+19
+19
+2
+19
+19
+19
+19
+19
+19
+2
+19
+2
+19
+2
+11
+11
+19
+19
+2
+17
+11
+19
+19
+11
+11
+11
+11
+19
+19
+19
+19
+11
+11
+19
+19
+18
+19
+11
+11
+19
+19
+11
+11
+19
+11
+19
+2
+19
+2
+11
+19
+19
+19
+11
+13
+10
+19
+19
+11
+2
+19
+18
+19
+19
+11
+19
+19
+12
+19
+19
+19
+19
+11
+2
+19
+11
+12
+19
+2
+19
+10
+19
+19
+18
+19
+19
+11
+19
+19
+11
+19
+2
+19
+11
+19
+19
+19
+18
+2
+11
+2
+2
+11
+19
+19
+2
+11
+19
+19
+19
+19
+11
+2
+18
+19
+11
+2
+19
+11
+18
+19
+17
+19
+11
+2
+19
+10
+2
+2
+2
+11
+11
+19
+19
+11
+2
+19
+19
+2
+18
+18
+19
+19
+11
+18
+19
+11
+11
+19
+19
+2
+19
+19
+19
+19
+18
+18
+10
+2
+19
+19
+16
+19
+11
+2
+11
+19
+19
+19
+19
+19
+19
+2
+18
+19
+19
+19
+11
+19
+11
+2
+19
+19
+19
+19
+11
+11
+12
+19
+12
+19
+19
+19
+11
+19
+10
+11
+19
+17
+19
+11
+11
+19
+19
+2
+19
+19
+2
+11
+19
+17
+19
+12
+11
+19
+19
+11
+19
+2
+19
+2
+2
+11
+11
+11
+19
+11
+17
+19
+17
+19
+19
+19
+11
+11
+19
+11
+11
+2
+19
+11
+2
+19
+17
+11
+2
+19
+19
+19
+19
+19
+18
+2
+11
+19
+19
+19
+19
+19
+19
+19
+19
+2
+2
+19
+19
+19
+19
+2
+19
+11
+19
+11
+12
+19
+19
+19
+19
+19
+2
+19
+19
+2
+19
+10
+19
+11
+19
+2
+17
+19
+19
+11
+10
+11
+19
+19
+18
+19
+2
+18
+19
+11
+19
+18
+19
+19
+18
+19
+18
+19
+19
+19
+19
+2
+19
+19
+19
+19
+19
+11
+11
+11
+19
+19
+19
+11
+2
+19
+19
+2
+19
+17
+2
+19
+18
+11
+19
+19
+18
+19
+2
+11
+19
+2
+2
+19
+18
+19
+11
+11
+2
+19
+11
+19
+18
+2
+19
+18
+19
+19
+11
+11
+19
+19
+19
+16
+2
+19
+11
+2
+2
+19
+19
+19
+11
+2
+19
+19
+19
+11
+19
+19
+2
+19
+2
+11
+19
+11
+2
+19
+19
+11
+19
+19
+2
+2
+19
+11
+2
+19
+19
+19
+19
+10
+11
+11
+19
+19
+2
+19
+19
+19
+19
+19
+11
+18
+19
+19
+18
+19
+19
+11
+19
+19
+11
+11
+11
+2
+11
+12
+19
+19
+19
+19
+19
+19
+19
+19
+19
+2
+17
+2
+19
+12
+2
+19
+17
+19
+11
+18
+19
+19
+17
+11
+11
+17
+19
+19
+19
+19
+19
+11
+19
+19
+19
+19
+18
+19
+19
+19
+19
+2
+19
+19
+19
+19
+19
+11
+19
+11
+11
+11
+19
+11
+19
+17
+2
+19
+11
+19
+11
+11
+19
+2
+18
+11
+19
+19
+18
+11
+19
+2
+2
+12
+12
+19
+11
+19
+19
+18
+19
+19
+19
+19
+19
+19
+19
+2
+17
+19
+11
+19
+2
+19
+2
+19
+11
+19
+11
+11
+12
+19
+19
+16
+2
+19
+2
+19
+2
+19
+18
+19
+19
+19
+19
+19
+11
+19
+18
+11
+19
+19
+11
+11
+18
+2
+19
+18
+19
+11
+11
+11
+19
+19
+19
+18
+11
+2
+19
+19
+19
+19
+2
+19
+2
+19
+19
+19
+11
+19
+11
+19
+19
+11
+2
+19
+19
+19
+11
+18
+19
+19
+19
+19
+19
+2
+19
+2
+19
+2
+19
+19
+17
+19
+19
+11
+11
+19
+19
+19
+11
+19
+11
+19
+11
+11
+18
+19
+19
+18
+11
+19
+19
+11
+19
+2
+11
+19
+19
+19
+19
+2
+19
+17
+19
+2
+11
+18
+11
+13
+11
+19
+19
+11
+11
+19
+16
+19
+2
+19
+2
+19
+19
+11
+19
+19
+11
+19
+11
+19
+2
+16
+11
+19
+11
+19
+19
+19
+11
+11
+19
+11
+19
+19
+11
+19
+19
+19
+19
+19
+11
+19
+19
+11
+2
+18
+19
+11
+11
+11
+19
+19
+18
+19
+19
+2
+19
+19
+11
+2
+19
+19
+19
+11
+11
+19
+19
+19
+11
+19
+2
+2
+11
+11
+19
+11
+11
+2
+19
+11
+11
+19
+11
+2
+16
+11
+19
+19
+2
+11
+2
+19
+11
+11
+19
+19
+2
+2
+19
+19
+2
+19
+11
+11
+18
+19
+19
+19
+19
+11
+19
+10
+19
+19
+19
+10
+11
+12
+11
+19
+11
+19
+18
+18
+19
+2
+2
+19
+19
+2
+11
+19
+19
+19
+11
+19
+17
+19
+11
+2
+19
+2
+2
+19
+19
+19
+19
+19
+11
+19
+19
+19
+19
+19
+11
+19
+2
+11
+2
+19
+19
+18
+19
+19
+11
+13
+2
+19
+11
+11
+19
+19
+2
+19
+11
+12
+19
+11
+18
+19
+10
+19
+19
+17
+2
+19
+19
+11
+11
+19
+11
+11
+19
+10
+2
+19
+17
+19
+2
+19
+19
+18
+2
+11
+2
+19
+19
+18
+19
+19
+19
+2
+19
+19
+19
+2
+11
+19
+19
+19
+2
+11
+2
+19
+19
+11
+11
+11
+19
+2
+19
+19
+11
+19
+19
+11
+19
+11
+11
+19
+19
+11
+2
+11
+13
+19
+18
+19
+18
+11
+11
+2
+19
+19
+19
+11
+19
+19
+2
+19
+19
+18
+18
+19
+19
+19
+11
+19
+19
+19
+11
+19
+19
+11
+11
+11
+10
+19
+19
+19
+18
+19
+12
+19
+19
+19
+17
+11
+19
+2
+19
+2
+10
+2
+2
+2
+2
+19
+19
+2
+19
+19
+11
+2
+19
+19
+19
+11
+2
+11
+18
+19
+19
+19
+11
+11
+19
+11
+19
+11
+19
+11
+10
+2
+19
+17
+2
+19
+11
+18
+19
+19
+11
+2
+19
+19
+19
+11
+18
+19
+19
+2
+11
+11
+2
+19
+19
+11
+2
+19
+19
+19
+11
+19
+19
+11
+2
+2
+19
+11
+19
+19
+19
+2
+19
+18
+18
+19
+19
+11
+18
+19
+19
+2
+2
+19
+2
+19
+11
+19
+11
+19
+19
+19
+18
+19
+19
+19
+19
+19
+2
+11
+19
+19
+19
+19
+19
+19
+19
+2
+10
+16
+19
+11
+11
+19
+19
+19
+19
+19
+19
+19
+19
+19
+2
+19
+19
+2
+11
+15
+19
+19
+2
+19
+19
+19
+2
+18
+19
+2
+11
+12
+19
+18
+19
+11
+11
+19
+11
+11
+2
+19
+18
+2
+19
+12
+2
+19
+13
+2
+19
+11
+2
+19
+18
+11
+19
+19
+19
+19
+18
+11
+19
+2
+10
+2
+19
+18
+11
+19
+11
+19
+19
+19
+9
+11
+11
+19
+19
+2
+17
+2
+19
+10
+19
+17
+19
+10
+19
+19
+19
+2
+11
+19
+19
+10
+10
+11
+19
+11
+19
+19
+19
+19
+19
+19
+2
+19
+11
+19
+2
+19
+11
+19
+2
+18
+11
+19
+19
+19
+12
+13
+12
+19
+16
+19
+17
+19
+19
+2
+19
+12
+2
+19
+2
+2
+19
+9
+19
+17
+2
+19
+12
+17
+19
+11
+11
+2
+19
+18
+11
+2
+19
+11
+2
+19
+19
+19
+19
+19
+11
+2
+11
+19
+11
+19
+11
+17
+19
+19
+18
+19
+2
+19
+19
+11
+13
+11
+19
+19
+11
+19
+19
+11
+11
+19
+11
+19
+2
+19
+19
+19
+18
+19
+19
+11
+18
+21
+13
+16
+18
+18
+18
+18
+18
+18
+0
+2
+6
+2
+2
+0
+4
+2
+2
+2
+2
+2
+10
+12
+3
+2
+8
+4
+3
+3
+3
+7
+3
+8
+3
+5
+3
+2
+30
+11
+9
+16
+19
+11
+10
+10
+17
+2
+11
+19
+12
+12
+10
+11
+11
+10
+18
+13
+11
+17
+12
+10
+17
+13
+2
+19
+11
+9
+14
+12
+11
+12
+15
+13
+16
+17
+12
+11
+12
+13
+11
+9
+11
+12
+12
+11
+13
+11
+12
+11
+12
+12
+10
+11
+11
+11
+17
+12
+12
+12
+12
+10
+12
+13
+12
+11
+10
+13
+10
+17
+11
+11
+18
+10
+12
+11
+12
+19
+12
+12
+15
+13
+11
+19
+11
+12
+10
+8
+16
+12
+11
+11
+13
+11
+10
+19
+12
+10
+17
+17
+13
+14
+11
+12
+10
+11
+12
+13
+16
+19
+19
+17
+11
+13
+11
+12
+10
+9
+11
+14
+19
+17
+12
+15
+12
+9
+13
+12
+12
+11
+13
+13
+11
+12
+12
+19
+10
+9
+17
+10
+11
+17
+11
+11
+11
+2
+17
+11
+11
+13
+11
+12
+10
+14
+17
+17
+19
+13
+12
+15
+11
+12
+12
+11
+11
+12
+11
+11
+19
+17
+10
+9
+13
+19
+10
+14
+11
+19
+17
+17
+11
+12
+10
+12
+10
+16
+11
+12
+19
+11
+11
+19
+12
+12
+12
+11
+16
+17
+10
+17
+19
+18
+17
+11
+11
+10
+12
+11
+2
+11
+11
+15
+14
+11
+17
+11
+2
+12
+10
+19
+17
+2
+19
+11
+11
+17
+11
+19
+11
+2
+16
+12
+9
+9
+11
+15
+17
+11
+11
+11
+12
+17
+10
+15
+12
+12
+11
+12
+14
+9
+17
+9
+19
+13
+11
+12
+9
+17
+11
+11
+19
+17
+10
+11
+17
+11
+10
+19
+10
+12
+12
+10
+14
+13
+11
+12
+7
+11
+16
+13
+10
+12
+10
+12
+11
+14
+17
+9
+11
+13
+11
+12
+12
+19
+12
+11
+11
+13
+9
+10
+11
+11
+16
+17
+17
+7
+10
+10
+11
+13
+13
+11
+2
+10
+19
+19
+12
+19
+19
+17
+19
+11
+17
+11
+10
+13
+12
+11
+10
+10
+13
+11
+11
+10
+13
+11
+17
+11
+11
+19
+17
+11
+11
+10
+19
+2
+17
+19
+12
+13
+7
+13
+14
+17
+11
+15
+19
+11
+11
+17
+18
+19
+12
+2
+18
+17
+19
+11
+18
+13
+15
+13
+12
+9
+10
+2
+18
+16
+11
+6
+11
+11
+11
+11
+16
+19
+19
+11
+19
+18
+10
+19
+19
+19
+12
+13
+12
+11
+12
+10
+11
+17
+15
+9
+15
+12
+14
+12
+11
+11
+14
+11
+10
+12
+11
+11
+10
+11
+11
+12
+19
+11
+10
+13
+11
+12
+14
+11
+13
+13
+11
+12
+14
+17
+11
+10
+11
+12
+11
+11
+11
+11
+2
+12
+12
+13
+13
+17
+14
+13
+12
+19
+11
+11
+11
+13
+13
+10
+13
+11
+11
+12
+13
+11
+11
+11
+2
+11
+18
+11
+11
+11
+11
+11
+19
+9
+18
+11
+13
+12
+13
+11
+9
+2
+19
+10
+18
+18
+11
+11
+11
+19
+19
+19
+18
+10
+11
+10
+12
+11
+10
+12
+10
+19
+2
+18
+11
+10
+10
+2
+11
+16
+15
+17
+19
+17
+11
+11
+17
+12
+8
+11
+19
+12
+14
+12
+14
+11
+12
+10
+19
+11
+19
+17
+10
+18
+19
+2
+18
+15
+19
+11
+19
+12
+15
+10
+13
+13
+12
+11
+13
+11
+11
+11
+11
+19
+11
+11
+16
+18
+11
+11
+2
+11
+18
+2
+11
+13
+7
+11
+9
+14
+13
+12
+15
+19
+19
+11
+15
+19
+19
+11
+10
+11
+17
+12
+13
+13
+13
+11
+17
+11
+12
+14
+15
+11
+11
+13
+11
+11
+12
+11
+11
+11
+19
+10
+17
+11
+11
+18
+11
+11
+10
+10
+15
+12
+11
+11
+13
+10
+13
+11
+10
+12
+12
+11
+10
+11
+10
+11
+16
+10
+15
+13
+18
+11
+11
+11
+10
+12
+14
+12
+12
+14
+12
+9
+13
+11
+10
+10
+11
+11
+11
+12
+14
+9
+10
+10
+18
+11
+14
+14
+9
+11
+10
+15
+9
+12
+11
+10
+16
+11
+10
+14
+12
+12
+13
+11
+11
+11
+2
+11
+17
+13
+11
+11
+15
+18
+18
+19
+19
+19
+13
+12
+17
+12
+12
+19
+12
+11
+17
+10
+11
+12
+18
+11
+12
+12
+12
+12
+18
+10
+19
+11
+18
+11
+12
+17
+11
+18
+11
+13
+12
+15
+14
+11
+10
+14
+10
+19
+19
+11
+13
+8
+2
+2
+16
+11
+11
+13
+10
+13
+13
+10
+14
+11
+11
+10
+18
+11
+11
+12
+13
+11
+11
+9
+13
+10
+11
+10
+11
+11
+19
+10
+12
+11
+10
+10
+13
+13
+11
+19
+11
+13
+12
+11
+12
+10
+12
+12
+17
+11
+9
+12
+16
+12
+12
+2
+12
+11
+16
+16
+11
+13
+11
+12
+2
+11
+14
+10
+11
+17
+16
+12
+19
+19
+17
+11
+11
+11
+9
+14
+11
+11
+11
+11
+11
+15
+11
+14
+12
+10
+16
+11
+12
+11
+11
+15
+12
+11
+16
+11
+11
+12
+12
+13
+8
+10
+19
+11
+17
+12
+13
+12
+8
+17
+13
+15
+17
+7
+9
+17
+10
+16
+6
+10
+12
+15
+16
+11
+5
+13
+9
+13
+5
+9
+9
+5
+9
+4
+3
+13
+7
+3
+3
+14
+4
+13
+4
+4
+14
+19
+19
+15
+14
+19
+11
+16
+15
+14
+18
+9
+5
+4
+13
+4
+12
+3
+13
+13
+2
+17
+13
+14
+19
+10
+12
+9
+6
+15
+5
+5
+15
+4
+13
+4
+13
+4
+4
+13
+4
+13
+3
+4
+13
+4
+13
+3
+2
+13
+4
+13
+4
+3
+4
+13
+3
+3
+13
+3
+3
+13
+4
+13
+3
+4
+13
+2
+4
+14
+13
+14
+19
+10
+15
+13
+14
+19
+10
+13
+11
+10
+15
+5
+6
+13
+4
+13
+4
+13
+3
+2
+13
+4
+13
+3
+2
+10
+3
+2
+13
+3
+2
+13
+4
+13
+3
+4
+13
+4
+13
+4
+2
+3
+13
+3
+3
+13
+3
+4
+13
+3
+2
+12
+3
+4
+13
+4
+13
+2
+2
+13
+14
+19
+19
+15
+13
+19
+19
+15
+12
+15
+5
+4
+13
+4
+13
+3
+13
+13
+19
+17
+13
+13
+19
+17
+11
+7
+7
+15
+5
+5
+15
+6
+15
+4
+13
+3
+4
+13
+4
+13
+3
+2
+13
+3
+2
+13
+3
+3
+13
+3
+12
+8
+3
+3
+13
+2
+2
+13
+4
+4
+13
+3
+13
+11
+3
+2
+13
+3
+12
+9
+14
+19
+15
+14
+19
+15
+13
+19
+15
+13
+19
+13
+12
+18
+8
+17
+8
+17
+8
+16
+6
+15
+6
+15
+6
+15
+6
+15
+4
+4
+14
+6
+15
+6
+15
+6
+16
+6
+15
+6
+15
+4
+4
+14
+6
+15
+6
+15
+6
+15
+5
+15
+6
+15
+4
+13
+10
+6
+15
+6
+15
+4
+6
+15
+6
+15
+6
+15
+4
+13
+9
+6
+15
+6
+15
+6
+15
+6
+15
+6
+15
+3
+4
+14
+13
+13
+19
+17
+13
+13
+19
+17
+12
+9
+6
+15
+5
+5
+15
+6
+13
+4
+13
+3
+3
+13
+4
+13
+3
+3
+13
+3
+2
+13
+3
+2
+13
+4
+13
+3
+4
+13
+3
+13
+3
+4
+13
+4
+2
+2
+2
+11
+5
+3
+0
+2
+11
+5
+4
+4
+3
+2
+2
+2
+11
+7
+5
+2
+2
+12
+11
+9
+5
+4
+4
+3
+2
+2
+11
+5
+2
+2
+12
+11
+9
+5
+4
+4
+3
+2
+2
+2
+11
+9
+2
+0
+0
+11
+7
+5
+4
+4
+4
+3
+2
+2
+12
+11
+9
+7
+3
+2
+2
+12
+11
+9
+5
+4
+4
+3
+2
+0
+12
+11
+8
+5
+2
+0
+12
+11
+9
+5
+4
+4
+3
+2
+2
+2
+11
+7
+5
+3
+2
+2
+11
+6
+4
+4
+3
+2
+2
+2
+11
+5
+3
+2
+2
+11
+7
+5
+4
+4
+3
+2
+2
+2
+12
+11
+9
+5
+2
+2
+11
+8
+4
+4
+3
+2
+2
+12
+11
+9
+5
+2
+2
+12
+11
+5
+4
+4
+3
+2
+12
+11
+9
+3
+2
+2
+11
+9
+7
+4
+4
+4
+3
+2
+2
+11
+9
+6
+3
+2
+2
+11
+7
+4
+4
+4
+3
+0
+0
+11
+9
+5
+2
+2
+2
+2
+11
+5
+4
+4
+3
+2
+2
+12
+11
+7
+3
+2
+2
+11
+10
+4
+4
+3
+2
+2
+11
+5
+3
+2
+2
+11
+7
+4
+4
+4
+3
+2
+2
+12
+11
+5
+3
+2
+2
+12
+11
+9
+5
+4
+4
+3
+2
+2
+11
+7
+3
+2
+2
+11
+5
+4
+4
+4
+3
+2
+2
+12
+11
+7
+3
+2
+2
+11
+9
+4
+4
+3
+2
+2
+11
+4
+3
+2
+2
+11
+9
+7
+4
+4
+4
+3
+2
+2
+11
+5
+3
+2
+2
+11
+7
+4
+4
+4
+3
+2
+2
+12
+11
+7
+3
+2
+2
+11
+9
+7
+5
+4
+4
+3
+2
+2
+12
+11
+8
+5
+3
+2
+2
+11
+7
+4
+4
+4
+3
+2
+2
+11
+7
+3
+2
+2
+2
+11
+5
+4
+4
+3
+2
+2
+11
+5
+2
+2
+2
+11
+8
+5
+4
+4
+4
+3
+2
+2
+11
+7
+3
+2
+2
+2
+11
+7
+4
+4
+3
+2
+2
+11
+7
+2
+2
+11
+6
+4
+4
+4
+3
+2
+2
+11
+5
+2
+2
+11
+5
+4
+4
+4
+3
+2
+2
+12
+11
+5
+3
+2
+0
+11
+4
+4
+4
+3
+2
+2
+11
+5
+3
+2
+2
+12
+11
+4
+4
+3
+2
+2
+2
+11
+7
+3
+2
+2
+11
+9
+4
+4
+3
+2
+2
+2
+12
+11
+5
+2
+2
+11
+9
+7
+4
+4
+3
+2
+2
+11
+3
+2
+2
+11
+7
+4
+4
+4
+2
+2
+11
+3
+2
+2
+11
+7
+4
+4
+3
+2
+2
+0
+11
+5
+2
+0
+12
+11
+7
+4
+4
+3
+2
+2
+11
+9
+5
+2
+2
+12
+11
+7
+5
+4
+4
+3
+2
+2
+2
+11
+7
+2
+0
+11
+6
+5
+4
+4
+4
+3
+2
+2
+11
+9
+5
+3
+2
+2
+11
+7
+4
+4
+4
+2
+2
+11
+9
+3
+2
+2
+11
+9
+4
+4
+3
+2
+2
+11
+9
+5
+2
+2
+11
+7
+4
+4
+4
+3
+2
+2
+11
+5
+3
+2
+2
+12
+11
+7
+5
+4
+4
+3
+2
+2
+12
+11
+5
+3
+2
+2
+12
+11
+5
+4
+4
+3
+2
+2
+12
+11
+7
+5
+3
+2
+2
+12
+11
+9
+5
+4
+4
+3
+2
+2
+12
+11
+5
+3
+2
+2
+11
+9
+4
+4
+3
+2
+2
+7
+12
+11
+5
+4
+2
+2
+2
+12
+11
+9
+4
+4
+3
+2
+2
+2
Copied: SwiftApps/SciColSim/docs/plotit (from rev 5634, SwiftApps/SciColSim/plotit)
--- SwiftApps/SciColSim/docs/plotit	                        (rev 0)
+++ SwiftApps/SciColSim/docs/plotit	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,42 @@
+set terminal png enhanced
+#set term postscript eps enhanced
+#set terminal svg enhanced size 1000 1000
+#set style line 1 linecolor rgb "blue"
+set output "activeplot.png"
+set nokey
+set xlabel "Time in sec"
+set ylabel "number of active jobs"
+set title "Active jobs"
+plot "plot_active.txt" using 1:2 with line
+set output "cumulativeplot-openmp.png"
+set xlabel "Time in seconds"
+set ylabel "number of completed jobs"
+set title "Cumulative SciColSim-openMP jobs"
+plot "plot_cumulative.txt" using 1:($2*24) with lines
+set output "cumulativeplot.png"
+set title "Cumulative jobs"
+plot "plot_cumulative.txt" using 1:2 with lines
+set output "scs.png"
+set xlabel "Evolution"
+set ylabel "Value of T"
+set title "SciColSim evolution Results"
+plot "T.data" using 1 with lines
+set output "scs_loss.png"
+set title "SciColSim evolution loss Results"
+set ylabel "Value of loss(AR)"
+plot "anneal.data" using 1 with lines
+set output "multiloss.png"
+set key auto
+set yrange [0:200]
+set ylabel "loss"
+plot "multiloss.txt" using 3 with lines title "multiloss mean val",  "multiloss.txt" using ($3+$4) with lines title "+stddev", "multiloss.txt" using ($3-$4) with lines title "-stddev"
Copied: SwiftApps/SciColSim/docs/sample.swift.output (from rev 5634, SwiftApps/SciColSim/sample.swift.output)
--- SwiftApps/SciColSim/docs/sample.swift.output	                        (rev 0)
+++ SwiftApps/SciColSim/docs/sample.swift.output	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,528 @@
+Swift 0.93 swift-r5483 cog-r3339
+RunID: 20120130-1217-63kot916
+Progress:  time: Mon, 30 Jan 2012 12:17:12 -0600
+multi_loss appCalls=1
+multi_loss: entered: ci=0 cj=0 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.0,50.0,-1.0]
+multi_annealing: AR: i=1 ....T = 2.0
+multi_loss: i=1 calling evolve, args=[0,0,4,50,-1,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:16 -0600  Checking status:1
+multi_annealing: AR: initial: 124.861101 +- 3.21017
+multi_loss: returning: ci=0 cj=0 r.loss=124.861101 r.sdev=3.21017
+multi_annealing: AR: 4.017889129124014 2
+multi_loss: entered: ci=1 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.017889129124014,50.0,-1.0]
+multi_loss: i=1 calling evolve, args=[0,0,4.017889129124014,50,-1,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:19 -0600  Checking status:1  Finished successfully:2
+multi_annealing: AR: 124.117401 +- 3.306
+multi_loss: returning: ci=1 cj=2 r.loss=124.117401 r.sdev=3.306
+multi_annealing: AF: best_opt_some.txt: 58.0,124.117401,0.0,0.0,4.017889129124014,50.0,-1.0,3.306
+multi_annealing: AR: 0.3916097778073887 vs 1.0
+math/min: result=1.0
+multi_annealing: AF: max_dist.txt - tbd
+multi_annealing: Accepting try_x[j], i=1 j=2
+multi_annealing: Accepting try_x[j], i=1 j=2 try_x[j]=4.017889129124014
+multi_annealing: AR: [1][2] Rejection counts: 0.0 0.0 0.0 0.0 0.0
+multi_annealing: AR: 1 ***** Did accept! 0.0 0.0 4.017889129124014 50.0 -1.0
+multi_annealing: AR: 48.711529653164106 3
+multi_loss: entered: ci=1 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.017889129124014,48.711529653164106,-1.0]
+multi_loss: i=1 calling evolve, args=[0,0,4.017889129124014,48.711529653164106,-1,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:22 -0600  Checking status:1  Finished successfully:4
+multi_annealing: AR: 125.18271 +- 3.599503
+multi_loss: returning: ci=1 cj=3 r.loss=125.18271 r.sdev=3.599503
+multi_annealing: AF: best_opt_some.txt: 58.0,125.18271,0.0,0.0,4.017889129124014,48.711529653164106,-1.0,3.599503
+multi_annealing: AR: 0.29338527075939624 vs 0.5870445897168992
+math/min: result=0.5870445897168992
+multi_annealing: Accepting try_x[j], i=1 j=3 try_x[j]=48.711529653164106
+multi_annealing: AR: 1 ***** Did accept! 0.0 0.0 4.017889129124014 48.711529653164106 -1.0
+multi_annealing: AR: [1][3] Rejection counts: 0.0 0.0 0.0 0.0 0.0
+multi_annealing: AR: -0.0033614536445253362 4
+multi_loss: entered: ci=1 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.017889129124014,48.711529653164106,-0.0033614536445253362]
+multi_loss: i=1 calling evolve, args=[0,0,4.017889129124014,48.711529653164106,-0.0033614536445253362,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:26 -0600  Checking status:1  Finished successfully:6
+multi_annealing: AR: 125.933179 +- 3.36805
+multi_loss: returning: ci=1 cj=4 r.loss=125.933179 r.sdev=3.36805
+multi_annealing: AF: best_opt_some.txt: 58.0,125.933179,0.0,0.0,4.017889129124014,48.711529653164106,-0.0033614536445253362,3.36805
+multi_annealing: AR: 0.6647548795660121 vs 0.6871281283507249
+math/min: result=0.6871281283507249
+multi_annealing: Accepting try_x[j], i=1 j=4
+multi_annealing: Accepting try_x[j], i=1 j=4 try_x[j]=-0.0033614536445253362
+multi_annealing: AR: 1 ***** Did accept! 0.0 0.0 4.017889129124014 48.711529653164106 -0.0033614536445253362
+multi_annealing: AR: [1][4] Rejection counts: 0.0 0.0 0.0 0.0 0.0
+multi_annealing: AR: i=2 ....T = 1.6762121943865207
+multi_annealing: AR: 5.284753614883805 2
+multi_loss: entered: ci=2 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.711529653164106,-0.0033614536445253362]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.711529653164106,-0.0033614536445253362,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:29 -0600  Checking status:1  Finished successfully:8
+multi_annealing: AR: 126.145367 +- 3.119133
+multi_loss: returning: ci=2 cj=2 r.loss=126.145367 r.sdev=3.119133
+multi_annealing: AF: best_opt_some.txt: 58.0,126.145367,0.0,0.0,5.284753614883805,48.711529653164106,-0.0033614536445253362,3.119133
+multi_annealing: AR: 0.8343453829181197 vs 0.8810967932193764
+math/min: result=0.8810967932193764
+multi_annealing: Accepting try_x[j], i=2 j=2 try_x[j]=5.284753614883805
+multi_annealing: AR: 2 ***** Did accept! 0.0 0.0 5.284753614883805 48.711529653164106 -0.0033614536445253362
+multi_annealing: AR: [2][2] Rejection counts: 0.0 0.0 0.0 0.0 0.0
+multi_annealing: AR: 47.49006278600924 3
+multi_loss: entered: ci=2 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,-0.0033614536445253362]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,-0.0033614536445253362,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:33 -0600  Checking status:1  Finished successfully:10
+multi_annealing: AR: 125.831434 +- 3.344003
+multi_loss: returning: ci=2 cj=3 r.loss=125.831434 r.sdev=3.344003
+multi_annealing: AF: best_opt_some.txt: 58.0,125.831434,0.0,0.0,5.284753614883805,47.49006278600924,-0.0033614536445253362,3.344003
+multi_annealing: AR: 0.7961447191161577 vs 1.0
+multi_annealing: Accepting try_x[j], i=2 j=3
+multi_annealing: Accepting try_x[j], i=2 j=3 try_x[j]=47.49006278600924
+multi_annealing: AR: 2 ***** Did accept! 0.0 0.0 5.284753614883805 47.49006278600924 -0.0033614536445253362
+multi_annealing: AR: [2][3] Rejection counts: 0.0 0.0 0.0 0.0 0.0
+multi_annealing: AR: 0.2830038287653472 4
+multi_loss: entered: ci=2 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,0.2830038287653472]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,0.2830038287653472,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:36 -0600  Checking status:1  Finished successfully:12
+multi_annealing: AR: 123.989674 +- 3.372759
+multi_loss: returning: ci=2 cj=4 r.loss=123.989674 r.sdev=3.372759
+multi_annealing: AF: best_opt_some.txt: 58.0,123.989674,0.0,0.0,5.284753614883805,47.49006278600924,0.2830038287653472,3.372759
+multi_annealing: AR: 0.19911890147442235 vs 1.0
+multi_annealing: Accepting try_x[j], i=2 j=4
+multi_annealing: Accepting try_x[j], i=2 j=4 try_x[j]=0.2830038287653472
+multi_annealing: AR: [2][4] Rejection counts: 0.0 0.0 0.0 0.0 0.0
+multi_annealing: AR: 2 ***** Did accept! 0.0 0.0 5.284753614883805 47.49006278600924 0.2830038287653472
+multi_annealing: AR: i=3 ....T = 1.4048436603050374
+multi_annealing: AR: 6.751519052449282 2
+multi_loss: entered: ci=3 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,6.751519052449282,47.49006278600924,0.2830038287653472]
+multi_loss: i=1 calling evolve, args=[0,0,6.751519052449282,47.49006278600924,0.2830038287653472,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:39 -0600  Checking status:1  Finished successfully:14
+multi_loss: returning: ci=3 cj=2 r.loss=125.83918 r.sdev=3.276288
+multi_annealing: AR: 125.83918 +- 3.276288
+multi_annealing: AF: best_opt_some.txt: 58.0,125.83918,0.0,0.0,6.751519052449282,47.49006278600924,0.2830038287653472,3.276288
+math/min: result=0.2680663186298088
+multi_annealing: AR: 3,2 3 Did not accept: 6.751519052449282 (2)
+multi_annealing: AR: 0.6852396383450929 vs 0.2680663186298088
+multi_annealing: AR: 0.0 0.0 6.751519052449282 47.49006278600924 0.2830038287653472
+multi_annealing: AR: 49.01109219848105 3
+multi_loss: entered: ci=3 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,49.01109219848105,0.2830038287653472]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,49.01109219848105,0.2830038287653472,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:42 -0600  Checking status:1  Finished successfully:16
+multi_loss: returning: ci=3 cj=3 r.loss=126.260409 r.sdev=3.474799
+multi_annealing: AF: best_opt_some.txt: 58.0,126.260409,0.0,0.0,5.284753614883805,49.01109219848105,0.2830038287653472,3.474799
+multi_annealing: AR: 126.260409 +- 3.474799
+math/min: result=0.1986200941793068
+multi_annealing: AR: 0.6989515725257741 vs 0.1986200941793068
+multi_annealing: AR: 3,3 3 Did not accept: 49.01109219848105 (3)
+multi_annealing: AR: 0.0 0.0 5.284753614883805 49.01109219848105 0.2830038287653472
+multi_annealing: AR: 0.7184988677898592 4
+multi_loss: entered: ci=3 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,0.7184988677898592]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:45 -0600  Checking status:1  Finished successfully:18
+multi_loss: returning: ci=3 cj=4 r.loss=123.593465 r.sdev=3.286319
+multi_annealing: AR: 123.593465 +- 3.286319
+multi_annealing: AF: best_opt_some.txt: 58.0,123.593465,0.0,0.0,5.284753614883805,47.49006278600924,0.7184988677898592,3.286319
+multi_annealing: AR: 0.10970841947076293 vs 1.0
+multi_annealing: Accepting try_x[j], i=3 j=4
+multi_annealing: Accepting try_x[j], i=3 j=4 try_x[j]=0.7184988677898592
+multi_annealing: AR: 3 ***** Did accept! 0.0 0.0 5.284753614883805 47.49006278600924 0.7184988677898592
+multi_annealing: AR: [3][4] Rejection counts: 0.0 0.0 1.0 1.0 0.0
+multi_annealing: AR: i=4 ....T = 1.1774080373049494
+multi_annealing: AR: 4.4255186274220115 2
+multi_loss: entered: ci=4 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.4255186274220115,47.49006278600924,0.7184988677898592]
+multi_loss: i=1 calling evolve, args=[0,0,4.4255186274220115,47.49006278600924,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:49 -0600  Checking status:1  Finished successfully:20
+multi_loss: returning: ci=4 cj=2 r.loss=126.444622 r.sdev=3.25147
+multi_annealing: AR: 126.444622 +- 3.25147
+multi_annealing: AF: best_opt_some.txt: 58.0,126.444622,0.0,0.0,4.4255186274220115,47.49006278600924,0.7184988677898592,3.25147
+multi_annealing: AR: 0.9535428038358379 vs 0.08878355131476454
+math/min: result=0.08878355131476454
+multi_annealing: AR: 4,2 4 Did not accept: 4.4255186274220115 (2)
+multi_annealing: AR: 0.0 0.0 4.4255186274220115 47.49006278600924 0.7184988677898592
+multi_annealing: AR: 46.92686166375319 3
+multi_loss: entered: ci=4 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,46.92686166375319,0.7184988677898592]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,46.92686166375319,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:52 -0600  Checking status:1  Finished successfully:22
+multi_annealing: AR: 124.963375 +- 3.41926
+multi_loss: returning: ci=4 cj=3 r.loss=124.963375 r.sdev=3.41926
+multi_annealing: AF: best_opt_some.txt: 58.0,124.963375,0.0,0.0,5.284753614883805,46.92686166375319,0.7184988677898592,3.41926
+multi_annealing: AR: 0.4500207377949753 vs 0.312392025102438
+math/min: result=0.312392025102438
+multi_annealing: AR: 4,3 4 Did not accept: 46.92686166375319 (3)
+multi_annealing: AR: 0.0 0.0 5.284753614883805 46.92686166375319 0.7184988677898592
+multi_annealing: AR: -0.3320316742658884 4
+multi_loss: entered: ci=4 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,-0.3320316742658884]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,-0.3320316742658884,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:55 -0600  Checking status:1  Finished successfully:24
+multi_annealing: AR: 125.407828 +- 3.018498
+multi_loss: returning: ci=4 cj=4 r.loss=125.407828 r.sdev=3.018498
+multi_annealing: AF: best_opt_some.txt: 58.0,125.407828,0.0,0.0,5.284753614883805,47.49006278600924,-0.3320316742658884,3.018498
+multi_annealing: AR: 0.8555641933973892 vs 0.21417097212905944
+math/min: result=0.21417097212905944
+multi_annealing: AR: 0.0 0.0 5.284753614883805 47.49006278600924 -0.3320316742658884
+multi_annealing: AR: 4,4 4 Did not accept: -0.3320316742658884 (4)
+multi_annealing: AR: i=5 ....T = 0.9867928549496278
+multi_annealing: AR: 6.833327620921641 2
+multi_loss: entered: ci=5 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,6.833327620921641,47.49006278600924,0.7184988677898592]
+multi_loss: i=1 calling evolve, args=[0,0,6.833327620921641,47.49006278600924,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:17:58 -0600  Checking status:1  Finished successfully:26
+multi_annealing: AR: 125.250487 +- 3.078819
+multi_loss: returning: ci=5 cj=2 r.loss=125.250487 r.sdev=3.078819
+multi_annealing: AF: best_opt_some.txt: 58.0,125.250487,0.0,0.0,6.833327620921641,47.49006278600924,0.7184988677898592,3.078819
+multi_annealing: AR: 0.44288167684075663 vs 0.18652324111077032
+math/min: result=0.18652324111077032
+multi_annealing: AR: 5,2 5 Did not accept: 6.833327620921641 (2)
+multi_annealing: AR: 0.0 0.0 6.833327620921641 47.49006278600924 0.7184988677898592
+multi_annealing: AR: 46.49027442733761 3
+multi_loss: entered: ci=5 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,46.49027442733761,0.7184988677898592]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,46.49027442733761,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:01 -0600  Checking status:1  Finished successfully:28
+multi_annealing: AR: 124.663101 +- 3.485893
+multi_loss: returning: ci=5 cj=3 r.loss=124.663101 r.sdev=3.485893
+multi_annealing: AF: best_opt_some.txt: 58.0,124.663101,0.0,0.0,5.284753614883805,46.49027442733761,0.7184988677898592,3.485893
+multi_annealing: AR: 0.42913823795768913 vs 0.33825612299835406
+math/min: result=0.33825612299835406
+multi_annealing: AR: 0.0 0.0 5.284753614883805 46.49027442733761 0.7184988677898592
+multi_annealing: AR: 5,3 5 Did not accept: 46.49027442733761 (3)
+multi_annealing: AR: 2.2333217492423234 4
+multi_loss: entered: ci=5 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,2.2333217492423234]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,2.2333217492423234,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:05 -0600  Checking status:1  Finished successfully:30
+multi_annealing: AR: 125.856136 +- 3.415745
+multi_loss: returning: ci=5 cj=4 r.loss=125.856136 r.sdev=3.415745
+multi_annealing: AF: best_opt_some.txt: 58.0,125.856136,0.0,0.0,5.284753614883805,47.49006278600924,2.2333217492423234,3.415745
+multi_annealing: AR: 0.5684553851797784 vs 0.10096772364295076
+math/min: result=0.10096772364295076
+multi_annealing: AR: 5,4 5 Did not accept: 2.2333217492423234 (4)
+multi_annealing: AR: 0.0 0.0 5.284753614883805 47.49006278600924 2.2333217492423234
+multi_annealing: AR: i=6 ....T = 0.8270371084000275
+multi_annealing: AR: 3.928981105935937 2
+multi_loss: entered: ci=6 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,3.928981105935937,47.49006278600924,0.7184988677898592]
+multi_loss: i=1 calling evolve, args=[0,0,3.928981105935937,47.49006278600924,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:08 -0600  Checking status:1  Finished successfully:32
+multi_annealing: AR: 125.944813 +- 3.343539
+multi_loss: returning: ci=6 cj=2 r.loss=125.944813 r.sdev=3.343539
+multi_annealing: AR: 0.0737231873586417 vs 0.05824491156028037
+multi_annealing: AF: best_opt_some.txt: 58.0,125.944813,0.0,0.0,3.928981105935937,47.49006278600924,0.7184988677898592,3.343539
+multi_annealing: AR: 6,2 6 Did not accept: 3.928981105935937 (2)
+math/min: result=0.05824491156028037
+multi_annealing: AR: 0.0 0.0 3.928981105935937 47.49006278600924 0.7184988677898592
+multi_annealing: AR: 47.456980868107266 3
+multi_loss: entered: ci=6 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.456980868107266,0.7184988677898592]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.456980868107266,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:11 -0600  Checking status:1  Finished successfully:34
+multi_annealing: AR: 126.604462 +- 3.183016
+multi_loss: returning: ci=6 cj=3 r.loss=126.604462 r.sdev=3.183016
+multi_annealing: AR: 0.5487345599809303 vs 0.02623387861162342
+math/min: result=0.02623387861162342
+multi_annealing: AF: best_opt_some.txt: 58.0,126.604462,0.0,0.0,5.284753614883805,47.456980868107266,0.7184988677898592,3.183016
+multi_annealing: AR: 6,3 6 Did not accept: 47.456980868107266 (3)
+multi_annealing: AR: 0.0 0.0 5.284753614883805 47.456980868107266 0.7184988677898592
+multi_loss: entered: ci=6 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,-1.5302000464747076]
+multi_annealing: AR: -1.5302000464747076 4
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,-1.5302000464747076,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:12 -0600  Active:1  Finished successfully:36
+Progress:  time: Mon, 30 Jan 2012 12:18:14 -0600  Checking status:1  Finished successfully:36
+multi_loss: returning: ci=6 cj=4 r.loss=125.062511 r.sdev=3.22833
+multi_annealing: AR: 125.062511 +- 3.22833
+multi_annealing: AF: best_opt_some.txt: 58.0,125.062511,0.0,0.0,5.284753614883805,47.49006278600924,-1.5302000464747076,3.22833
+multi_annealing: AR: 0.4295446121391554 vs 0.16926736066405584
+math/min: result=0.16926736066405584
+multi_annealing: AR: 6,4 6 Did not accept: -1.5302000464747076 (4)
+multi_annealing: AR: 0.0 0.0 5.284753614883805 47.49006278600924 -1.5302000464747076
+multi_annealing: AR: i=7 ....T = 0.6931448431551464
+multi_annealing: AR: 5.698890855198198 2
+multi_loss: entered: ci=7 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.698890855198198,47.49006278600924,0.7184988677898592]
+multi_loss: i=1 calling evolve, args=[0,0,5.698890855198198,47.49006278600924,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:17 -0600  Checking status:1  Finished successfully:38
+multi_annealing: AR: 124.92233 +- 3.519439
+multi_loss: returning: ci=7 cj=2 r.loss=124.92233 r.sdev=3.519439
+multi_annealing: AF: best_opt_some.txt: 58.0,124.92233,0.0,0.0,5.698890855198198,47.49006278600924,0.7184988677898592,3.519439
+multi_annealing: AR: 0.26061833782383614 vs 0.14702488652213752
+math/min: result=0.14702488652213752
+multi_annealing: AR: 7,2 7 Did not accept: 5.698890855198198 (2)
+multi_annealing: AR: 0.0 0.0 5.698890855198198 47.49006278600924 0.7184988677898592
+multi_annealing: AR: 48.00451051760781 3
+multi_loss: entered: ci=7 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,0.7184988677898592]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:21 -0600  Checking status:1  Finished successfully:40
+multi_annealing: AR: 123.700997 +- 3.061641
+multi_loss: returning: ci=7 cj=3 r.loss=123.700997 r.sdev=3.061641
+multi_annealing: AF: best_opt_some.txt: 58.0,123.700997,0.0,0.0,5.284753614883805,48.00451051760781,0.7184988677898592,3.061641
+multi_annealing: AR: 0.04383216320955852 vs 0.8562983650405412
+math/min: result=0.8562983650405412
+multi_annealing: Accepting try_x[j], i=7 j=3
+multi_annealing: Accepting try_x[j], i=7 j=3 try_x[j]=48.00451051760781
+multi_annealing: AR: 7 ***** Did accept! 0.0 0.0 5.284753614883805 48.00451051760781 0.7184988677898592
+multi_annealing: AR: [7][3] Rejection counts: 0.0 0.0 5.0 4.0 3.0
+multi_annealing: AR: -0.41452399887346414 4
+multi_loss: entered: ci=7 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,-0.41452399887346414]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:24 -0600  Checking status:1  Finished successfully:42
+multi_annealing: AR: 122.427501 +- 3.484433
+multi_loss: returning: ci=7 cj=4 r.loss=122.427501 r.sdev=3.484433
+multi_annealing: AR: 0.6794911655574871 vs 1.0
+multi_annealing: AF: best_opt_some.txt: 58.0,122.427501,0.0,0.0,5.284753614883805,48.00451051760781,-0.41452399887346414,3.484433
+multi_annealing: Accepting try_x[j], i=7 j=4
+multi_annealing: Accepting try_x[j], i=7 j=4 try_x[j]=-0.41452399887346414
+multi_annealing: AR: [7][4] Rejection counts: 0.0 0.0 5.0 4.0 3.0
+multi_annealing: AR: 7 ***** Did accept! 0.0 0.0 5.284753614883805 48.00451051760781 -0.41452399887346414
+multi_annealing: AR: i=8 ....T = 0.5809289192863943
+multi_annealing: AR: 4.228373615739721 2
+multi_loss: entered: ci=8 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.228373615739721,48.00451051760781,-0.41452399887346414]
+multi_loss: i=1 calling evolve, args=[0,0,4.228373615739721,48.00451051760781,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:27 -0600  Checking status:1  Finished successfully:44
+multi_loss: returning: ci=8 cj=2 r.loss=125.825434 r.sdev=3.06081
+multi_annealing: AR: 125.825434 +- 3.06081
+multi_annealing: AF: best_opt_some.txt: 58.0,125.825434,0.0,0.0,4.228373615739721,48.00451051760781,-0.41452399887346414,3.06081
+multi_annealing: AR: 0.43307949429152304 vs 0.0028823847709179276
+math/min: result=0.0028823847709179276
+multi_annealing: AR: 0.0 0.0 4.228373615739721 48.00451051760781 -0.41452399887346414
+multi_annealing: AR: 8,2 8 Did not accept: 4.228373615739721 (2)
+multi_annealing: AR: 46.894163840589215 3
+multi_loss: entered: ci=8 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,46.894163840589215,-0.41452399887346414]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,46.894163840589215,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:30 -0600  Checking status:1  Finished successfully:46
+multi_annealing: AR: 124.871719 +- 3.122439
+multi_loss: returning: ci=8 cj=3 r.loss=124.871719 r.sdev=3.122439
+multi_annealing: AF: best_opt_some.txt: 58.0,124.871719,0.0,0.0,5.284753614883805,46.894163840589215,-0.41452399887346414,3.122439
+multi_annealing: AR: 0.34644774801935974 vs 0.014884566500466245
+math/min: result=0.014884566500466245
+multi_annealing: AR: 0.0 0.0 5.284753614883805 46.894163840589215 -0.41452399887346414
+multi_annealing: AR: 8,3 8 Did not accept: 46.894163840589215 (3)
+multi_annealing: AR: -2.2286308752011443 4
+multi_loss: entered: ci=8 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,-2.2286308752011443]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,-2.2286308752011443,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:33 -0600  Checking status:1  Finished successfully:48
+multi_annealing: AR: 125.200576 +- 3.137099
+multi_loss: returning: ci=8 cj=4 r.loss=125.200576 r.sdev=3.137099
+multi_annealing: AF: best_opt_some.txt: 58.0,125.200576,0.0,0.0,5.284753614883805,48.00451051760781,-2.2286308752011443,3.137099
+multi_annealing: AR: 0.47163119315783886 vs 0.008450593550370632
+math/min: result=0.008450593550370632
+multi_annealing: AR: 8,4 8 Did not accept: -2.2286308752011443 (4)
+multi_annealing: AR: 0.0 0.0 5.284753614883805 48.00451051760781 -2.2286308752011443
+multi_annealing: AR: i=9 ....T = 0.48688006928981853
+multi_annealing: AR: 5.695013169826046 2
+multi_loss: entered: ci=9 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.695013169826046,48.00451051760781,-0.41452399887346414]
+multi_loss: i=1 calling evolve, args=[0,0,5.695013169826046,48.00451051760781,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:37 -0600  Checking status:1  Finished successfully:50
+multi_annealing: AR: 125.017227 +- 3.237815
+multi_loss: returning: ci=9 cj=2 r.loss=125.017227 r.sdev=3.237815
+multi_annealing: AF: best_opt_some.txt: 58.0,125.017227,0.0,0.0,5.695013169826046,48.00451051760781,-0.41452399887346414,3.237815
+multi_annealing: AR: 0.17076495981302242 vs 0.004897539166396153
+math/min: result=0.004897539166396153
+multi_annealing: AR: 9,2 9 Did not accept: 5.695013169826046 (2)
+multi_annealing: AR: 0.0 0.0 5.695013169826046 48.00451051760781 -0.41452399887346414
+multi_annealing: AR: 48.00679484464189 3
+multi_loss: entered: ci=9 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00679484464189,-0.41452399887346414]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00679484464189,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:40 -0600  Checking status:1  Finished successfully:52
+multi_annealing: AR: 125.213924 +- 3.333561
+multi_loss: returning: ci=9 cj=3 r.loss=125.213924 r.sdev=3.333561
+multi_annealing: AF: best_opt_some.txt: 58.0,125.213924,0.0,0.0,5.284753614883805,48.00679484464189,-0.41452399887346414,3.333561
+multi_annealing: AR: 0.15928070563724706 vs 0.003269830345111401
+math/min: result=0.003269830345111401
+multi_annealing: AR: 0.0 0.0 5.284753614883805 48.00679484464189 -0.41452399887346414
+multi_annealing: AR: 9,3 9 Did not accept: 48.00679484464189 (3)
+multi_annealing: AR: -0.7507963173758503 4
+multi_loss: entered: ci=9 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,-0.7507963173758503]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,-0.7507963173758503,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:42 -0600  Active:1  Finished successfully:54
+multi_loss: returning: ci=9 cj=4 r.loss=125.856406 r.sdev=3.764608
+multi_annealing: AR: 125.856406 +- 3.764608
+multi_annealing: AF: best_opt_some.txt: 58.0,125.856406,0.0,0.0,5.284753614883805,48.00451051760781,-0.7507963173758503,3.764608
+math/min: result=8.738454465360378E-4
+multi_annealing: AR: 0.061628429129563234 vs 8.738454465360378E-4
+multi_annealing: AR: 9,4 9 Did not accept: -0.7507963173758503 (4)
+multi_annealing: AR: 0.0 0.0 5.284753614883805 48.00451051760781 -0.7507963173758503
+multi_annealing: AR: i=10 ....T = 0.408057154673674
+multi_annealing: AR: 3.29267604969456 2
+multi_loss: entered: ci=10 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,3.29267604969456,48.00451051760781,-0.41452399887346414]
+multi_loss: i=1 calling evolve, args=[0,0,3.29267604969456,48.00451051760781,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:46 -0600  Checking status:1  Finished successfully:56
+multi_annealing: AR: 125.360364 +- 3.317013
+multi_loss: returning: ci=10 cj=2 r.loss=125.360364 r.sdev=3.317013
+multi_annealing: AF: best_opt_some.txt: 58.0,125.360364,0.0,0.0,3.29267604969456,48.00451051760781,-0.41452399887346414,3.317013
+multi_annealing: AR: 0.27027335203696023 vs 7.56065260977875E-4
+math/min: result=7.56065260977875E-4
+multi_annealing: AR: 0.0 0.0 3.29267604969456 48.00451051760781 -0.41452399887346414
+multi_annealing: AR: 10,2 10 Did not accept: 3.29267604969456 (2)
+multi_annealing: AR: 46.275556353155956 3
+multi_loss: entered: ci=10 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,46.275556353155956,-0.41452399887346414]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,46.275556353155956,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:49 -0600  Checking status:1  Finished successfully:58
+multi_annealing: AR: 126.434478 +- 3.246686
+multi_loss: returning: ci=10 cj=3 r.loss=126.434478 r.sdev=3.246686
+multi_annealing: AF: best_opt_some.txt: 58.0,126.434478,0.0,0.0,5.284753614883805,46.275556353155956,-0.41452399887346414,3.246686
+multi_annealing: AR: 0.14920802306232583 vs 5.4372803009239825E-5
+math/min: result=5.4372803009239825E-5
+multi_annealing: AR: 10,3 10 Did not accept: 46.275556353155956 (3)
+multi_annealing: AR: 0.0 0.0 5.284753614883805 46.275556353155956 -0.41452399887346414
+multi_annealing: AR: 1.5046793086101826 4
+multi_loss: entered: ci=10 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,1.5046793086101826]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,1.5046793086101826,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:53 -0600  Checking status:1  Finished successfully:60
+multi_loss: returning: ci=10 cj=4 r.loss=125.785376 r.sdev=3.346594
+multi_annealing: AR: 125.785376 +- 3.346594
+multi_annealing: AF: best_opt_some.txt: 58.0,125.785376,0.0,0.0,5.284753614883805,48.00451051760781,1.5046793086101826,3.346594
+multi_annealing: AR: 0.6250655950503741 vs 2.668208671281028E-4
+math/min: result=2.668208671281028E-4
+multi_annealing: AR: 0.0 0.0 5.284753614883805 48.00451051760781 1.5046793086101826
+multi_annealing: AR: 10,4 10 Did not accept: 1.5046793086101826 (4)
+multi_annealing: new cycle at i=11
+multi_annealing: AR: New cycle at 11: prev dx[0-4]=[2.3 2.3 2.3 2.3 2.3]
+multi_annealing: AR: i=11 ....T = 0.34199518933533946
+multi_annealing: AR: New cycle at 11: dx[0-4]=[4.6 4.6 0.8624999999999998 0.9857142857142855 1.15]
+multi_annealing: AR: 3.791705563626845 2
+multi_loss: entered: ci=11 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,3.791705563626845,48.00451051760781,-0.41452399887346414]
+multi_loss: i=1 calling evolve, args=[0,0,3.791705563626845,48.00451051760781,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:56 -0600  Checking status:1  Finished successfully:62
+multi_loss: returning: ci=11 cj=2 r.loss=124.596526 r.sdev=3.176561
+multi_annealing: AR: 124.596526 +- 3.176561
+multi_annealing: AF: best_opt_some.txt: 58.0,124.596526,0.0,0.0,3.791705563626845,48.00451051760781,-0.41452399887346414,3.176561
+multi_annealing: AR: 0.9715442940965933 vs 0.001760306082349071
+math/min: result=0.001760306082349071
+multi_annealing: AR: 0.0 0.0 3.791705563626845 48.00451051760781 -0.41452399887346414
+multi_annealing: AR: 11,2 11 Did not accept: 3.791705563626845 (2)
+multi_annealing: AR: 49.92607616034099 3
+multi_loss: entered: ci=11 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,49.92607616034099,-0.41452399887346414]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,49.92607616034099,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:18:59 -0600  Checking status:1  Finished successfully:64
+multi_annealing: AR: 124.00716 +- 3.111738
+multi_loss: returning: ci=11 cj=3 r.loss=124.00716 r.sdev=3.111738
+multi_annealing: AF: best_opt_some.txt: 58.0,124.00716,0.0,0.0,5.284753614883805,49.92607616034099,-0.41452399887346414,3.111738
+multi_annealing: AR: 0.38818246796613753 vs 0.009863137695174688
+math/min: result=0.009863137695174688
+multi_annealing: AR: 11,3 11 Did not accept: 49.92607616034099 (3)
+multi_annealing: AR: 0.0 0.0 5.284753614883805 49.92607616034099 -0.41452399887346414
+multi_annealing: AR: -0.7771568808805009 4
+multi_loss: entered: ci=11 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,-0.7771568808805009]
+multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,-0.7771568808805009,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
+Progress:  time: Mon, 30 Jan 2012 12:19:02 -0600  Checking status:1  Finished successfully:66
+multi_annealing: AR: 123.567412 +- 3.66859
+multi_loss: returning: ci=11 cj=4 r.loss=123.567412 r.sdev=3.66859
+multi_annealing: AF: best_opt_some.txt: 58.0,123.567412,0.0,0.0,5.284753614883805,48.00451051760781,-0.7771568808805009,3.66859
+multi_annealing: AR: 0.5338319788181374 vs 0.03568160518248377
+math/min: result=0.03568160518248377
+multi_annealing: AR: 11,4 11 Did not accept: -0.7771568808805009 (4)
+multi_annealing: AR: 0.0 0.0 5.284753614883805 48.00451051760781 -0.7771568808805009
+Progress:  time: Mon, 30 Jan 2012 12:19:12 -0600  Finished successfully:68
+No events in 10s.
+Registered futures:
+string[] args  Closed, 24 elements, no listeners
+Waiting threads:
+No events in 10s.
+Waiting threads:
+No events in 10s.
+Waiting threads:
+Progress:  time: Mon, 30 Jan 2012 12:19:42 -0600  Finished successfully:68
Copied: SwiftApps/SciColSim/docs/sample.testopt.py.output (from rev 5634, SwiftApps/SciColSim/sample.testopt.py.output)
--- SwiftApps/SciColSim/docs/sample.testopt.py.output	                        (rev 0)
+++ SwiftApps/SciColSim/docs/sample.testopt.py.output	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,243 @@
+**** Calling optimizer: OMP_NUM_THREADS=4 ./openmp-optimizer 0 0 4 50 -1 58 40000 20 100 2 1 2. 0.01 5 0.3 2.3 1 1 0 0 0 n 4 1234567
+alpha_i: 0
+alpha_m: 0
+beta: 4
+gamma: 50
+delta: -1
+target: 58
+n_epochs: 40000
+n_steps: 20
+n_reruns: 100
+range: 2
+verbose level: 1
+T_start: 2
+T_end: 0.01
+Annealing_steps: 5
+Target_rejection: 0.3
+Starting_jump: 2.3
+FREEZE_alpha_i: 1
+FREEZE_alpha_m: 1
+FREEZE_beta: 0
+FREEZE_gamma: 0
+FREEZE_delta: 0
+Operation: n
+Nworkers: 4
+initSeed: 1234567
+0 | 1 (fixed)
+1 | 1 (fixed)
+2 | 0 (fixed)
+3 | 0 (fixed)
+4 | 0 (fixed)
+0.742788 0.631704 0.118309 0.922271 0.141282 0.80831 0.961468 0.363704 0.665483 0.683465 0.771216 0.267925 0.224677 0.153439 0.23455 0.816502 0.718347 0.371612 0.948727 0.404154 0.600908 0.766305 0.493219 0.82445 0.100233 0.672304 0.157299 0.53804 0.6794 0.57498 0.758357 0.422188 0.206684 0.876666 0.344459 0.347966 0.684976 0.305927 0.71167 0.350459 0.989392 0.482885 0.618384 0.214069 0.636325 0.852934 0.0305713 0.354672 0.224546 0.979299 0.758825 0.825454 0.745604 0.252044 0.649904 0.845837 0.924348 0.807203 0.383877 0.603748 0.382183 0.142234 0.0259353 0.588867 0.0189005 0.370394 0.936833 0.703877 0.676321 0.648502 0.0543356 0.665713 0.131387 0.672719 0.879782 0.767712 0.525653 0.910353 0.122384 0.750199 0.889652 0.881209 0.575653 0.635256 0.133253 0.225557 0.481092 0.0576008 0.0327595 0.864969 0.661348 0.414942 0.00720323 0.687284 0.00380882 0.0261037 0.0576777 0.940641 0.72998 0.733998
+multi_loss: Calling evolve_to_target_and_save i=0 N=100 step=25 istart=0 iend=25
+multi_loss: Calling evolve_to_target_and_save i=1 N=100 step=25 istart=25 iend=50
+multi_loss: Calling evolve_to_target_and_save i=2 N=100 step=25 istart=50 iend=75
+multi_loss: Calling evolve_to_target_and_save i=3 N=100 step=25 istart=75 iend=100
+multi_loss(N=100, target=58) elapsed time: 2.9134 seconds 0.0485567 minutes
+126.43 +- 3.11244
+....T = 2
+3.77342 2
+multi_loss(N=100, target=58) elapsed time: 2.90873 seconds 0.0484788 minutes
+126.523 +- 3.32417
+0.82704 vs 0.954153
+1 Rejection counts: 0 0 0 0 0
+ 1,2 ***** Did accept! 0 0 3.77342 50 -1
+52.2335 3
+multi_loss(N=100, target=58) elapsed time: 2.93802 seconds 0.0489671 minutes
+130.173 +- 3.67201
+0.188468 vs 0.161259
+ 1,3 1 Did not accept 52.2335(3)
+0 0 3.77342 52.2335 -1
+-2.00667 4
+multi_loss(N=100, target=58) elapsed time: 2.95626 seconds 0.049271 minutes
+129.554 +- 3.1612
+0.88704 vs 0.219698
+ 1,4 1 Did not accept -2.00667(4)
+0 0 3.77342 50 -2.00667
+....T = 0.693145
+4.07035 2
+multi_loss(N=100, target=58) elapsed time: 2.99097 seconds 0.0498495 minutes
+130.603 +- 3.25174
+0.0501227 vs 0.00277796
+ 2,2 2 Did not accept 4.07035(2)
+0 0 4.07035 50 -1
+48.5261 3
+multi_loss(N=100, target=58) elapsed time: 2.94022 seconds 0.0490036 minutes
+128.508 +- 3.34913
+0.685387 vs 0.0571204
+ 2,3 2 Did not accept 48.5261(3)
+0 0 3.77342 48.5261 -1
+-2.2438 4
+multi_loss(N=100, target=58) elapsed time: 2.95557 seconds 0.0492594 minutes
+128.768 +- 3.41509
+0.579097 vs 0.0392132
+ 2,4 2 Did not accept -2.2438(4)
+0 0 3.77342 50 -2.2438
+....T = 0.240225
+2.54662 2
+multi_loss(N=100, target=58) elapsed time: 3.02841 seconds 0.0504735 minutes
+127.262 +- 3.06273
+0.274094 vs 0.0462924
+ 3,2 3 Did not accept 2.54662(2)
+0 0 2.54662 50 -1
+51.7319 3
+multi_loss(N=100, target=58) elapsed time: 3.00121 seconds 0.0500201 minutes
+128.927 +- 3.75415
+0.00641465 vs 4.52253e-05
+ 3,3 3 Did not accept 51.7319(3)
+0 0 3.77342 51.7319 -1
+0.232896 4
+multi_loss(N=100, target=58) elapsed time: 2.98499 seconds 0.0497499 minutes
+128.55 +- 3.56206
+0.941162 vs 0.000216463
+ 3,4 3 Did not accept 0.232896(4)
+0 0 3.77342 50 0.232896
+....T = 0.0832553
+4.37082 2
+multi_loss(N=100, target=58) elapsed time: 2.95775 seconds 0.0492958 minutes
+128.816 +- 3.45615
+0.803355 vs 1.09972e-12
+ 4,2 4 Did not accept 4.37082(2)
+0 0 4.37082 50 -1
+49.3468 3
+multi_loss(N=100, target=58) elapsed time: 2.9872 seconds 0.0497866 minutes
+128.915 +- 3.17434
+0.126163 vs 3.35758e-13
+ 4,3 4 Did not accept 49.3468(3)
+0 0 3.77342 49.3468 -1
+-0.0551126 4
+multi_loss(N=100, target=58) elapsed time: 2.93849 seconds 0.0489748 minutes
+125.1 +- 3.35383
+0.17234 vs 1
+4 Rejection counts: 0 0 3 4 3
+ 4,4 ***** Did accept! 0 0 3.77342 50 -0.0551126
+....T = 0.028854
+5.90757 2
+multi_loss(N=100, target=58) elapsed time: 3.04963 seconds 0.0508272 minutes
+131.481 +- 3.49648
+0.318332 vs 9.27549e-97
+ 5,2 5 Did not accept 5.90757(2)
+0 0 5.90757 50 -0.0551126
+49.5818 3
+multi_loss(N=100, target=58) elapsed time: 3.0051 seconds 0.050085 minutes
+131.054 +- 3.3899
+0.854774 vs 2.47481e-90
+ 5,3 5 Did not accept 49.5818(3)
+0 0 3.77342 49.5818 -0.0551126
+-1.93165 4
+multi_loss(N=100, target=58) elapsed time: 2.95204 seconds 0.0492006 minutes
+127.676 +- 3.04749
+0.356781 vs 1.74605e-39
+ 5,4 5 Did not accept -1.93165(4)
+0 0 3.77342 50 -1.93165
+*** optimizer completed, elapsed time=47.6158 seconds 0.793596 minutes)
+./mw.py Done!
Deleted: SwiftApps/SciColSim/extract4plots
--- SwiftApps/SciColSim/extract4plots	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/extract4plots	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,42 +0,0 @@
-#!/bin/bash
-#usage: ./swiftoutput2plot <swift.outfile>
-SWIFTOUTFILE=$1
-#extract start time
-TMPDATE=`grep -i progress $SWIFTOUTFILE | head -n 1 | cut -f4-9 -d ' '`
-START_TIME=`date +%s -d "$TMPDATE"`
-#extract end time
-TMPDATE=`grep -i progress $SWIFTOUTFILE | tail -n 1 | cut -f4-9 -d ' '`
-END_TIME=`date +%s -d "$TMPDATE"`
-#duration
-DIFFTIME=$((END_TIME - START_TIME))
-#extract active runs in a file
-grep -o -i "Active:[0-9]*" $SWIFTOUTFILE | awk -F: '{print $2}' > active.txt
-#extract successful completions in a file
-grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE | awk -F: '{print $2}' > cumulative.txt
-#prepare tics
-activelines=`wc -l active.txt | awk '{print $1}'`
-cumulines=`wc -l cumulative.txt | awk '{print $1}'`
-activelinespertic=`echo "scale=5 ; $DIFFTIME / $activelines" | bc`
-seq 0 $activelinespertic $DIFFTIME > activetics.txt
-cumulinespertic=`echo "scale=5 ; $DIFFTIME / $cumulines" | bc`
-seq 0 $cumulinespertic $DIFFTIME > cumultics.txt
-#final plot data
-paste activetics.txt active.txt > plot_active.txt
-paste cumultics.txt cumulative.txt > plot_cumulative.txt
-grep  "T =" $SWIFTOUTFILE | awk '{print $6}' | cut -c8- | sed 's/....$//' > T.data
-grep multi_annealing $SWIFTOUTFILE | grep "1;30" | awk '{print $3}' | cut -c11- | sed 's/....$//' > anneal.data
-grep returning $SWIFTOUTFILE | awk '{print $3, $4, $5, $6}' | sed -e 's/'ci='//' -e 's/'cj='//' -e 's/'r.loss='//' -e 's/'r.sdev='//' | sort -t' ' -k 1,2n > multiloss.txt
Deleted: SwiftApps/SciColSim/getallparams.sh
--- SwiftApps/SciColSim/getallparams.sh	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/getallparams.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,10 +0,0 @@
-#! /bin/sh
-# targetinno=${1:-58}
-grep 'calling evolve' swift.out | # grep ,$targetinno, |
-  sed -e 's/^.*\[//' \
-      -e 's/\]$//' \
-      -e 's/,/ /g' \
-      -e 's/\(\......\)[0-9]* /\1 /g' |
-  awk '{print $3, $4, $5}' | uniq
Deleted: SwiftApps/SciColSim/getparamtrace.sh
--- SwiftApps/SciColSim/getparamtrace.sh	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/getparamtrace.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,9 +0,0 @@
-#! /bin/sh
-targetinno=${1:-58}
-grep 'calling evolve' swift.out | grep ,$targetinno, |
-      -e 's/\]$//' \
-      -e 's/,/ /g' \
Deleted: SwiftApps/SciColSim/local.xml
--- SwiftApps/SciColSim/local.xml	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/local.xml	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,9 +0,0 @@
-<config>
-  <pool handle="localhost" >
-    <execution provider="local" url="none" />
-    <profile namespace="karajan" key="jobThrottle">0.05</profile>
-    <profile namespace="karajan" key="initialScore">10000</profile>
-    <filesystem provider="local"/>
-    <workdirectory>/gpfs/pads/swift/jonmon/Swift/work/pads</workdirectory>
-  </pool>
-</config>
Deleted: SwiftApps/SciColSim/mathtest.swift
--- SwiftApps/SciColSim/mathtest.swift	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/mathtest.swift	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,18 +0,0 @@
-import "math";
-float a = 0.5;
-tracef("random(): %f\n", random());
-tracef("sin(%f): %f\n", a, sin(a));
-tracef("jlog(%f): %f\n", a, jlog(a));
-tracef("log10(%f): %f\n", a, log10(a));
-tracef("exp(%f): %f\n", a, exp(a));
-tracef("ceil(%f): %f\n", 1.23, ceil(1.23));
-tracef("floor(%f): %f\n", 1.23, floor(1.23));
-tracef("pow(%f,%f): %f\n", 2.0, 4.0, pow(2.0,4.0));
-tracef("min(%f,%f): %f\n", 2.0, 4.0, min(2.0,4.0));
-tracef("min(%f,%f): %f\n", 2.0, 1.5, min(2.0,1.5));
Copied: SwiftApps/SciColSim/old/RunSwift.sh (from rev 5634, SwiftApps/SciColSim/RunSwift.sh)
--- SwiftApps/SciColSim/old/RunSwift.sh	                        (rev 0)
+++ SwiftApps/SciColSim/old/RunSwift.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,49 @@
+#!/bin/bash
+# ./Runswift local to run on sandbox
+# ./Runswift clustersmall to run on beagle pbs cluster at small scale
+# ./Runswift clusterquick to run on beagle pbs cluster at large scale
+escapecode=$(echo -n -e '\033')
+count=$(head -1 counter.txt);
+expr $count + 1 > counter.txt
+mkdir run$count
+cp /home/ketan/SciColSim/*.swift run$count/
+cp /home/ketan/SciColSim/sites.beagle.xml run$count/
+cp /home/ketan/SciColSim/sites.beagle.quick.xml run$count/
+cp local.xml run$count/
+cp /home/ketan/SciColSim/tc run$count/
+cp /home/ketan/SciColSim/movie_graph.txt run$count/
+cp /home/ketan/SciColSim/cf run$count/
+cd run$count
+if [ $1 = "local" ]
+then
+ #SWIFT_HEAP_MAX=7000M swift -tc.file tc -sites.file local.xml -config cf annealing.swift -e33="$escapecode" -nworkers=36 >& swift.out
+ #Total jobs = 6 * 1 * 120/20 * 3 * 100 = 10,800
+ SWIFT_HEAP_MAX=7000M swift -tc.file tc -sites.file local.xml -config cf annealing.swift -e33="$escapecode" -nworkers=6 -minrange=58 -maxrange=64 -rangeinc=1 -evoreruns=120 -nreps=1 -alphai=0 -alpham=0 -beta=4.0 -gamma=50.0 -delta=-1 -annealingcycles=100 -rerunsperapp=20  >& swift.out
+elif [ $1 = "clusterbig" ]
+then
+ SWIFT_HEAP_MAX=7000M swift -tc.file tc -sites.file sites.beagle.xml -config cf annealing.swift -e33="$escapecode" -nworkers=24 -rangeinc=50 -evoreruns=960 -startingjump=2.3 -alphai=0 -alpham=0 -beta=4.0 -gamma=50.0 -delta=-1 -annealingcycles=100 -rerunsperapp=192  >& swift.out
+elif [ $1 = "clustersmall" ]
+then
+ SWIFT_HEAP_MAX=7000M swift -tc.file tc -sites.file sites.beagle.xml -config cf annealing.swift \-e33="$escapecode" \
+      >& swift.out
+elif [ $1 = "clusterquick" ]
+then
+#target_innovation=(1009-58)/50=~20
+#repeats=nreps=1
+# 3 repeats constant (serial)
+#annealing_cycles=100 (serial)
+#rerunsperapp=192
+#evoreruns=960
+#J=evoreruns/rerunsperapp=960/192=5
+#Total parallel jobs = (maxrange-minrange)/rangeinc * nreps * (evoreruns/rerunsperapp) = (1009-58)/50 * 1 * 960/192 = 20*5 = 100 Jobs = 2400 openmp jobs in parallel
+ SWIFT_HEAP_MAX=7000M swift -tc.file tc -sites.file sites.beagle.quick.xml -config cf annealing.swift -e33="$escapecode" -nworkers=24 -minrange=58 -maxrange=1009 -rangeinc=50 -evoreruns=960 -nreps=1 -alphai=0 -alpham=0 -beta=4.0 -gamma=50.0 -delta=-1 -annealingcycles=100 -rerunsperapp=192  >& swift.out
+fi
Copied: SwiftApps/SciColSim/old/annealing.open-issues.swift (from rev 5634, SwiftApps/SciColSim/annealing.open-issues.swift)
--- SwiftApps/SciColSim/old/annealing.open-issues.swift	                        (rev 0)
+++ SwiftApps/SciColSim/old/annealing.open-issues.swift	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,379 @@
+import "math";
+import "colortext";
+type file;
+type Res
+    float loss;
+    float sdev;
+global boolean FIX_VARIABLES = true;
+global int var_fixed[] = [1,1,0,0,0];
+global int Nworkers = @toint(@arg("nworkers","4"));
+global int rerunsPerApp;
+(float nx) newx(float x, float dx)
+    float r = (random()) ; // / (pow(2.0,31.0)-1.0);
+    if (r > 0.5)
+        nx = x + (random())*dx; // /(pow(2.0,31.0)-1.0);
+    else
+        nx = x - (random())*dx; // /(pow(2.0,31.0)-1.0);
+    // tracef("newx(%f,%f)=%f\n",x,dx,nx);
+app (file outfile, file loss) evolve (string args[], file graph)
+    evolve @loss args stdout=@outfile ;  // graph is passed implicitly
+app (file x) sumloss(file loss[])
+    sumloss @filenames(loss) stdout=@x;
+  Program structure:
+  main
+  optimizer_sweep() - formerly, python script
+  multi_annealing()
+  multi_loss()
+  evolve()
+  sumloss()
+(file bestfile, file maxfile) multi_annealing (
+    float T_start,
+    float T_end,
+    float Target_rejection,
+    int evolve_reruns,
+    float starting_jump,
+    float params0[],
+    float target_innov,
+    int annealing_cycles)
+    int cycle=10;     // const
+    int NEVOPARAMS=5; // const - 5 params, alpha 1,m through delta, does not include target_innovation
+    float rejection[][];  // [i][j] where i is cycle and j is evolve-parameter (alpha_i, alpha_m, beta, gamma, delta)
+    float x[][], dx[][], curr_loss[], curr_sdev[];
+    Res mlres[][];
+    mlres[0][0] = multi_loss( 0, 0, params0, target_innov, evolve_reruns ); // FIXME: serves for all evolve-params ???
+    tracef("multi_annealing: AR: initial: %f +- %f\n",mlres[0][0].loss,mlres[0][0].sdev);
+    foreach j in [0:NEVOPARAMS-1]
+        x[0][j]=params0[j];
+        dx[0][j] = starting_jump;
+        rejection[0][j] = 0.0;
+        curr_loss[j] = mlres[0][0].loss;
+        curr_sdev[j] = mlres[0][0].sdev;
+    iterate iter_i
+    {    // foreach i in [1:annealing_cycles]
+        int i = iter_i + 1;
+        // set new temperature, rejection threshold, and dx values for this cycle
+        float temperature = T_start*exp( @tofloat(i-1)*(jlog(T_end)-jlog(T_start))/@tofloat(annealing_cycles));
+        tracef(@strcat("multi_annealing: AR: i=%i ....T = ",color(3,"%f"),"\n"), i, temperature);
+        // On each new "major" cycle within the annealing_cycles (other than the first) set new rejection and dx values
+        if ( i %% cycle == 1 && i > 1 )
+            tracef("multi_annealing: new cycle at i=%i\n",i);
+            tracef(color(Pink, "multi_annealing: AR: New cycle at %i: prev dx[0-4]=[%f %f %f %f %f]\n"),i,dx[i-1][0],dx[i-1][1],dx[i-1][2],dx[i-1][3],dx[i-1][4]);
+            foreach  k in [0:NEVOPARAMS-1]
+                float newrejection = rejection[i-1][k] / @tofloat(cycle);
+                if (newrejection > 0.0)
+                    dx[i][k] = dx[i-1][k] / (newrejection / Target_rejection);
+                    // FIXME: re-enable: rejection[i][k]=0.0;
+                else
+                    dx[i][k] = dx[i-1][k] * 2.0;
+                    // FIXME: re-enable: rejection[i][k]=rejection[i-1][k];
+                // FIXME: HANGS? : tracef(color(Red,"Recomputed rejection: i=%d k=%d dx[i][k]=%f\n"), i, k, dx[i][k]);
+            tracef(color(Blue, "multi_annealing: AR: New cycle at %i: dx[0-4]=[%f %f %f %f %f]\n"),i,dx[i][0],dx[i][1],dx[i][2],dx[i][3],dx[i][4]);
+        else
+        { // If not new cycle, set dx[i][*] from previous dx ([i-1]). rejection[i]j] is set later.
+                dx[i][k] = dx[i-1][k];
+        //foreach j in [0:NEVOPARAMS-1] { // Try a new value for each non-fixed param; then write results and accept or reject
+        iterate j
+        {  // Try a new value for each non-fixed param; then write results and accept or reject
+            // float try_x[];
+            int curr = (i * NEVOPARAMS) + j;
+            int prev = curr-1;
+            // tracef("in multi_annealing: i=%i j=%i curr=%i prev=%i\n", i, j, curr, prev);
+            if ( /*(!FIX_VARIABLES) || */ (var_fixed[j]==0) ) {  // Adjustable vars
+                // fixed=1,1,0,0,0: FIXME: FIX_VARIABLES flag has faulty logic but OK when TRUE
+                float try_x[];
+                { // Select the evolve params to try
+                    if ( k < j )
+                        try_x[k] = x[i][k]; // already set x[i][k]
+                    else
+                        if ( k == j )
+                            try_x[k] = newx(x[i-1][j],dx[i-1][j]); // permute x[i-1][j]
+                        else
+                        { // k > j
+                            try_x[k] = x[i-1][k]; // use x[i-1][k] (from prior cycle)
+                tracef(@strcat("multi_annealing: AR: ", color(10,"%f"), " ", color(9,"%i"),"\n"), try_x[j],j);
+                // Up to here, x[] and dx[] are only set for previous i
+                mlres[i][j] = multi_loss(i,j,try_x, target_innov, evolve_reruns); // do the N evolve()'s, N=evolve_reruns
+                tracef("multi_annealing: AR: %f +- %f\n", mlres[i][j].loss, mlres[i][j].sdev);
+                // Beyond this point, x[] and dx[] are being set for this i,j
+                float ALOT=100000000000.0; // 100,000,000,000. = 10^11
+                if (mlres[i][j].loss < ALOT)
+                    tracef("multi_annealing: AF: best_opt_some.txt: %f,%f,%f,%f,%f,%f,%f,%f\n",
+                           target_innov,mlres[i][j].loss,try_x[0],try_x[1],try_x[2],try_x[3],try_x[4],mlres[i][j].sdev);
+                    tracef(color(Red,"multi_annealing: AF: max_dist.txt - tbd\n")); // FIXME: max_dist is global set in evolve()
+                else
+                {  // does this ever occur? if so did we want to still do the ratio computation above???
+                    tracef("multi_annealing: Loss %f > ALOT at [i][j] = [%d][%d]\n", mlres[i][j].loss, i ,j);
+                float ratio = min(1.0, exp( -(mlres[i][j].loss-curr_loss[prev]) / temperature));
+                float r = (random()) ; // / (pow(2.0,31.0)-1.0);  // FIXME: AR: why all the 2^31's ???
+                tracef("multi_annealing: AR: %f vs %f\n", r, ratio);
+                if (r > ratio)
+                {  // Reject new parameter
+                    x[i][j] = x[i-1][j];
+                    rejection[i][j] = rejection[i-1][j] + 1.0;  // FIXME: AR: Is this correct? incr rejection?
+                    curr_loss[curr] = curr_loss[prev];
+                    curr_sdev[curr] = curr_sdev[prev];
+                    // FIXME: AR: the following prints seem to replicate values in the .cpp version - please clarify.
+                    tracef("multi_annealing: AR: %i,%i %i Did not accept: %f (%i)\n", i, j, i, try_x[j], j);
+                    tracef("multi_annealing: AR: %f %f %f %f %f\n", try_x[0],try_x[1],try_x[2],try_x[3],try_x[4]);
+                else
+                {           // Accept new parameter
+                    tracef("multi_annealing: Accepting try_x[j], i=%i j=%i\n",i,j);
+                    x[i][j] = try_x[j];
+                    rejection[i][j] = rejection[i-1][j];  // FIXME: AR: Is this correct? no incr of rejection?
+                    tracef("multi_annealing: Accepting try_x[j], i=%i j=%i try_x[j]=%f\n",i,j,try_x[j]);
+                    curr_loss[curr] = mlres[i][j].loss;
+                    curr_sdev[curr] = mlres[i][j].sdev;
+                    float rj[];
+                    {  // FIXME!!!
+                        if (k <= j)
+                            rj[k] = rejection[i][k]; // Was either set from previous j or just set for this j
+                        else
+                            rj[k] = rejection[i-1][k]; // Not yet set, use previous
+                    tracef(@strcat("multi_annealing: AR: [%i][%i] ", color(8,"Rejection counts: "),
+                                   color(1,"%f"), " ", color(7,"%f"), " ", color(5,"%f"), " ", color(9,"%f"), " ", color(6,"%f"), "\n\n"),
+                           i, j, rj[0], rj[1], rj[2], rj[3], rj[4]);
+                    tracef(@strcat("multi_annealing: AR: %i ", color(8,"***** Did accept! "),
+                           i, try_x[0], try_x[1], try_x[2], try_x[3], try_x[4]);
+            else
+            { // Fixed Vars
+                // dx[i][j] not set for fixed vars
+        } until(j == NEVOPARAMS-1);
+    } until(iter_i == (annealing_cycles-1));
+(Res r) multi_loss( int ci, int cj, float x[], float target_innov, int evolve_reruns )
+// (Res r, Stats s) multi_loss( int ci, int cj, float x[], float target_innov, int evolve_reruns ) FIXME: To obtain stats
+    file rfile[];
+    file ofile[]; // FIXME: to obtain timings and otehr stats
+    tracef("multi_loss: entered: ci=%i cj=%i target_innov=%f evolve_reruns=%i x=%q\n",ci, cj, target_innov,evolve_reruns,x);
+    int appCalls = @toint(@tofloat(evolve_reruns) / @tofloat(rerunsPerApp));  // FIXME: handle fractional issues and rounding etc. For now must divide evenly
+    tracef("multi_loss appCalls=%i\n", appCalls);
+    foreach i in [1:appCalls] {  // repeats of the evolove() - same as n_reruns
+        file outfile; // FIXME: map and save in future
+        string args[] = [ // FIXME: move this to a setargs() function
+            //    alpha_i        alpha_m        beta           gamma          delta          target_innov
+            @strcat(x[0]), @strcat(x[1]), @strcat(x[2]), @strcat(x[3]), @strcat(x[4]), @strcat(target_innov),
+            //     n_epochs n_steps evolve_reruns           range
+            //    "40000",  "20",   @strcat(evolve_reruns), "2",
+            "40000",  "20",   @strcat(rerunsPerApp),  "2",
+            //    verbose_level
+            "1",
+            //    T_start T_end   Annealing_steps Target_rejection Starting_jump
+            "2.",   "0.01", "2",            "0.3",           "2.3",
+            //    FREEZE: alpha_i alpha_m beta gamma delta
+            "1",    "1",    "0", "0",  "0",
+            //   operation-code:(m,a) Nworkers           seed
+            "m",                 @strcat(Nworkers), "1234567" ];
+        file graph <"movie_graph.txt">;
+        (outfile, rfile[i]) = evolve(args,graph);
+        // (ofile[i], rfile[i]) = evolve(args,graph);
+        tracef("multi_loss: i=%i calling evolve, args=%q\n", i, args);
+        // tracef("multi_loss: after evolve: i=%i %k %k\n", i, outfile, rfile[i]);
+    file sumfile = sumloss(rfile);
+    r = readData(sumfile);
+    tracef("multi_loss: returning: ci=%i cj=%i r.loss=%f r.sdev=%f\n",ci,cj,r.loss,r.sdev);
+    // file statfile = sumstats(ofile);  FIXME: to obtain timings and otehr stats
+    // s = readStat(statsfile);          FIXME: to obtain timings and otehr stats
+optimizer_sweep() // Implements logic of python driver script
+    int minrange=58;
+    int maxrange=59;
+    int rangeinc=50;
+    //int maxrange=1009;
+    //int maxrange=209;
+    // FIXME: add provision for random priming and random param values when x[i] == -100 (see optimizer.cpp main())
+    int nreps=1; // 15
+//    file bestfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".best_opt_some")>;
+//    file maxfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".max_dist")>;
+    foreach target_innov in [minrange:maxrange:rangeinc]
+        foreach rep in [1:nreps]
+            file outfile;  // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".out")>;
+            file lossfile; // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".loss_data")>;
+  (outfile,lossfile) = multi_annealing(
+  T_start          = 2.0,
+  T_end            = 0.01,
+  Target_rejection = 0.3,
+  evolve_reruns    = 10,
+  starting_jump    = 2.3,
+  params0[]        = [0.0, 0.0, 4.0, 50.0, -1.0],
+  @tofloat(target_innov),
+  annealing_cycles = 2);
+                2.0,
+                0.01,
+                0.3,
+                100,
+                2.3,
+                [0.0, 0.0, 4.0, 50.0, -1.0],
+                30);
+rerunsPerApp = 100;
+main()
+    optimizer_sweep();
+main();
+  main
+  optimizer_sweep()
+  multi_annealing()
+  multi_loss()
+  evolve()
+  sumloss()
+  Example parameter sets:
+  for target in range(58,59,50):
+  for i in range(1):
+  args="./toptimizer 0 0 4 50 -1 "+target+" 40000 20 75    2 1 2. 0.01 2 0.3 2.3 1 1 1 0 0 m // > out.T"+str(target)+".i"+str(i)
+  os.system(args);
+  string fastargs1[] = [
+  "0", "0", "4", "50", "-1", @strcat(target),
+  "40000", "20", "1000", "2",
+  "1",
+  "2.", "0.01", "100", "0.3", "2.3",
+  "1", "1", "0", "0", "0"];
+  string fastargs2[] = [
+  "1",
+  "2.", "0.01",  "5", "0.3", "2.3",
+  "1", "1", "0", "0", "0", "m"];
+  string fastargs3[] = [
+  "40000", "20", @strcat(repeats), "2",
+  "1",
+(string args[]) setargs()
+    // string longargs[] = @strcat("0 0 4 50 -1 ",target," 40000 20 1000 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0 m");
+    //  [alpha_i alpha_m beta gamma delta target_innov
+    //  [n_epochs n_steps n_reruns] [range]
+    //  [verbose_level]
+    //  [T_start T_end Annealing_steps Target_rejection Starting_jump]
+    //  [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta] [operation-code:(m,a) Nworkers]
+////////////////// HOLD JUNK
+//                    tracef(@strcat("multi_annealing: AR: %i ", color(8,"Rejection counts: "),
+//                                   color( /* 2 */ 1," %f"), "\n\n"),
+//                                   i, rejection[i][j] ); // , rejection[i][1], rejection[i][2], rejection[i][3], rejection[i][4]);
+// FIXME: determine correct rejection[] values to avoid hanging:
+//                                   color( /* 2 */ 1," %f"), color(7," %f"), color(5," %f"), color(9," %f"), color(6," %f"), "\n\n"),
+//                                   rejection[i][0], rejection[i][1], rejection[i][2], rejection[i][3], rejection[i][4]);
+// END FIXME
Copied: SwiftApps/SciColSim/old/beagle.xml (from rev 5634, SwiftApps/SciColSim/beagle.xml)
--- SwiftApps/SciColSim/old/beagle.xml	                        (rev 0)
+++ SwiftApps/SciColSim/old/beagle.xml	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,60 @@
+<config>
+<!-- From Glen: used w/ "Swift svn swift-r4813 (swift modified locally) cog-r3175" -->
+  <pool handle="beagle">
+    <execution provider="coaster" jobmanager="local:pbs" url="none"/>
+    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
+    <profile key="jobsPerNode" namespace="globus">1</profile>
+    <profile namespace="env" key="OMP_NUM_THREADS">24</profile>
+    <profile namespace="globus" key="maxwalltime">02:00:00</profile>
+    <profile namespace="globus" key="maxTime">14400</profile>
+    <profile namespace="globus" key="slots">20</profile>
+    <profile namespace="globus" key="nodeGranularity">1</profile>
+    <profile namespace="globus" key="maxNodes">1</profile>
+    <profile namespace="globus" key="lowOverAllocation">100</profile>
+    <profile namespace="globus" key="highOverAllocation">100</profile>
+    <profile namespace="karajan" key="jobThrottle">.15</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <profile namespace="globus" key="project">CI-MCB000119</profile>
+    <profile namespace="globus" key="queue">route</profile>
+    <filesystem provider="local"/>
+    <workdirectory >/lustre/beagle/wilde/swiftwork</workdirectory>
+  </pool>
+<!-- From Justin's swift-devel page:
+<import file="sys.xml"/>
+<set name="wdir" value="/lustre/beagle/{user.name}/work"/>
+<echo message="setting workDirectory to: {wdir}"/>
+<pool handle="beagle-pbs">
+  <execution jobmanager="local:pbs" provider="coaster" url="none"/>
+  <profile namespace="globus" key="maxWallTime">1</profile>
+  <profile namespace="globus" key="maxTime">7200</profile>
+    pbs.aprun;pbs.mpp;depth=24
+  </profile>
+  <profile key="jobsPerNode" namespace="globus">24</profile>
+  <profile key="slots" namespace="globus">1</profile>
+  <profile key="nodeGranularity" namespace="globus">1</profile>
+  <profile key="maxNodes" namespace="globus">1</profile>
+  <profile key="queue" namespace="globus">batch</profile>
+  <profile key="jobThrottle" namespace="karajan">5.99</profile>
+  <profile key="initialScore" namespace="karajan">10000</profile>
+  <profile namespace="globus" key="project">_PROJECT_</profile>
+  <profile namespace="globus" key="project">_QUEUE_</profile>
+  <filesystem provider="local" url="none" />
+  <workdirectory>{wdir}</workdirectory>
+</pool>
+</config>
Copied: SwiftApps/SciColSim/old/mathtest.swift (from rev 5634, SwiftApps/SciColSim/mathtest.swift)
--- SwiftApps/SciColSim/old/mathtest.swift	                        (rev 0)
+++ SwiftApps/SciColSim/old/mathtest.swift	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,18 @@
+import "math";
+float a = 0.5;
+tracef("random(): %f\n", random());
+tracef("sin(%f): %f\n", a, sin(a));
+tracef("jlog(%f): %f\n", a, jlog(a));
+tracef("log10(%f): %f\n", a, log10(a));
+tracef("exp(%f): %f\n", a, exp(a));
+tracef("ceil(%f): %f\n", 1.23, ceil(1.23));
+tracef("floor(%f): %f\n", 1.23, floor(1.23));
+tracef("pow(%f,%f): %f\n", 2.0, 4.0, pow(2.0,4.0));
+tracef("min(%f,%f): %f\n", 2.0, 4.0, min(2.0,4.0));
+tracef("min(%f,%f): %f\n", 2.0, 1.5, min(2.0,1.5));
Copied: SwiftApps/SciColSim/old/optimizer.protomods.cpp (from rev 5634, SwiftApps/SciColSim/optimizer.protomods.cpp)
--- SwiftApps/SciColSim/old/optimizer.protomods.cpp	                        (rev 0)
+++ SwiftApps/SciColSim/old/optimizer.protomods.cpp	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,1818 @@
+//  main.cpp
+//  optimizer
+//  Created by Andrey Rzhetsky on 4/11/11.
+//  Copyright 2011 University of Chicago. All rights reserved.
+#define MAXNworkers 24
+int Nworkers=MAXNworkers;
+// Add operation code to enable existing code to be used at lower level from Swift scripts:
+char operation = 'n'; // n: normal; m: do one multi_loss (with n_reruns).
+                      // Not used: a: analyze and generate next annealing parameter set. g: tbd
+#include <fstream>
+#include <sstream>
+#include <iostream>
+#include <stdio.h>
+#include <time.h>
+#include <ctime>
+#include <algorithm>
+#include <string>
+#include <stdio.h>
+#include <sys/param.h>
+#include <sys/time.h>
+#include <sys/types.h>
+// #include <dispatch/dispatch.h>
+#include <fstream>
+#include <stdlib.h>
+#include <boost/numeric/ublas/io.hpp>
+#include <boost/graph/graph_traits.hpp>
+#include <boost/graph/dijkstra_shortest_paths.hpp>
+#include <boost/graph/loop_erased_random_walk.hpp>
+#include <boost/graph/random.hpp>
+#include <boost/property_map/property_map.hpp>
+#include <boost/graph/graph_concepts.hpp>
+#include <boost/graph/properties.hpp>
+#include <boost/graph/adjacency_list.hpp>
+#include <boost/graph/adjacency_matrix.hpp>
+#define BOOST_MATH_OVERFLOW_ERROR_POLICY ignore_error
+#define BOOST_MATH_DISCRETE_QUANTILE_POLICY real
+#include <boost/random/geometric_distribution.hpp>
+#include <boost/random/uniform_01.hpp>
+#include <boost/random.hpp>
+#include <boost/random/linear_congruential.hpp>
+#include <boost/random/uniform_int.hpp>
+#include <boost/random/uniform_real.hpp>
+#include <boost/random/variate_generator.hpp>
+#include <boost/generator_iterator.hpp>
+#include <boost/lexical_cast.hpp>
+#define INT_INFINITY 2147483647
+#define NEVOPARAMS 5
+#define FIX_VARIABLES 1
+using namespace boost;
+using namespace std;
+using namespace boost::numeric::ublas;
+static int max_dist=0;
+typedef boost::adjacency_matrix<boost::directedS> Graph;
+typedef std::pair<int,int> Edge;
+typedef boost::graph_traits<Graph> GraphTraits;
+typedef boost::numeric::ublas::triangular_matrix<double, boost::numeric::ublas::strict_upper> prob;
+typedef boost::numeric::ublas::triangular_matrix<double, boost::numeric::ublas::strict_upper> pathlength;
+typedef boost::graph_traits<Graph>::vertex_descriptor vertex_descriptor;
+namespace std {
+	using ::time;
+static int var_fixed[NEVOPARAMS] = {1, 0, 1, 1, 0};
+typedef boost::minstd_rand base_generator_type;
+typedef adjacency_list < listS, vecS, directedS,
+no_property, property < edge_weight_t, int > > graph_t;
+typedef graph_traits < graph_t >::vertex_descriptor vertex_descriptor;
+typedef graph_traits < graph_t >::edge_descriptor edge_descriptor;
+string strDouble(double number)
+    stringstream ss;//create a stringstream
+    ss << number;//add number to the stream
+    return ss.str();//return a string with the contents of the stream
+double gaussian(double sigma)
+    double GaussNum = 0.0;
+    int NumInSum = 10;
+    for(int i = 0; i < NumInSum; i++)
+        GaussNum += ((double)rand()/(double)RAND_MAX - 0.5);
+    GaussNum = GaussNum*sqrt((double)12/(double)NumInSum);
+    return GaussNum;
+double diffclock(clock_t clock1,clock_t clock2)
+	double diffticks=clock1-clock2;
+	double diffms=(diffticks)/CLOCKS_PER_SEC;
+	return diffms;
+double get_new_x(double x, double dx){
+    double new_x;
+    // boost::variate_generator<base_generator_type&, boost::uniform_real<> > uni(generator, uni_dist);
+    double r = rand()/(double)(pow(2.,31)-1.);
+    if (r > 0.5){
+        new_x = x + rand()*dx/(double)(pow(2.,31)-1.);
+    } else {
+        new_x = x - rand()*dx/(double)(pow(2.,31)-1.);
+    return new_x;
+string string_wrap(string ins, int mode){
+    std::ostringstream s;
+    switch(mode){
+        case 0:
+            s << "\033[1;29m" << ins << "\033[0m";
+            break;
+        case 1:
+            s << "\033[1;34m" << ins << "\033[0m";
+            break;
+        case 2:
+            s << "\033[1;44m" << ins << "\033[0m";
+            break;
+        case 3:
+            s << "\033[1;35m" << ins << "\033[0m";
+            break;
+        case 4:
+            s << "\033[1;33;44m" << ins << "\033[0m";
+            break;
+        case 5:
+            s << "\033[1;47;34m" << ins << "\033[0m";
+            break;
+        case 6:
+            s << "\033[1;1;31m" << ins << "\033[0m";
+            break;
+        case 7:
+            s << "\033[1;1;33m" << ins << "\033[0m";
+            break;
+        case 8:
+            s << "\033[1;1;43;34m" << ins << "\033[0m";
+            break;
+        case 9:
+            s << "\033[1;1;37m" << ins << "\033[0m";
+            break;
+        case 10:
+            s << "\033[1;30;47m" << ins << "\033[0m";
+            break;
+        default:
+            s << ins;
+    return s.str();
+string wrap_double(double val, int mode){
+    s << string_wrap(strDouble(val),mode);
+    return s.str();
+const
+string i2string(int i){
+    s << "worker"
+    << lexical_cast<std::string>(i);
+    return s.str();
+char* i2char(int i){
+    s << "worker"
+    char* a=new char[s.str().size()+1];
+    memcpy(a,s.str().c_str(), s.str().size());
+    return a;
+template <class T>
+bool from_string(T& t,
+                 const std::string& s,
+                 std::ios_base& (*f)(std::ios_base&))
+  std::istringstream iss(s);
+  return !(iss >> f >> t).fail();
+class Universe {
+private:
+	double alpha_i;
+	double alpha_m;
+	double beta;
+	double gamma;
+	double delta;
+    double TargetNovelty;
+    double CumulativeRelativeLoss;
+    double CRLsquare;
+    string id;
+	int N_nodes;
+	int M_edges;
+	int N_epochs;
+	int N_steps;
+	int N_repeats;
+	int current_epoch;
+	double current_loss;
+	int current_repeat;
+    double current_novelty;
+	int mode_identify_failed;
+    int verbose_level; // 0 is silent, higher is more
+	double k_max;
+	graph_t Full_g;
+	double **Prob;
+	double **Tried;
+	double **Dist;
+	double **Final;
+    double **EdgeIndex;
+	double *Rank;
+    base_generator_type generator;
+    boost::uniform_real<> uni_dist;
+    boost::geometric_distribution<double> geo;
+public:
+	//======  Constructor ======
+	Universe(const std::string FileToOpen, int Epochs, int Steps, int Repeats, int identify_failed, double target, const std::string idd)
+		//typedef array_type2::index index2;
+		std::ifstream inFile;
+        //string line;
+        base_generator_type gene(42u);
+        generator = gene;
+        generator.seed(static_cast<unsigned int>(std::time(0)));
+        boost::uniform_real<> uni_d(0,1);
+        uni_dist = uni_d;
+		int i, k;
+        int x, y;
+		Edge* edge_array_mine;
+		int num_arcs_mine, num_nodes_mine;
+		int* weights_mine;
+        TargetNovelty = target;
+        CumulativeRelativeLoss = 0.;
+        CRLsquare = 0.;
+		N_epochs  = Epochs;
+		N_steps   = Steps;
+		N_repeats = Repeats;
+		current_epoch = 0;
+		current_loss = 0.;
+		current_repeat = 0;
+        id = idd;
+        verbose_level = 1;
+		mode_identify_failed = identify_failed;
+		// The first pass though file with the graph
+		inFile.open(FileToOpen.c_str());
+		if (inFile.fail()) {
+			cout << "Unable to open file";
+			exit(1); // terminate with error
+		}else {
+            if (verbose_level > 2){
+                std::cout <<  " Opened <" << FileToOpen << ">"<<std::endl;
+		i=0;
+        std::string line;
+		//while (! inFile.eof() && ! inFile.fail()) {
+        while (1==1) {
+            inFile >> x;
+            inFile >> y;
+                std::cout << " x: " << x;
+                std::cout << " y: " << y << std::endl;
+			if (i==0){
+				N_nodes=x;
+				M_edges=y;
+                break;
+			i++;
+		inFile.close();
+        if (verbose_level == 2){
+            std::cout << N_nodes <<  " nodes, " << M_edges << " edges"<<std::endl;
+		// k_max is the longest distance possible
+        //k_max = M_edges;
+		k_max = 70;
+		// Get memory allocated for all class members
+		Prob = allocate_2Dmatrix(N_nodes, N_nodes);
+		Tried = allocate_2Dmatrix(N_nodes, N_nodes);
+		Dist = allocate_2Dmatrix(N_nodes, N_nodes);
+		Final = allocate_2Dmatrix(N_nodes, N_nodes);
+        EdgeIndex = allocate_2Dmatrix(N_nodes, N_nodes);
+		Rank = allocate_1Dmatrix(N_nodes);
+        //The second pass through file with the graph
+		for(int i = 0; i < N_nodes; ++i) {
+			Rank[i]=0.;
+			for(int j = 0; j < N_nodes; ++j) {
+				Final[i][j] = 0.;
+				Prob[i][j]=0.;
+				Dist[i][j]=-1.;
+				Tried[i][j]=0.;
+                EdgeIndex[i][j]=-1;
+		// Fill in the final graph -- and we are ready to go!
+		if (!inFile) {
+            std::cout << "Unable to open file";
+		else {
+		i=0;
+		while (inFile >> x && inFile >>y) {
+			if (i > 0) {
+				Final[x][y]=1.;
+				Final[y][x]=1.;
+                    std::cout << ".";
+			i++;
+            std::cout << std::endl;
+		inFile.close();
+        k=0;
+        for (int i=0; i<N_nodes-1; i++){
+            for (int j=i+1;j<N_nodes; j++){
+                if(Final[i][j] > 0.){
+                    EdgeIndex[i][j]=k;
+                    k++;
+		// create graph -- hopefully, we can keep it, just modifying edge weights
+		edge_array_mine = new Edge[2*M_edges];
+		num_arcs_mine = 2*M_edges;
+		num_nodes_mine = N_nodes;
+		weights_mine = new int[2*M_edges];
+		for (int i=0; i<2*M_edges; i++){ weights_mine[i]=1;}
+		k=0;
+		for(int i=0; i<N_nodes-1; i++){
+			for( int j=i+1; j<N_nodes; j++){
+				if (Final[i][j]>0.){
+					edge_array_mine[2*k]  =Edge(i,j);
+					edge_array_mine[2*k+1]=Edge(j,i);
+					k++;
+		graph_t g(edge_array_mine, edge_array_mine + num_arcs_mine, weights_mine, num_nodes_mine);
+		Full_g = g;
+		delete edge_array_mine;
+		delete weights_mine;
+		std::vector<edge_descriptor> p(num_edges(Full_g));
+		std::vector<int> d(num_edges(Full_g));
+		edge_descriptor s;
+		boost::graph_traits<graph_t>::vertex_descriptor u, v;
+			for (int j=i+1; j<N_nodes; j++){
+				if (Final[i][j] > 0.){
+					u = vertex(i, Full_g);
+					v = vertex(j, Full_g);
+					remove_edge(u,v,Full_g);
+					remove_edge(v,u,Full_g);
+	int sample_failed_number(double pfail){
+		//boost::geometric_distribution<double> geo(pfail);
+		//boost::variate_generator<base_generator_type&, geometric_distribution<double> > geom(generator, geo);
+		double r, u, g;
+        r=0.;
+		for(int i=0; i<N_steps; i++){
+            u=(double)rand();
+            u = 1.-u /(double)(pow(2.,31)-1.);
+            g=(int)(ceil(log(u) / log(pfail)));
+			//r += geom();
+            r+=g;
+        if (verbose_level>=3){
+            std::cout << id << " failed " << r << std::endl;
+		return r;
+    double get_target(void){
+        return TargetNovelty;
+    void set_target(double target){
+        TargetNovelty=target;
+	int sample(){
+        //boost::variate_generator<base_generator_type&, boost::uniform_real<> > uni(generator, uni_dist);
+        // double r = uni(), Summa = 0.;
+        double r = rand(), Summa = 0.;
+        r /= (double)(pow(2.,31)-1.);
+		int result = 0;
+		int finished = 0;
+        if (verbose_level==4){
+            std::cout << id << " sampled " << r << std::endl;
+		for(int i=0; i<N_nodes-1 && finished==0; i++){
+			for( int j=i+1; j<N_nodes && finished==0; j++){
+				Summa += Prob[i][j];
+				if (Summa > r){
+					Tried[i][j]+=1.;
+						result = 1;
+					finished = 1;
+		return result;
+	void update_current_graph(void){
+		//property_map<graph_t, edge_weight_t>::type weightmap = get(edge_weight, Full_g);
+				if (Final[i][j] > 0. && Tried[i][j]>0){
+					//s = edge(i, j, Full_g);
+					boost::graph_traits<graph_t>::edge_descriptor e1,e2;
+					bool found1, found2;
+					tie(e1, found1) = edge(u, v, Full_g);
+					tie(e2, found2) = edge(v, u, Full_g);
+					if (!found1 && !found2){
+						add_edge(u,v,1,Full_g);
+					    add_edge(v,u,1,Full_g);
+	void update_distances(void){
+		// put shortest paths to the *Dist[][]
+		std::vector<vertex_descriptor> p(num_vertices(Full_g));
+		std::vector<int> d(num_vertices(Full_g));
+		vertex_descriptor s;
+		for (int j=0; j<num_vertices(Full_g); j++){
+			if(Rank[j] > 0.){
+				s = vertex(j, Full_g);
+				dijkstra_shortest_paths(Full_g, s, predecessor_map(&p[0]).distance_map(&d[0]));
+				//std::cout <<" Vertex "<< j << std::endl;
+				graph_traits < graph_t >::vertex_iterator vi, vend;
+				for (boost::tie(vi, vend) = vertices(Full_g); vi != vend; ++vi) {
+					if (p[*vi]!=*vi){
+						Dist[*vi][j]=d[*vi];
+						Dist[j][*vi]=d[*vi];
+                        if (Dist[*vi][j]>max_dist){
+                            max_dist=Dist[*vi][j];
+					} else {
+						Dist[*vi][j]=-1.;
+						Dist[j][*vi]=-1.;
+	void update_ranks(void){
+		for(int i=0; i<N_nodes; i++){
+			Rank[i]=0.;
+				if (Tried[i][j]>0. && Final[i][j] >0.){
+					Rank[i]++;
+					Rank[j]++;
+	void set_world(double a_i, double a_m, double b, double g, double d){
+		alpha_i=a_i;
+		alpha_m=a_m;
+		gamma=g;
+		beta=b;
+		delta=d;
+	void reset_world(){
+				if (Final[i][j] > 0. && Tried[i][j] > 0){
+		current_loss=0;
+		current_epoch=0;
+		current_repeat++;
+        current_novelty=0;
+			Rank[i]=0.;
+				Prob[i][j]=0.;
+				Dist[i][j]=-1.;
+				Tried[i][j]=0.;
+    void show_parameters(void){
+        std::cout << "Parameters: "
+        << alpha_i << " "
+        << alpha_m << " | "
+        << beta << " "
+        << gamma << " | "
+        << delta << std::endl;
+    string file_name(){
+        s << "world_"
+        << lexical_cast<std::string>(alpha_i) << "_"
+        << lexical_cast<std::string>(alpha_m) << "_"
+        << lexical_cast<std::string>(beta) << "_"
+        << lexical_cast<std::string>(gamma) << "_"
+        << lexical_cast<std::string>(delta) << "_"
+        << lexical_cast<std::string>(N_epochs) << "_"
+        << lexical_cast<std::string>(N_steps) << "_"
+        << lexical_cast<std::string>(N_repeats) << ".txt";
+        return s.str();
+    void set_verbose(int verbose){
+        verbose_level = verbose;
+    void update_probabilities(void){
+		// Compute sampling probabilities
+		// first pass: \xi_i,j
+				double bg = 0.;
+				Prob[i][j] = alpha_i*log(min(Rank[i]+1.,Rank[j]+1.)) +
+                alpha_m*log(max(Rank[i]+1.,Rank[j]+1.));
+                if (Dist[i][j] > 0.){
+                    double k = Dist[i][j];
+                    if (k >= k_max){
+                        k = k_max-1;
+                    bg = beta * log(k/k_max) + gamma * log(1. - k/k_max);
+                } else {
+                    bg = delta;
+				Prob[i][j] = exp(Prob[i][j] + bg);
+		// second pass: sum
+		double Summa = 0.;
+		// third pass: normalize
+				Prob[i][j] /= Summa;
+	// Now we are ready for simulations
+	void update_world(){
+		int failed = 0;
+		// Given current universe compute shortest paths
+		update_current_graph();
+		update_ranks();
+		update_distances();
+		update_probabilities();
+		// sampling
+		int result;
+		double cost=0., novel=0.;
+		int publishable = 0;
+		if (mode_identify_failed == 1){
+			while(publishable < N_steps){
+		    	result = sample();
+			    publishable += result;
+			    failed += (1-result);
+					cost+=Tried[i][j];
+					if (Tried[i][j]>0. && Final[i][j]>0.){
+						novel+=1.;
+		else {
+			double pfail=0.;
+			int n_failed;
+			//, n_check = 0;
+					if (Final[i][j] == 0.){
+						pfail += Prob[i][j];
+						Prob[i][j] = 0.;
+					Prob[i][j] /= (1.-pfail);
+				//std::cout << std::endl;
+			n_failed = sample_failed_number(pfail);
+			current_loss += (n_failed + N_steps);
+			cost = current_loss;
+						novel+=1.;
+        current_novelty = novel;
+            std::cout << (current_repeat+1) << "  epoch=" << (current_epoch+1)
+		    << "  cost=" << cost
+		    << " novel=" << novel
+		    << " rel_loss=" << cost/novel
+		    << std::endl;
+		current_epoch++;
+	//======  Destructor ======
+	~Universe(){
+		delete_2Dmatrix(Final, N_nodes);
+		delete_2Dmatrix(Dist, N_nodes);
+		delete_2Dmatrix(Tried, N_nodes);
+		delete_2Dmatrix(Prob, N_nodes);
+        delete_2Dmatrix(EdgeIndex, N_nodes);
+		delete_1Dmatrix(Rank);
+    // Allocate memory
+    double** allocate_2Dmatrix(int N, int M)
+        double **pointer;
+            std::cout<< "["<<N<<"|"<<M<<"]"<<std::endl;
+        pointer = new double*[N];
+        for (int i = 0; i < N; ++i)
+            pointer[i] = new double[M];
+        return pointer;
+    double* allocate_1Dmatrix(int N)
+        double *pointer;
+        if(N > 0){
+            pointer = new double[N];
+        }else {
+            pointer = NULL;
+        return pointer;
+    // De-Allocate memory to prevent memory leak
+    void delete_2Dmatrix(double **pointer, int N){
+        if (pointer != NULL){
+            for (int i = 0; i < N; ++i){
+                delete [] pointer[i];
+            delete [] pointer;
+    void delete_1Dmatrix(double *pointer){
+    double get_rel_loss(){
+        return CumulativeRelativeLoss ;
+    double get_rel_loss_err(){
+        return CRLsquare ;
+    void evolve_to_target_and_save(int istart, int iend, double* storage, int* counters){
+        double ALOT=100000000000.;
+	// std::cout<<" evolve_to_target_and_save: istart=" << istart << "iend=" << iend << "\n";
+        reset_world();
+        for (int k = istart; k < iend; k++){
+	  // std::cout<<" evolve: k=" << k << "\n";
+            for(int i=0; i< N_epochs &&  current_novelty < TargetNovelty; i++){
+	      // std::cout<<" evolve: k=" << k << " i=" << i << " cur=" << current_novelty << " Target=" << TargetNovelty << "\n";
+                update_world();
+            storage[k]=current_loss/current_novelty;
+            counters[k]=1;
+            reset_world();
+    int get_reruns(void){
+        return N_repeats;
+    double get_parameter(int i){
+        switch(i){
+            case 0:
+                return alpha_i;
+            case 1:
+                return alpha_m;
+            case 2:
+                return beta;
+            case 3:
+                return gamma;
+            case 4:
+                return delta;
+            default:
+                std::cout << "Erroneous parameter id!!!!\n\n\n";
+                return 0.;
+    void evolve_to_target(){
+        reset_world();
+        if (beta < -1. || gamma < -1.){
+            CumulativeRelativeLoss = 100000000000.;
+            CRLsquare = 0.;
+            return;
+        for (int k=0; k< N_repeats; k++){
+            for(int i=0; i<N_epochs &&  current_novelty < TargetNovelty; i++){
+                update_world();
+            CumulativeRelativeLoss += current_loss/current_novelty;
+            CRLsquare += (current_loss/current_novelty)*(current_loss/current_novelty);
+            if(verbose_level==3){
+                std::cout <<  CumulativeRelativeLoss << " | " << CRLsquare << std::endl;
+            if(verbose_level==1){
+                std::cout <<  "." ;
+            else if(verbose_level==2){
+                std::cout <<  "**" << (k+1) <<  "**  curr loss " << current_loss << "; curr novelty " << current_novelty << std::endl;
+            reset_world();
+        CumulativeRelativeLoss /= double(N_repeats);
+        CRLsquare /= double(N_repeats);
+        if(verbose_level==2){
+            std::cout <<  CumulativeRelativeLoss << " || " << CRLsquare << std::endl;
+        CRLsquare = 2*sqrt((CRLsquare - CumulativeRelativeLoss*CumulativeRelativeLoss)/double(N_repeats));
+    int set_parameter(double value, int position){
+        if (position < 0 || position > 4) {return 0;}
+        else {
+            switch(position){
+                case 0:
+                    alpha_i=value;
+                    return 1;
+                case 1:
+                    alpha_m=value;
+                    return 1;
+                case 2:
+                    beta=value;
+                    return 1;
+                case 3:
+                    gamma=value;
+                    return 1;
+                case 4:
+                    delta=value;
+                    return 1;
+        return 0;
+#ifdef notdef
+    void try_annealing(double starting_jump, int iterations,
+                       double temp_start, double temp_end, double target_rejection){
+        double dx[5]={0.,0.,0.,0.,0};
+        double x[5]={0.,0.,0.,0.,0};
+        double rejection[5]={0., 0., 0., 0., 0.};
+        double curr_x, curr_err, x_tmp;
+        double temperature;
+        double ratio, r;
+        int cycle=10;
+        boost::variate_generator<base_generator_type&, boost::uniform_real<> > uni(generator, uni_dist);
+        // set up parameter for annealing
+        x[0]=alpha_i;
+        x[1]=alpha_m;
+        x[2]=beta;
+        x[3]=gamma;
+        x[4]=delta;
+        for(int i=0;i<5;i++){
+            dx[i] = starting_jump;
+        // establish the current value
+        evolve_to_target();
+        std::cout << CumulativeRelativeLoss << " +- " << CRLsquare << std::endl;
+        curr_x   = CumulativeRelativeLoss;
+        curr_err = CRLsquare;
+        CumulativeRelativeLoss = 0;
+        CRLsquare = 0;
+        // optimization cycle
+        for(int i=0; i<iterations; i++){
+            temperature = temp_start*exp( i*(log(temp_end)-log(temp_start))/(double)iterations);
+            std::cout  << std::endl << "....T = " << wrap_double(temperature,3) << std::endl << std::endl;
+            if (i % cycle == 0 && i > 0){
+                for (int k=0; k<5; k++){
+                    rejection[k]/=(double)cycle;
+                    if (rejection[k] > 0){
+                        dx[k] = dx[k]/(rejection[k]/target_rejection);
+                        rejection[k]=0.;
+                    else{
+                        dx[k]*=2.;
+                    std::cout  << dx[k] << " ";
+            for (int j=0; j<5; j++){
+                // get new value of x[j]
+                x_tmp = get_new_x(x[j],dx[j]);
+                set_parameter(x_tmp, j);
+                std::cout  << std::endl << "......... " << std::endl;
+                std::cout << "Trying... " << CumulativeRelativeLoss << " +- " << CRLsquare << std::endl;
+                ratio = min(1.,exp(-(CumulativeRelativeLoss-curr_x)/temperature));
+                r = uni();
+                std::cout << r << " vs " << ratio << std::endl;
+                if (r > ratio){
+                    std::cout << string_wrap(id, 4) <<" "<< (i+1) << ","<< (j)
+                    <<" "<< (i+1) << " Did not accept "
+                    << x_tmp << "(" << j << ")" << std::endl;
+                    std::cout << alpha_i << " "<< alpha_m << " "
+                    << beta << " " << gamma << " "
+                    << delta << " " << std::endl;
+                    set_parameter(x[j], j);
+                    CRLsquare = 0;
+                    rejection[j]+=1.;
+                else {
+                    x[j] = x_tmp;
+                    CRLsquare = 0;
+                    std::cout << (i+1) << string_wrap((string) " Rejection counts: ", 8)
+                    << wrap_double(rejection[0],2)
+                    << " "<< wrap_double(rejection[1], 7) << " "
+                    << wrap_double(rejection[2],5) << " " << wrap_double(rejection[2],9) << " "
+                    << wrap_double(rejection[4],6) << " "
+                    << std::endl << std::endl;
+                    std::cout << string_wrap(id, 4) <<" "<< (i+1) <<","<< (j)
+                    << string_wrap((string) "***** Did accept! ", 3)
+                    << wrap_double(alpha_i,2)
+                    << " "<< wrap_double(alpha_m, 7) << " "
+                    << wrap_double(beta,5) << " "
+                    << wrap_double(gamma,9) << " "
+                    << wrap_double(delta,6) << " "
+#endif // notdef
+std::pair<double,double> multi_loss( // dispatch_group_t group,
+                                    Universe* un[],
+                                    // dispatch_queue_t* CustomQueues,
+                                    double* Results,
+                                    int*    Counters,
+                                    double* params){
+    int N = un[0]->get_reruns();
+    int step = (int)(double)N/(double)(Nworkers);
+    int istart=0;
+    int iend = istart+step;
+    double Loss=0., LossSquare=0.;
+    timeval startTime, endTime;
+    double elapsedTime;
+    // start timer
+    gettimeofday(&startTime, NULL);
+    //err:    for(int i=0; i<Nworkers; i++){
+    std::cout << "Entry to multi_loss, params: ";
+    for(int i=0; i<Nworkers; i++){
+        for(int j=0; j<NEVOPARAMS; j++){
+	  std::cout << "[" << un[i]->get_parameter(j) << "," << params[j] << "] ";
+            un[i]->set_parameter(params[j],j);
+    std::cout << "\n";
+    int i;
+    #pragma omp parallel for private (i)
+    for(i=0; i<Nworkers; i++){
+      // dispatch_group_async(group, CustomQueues[i], ^{
+      std::cout<<"multi_loss: Calling evolve_to_target_and_save i=" << i << " N=" << N << " step=" << step << " istart=" << i*step << " iend=" << (i+1)*step << "\n";
+      //un[i]->evolve_to_target_and_save(istart, iend, Results, Counters);
+      un[i]->evolve_to_target_and_save(i*step, min((i+1)*step,N), Results, Counters);
+      // std::cout<<"multi_loss: Returned from evolve_to_target_and_save " << i << "\n";
+      //istart += step;
+      //iend = min(istart+step,N);
+    // err    }
+    // dispatch_group_wait(group, DISPATCH_TIME_FOREVER);
+    //dispatch_release(group);
+    for (int i=0; i<N; i++){
+        Loss+=Results[i]/(double)N;
+        LossSquare+=Results[i]*Results[i]/(double)N;
+        std::cout<<i<<":"<< Results[i] << " ";
+    std::cout<<" \n\n\n";
+    double two_std = ((LossSquare - Loss*Loss)/(double)N);
+    two_std = 2.*sqrt(two_std);
+    std::pair<double,double> Res;
+    Res.first=Loss;
+    Res.second=two_std;
+    gettimeofday(&endTime, NULL);
+    elapsedTime = (endTime.tv_sec - startTime.tv_sec) * 1000.0;      // sec to ms
+    elapsedTime += (endTime.tv_usec - startTime.tv_usec) / 1000.0;   // us to ms
+    elapsedTime /= 1000.;
+    cout << "multi_loss(N=" << N << ") elapsed time: " << elapsedTime << " seconds " << elapsedTime/60. << " minutes\n\n";
+    return Res;
+void multi_annealing( // dispatch_group_t group,
+                     Universe* un[],
+                     double T_start, double T_end,
+                     double Target_rejection,
+                     int Annealing_repeats,
+                     double starting_jump,
+                     double* Results,
+                     int*    Counters,
+                     double* params0,
+                     double annealing_cycles){
+    // re-implement annealing
+    double dx[NEVOPARAMS]={0.,0.,0.,0.,0};
+    double x[NEVOPARAMS]={0.,0.,0.,0.,0};
+    double rejection[NEVOPARAMS]={0., 0., 0., 0., 0.};
+    double ratio, r;
+    int cycle=10;
+    for(int i=0;i<NEVOPARAMS;i++){
+        x[i]=params0[i];
+	for(int w=0; w<Nworkers; w++){
+	  un[w]->set_parameter(x[i], i);
+    std::pair<double,double>Res;
+    if ( operation == 'm' ) {
+      // Nworkers = 1;
+    else if (operation == 'g') {
+      // generate params: not yet implemented - to be deprecated
+    else if (operation == 'a') {
+      // analyze multi_loss() results: not tested or used - to be deprecated
+      string line;
+      ifstream mlossdata ("multi_loss.data");
+      double d, Loss, LossSquare, two_std;
+      bool b;
+      int n=0;
+      if (mlossdata.is_open()) {
+	while ( getline (mlossdata,line) ) {
+	  b = from_string<double>(d, std::string(line), std::dec);
+	  cout << line << " d=" << d << endl;
+	  Loss += d;
+          LossSquare += (d*d);
+          n++;
+        Loss /= double(n);
+	LossSquare /= double(n);
+	two_std = ((LossSquare - Loss*Loss)/(double)n);
+	std::cout<<"n="<<n<<" Loss="<<Loss<<" LossSquare="<<LossSquare<<" two_std="<<two_std<<"\n\n\n";
+	mlossdata.close();
+	FILE *f=fopen("multi_loss_stats.txt","w");
+	fprintf(f,"%d n\n",n);
+	fprintf(f,"%.20e Loss\n",Loss);
+	fprintf(f,"%.20e LossSquare\n",LossSquare);
+	fprintf(f,"%.20e two_std\n",two_std);
+        fclose(f);
+	exit(0);
+      else {
+	cout << "Unable to open file multi_loss.data";
+	exit(1);
+    std::cout << "Calling initial multi_loss:\n";
+    Res = multi_loss( /* group,*/ un, /* CustomQueues,*/ Results, Counters, x);
+    std::cout << "Ret from initial multi_loss:\n";
+    std::cout << Res.first << " +- " << Res.second << std::endl;
+      FILE *f;
+      f = fopen("multi_loss.data","w");
+      for(int i=0; i<N; i++) {
+	fprintf(f,"%.20e\n",Results[i]);
+      fclose(f);
+      exit(0);
+    curr_x   = Res.first;
+    curr_err = Res.second;
+    for(int i=0; i<annealing_cycles; i++){
+        temperature = T_start*exp( i*(log(T_end)-log(T_start))/(double)annealing_cycles);
+            for (int k=0; k<NEVOPARAMS; k++){
+                    dx[k] = dx[k]/(rejection[k]/Target_rejection);
+                    rejection[k]=0.;
+                else{
+                    dx[k]*=2.;
+        for (int j=0; j<NEVOPARAMS; j++){
+            if (FIX_VARIABLES==0 || var_fixed[j]==0){
+                double x_hold=x[j];
+                x[j]=x_tmp;
+                std::cout << wrap_double(x_tmp,10) << " " << wrap_double(j,9) << "\n\n";
+                    un[w]->set_parameter(x_tmp, j);
+		// WRITE OUT PARAMS HERE; then exit.
+		std::cout << "Calling multi_loss: i=" << i << " j=" << j << "\n";
+                Res = multi_loss(/* group, */ un, /* CustomQueues, */ Results, Counters, x);
+		std::cout << "Ret from multi_loss: i=" << i << " j=" << j << "\n";
+                ratio = min(1.,exp(-(Res.first-curr_x)/temperature));
+                r = rand()/(double)(pow(2.,31)-1.);
+                if (Res.first < ALOT)
+                    ofstream filestr;
+                    filestr.open ("best_opt_some.txt", ofstream::app);
+                    // >> i/o operations here <<
+                    filestr << un[0]->get_target() << ","
+                    << Res.first
+                    << "," << un[0]->get_parameter(0)
+                    << "," << un[0]->get_parameter(1)
+                    << "," << un[0]->get_parameter(2)
+                    << "," << un[0]->get_parameter(3)
+                    << "," << un[0]->get_parameter(4) << "," << Res.second << ",\n";
+                    filestr.close();
+                    filestr.open ("max_dist.txt", ofstream::app);
+                    filestr << max_dist << ",\n";
+                    filestr.close();
+                if (r > ratio){
+                    std::cout << " "<< (i+1) << ","<< (j)
+                    std::cout << un[0]->get_parameter(0)
+                    << " " << un[0]->get_parameter(1)
+                    << " " << un[0]->get_parameter(2)
+                    << " " << un[0]->get_parameter(3)
+                    << " " << un[0]->get_parameter(4) << " " << std::endl;
+                    x[j]=x_hold;
+                        un[w]->set_parameter(x[j], j);
+                    //set_parameter(x[j], j);
+                    rejection[j]+=1.;
+                else {
+                    x[j] = x_tmp;
+                    << wrap_double(rejection[0],2) << " "
+                    << wrap_double(rejection[1],7) << " "
+                    << wrap_double(rejection[3],9) << " "
+                    std::cout << " "<< (i+1) <<","<< (j)
+                    << wrap_double(un[0]->get_parameter(0),2) << " "
+                    << wrap_double(un[0]->get_parameter(1),7) << " "
+                    << wrap_double(un[0]->get_parameter(2),5) << " "
+                    << wrap_double(un[0]->get_parameter(3),9) << " "
+                    << wrap_double(un[0]->get_parameter(4),6) << " "
+int
+main(int argc, char* argv[])
+    double params0[6] = {0., 0., 0., 0., 0., 0.2}, target=50., range;
+    string par_names0[6] = {"alpha_i", "alpha_m", "beta", "gamma", "delta", "target"};
+    string par_names1[4] = {"n_epochs", "n_steps", "n_reruns", "range"};
+    string par_names2[5] = {"T_start", "T_end", "Annealing_steps","Target_rejection","Starting_jump"};
+    string par_names3[5] = {"FREEZE_alpha_i", "FREEZE_alpha_m", "FREEZE_beta", "FREEZE_gamma", "FREEZE_delta"};
+    string par_names4[2] = {"Operation", "Nworkers"};
+    int params1[4] = {300, 50, 1000, 10};
+    int params3[5] = { 0, 0, 0, 0, 0};
+    //          temperature_start,  temperature_end,  annealing_steps target_rejection  Starting_jump
+    double params2[5] = {1,             0.001,               100,              0.3,           1.5};
+    int verbose_level = 2;
+    const std::string one="one", two="two";
+    static Universe* un[MAXNworkers];
+    // static dispatch_queue_t CustomQueues[MAXNworkers];
+    static double* Results;
+    static int*    Counters;
+    timeval t1, t2;
+    // start timer
+    gettimeofday(&t1, NULL);
+    if (argc < 8) {
+        std::cout << "Usage: super_optimizer alpha_i alpha_m beta gamma delta target_innov [n_epochs n_steps n_reruns] [range] [verbose_level]\n";
+        std::cout << "         [T_start T_end Annealing_steps Target_rejection Starting_jump]\n";
+        std::cout << "         [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta]\n";
+        system("pwd");
+        return(1);
+    else {
+      std::cout << "argc=" << argc << std::endl;
+        for (int nArg=0; nArg < argc; nArg++){
+            //std::cout << nArg << " " << argv[nArg] << std::endl;
+            if (nArg > 0 && nArg < 7){
+                params0[nArg-1]= atof(argv[nArg]);
+                std::cout << par_names0[nArg-1] << ": " << params0[nArg-1] <<  std::endl;
+            if (nArg > 6 && nArg < 11){
+                params1[nArg-7]= atoi(argv[nArg]);
+                std::cout << par_names1[nArg-7] << ": " << params1[nArg-7] <<  std::endl;
+            if (nArg == 11){
+                verbose_level = atoi(argv[nArg]);
+                std::cout << "verbose level: " << verbose_level <<  std::endl;
+            if (nArg > 11 && nArg < 17){
+                params2[nArg-12]= atof(argv[nArg]);
+                std::cout << par_names2[nArg-12] << ": " << params2[nArg-12] <<  std::endl;
+            if (nArg > 16 && nArg < 22){
+                params3[nArg-17]= atof(argv[nArg]);
+                var_fixed[nArg-17]= atof(argv[nArg]);
+                std::cout << par_names3[nArg-17] << ": " << var_fixed[nArg-17] <<  std::endl;
+            if (nArg == 22 ){
+                operation = *argv[nArg];
+		std::cout << par_names4[0] << ": " << operation <<  std::endl;
+            if (nArg == 23 ){
+	        Nworkers = atoi(argv[nArg]);
+		std::cout << par_names4[1] << ": " << Nworkers <<  std::endl;
+    for target in range(58,1009,50):
+	s = ("%d" % target)
+	print s
+	for i in range(15):
+          # Param groups separated by "|" below for documentation. NOTE that | is not used on command line!
+	  os.system("./supe_duper_optimizer |0 0 4 50 -1 "+s+" | 40000 20 1000 2 | 1 | 2. 0.01 100 0.3 2.3 | 1 1 0 0 0")
+    /*   Parameters, re-iterated:
+                        "alpha_i", "alpha_m", "beta", "gamma", "delta", "target"};
+                    {"n_epochs", "n_steps", "n_reruns", "range"};
+                       {"T_start",          "T_end",          "Annealing_steps","Target_rejection","Starting_jump"};
+                         temperature_start,  temperature_end,  annealing_steps target_rejection  Starting_jump
+                     {"FREEZE_alpha_i", "FREEZE_alpha_m", "FREEZE_beta", "FREEZE_gamma", "FREEZE_delta"};
+        cout << j << " | " << var_fixed[j] << " (fixed) \n";
+    target=params0[NEVOPARAMS];
+    range = (double)params1[3];
+	int identify_failed = 0;
+	char* filename= (char *)"movie_graph.txt";
+ 	int n_ep=params1[0], n_st=params1[1], n_rep=params1[2];
+        un[i] = new Universe((char *)filename,n_ep,n_st,
+                             (int)n_rep,
+                             identify_failed, target, i2string(i));
+        // CustomQueues[i] = dispatch_queue_create(i2char(i), NULL);
+    // mw: n_rep == n_reruns = # times evolve is done within multi_loss, spread across Nworkers.
+    if(n_rep > 0){
+        Results = new double[n_rep];
+        Counters = new int[n_rep];
+    }else {
+        Results =  NULL;
+        Counters = NULL;
+        std::cout << " Number of reruns should be positive! " <<  std::endl;
+        return 0;
+    //srand(time(0));
+    //srandomdev();
+      timeval t;
+      gettimeofday(&t, NULL);
+      srand(t.tv_usec);
+        double r=0;
+        for (int j=0; j<100; j++){
+            std::cout << r << " ";
+        std::cout << "\n ";
+  	//random initiation of starting parameters
+    if (range > 0.){
+        for (int i=0; i < 5; i++){
+            if (params0[i]==-100.){
+                double r1 = (rand()/(double)(pow(2.,31)-1.));
+                double r2 = (rand()/(double)(pow(2.,31)-1.));
+                double sign = 1.;
+                if(r1 > 0.5){
+                    sign=-1.;
+                params0[i] = sign*r2*range;
+                std::cout << par_names0[i] << ": " << params0[i] <<  std::endl;
+    double T_start=params2[0], T_end=params2[1], Target_rejection=params2[3], starting_jump=params2[4];
+    int Annealing_repeats = (int) params2[2];
+    // dispatch_group_t group = dispatch_group_create();
+    multi_annealing( /* group, */ un, /* CustomQueues, */ T_start, T_end, Target_rejection, Annealing_repeats,
+		     starting_jump, Results, Counters, params0, Annealing_repeats);
+    //dispatch_group_wait(group, DISPATCH_TIME_FOREVER);
+    // dispatch_release(group);
+    // stop timer
+    gettimeofday(&t2, NULL);
+    // compute and print the elapsed time in millisec
+    elapsedTime = (t2.tv_sec - t1.tv_sec) * 1000.0;      // sec to ms
+    elapsedTime += (t2.tv_usec - t1.tv_usec) / 1000.0;   // us to ms
+    cout << elapsedTime << " seconds " << elapsedTime/60. << " minutes\n\n";
+        delete un[i];
+    if(n_rep > 0){
+        delete [] Results;
+        delete [] Counters;
+    return 0;
Copied: SwiftApps/SciColSim/old/optirun.swift (from rev 5634, SwiftApps/SciColSim/optirun.swift)
--- SwiftApps/SciColSim/old/optirun.swift	                        (rev 0)
+++ SwiftApps/SciColSim/old/optirun.swift	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,41 @@
+type file;
+app (file outfile, file best, file max) optimize ( string args[], file graph )
+  optimizersh @best @max args stdout=@outfile ;
+int minrange=58;
+int maxrange=1009;
+//int maxrange=209;
+int rangeinc=50;
+int nreps=2; # 15
+//      [alpha_i alpha_m beta gamma delta target_innov
+//      [n_epochs n_steps n_reruns] [range]
+//      [verbose_level]
+//      [T_start T_end Annealing_steps Target_rejection Starting_jump]
+//      [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta]
+file graph <"movie_graph.txt">;
+foreach target in [minrange:maxrange:rangeinc] {
+  foreach rep in [1:nreps] {
+    file outfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".out")>;
+    // file errfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".err")>;
+    file bestfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".best_opt_some")>;
+    file maxfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".max_dist")>;
+    // string longargs[] = @strcat("0 0 4 50 -1 ",target," 40000 20 1000 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0");
+    string fastargs1[] = ["0", "0", "4", "50", "-1", @strcat(target), "40000", "20", "1000", "2", "1", "2.", "0.01", "100", "0.3", "2.3", "1", "1", "0", "0", "0"];
+       "1",
+    (outfile, bestfile, maxfile) = optimize(fastargs2,graph);
Copied: SwiftApps/SciColSim/old/sites.beagle.quick.xml (from rev 5634, SwiftApps/SciColSim/sites.beagle.quick.xml)
--- SwiftApps/SciColSim/old/sites.beagle.quick.xml	                        (rev 0)
+++ SwiftApps/SciColSim/old/sites.beagle.quick.xml	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,25 @@
+<config>
+    <execution provider="coaster" jobmanager="local:pbs"/>
+    <profile namespace="env" key="SWIFT_GEN_SCRIPTS">KEEP</profile>
+    <profile namespace="globus" key="jobsPerNode">1</profile>
+    <profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
+    <profile namespace="globus" key="maxTime">10000</profile>
+    <profile namespace="globus" key="maxWallTime">01:30:00</profile>
+    <profile namespace="globus" key="slots">50</profile>
+    <profile namespace="globus" key="nodeGranularity">2</profile>
+    <profile namespace="globus" key="maxNodes">2</profile>
+    <profile namespace="karajan" key="jobThrottle">9.59</profile>
+    <workdirectory >/lustre/beagle/ketan/labs/SciColSim-Bgl/swift.workdir</workdirectory>
+  </pool>
+</config>
Copied: SwiftApps/SciColSim/old/sites.beagle.xml (from rev 5634, SwiftApps/SciColSim/sites.beagle.xml)
--- SwiftApps/SciColSim/old/sites.beagle.xml	                        (rev 0)
+++ SwiftApps/SciColSim/old/sites.beagle.xml	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,24 @@
+<config>
+    <!--<profile namespace="globus" key="jobsPerNode">24</profile>-->
+    <profile namespace="globus" key="maxTime">37000</profile>
+    <profile namespace="globus" key="maxWallTime">10:00:00</profile>
+  </pool>
+</config>
Copied: SwiftApps/SciColSim/old/t1.py (from rev 5634, SwiftApps/SciColSim/t1.py)
--- SwiftApps/SciColSim/old/t1.py	                        (rev 0)
+++ SwiftApps/SciColSim/old/t1.py	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,22 @@
+#! /usr/bin/env python
+import os
+# FULL for target in range(58,1009,50):
+# FAST for target in range(58,209,50):
+for target in range(58,59,50):
+	print s
+# FULL	for i in range(15):
+# FAST	for i in range(2):
+		args="./toptimizer 0 0 4 50 -1 "+s+" 40000 20 1000 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0 # > out.T"+str(target)+".i"+str(i)
+		args="OMP_NUM_THREADS=24 ./toptimizer 0 0 4 50 -1 "+s+" 40000 20 100 2 1 2. 0.01 2 0.3 2.3 1 1 0 0 0 # > out.T"+str(target)+".i"+str(i)
+		args="OMP_NUM_THREADS=24 ./toptimizer 0 0 4 50 -1 "+s+" 40000 20 100 2 1 2. 0.01 2 0.3 2.3 1 1 1 0 0 # > out.T"+str(target)+".i"+str(i)
+		print("\n\n **** CALLING APP: "+args+"\n\n\n")
+	        os.system(args);
+#		print("\n\n **** CALLING APP: ./optimizer 0 0 4 50 -1 "+s+" 40000 20 10 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0\n\n\n")
+#		FAST: os.system("./optimizer 0 0 4 50 -1 "+s+" 40000 20 10 2 1 2. 0.01 2 0.3 2.3 1 1 0 0 0")
+print "Done!"
Copied: SwiftApps/SciColSim/old/t2.py (from rev 5634, SwiftApps/SciColSim/t2.py)
--- SwiftApps/SciColSim/old/t2.py	                        (rev 0)
+++ SwiftApps/SciColSim/old/t2.py	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,23 @@
+import os
+	print s
+		args="./toptimizer 0 0 4 50 -1 "+s+" 40000 20 75    2 1 2. 0.01 2 0.3 2.3 1 1 1 0 0 m # > out.T"+str(target)+".i"+str(i)
+		args="OMP_NUM_THREADS=24 ./toptimizer 0 0 4 50 -1 "+s+" 40000 20 96    2 1 2. 0.01 2 0.3 2.3 1 1 0 0 0 m 24 # > out.T"+str(target)+".i"+str(i)
+	        os.system(args);
+print "Done!"
Copied: SwiftApps/SciColSim/old/t3.py (from rev 5634, SwiftApps/SciColSim/t3.py)
--- SwiftApps/SciColSim/old/t3.py	                        (rev 0)
+++ SwiftApps/SciColSim/old/t3.py	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,22 @@
+import os
+	print s
+		args="./toptimizer 0 0 4 50 -1 "+s+" 40000 20 75    2 1 2. 0.01 2 0.3 2.3 1 1 1 0 0 a # > out.T"+str(target)+".i"+str(i)
+	        os.system(args);
+print "Done!"
Copied: SwiftApps/SciColSim/old/tc (from rev 5634, SwiftApps/SciColSim/tc)
--- SwiftApps/SciColSim/old/tc	                        (rev 0)
+++ SwiftApps/SciColSim/old/tc	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,15 @@
+localhost sh /bin/sh null null null
+localhost cat /bin/cat null null null
+pbs cat /bin/cat null null null
+mcs cat /bin/cat null null null
+localhost catnap /home/wilde/swift/lab/catnap.sh null null GLOBUS::maxwalltime="00:01:00"
+beagle optimizer /home/wilde/AndreysOptimizer/src/Optimizer null null null
+beagle optimizersh /home/wilde/AndreysOptimizer/src/optimizer.sh null null null
+beagle evolve /home/wilde/AndreysOptimizer/src/evolve.sh null null null
+localhost evolve /home/wilde/AndreysOptimizer/src/evolve.sh null null GLOBUS::maxwalltime="02:00:00"
+beagle sumloss /home/wilde/AndreysOptimizer/src/sumloss.sh null null null
+localhost sumloss /home/wilde/AndreysOptimizer/src/sumloss.sh null null GLOBUS::maxwalltime="02:00:00"
Copied: SwiftApps/SciColSim/old/test-orig.sh (from rev 5634, SwiftApps/SciColSim/test-orig.sh)
--- SwiftApps/SciColSim/old/test-orig.sh	                        (rev 0)
+++ SwiftApps/SciColSim/old/test-orig.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,21 @@
+#! /bin/bash
+python <<END
+import os
+target = 58
+s = ("%d" % target)
+args="0 0 4 50 -1 "+s+" 40000 20 1000 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0 "
+args="0 0 4 50 -1 "+s+" 40000 20  100 2 1 2. 0.01   2 0.3 2.3 1 1 0 0 0 "
+print("\n\n **** CALLING APP: "+args+"\n\n\n")
+os.system("./optimizer "+args+" >out.o.T"+s);
+os.system("./Optimizer "+args+" >out.O.T"+s);
+print "Done!"
+END
Copied: SwiftApps/SciColSim/old/test-swift.sh (from rev 5634, SwiftApps/SciColSim/test-swift.sh)
--- SwiftApps/SciColSim/old/test-swift.sh	                        (rev 0)
+++ SwiftApps/SciColSim/old/test-swift.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -0,0 +1,7 @@
+swift -config cf -tc.file tc -sites.file local.xml annealing.swift \
+  -e33="$escapecode"
+#  -evolveReruns=20  \
+#  -annealingCycles=10
Property changes on: SwiftApps/SciColSim/optimizer.cpp
___________________________________________________________________
Deleted: svn:executable
Deleted: SwiftApps/SciColSim/optimizer.orig-mac.cpp
--- SwiftApps/SciColSim/optimizer.orig-mac.cpp	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/optimizer.orig-mac.cpp	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,1673 +0,0 @@
-//  main.cpp
-//  optimizer
-//  Created by Andrey Rzhetsky on 4/11/11.
-//  Copyright 2011 University of Chicago. All rights reserved.
-#define Nworkers 2
-#include <fstream>
-#include <iostream>
-#include <stdio.h>
-#include <time.h>
-#include <ctime>
-#include <algorithm>
-#include <string>
-#include <stdio.h>
-#include <sys/param.h>
-#include <sys/time.h>
-#include <sys/types.h>
-#include <dispatch/dispatch.h>
-#include <fstream>
-#include <stdlib.h>
-#include <boost/numeric/ublas/io.hpp>
-#include <boost/graph/graph_traits.hpp>
-#include <boost/graph/dijkstra_shortest_paths.hpp>
-#include <boost/graph/loop_erased_random_walk.hpp>
-#include <boost/graph/random.hpp>
-#include <boost/property_map/property_map.hpp>
-#include <boost/graph/graph_concepts.hpp>
-#include <boost/graph/properties.hpp>
-#include <boost/graph/adjacency_list.hpp>
-#include <boost/graph/adjacency_matrix.hpp>
-#define BOOST_MATH_OVERFLOW_ERROR_POLICY ignore_error
-#define BOOST_MATH_DISCRETE_QUANTILE_POLICY real
-#include <boost/random/geometric_distribution.hpp>
-#include <boost/random/uniform_01.hpp>
-#include <boost/random.hpp>
-#include <boost/random/linear_congruential.hpp>
-#include <boost/random/uniform_int.hpp>
-#include <boost/random/uniform_real.hpp>
-#include <boost/random/variate_generator.hpp>
-#include <boost/generator_iterator.hpp>
-#include <boost/lexical_cast.hpp>
-#define INT_INFINITY 2147483647
-#define FIX_VARIABLES 1
-using namespace boost;
-using namespace std;
-using namespace boost::numeric::ublas;
-static int max_dist=0;
-typedef boost::adjacency_matrix<boost::directedS> Graph;
-typedef std::pair<int,int> Edge;
-typedef boost::graph_traits<Graph> GraphTraits;
-typedef boost::numeric::ublas::triangular_matrix<double, boost::numeric::ublas::strict_upper> prob;
-typedef boost::numeric::ublas::triangular_matrix<double, boost::numeric::ublas::strict_upper> pathlength;
-typedef boost::graph_traits<Graph>::vertex_descriptor vertex_descriptor;
-namespace std {
-	using ::time;
-static int var_fixed[5] = {1, 0, 1, 1, 0};
-typedef boost::minstd_rand base_generator_type;
-typedef adjacency_list < listS, vecS, directedS,
-no_property, property < edge_weight_t, int > > graph_t;
-typedef graph_traits < graph_t >::vertex_descriptor vertex_descriptor;
-typedef graph_traits < graph_t >::edge_descriptor edge_descriptor;
-string strDouble(double number)
-    stringstream ss;//create a stringstream
-    ss << number;//add number to the stream
-    return ss.str();//return a string with the contents of the stream
-double gaussian(double sigma)
-    double GaussNum = 0.0;
-    int NumInSum = 10;
-    for(int i = 0; i < NumInSum; i++)
-        GaussNum += ((double)rand()/(double)RAND_MAX - 0.5);
-    GaussNum = GaussNum*sqrt((double)12/(double)NumInSum);
-    return GaussNum;
-double diffclock(clock_t clock1,clock_t clock2)
-	double diffticks=clock1-clock2;
-	double diffms=(diffticks)/CLOCKS_PER_SEC;
-	return diffms;
-double get_new_x(double x, double dx){
-    double new_x;
-    // boost::variate_generator<base_generator_type&, boost::uniform_real<> > uni(generator, uni_dist);
-    double r = rand()/(double)(pow(2.,31)-1.);
-    if (r > 0.5){
-        new_x = x + rand()*dx/(double)(pow(2.,31)-1.);
-    } else {
-        new_x = x - rand()*dx/(double)(pow(2.,31)-1.);
-    return new_x;
-string string_wrap(string ins, int mode){
-    std::ostringstream s;
-    switch(mode){
-        case 0:
-            s << "\033[1;29m" << ins << "\033[0m";
-            break;
-        case 1:
-            s << "\033[1;34m" << ins << "\033[0m";
-            break;
-        case 2:
-            s << "\033[1;44m" << ins << "\033[0m";
-            break;
-        case 3:
-            s << "\033[1;35m" << ins << "\033[0m";
-            break;
-        case 4:
-            s << "\033[1;33;44m" << ins << "\033[0m";
-            break;
-        case 5:
-            s << "\033[1;47;34m" << ins << "\033[0m";
-            break;
-        case 6:
-            s << "\033[1;1;31m" << ins << "\033[0m";
-            break;
-        case 7:
-            s << "\033[1;1;33m" << ins << "\033[0m";
-            break;
-        case 8:
-            s << "\033[1;1;43;34m" << ins << "\033[0m";
-            break;
-        case 9:
-            s << "\033[1;1;37m" << ins << "\033[0m";
-            break;
-        case 10:
-            s << "\033[1;30;47m" << ins << "\033[0m";
-            break;
-        default:
-            s << ins;
-    return s.str();
-string wrap_double(double val, int mode){
-    s << string_wrap(strDouble(val),mode);
-    return s.str();
-const
-string i2string(int i){
-    s << "worker"
-    << lexical_cast<std::string>(i);
-    return s.str();
-char* i2char(int i){
-    s << "worker"
-    char* a=new char[s.str().size()+1];
-    memcpy(a,s.str().c_str(), s.str().size());
-    return a;
-class Universe {
-private:
-	double alpha_i;
-	double alpha_m;
-	double beta;
-	double gamma;
-	double delta;
-    double TargetNovelty;
-    double CumulativeRelativeLoss;
-    double CRLsquare;
-    string id;
-	int N_nodes;
-	int M_edges;
-	int N_epochs;
-	int N_steps;
-	int N_repeats;
-	int current_epoch;
-	double current_loss;
-	int current_repeat;
-    double current_novelty;
-	int mode_identify_failed;
-    int verbose_level; // 0 is silent, higher is more
-	double k_max;
-	graph_t Full_g;
-	double **Prob;
-	double **Tried;
-	double **Dist;
-	double **Final;
-    double **EdgeIndex;
-	double *Rank;
-    base_generator_type generator;
-    boost::uniform_real<> uni_dist;
-    boost::geometric_distribution<double> geo;
-public:
-	//======  Constructor ======
-	Universe(const std::string FileToOpen, int Epochs, int Steps, int Repeats, int identify_failed, double target, const std::string idd)
-		//typedef array_type2::index index2;
-		std::ifstream inFile;
-        //string line;
-        base_generator_type gene(42u);
-        generator = gene;
-        generator.seed(static_cast<unsigned int>(std::time(0)));
-        boost::uniform_real<> uni_d(0,1);
-        uni_dist = uni_d;
-		int i, k;
-        int x, y;
-		Edge* edge_array_mine;
-		int num_arcs_mine, num_nodes_mine;
-		int* weights_mine;
-        TargetNovelty = target;
-        CumulativeRelativeLoss = 0.;
-        CRLsquare = 0.;
-		N_epochs  = Epochs;
-		N_steps   = Steps;
-		N_repeats = Repeats;
-		current_epoch = 0;
-		current_loss = 0.;
-		current_repeat = 0;
-        id = idd;
-        verbose_level = 1;
-		mode_identify_failed = identify_failed;
-		// The first pass though file with the graph
-		inFile.open(FileToOpen.c_str());
-		if (inFile.fail()) {
-			cout << "Unable to open file";
-			exit(1); // terminate with error
-		}else {
-            if (verbose_level > 2){
-                std::cout <<  " Opened <" << FileToOpen << ">"<<std::endl;
-		i=0;
-        std::string line;
-		//while (! inFile.eof() && ! inFile.fail()) {
-        while (1==1) {
-            inFile >> x;
-            inFile >> y;
-                std::cout << " x: " << x;
-                std::cout << " y: " << y << std::endl;
-			if (i==0){
-				N_nodes=x;
-				M_edges=y;
-                break;
-			i++;
-		inFile.close();
-        if (verbose_level == 2){
-            std::cout << N_nodes <<  " nodes, " << M_edges << " edges"<<std::endl;
-		// k_max is the longest distance possible
-        //k_max = M_edges;
-		k_max = 70;
-		// Get memory allocated for all class members
-		Prob = allocate_2Dmatrix(N_nodes, N_nodes);
-		Tried = allocate_2Dmatrix(N_nodes, N_nodes);
-		Dist = allocate_2Dmatrix(N_nodes, N_nodes);
-		Final = allocate_2Dmatrix(N_nodes, N_nodes);
-        EdgeIndex = allocate_2Dmatrix(N_nodes, N_nodes);
-		Rank = allocate_1Dmatrix(N_nodes);
-        //The second pass through file with the graph
-		for(int i = 0; i < N_nodes; ++i) {
-			Rank[i]=0.;
-			for(int j = 0; j < N_nodes; ++j) {
-				Final[i][j] = 0.;
-				Prob[i][j]=0.;
-				Dist[i][j]=-1.;
-				Tried[i][j]=0.;
-                EdgeIndex[i][j]=-1;
-		// Fill in the final graph -- and we are ready to go!
-		if (!inFile) {
-            std::cout << "Unable to open file";
-		else {
-		i=0;
-		while (inFile >> x && inFile >>y) {
-			if (i > 0) {
-				Final[x][y]=1.;
-				Final[y][x]=1.;
-                    std::cout << ".";
-			i++;
-            std::cout << std::endl;
-		inFile.close();
-        k=0;
-        for (int i=0; i<N_nodes-1; i++){
-            for (int j=i+1;j<N_nodes; j++){
-                if(Final[i][j] > 0.){
-                    EdgeIndex[i][j]=k;
-                    k++;
-		// create graph -- hopefully, we can keep it, just modifying edge weights
-		edge_array_mine = new Edge[2*M_edges];
-		num_arcs_mine = 2*M_edges;
-		num_nodes_mine = N_nodes;
-		weights_mine = new int[2*M_edges];
-		for (int i=0; i<2*M_edges; i++){ weights_mine[i]=1;}
-		k=0;
-		for(int i=0; i<N_nodes-1; i++){
-			for( int j=i+1; j<N_nodes; j++){
-				if (Final[i][j]>0.){
-					edge_array_mine[2*k]  =Edge(i,j);
-					edge_array_mine[2*k+1]=Edge(j,i);
-					k++;
-		graph_t g(edge_array_mine, edge_array_mine + num_arcs_mine, weights_mine, num_nodes_mine);
-		Full_g = g;
-		delete edge_array_mine;
-		delete weights_mine;
-		std::vector<edge_descriptor> p(num_edges(Full_g));
-		std::vector<int> d(num_edges(Full_g));
-		edge_descriptor s;
-		boost::graph_traits<graph_t>::vertex_descriptor u, v;
-			for (int j=i+1; j<N_nodes; j++){
-				if (Final[i][j] > 0.){
-					u = vertex(i, Full_g);
-					v = vertex(j, Full_g);
-					remove_edge(u,v,Full_g);
-					remove_edge(v,u,Full_g);
-	int sample_failed_number(double pfail){
-		//boost::geometric_distribution<double> geo(pfail);
-		//boost::variate_generator<base_generator_type&, geometric_distribution<double> > geom(generator, geo);
-		double r, u, g;
-        r=0.;
-		for(int i=0; i<N_steps; i++){
-            u=(double)rand();
-            u = 1.-u /(double)(pow(2.,31)-1.);
-            g=(int)(ceil(log(u) / log(pfail)));
-			//r += geom();
-            r+=g;
-        if (verbose_level>=3){
-            std::cout << id << " failed " << r << std::endl;
-		return r;
-    double get_target(void){
-        return TargetNovelty;
-    void set_target(double target){
-        TargetNovelty=target;
-	int sample(){
-        //boost::variate_generator<base_generator_type&, boost::uniform_real<> > uni(generator, uni_dist);
-        // double r = uni(), Summa = 0.;
-        double r = rand(), Summa = 0.;
-        r /= (double)(pow(2.,31)-1.);
-		int result = 0;
-		int finished = 0;
-        if (verbose_level==4){
-            std::cout << id << " sampled " << r << std::endl;
-		for(int i=0; i<N_nodes-1 && finished==0; i++){
-			for( int j=i+1; j<N_nodes && finished==0; j++){
-				Summa += Prob[i][j];
-				if (Summa > r){
-					Tried[i][j]+=1.;
-						result = 1;
-					finished = 1;
-		return result;
-	void update_current_graph(void){
-		//property_map<graph_t, edge_weight_t>::type weightmap = get(edge_weight, Full_g);
-				if (Final[i][j] > 0. && Tried[i][j]>0){
-					//s = edge(i, j, Full_g);
-					boost::graph_traits<graph_t>::edge_descriptor e1,e2;
-					bool found1, found2;
-					tie(e1, found1) = edge(u, v, Full_g);
-					tie(e2, found2) = edge(v, u, Full_g);
-					if (!found1 && !found2){
-						add_edge(u,v,1,Full_g);
-					    add_edge(v,u,1,Full_g);
-	void update_distances(void){
-		// put shortest paths to the *Dist[][]
-		std::vector<vertex_descriptor> p(num_vertices(Full_g));
-		std::vector<int> d(num_vertices(Full_g));
-		vertex_descriptor s;
-		for (int j=0; j<num_vertices(Full_g); j++){
-			if(Rank[j] > 0.){
-				s = vertex(j, Full_g);
-				dijkstra_shortest_paths(Full_g, s, predecessor_map(&p[0]).distance_map(&d[0]));
-				//std::cout <<" Vertex "<< j << std::endl;
-				graph_traits < graph_t >::vertex_iterator vi, vend;
-				for (boost::tie(vi, vend) = vertices(Full_g); vi != vend; ++vi) {
-					if (p[*vi]!=*vi){
-						Dist[*vi][j]=d[*vi];
-						Dist[j][*vi]=d[*vi];
-                        if (Dist[*vi][j]>max_dist){
-                            max_dist=Dist[*vi][j];
-					} else {
-						Dist[*vi][j]=-1.;
-						Dist[j][*vi]=-1.;
-	void update_ranks(void){
-		for(int i=0; i<N_nodes; i++){
-			Rank[i]=0.;
-				if (Tried[i][j]>0. && Final[i][j] >0.){
-					Rank[i]++;
-					Rank[j]++;
-	void set_world(double a_i, double a_m, double b, double g, double d){
-		alpha_i=a_i;
-		alpha_m=a_m;
-		gamma=g;
-		beta=b;
-		delta=d;
-	void reset_world(){
-				if (Final[i][j] > 0. && Tried[i][j] > 0){
-		current_loss=0;
-		current_epoch=0;
-		current_repeat++;
-        current_novelty=0;
-			Rank[i]=0.;
-				Prob[i][j]=0.;
-				Dist[i][j]=-1.;
-				Tried[i][j]=0.;
-    void show_parameters(void){
-        std::cout << "Parameters: "
-        << alpha_i << " "
-        << alpha_m << " | "
-        << beta << " "
-        << gamma << " | "
-        << delta << std::endl;
-    string file_name(){
-        s << "world_"
-        << lexical_cast<std::string>(alpha_i) << "_"
-        << lexical_cast<std::string>(alpha_m) << "_"
-        << lexical_cast<std::string>(beta) << "_"
-        << lexical_cast<std::string>(gamma) << "_"
-        << lexical_cast<std::string>(delta) << "_"
-        << lexical_cast<std::string>(N_epochs) << "_"
-        << lexical_cast<std::string>(N_steps) << "_"
-        << lexical_cast<std::string>(N_repeats) << ".txt";
-        return s.str();
-    void set_verbose(int verbose){
-        verbose_level = verbose;
-    void update_probabilities(void){
-		// Compute sampling probabilities
-		// first pass: \xi_i,j
-				double bg = 0.;
-				Prob[i][j] = alpha_i*log(min(Rank[i]+1.,Rank[j]+1.)) +
-                alpha_m*log(max(Rank[i]+1.,Rank[j]+1.));
-                if (Dist[i][j] > 0.){
-                    double k = Dist[i][j];
-                    if (k >= k_max){
-                        k = k_max-1;
-                    bg = beta * log(k/k_max) + gamma * log(1. - k/k_max);
-                } else {
-                    bg = delta;
-				Prob[i][j] = exp(Prob[i][j] + bg);
-		// second pass: sum
-		double Summa = 0.;
-		// third pass: normalize
-				Prob[i][j] /= Summa;
-	// Now we are ready for simulations
-	void update_world(){
-		int failed = 0;
-		// Given current universe compute shortest paths
-		update_current_graph();
-		update_ranks();
-		update_distances();
-		update_probabilities();
-		// sampling
-		int result;
-		double cost=0., novel=0.;
-		int publishable = 0;
-		if (mode_identify_failed == 1){
-			while(publishable < N_steps){
-		    	result = sample();
-			    publishable += result;
-			    failed += (1-result);
-					cost+=Tried[i][j];
-					if (Tried[i][j]>0. && Final[i][j]>0.){
-						novel+=1.;
-		else {
-			double pfail=0.;
-			int n_failed;
-			//, n_check = 0;
-					if (Final[i][j] == 0.){
-						pfail += Prob[i][j];
-						Prob[i][j] = 0.;
-					Prob[i][j] /= (1.-pfail);
-				//std::cout << std::endl;
-			n_failed = sample_failed_number(pfail);
-			current_loss += (n_failed + N_steps);
-			cost = current_loss;
-						novel+=1.;
-        current_novelty = novel;
-            std::cout << (current_repeat+1) << "  epoch=" << (current_epoch+1)
-		    << "  cost=" << cost
-		    << " novel=" << novel
-		    << " rel_loss=" << cost/novel
-		    << std::endl;
-		current_epoch++;
-	//======  Destructor ======
-	~Universe(){
-		delete_2Dmatrix(Final, N_nodes);
-		delete_2Dmatrix(Dist, N_nodes);
-		delete_2Dmatrix(Tried, N_nodes);
-		delete_2Dmatrix(Prob, N_nodes);
-        delete_2Dmatrix(EdgeIndex, N_nodes);
-		delete_1Dmatrix(Rank);
-    // Allocate memory
-    double** allocate_2Dmatrix(int N, int M)
-        double **pointer;
-            std::cout<< "["<<N<<"|"<<M<<"]"<<std::endl;
-        pointer = new double*[N];
-        for (int i = 0; i < N; ++i)
-            pointer[i] = new double[M];
-        return pointer;
-    double* allocate_1Dmatrix(int N)
-        double *pointer;
-        if(N > 0){
-            pointer = new double[N];
-        }else {
-            pointer = NULL;
-        return pointer;
-    // De-Allocate memory to prevent memory leak
-    void delete_2Dmatrix(double **pointer, int N){
-        if (pointer != NULL){
-            for (int i = 0; i < N; ++i){
-                delete [] pointer[i];
-            delete [] pointer;
-    void delete_1Dmatrix(double *pointer){
-    double get_rel_loss(){
-        return CumulativeRelativeLoss ;
-    double get_rel_loss_err(){
-        return CRLsquare ;
-    void evolve_to_target_and_save(int istart, int iend, double* storage, int* counters){
-        double ALOT=100000000000.;
-        reset_world();
-        for (int k = istart; k < iend; k++){
-            for(int i=0; i< N_epochs &&  current_novelty < TargetNovelty; i++){
-                update_world();
-            storage[k]=current_loss/current_novelty;
-            counters[k]=1;
-            reset_world();
-    int get_reruns(void){
-        return N_repeats;
-    double get_parameter(int i){
-        switch(i){
-            case 0:
-                return alpha_i;
-            case 1:
-                return alpha_m;
-            case 2:
-                return beta;
-            case 3:
-                return gamma;
-            case 4:
-                return delta;
-            default:
-                std::cout << "Erroneous parameter id!!!!\n\n\n";
-                return 0.;
-    void evolve_to_target(){
-        reset_world();
-        if (beta < -1. || gamma < -1.){
-            CumulativeRelativeLoss = 100000000000.;
-            CRLsquare = 0.;
-            return;
-        for (int k=0; k< N_repeats; k++){
-            for(int i=0; i<N_epochs &&  current_novelty < TargetNovelty; i++){
-                update_world();
-            CumulativeRelativeLoss += current_loss/current_novelty;
-            CRLsquare += (current_loss/current_novelty)*(current_loss/current_novelty);
-            if(verbose_level==3){
-                std::cout <<  CumulativeRelativeLoss << " | " << CRLsquare << std::endl;
-            if(verbose_level==1){
-                std::cout <<  "." ;
-            else if(verbose_level==2){
-                std::cout <<  "**" << (k+1) <<  "**  curr loss " << current_loss << "; curr novelty " << current_novelty << std::endl;
-            reset_world();
-        CumulativeRelativeLoss /= double(N_repeats);
-        CRLsquare /= double(N_repeats);
-        if(verbose_level==2){
-            std::cout <<  CumulativeRelativeLoss << " || " << CRLsquare << std::endl;
-        CRLsquare = 2*sqrt((CRLsquare - CumulativeRelativeLoss*CumulativeRelativeLoss)/double(N_repeats));
-    int set_parameter(double value, int position){
-        if (position < 0 || position > 4) {return 0;}
-        else {
-            switch(position){
-                case 0:
-                    alpha_i=value;
-                    return 1;
-                case 1:
-                    alpha_m=value;
-                    return 1;
-                case 2:
-                    beta=value;
-                    return 1;
-                case 3:
-                    gamma=value;
-                    return 1;
-                case 4:
-                    delta=value;
-                    return 1;
-        return 0;
-    void try_annealing(double starting_jump, int iterations,
-                       double temp_start, double temp_end, double target_rejection){
-        double dx[5]={0.,0.,0.,0.,0};
-        double x[5]={0.,0.,0.,0.,0};
-        double rejection[5]={0., 0., 0., 0., 0.};
-        double curr_x, curr_err, x_tmp;
-        double temperature;
-        double ratio, r;
-        int cycle=10;
-        boost::variate_generator<base_generator_type&, boost::uniform_real<> > uni(generator, uni_dist);
-        // set up parameter for annealing
-        x[0]=alpha_i;
-        x[1]=alpha_m;
-        x[2]=beta;
-        x[3]=gamma;
-        x[4]=delta;
-        for(int i=0;i<5;i++){
-            dx[i] = starting_jump;
-        // establish the current value
-        evolve_to_target();
-        std::cout << CumulativeRelativeLoss << " +- " << CRLsquare << std::endl;
-        curr_x   = CumulativeRelativeLoss;
-        curr_err = CRLsquare;
-        CumulativeRelativeLoss = 0;
-        CRLsquare = 0;
-        // optimization cycle
-        for(int i=0; i<iterations; i++){
-            temperature = temp_start*exp( i*(log(temp_end)-log(temp_start))/(double)iterations);
-            std::cout  << std::endl << "....T = " << wrap_double(temperature,3) << std::endl << std::endl;
-            if (i % cycle == 0 && i > 0){
-                for (int k=0; k<5; k++){
-                    rejection[k]/=(double)cycle;
-                    if (rejection[k] > 0){
-                        dx[k] = dx[k]/(rejection[k]/target_rejection);
-                        rejection[k]=0.;
-                    else{
-                        dx[k]*=2.;
-                    std::cout  << dx[k] << " ";
-            for (int j=0; j<5; j++){
-                // get new value of x[j]
-                x_tmp = get_new_x(x[j],dx[j]);
-                set_parameter(x_tmp, j);
-                std::cout  << std::endl << "......... " << std::endl;
-                std::cout << "Trying... " << CumulativeRelativeLoss << " +- " << CRLsquare << std::endl;
-                ratio = min(1.,exp(-(CumulativeRelativeLoss-curr_x)/temperature));
-                r = uni();
-                std::cout << r << " vs " << ratio << std::endl;
-                if (r > ratio){
-                    std::cout << string_wrap(id, 4) <<" "<< (i+1) << ","<< (j)
-                    <<" "<< (i+1) << " Did not accept "
-                    << x_tmp << "(" << j << ")" << std::endl;
-                    std::cout << alpha_i << " "<< alpha_m << " "
-                    << beta << " " << gamma << " "
-                    << delta << " " << std::endl;
-                    set_parameter(x[j], j);
-                    CRLsquare = 0;
-                    rejection[j]+=1.;
-                else {
-                    x[j] = x_tmp;
-                    CRLsquare = 0;
-                    std::cout << (i+1) << string_wrap((string) " Rejection counts: ", 8)
-                    << wrap_double(rejection[0],2)
-                    << " "<< wrap_double(rejection[1], 7) << " "
-                    << wrap_double(rejection[2],5) << " " << wrap_double(rejection[2],9) << " "
-                    << wrap_double(rejection[4],6) << " "
-                    << std::endl << std::endl;
-                    std::cout << string_wrap(id, 4) <<" "<< (i+1) <<","<< (j)
-                    << string_wrap((string) "***** Did accept! ", 3)
-                    << wrap_double(alpha_i,2)
-                    << " "<< wrap_double(alpha_m, 7) << " "
-                    << wrap_double(beta,5) << " "
-                    << wrap_double(gamma,9) << " "
-                    << wrap_double(delta,6) << " "
-std::pair<double,double> multi_loss(dispatch_group_t group,
-                                    Universe* un[],
-                                    dispatch_queue_t* CustomQueues,
-                                    double* Results,
-                                    int*    Counters,
-                                    double* params){
-    int N = un[0]->get_reruns();
-    int step = (int)(double)N/(double)(Nworkers);
-    int istart=0;
-    int iend = istart+step;
-    double Loss=0., LossSquare=0.;
-    for(int i=0; i<Nworkers; i++){
-        for(int j=0; j<5; j++){
-            un[i]->set_parameter(params[j],j);
-        dispatch_group_async(group, CustomQueues[i], ^{
-            un[i]->evolve_to_target_and_save(istart, iend, Results, Counters);
-        std::cout << "queued: i=" << i << " N=" << N << " istart=" << istart << " iend=" << iend << "\n";
-        istart += step;
-        iend = min(istart+step,N);
-    dispatch_group_wait(group, DISPATCH_TIME_FOREVER);
-    //dispatch_release(group);
-    for (int i=0; i<N; i++){
-        Loss+=Results[i]/(double)N;
-        LossSquare+=Results[i]*Results[i]/(double)N;
-        // std::cout<<" " << Results[i];
-    //std::cout<<" \n\n\n";
-    double two_std = ((LossSquare - Loss*Loss)/(double)N);
-    two_std = 2.*sqrt(two_std);
-    std::pair<double,double> Res;
-    Res.first=Loss;
-    Res.second=two_std;
-    return Res;
-void multi_annealing( dispatch_group_t group,
-                     Universe* un[],
-                     double T_start, double T_end,
-                     double Target_rejection,
-                     int Annealing_repeats,
-                     double starting_jump,
-                     double* Results,
-                     int*    Counters,
-                     double* params0,
-                     double annealing_cycles){
-    // re-implement annealing
-    double ratio, r;
-    int cycle=10;
-    x[0]=params0[0];
-    x[1]=params0[1];
-    x[2]=params0[2];
-    x[3]=params0[3];
-    x[4]=params0[4];
-    std::pair<double,double>Res;
-    Res = multi_loss(group, un, CustomQueues, Results, Counters, x);
-    std::cout << Res.first << " +- " << Res.second << std::endl;
-    curr_x   = Res.first;
-    curr_err = Res.second;
-    for(int i=0; i<annealing_cycles; i++){
-        temperature = T_start*exp( i*(log(T_end)-log(T_start))/(double)annealing_cycles);
-                    dx[k] = dx[k]/(rejection[k]/Target_rejection);
-                    rejection[k]=0.;
-                else{
-                    dx[k]*=2.;
-            if (FIX_VARIABLES==0 || var_fixed[j]==0){
-                double x_hold=x[j];
-                x[j]=x_tmp;
-                std::cout << wrap_double(x_tmp,10) << " " << wrap_double(j,9) << "\n\n";
-                for(int w=0; w<Nworkers; w++){
-                    un[w]->set_parameter(x_tmp, j);
-                ratio = min(1.,exp(-(Res.first-curr_x)/temperature));
-                r = rand()/(double)(pow(2.,31)-1.);
-                if (Res.first < ALOT)
-                    ofstream filestr;
-                    filestr.open ("best_opt_some.txt", ofstream::app);
-                    // >> i/o operations here <<
-                    filestr << un[0]->get_target() << ","
-                    << Res.first
-                    << "," << un[0]->get_parameter(0)
-                    << "," << un[0]->get_parameter(1)
-                    << "," << un[0]->get_parameter(2)
-                    << "," << un[0]->get_parameter(3)
-                    << "," << un[0]->get_parameter(4) << "," << Res.second << ",\n";
-                    filestr.close();
-                    filestr.open ("max_dist.txt", ofstream::app);
-                    filestr << max_dist << ",\n";
-                    filestr.close();
-                if (r > ratio){
-                    std::cout << " "<< (i+1) << ","<< (j)
-                    std::cout << un[0]->get_parameter(0)
-                    << " " << un[0]->get_parameter(1)
-                    << " " << un[0]->get_parameter(2)
-                    << " " << un[0]->get_parameter(3)
-                    << " " << un[0]->get_parameter(4) << " " << std::endl;
-                    x[j]=x_hold;
-                        un[w]->set_parameter(x[j], j);
-                    //set_parameter(x[j], j);
-                    rejection[j]+=1.;
-                else {
-                    x[j] = x_tmp;
-                    << wrap_double(rejection[0],2) << " "
-                    << wrap_double(rejection[1],7) << " "
-                    << wrap_double(rejection[3],9) << " "
-                    std::cout << " "<< (i+1) <<","<< (j)
-                    << wrap_double(un[0]->get_parameter(0),2) << " "
-                    << wrap_double(un[0]->get_parameter(1),7) << " "
-                    << wrap_double(un[0]->get_parameter(2),5) << " "
-                    << wrap_double(un[0]->get_parameter(3),9) << " "
-                    << wrap_double(un[0]->get_parameter(4),6) << " "
-int
-main(int argc, char* argv[])
-    double params0[6] = {0., 0., 0., 0., 0., 0.2}, target=50., range;
-    string par_names0[6] = {"alpha_i", "alpha_m", "beta", "gamma", "delta", "target"};
-    string par_names1[4] = {"n_epochs", "n_steps", "n_reruns", "range"};
-    string par_names2[5] = {"T_start", "T_end", "Annealing_steps","Target_rejection","Starting_jump"};
-    string par_names3[5] = {"FREEZE_alpha_i", "FREEZE_alpha_m", "FREEZE_beta", "FREEZE_gamma", "FREEZE_delta"};
-    int params1[4] = {300, 50, 1000, 10};
-    int params3[5] = { 0, 0, 0, 0, 0};
-    //          temperature_start,  temperature_end,  annealing_steps target_rejection  Starting_jump
-    double params2[5] = {1,             0.001,               100,              0.3,           1.5};
-    int verbose_level = 2;
-    const std::string one="one", two="two";
-    static Universe* un[Nworkers];
-    static dispatch_queue_t CustomQueues[Nworkers];
-    static double* Results;
-    static int*    Counters;
-    timeval t1, t2;
-    double elapsedTime;
-    // start timer
-    gettimeofday(&t1, NULL);
-    if (argc < 8) {
-        std::cout << "Usage: super_optimizer alpha_i alpha_m beta gamma delta target_innov [n_epochs n_steps n_reruns] [range] [verbose_level]\n";
-        std::cout << "         [T_start T_end Annealing_steps Target_rejection Starting_jump]\n";
-        std::cout << "         [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta]\n";
-        system("pwd");
-        return(1);
-    else {
-        for (int nArg=0; nArg < argc; nArg++){
-            //std::cout << nArg << " " << argv[nArg] << std::endl;
-            if (nArg > 0 && nArg < 7){
-                params0[nArg-1]= atof(argv[nArg]);
-                std::cout << par_names0[nArg-1] << ": " << params0[nArg-1] <<  std::endl;
-            if (nArg > 6 && nArg < 11){
-                params1[nArg-7]= atoi(argv[nArg]);
-                std::cout << par_names1[nArg-7] << ": " << params1[nArg-7] <<  std::endl;
-            if (nArg == 11){
-                verbose_level = atoi(argv[nArg]);
-                std::cout << "verbose level: " << verbose_level <<  std::endl;
-            if (nArg > 11 && nArg < 17){
-                params2[nArg-12]= atof(argv[nArg]);
-                std::cout << par_names2[nArg-12] << ": " << params2[nArg-12] <<  std::endl;
-            if (nArg > 16 && nArg < 22){
-                params3[nArg-17]= atof(argv[nArg]);
-                var_fixed[nArg-17]= atof(argv[nArg]);
-                std::cout << par_names3[nArg-17] << ": " << var_fixed[nArg-17] <<  std::endl;
-        cout << j << " | " << var_fixed[j] << " (fixed) \n";
-    target=params0[5];
-    range = (double)params1[3];
-	int identify_failed = 0;
-	char* filename= (char *)"movie_graph.txt";
- 	int n_ep=params1[0], n_st=params1[1], n_rep=params1[2];
-        un[i] = new Universe((char *)filename,n_ep,n_st,
-                             (int)n_rep,
-                             identify_failed, target, i2string(i));
-        CustomQueues[i] = dispatch_queue_create(i2char(i), NULL);
-    if(n_rep > 0){
-        Results = new double[n_rep];
-        Counters = new int[n_rep];
-    }else {
-        Results =  NULL;
-        Counters = NULL;
-        std::cout << " Number of reruns should be positive! " <<  std::endl;
-        return 0;
-    srand(time(0));
-    //srandomdev();
-        double r=0;
-        for (int j=0; j<100; j++){
-            std::cout << r << " ";
-        std::cout << "\n ";
-  	//random initiation of starting parameters
-    if (range > 0.){
-        for (int i=0; i < 5; i++){
-            if (params0[i]==-100.){
-                double r1 = (rand()/(double)(pow(2.,31)-1.));
-                double r2 = (rand()/(double)(pow(2.,31)-1.));
-                double sign = 1.;
-                if(r1 > 0.5){
-                    sign=-1.;
-                params0[i] = sign*r2*range;
-                std::cout << par_names0[i] << ": " << params0[i] <<  std::endl;
-    double T_start=params2[0], T_end=params2[1], Target_rejection=params2[3], starting_jump=params2[4];
-    int Annealing_repeats = (int) params2[2];
-    dispatch_group_t group = dispatch_group_create();
-    multi_annealing(group, un, CustomQueues, T_start, T_end, Target_rejection, Annealing_repeats,
-                    starting_jump, Results, Counters, params0, Annealing_repeats);
-    //dispatch_group_wait(group, DISPATCH_TIME_FOREVER);
-    dispatch_release(group);
-    // stop timer
-    gettimeofday(&t2, NULL);
-    // compute and print the elapsed time in millisec
-    elapsedTime = (t2.tv_sec - t1.tv_sec) * 1000.0;      // sec to ms
-    elapsedTime += (t2.tv_usec - t1.tv_usec) / 1000.0;   // us to ms
-    elapsedTime /= 1000.;
-    cout << elapsedTime << " seconds \n .....(" << elapsedTime/60. << " minutes)\n\n";
-        delete un[i];
-    if(n_rep > 0){
-        delete [] Results;
-        delete [] Counters;
-    return 0;
Copied: SwiftApps/SciColSim/optimizer.orig-mac.cpp (from rev 5634, SwiftApps/SciColSim/optimizer.orig-mac.cpp)
--- SwiftApps/SciColSim/optimizer.orig-mac.cpp	                        (rev 0)
@@ -0,0 +1,1673 @@
+//  main.cpp
+//  optimizer
+//  Created by Andrey Rzhetsky on 4/11/11.
+//  Copyright 2011 University of Chicago. All rights reserved.
+#define Nworkers 2
+#include <fstream>
+#include <iostream>
+#include <stdio.h>
+#include <time.h>
+#include <ctime>
+#include <algorithm>
+#include <string>
+#include <stdio.h>
+#include <sys/param.h>
+#include <sys/time.h>
+#include <sys/types.h>
+#include <dispatch/dispatch.h>
+#include <fstream>
+#include <stdlib.h>
+#include <boost/numeric/ublas/io.hpp>
+#include <boost/graph/graph_traits.hpp>
+#include <boost/graph/dijkstra_shortest_paths.hpp>
+#include <boost/graph/loop_erased_random_walk.hpp>
+#include <boost/graph/random.hpp>
+#include <boost/property_map/property_map.hpp>
+#include <boost/graph/graph_concepts.hpp>
+#include <boost/graph/properties.hpp>
+#include <boost/graph/adjacency_list.hpp>
+#include <boost/graph/adjacency_matrix.hpp>
+#define BOOST_MATH_OVERFLOW_ERROR_POLICY ignore_error
+#define BOOST_MATH_DISCRETE_QUANTILE_POLICY real
+#include <boost/random/geometric_distribution.hpp>
+#include <boost/random/uniform_01.hpp>
+#include <boost/random.hpp>
+#include <boost/random/linear_congruential.hpp>
+#include <boost/random/uniform_int.hpp>
+#include <boost/random/uniform_real.hpp>
+#include <boost/random/variate_generator.hpp>
+#include <boost/generator_iterator.hpp>
+#include <boost/lexical_cast.hpp>
+#define INT_INFINITY 2147483647
+#define FIX_VARIABLES 1
+using namespace boost;
+using namespace std;
+using namespace boost::numeric::ublas;
+static int max_dist=0;
+typedef boost::adjacency_matrix<boost::directedS> Graph;
+typedef std::pair<int,int> Edge;
+typedef boost::graph_traits<Graph> GraphTraits;
+typedef boost::numeric::ublas::triangular_matrix<double, boost::numeric::ublas::strict_upper> prob;
+typedef boost::numeric::ublas::triangular_matrix<double, boost::numeric::ublas::strict_upper> pathlength;
+typedef boost::graph_traits<Graph>::vertex_descriptor vertex_descriptor;
+namespace std {
+	using ::time;
+static int var_fixed[5] = {1, 0, 1, 1, 0};
+typedef boost::minstd_rand base_generator_type;
+typedef adjacency_list < listS, vecS, directedS,
+no_property, property < edge_weight_t, int > > graph_t;
+typedef graph_traits < graph_t >::vertex_descriptor vertex_descriptor;
+typedef graph_traits < graph_t >::edge_descriptor edge_descriptor;
+string strDouble(double number)
+    stringstream ss;//create a stringstream
+    ss << number;//add number to the stream
+    return ss.str();//return a string with the contents of the stream
+double gaussian(double sigma)
+    double GaussNum = 0.0;
+    int NumInSum = 10;
+    for(int i = 0; i < NumInSum; i++)
+        GaussNum += ((double)rand()/(double)RAND_MAX - 0.5);
+    GaussNum = GaussNum*sqrt((double)12/(double)NumInSum);
+    return GaussNum;
+double diffclock(clock_t clock1,clock_t clock2)
+	double diffticks=clock1-clock2;
+	double diffms=(diffticks)/CLOCKS_PER_SEC;
+	return diffms;
+double get_new_x(double x, double dx){
+    double new_x;
+    // boost::variate_generator<base_generator_type&, boost::uniform_real<> > uni(generator, uni_dist);
+    double r = rand()/(double)(pow(2.,31)-1.);
+    if (r > 0.5){
+        new_x = x + rand()*dx/(double)(pow(2.,31)-1.);
+    } else {
+        new_x = x - rand()*dx/(double)(pow(2.,31)-1.);
+    return new_x;
+string string_wrap(string ins, int mode){
+    std::ostringstream s;
+    switch(mode){
+        case 0:
+            s << "\033[1;29m" << ins << "\033[0m";
+            break;
+        case 1:
+            s << "\033[1;34m" << ins << "\033[0m";
+            break;
+        case 2:
+            s << "\033[1;44m" << ins << "\033[0m";
+            break;
+        case 3:
+            s << "\033[1;35m" << ins << "\033[0m";
+            break;
+        case 4:
+            s << "\033[1;33;44m" << ins << "\033[0m";
+            break;
+        case 5:
+            s << "\033[1;47;34m" << ins << "\033[0m";
+            break;
+        case 6:
+            s << "\033[1;1;31m" << ins << "\033[0m";
+            break;
+        case 7:
+            s << "\033[1;1;33m" << ins << "\033[0m";
+            break;
+        case 8:
+            s << "\033[1;1;43;34m" << ins << "\033[0m";
+            break;
+        case 9:
+            s << "\033[1;1;37m" << ins << "\033[0m";
+            break;
+        case 10:
+            s << "\033[1;30;47m" << ins << "\033[0m";
+            break;
+        default:
+            s << ins;
+    return s.str();
+string wrap_double(double val, int mode){
+    s << string_wrap(strDouble(val),mode);
+    return s.str();
+const
+string i2string(int i){
+    s << "worker"
+    << lexical_cast<std::string>(i);
+    return s.str();
+char* i2char(int i){
+    s << "worker"
+    char* a=new char[s.str().size()+1];
+    memcpy(a,s.str().c_str(), s.str().size());
+    return a;
+class Universe {
+private:
+	double alpha_i;
+	double alpha_m;
+	double beta;
+	double gamma;
+	double delta;
+    double TargetNovelty;
+    double CumulativeRelativeLoss;
+    double CRLsquare;
+    string id;
+	int N_nodes;
+	int M_edges;
+	int N_epochs;
+	int N_steps;
+	int N_repeats;
+	int current_epoch;
+	double current_loss;
+	int current_repeat;
+    double current_novelty;
+	int mode_identify_failed;
+    int verbose_level; // 0 is silent, higher is more
+	double k_max;
+	graph_t Full_g;
+	double **Prob;
+	double **Tried;
+	double **Dist;
+	double **Final;
+    double **EdgeIndex;
+	double *Rank;
+    base_generator_type generator;
+    boost::uniform_real<> uni_dist;
+    boost::geometric_distribution<double> geo;
+public:
+	//======  Constructor ======
+	Universe(const std::string FileToOpen, int Epochs, int Steps, int Repeats, int identify_failed, double target, const std::string idd)
+		//typedef array_type2::index index2;
+		std::ifstream inFile;
+        //string line;
+        base_generator_type gene(42u);
+        generator = gene;
+        generator.seed(static_cast<unsigned int>(std::time(0)));
+        boost::uniform_real<> uni_d(0,1);
+        uni_dist = uni_d;
+		int i, k;
+        int x, y;
+		Edge* edge_array_mine;
+		int num_arcs_mine, num_nodes_mine;
+		int* weights_mine;
+        TargetNovelty = target;
+        CumulativeRelativeLoss = 0.;
+        CRLsquare = 0.;
+		N_epochs  = Epochs;
+		N_steps   = Steps;
+		N_repeats = Repeats;
+		current_epoch = 0;
+		current_loss = 0.;
+		current_repeat = 0;
+        id = idd;
+        verbose_level = 1;
+		mode_identify_failed = identify_failed;
+		// The first pass though file with the graph
+		inFile.open(FileToOpen.c_str());
+		if (inFile.fail()) {
+			cout << "Unable to open file";
+			exit(1); // terminate with error
+		}else {
+            if (verbose_level > 2){
+                std::cout <<  " Opened <" << FileToOpen << ">"<<std::endl;
+		i=0;
+        std::string line;
+		//while (! inFile.eof() && ! inFile.fail()) {
+        while (1==1) {
+            inFile >> x;
+            inFile >> y;
+                std::cout << " x: " << x;
+                std::cout << " y: " << y << std::endl;
+			if (i==0){
+				N_nodes=x;
+				M_edges=y;
+                break;
+			i++;
+		inFile.close();
+        if (verbose_level == 2){
+            std::cout << N_nodes <<  " nodes, " << M_edges << " edges"<<std::endl;
+		// k_max is the longest distance possible
+        //k_max = M_edges;
+		k_max = 70;
+		// Get memory allocated for all class members
+		Prob = allocate_2Dmatrix(N_nodes, N_nodes);
+		Tried = allocate_2Dmatrix(N_nodes, N_nodes);
+		Dist = allocate_2Dmatrix(N_nodes, N_nodes);
+		Final = allocate_2Dmatrix(N_nodes, N_nodes);
+        EdgeIndex = allocate_2Dmatrix(N_nodes, N_nodes);
+		Rank = allocate_1Dmatrix(N_nodes);
+        //The second pass through file with the graph
+		for(int i = 0; i < N_nodes; ++i) {
+			Rank[i]=0.;
+			for(int j = 0; j < N_nodes; ++j) {
+				Final[i][j] = 0.;
+				Prob[i][j]=0.;
+				Dist[i][j]=-1.;
+				Tried[i][j]=0.;
+                EdgeIndex[i][j]=-1;
+		// Fill in the final graph -- and we are ready to go!
+		if (!inFile) {
+            std::cout << "Unable to open file";
+		else {
+		i=0;
+		while (inFile >> x && inFile >>y) {
+			if (i > 0) {
+				Final[x][y]=1.;
+				Final[y][x]=1.;
+                    std::cout << ".";
+			i++;
+            std::cout << std::endl;
+		inFile.close();
+        k=0;
+        for (int i=0; i<N_nodes-1; i++){
+            for (int j=i+1;j<N_nodes; j++){
+                if(Final[i][j] > 0.){
+                    EdgeIndex[i][j]=k;
+                    k++;
+		// create graph -- hopefully, we can keep it, just modifying edge weights
+		edge_array_mine = new Edge[2*M_edges];
+		num_arcs_mine = 2*M_edges;
+		num_nodes_mine = N_nodes;
+		weights_mine = new int[2*M_edges];
+		for (int i=0; i<2*M_edges; i++){ weights_mine[i]=1;}
+		k=0;
+		for(int i=0; i<N_nodes-1; i++){
+			for( int j=i+1; j<N_nodes; j++){
+				if (Final[i][j]>0.){
+					edge_array_mine[2*k]  =Edge(i,j);
+					edge_array_mine[2*k+1]=Edge(j,i);
+					k++;
+		graph_t g(edge_array_mine, edge_array_mine + num_arcs_mine, weights_mine, num_nodes_mine);
+		Full_g = g;
+		delete edge_array_mine;
+		delete weights_mine;
+		std::vector<edge_descriptor> p(num_edges(Full_g));
+		std::vector<int> d(num_edges(Full_g));
+		edge_descriptor s;
+		boost::graph_traits<graph_t>::vertex_descriptor u, v;
+			for (int j=i+1; j<N_nodes; j++){
+				if (Final[i][j] > 0.){
+					u = vertex(i, Full_g);
+					v = vertex(j, Full_g);
+					remove_edge(u,v,Full_g);
+					remove_edge(v,u,Full_g);
+	int sample_failed_number(double pfail){
+		//boost::geometric_distribution<double> geo(pfail);
+		//boost::variate_generator<base_generator_type&, geometric_distribution<double> > geom(generator, geo);
+		double r, u, g;
+        r=0.;
+		for(int i=0; i<N_steps; i++){
+            u=(double)rand();
+            u = 1.-u /(double)(pow(2.,31)-1.);
+            g=(int)(ceil(log(u) / log(pfail)));
+			//r += geom();
+            r+=g;
+        if (verbose_level>=3){
+            std::cout << id << " failed " << r << std::endl;
+		return r;
+    double get_target(void){
+        return TargetNovelty;
+    void set_target(double target){
+        TargetNovelty=target;
+	int sample(){
+        //boost::variate_generator<base_generator_type&, boost::uniform_real<> > uni(generator, uni_dist);
+        // double r = uni(), Summa = 0.;
+        double r = rand(), Summa = 0.;
+        r /= (double)(pow(2.,31)-1.);
+		int result = 0;
+		int finished = 0;
+        if (verbose_level==4){
+            std::cout << id << " sampled " << r << std::endl;
+		for(int i=0; i<N_nodes-1 && finished==0; i++){
+			for( int j=i+1; j<N_nodes && finished==0; j++){
+				Summa += Prob[i][j];
+				if (Summa > r){
+					Tried[i][j]+=1.;
+						result = 1;
+					finished = 1;
+		return result;
+	void update_current_graph(void){
+		//property_map<graph_t, edge_weight_t>::type weightmap = get(edge_weight, Full_g);
+				if (Final[i][j] > 0. && Tried[i][j]>0){
+					//s = edge(i, j, Full_g);
+					boost::graph_traits<graph_t>::edge_descriptor e1,e2;
+					bool found1, found2;
+					tie(e1, found1) = edge(u, v, Full_g);
+					tie(e2, found2) = edge(v, u, Full_g);
+					if (!found1 && !found2){
+						add_edge(u,v,1,Full_g);
+					    add_edge(v,u,1,Full_g);
+	void update_distances(void){
+		// put shortest paths to the *Dist[][]
+		std::vector<vertex_descriptor> p(num_vertices(Full_g));
+		std::vector<int> d(num_vertices(Full_g));
+		vertex_descriptor s;
+		for (int j=0; j<num_vertices(Full_g); j++){
+			if(Rank[j] > 0.){
+				s = vertex(j, Full_g);
+				dijkstra_shortest_paths(Full_g, s, predecessor_map(&p[0]).distance_map(&d[0]));
+				//std::cout <<" Vertex "<< j << std::endl;
+				graph_traits < graph_t >::vertex_iterator vi, vend;
+				for (boost::tie(vi, vend) = vertices(Full_g); vi != vend; ++vi) {
+					if (p[*vi]!=*vi){
+						Dist[*vi][j]=d[*vi];
+						Dist[j][*vi]=d[*vi];
+                        if (Dist[*vi][j]>max_dist){
+                            max_dist=Dist[*vi][j];
+					} else {
+						Dist[*vi][j]=-1.;
+						Dist[j][*vi]=-1.;
+	void update_ranks(void){
+		for(int i=0; i<N_nodes; i++){
+			Rank[i]=0.;
+				if (Tried[i][j]>0. && Final[i][j] >0.){
+					Rank[i]++;
+					Rank[j]++;
+	void set_world(double a_i, double a_m, double b, double g, double d){
+		alpha_i=a_i;
+		alpha_m=a_m;
+		gamma=g;
+		beta=b;
+		delta=d;
+	void reset_world(){
+				if (Final[i][j] > 0. && Tried[i][j] > 0){
+		current_loss=0;
+		current_epoch=0;
+		current_repeat++;
+        current_novelty=0;
+			Rank[i]=0.;
+				Prob[i][j]=0.;
+				Dist[i][j]=-1.;
+				Tried[i][j]=0.;
+    void show_parameters(void){
+        std::cout << "Parameters: "
+        << alpha_i << " "
+        << alpha_m << " | "
+        << beta << " "
+        << gamma << " | "
+        << delta << std::endl;
+    string file_name(){
+        s << "world_"
+        << lexical_cast<std::string>(alpha_i) << "_"
+        << lexical_cast<std::string>(alpha_m) << "_"
+        << lexical_cast<std::string>(beta) << "_"
+        << lexical_cast<std::string>(gamma) << "_"
+        << lexical_cast<std::string>(delta) << "_"
+        << lexical_cast<std::string>(N_epochs) << "_"
+        << lexical_cast<std::string>(N_steps) << "_"
+        << lexical_cast<std::string>(N_repeats) << ".txt";
+        return s.str();
+    void set_verbose(int verbose){
+        verbose_level = verbose;
+    void update_probabilities(void){
+		// Compute sampling probabilities
+		// first pass: \xi_i,j
+				double bg = 0.;
+				Prob[i][j] = alpha_i*log(min(Rank[i]+1.,Rank[j]+1.)) +
+                alpha_m*log(max(Rank[i]+1.,Rank[j]+1.));
+                if (Dist[i][j] > 0.){
+                    double k = Dist[i][j];
+                    if (k >= k_max){
+                        k = k_max-1;
+                    bg = beta * log(k/k_max) + gamma * log(1. - k/k_max);
+                } else {
+                    bg = delta;
+				Prob[i][j] = exp(Prob[i][j] + bg);
+		// second pass: sum
+		double Summa = 0.;
+		// third pass: normalize
+				Prob[i][j] /= Summa;
+	// Now we are ready for simulations
+	void update_world(){
+		int failed = 0;
+		// Given current universe compute shortest paths
+		update_current_graph();
+		update_ranks();
+		update_distances();
+		update_probabilities();
+		// sampling
+		int result;
+		double cost=0., novel=0.;
+		int publishable = 0;
+		if (mode_identify_failed == 1){
+			while(publishable < N_steps){
+		    	result = sample();
+			    publishable += result;
+			    failed += (1-result);
+					cost+=Tried[i][j];
+					if (Tried[i][j]>0. && Final[i][j]>0.){
+						novel+=1.;
+		else {
+			double pfail=0.;
+			int n_failed;
+			//, n_check = 0;
+					if (Final[i][j] == 0.){
+						pfail += Prob[i][j];
+						Prob[i][j] = 0.;
+					Prob[i][j] /= (1.-pfail);
+				//std::cout << std::endl;
+			n_failed = sample_failed_number(pfail);
+			current_loss += (n_failed + N_steps);
+			cost = current_loss;
+						novel+=1.;
+        current_novelty = novel;
+            std::cout << (current_repeat+1) << "  epoch=" << (current_epoch+1)
+		    << "  cost=" << cost
+		    << " novel=" << novel
+		    << " rel_loss=" << cost/novel
+		    << std::endl;
+		current_epoch++;
+	//======  Destructor ======
+	~Universe(){
+		delete_2Dmatrix(Final, N_nodes);
+		delete_2Dmatrix(Dist, N_nodes);
+		delete_2Dmatrix(Tried, N_nodes);
+		delete_2Dmatrix(Prob, N_nodes);
+        delete_2Dmatrix(EdgeIndex, N_nodes);
+		delete_1Dmatrix(Rank);
+    // Allocate memory
+    double** allocate_2Dmatrix(int N, int M)
+        double **pointer;
+            std::cout<< "["<<N<<"|"<<M<<"]"<<std::endl;
+        pointer = new double*[N];
+        for (int i = 0; i < N; ++i)
+            pointer[i] = new double[M];
+        return pointer;
+    double* allocate_1Dmatrix(int N)
+        double *pointer;
+        if(N > 0){
+            pointer = new double[N];
+        }else {
+            pointer = NULL;
+        return pointer;
+    // De-Allocate memory to prevent memory leak
+    void delete_2Dmatrix(double **pointer, int N){
+        if (pointer != NULL){
+            for (int i = 0; i < N; ++i){
+                delete [] pointer[i];
+            delete [] pointer;
+    void delete_1Dmatrix(double *pointer){
+    double get_rel_loss(){
+        return CumulativeRelativeLoss ;
+    double get_rel_loss_err(){
+        return CRLsquare ;
+    void evolve_to_target_and_save(int istart, int iend, double* storage, int* counters){
+        double ALOT=100000000000.;
+        reset_world();
+        for (int k = istart; k < iend; k++){
+            for(int i=0; i< N_epochs &&  current_novelty < TargetNovelty; i++){
+                update_world();
+            storage[k]=current_loss/current_novelty;
+            counters[k]=1;
+            reset_world();
+    int get_reruns(void){
+        return N_repeats;
+    double get_parameter(int i){
+        switch(i){
+            case 0:
+                return alpha_i;
+            case 1:
+                return alpha_m;
+            case 2:
+                return beta;
+            case 3:
+                return gamma;
+            case 4:
+                return delta;
+            default:
+                std::cout << "Erroneous parameter id!!!!\n\n\n";
+                return 0.;
+    void evolve_to_target(){
+        reset_world();
+        if (beta < -1. || gamma < -1.){
+            CumulativeRelativeLoss = 100000000000.;
+            CRLsquare = 0.;
+            return;
+        for (int k=0; k< N_repeats; k++){
+            for(int i=0; i<N_epochs &&  current_novelty < TargetNovelty; i++){
+                update_world();
+            CumulativeRelativeLoss += current_loss/current_novelty;
+            CRLsquare += (current_loss/current_novelty)*(current_loss/current_novelty);
+            if(verbose_level==3){
+                std::cout <<  CumulativeRelativeLoss << " | " << CRLsquare << std::endl;
+            if(verbose_level==1){
+                std::cout <<  "." ;
+            else if(verbose_level==2){
+                std::cout <<  "**" << (k+1) <<  "**  curr loss " << current_loss << "; curr novelty " << current_novelty << std::endl;
+            reset_world();
+        CumulativeRelativeLoss /= double(N_repeats);
+        CRLsquare /= double(N_repeats);
+        if(verbose_level==2){
+            std::cout <<  CumulativeRelativeLoss << " || " << CRLsquare << std::endl;
+        CRLsquare = 2*sqrt((CRLsquare - CumulativeRelativeLoss*CumulativeRelativeLoss)/double(N_repeats));
+    int set_parameter(double value, int position){
+        if (position < 0 || position > 4) {return 0;}
+        else {
+            switch(position){
+                case 0:
+                    alpha_i=value;
+                    return 1;
+                case 1:
+                    alpha_m=value;
+                    return 1;
+                case 2:
+                    beta=value;
+                    return 1;
+                case 3:
+                    gamma=value;
+                    return 1;
+                case 4:
+                    delta=value;
+                    return 1;
+        return 0;
+    void try_annealing(double starting_jump, int iterations,
+                       double temp_start, double temp_end, double target_rejection){
+        double dx[5]={0.,0.,0.,0.,0};
+        double x[5]={0.,0.,0.,0.,0};
+        double rejection[5]={0., 0., 0., 0., 0.};
+        double curr_x, curr_err, x_tmp;
+        double temperature;
+        double ratio, r;
+        int cycle=10;
+        boost::variate_generator<base_generator_type&, boost::uniform_real<> > uni(generator, uni_dist);
+        // set up parameter for annealing
+        x[0]=alpha_i;
+        x[1]=alpha_m;
+        x[2]=beta;
+        x[3]=gamma;
+        x[4]=delta;
+        for(int i=0;i<5;i++){
+            dx[i] = starting_jump;
+        // establish the current value
+        evolve_to_target();
+        std::cout << CumulativeRelativeLoss << " +- " << CRLsquare << std::endl;
+        curr_x   = CumulativeRelativeLoss;
+        curr_err = CRLsquare;
+        CumulativeRelativeLoss = 0;
+        CRLsquare = 0;
+        // optimization cycle
+        for(int i=0; i<iterations; i++){
+            temperature = temp_start*exp( i*(log(temp_end)-log(temp_start))/(double)iterations);
+            std::cout  << std::endl << "....T = " << wrap_double(temperature,3) << std::endl << std::endl;
+            if (i % cycle == 0 && i > 0){
+                for (int k=0; k<5; k++){
+                    rejection[k]/=(double)cycle;
+                    if (rejection[k] > 0){
+                        dx[k] = dx[k]/(rejection[k]/target_rejection);
+                        rejection[k]=0.;
+                    else{
+                        dx[k]*=2.;
+                    std::cout  << dx[k] << " ";
+            for (int j=0; j<5; j++){
+                // get new value of x[j]
+                x_tmp = get_new_x(x[j],dx[j]);
+                set_parameter(x_tmp, j);
+                std::cout  << std::endl << "......... " << std::endl;
+                std::cout << "Trying... " << CumulativeRelativeLoss << " +- " << CRLsquare << std::endl;
+                ratio = min(1.,exp(-(CumulativeRelativeLoss-curr_x)/temperature));
+                r = uni();
+                std::cout << r << " vs " << ratio << std::endl;
+                if (r > ratio){
+                    std::cout << string_wrap(id, 4) <<" "<< (i+1) << ","<< (j)
+                    <<" "<< (i+1) << " Did not accept "
+                    << x_tmp << "(" << j << ")" << std::endl;
+                    std::cout << alpha_i << " "<< alpha_m << " "
+                    << beta << " " << gamma << " "
+                    << delta << " " << std::endl;
+                    set_parameter(x[j], j);
+                    CRLsquare = 0;
+                    rejection[j]+=1.;
+                else {
+                    x[j] = x_tmp;
+                    CRLsquare = 0;
+                    std::cout << (i+1) << string_wrap((string) " Rejection counts: ", 8)
+                    << " "<< wrap_double(rejection[1], 7) << " "
+                    << wrap_double(rejection[2],5) << " " << wrap_double(rejection[2],9) << " "
+                    << wrap_double(rejection[4],6) << " "
+                    << std::endl << std::endl;
+                    std::cout << string_wrap(id, 4) <<" "<< (i+1) <<","<< (j)
+                    << string_wrap((string) "***** Did accept! ", 3)
+                    << wrap_double(alpha_i,2)
+                    << " "<< wrap_double(alpha_m, 7) << " "
+                    << wrap_double(beta,5) << " "
+                    << wrap_double(gamma,9) << " "
+                    << wrap_double(delta,6) << " "
+std::pair<double,double> multi_loss(dispatch_group_t group,
+                                    Universe* un[],
+                                    dispatch_queue_t* CustomQueues,
+                                    double* Results,
+                                    int*    Counters,
+                                    double* params){
+    int N = un[0]->get_reruns();
+    int step = (int)(double)N/(double)(Nworkers);
+    int istart=0;
+    int iend = istart+step;
+    double Loss=0., LossSquare=0.;
+    for(int i=0; i<Nworkers; i++){
+        for(int j=0; j<5; j++){
+            un[i]->set_parameter(params[j],j);
+        dispatch_group_async(group, CustomQueues[i], ^{
+            un[i]->evolve_to_target_and_save(istart, iend, Results, Counters);
+        std::cout << "queued: i=" << i << " N=" << N << " istart=" << istart << " iend=" << iend << "\n";
+        istart += step;
+        iend = min(istart+step,N);
+    dispatch_group_wait(group, DISPATCH_TIME_FOREVER);
+    //dispatch_release(group);
+    for (int i=0; i<N; i++){
+        Loss+=Results[i]/(double)N;
+        LossSquare+=Results[i]*Results[i]/(double)N;
+        // std::cout<<" " << Results[i];
+    //std::cout<<" \n\n\n";
+    double two_std = ((LossSquare - Loss*Loss)/(double)N);
+    two_std = 2.*sqrt(two_std);
+    std::pair<double,double> Res;
+    Res.first=Loss;
+    Res.second=two_std;
+    return Res;
+void multi_annealing( dispatch_group_t group,
+                     Universe* un[],
+                     double T_start, double T_end,
+                     double Target_rejection,
+                     int Annealing_repeats,
+                     double starting_jump,
+                     double* Results,
+                     int*    Counters,
+                     double* params0,
+                     double annealing_cycles){
+    // re-implement annealing
+    double ratio, r;
+    int cycle=10;
+    x[0]=params0[0];
+    x[1]=params0[1];
+    x[2]=params0[2];
+    x[3]=params0[3];
+    x[4]=params0[4];
+    std::pair<double,double>Res;
+    Res = multi_loss(group, un, CustomQueues, Results, Counters, x);
+    std::cout << Res.first << " +- " << Res.second << std::endl;
+    curr_x   = Res.first;
+    curr_err = Res.second;
+    for(int i=0; i<annealing_cycles; i++){
+        temperature = T_start*exp( i*(log(T_end)-log(T_start))/(double)annealing_cycles);
+                    dx[k] = dx[k]/(rejection[k]/Target_rejection);
+                    rejection[k]=0.;
+                else{
+                    dx[k]*=2.;
+            if (FIX_VARIABLES==0 || var_fixed[j]==0){
+                double x_hold=x[j];
+                x[j]=x_tmp;
+                std::cout << wrap_double(x_tmp,10) << " " << wrap_double(j,9) << "\n\n";
+                for(int w=0; w<Nworkers; w++){
+                    un[w]->set_parameter(x_tmp, j);
+                ratio = min(1.,exp(-(Res.first-curr_x)/temperature));
+                r = rand()/(double)(pow(2.,31)-1.);
+                if (Res.first < ALOT)
+                    ofstream filestr;
+                    filestr.open ("best_opt_some.txt", ofstream::app);
+                    // >> i/o operations here <<
+                    filestr << un[0]->get_target() << ","
+                    << Res.first
+                    << "," << un[0]->get_parameter(0)
+                    << "," << un[0]->get_parameter(1)
+                    << "," << un[0]->get_parameter(2)
+                    << "," << un[0]->get_parameter(3)
+                    << "," << un[0]->get_parameter(4) << "," << Res.second << ",\n";
+                    filestr.close();
+                    filestr.open ("max_dist.txt", ofstream::app);
+                    filestr << max_dist << ",\n";
+                    filestr.close();
+                if (r > ratio){
+                    std::cout << " "<< (i+1) << ","<< (j)
+                    std::cout << un[0]->get_parameter(0)
+                    << " " << un[0]->get_parameter(1)
+                    << " " << un[0]->get_parameter(2)
+                    << " " << un[0]->get_parameter(3)
+                    << " " << un[0]->get_parameter(4) << " " << std::endl;
+                    x[j]=x_hold;
+                        un[w]->set_parameter(x[j], j);
+                    //set_parameter(x[j], j);
+                    rejection[j]+=1.;
+                else {
+                    x[j] = x_tmp;
+                    << wrap_double(rejection[0],2) << " "
+                    << wrap_double(rejection[1],7) << " "
+                    << wrap_double(rejection[3],9) << " "
+                    std::cout << " "<< (i+1) <<","<< (j)
+                    << wrap_double(un[0]->get_parameter(0),2) << " "
+                    << wrap_double(un[0]->get_parameter(1),7) << " "
+                    << wrap_double(un[0]->get_parameter(2),5) << " "
+                    << wrap_double(un[0]->get_parameter(3),9) << " "
+                    << wrap_double(un[0]->get_parameter(4),6) << " "
+int
+main(int argc, char* argv[])
+    double params0[6] = {0., 0., 0., 0., 0., 0.2}, target=50., range;
+    string par_names0[6] = {"alpha_i", "alpha_m", "beta", "gamma", "delta", "target"};
+    string par_names1[4] = {"n_epochs", "n_steps", "n_reruns", "range"};
+    string par_names2[5] = {"T_start", "T_end", "Annealing_steps","Target_rejection","Starting_jump"};
+    string par_names3[5] = {"FREEZE_alpha_i", "FREEZE_alpha_m", "FREEZE_beta", "FREEZE_gamma", "FREEZE_delta"};
+    int params1[4] = {300, 50, 1000, 10};
+    int params3[5] = { 0, 0, 0, 0, 0};
+    //          temperature_start,  temperature_end,  annealing_steps target_rejection  Starting_jump
+    double params2[5] = {1,             0.001,               100,              0.3,           1.5};
+    int verbose_level = 2;
+    const std::string one="one", two="two";
+    static Universe* un[Nworkers];
+    static dispatch_queue_t CustomQueues[Nworkers];
+    static double* Results;
+    static int*    Counters;
+    timeval t1, t2;
+    double elapsedTime;
+    // start timer
+    gettimeofday(&t1, NULL);
+    if (argc < 8) {
+        std::cout << "Usage: super_optimizer alpha_i alpha_m beta gamma delta target_innov [n_epochs n_steps n_reruns] [range] [verbose_level]\n";
+        std::cout << "         [T_start T_end Annealing_steps Target_rejection Starting_jump]\n";
+        std::cout << "         [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta]\n";
+        system("pwd");
+        return(1);
+    else {
+        for (int nArg=0; nArg < argc; nArg++){
+            //std::cout << nArg << " " << argv[nArg] << std::endl;
+            if (nArg > 0 && nArg < 7){
+                params0[nArg-1]= atof(argv[nArg]);
+                std::cout << par_names0[nArg-1] << ": " << params0[nArg-1] <<  std::endl;
+            if (nArg > 6 && nArg < 11){
+                params1[nArg-7]= atoi(argv[nArg]);
+                std::cout << par_names1[nArg-7] << ": " << params1[nArg-7] <<  std::endl;
+            if (nArg == 11){
+                verbose_level = atoi(argv[nArg]);
+                std::cout << "verbose level: " << verbose_level <<  std::endl;
+            if (nArg > 11 && nArg < 17){
+                params2[nArg-12]= atof(argv[nArg]);
+                std::cout << par_names2[nArg-12] << ": " << params2[nArg-12] <<  std::endl;
+            if (nArg > 16 && nArg < 22){
+                params3[nArg-17]= atof(argv[nArg]);
+                var_fixed[nArg-17]= atof(argv[nArg]);
+                std::cout << par_names3[nArg-17] << ": " << var_fixed[nArg-17] <<  std::endl;
+        cout << j << " | " << var_fixed[j] << " (fixed) \n";
+    target=params0[5];
+    range = (double)params1[3];
+	int identify_failed = 0;
+	char* filename= (char *)"movie_graph.txt";
+ 	int n_ep=params1[0], n_st=params1[1], n_rep=params1[2];
+        un[i] = new Universe((char *)filename,n_ep,n_st,
+                             (int)n_rep,
+                             identify_failed, target, i2string(i));
+        CustomQueues[i] = dispatch_queue_create(i2char(i), NULL);
+    if(n_rep > 0){
+        Results = new double[n_rep];
+        Counters = new int[n_rep];
+    }else {
+        Results =  NULL;
+        Counters = NULL;
+        std::cout << " Number of reruns should be positive! " <<  std::endl;
+        return 0;
+    srand(time(0));
+    //srandomdev();
+        double r=0;
+        for (int j=0; j<100; j++){
+            std::cout << r << " ";
+        std::cout << "\n ";
+  	//random initiation of starting parameters
+    if (range > 0.){
+        for (int i=0; i < 5; i++){
+            if (params0[i]==-100.){
+                double r1 = (rand()/(double)(pow(2.,31)-1.));
+                double r2 = (rand()/(double)(pow(2.,31)-1.));
+                double sign = 1.;
+                if(r1 > 0.5){
+                    sign=-1.;
+                params0[i] = sign*r2*range;
+                std::cout << par_names0[i] << ": " << params0[i] <<  std::endl;
+    double T_start=params2[0], T_end=params2[1], Target_rejection=params2[3], starting_jump=params2[4];
+    int Annealing_repeats = (int) params2[2];
+    dispatch_group_t group = dispatch_group_create();
+    multi_annealing(group, un, CustomQueues, T_start, T_end, Target_rejection, Annealing_repeats,
+                    starting_jump, Results, Counters, params0, Annealing_repeats);
+    //dispatch_group_wait(group, DISPATCH_TIME_FOREVER);
+    dispatch_release(group);
+    // stop timer
+    gettimeofday(&t2, NULL);
+    // compute and print the elapsed time in millisec
+    elapsedTime = (t2.tv_sec - t1.tv_sec) * 1000.0;      // sec to ms
+    elapsedTime += (t2.tv_usec - t1.tv_usec) / 1000.0;   // us to ms
+    elapsedTime /= 1000.;
+    cout << elapsedTime << " seconds \n .....(" << elapsedTime/60. << " minutes)\n\n";
+        delete un[i];
+    if(n_rep > 0){
+        delete [] Results;
+        delete [] Counters;
+    return 0;
Deleted: SwiftApps/SciColSim/optimizer.protomods.cpp
--- SwiftApps/SciColSim/optimizer.protomods.cpp	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/optimizer.protomods.cpp	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,1818 +0,0 @@
-//  main.cpp
-//  optimizer
-#define MAXNworkers 24
-int Nworkers=MAXNworkers;
-// Add operation code to enable existing code to be used at lower level from Swift scripts:
-char operation = 'n'; // n: normal; m: do one multi_loss (with n_reruns).
-                      // Not used: a: analyze and generate next annealing parameter set. g: tbd
-#include <fstream>
-#include <sstream>
-#include <stdio.h>
-#include <time.h>
-#include <ctime>
-#include <string>
-#include <stdio.h>
-// #include <dispatch/dispatch.h>
-#include <fstream>
-#define NEVOPARAMS 5
-namespace std {
-	using ::time;
-static int var_fixed[NEVOPARAMS] = {1, 0, 1, 1, 0};
-    return GaussNum;
-	return diffms;
-    double new_x;
-    if (r > 0.5){
-    } else {
-    return new_x;
-    switch(mode){
-        case 0:
-            break;
-        case 1:
-            break;
-        case 2:
-            break;
-        case 3:
-            break;
-        case 4:
-            break;
-        case 5:
-            break;
-        case 6:
-            break;
-        case 7:
-            break;
-        case 8:
-            break;
-        case 9:
-            break;
-        case 10:
-            break;
-        default:
-            s << ins;
-    return s.str();
-    return s.str();
-const
-    s << "worker"
-    return s.str();
-    s << "worker"
-    return a;
-template <class T>
-bool from_string(T& t,
-                 const std::string& s,
-                 std::ios_base& (*f)(std::ios_base&))
-  std::istringstream iss(s);
-  return !(iss >> f >> t).fail();
-class Universe {
-private:
-	double alpha_i;
-	double alpha_m;
-	double beta;
-	double gamma;
-	double delta;
-    double CRLsquare;
-    string id;
-	int N_nodes;
-	int M_edges;
-	int N_epochs;
-	int N_steps;
-	int N_repeats;
-	double k_max;
-	graph_t Full_g;
-	double **Prob;
-	double **Tried;
-	double **Dist;
-	double **Final;
-	double *Rank;
-public:
-        //string line;
-        generator = gene;
-        uni_dist = uni_d;
-		int i, k;
-        int x, y;
-        CRLsquare = 0.;
-		N_steps   = Steps;
-        id = idd;
-		}else {
-		i=0;
-        std::string line;
-        while (1==1) {
-            inFile >> x;
-            inFile >> y;
-			if (i==0){
-				N_nodes=x;
-				M_edges=y;
-                break;
-			i++;
-		inFile.close();
-		k_max = 70;
-			Rank[i]=0.;
-				Final[i][j] = 0.;
-				Prob[i][j]=0.;
-				Dist[i][j]=-1.;
-				Tried[i][j]=0.;
-		if (!inFile) {
-		else {
-		i=0;
-			if (i > 0) {
-				Final[x][y]=1.;
-				Final[y][x]=1.;
-                    std::cout << ".";
-			i++;
-		inFile.close();
-        k=0;
-                    k++;
-		k=0;
-					k++;
-		Full_g = g;
-		double r, u, g;
-        r=0.;
-            u=(double)rand();
-			//r += geom();
-            r+=g;
-		return r;
-	int sample(){
-		int result = 0;
-		int finished = 0;
-				if (Summa > r){
-					Tried[i][j]+=1.;
-						result = 1;
-					finished = 1;
-		return result;
-			if(Rank[j] > 0.){
-					if (p[*vi]!=*vi){
-					} else {
-						Dist[*vi][j]=-1.;
-						Dist[j][*vi]=-1.;
-			Rank[i]=0.;
-					Rank[i]++;
-					Rank[j]++;
-		alpha_i=a_i;
-		alpha_m=a_m;
-		gamma=g;
-		beta=b;
-		delta=d;
-		current_loss=0;
-		current_epoch=0;
-		current_repeat++;
-			Rank[i]=0.;
-				Prob[i][j]=0.;
-				Dist[i][j]=-1.;
-				Tried[i][j]=0.;
-        << alpha_i << " "
-        << beta << " "
-        << gamma << " | "
-        s << "world_"
-        return s.str();
-				double bg = 0.;
-                    if (k >= k_max){
-                        k = k_max-1;
-                } else {
-                    bg = delta;
-		int failed = 0;
-		update_ranks();
-		// sampling
-		int result;
-						novel+=1.;
-		else {
-			double pfail=0.;
-			int n_failed;
-			//, n_check = 0;
-						Prob[i][j] = 0.;
-						novel+=1.;
-		    << std::endl;
-		current_epoch++;
-	~Universe(){
-        double **pointer;
-        return pointer;
-        double *pointer;
-        if(N > 0){
-        }else {
-            pointer = NULL;
-        return pointer;
-	// std::cout<<" evolve_to_target_and_save: istart=" << istart << "iend=" << iend << "\n";
-        reset_world();
-	  // std::cout<<" evolve: k=" << k << "\n";
-	      // std::cout<<" evolve: k=" << k << " i=" << i << " cur=" << current_novelty << " Target=" << TargetNovelty << "\n";
-                update_world();
-            counters[k]=1;
-            reset_world();
-        return N_repeats;
-        switch(i){
-            case 0:
-                return alpha_i;
-            case 1:
-                return alpha_m;
-            case 2:
-                return beta;
-            case 3:
-                return gamma;
-            case 4:
-                return delta;
-            default:
-                return 0.;
-        reset_world();
-            CRLsquare = 0.;
-            return;
-                update_world();
-            reset_world();
-        else {
-            switch(position){
-                case 0:
-                    alpha_i=value;
-                    return 1;
-                case 1:
-                    alpha_m=value;
-                    return 1;
-                case 2:
-                    beta=value;
-                    return 1;
-                case 3:
-                    gamma=value;
-                    return 1;
-                case 4:
-                    delta=value;
-                    return 1;
-        return 0;
-#ifdef notdef
-        double ratio, r;
-        int cycle=10;
-        x[0]=alpha_i;
-        x[1]=alpha_m;
-        x[2]=beta;
-        x[3]=gamma;
-        x[4]=delta;
-        CRLsquare = 0;
-                        rejection[k]=0.;
-                    else{
-                        dx[k]*=2.;
-                r = uni();
-                if (r > ratio){
-                    CRLsquare = 0;
-                    rejection[j]+=1.;
-                else {
-                    x[j] = x_tmp;
-                    CRLsquare = 0;
-#endif // notdef
-std::pair<double,double> multi_loss( // dispatch_group_t group,
-                                    Universe* un[],
-                                    // dispatch_queue_t* CustomQueues,
-                                    double* Results,
-                                    int*    Counters,
-                                    double* params){
-    int istart=0;
-    timeval startTime, endTime;
-    // start timer
-    gettimeofday(&startTime, NULL);
-    //err:    for(int i=0; i<Nworkers; i++){
-    std::cout << "Entry to multi_loss, params: ";
-        for(int j=0; j<NEVOPARAMS; j++){
-	  std::cout << "[" << un[i]->get_parameter(j) << "," << params[j] << "] ";
-    std::cout << "\n";
-    int i;
-    #pragma omp parallel for private (i)
-    for(i=0; i<Nworkers; i++){
-      // dispatch_group_async(group, CustomQueues[i], ^{
-      std::cout<<"multi_loss: Calling evolve_to_target_and_save i=" << i << " N=" << N << " step=" << step << " istart=" << i*step << " iend=" << (i+1)*step << "\n";
-      //un[i]->evolve_to_target_and_save(istart, iend, Results, Counters);
-      un[i]->evolve_to_target_and_save(i*step, min((i+1)*step,N), Results, Counters);
-      // std::cout<<"multi_loss: Returned from evolve_to_target_and_save " << i << "\n";
-      //istart += step;
-      //iend = min(istart+step,N);
-    // err    }
-    // dispatch_group_wait(group, DISPATCH_TIME_FOREVER);
-        std::cout<<i<<":"<< Results[i] << " ";
-    std::cout<<" \n\n\n";
-    Res.first=Loss;
-    gettimeofday(&endTime, NULL);
-    elapsedTime = (endTime.tv_sec - startTime.tv_sec) * 1000.0;      // sec to ms
-    elapsedTime += (endTime.tv_usec - startTime.tv_usec) / 1000.0;   // us to ms
-    cout << "multi_loss(N=" << N << ") elapsed time: " << elapsedTime << " seconds " << elapsedTime/60. << " minutes\n\n";
-    return Res;
-void multi_annealing( // dispatch_group_t group,
-                     Universe* un[],
-                     double* Results,
-                     int*    Counters,
-                     double* params0,
-    double dx[NEVOPARAMS]={0.,0.,0.,0.,0};
-    double x[NEVOPARAMS]={0.,0.,0.,0.,0};
-    double rejection[NEVOPARAMS]={0., 0., 0., 0., 0.};
-    double ratio, r;
-    int cycle=10;
-    for(int i=0;i<NEVOPARAMS;i++){
-        x[i]=params0[i];
-	  un[w]->set_parameter(x[i], i);
-    if ( operation == 'm' ) {
-      // Nworkers = 1;
-    else if (operation == 'g') {
-      // generate params: not yet implemented - to be deprecated
-    else if (operation == 'a') {
-      // analyze multi_loss() results: not tested or used - to be deprecated
-      string line;
-      ifstream mlossdata ("multi_loss.data");
-      double d, Loss, LossSquare, two_std;
-      bool b;
-      int n=0;
-      if (mlossdata.is_open()) {
-	while ( getline (mlossdata,line) ) {
-	  b = from_string<double>(d, std::string(line), std::dec);
-	  cout << line << " d=" << d << endl;
-	  Loss += d;
-          LossSquare += (d*d);
-          n++;
-        Loss /= double(n);
-	LossSquare /= double(n);
-	two_std = ((LossSquare - Loss*Loss)/(double)n);
-	std::cout<<"n="<<n<<" Loss="<<Loss<<" LossSquare="<<LossSquare<<" two_std="<<two_std<<"\n\n\n";
-	mlossdata.close();
-	FILE *f=fopen("multi_loss_stats.txt","w");
-	fprintf(f,"%d n\n",n);
-	fprintf(f,"%.20e Loss\n",Loss);
-	fprintf(f,"%.20e LossSquare\n",LossSquare);
-	fprintf(f,"%.20e two_std\n",two_std);
-        fclose(f);
-	exit(0);
-      else {
-	cout << "Unable to open file multi_loss.data";
-	exit(1);
-    std::cout << "Calling initial multi_loss:\n";
-    Res = multi_loss( /* group,*/ un, /* CustomQueues,*/ Results, Counters, x);
-    std::cout << "Ret from initial multi_loss:\n";
-      FILE *f;
-      f = fopen("multi_loss.data","w");
-      for(int i=0; i<N; i++) {
-	fprintf(f,"%.20e\n",Results[i]);
-      fclose(f);
-      exit(0);
-            for (int k=0; k<NEVOPARAMS; k++){
-                    rejection[k]=0.;
-                else{
-                    dx[k]*=2.;
-        for (int j=0; j<NEVOPARAMS; j++){
-                x[j]=x_tmp;
-		// WRITE OUT PARAMS HERE; then exit.
-		std::cout << "Calling multi_loss: i=" << i << " j=" << j << "\n";
-                Res = multi_loss(/* group, */ un, /* CustomQueues, */ Results, Counters, x);
-		std::cout << "Ret from multi_loss: i=" << i << " j=" << j << "\n";
-                    ofstream filestr;
-                    << Res.first
-                    filestr.close();
-                    filestr.close();
-                if (r > ratio){
-                    x[j]=x_hold;
-                    rejection[j]+=1.;
-                else {
-                    x[j] = x_tmp;
-int
-    string par_names4[2] = {"Operation", "Nworkers"};
-    static Universe* un[MAXNworkers];
-    // static dispatch_queue_t CustomQueues[MAXNworkers];
-    timeval t1, t2;
-    // start timer
-    if (argc < 8) {
-        system("pwd");
-        return(1);
-    else {
-      std::cout << "argc=" << argc << std::endl;
-            if (nArg == 11){
-            if (nArg == 22 ){
-                operation = *argv[nArg];
-		std::cout << par_names4[0] << ": " << operation <<  std::endl;
-            if (nArg == 23 ){
-	        Nworkers = atoi(argv[nArg]);
-		std::cout << par_names4[1] << ": " << Nworkers <<  std::endl;
-    for target in range(58,1009,50):
-	s = ("%d" % target)
-	print s
-	for i in range(15):
-          # Param groups separated by "|" below for documentation. NOTE that | is not used on command line!
-	  os.system("./supe_duper_optimizer |0 0 4 50 -1 "+s+" | 40000 20 1000 2 | 1 | 2. 0.01 100 0.3 2.3 | 1 1 0 0 0")
-    /*   Parameters, re-iterated:
-                        "alpha_i", "alpha_m", "beta", "gamma", "delta", "target"};
-                    {"n_epochs", "n_steps", "n_reruns", "range"};
-                       {"T_start",          "T_end",          "Annealing_steps","Target_rejection","Starting_jump"};
-                         temperature_start,  temperature_end,  annealing_steps target_rejection  Starting_jump
-                     {"FREEZE_alpha_i", "FREEZE_alpha_m", "FREEZE_beta", "FREEZE_gamma", "FREEZE_delta"};
-    target=params0[NEVOPARAMS];
-                             (int)n_rep,
-        // CustomQueues[i] = dispatch_queue_create(i2char(i), NULL);
-    // mw: n_rep == n_reruns = # times evolve is done within multi_loss, spread across Nworkers.
-    if(n_rep > 0){
-    }else {
-        Results =  NULL;
-        Counters = NULL;
-        return 0;
-    //srand(time(0));
-    //srandomdev();
-      timeval t;
-      gettimeofday(&t, NULL);
-      srand(t.tv_usec);
-        double r=0;
-    if (range > 0.){
-                double sign = 1.;
-                if(r1 > 0.5){
-                    sign=-1.;
-    // dispatch_group_t group = dispatch_group_create();
-    multi_annealing( /* group, */ un, /* CustomQueues, */ T_start, T_end, Target_rejection, Annealing_repeats,
-    // dispatch_release(group);
-    // stop timer
-    cout << elapsedTime << " seconds " << elapsedTime/60. << " minutes\n\n";
-        delete un[i];
-    if(n_rep > 0){
-    return 0;
Deleted: SwiftApps/SciColSim/optirun.swift
--- SwiftApps/SciColSim/optirun.swift	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/optirun.swift	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,41 +0,0 @@
-type file;
-app (file outfile, file best, file max) optimize ( string args[], file graph )
-  optimizersh @best @max args stdout=@outfile ;
-int minrange=58;
-int maxrange=1009;
-//int maxrange=209;
-int rangeinc=50;
-int nreps=2; # 15
-//      [alpha_i alpha_m beta gamma delta target_innov
-//      [n_epochs n_steps n_reruns] [range]
-//      [verbose_level]
-//      [T_start T_end Annealing_steps Target_rejection Starting_jump]
-//      [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta]
-file graph <"movie_graph.txt">;
-foreach target in [minrange:maxrange:rangeinc] {
-  foreach rep in [1:nreps] {
-    file outfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".out")>;
-    // file errfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".err")>;
-    file bestfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".best_opt_some")>;
-    file maxfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".max_dist")>;
-    // string longargs[] = @strcat("0 0 4 50 -1 ",target," 40000 20 1000 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0");
-    string fastargs1[] = ["0", "0", "4", "50", "-1", @strcat(target), "40000", "20", "1000", "2", "1", "2.", "0.01", "100", "0.3", "2.3", "1", "1", "0", "0", "0"];
-    string fastargs2[] = [
-       "0", "0", "4", "50", "-1", @strcat(target),
-       "40000", "20", "1000", "2",
-       "1",
-       "2.", "0.01",  "5", "0.3", "2.3",
-       "1", "1", "0", "0", "0"];
-    (outfile, bestfile, maxfile) = optimize(fastargs2,graph);
Deleted: SwiftApps/SciColSim/pads.similar.beagle.xml
--- SwiftApps/SciColSim/pads.similar.beagle.xml	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/pads.similar.beagle.xml	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,23 +0,0 @@
-<config>
-  <pool handle="pads">
-    <execution provider="coaster" jobmanager="ssh:pbs" url="login.pads.ci.uchicago.edu" />
-    <filesystem provider="local"/>
-     <profile namespace="globus" key="project">CI-CCR000013</profile>
-    <profile namespace="env" key="SWIFT_GEN_SCRIPTS">KEEP</profile>
-    <profile namespace="globus" key="ppn">8</profile>
-    <profile namespace="globus" key="jobsPerNode">1</profile>
-    <profile namespace="globus" key="lowOverAllocation">100</profile>
-    <profile namespace="globus" key="highOverAllocation">100</profile>
-    <profile namespace="globus" key="maxTime">3600</profile>
-    <profile namespace="globus" key="maxWallTime">00:02:00</profile>
-    <profile namespace="globus" key="slots">10</profile>
-    <profile namespace="globus" key="nodeGranularity">1</profile>
-    <profile namespace="globus" key="maxNodes">1</profile>
-    <profile namespace="globus" key="queue">fast</profile>
-    <profile namespace="karajan" key="jobThrottle">9.59</profile>
-    <profile namespace="karajan" key="initialScore">10000</profile>
-     <workdirectory>/gpfs/pads/swift/jonmon/Swift/work/pads</workdirectory>
-  </pool>
-</config>
Deleted: SwiftApps/SciColSim/paramtraceall.sh
--- SwiftApps/SciColSim/paramtraceall.sh	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/paramtraceall.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,7 +0,0 @@
-for ti in $(seq 58 70); do
-  echo
-  echo "=======" $ti ; /home/wilde/AndreysOptimizer/src/getparamtrace.sh $ti
-  echo
-done
Deleted: SwiftApps/SciColSim/plot_active.txt
--- SwiftApps/SciColSim/plot_active.txt	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/plot_active.txt	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,7767 +0,0 @@
-0	1
-10.9679	3
-21.9359	3
-32.9038	4
-43.8717	3
-54.8397	3
-65.8076	3
-76.7755	3
-87.7434	3
-98.7114	3
-109.679	3
-120.647	3
-131.615	3
-142.583	3
-153.551	3
-164.519	3
-175.487	3
-186.455	4
-197.423	3
-208.391	4
-219.359	3
-230.327	3
-241.294	3
-252.262	3
-263.23	3
-274.198	3
-285.166	3
-296.134	4
-307.102	4
-318.07	3
-329.038	4
-340.006	4
-350.974	3
-361.942	4
-372.91	4
-383.878	4
-394.845	3
-405.813	3
-416.781	4
-427.749	3
-438.717	3
-449.685	3
-460.653	3
-471.621	3
-482.589	3
-493.557	4
-504.525	3
-515.493	4
-526.461	3
-537.429	4
-548.397	3
-559.364	3
-570.332	3
-581.3	3
-592.268	4
-603.236	3
-614.204	3
-625.172	4
-636.14	4
-647.108	3
-658.076	4
-669.044	3
-680.012	3
-690.98	3
-701.948	3
-712.915	4
-723.883	3
-734.851	4
-745.819	4
-756.787	4
-767.755	3
-778.723	3
-789.691	3
-800.659	3
-811.627	3
-822.595	3
-833.563	4
-844.531	4
-855.499	3
-866.466	4
-877.434	3
-888.402	4
-899.37	4
-910.338	3
-921.306	3
-932.274	3
-943.242	4
-954.21	3
-965.178	4
-976.146	3
-987.114	4
-998.082	3
-1009.05	3
-1020.02	3
-1030.99	3
-1041.95	3
-1052.92	3
-1063.89	3
-1074.86	4
-1085.83	4
-1096.79	3
-1107.76	4
-1118.73	3
-1129.7	3
-1140.66	3
-1151.63	4
-1162.6	4
-1173.57	3
-1184.54	4
-1195.5	3
-1206.47	4
-1217.44	3
-1228.41	4
-1239.38	4
-1250.34	3
-1261.31	3
-1272.28	3
-1283.25	3
-1294.22	3
-1305.18	4
-1316.15	3
-1327.12	4
-1338.09	4
-1349.06	3
-1360.02	3
-1370.99	4
-1381.96	3
-1392.93	3
-1403.9	3
-1414.86	3
-1425.83	4
-1436.8	3
-1447.77	3
-1458.73	4
-1469.7	3
-1480.67	4
-1491.64	3
-1502.61	4
-1513.57	4
-1524.54	3
-1535.51	3
-1546.48	3
-1557.45	3
-1568.41	4
-1579.38	4
-1590.35	3
-1601.32	3
-1612.29	3
-1623.25	4
-1634.22	4
-1645.19	3
-1656.16	4
-1667.13	4
-1678.09	3
-1689.06	3
-1700.03	3
-1711	3
-1721.97	4
-1732.93	3
-1743.9	4
-1754.87	4
-1765.84	3
-1776.8	3
-1787.77	3
-1798.74	4
-1809.71	3
-1820.68	4
-1831.64	3
-1842.61	4
-1853.58	4
-1864.55	3
-1875.52	3
-1886.48	4
-1897.45	3
-1908.42	3
-1919.39	4
-1930.36	4
-1941.32	3
-1952.29	4
-1963.26	3
-1974.23	3
-1985.2	3
-1996.16	4
-2007.13	3
-2018.1	4
-2029.07	3
-2040.03	4
-2051	3
-2061.97	4
-2072.94	3
-2083.91	3
-2094.87	3
-2105.84	3
-2116.81	4
-2127.78	3
-2138.75	3
-2149.71	3
-2160.68	4
-2171.65	3
-2182.62	3
-2193.59	3
-2204.55	3
-2215.52	4
-2226.49	4
-2237.46	2
-2248.43	3
-2259.39	3
-2270.36	4
-2281.33	3
-2292.3	3
-2303.27	3
-2314.23	3
-2325.2	3
-2336.17	4
-2347.14	3
-2358.1	3
-2369.07	4
-2380.04	3
-2391.01	3
-2401.98	3
-2412.94	4
-2423.91	3
-2434.88	4
-2445.85	3
-2456.82	4
-2467.78	3
-2478.75	4
-2489.72	3
-2500.69	4
-2511.66	3
-2522.62	4
-2533.59	3
-2544.56	4
-2555.53	4
-2566.5	3
-2577.46	4
-2588.43	3
-2599.4	4
-2610.37	3
-2621.34	3
-2632.3	4
-2643.27	4
-2654.24	4
-2665.21	4
-2676.17	3
-2687.14	3
-2698.11	4
-2709.08	4
-2720.05	2
-2731.01	3
-2741.98	3
-2752.95	3
-2763.92	3
-2774.89	4
-2785.85	4
-2796.82	3
-2807.79	3
-2818.76	3
-2829.73	3
-2840.69	3
-2851.66	3
-2862.63	4
-2873.6	4
-2884.57	4
-2895.53	3
-2906.5	3
-2917.47	3
-2928.44	3
-2939.41	3
-2950.37	3
-2961.34	4
-2972.31	3
-2983.28	3
-2994.24	3
-3005.21	4
-3016.18	4
-3027.15	3
-3038.12	4
-3049.08	3
-3060.05	3
-3071.02	4
-3081.99	3
-3092.96	3
-3103.92	3
-3114.89	4
-3125.86	3
-3136.83	4
-3147.8	3
-3158.76	3
-3169.73	3
-3180.7	4
-3191.67	4
-3202.64	4
-3213.6	4
-3224.57	3
-3235.54	4
-3246.51	4
-3257.48	4
-3268.44	4
-3279.41	4
-3290.38	3
-3301.35	4
-3312.31	4
-3323.28	4
-3334.25	3
-3345.22	3
-3356.19	4
-3367.15	3
-3378.12	3
-3389.09	4
-3400.06	3
-3411.03	4
-3421.99	3
-3432.96	4
-3443.93	3
-3454.9	3
-3465.87	3
-3476.83	4
-3487.8	3
-3498.77	4
-3509.74	3
-3520.71	3
-3531.67	3
-3542.64	3
-3553.61	3
-3564.58	4
-3575.55	4
-3586.51	3
-3597.48	3
-3608.45	4
-3619.42	4
-3630.38	4
-3641.35	3
-3652.32	4
-3663.29	3
-3674.26	4
-3685.22	3
-3696.19	3
-3707.16	4
-3718.13	3
-3729.1	3
-3740.06	3
-3751.03	4
-3762	3
-3772.97	4
-3783.94	3
-3794.9	3
-3805.87	3
-3816.84	3
-3827.81	4
-3838.78	3
-3849.74	3
-3860.71	3
-3871.68	3
-3882.65	4
-3893.62	3
-3904.58	3
-3915.55	3
-3926.52	4
-3937.49	4
-3948.45	3
-3959.42	3
-3970.39	4
-3981.36	4
-3992.33	4
-4003.29	4
-4014.26	3
-4025.23	3
-4036.2	3
-4047.17	4
-4058.13	3
-4069.1	4
-4080.07	3
-4091.04	4
-4102.01	3
-4112.97	4
-4123.94	3
-4134.91	4
-4145.88	3
-4156.85	4
-4167.81	4
-4178.78	3
-4189.75	4
-4200.72	3
-4211.69	4
-4222.65	4
-4233.62	3
-4244.59	3
-4255.56	3
-4266.52	4
-4277.49	3
-4288.46	3
-4299.43	3
-4310.4	4
-4321.36	3
-4332.33	4
-4343.3	3
-4354.27	3
-4365.24	3
-4376.2	4
-4387.17	3
-4398.14	4
-4409.11	3
-4420.08	4
-4431.04	3
-4442.01	3
-4452.98	3
-4463.95	3
-4474.92	3
-4485.88	4
-4496.85	3
-4507.82	3
-4518.79	3
-4529.76	3
-4540.72	3
-4551.69	4
-4562.66	3
-4573.63	4
-4584.59	3
-4595.56	4
-4606.53	3
-4617.5	3
-4628.47	4
-4639.43	3
-4650.4	4
-4661.37	3
-4672.34	3
-4683.31	3
-4694.27	4
-4705.24	3
-4716.21	3
-4727.18	4
-4738.15	4
-4749.11	4
-4760.08	3
-4771.05	3
-4782.02	4
-4792.99	3
-4803.95	3
-4814.92	4
-4825.89	3
-4836.86	4
-4847.83	3
-4858.79	4
-4869.76	3
-4880.73	3
-4891.7	3
-4902.66	3
-4913.63	3
-4924.6	3
-4935.57	4
-4946.54	3
-4957.5	3
-4968.47	4
-4979.44	3
-4990.41	3
-5001.38	3
-5012.34	3
-5023.31	3
-5034.28	3
-5045.25	4
-5056.22	3
-5067.18	4
-5078.15	3
-5089.12	3
-5100.09	3
-5111.06	4
-5122.02	4
-5132.99	3
-5143.96	3
-5154.93	3
-5165.9	4
-5176.86	3
-5187.83	4
-5198.8	3
-5209.77	3
-5220.73	3
-5231.7	3
-5242.67	4
-5253.64	3
-5264.61	3
-5275.57	3
-5286.54	3
-5297.51	3
-5308.48	3
-5319.45	4
-5330.41	4
-5341.38	3
-5352.35	4
-5363.32	3
-5374.29	3
-5385.25	4
-5396.22	3
-5407.19	3
-5418.16	4
-5429.13	3
-5440.09	3
-5451.06	4
-5462.03	3
-5473	3
-5483.97	3
-5494.93	3
-5505.9	3
-5516.87	4
-5527.84	3
-5538.8	4
-5549.77	3
-5560.74	3
-5571.71	4
-5582.68	3
-5593.64	4
-5604.61	3
-5615.58	3
-5626.55	3
-5637.52	3
-5648.48	3
-5659.45	4
-5670.42	3
-5681.39	4
-5692.36	3
-5703.32	3
-5714.29	3
-5725.26	3
-5736.23	3
-5747.2	3
-5758.16	4
-5769.13	3
-5780.1	4
-5791.07	3
-5802.03	4
-5813	4
-5823.97	3
-5834.94	4
-5845.91	4
-5856.87	3
-5867.84	3
-5878.81	3
-5889.78	4
-5900.75	3
-5911.71	3
-5922.68	3
-5933.65	4
-5944.62	3
-5955.59	4
-5966.55	4
-5977.52	3
-5988.49	3
-5999.46	3
-6010.43	3
-6021.39	4
-6032.36	4
-6043.33	3
-6054.3	4
-6065.27	4
-6076.23	4
-6087.2	3
-6098.17	3
-6109.14	3
-6120.1	3
-6131.07	3
-6142.04	3
-6153.01	4
-6163.98	4
-6174.94	4
-6185.91	3
-6196.88	3
-6207.85	4
-6218.82	3
-6229.78	3
-6240.75	4
-6251.72	4
-6262.69	3
-6273.66	3
-6284.62	4
-6295.59	3
-6306.56	4
-6317.53	4
-6328.5	3
-6339.46	4
-6350.43	3
-6361.4	3
-6372.37	3
-6383.34	3
-6394.3	3
-6405.27	3
-6416.24	3
-6427.21	4
-6438.17	3
-6449.14	3
-6460.11	3
-6471.08	3
-6482.05	3
-6493.01	3
-6503.98	4
-6514.95	4
-6525.92	3
-6536.89	3
-6547.85	4
-6558.82	4
-6569.79	4
-6580.76	4
-6591.73	4
-6602.69	4
-6613.66	3
-6624.63	3
-6635.6	4
-6646.57	4
-6657.53	3
-6668.5	4
-6679.47	4
-6690.44	3
-6701.41	3
-6712.37	3
-6723.34	3
-6734.31	3
-6745.28	3
-6756.24	3
-6767.21	3
-6778.18	3
-6789.15	3
-6800.12	2
-6811.08	3
-6822.05	3
-6833.02	3
-6843.99	3
-6854.96	4
-6865.92	3
-6876.89	4
-6887.86	4
-6898.83	4
-6909.8	3
-6920.76	4
-6931.73	3
-6942.7	3
-6953.67	3
-6964.64	4
-6975.6	3
-6986.57	3
-6997.54	3
-7008.51	3
-7019.48	3
-7030.44	3
-7041.41	3
-7052.38	4
-7063.35	3
-7074.31	4
-7085.28	3
-7096.25	4
-7107.22	4
-7118.19	3
-7129.15	3
-7140.12	3
-7151.09	4
-7162.06	3
-7173.03	4
-7183.99	3
-7194.96	3
-7205.93	4
-7216.9	4
-7227.87	3
-7238.83	3
-7249.8	3
-7260.77	3
-7271.74	3
-7282.71	4
-7293.67	3
-7304.64	3
-7315.61	3
-7326.58	3
-7337.55	3
-7348.51	3
-7359.48	3
-7370.45	4
-7381.42	3
-7392.38	4
-7403.35	4
-7414.32	3
-7425.29	3
-7436.26	4
-7447.22	3
-7458.19	3
-7469.16	4
-7480.13	3
-7491.1	4
-7502.06	3
-7513.03	4
-7524	3
-7534.97	3
-7545.94	3
-7556.9	3
-7567.87	3
-7578.84	4
-7589.81	3
-7600.78	4
-7611.74	3
-7622.71	4
-7633.68	3
-7644.65	3
-7655.62	3
-7666.58	3
-7677.55	4
-7688.52	3
-7699.49	3
-7710.45	4
-7721.42	4
-7732.39	4
-7743.36	4
-7754.33	4
-7765.29	3
-7776.26	3
-7787.23	3
-7798.2	3
-7809.17	3
-7820.13	3
-7831.1	3
-7842.07	3
-7853.04	3
-7864.01	3
-7874.97	3
-7885.94	3
-7896.91	3
-7907.88	3
-7918.85	3
-7929.81	3
-7940.78	3
-7951.75	3
-7962.72	4
-7973.69	4
-7984.65	4
-7995.62	3
-8006.59	3
-8017.56	3
-8028.52	3
-8039.49	4
-8050.46	3
-8061.43	3
-8072.4	3
-8083.36	3
-8094.33	3
-8105.3	3
-8116.27	4
-8127.24	3
-8138.2	3
-8149.17	4
-8160.14	3
-8171.11	3
-8182.08	3
-8193.04	4
-8204.01	3
-8214.98	3
-8225.95	3
-8236.92	4
-8247.88	3
-8258.85	3
-8269.82	4
-8280.79	3
-8291.76	3
-8302.72	3
-8313.69	3
-8324.66	4
-8335.63	4
-8346.59	4
-8357.56	3
-8368.53	3
-8379.5	3
-8390.47	3
-8401.43	4
-8412.4	4
-8423.37	3
-8434.34	4
-8445.31	4
-8456.27	3
-8467.24	3
-8478.21	3
-8489.18	3
-8500.15	4
-8511.11	3
-8522.08	3
-8533.05	3
-8544.02	3
-8554.99	3
-8565.95	3
-8576.92	3
-8587.89	3
-8598.86	4
-8609.83	3
-8620.79	3
-8631.76	4
-8642.73	4
-8653.7	4
-8664.66	3
-8675.63	4
-8686.6	3
-8697.57	3
-8708.54	3
-8719.5	3
-8730.47	3
-8741.44	3
-8752.41	3
-8763.38	3
-8774.34	3
-8785.31	3
-8796.28	3
-8807.25	3
-8818.22	3
-8829.18	3
-8840.15	3
-8851.12	4
-8862.09	3
-8873.06	4
-8884.02	3
-8894.99	4
-8905.96	3
-8916.93	3
-8927.9	3
-8938.86	4
-8949.83	3
-8960.8	4
-8971.77	3
-8982.73	4
-8993.7	3
-9004.67	4
-9015.64	3
-9026.61	3
-9037.57	4
-9048.54	3
-9059.51	4
-9070.48	3
-9081.45	4
-9092.41	3
-9103.38	3
-9114.35	3
-9125.32	4
-9136.29	3
-9147.25	3
-9158.22	3
-9169.19	3
-9180.16	3
-9191.13	3
-9202.09	3
-9213.06	3
-9224.03	3
-9235	3
-9245.96	3
-9256.93	3
-9267.9	3
-9278.87	3
-9289.84	3
-9300.8	4
-9311.77	4
-9322.74	4
-9333.71	3
-9344.68	3
-9355.64	3
-9366.61	4
-9377.58	3
-9388.55	3
-9399.52	4
-9410.48	3
-9421.45	4
-9432.42	3
-9443.39	4
-9454.36	4
-9465.32	3
-9476.29	3
-9487.26	3
-9498.23	3
-9509.2	3
-9520.16	3
-9531.13	3
-9542.1	3
-9553.07	3
-9564.03	3
-9575	3
-9585.97	3
-9596.94	4
-9607.91	4
-9618.87	4
-9629.84	3
-9640.81	3
-9651.78	3
-9662.75	3
-9673.71	3
-9684.68	4
-9695.65	3
-9706.62	4
-9717.59	3
-9728.55	3
-9739.52	3
-9750.49	3
-9761.46	3
-9772.43	4
-9783.39	3
-9794.36	4
-9805.33	3
-9816.3	4
-9827.27	3
-9838.23	4
-9849.2	3
-9860.17	3
-9871.14	3
-9882.1	4
-9893.07	4
-9904.04	3
-9915.01	4
-9925.98	4
-9936.94	3
-9947.91	3
-9958.88	3
-9969.85	4
-9980.82	3
-9991.78	4
-10002.8	3
-10013.7	3
-10024.7	3
-10035.7	3
-10046.6	3
-10057.6	4
-10068.6	3
-10079.5	4
-10090.5	3
-10101.5	4
-10112.4	3
-10123.4	4
-10134.4	3
-10145.3	4
-10156.3	3
-10167.3	3
-10178.2	3
-10189.2	4
-10200.2	4
-10211.1	3
-10222.1	4
-10233.1	3
-10244	4
-10255	3
-10266	3
-10277	4
-10287.9	4
-10298.9	4
-10309.9	3
-10320.8	3
-10331.8	4
-10342.8	4
-10353.7	3
-10364.7	3
-10375.7	3
-10386.6	3
-10397.6	3
-10408.6	4
-10419.5	3
-10430.5	3
-10441.5	4
-10452.4	3
-10463.4	4
-10474.4	3
-10485.3	4
-10496.3	3
-10507.3	3
-10518.2	3
-10529.2	3
-10540.2	4
-10551.1	3
-10562.1	4
-10573.1	3
-10584.1	3
-10595	3
-10606	3
-10617	4
-10627.9	4
-10638.9	3
-10649.9	3
-10660.8	3
-10671.8	3
-10682.8	3
-10693.7	4
-10704.7	4
-10715.7	4
-10726.6	3
-10737.6	3
-10748.6	3
-10759.5	4
-10770.5	3
-10781.5	3
-10792.4	3
-10803.4	4
-10814.4	3
-10825.3	3
-10836.3	3
-10847.3	3
-10858.3	3
-10869.2	4
-10880.2	4
-10891.2	3
-10902.1	3
-10913.1	3
-10924.1	3
-10935	3
-10946	4
-10957	3
-10967.9	4
-10978.9	3
-10989.9	3
-11000.8	3
-11011.8	4
-11022.8	3
-11033.7	3
-11044.7	3
-11055.7	3
-11066.6	3
-11077.6	3
-11088.6	3
-11099.5	4
-11110.5	4
-11121.5	3
-11132.4	3
-11143.4	3
-11154.4	3
-11165.4	3
-11176.3	3
-11187.3	4
-11198.3	3
-11209.2	4
-11220.2	3
-11231.2	3
-11242.1	4
-11253.1	3
-11264.1	4
-11275	3
-11286	3
-11297	3
-11307.9	3
-11318.9	4
-11329.9	4
-11340.8	3
-11351.8	3
-11362.8	4
-11373.7	3
-11384.7	3
-11395.7	4
-11406.6	4
-11417.6	3
-11428.6	4
-11439.6	3
-11450.5	3
-11461.5	3
-11472.5	3
-11483.4	3
-11494.4	4
-11505.4	3
-11516.3	3
-11527.3	3
-11538.3	3
-11549.2	3
-11560.2	4
-11571.2	3
-11582.1	3
-11593.1	3
-11604.1	3
-11615	3
-11626	3
-11637	3
-11647.9	3
-11658.9	3
-11669.9	2
-11680.8	3
-11691.8	3
-11702.8	3
-11713.7	3
-11724.7	4
-11735.7	3
-11746.7	3
-11757.6	3
-11768.6	4
-11779.6	3
-11790.5	3
-11801.5	4
-11812.5	4
-11823.4	4
-11834.4	3
-11845.4	4
-11856.3	4
-11867.3	3
-11878.3	3
-11889.2	3
-11900.2	4
-11911.2	3
-11922.1	4
-11933.1	3
-11944.1	3
-11955	3
-11966	3
-11977	4
-11987.9	3
-11998.9	3
-12009.9	3
-12020.9	3
-12031.8	3
-12042.8	3
-12053.8	4
-12064.7	4
-12075.7	3
-12086.7	3
-12097.6	3
-12108.6	3
-12119.6	4
-12130.5	3
-12141.5	3
-12152.5	4
-12163.4	4
-12174.4	3
-12185.4	3
-12196.3	3
-12207.3	4
-12218.3	3
-12229.2	3
-12240.2	4
-12251.2	3
-12262.1	3
-12273.1	4
-12284.1	3
-12295	3
-12306	3
-12317	4
-12328	3
-12338.9	3
-12349.9	3
-12360.9	4
-12371.8	4
-12382.8	3
-12393.8	4
-12404.7	3
-12415.7	4
-12426.7	3
-12437.6	3
-12448.6	3
-12459.6	3
-12470.5	4
-12481.5	3
-12492.5	3
-12503.4	3
-12514.4	3
-12525.4	4
-12536.3	4
-12547.3	3
-12558.3	3
-12569.2	3
-12580.2	3
-12591.2	3
-12602.2	3
-12613.1	4
-12624.1	3
-12635.1	4
-12646	3
-12657	3
-12668	3
-12678.9	3
-12689.9	3
-12700.9	3
-12711.8	4
-12722.8	4
-12733.8	3
-12744.7	4
-12755.7	3
-12766.7	3
-12777.6	3
-12788.6	4
-12799.6	3
-12810.5	3
-12821.5	3
-12832.5	4
-12843.4	3
-12854.4	3
-12865.4	3
-12876.3	4
-12887.3	3
-12898.3	4
-12909.3	3
-12920.2	4
-12931.2	3
-12942.2	3
-12953.1	4
-12964.1	4
-12975.1	3
-12986	4
-12997	3
-13008	3
-13018.9	3
-13029.9	3
-13040.9	3
-13051.8	2
-13062.8	4
-13073.8	3
-13084.7	3
-13095.7	4
-13106.7	3
-13117.6	4
-13128.6	4
-13139.6	4
-13150.5	3
-13161.5	3
-13172.5	4
-13183.5	3
-13194.4	3
-13205.4	3
-13216.4	4
-13227.3	3
-13238.3	4
-13249.3	4
-13260.2	3
-13271.2	4
-13282.2	3
-13293.1	3
-13304.1	3
-13315.1	3
-13326	3
-13337	3
-13348	3
-13358.9	4
-13369.9	4
-13380.9	3
-13391.8	3
-13402.8	3
-13413.8	3
-13424.7	4
-13435.7	3
-13446.7	4
-13457.7	3
-13468.6	4
-13479.6	3
-13490.6	4
-13501.5	3
-13512.5	4
-13523.5	3
-13534.4	4
-13545.4	4
-13556.4	4
-13567.3	3
-13578.3	4
-13589.3	4
-13600.2	4
-13611.2	3
-13622.2	4
-13633.1	3
-13644.1	3
-13655.1	3
-13666	3
-13677	3
-13688	3
-13698.9	3
-13709.9	4
-13720.9	3
-13731.8	3
-13742.8	3
-13753.8	3
-13764.8	3
-13775.7	3
-13786.7	4
-13797.7	3
-13808.6	3
-13819.6	4
-13830.6	3
-13841.5	3
-13852.5	4
-13863.5	3
-13874.4	4
-13885.4	3
-13896.4	4
-13907.3	3
-13918.3	3
-13929.3	3
-13940.2	3
-13951.2	3
-13962.2	3
-13973.1	3
-13984.1	3
-13995.1	3
-14006	4
-14017	4
-14028	4
-14039	4
-14049.9	4
-14060.9	3
-14071.9	3
-14082.8	4
-14093.8	4
-14104.8	3
-14115.7	3
-14126.7	3
-14137.7	3
-14148.6	3
-14159.6	3
-14170.6	3
-14181.5	3
-14192.5	3
-14203.5	4
-14214.4	3
-14225.4	3
-14236.4	4
-14247.3	3
-14258.3	4
-14269.3	4
-14280.2	3
-14291.2	4
-14302.2	3
-14313.1	3
-14324.1	3
-14335.1	3
-14346.1	3
-14357	3
-14368	4
-14379	3
-14389.9	3
-14400.9	3
-14411.9	4
-14422.8	3
-14433.8	4
-14444.8	4
-14455.7	3
-14466.7	3
-14477.7	4
-14488.6	3
-14499.6	3
-14510.6	3
-14521.5	3
-14532.5	3
-14543.5	4
-14554.4	4
-14565.4	3
-14576.4	3
-14587.3	3
-14598.3	3
-14609.3	3
-14620.3	3
-14631.2	4
-14642.2	3
-14653.2	3
-14664.1	3
-14675.1	3
-14686.1	4
-14697	3
-14708	3
-14719	3
-14729.9	4
-14740.9	3
-14751.9	3
-14762.8	3
-14773.8	4
-14784.8	3
-14795.7	3
-14806.7	3
-14817.7	3
-14828.6	3
-14839.6	4
-14850.6	3
-14861.5	4
-14872.5	3
-14883.5	4
-14894.4	3
-14905.4	4
-14916.4	4
-14927.4	3
-14938.3	4
-14949.3	3
-14960.3	3
-14971.2	4
-14982.2	3
-14993.2	3
-15004.1	3
-15015.1	3
-15026.1	3
-15037	4
-15048	4
-15059	3
-15069.9	3
-15080.9	4
-15091.9	4
-15102.8	3
-15113.8	3
-15124.8	3
-15135.7	3
-15146.7	3
-15157.7	3
-15168.6	4
-15179.6	4
-15190.6	4
-15201.6	3
-15212.5	4
-15223.5	3
-15234.5	3
-15245.4	4
-15256.4	4
-15267.4	3
-15278.3	4
-15289.3	4
-15300.3	3
-15311.2	3
-15322.2	3
-15333.2	3
-15344.1	4
-15355.1	4
-15366.1	3
-15377	3
-15388	3
-15399	3
-15409.9	3
-15420.9	4
-15431.9	3
-15442.8	4
-15453.8	3
-15464.8	3
-15475.7	3
-15486.7	3
-15497.7	3
-15508.7	3
-15519.6	3
-15530.6	3
-15541.6	3
-15552.5	3
-15563.5	3
-15574.5	3
-15585.4	3
-15596.4	3
-15607.4	3
-15618.3	3
-15629.3	3
-15640.3	4
-15651.2	3
-15662.2	3
-15673.2	3
-15684.1	3
-15695.1	4
-15706.1	3
-15717	3
-15728	3
-15739	4
-15749.9	4
-15760.9	3
-15771.9	3
-15782.9	3
-15793.8	4
-15804.8	3
-15815.8	4
-15826.7	3
-15837.7	3
-15848.7	3
-15859.6	4
-15870.6	3
-15881.6	3
-15892.5	4
-15903.5	3
-15914.5	3
-15925.4	4
-15936.4	3
-15947.4	3
-15958.3	3
-15969.3	4
-15980.3	4
-15991.2	3
-16002.2	3
-16013.2	3
-16024.1	3
-16035.1	4
-16046.1	3
-16057	3
-16068	3
-16079	4
-16090	4
-16100.9	3
-16111.9	3
-16122.9	4
-16133.8	4
-16144.8	4
-16155.8	4
-16166.7	4
-16177.7	4
-16188.7	4
-16199.6	4
-16210.6	4
-16221.6	4
-16232.5	4
-16243.5	4
-16254.5	4
-16265.4	4
-16276.4	4
-16287.4	4
-16298.3	4
-16309.3	4
-16320.3	4
-16331.2	5
-16342.2	5
-16353.2	5
-16364.2	5
-16375.1	5
-16386.1	5
-16397.1	6
-16408	5
-16419	5
-16430	6
-16440.9	5
-16451.9	5
-16462.9	5
-16473.8	6
-16484.8	5
-16495.8	5
-16506.7	5
-16517.7	5
-16528.7	5
-16539.6	5
-16550.6	5
-16561.6	5
-16572.5	5
-16583.5	5
-16594.5	5
-16605.4	5
-16616.4	5
-16627.4	5
-16638.3	5
-16649.3	6
-16660.3	5
-16671.3	5
-16682.2	6
-16693.2	5
-16704.2	6
-16715.1	5
-16726.1	5
-16737.1	5
-16748	5
-16759	5
-16770	5
-16780.9	5
-16791.9	5
-16802.9	5
-16813.8	5
-16824.8	5
-16835.8	5
-16846.7	5
-16857.7	5
-16868.7	5
-16879.6	5
-16890.6	5
-16901.6	5
-16912.5	6
-16923.5	5
-16934.5	5
-16945.5	5
-16956.4	5
-16967.4	5
-16978.4	5
-16989.3	5
-17000.3	5
-17011.3	5
-17022.2	5
-17033.2	5
-17044.2	5
-17055.1	5
-17066.1	5
-17077.1	5
-17088	5
-17099	5
-17110	5
-17120.9	5
-17131.9	6
-17142.9	5
-17153.8	5
-17164.8	6
-17175.8	5
-17186.7	6
-17197.7	5
-17208.7	5
-17219.7	5
-17230.6	5
-17241.6	5
-17252.6	5
-17263.5	6
-17274.5	5
-17285.5	5
-17296.4	5
-17307.4	5
-17318.4	5
-17329.3	5
-17340.3	5
-17351.3	5
-17362.2	5
-17373.2	6
-17384.2	6
-17395.1	5
-17406.1	5
-17417.1	6
-17428	5
-17439	6
-17450	5
-17460.9	5
-17471.9	5
-17482.9	5
-17493.8	5
-17504.8	6
-17515.8	5
-17526.8	6
-17537.7	6
-17548.7	5
-17559.7	5
-17570.6	6
-17581.6	6
-17592.6	6
-17603.5	6
-17614.5	6
-17625.5	5
-17636.4	6
-17647.4	6
-17658.4	6
-17669.3	6
-17680.3	6
-17691.3	5
-17702.2	6
-17713.2	6
-17724.2	6
-17735.1	6
-17746.1	6
-17757.1	6
-17768	5
-17779	6
-17790	6
-17801	6
-17811.9	6
-17822.9	6
-17833.9	5
-17844.8	6
-17855.8	6
-17866.8	6
-17877.7	6
-17888.7	6
-17899.7	6
-17910.6	9
-17921.6	8
-17932.6	10
-17943.5	9
-17954.5	9
-17965.5	9
-17976.4	9
-17987.4	10
-17998.4	9
-18009.3	10
-18020.3	9
-18031.3	9
-18042.2	10
-18053.2	9
-18064.2	9
-18075.1	9
-18086.1	9
-18097.1	9
-18108.1	10
-18119	10
-18130	9
-18141	9
-18151.9	8
-18162.9	9
-18173.9	9
-18184.8	9
-18195.8	9
-18206.8	9
-18217.7	9
-18228.7	9
-18239.7	9
-18250.6	9
-18261.6	9
-18272.6	10
-18283.5	10
-18294.5	9
-18305.5	10
-18316.4	10
-18327.4	9
-18338.4	9
-18349.3	9
-18360.3	10
-18371.3	10
-18382.3	9
-18393.2	10
-18404.2	9
-18415.2	10
-18426.1	10
-18437.1	9
-18448.1	10
-18459	10
-18470	9
-18481	10
-18491.9	10
-18502.9	9
-18513.9	9
-18524.8	9
-18535.8	9
-18546.8	10
-18557.7	10
-18568.7	9
-18579.7	10
-18590.6	10
-18601.6	9
-18612.6	9
-18623.5	9
-18634.5	10
-18645.5	10
-18656.4	10
-18667.4	10
-18678.4	10
-18689.4	10
-18700.3	10
-18711.3	10
-18722.3	10
-18733.2	10
-18744.2	10
-18755.2	10
-18766.1	10
-18777.1	10
-18788.1	10
-18799	10
-18810	10
-18821	10
-18831.9	10
-18842.9	10
-18853.9	10
-18864.8	9
-18875.8	9
-18886.8	10
-18897.7	9
-18908.7	9
-18919.7	10
-18930.6	10
-18941.6	10
-18952.6	10
-18963.6	10
-18974.5	10
-18985.5	10
-18996.5	10
-19007.4	10
-19018.4	10
-19029.4	10
-19040.3	10
-19051.3	10
-19062.3	10
-19073.2	10
-19084.2	10
-19095.2	10
-19106.1	10
-19117.1	10
-19128.1	10
-19139	10
-19150	10
-19161	10
-19171.9	10
-19182.9	10
-19193.9	10
-19204.8	10
-19215.8	10
-19226.8	10
-19237.7	10
-19248.7	10
-19259.7	10
-19270.7	10
-19281.6	10
-19292.6	10
-19303.6	10
-19314.5	10
-19325.5	10
-19336.5	10
-19347.4	10
-19358.4	10
-19369.4	10
-19380.3	10
-19391.3	10
-19402.3	10
-19413.2	10
-19424.2	10
-19435.2	10
-19446.1	10
-19457.1	10
-19468.1	10
-19479	10
-19490	10
-19501	10
-19511.9	10
-19522.9	10
-19533.9	10
-19544.9	10
-19555.8	10
-19566.8	10
-19577.8	10
-19588.7	11
-19599.7	11
-19610.7	11
-19621.6	11
-19632.6	11
-19643.6	11
-19654.5	12
-19665.5	11
-19676.5	11
-19687.4	11
-19698.4	11
-19709.4	11
-19720.3	11
-19731.3	11
-19742.3	11
-19753.2	11
-19764.2	11
-19775.2	11
-19786.1	12
-19797.1	11
-19808.1	11
-19819	12
-19830	12
-19841	11
-19852	11
-19862.9	11
-19873.9	11
-19884.9	11
-19895.8	11
-19906.8	11
-19917.8	11
-19928.7	11
-19939.7	11
-19950.7	11
-19961.6	11
-19972.6	11
-19983.6	11
-19994.5	11
-20005.5	11
-20016.5	11
-20027.4	11
-20038.4	11
-20049.4	11
-20060.3	11
-20071.3	12
-20082.3	11
-20093.2	12
-20104.2	11
-20115.2	11
-20126.2	11
-20137.1	12
-20148.1	11
-20159.1	11
-20170	11
-20181	11
-20192	11
-20202.9	11
-20213.9	11
-20224.9	11
-20235.8	11
-20246.8	11
-20257.8	11
-20268.7	11
-20279.7	11
-20290.7	11
-20301.6	11
-20312.6	11
-20323.6	11
-20334.5	11
-20345.5	11
-20356.5	11
-20367.4	12
-20378.4	12
-20389.4	11
-20400.3	12
-20411.3	11
-20422.3	11
-20433.3	11
-20444.2	11
-20455.2	11
-20466.2	11
-20477.1	11
-20488.1	11
-20499.1	11
-20510	11
-20521	11
-20532	11
-20542.9	11
-20553.9	11
-20564.9	11
-20575.8	11
-20586.8	12
-20597.8	11
-20608.7	11
-20619.7	11
-20630.7	11
-20641.6	11
-20652.6	11
-20663.6	12
-20674.5	12
-20685.5	12
-20696.5	11
-20707.5	11
-20718.4	11
-20729.4	11
-20740.4	12
-20751.3	11
-20762.3	11
-20773.3	11
-20784.2	11
-20795.2	11
-20806.2	11
-20817.1	11
-20828.1	11
-20839.1	12
-20850	12
-20861	11
-20872	12
-20882.9	11
-20893.9	12
-20904.9	12
-20915.8	11
-20926.8	12
-20937.8	12
-20948.7	12
-20959.7	11
-20970.7	11
-20981.7	11
-20992.6	11
-21003.6	11
-21014.6	11
-21025.5	12
-21036.5	11
-21047.5	11
-21058.4	11
-21069.4	11
-21080.4	11
-21091.3	11
-21102.3	11
-21113.3	11
-21124.2	11
-21135.2	11
-21146.2	11
-21157.1	11
-21168.1	11
-21179.1	11
-21190	11
-21201	11
-21212	12
-21222.9	12
-21233.9	12
-21244.9	12
-21255.8	11
-21266.8	11
-21277.8	11
-21288.8	12
-21299.7	11
-21310.7	11
-21321.7	11
-21332.6	12
-21343.6	12
-21354.6	12
-21365.5	11
-21376.5	11
-21387.5	11
-21398.4	11
-21409.4	11
-21420.4	11
-21431.3	11
-21442.3	11
-21453.3	11
-21464.2	11
-21475.2	12
-21486.2	11
-21497.1	11
-21508.1	11
-21519.1	11
-21530	11
-21541	11
-21552	11
-21563	11
-21573.9	11
-21584.9	12
-21595.9	11
-21606.8	12
-21617.8	11
-21628.8	12
-21639.7	11
-21650.7	12
-21661.7	12
-21672.6	12
-21683.6	12
-21694.6	11
-21705.5	11
-21716.5	11
-21727.5	11
-21738.4	12
-21749.4	11
-21760.4	11
-21771.3	11
-21782.3	11
-21793.3	11
-21804.2	11
-21815.2	11
-21826.2	11
-21837.1	11
-21848.1	12
-21859.1	11
-21870.1	11
-21881	11
-21892	11
-21903	11
-21913.9	12
-21924.9	11
-21935.9	11
-21946.8	11
-21957.8	12
-21968.8	11
-21979.7	11
-21990.7	11
-22001.7	11
-22012.6	11
-22023.6	11
-22034.6	12
-22045.5	11
-22056.5	11
-22067.5	11
-22078.4	11
-22089.4	11
-22100.4	11
-22111.3	12
-22122.3	12
-22133.3	12
-22144.3	12
-22155.2	11
-22166.2	11
-22177.2	11
-22188.1	12
-22199.1	11
-22210.1	11
-22221	11
-22232	12
-22243	12
-22253.9	11
-22264.9	11
-22275.9	11
-22286.8	12
-22297.8	11
-22308.8	12
-22319.7	11
-22330.7	11
-22341.7	11
-22352.6	11
-22363.6	11
-22374.6	11
-22385.5	11
-22396.5	11
-22407.5	11
-22418.4	11
-22429.4	11
-22440.4	11
-22451.4	11
-22462.3	11
-22473.3	11
-22484.3	11
-22495.2	11
-22506.2	11
-22517.2	11
-22528.1	11
-22539.1	11
-22550.1	11
-22561	11
-22572	11
-22583	11
-22593.9	12
-22604.9	11
-22615.9	11
-22626.8	12
-22637.8	11
-22648.8	11
-22659.7	11
-22670.7	11
-22681.7	12
-22692.6	11
-22703.6	11
-22714.6	12
-22725.6	11
-22736.5	11
-22747.5	12
-22758.5	11
-22769.4	11
-22780.4	11
-22791.4	12
-22802.3	11
-22813.3	11
-22824.3	11
-22835.2	11
-22846.2	11
-22857.2	11
-22868.1	12
-22879.1	11
-22890.1	12
-22901	12
-22912	12
-22923	12
-22933.9	13
-22944.9	14
-22955.9	13
-22966.8	13
-22977.8	14
-22988.8	14
-22999.7	13
-23010.7	13
-23021.7	13
-23032.7	13
-23043.6	13
-23054.6	13
-23065.6	13
-23076.5	13
-23087.5	13
-23098.5	14
-23109.4	14
-23120.4	13
-23131.4	13
-23142.3	13
-23153.3	13
-23164.3	13
-23175.2	13
-23186.2	14
-23197.2	13
-23208.1	13
-23219.1	13
-23230.1	14
-23241	14
-23252	13
-23263	14
-23273.9	13
-23284.9	13
-23295.9	13
-23306.9	13
-23317.8	13
-23328.8	14
-23339.8	13
-23350.7	13
-23361.7	13
-23372.7	14
-23383.6	13
-23394.6	13
-23405.6	13
-23416.5	13
-23427.5	14
-23438.5	13
-23449.4	13
-23460.4	13
-23471.4	13
-23482.3	13
-23493.3	13
-23504.3	13
-23515.2	13
-23526.2	13
-23537.2	13
-23548.1	13
-23559.1	14
-23570.1	13
-23581	14
-23592	14
-23603	14
-23614	14
-23624.9	14
-23635.9	13
-23646.9	13
-23657.8	14
-23668.8	13
-23679.8	13
-23690.7	13
-23701.7	13
-23712.7	13
-23723.6	13
-23734.6	13
-23745.6	13
-23756.5	13
-23767.5	14
-23778.5	14
-23789.4	14
-23800.4	14
-23811.4	13
-23822.3	13
-23833.3	14
-23844.3	13
-23855.2	13
-23866.2	14
-23877.2	13
-23888.2	14
-23899.1	13
-23910.1	14
-23921.1	14
-23932	13
-23943	14
-23954	13
-23964.9	13
-23975.9	13
-23986.9	14
-23997.8	14
-24008.8	13
-24019.8	14
-24030.7	13
-24041.7	14
-24052.7	13
-24063.6	13
-24074.6	13
-24085.6	13
-24096.5	14
-24107.5	14
-24118.5	13
-24129.4	14
-24140.4	14
-24151.4	14
-24162.3	14
-24173.3	13
-24184.3	14
-24195.3	14
-24206.2	14
-24217.2	14
-24228.2	14
-24239.1	14
-24250.1	14
-24261.1	14
-24272	14
-24283	14
-24294	14
-24304.9	14
-24315.9	14
-24326.9	14
-24337.8	14
-24348.8	14
-24359.8	14
-24370.7	14
-24381.7	14
-24392.7	14
-24403.6	14
-24414.6	14
-24425.6	14
-24436.5	14
-24447.5	14
-24458.5	14
-24469.5	14
-24480.4	14
-24491.4	14
-24502.4	14
-24513.3	14
-24524.3	14
-24535.3	14
-24546.2	14
-24557.2	14
-24568.2	14
-24579.1	14
-24590.1	14
-24601.1	14
-24612	14
-24623	14
-24634	14
-24644.9	14
-24655.9	14
-24666.9	14
-24677.8	12
-24688.8	10
-24699.8	10
-24710.7	11
-24721.7	12
-24732.7	11
-24743.7	11
-24754.6	11
-24765.6	11
-24776.6	11
-24787.5	11
-24798.5	11
-24809.5	11
-24820.4	11
-24831.4	11
-24842.4	11
-24853.3	11
-24864.3	12
-24875.3	12
-24886.2	12
-24897.2	12
-24908.2	12
-24919.1	12
-24930.1	12
-24941.1	12
-24952	12
-24963	12
-24974	12
-24984.9	12
-24995.9	12
-25006.9	12
-25017.8	12
-25028.8	12
-25039.8	12
-25050.8	12
-25061.7	12
-25072.7	12
-25083.7	12
-25094.6	12
-25105.6	12
-25116.6	12
-25127.5	12
-25138.5	12
-25149.5	12
-25160.4	12
-25171.4	12
-25182.4	12
-25193.3	12
-25204.3	12
-25215.3	12
-25226.2	12
-25237.2	12
-25248.2	12
-25259.1	12
-25270.1	12
-25281.1	12
-25292	12
-25303	12
-25314	12
-25325	12
-25335.9	12
-25346.9	12
-25357.9	12
-25368.8	12
-25379.8	12
-25390.8	12
-25401.7	12
-25412.7	12
-25423.7	12
-25434.6	12
-25445.6	12
-25456.6	12
-25467.5	12
-25478.5	12
-25489.5	12
-25500.4	12
-25511.4	12
-25522.4	12
-25533.3	12
-25544.3	12
-25555.3	12
-25566.2	12
-25577.2	12
-25588.2	12
-25599.1	12
-25610.1	12
-25621.1	13
-25632.1	14
-25643	14
-25654	14
-25665	14
-25675.9	14
-25686.9	15
-25697.9	15
-25708.8	15
-25719.8	15
-25730.8	15
-25741.7	15
-25752.7	16
-25763.7	15
-25774.6	15
-25785.6	15
-25796.6	15
-25807.5	15
-25818.5	15
-25829.5	15
-25840.4	15
-25851.4	15
-25862.4	16
-25873.3	15
-25884.3	15
-25895.3	15
-25906.3	15
-25917.2	15
-25928.2	15
-25939.2	15
-25950.1	15
-25961.1	15
-25972.1	16
-25983	15
-25994	15
-26005	15
-26015.9	15
-26026.9	15
-26037.9	15
-26048.8	15
-26059.8	15
-26070.8	15
-26081.7	15
-26092.7	15
-26103.7	15
-26114.6	15
-26125.6	15
-26136.6	15
-26147.5	15
-26158.5	15
-26169.5	15
-26180.4	16
-26191.4	15
-26202.4	15
-26213.4	15
-26224.3	15
-26235.3	15
-26246.3	15
-26257.2	15
-26268.2	15
-26279.2	15
-26290.1	15
-26301.1	15
-26312.1	15
-26323	15
-26334	15
-26345	15
-26355.9	15
-26366.9	15
-26377.9	15
-26388.8	15
-26399.8	15
-26410.8	15
-26421.7	15
-26432.7	15
-26443.7	15
-26454.6	15
-26465.6	15
-26476.6	15
-26487.6	15
-26498.5	15
-26509.5	15
-26520.5	15
-26531.4	15
-26542.4	15
-26553.4	15
-26564.3	15
-26575.3	15
-26586.3	15
-26597.2	15
-26608.2	15
-26619.2	15
-26630.1	15
-26641.1	15
-26652.1	15
-26663	15
-26674	15
-26685	15
-26695.9	15
-26706.9	16
-26717.9	15
-26728.8	15
-26739.8	15
-26750.8	15
-26761.7	16
-26772.7	16
-26783.7	15
-26794.7	15
-26805.6	15
-26816.6	15
-26827.6	15
-26838.5	16
-26849.5	15
-26860.5	15
-26871.4	15
-26882.4	15
-26893.4	15
-26904.3	16
-26915.3	15
-26926.3	15
-26937.2	16
-26948.2	15
-26959.2	15
-26970.1	15
-26981.1	15
-26992.1	15
-27003	15
-27014	15
-27025	16
-27035.9	16
-27046.9	15
-27057.9	15
-27068.9	15
-27079.8	15
-27090.8	15
-27101.8	15
-27112.7	15
-27123.7	15
-27134.7	15
-27145.6	15
-27156.6	15
-27167.6	15
-27178.5	15
-27189.5	15
-27200.5	15
-27211.4	15
-27222.4	15
-27233.4	15
-27244.3	15
-27255.3	15
-27266.3	15
-27277.2	15
-27288.2	15
-27299.2	15
-27310.1	15
-27321.1	15
-27332.1	15
-27343	15
-27354	15
-27365	15
-27376	15
-27386.9	16
-27397.9	16
-27408.9	16
-27419.8	16
-27430.8	16
-27441.8	16
-27452.7	14
-27463.7	14
-27474.7	15
-27485.6	16
-27496.6	16
-27507.6	16
-27518.5	16
-27529.5	16
-27540.5	16
-27551.4	17
-27562.4	18
-27573.4	18
-27584.3	18
-27595.3	18
-27606.3	18
-27617.2	18
-27628.2	18
-27639.2	18
-27650.2	18
-27661.1	18
-27672.1	18
-27683.1	18
-27694	18
-27705	18
-27716	18
-27726.9	18
-27737.9	18
-27748.9	18
-27759.8	18
-27770.8	18
-27781.8	18
-27792.7	18
-27803.7	18
-27814.7	18
-27825.6	18
-27836.6	18
-27847.6	18
-27858.5	18
-27869.5	18
-27880.5	18
-27891.4	18
-27902.4	18
-27913.4	14
-27924.3	14
-27935.3	14
-27946.3	14
-27957.3	13
-27968.2	13
-27979.2	13
-27990.2	13
-28001.1	13
-28012.1	13
-28023.1	13
-28034	14
-28045	14
-28056	13
-28066.9	14
-28077.9	13
-28088.9	13
-28099.8	13
-28110.8	13
-28121.8	14
-28132.7	14
-28143.7	14
-28154.7	14
-28165.6	14
-28176.6	13
-28187.6	13
-28198.5	14
-28209.5	14
-28220.5	14
-28231.5	13
-28242.4	14
-28253.4	14
-28264.4	14
-28275.3	14
-28286.3	14
-28297.3	14
-28308.2	14
-28319.2	14
-28330.2	14
-28341.1	14
-28352.1	14
-28363.1	14
-28374	14
-28385	14
-28396	14
-28406.9	14
-28417.9	14
-28428.9	14
-28439.8	14
-28450.8	14
-28461.8	14
-28472.7	14
-28483.7	14
-28494.7	14
-28505.7	14
-28516.6	14
-28527.6	14
-28538.6	14
-28549.5	14
-28560.5	14
-28571.5	14
-28582.4	14
-28593.4	14
-28604.4	14
-28615.3	14
-28626.3	14
-28637.3	14
-28648.2	14
-28659.2	14
-28670.2	14
-28681.1	14
-28692.1	14
-28703.1	14
-28714	14
-28725	14
-28736	14
-28746.9	14
-28757.9	14
-28768.9	14
-28779.8	14
-28790.8	15
-28801.8	17
-28812.8	18
-28823.7	17
-28834.7	17
-28845.7	17
-28856.6	17
-28867.6	17
-28878.6	18
-28889.5	17
-28900.5	17
-28911.5	17
-28922.4	17
-28933.4	17
-28944.4	18
-28955.3	17
-28966.3	17
-28977.3	17
-28988.2	17
-28999.2	18
-29010.2	18
-29021.1	17
-29032.1	18
-29043.1	17
-29054	17
-29065	17
-29076	18
-29087	18
-29097.9	17
-29108.9	18
-29119.9	18
-29130.8	17
-29141.8	17
-29152.8	18
-29163.7	17
-29174.7	18
-29185.7	18
-29196.6	18
-29207.6	17
-29218.6	17
-29229.5	18
-29240.5	18
-29251.5	17
-29262.4	17
-29273.4	17
-29284.4	17
-29295.3	18
-29306.3	17
-29317.3	18
-29328.2	17
-29339.2	17
-29350.2	18
-29361.1	17
-29372.1	17
-29383.1	17
-29394.1	17
-29405	17
-29416	17
-29427	18
-29437.9	17
-29448.9	17
-29459.9	18
-29470.8	18
-29481.8	17
-29492.8	18
-29503.7	17
-29514.7	18
-29525.7	16
-29536.6	17
-29547.6	18
-29558.6	17
-29569.5	17
-29580.5	17
-29591.5	17
-29602.4	18
-29613.4	17
-29624.4	17
-29635.3	18
-29646.3	18
-29657.3	17
-29668.3	17
-29679.2	17
-29690.2	18
-29701.2	17
-29712.1	18
-29723.1	17
-29734.1	18
-29745	17
-29756	17
-29767	17
-29777.9	18
-29788.9	17
-29799.9	18
-29810.8	17
-29821.8	18
-29832.8	18
-29843.7	17
-29854.7	17
-29865.7	17
-29876.6	17
-29887.6	16
-29898.6	18
-29909.5	17
-29920.5	17
-29931.5	18
-29942.4	17
-29953.4	17
-29964.4	17
-29975.4	18
-29986.3	18
-29997.3	17
-30008.3	17
-30019.2	17
-30030.2	17
-30041.2	18
-30052.1	17
-30063.1	18
-30074.1	17
-30085	17
-30096	18
-30107	18
-30117.9	17
-30128.9	18
-30139.9	17
-30150.8	18
-30161.8	17
-30172.8	18
-30183.7	17
-30194.7	18
-30205.7	17
-30216.6	17
-30227.6	17
-30238.6	18
-30249.6	17
-30260.5	17
-30271.5	17
-30282.5	18
-30293.4	17
-30304.4	18
-30315.4	18
-30326.3	18
-30337.3	18
-30348.3	17
-30359.2	18
-30370.2	18
-30381.2	17
-30392.1	17
-30403.1	17
-30414.1	17
-30425	17
-30436	18
-30447	17
-30457.9	17
-30468.9	18
-30479.9	17
-30490.8	18
-30501.8	18
-30512.8	17
-30523.7	17
-30534.7	17
-30545.7	17
-30556.7	17
-30567.6	17
-30578.6	17
-30589.6	17
-30600.5	18
-30611.5	17
-30622.5	17
-30633.4	17
-30644.4	17
-30655.4	18
-30666.3	17
-30677.3	17
-30688.3	18
-30699.2	17
-30710.2	17
-30721.2	17
-30732.1	18
-30743.1	17
-30754.1	18
-30765	18
-30776	18
-30787	17
-30797.9	17
-30808.9	17
-30819.9	18
-30830.9	17
-30841.8	18
-30852.8	18
-30863.8	18
-30874.7	17
-30885.7	18
-30896.7	17
-30907.6	18
-30918.6	17
-30929.6	17
-30940.5	17
-30951.5	17
-30962.5	18
-30973.4	18
-30984.4	17
-30995.4	18
-31006.3	17
-31017.3	17
-31028.3	18
-31039.2	17
-31050.2	17
-31061.2	17
-31072.1	17
-31083.1	18
-31094.1	17
-31105	17
-31116	18
-31127	17
-31138	17
-31148.9	17
-31159.9	17
-31170.9	18
-31181.8	17
-31192.8	18
-31203.8	17
-31214.7	18
-31225.7	17
-31236.7	17
-31247.6	17
-31258.6	18
-31269.6	18
-31280.5	18
-31291.5	18
-31302.5	17
-31313.4	17
-31324.4	17
-31335.4	17
-31346.3	17
-31357.3	17
-31368.3	17
-31379.2	18
-31390.2	17
-31401.2	17
-31412.2	17
-31423.1	17
-31434.1	18
-31445.1	17
-31456	17
-31467	18
-31478	17
-31488.9	17
-31499.9	18
-31510.9	17
-31521.8	18
-31532.8	17
-31543.8	18
-31554.7	17
-31565.7	18
-31576.7	17
-31587.6	18
-31598.6	18
-31609.6	18
-31620.5	18
-31631.5	18
-31642.5	17
-31653.4	18
-31664.4	18
-31675.4	17
-31686.3	17
-31697.3	18
-31708.3	17
-31719.3	17
-31730.2	17
-31741.2	17
-31752.2	17
-31763.1	18
-31774.1	18
-31785.1	18
-31796	18
-31807	17
-31818	17
-31828.9	17
-31839.9	17
-31850.9	17
-31861.8	17
-31872.8	17
-31883.8	18
-31894.7	17
-31905.7	17
-31916.7	17
-31927.6	18
-31938.6	18
-31949.6	18
-31960.5	18
-31971.5	18
-31982.5	18
-31993.5	17
-32004.4	16
-32015.4	16
-32026.4	16
-32037.3	16
-32048.3	16
-32059.3	16
-32070.2	16
-32081.2	16
-32092.2	16
-32103.1	16
-32114.1	16
-32125.1	16
-32136	16
-32147	16
-32158	16
-32168.9	16
-32179.9	16
-32190.9	16
-32201.8	16
-32212.8	16
-32223.8	16
-32234.7	16
-32245.7	16
-32256.7	16
-32267.7	16
-32278.6	16
-32289.6	16
-32300.6	16
-32311.5	16
-32322.5	15
-32333.5	16
-32344.4	16
-32355.4	15
-32366.4	16
-32377.3	16
-32388.3	16
-32399.3	15
-32410.2	15
-32421.2	16
-32432.2	15
-32443.1	16
-32454.1	15
-32465.1	15
-32476	15
-32487	15
-32498	16
-32508.9	15
-32519.9	15
-32530.9	15
-32541.8	15
-32552.8	15
-32563.8	16
-32574.8	16
-32585.7	16
-32596.7	16
-32607.7	16
-32618.6	16
-32629.6	16
-32640.6	16
-32651.5	16
-32662.5	16
-32673.5	16
-32684.4	16
-32695.4	14
-32706.4	14
-32717.3	14
-32728.3	14
-32739.3	14
-32750.2	14
-32761.2	14
-32772.2	14
-32783.1	14
-32794.1	14
-32805.1	14
-32816	14
-32827	14
-32838	14
-32849	14
-32859.9	14
-32870.9	14
-32881.9	14
-32892.8	14
-32903.8	13
-32914.8	14
-32925.7	14
-32936.7	14
-32947.7	13
-32958.6	13
-32969.6	13
-32980.6	14
-32991.5	13
-33002.5	13
-33013.5	13
-33024.4	13
-33035.4	14
-33046.4	13
-33057.3	13
-33068.3	14
-33079.3	13
-33090.2	13
-33101.2	13
-33112.2	14
-33123.1	14
-33134.1	13
-33145.1	14
-33156.1	13
-33167	13
-33178	13
-33189	14
-33199.9	13
-33210.9	13
-33221.9	13
-33232.8	13
-33243.8	13
-33254.8	13
-33265.7	13
-33276.7	13
-33287.7	13
-33298.6	14
-33309.6	13
-33320.6	14
-33331.5	14
-33342.5	14
-33353.5	14
-33364.4	13
-33375.4	14
-33386.4	13
-33397.3	14
-33408.3	13
-33419.3	13
-33430.3	13
-33441.2	14
-33452.2	13
-33463.2	14
-33474.1	13
-33485.1	13
-33496.1	14
-33507	14
-33518	14
-33529	14
-33539.9	14
-33550.9	14
-33561.9	14
-33572.8	14
-33583.8	14
-33594.8	14
-33605.7	14
-33616.7	14
-33627.7	14
-33638.6	14
-33649.6	14
-33660.6	14
-33671.5	14
-33682.5	14
-33693.5	14
-33704.4	14
-33715.4	14
-33726.4	14
-33737.4	14
-33748.3	14
-33759.3	14
-33770.3	14
-33781.2	14
-33792.2	14
-33803.2	14
-33814.1	14
-33825.1	14
-33836.1	14
-33847	14
-33858	14
-33869	14
-33879.9	14
-33890.9	14
-33901.9	13
-33912.8	12
-33923.8	12
-33934.8	12
-33945.7	12
-33956.7	12
-33967.7	12
-33978.6	12
-33989.6	12
-34000.6	12
-34011.6	12
-34022.5	12
-34033.5	12
-34044.5	12
-34055.4	12
-34066.4	12
-34077.4	12
-34088.3	12
-34099.3	12
-34110.3	12
-34121.2	12
-34132.2	12
-34143.2	12
-34154.1	12
-34165.1	12
-34176.1	12
-34187	12
-34198	12
-34209	12
-34219.9	12
-34230.9	12
-34241.9	12
-34252.8	12
-34263.8	12
-34274.8	12
-34285.7	12
-34296.7	12
-34307.7	12
-34318.7	12
-34329.6	12
-34340.6	12
-34351.6	12
-34362.5	12
-34373.5	12
-34384.5	12
-34395.4	12
-34406.4	12
-34417.4	12
-34428.3	12
-34439.3	12
-34450.3	12
-34461.2	12
-34472.2	12
-34483.2	12
-34494.1	12
-34505.1	12
-34516.1	12
-34527	12
-34538	12
-34549	12
-34559.9	12
-34570.9	12
-34581.9	12
-34592.9	12
-34603.8	12
-34614.8	12
-34625.8	12
-34636.7	12
-34647.7	12
-34658.7	12
-34669.6	11
-34680.6	10
-34691.6	10
-34702.5	10
-34713.5	10
-34724.5	9
-34735.4	8
-34746.4	8
-34757.4	8
-34768.3	8
-34779.3	8
-34790.3	8
-34801.2	8
-34812.2	8
-34823.2	8
-34834.1	8
-34845.1	8
-34856.1	8
-34867	8
-34878	8
-34889	8
-34900	8
-34910.9	8
-34921.9	8
-34932.9	8
-34943.8	8
-34954.8	8
-34965.8	8
-34976.7	8
-34987.7	8
-34998.7	7
-35009.6	6
-35020.6	6
-35031.6	6
-35042.5	6
-35053.5	6
-35064.5	5
-35075.4	4
-35086.4	4
-35097.4	4
-35108.3	4
-35119.3	4
-35130.3	4
-35141.2	4
-35152.2	4
-35163.2	4
-35174.2	4
-35185.1	4
-35196.1	4
-35207.1	4
-35218	4
-35229	4
-35240	4
-35250.9	4
-35261.9	4
-35272.9	4
-35283.8	4
-35294.8	4
-35305.8	4
-35316.7	4
-35327.7	4
-35338.7	4
-35349.6	4
-35360.6	4
-35371.6	4
-35382.5	4
-35393.5	4
-35404.5	4
-35415.4	4
-35426.4	4
-35437.4	4
-35448.3	4
-35459.3	4
-35470.3	4
-35481.3	4
-35492.2	4
-35503.2	4
-35514.2	4
-35525.1	4
-35536.1	4
-35547.1	4
-35558	4
-35569	4
-35580	4
-35590.9	4
-35601.9	4
-35612.9	4
-35623.8	4
-35634.8	4
-35645.8	4
-35656.7	4
-35667.7	4
-35678.7	4
-35689.6	4
-35700.6	4
-35711.6	4
-35722.5	4
-35733.5	4
-35744.5	4
-35755.5	4
-35766.4	4
-35777.4	4
-35788.4	4
-35799.3	4
-35810.3	4
-35821.3	4
-35832.2	4
-35843.2	4
-35854.2	4
-35865.1	4
-35876.1	4
-35887.1	4
-35898	4
-35909	4
-35920	4
-35930.9	4
-35941.9	4
-35952.9	4
-35963.8	4
-35974.8	4
-35985.8	4
-35996.7	4
-36007.7	4
-36018.7	4
-36029.7	4
-36040.6	4
-36051.6	4
-36062.6	4
-36073.5	4
-36084.5	4
-36095.5	4
-36106.4	3
-36117.4	1
-36128.4	1
-36139.3	7
-36150.3	11
-36161.3	13
-36172.2	20
-36183.2	23
-36194.2	23
-36205.1	23
-36216.1	24
-36227.1	23
-36238	24
-36249	23
-36260	23
-36270.9	23
-36281.9	23
-36292.9	23
-36303.8	25
-36314.8	25
-36325.8	25
-36336.8	25
-36347.7	25
-36358.7	25
-36369.7	26
-36380.6	26
-36391.6	25
-36402.6	26
-36413.5	25
-36424.5	25
-36435.5	26
-36446.4	26
-36457.4	25
-36468.4	26
-36479.3	25
-36490.3	26
-36501.3	26
-36512.2	25
-36523.2	25
-36534.2	25
-36545.1	25
-36556.1	25
-36567.1	26
-36578	25
-36589	25
-36600	25
-36611	25
-36621.9	25
-36632.9	25
-36643.9	25
-36654.8	25
-36665.8	26
-36676.8	26
-36687.7	25
-36698.7	25
-36709.7	25
-36720.6	25
-36731.6	25
-36742.6	25
-36753.5	25
-36764.5	25
-36775.5	25
-36786.4	26
-36797.4	26
-36808.4	25
-36819.3	25
-36830.3	25
-36841.3	25
-36852.2	25
-36863.2	25
-36874.2	25
-36885.1	25
-36896.1	25
-36907.1	25
-36918.1	25
-36929	25
-36940	26
-36951	25
-36961.9	25
-36972.9	25
-36983.9	26
-36994.8	25
-37005.8	25
-37016.8	26
-37027.7	25
-37038.7	25
-37049.7	26
-37060.6	26
-37071.6	26
-37082.6	25
-37093.5	26
-37104.5	25
-37115.5	25
-37126.4	25
-37137.4	26
-37148.4	26
-37159.3	25
-37170.3	25
-37181.3	26
-37192.3	26
-37203.2	26
-37214.2	25
-37225.2	25
-37236.1	26
-37247.1	25
-37258.1	25
-37269	25
-37280	26
-37291	25
-37301.9	25
-37312.9	25
-37323.9	26
-37334.8	26
-37345.8	26
-37356.8	26
-37367.7	25
-37378.7	26
-37389.7	26
-37400.6	25
-37411.6	26
-37422.6	25
-37433.5	25
-37444.5	26
-37455.5	25
-37466.4	26
-37477.4	25
-37488.4	26
-37499.4	26
-37510.3	25
-37521.3	26
-37532.3	25
-37543.2	25
-37554.2	25
-37565.2	25
-37576.1	26
-37587.1	26
-37598.1	25
-37609	26
-37620	25
-37631	26
-37641.9	26
-37652.9	25
-37663.9	25
-37674.8	26
-37685.8	25
-37696.8	25
-37707.7	25
-37718.7	25
-37729.7	25
-37740.6	26
-37751.6	25
-37762.6	26
-37773.6	26
-37784.5	26
-37795.5	25
-37806.5	25
-37817.4	26
-37828.4	25
-37839.4	25
-37850.3	26
-37861.3	25
-37872.3	25
-37883.2	25
-37894.2	25
-37905.2	25
-37916.1	26
-37927.1	25
-37938.1	25
-37949	25
-37960	26
-37971	25
-37981.9	26
-37992.9	26
-38003.9	26
-38014.8	26
-38025.8	25
-38036.8	26
-38047.7	25
-38058.7	25
-38069.7	25
-38080.7	26
-38091.6	25
-38102.6	25
-38113.6	26
-38124.5	26
-38135.5	25
-38146.5	25
-38157.4	26
-38168.4	25
-38179.4	26
-38190.3	25
-38201.3	25
-38212.3	26
-38223.2	26
-38234.2	25
-38245.2	26
-38256.1	26
-38267.1	25
-38278.1	26
-38289	25
-38300	25
-38311	26
-38321.9	25
-38332.9	26
-38343.9	25
-38354.9	26
-38365.8	26
-38376.8	26
-38387.8	25
-38398.7	25
-38409.7	26
-38420.7	26
-38431.6	26
-38442.6	26
-38453.6	26
-38464.5	25
-38475.5	26
-38486.5	25
-38497.4	25
-38508.4	25
-38519.4	25
-38530.3	26
-38541.3	25
-38552.3	26
-38563.2	25
-38574.2	25
-38585.2	26
-38596.1	25
-38607.1	25
-38618.1	26
-38629	26
-38640	26
-38651	25
-38662	25
-38672.9	25
-38683.9	25
-38694.9	25
-38705.8	26
-38716.8	25
-38727.8	26
-38738.7	26
-38749.7	25
-38760.7	26
-38771.6	26
-38782.6	25
-38793.6	26
-38804.5	25
-38815.5	25
-38826.5	25
-38837.4	25
-38848.4	26
-38859.4	25
-38870.3	25
-38881.3	24
-38892.3	25
-38903.2	26
-38914.2	26
-38925.2	25
-38936.2	26
-38947.1	25
-38958.1	25
-38969.1	25
-38980	26
-38991	26
-39002	25
-39012.9	25
-39023.9	25
-39034.9	25
-39045.8	25
-39056.8	25
-39067.8	25
-39078.7	25
-39089.7	25
-39100.7	25
-39111.6	25
-39122.6	25
-39133.6	25
-39144.5	26
-39155.5	26
-39166.5	25
-39177.4	26
-39188.4	25
-39199.4	25
-39210.3	25
-39221.3	26
-39232.3	25
-39243.3	25
-39254.2	25
-39265.2	25
-39276.2	25
-39287.1	26
-39298.1	26
-39309.1	25
-39320	26
-39331	26
-39342	26
-39352.9	26
-39363.9	25
-39374.9	25
-39385.8	25
-39396.8	26
-39407.8	26
-39418.7	26
-39429.7	25
-39440.7	25
-39451.6	25
-39462.6	25
-39473.6	25
-39484.5	25
-39495.5	25
-39506.5	26
-39517.5	25
-39528.4	26
-39539.4	25
-39550.4	25
-39561.3	25
-39572.3	26
-39583.3	25
-39594.2	25
-39605.2	26
-39616.2	25
-39627.1	25
-39638.1	25
-39649.1	25
-39660	26
-39671	25
-39682	26
-39692.9	25
-39703.9	25
-39714.9	25
-39725.8	26
-39736.8	26
-39747.8	25
-39758.7	25
-39769.7	25
-39780.7	26
-39791.7	26
-39802.6	25
-39813.6	24
-39824.6	25
-39835.5	26
-39846.5	26
-39857.5	25
-39868.4	26
-39879.4	26
-39890.4	26
-39901.3	25
-39912.3	26
-39923.3	25
-39934.2	25
-39945.2	25
-39956.2	26
-39967.1	25
-39978.1	25
-39989.1	25
-40000	24
-40011	26
-40022	25
-40032.9	26
-40043.9	25
-40054.9	25
-40065.8	25
-40076.8	26
-40087.8	26
-40098.8	25
-40109.7	25
-40120.7	25
-40131.7	26
-40142.6	25
-40153.6	25
-40164.6	26
-40175.5	26
-40186.5	25
-40197.5	26
-40208.4	26
-40219.4	25
-40230.4	26
-40241.3	26
-40252.3	26
-40263.3	25
-40274.2	25
-40285.2	26
-40296.2	26
-40307.1	25
-40318.1	26
-40329.1	26
-40340	25
-40351	26
-40362	26
-40373	26
-40383.9	25
-40394.9	25
-40405.9	25
-40416.8	25
-40427.8	26
-40438.8	25
-40449.7	25
-40460.7	25
-40471.7	26
-40482.6	25
-40493.6	26
-40504.6	26
-40515.5	26
-40526.5	25
-40537.5	26
-40548.4	26
-40559.4	25
-40570.4	25
-40581.3	25
-40592.3	25
-40603.3	25
-40614.2	25
-40625.2	25
-40636.2	25
-40647.1	25
-40658.1	26
-40669.1	24
-40680.1	25
-40691	25
-40702	25
-40713	25
-40723.9	25
-40734.9	26
-40745.9	25
-40756.8	25
-40767.8	26
-40778.8	25
-40789.7	25
-40800.7	26
-40811.7	25
-40822.6	25
-40833.6	25
-40844.6	25
-40855.5	25
-40866.5	25
-40877.5	25
-40888.4	26
-40899.4	25
-40910.4	25
-40921.3	25
-40932.3	25
-40943.3	25
-40954.3	24
-40965.2	26
-40976.2	25
-40987.2	25
-40998.1	25
-41009.1	25
-41020.1	25
-41031	25
-41042	26
-41053	26
-41063.9	26
-41074.9	26
-41085.9	26
-41096.8	25
-41107.8	25
-41118.8	26
-41129.7	26
-41140.7	25
-41151.7	26
-41162.6	25
-41173.6	25
-41184.6	26
-41195.5	25
-41206.5	25
-41217.5	26
-41228.4	25
-41239.4	26
-41250.4	26
-41261.4	25
-41272.3	26
-41283.3	25
-41294.3	25
-41305.2	25
-41316.2	26
-41327.2	25
-41338.1	25
-41349.1	25
-41360.1	25
-41371	25
-41382	26
-41393	25
-41403.9	25
-41414.9	26
-41425.9	25
-41436.8	25
-41447.8	26
-41458.8	25
-41469.7	25
-41480.7	26
-41491.7	26
-41502.6	25
-41513.6	25
-41524.6	25
-41535.6	25
-41546.5	26
-41557.5	26
-41568.5	25
-41579.4	25
-41590.4	25
-41601.4	26
-41612.3	25
-41623.3	25
-41634.3	26
-41645.2	25
-41656.2	26
-41667.2	26
-41678.1	25
-41689.1	26
-41700.1	26
-41711	26
-41722	25
-41733	25
-41743.9	25
-41754.9	26
-41765.9	26
-41776.8	25
-41787.8	26
-41798.8	25
-41809.7	26
-41820.7	25
-41831.7	25
-41842.7	26
-41853.6	25
-41864.6	25
-41875.6	26
-41886.5	25
-41897.5	26
-41908.5	26
-41919.4	25
-41930.4	26
-41941.4	25
-41952.3	26
-41963.3	25
-41974.3	26
-41985.2	25
-41996.2	25
-42007.2	25
-42018.1	25
-42029.1	26
-42040.1	25
-42051	26
-42062	25
-42073	25
-42083.9	26
-42094.9	25
-42105.9	26
-42116.9	26
-42127.8	25
-42138.8	26
-42149.8	25
-42160.7	25
-42171.7	25
-42182.7	26
-42193.6	25
-42204.6	25
-42215.6	26
-42226.5	25
-42237.5	26
-42248.5	26
-42259.4	25
-42270.4	25
-42281.4	25
-42292.3	25
-42303.3	24
-42314.3	25
-42325.2	25
-42336.2	26
-42347.2	25
-42358.1	25
-42369.1	26
-42380.1	25
-42391	25
-42402	26
-42413	25
-42424	26
-42434.9	25
-42445.9	26
-42456.9	25
-42467.8	26
-42478.8	26
-42489.8	26
-42500.7	26
-42511.7	25
-42522.7	26
-42533.6	25
-42544.6	26
-42555.6	25
-42566.5	26
-42577.5	25
-42588.5	25
-42599.4	26
-42610.4	25
-42621.4	26
-42632.3	25
-42643.3	25
-42654.3	25
-42665.2	26
-42676.2	25
-42687.2	26
-42698.2	25
-42709.1	26
-42720.1	26
-42731.1	26
-42742	26
-42753	25
-42764	25
-42774.9	26
-42785.9	25
-42796.9	26
-42807.8	25
-42818.8	26
-42829.8	25
-42840.7	26
-42851.7	25
-42862.7	26
-42873.6	25
-42884.6	26
-42895.6	25
-42906.5	25
-42917.5	26
-42928.5	26
-42939.4	25
-42950.4	26
-42961.4	26
-42972.3	25
-42983.3	25
-42994.3	26
-43005.3	26
-43016.2	25
-43027.2	25
-43038.2	26
-43049.1	25
-43060.1	25
-43071.1	25
-43082	26
-43093	26
-43104	25
-43114.9	25
-43125.9	26
-43136.9	25
-43147.8	26
-43158.8	25
-43169.8	26
-43180.7	26
-43191.7	26
-43202.7	25
-43213.6	25
-43224.6	25
-43235.6	26
-43246.5	26
-43257.5	25
-43268.5	25
-43279.5	25
-43290.4	26
-43301.4	26
-43312.4	25
-43323.3	26
-43334.3	26
-43345.3	26
-43356.2	25
-43367.2	25
-43378.2	25
-43389.1	26
-43400.1	25
-43411.1	26
-43422	25
-43433	25
-43444	25
-43454.9	25
-43465.9	25
-43476.9	26
-43487.8	25
-43498.8	25
-43509.8	25
-43520.7	25
-43531.7	26
-43542.7	25
-43553.7	26
-43564.6	25
-43575.6	24
-43586.6	25
-43597.5	26
-43608.5	25
-43619.5	26
-43630.4	26
-43641.4	25
-43652.4	26
-43663.3	26
-43674.3	25
-43685.3	25
-43696.2	25
-43707.2	26
-43718.2	26
-43729.1	25
-43740.1	25
-43751.1	25
-43762	26
-43773	25
-43784	25
-43794.9	26
-43805.9	26
-43816.9	25
-43827.8	25
-43838.8	25
-43849.8	25
-43860.8	25
-43871.7	26
-43882.7	25
-43893.7	26
-43904.6	25
-43915.6	26
-43926.6	25
-43937.5	26
-43948.5	25
-43959.5	25
-43970.4	25
-43981.4	26
-43992.4	25
-44003.3	26
-44014.3	25
-44025.3	25
-44036.2	25
-44047.2	25
-44058.2	25
-44069.1	26
-44080.1	25
-44091.1	25
-44102	25
-44113	25
-44124	25
-44135	25
-44145.9	25
-44156.9	25
-44167.9	26
-44178.8	25
-44189.8	25
-44200.8	25
-44211.7	25
-44222.7	25
-44233.7	26
-44244.6	25
-44255.6	26
-44266.6	26
-44277.5	26
-44288.5	25
-44299.5	26
-44310.4	26
-44321.4	25
-44332.4	25
-44343.3	25
-44354.3	25
-44365.3	26
-44376.2	25
-44387.2	26
-44398.2	26
-44409.1	25
-44420.1	25
-44431.1	25
-44442.1	25
-44453	25
-44464	26
-44475	25
-44485.9	25
-44496.9	26
-44507.9	26
-44518.8	25
-44529.8	26
-44540.8	25
-44551.7	26
-44562.7	26
-44573.7	25
-44584.6	25
-44595.6	25
-44606.6	25
-44617.5	25
-44628.5	25
-44639.5	25
-44650.4	25
-44661.4	25
-44672.4	26
-44683.3	26
-44694.3	25
-44705.3	26
-44716.3	26
-44727.2	26
-44738.2	25
-44749.2	26
-44760.1	25
-44771.1	25
-44782.1	26
-44793	25
-44804	26
-44815	26
-44825.9	25
-44836.9	26
-44847.9	25
-44858.8	26
-44869.8	25
-44880.8	25
-44891.7	26
-44902.7	26
-44913.7	25
-44924.6	26
-44935.6	25
-44946.6	25
-44957.5	25
-44968.5	25
-44979.5	25
-44990.4	25
-45001.4	26
-45012.4	25
-45023.4	26
-45034.3	25
-45045.3	25
-45056.3	25
-45067.2	25
-45078.2	26
-45089.2	25
-45100.1	26
-45111.1	25
-45122.1	26
-45133	25
-45144	26
-45155	26
-45165.9	25
-45176.9	25
-45187.9	26
-45198.8	25
-45209.8	26
-45220.8	25
-45231.7	25
-45242.7	26
-45253.7	25
-45264.6	25
-45275.6	26
-45286.6	25
-45297.6	25
-45308.5	25
-45319.5	26
-45330.5	26
-45341.4	26
-45352.4	25
-45363.4	26
-45374.3	26
-45385.3	25
-45396.3	25
-45407.2	26
-45418.2	25
-45429.2	25
-45440.1	25
-45451.1	25
-45462.1	25
-45473	25
-45484	25
-45495	25
-45505.9	26
-45516.9	25
-45527.9	25
-45538.8	25
-45549.8	25
-45560.8	25
-45571.7	26
-45582.7	26
-45593.7	25
-45604.7	25
-45615.6	25
-45626.6	25
-45637.6	25
-45648.5	25
-45659.5	26
-45670.5	25
-45681.4	25
-45692.4	25
-45703.4	25
-45714.3	26
-45725.3	25
-45736.3	25
-45747.2	25
-45758.2	26
-45769.2	25
-45780.1	25
-45791.1	25
-45802.1	25
-45813	25
-45824	26
-45835	25
-45845.9	25
-45856.9	26
-45867.9	25
-45878.9	25
-45889.8	25
-45900.8	25
-45911.8	25
-45922.7	26
-45933.7	25
-45944.7	25
-45955.6	25
-45966.6	25
-45977.6	26
-45988.5	25
-45999.5	26
-46010.5	26
-46021.4	27
-46032.4	27
-46043.4	27
-46054.3	27
-46065.3	27
-46076.3	28
-46087.2	28
-46098.2	27
-46109.2	28
-46120.1	28
-46131.1	27
-46142.1	27
-46153	27
-46164	27
-46175	29
-46186	29
-46196.9	29
-46207.9	29
-46218.9	29
-46229.8	29
-46240.8	29
-46251.8	30
-46262.7	30
-46273.7	29
-46284.7	29
-46295.6	29
-46306.6	29
-46317.6	29
-46328.5	29
-46339.5	29
-46350.5	29
-46361.4	30
-46372.4	29
-46383.4	29
-46394.3	29
-46405.3	29
-46416.3	29
-46427.2	29
-46438.2	29
-46449.2	30
-46460.2	29
-46471.1	28
-46482.1	29
-46493.1	29
-46504	29
-46515	29
-46526	29
-46536.9	29
-46547.9	29
-46558.9	30
-46569.8	30
-46580.8	28
-46591.8	30
-46602.7	29
-46613.7	30
-46624.7	29
-46635.6	29
-46646.6	29
-46657.6	30
-46668.5	30
-46679.5	30
-46690.5	29
-46701.4	29
-46712.4	30
-46723.4	29
-46734.3	29
-46745.3	30
-46756.3	29
-46767.3	30
-46778.2	30
-46789.2	29
-46800.2	29
-46811.1	29
-46822.1	30
-46833.1	30
-46844	29
-46855	30
-46866	29
-46876.9	29
-46887.9	29
-46898.9	30
-46909.8	30
-46920.8	30
-46931.8	29
-46942.7	30
-46953.7	30
-46964.7	29
-46975.6	29
-46986.6	29
-46997.6	30
-47008.5	29
-47019.5	29
-47030.5	30
-47041.5	30
-47052.4	28
-47063.4	30
-47074.4	30
-47085.3	29
-47096.3	30
-47107.3	29
-47118.2	30
-47129.2	30
-47140.2	30
-47151.1	29
-47162.1	30
-47173.1	29
-47184	30
-47195	29
-47206	30
-47216.9	29
-47227.9	29
-47238.9	29
-47249.8	29
-47260.8	30
-47271.8	29
-47282.7	30
-47293.7	30
-47304.7	30
-47315.7	30
-47326.6	30
-47337.6	30
-47348.6	29
-47359.5	29
-47370.5	30
-47381.5	29
-47392.4	29
-47403.4	29
-47414.4	30
-47425.3	29
-47436.3	29
-47447.3	30
-47458.2	30
-47469.2	30
-47480.2	30
-47491.1	29
-47502.1	29
-47513.1	29
-47524	29
-47535	29
-47546	29
-47556.9	29
-47567.9	30
-47578.9	30
-47589.8	29
-47600.8	29
-47611.8	30
-47622.8	29
-47633.7	29
-47644.7	29
-47655.7	30
-47666.6	29
-47677.6	30
-47688.6	30
-47699.5	29
-47710.5	30
-47721.5	30
-47732.4	29
-47743.4	29
-47754.4	30
-47765.3	30
-47776.3	29
-47787.3	30
-47798.2	30
-47809.2	30
-47820.2	29
-47831.1	30
-47842.1	29
-47853.1	29
-47864	29
-47875	29
-47886	29
-47897	30
-47907.9	29
-47918.9	29
-47929.9	30
-47940.8	29
-47951.8	30
-47962.8	29
-47973.7	29
-47984.7	30
-47995.7	29
-48006.6	29
-48017.6	30
-48028.6	29
-48039.5	29
-48050.5	30
-48061.5	29
-48072.4	29
-48083.4	30
-48094.4	29
-48105.3	29
-48116.3	30
-48127.3	29
-48138.2	30
-48149.2	30
-48160.2	29
-48171.1	29
-48182.1	29
-48193.1	30
-48204.1	29
-48215	29
-48226	29
-48237	29
-48247.9	29
-48258.9	29
-48269.9	30
-48280.8	30
-48291.8	29
-48302.8	30
-48313.7	30
-48324.7	29
-48335.7	29
-48346.6	30
-48357.6	29
-48368.6	29
-48379.5	30
-48390.5	29
-48401.5	29
-48412.4	30
-48423.4	29
-48434.4	29
-48445.3	29
-48456.3	30
-48467.3	30
-48478.3	29
-48489.2	30
-48500.2	29
-48511.2	30
-48522.1	30
-48533.1	29
-48544.1	28
-48555	29
-48566	30
-48577	30
-48587.9	30
-48598.9	30
-48609.9	30
-48620.8	30
-48631.8	30
-48642.8	29
-48653.7	30
-48664.7	30
-48675.7	29
-48686.6	29
-48697.6	29
-48708.6	29
-48719.5	29
-48730.5	29
-48741.5	29
-48752.4	30
-48763.4	30
-48774.4	31
-48785.4	35
-48796.3	35
-48807.3	35
-48818.3	35
-48829.2	35
-48840.2	35
-48851.2	36
-48862.1	35
-48873.1	34
-48884.1	36
-48895	36
-48906	36
-48917	36
-48927.9	36
-48938.9	36
-48949.9	35
-48960.8	36
-48971.8	36
-48982.8	35
-48993.7	35
-49004.7	36
-49015.7	35
-49026.6	36
-49037.6	36
-49048.6	36
-49059.6	36
-49070.5	36
-49081.5	34
-49092.5	35
-49103.4	35
-49114.4	34
-49125.4	36
-49136.3	36
-49147.3	35
-49158.3	36
-49169.2	35
-49180.2	36
-49191.2	36
-49202.1	35
-49213.1	35
-49224.1	36
-49235	35
-49246	35
-49257	35
-49267.9	36
-49278.9	35
-49289.9	36
-49300.8	35
-49311.8	36
-49322.8	36
-49333.7	36
-49344.7	35
-49355.7	35
-49366.7	36
-49377.6	35
-49388.6	35
-49399.6	35
-49410.5	36
-49421.5	35
-49432.5	35
-49443.4	35
-49454.4	36
-49465.4	35
-49476.3	36
-49487.3	35
-49498.3	36
-49509.2	35
-49520.2	35
-49531.2	35
-49542.1	36
-49553.1	35
-49564.1	36
-49575	36
-49586	35
-49597	36
-49607.9	36
-49618.9	36
-49629.9	36
-49640.9	35
-49651.8	36
-49662.8	35
-49673.8	36
-49684.7	36
-49695.7	35
-49706.7	35
-49717.6	36
-49728.6	35
-49739.6	33
-49750.5	35
-49761.5	36
-49772.5	34
-49783.4	35
-49794.4	35
-49805.4	35
-49816.3	35
-49827.3	36
-49838.3	36
-49849.2	36
-49860.2	35
-49871.2	35
-49882.1	36
-49893.1	36
-49904.1	35
-49915	35
-49926	30
-49937	34
-49948	32
-49958.9	35
-49969.9	36
-49980.9	31
-49991.8	35
-50002.8	31
-50013.8	32
-50024.7	35
-50035.7	36
-50046.7	36
-50057.6	35
-50068.6	36
-50079.6	35
-50090.5	36
-50101.5	35
-50112.5	35
-50123.4	36
-50134.4	35
-50145.4	36
-50156.3	35
-50167.3	35
-50178.3	35
-50189.2	34
-50200.2	35
-50211.2	36
-50222.2	32
-50233.1	35
-50244.1	36
-50255.1	36
-50266	35
-50277	36
-50288	36
-50298.9	35
-50309.9	36
-50320.9	35
-50331.8	36
-50342.8	35
-50353.8	36
-50364.7	36
-50375.7	35
-50386.7	35
-50397.6	37
-50408.6	38
-50419.6	38
-50430.5	37
-50441.5	37
-50452.5	38
-50463.4	37
-50474.4	37
-50485.4	37
-50496.3	37
-50507.3	38
-50518.3	37
-50529.3	37
-50540.2	37
-50551.2	38
-50562.2	38
-50573.1	40
-50584.1	39
-50595.1	35
-50606	34
-50617	29
-50628	33
-50638.9	39
-50649.9	39
-50660.9	39
-50671.8	38
-50682.8	40
-50693.8	39
-50704.7	39
-50715.7	39
-50726.7	39
-50737.6	39
-50748.6	40
-50759.6	39
-50770.5	39
-50781.5	39
-50792.5	39
-50803.5	40
-50814.4	40
-50825.4	39
-50836.4	40
-50847.3	40
-50858.3	40
-50869.3	39
-50880.2	39
-50891.2	40
-50902.2	40
-50913.1	40
-50924.1	37
-50935.1	40
-50946	39
-50957	39
-50968	40
-50978.9	40
-50989.9	39
-51000.9	39
-51011.8	39
-51022.8	39
-51033.8	40
-51044.7	39
-51055.7	39
-51066.7	39
-51077.7	39
-51088.6	40
-51099.6	40
-51110.6	37
-51121.5	38
-51132.5	40
-51143.5	38
-51154.4	31
-51165.4	37
-51176.4	40
-51187.3	40
-51198.3	39
-51209.3	40
-51220.2	37
-51231.2	40
-51242.2	39
-51253.1	40
-51264.1	40
-51275.1	39
-51286	39
-51297	39
-51308	40
-51318.9	40
-51329.9	39
-51340.9	39
-51351.8	39
-51362.8	39
-51373.8	39
-51384.8	39
-51395.7	40
-51406.7	39
-51417.7	40
-51428.6	40
-51439.6	40
-51450.6	40
-51461.5	39
-51472.5	38
-51483.5	37
-51494.4	37
-51505.4	39
-51516.4	39
-51527.3	40
-51538.3	40
-51549.3	40
-51560.2	40
-51571.2	40
-51582.2	39
-51593.1	40
-51604.1	40
-51615.1	40
-51626	39
-51637	40
-51648	40
-51659	39
-51669.9	40
-51680.9	38
-51691.9	39
-51702.8	40
-51713.8	40
-51724.8	40
-51735.7	39
-51746.7	39
-51757.7	40
-51768.6	40
-51779.6	39
-51790.6	40
-51801.5	40
-51812.5	39
-51823.5	35
-51834.4	40
-51845.4	39
-51856.4	39
-51867.3	40
-51878.3	39
-51889.3	39
-51900.2	40
-51911.2	39
-51922.2	39
-51933.1	40
-51944.1	39
-51955.1	39
-51966.1	40
-51977	39
-51988	40
-51999	40
-52009.9	40
-52020.9	40
-52031.9	39
-52042.8	38
-52053.8	39
-52064.8	39
-52075.7	40
-52086.7	40
-52097.7	39
-52108.6	40
-52119.6	39
-52130.6	40
-52141.5	40
-52152.5	40
-52163.5	39
-52174.4	39
-52185.4	39
-52196.4	40
-52207.3	39
-52218.3	40
-52229.3	39
-52240.3	40
-52251.2	39
-52262.2	40
-52273.2	40
-52284.1	39
-52295.1	40
-52306.1	40
-52317	39
-52328	39
-52339	39
-52349.9	40
-52360.9	39
-52371.9	40
-52382.8	35
-52393.8	36
-52404.8	38
-52415.7	39
-52426.7	39
-52437.7	40
-52448.6	40
-52459.6	40
-52470.6	35
-52481.5	39
-52492.5	40
-52503.5	39
-52514.4	40
-52525.4	39
-52536.4	39
-52547.4	40
-52558.3	40
-52569.3	39
-52580.3	39
-52591.2	40
-52602.2	39
-52613.2	34
-52624.1	39
-52635.1	40
-52646.1	39
-52657	39
-52668	39
-52679	40
-52689.9	39
-52700.9	39
-52711.9	39
-52722.8	39
-52733.8	40
-52744.8	39
-52755.7	39
-52766.7	40
-52777.7	40
-52788.6	39
-52799.6	40
-52810.6	39
-52821.6	40
-52832.5	40
-52843.5	39
-52854.5	40
-52865.4	40
-52876.4	40
-52887.4	40
-52898.3	39
-52909.3	33
-52920.3	30
-52931.2	28
-52942.2	39
-52953.2	40
-52964.1	39
-52975.1	40
-52986.1	39
-52997	40
-53008	38
-53019	38
-53029.9	39
-53040.9	40
-53051.9	40
-53062.8	40
-53073.8	39
-53084.8	39
-53095.7	40
-53106.7	39
-53117.7	39
-53128.7	39
-53139.6	39
-53150.6	39
-53161.6	39
-53172.5	39
-53183.5	40
-53194.5	40
-53205.4	40
-53216.4	39
-53227.4	39
-53238.3	33
-53249.3	40
-53260.3	40
-53271.2	40
-53282.2	39
-53293.2	39
-53304.1	39
-53315.1	40
-53326.1	40
-53337	39
-53348	39
-53359	33
-53369.9	39
-53380.9	39
-53391.9	40
-53402.9	39
-53413.8	40
-53424.8	40
-53435.8	40
-53446.7	40
-53457.7	39
-53468.7	39
-53479.6	40
-53490.6	39
-53501.6	40
-53512.5	38
-53523.5	40
-53534.5	40
-53545.4	40
-53556.4	39
-53567.4	39
-53578.3	40
-53589.3	39
-53600.3	39
-53611.2	39
-53622.2	40
-53633.2	37
-53644.1	39
-53655.1	38
-53666.1	39
-53677	40
-53688	33
-53699	40
-53710	39
-53720.9	40
-53731.9	39
-53742.9	39
-53753.8	39
-53764.8	38
-53775.8	40
-53786.7	39
-53797.7	39
-53808.7	40
-53819.6	39
-53830.6	33
-53841.6	39
-53852.5	39
-53863.5	39
-53874.5	39
-53885.4	40
-53896.4	40
-53907.4	39
-53918.3	40
-53929.3	40
-53940.3	40
-53951.2	38
-53962.2	38
-53973.2	39
-53984.2	40
-53995.1	39
-54006.1	39
-54017.1	40
-54028	39
-54039	39
-54050	39
-54060.9	37
-54071.9	40
-54082.9	40
-54093.8	39
-54104.8	40
-54115.8	39
-54126.7	40
-54137.7	40
-54148.7	40
-54159.6	38
-54170.6	39
-54181.6	39
-54192.5	40
-54203.5	40
-54214.5	39
-54225.4	39
-54236.4	40
-54247.4	39
-54258.3	40
-54269.3	39
-54280.3	39
-54291.3	39
-54302.2	40
-54313.2	39
-54324.2	39
-54335.1	39
-54346.1	39
-54357.1	39
-54368	32
-54379	39
-54390	40
-54400.9	40
-54411.9	38
-54422.9	39
-54433.8	36
-54444.8	40
-54455.8	40
-54466.7	39
-54477.7	40
-54488.7	40
-54499.6	39
-54510.6	39
-54521.6	40
-54532.5	40
-54543.5	40
-54554.5	39
-54565.5	36
-54576.4	26
-54587.4	40
-54598.4	40
-54609.3	40
-54620.3	40
-54631.3	40
-54642.2	39
-54653.2	39
-54664.2	40
-54675.1	38
-54686.1	39
-54697.1	39
-54708	38
-54719	40
-54730	39
-54740.9	39
-54751.9	39
-54762.9	39
-54773.8	39
-54784.8	39
-54795.8	39
-54806.7	39
-54817.7	40
-54828.7	39
-54839.7	39
-54850.6	40
-54861.6	40
-54872.6	39
-54883.5	40
-54894.5	40
-54905.5	40
-54916.4	39
-54927.4	39
-54938.4	40
-54949.3	40
-54960.3	40
-54971.3	39
-54982.2	40
-54993.2	40
-55004.2	40
-55015.1	39
-55026.1	39
-55037.1	40
-55048	40
-55059	39
-55070	39
-55080.9	40
-55091.9	39
-55102.9	39
-55113.8	38
-55124.8	38
-55135.8	38
-55146.8	38
-55157.7	39
-55168.7	40
-55179.7	39
-55190.6	39
-55201.6	40
-55212.6	39
-55223.5	36
-55234.5	39
-55245.5	39
-55256.4	39
-55267.4	40
-55278.4	39
-55289.3	39
-55300.3	39
-55311.3	38
-55322.2	40
-55333.2	39
-55344.2	38
-55355.1	39
-55366.1	40
-55377.1	40
-55388	40
-55399	40
-55410	39
-55421	39
-55431.9	39
-55442.9	40
-55453.9	39
-55464.8	40
-55475.8	40
-55486.8	39
-55497.7	40
-55508.7	39
-55519.7	40
-55530.6	39
-55541.6	39
-55552.6	40
-55563.5	40
-55574.5	39
-55585.5	34
-55596.4	40
-55607.4	38
-55618.4	40
-55629.3	39
-55640.3	39
-55651.3	39
-55662.2	40
-55673.2	40
-55684.2	39
-55695.1	39
-55706.1	39
-55717.1	36
-55728.1	33
-55739	31
-55750	39
-55761	39
-55771.9	40
-55782.9	39
-55793.9	39
-55804.8	39
-55815.8	40
-55826.8	40
-55837.7	39
-55848.7	40
-55859.7	40
-55870.6	40
-55881.6	39
-55892.6	40
-55903.5	38
-55914.5	39
-55925.5	38
-55936.4	40
-55947.4	39
-55958.4	39
-55969.3	39
-55980.3	39
-55991.3	40
-56002.3	40
-56013.2	40
-56024.2	36
-56035.2	40
-56046.1	39
-56057.1	40
-56068.1	39
-56079	40
-56090	39
-56101	40
-56111.9	39
-56122.9	40
-56133.9	40
-56144.8	39
-56155.8	38
-56166.8	36
-56177.7	38
-56188.7	40
-56199.7	39
-56210.6	38
-56221.6	40
-56232.6	40
-56243.5	39
-56254.5	40
-56265.5	38
-56276.4	39
-56287.4	39
-56298.4	39
-56309.4	39
-56320.3	40
-56331.3	40
-56342.3	39
-56353.2	39
-56364.2	40
-56375.2	40
-56386.1	39
-56397.1	40
-56408.1	39
-56419	40
-56430	40
-56441	39
-56451.9	39
-56462.9	39
-56473.9	39
-56484.8	38
-56495.8	39
-56506.8	40
-56517.7	40
-56528.7	39
-56539.7	39
-56550.6	40
-56561.6	39
-56572.6	39
-56583.6	40
-56594.5	39
-56605.5	39
-56616.5	36
-56627.4	28
-56638.4	32
-56649.4	29
-56660.3	35
-56671.3	35
-56682.3	35
-56693.2	32
-56704.2	35
-56715.2	30
-56726.1	39
-56737.1	40
-56748.1	40
-56759	39
-56770	39
-56781	33
-56791.9	38
-56802.9	40
-56813.9	39
-56824.8	40
-56835.8	40
-56846.8	39
-56857.7	40
-56868.7	39
-56879.7	40
-56890.7	39
-56901.6	40
-56912.6	40
-56923.6	40
-56934.5	39
-56945.5	39
-56956.5	40
-56967.4	39
-56978.4	39
-56989.4	39
-57000.3	40
-57011.3	40
-57022.3	39
-57033.2	39
-57044.2	39
-57055.2	40
-57066.1	39
-57077.1	39
-57088.1	36
-57099	40
-57110	40
-57121	40
-57131.9	39
-57142.9	40
-57153.9	40
-57164.9	40
-57175.8	40
-57186.8	39
-57197.8	38
-57208.7	40
-57219.7	39
-57230.7	40
-57241.6	35
-57252.6	31
-57263.6	39
-57274.5	40
-57285.5	40
-57296.5	38
-57307.4	39
-57318.4	39
-57329.4	39
-57340.3	39
-57351.3	39
-57362.3	40
-57373.2	40
-57384.2	39
-57395.2	40
-57406.1	40
-57417.1	39
-57428.1	39
-57439	40
-57450	40
-57461	39
-57472	39
-57482.9	38
-57493.9	38
-57504.9	39
-57515.8	40
-57526.8	40
-57537.8	36
-57548.7	36
-57559.7	40
-57570.7	40
-57581.6	39
-57592.6	39
-57603.6	32
-57614.5	39
-57625.5	39
-57636.5	40
-57647.4	39
-57658.4	40
-57669.4	40
-57680.3	37
-57691.3	40
-57702.3	40
-57713.2	39
-57724.2	39
-57735.2	40
-57746.2	40
-57757.1	39
-57768.1	39
-57779.1	39
-57790	40
-57801	39
-57812	40
-57822.9	40
-57833.9	39
-57844.9	39
-57855.8	40
-57866.8	40
-57877.8	36
-57888.7	40
-57899.7	40
-57910.7	39
-57921.6	40
-57932.6	39
-57943.6	40
-57954.5	40
-57965.5	40
-57976.5	39
-57987.4	39
-57998.4	39
-58009.4	39
-58020.3	40
-58031.3	40
-58042.3	40
-58053.3	40
-58064.2	38
-58075.2	31
-58086.2	39
-58097.1	39
-58108.1	39
-58119.1	39
-58130	40
-58141	39
-58152	39
-58162.9	40
-58173.9	39
-58184.9	39
-58195.8	40
-58206.8	40
-58217.8	40
-58228.7	35
-58239.7	38
-58250.7	39
-58261.6	39
-58272.6	39
-58283.6	39
-58294.5	40
-58305.5	39
-58316.5	40
-58327.5	39
-58338.4	40
-58349.4	39
-58360.4	39
-58371.3	40
-58382.3	40
-58393.3	40
-58404.2	39
-58415.2	40
-58426.2	39
-58437.1	40
-58448.1	39
-58459.1	39
-58470	40
-58481	40
-58492	40
-58502.9	40
-58513.9	40
-58524.9	39
-58535.8	39
-58546.8	39
-58557.8	40
-58568.7	39
-58579.7	39
-58590.7	40
-58601.6	39
-58612.6	40
-58623.6	39
-58634.6	39
-58645.5	40
-58656.5	40
-58667.5	40
-58678.4	39
-58689.4	32
-58700.4	35
-58711.3	37
-58722.3	40
-58733.3	40
-58744.2	40
-58755.2	39
-58766.2	40
-58777.1	40
-58788.1	40
-58799.1	39
-58810	39
-58821	39
-58832	40
-58842.9	40
-58853.9	39
-58864.9	40
-58875.8	40
-58886.8	40
-58897.8	40
-58908.8	39
-58919.7	40
-58930.7	39
-58941.7	40
-58952.6	38
-58963.6	39
-58974.6	40
-58985.5	39
-58996.5	40
-59007.5	39
-59018.4	38
-59029.4	30
-59040.4	37
-59051.3	38
-59062.3	39
-59073.3	40
-59084.2	39
-59095.2	40
-59106.2	39
-59117.1	38
-59128.1	39
-59139.1	40
-59150	39
-59161	40
-59172	40
-59183	39
-59193.9	39
-59204.9	39
-59215.9	39
-59226.8	39
-59237.8	40
-59248.8	39
-59259.7	39
-59270.7	39
-59281.7	40
-59292.6	39
-59303.6	39
-59314.6	40
-59325.5	40
-59336.5	40
-59347.5	39
-59358.4	40
-59369.4	39
-59380.4	40
-59391.3	40
-59402.3	39
-59413.3	35
-59424.2	28
-59435.2	40
-59446.2	39
-59457.1	39
-59468.1	40
-59479.1	39
-59490.1	39
-59501	39
-59512	39
-59523	39
-59533.9	40
-59544.9	39
-59555.9	36
-59566.8	32
-59577.8	38
-59588.8	39
-59599.7	40
-59610.7	40
-59621.7	39
-59632.6	39
-59643.6	40
-59654.6	40
-59665.5	40
-59676.5	38
-59687.5	33
-59698.4	34
-59709.4	36
-59720.4	35
-59731.3	39
-59742.3	39
-59753.3	39
-59764.3	39
-59775.2	40
-59786.2	40
-59797.2	39
-59808.1	38
-59819.1	40
-59830.1	40
-59841	39
-59852	39
-59863	40
-59873.9	40
-59884.9	39
-59895.9	40
-59906.8	39
-59917.8	40
-59928.8	39
-59939.7	39
-59950.7	39
-59961.7	40
-59972.6	40
-59983.6	39
-59994.6	39
-60005.5	39
-60016.5	39
-60027.5	39
-60038.4	40
-60049.4	39
-60060.4	40
-60071.4	40
-60082.3	40
-60093.3	40
-60104.3	40
-60115.2	39
-60126.2	40
-60137.2	39
-60148.1	38
-60159.1	36
-60170.1	39
-60181	38
-60192	40
-60203	40
-60213.9	40
-60224.9	39
-60235.9	35
-60246.8	40
-60257.8	39
-60268.8	40
-60279.7	38
-60290.7	32
-60301.7	39
-60312.6	39
-60323.6	39
-60334.6	40
-60345.6	39
-60356.5	39
-60367.5	39
-60378.5	40
-60389.4	40
-60400.4	40
-60411.4	40
-60422.3	40
-60433.3	40
-60444.3	40
-60455.2	39
-60466.2	40
-60477.2	40
-60488.1	39
-60499.1	40
-60510.1	39
-60521	40
-60532	39
-60543	40
-60553.9	39
-60564.9	40
-60575.9	39
-60586.8	39
-60597.8	39
-60608.8	38
-60619.7	39
-60630.7	38
-60641.7	39
-60652.7	40
-60663.6	40
-60674.6	39
-60685.6	40
-60696.5	39
-60707.5	40
-60718.5	39
-60729.4	39
-60740.4	40
-60751.4	40
-60762.3	40
-60773.3	40
-60784.3	39
-60795.2	40
-60806.2	40
-60817.2	39
-60828.1	40
-60839.1	39
-60850.1	39
-60861	40
-60872	40
-60883	39
-60893.9	39
-60904.9	40
-60915.9	40
-60926.9	39
-60937.8	39
-60948.8	39
-60959.8	40
-60970.7	40
-60981.7	39
-60992.7	39
-61003.6	39
-61014.6	39
-61025.6	40
-61036.5	38
-61047.5	39
-61058.5	38
-61069.4	40
-61080.4	40
-61091.4	39
-61102.3	38
-61113.3	35
-61124.3	39
-61135.2	39
-61146.2	40
-61157.2	39
-61168.1	39
-61179.1	40
-61190.1	39
-61201	39
-61212	39
-61223	40
-61234	40
-61244.9	39
-61255.9	40
-61266.9	39
-61277.8	40
-61288.8	33
-61299.8	39
-61310.7	40
-61321.7	39
-61332.7	39
-61343.6	39
-61354.6	40
-61365.6	40
-61376.5	39
-61387.5	33
-61398.5	28
-61409.4	39
-61420.4	39
-61431.4	39
-61442.3	40
-61453.3	39
-61464.3	39
-61475.2	39
-61486.2	39
-61497.2	40
-61508.2	39
-61519.1	40
-61530.1	40
-61541.1	39
-61552	40
-61563	39
-61574	40
-61584.9	38
-61595.9	39
-61606.9	39
-61617.8	39
-61628.8	38
-61639.8	39
-61650.7	40
-61661.7	38
-61672.7	39
-61683.6	40
-61694.6	40
-61705.6	39
-61716.5	39
-61727.5	39
-61738.5	39
-61749.4	40
-61760.4	39
-61771.4	39
-61782.3	39
-61793.3	39
-61804.3	40
-61815.3	37
-61826.2	39
-61837.2	40
-61848.2	39
-61859.1	39
-61870.1	40
-61881.1	39
-61892	40
-61903	40
-61914	40
-61924.9	39
-61935.9	40
-61946.9	40
-61957.8	40
-61968.8	39
-61979.8	40
-61990.7	39
-62001.7	40
-62012.7	40
-62023.6	40
-62034.6	40
-62045.6	38
-62056.5	40
-62067.5	40
-62078.5	40
-62089.5	38
-62100.4	39
-62111.4	39
-62122.4	40
-62133.3	40
-62144.3	40
-62155.3	39
-62166.2	40
-62177.2	40
-62188.2	39
-62199.1	39
-62210.1	39
-62221.1	39
-62232	40
-62243	40
-62254	40
-62264.9	39
-62275.9	40
-62286.9	39
-62297.8	40
-62308.8	40
-62319.8	40
-62330.7	40
-62341.7	39
-62352.7	39
-62363.6	39
-62374.6	39
-62385.6	40
-62396.6	40
-62407.5	39
-62418.5	39
-62429.5	39
-62440.4	39
-62451.4	40
-62462.4	40
-62473.3	39
-62484.3	40
-62495.3	39
-62506.2	40
-62517.2	39
-62528.2	39
-62539.1	40
-62550.1	39
-62561.1	40
-62572	40
-62583	38
-62594	39
-62604.9	39
-62615.9	40
-62626.9	39
-62637.8	39
-62648.8	40
-62659.8	39
-62670.8	39
-62681.7	40
-62692.7	40
-62703.7	40
-62714.6	39
-62725.6	40
-62736.6	40
-62747.5	39
-62758.5	39
-62769.5	39
-62780.4	39
-62791.4	40
-62802.4	39
-62813.3	40
-62824.3	39
-62835.3	39
-62846.2	39
-62857.2	39
-62868.2	39
-62879.1	39
-62890.1	40
-62901.1	40
-62912	39
-62923	39
-62934	39
-62945	40
-62955.9	40
-62966.9	40
-62977.9	39
-62988.8	38
-62999.8	38
-63010.8	39
-63021.7	39
-63032.7	40
-63043.7	39
-63054.6	40
-63065.6	40
-63076.6	39
-63087.5	40
-63098.5	39
-63109.5	39
-63120.4	39
-63131.4	39
-63142.4	39
-63153.3	39
-63164.3	39
-63175.3	39
-63186.2	39
-63197.2	40
-63208.2	40
-63219.1	40
-63230.1	39
-63241.1	39
-63252.1	40
-63263	40
-63274	40
-63285	39
-63295.9	39
-63306.9	40
-63317.9	39
-63328.8	39
-63339.8	39
-63350.8	39
-63361.7	39
-63372.7	40
-63383.7	39
-63394.6	40
-63405.6	40
-63416.6	40
-63427.5	40
-63438.5	39
-63449.5	39
-63460.4	39
-63471.4	38
-63482.4	39
-63493.3	40
-63504.3	39
-63515.3	39
-63526.3	39
-63537.2	39
-63548.2	40
-63559.2	38
-63570.1	40
-63581.1	40
-63592.1	39
-63603	39
-63614	40
-63625	39
-63635.9	39
-63646.9	40
-63657.9	40
-63668.8	39
-63679.8	39
-63690.8	40
-63701.7	39
-63712.7	40
-63723.7	39
-63734.6	39
-63745.6	40
-63756.6	33
-63767.5	24
-63778.5	39
-63789.5	40
-63800.4	40
-63811.4	39
-63822.4	40
-63833.4	39
-63844.3	39
-63855.3	39
-63866.3	39
-63877.2	40
-63888.2	39
-63899.2	38
-63910.1	39
-63921.1	39
-63932.1	39
-63943	40
-63954	39
-63965	39
-63975.9	39
-63986.9	40
-63997.9	39
-64008.8	39
-64019.8	39
-64030.8	39
-64041.7	37
-64052.7	39
-64063.7	39
-64074.6	39
-64085.6	38
-64096.6	40
-64107.6	39
-64118.5	40
-64129.5	39
-64140.5	39
-64151.4	39
-64162.4	39
-64173.4	40
-64184.3	39
-64195.3	39
-64206.3	40
-64217.2	40
-64228.2	38
-64239.2	40
-64250.1	39
-64261.1	39
-64272.1	39
-64283	39
-64294	39
-64305	39
-64315.9	39
-64326.9	38
-64337.9	39
-64348.8	40
-64359.8	40
-64370.8	38
-64381.7	39
-64392.7	40
-64403.7	39
-64414.7	39
-64425.6	39
-64436.6	39
-64447.6	39
-64458.5	40
-64469.5	39
-64480.5	37
-64491.4	39
-64502.4	39
-64513.4	40
-64524.3	40
-64535.3	39
-64546.3	39
-64557.2	39
-64568.2	40
-64579.2	40
-64590.1	40
-64601.1	39
-64612.1	39
-64623	39
-64634	39
-64645	39
-64655.9	39
-64666.9	40
-64677.9	40
-64688.9	38
-64699.8	40
-64710.8	40
-64721.8	39
-64732.7	38
-64743.7	39
-64754.7	40
-64765.6	39
-64776.6	39
-64787.6	40
-64798.5	40
-64809.5	39
-64820.5	39
-64831.4	39
-64842.4	39
-64853.4	40
-64864.3	40
-64875.3	39
-64886.3	39
-64897.2	40
-64908.2	36
-64919.2	40
-64930.1	40
-64941.1	40
-64952.1	39
-64963	39
-64974	40
-64985	39
-64996	40
-65006.9	38
-65017.9	40
-65028.9	40
-65039.8	40
-65050.8	39
-65061.8	40
-65072.7	40
-65083.7	40
-65094.7	40
-65105.6	39
-65116.6	39
-65127.6	39
-65138.5	39
-65149.5	39
-65160.5	39
-65171.4	40
-65182.4	39
-65193.4	39
-65204.3	40
-65215.3	38
-65226.3	38
-65237.2	40
-65248.2	39
-65259.2	39
-65270.2	40
-65281.1	40
-65292.1	39
-65303.1	38
-65314	39
-65325	40
-65336	40
-65346.9	39
-65357.9	39
-65368.9	40
-65379.8	40
-65390.8	40
-65401.8	40
-65412.7	40
-65423.7	39
-65434.7	39
-65445.6	39
-65456.6	37
-65467.6	39
-65478.5	40
-65489.5	39
-65500.5	39
-65511.4	39
-65522.4	39
-65533.4	39
-65544.3	40
-65555.3	39
-65566.3	39
-65577.3	39
-65588.2	40
-65599.2	40
-65610.2	39
-65621.1	31
-65632.1	40
-65643.1	39
-65654	39
-65665	39
-65676	38
-65686.9	40
-65697.9	40
-65708.9	40
-65719.8	40
-65730.8	39
-65741.8	40
-65752.7	40
-65763.7	40
-65774.7	39
-65785.6	40
-65796.6	40
-65807.6	40
-65818.5	40
-65829.5	40
-65840.5	39
-65851.5	38
-65862.4	40
-65873.4	39
-65884.4	40
-65895.3	38
-65906.3	39
-65917.3	39
-65928.2	40
-65939.2	39
-65950.2	39
-65961.1	38
-65972.1	40
-65983.1	39
-65994	40
-66005	39
-66016	40
-66026.9	39
-66037.9	37
-66048.9	39
-66059.8	40
-66070.8	39
-66081.8	39
-66092.7	39
-66103.7	39
-66114.7	39
-66125.6	36
-66136.6	39
-66147.6	39
-66158.6	40
-66169.5	40
-66180.5	39
-66191.5	39
-66202.4	38
-66213.4	40
-66224.4	38
-66235.3	38
-66246.3	40
-66257.3	40
-66268.2	39
-66279.2	39
-66290.2	40
-66301.1	40
-66312.1	39
-66323.1	40
-66334	39
-66345	40
-66356	40
-66366.9	40
-66377.9	40
-66388.9	39
-66399.8	39
-66410.8	39
-66421.8	40
-66432.8	40
-66443.7	39
-66454.7	40
-66465.7	38
-66476.6	39
-66487.6	39
-66498.6	40
-66509.5	39
-66520.5	36
-66531.5	39
-66542.4	39
-66553.4	39
-66564.4	39
-66575.3	40
-66586.3	40
-66597.3	35
-66608.2	39
-66619.2	40
-66630.2	39
-66641.1	39
-66652.1	38
-66663.1	39
-66674	31
-66685	39
-66696	39
-66707	39
-66717.9	39
-66728.9	39
-66739.9	35
-66750.8	36
-66761.8	39
-66772.8	39
-66783.7	40
-66794.7	32
-66805.7	37
-66816.6	39
-66827.6	36
-66838.6	32
-66849.5	39
-66860.5	38
-66871.5	36
-66882.4	36
-66893.4	35
-66904.4	36
-66915.3	39
-66926.3	31
-66937.3	36
-66948.2	34
-66959.2	29
-66970.2	31
-66981.1	32
-66992.1	31
-67003.1	30
-67014.1	35
-67025	29
-67036	30
-67047	25
-67057.9	29
-67068.9	25
-67079.9	27
-67090.8	25
-67101.8	24
-67112.8	20
-67123.7	24
-67134.7	20
-67145.7	20
-67156.6	24
-67167.6	20
-67178.6	25
-67189.5	20
-67200.5	24
-67211.5	20
-67222.4	24
-67233.4	20
-67244.4	24
-67255.3	20
-67266.3	24
-67277.3	20
-67288.3	24
-67299.2	20
-67310.2	24
-67321.2	20
-67332.1	24
-67343.1	20
-67354.1	24
-67365	20
-67376	24
-67387	20
-67397.9	24
-67408.9	21
-67419.9	20
-67430.8	20
-67441.8	20
-67452.8	20
-67463.7	20
-67474.7	20
-67485.7	20
-67496.6	20
-67507.6	20
-67518.6	20
-67529.5	20
-67540.5	19
-67551.5	19
-67562.4	18
-67573.4	18
-67584.4	18
-67595.4	18
-67606.3	17
-67617.3	16
-67628.3	16
-67639.2	15
-67650.2	17
-67661.2	17
-67672.1	16
-67683.1	15
-67694.1	18
-67705	19
-67716	20
-67727	20
-67737.9	20
-67748.9	20
-67759.9	20
-67770.8	20
-67781.8	20
-67792.8	19
-67803.7	18
-67814.7	18
-67825.7	17
-67836.6	16
-67847.6	16
-67858.6	15
-67869.6	18
-67880.5	19
-67891.5	20
-67902.5	19
-67913.4	17
-67924.4	17
-67935.4	16
-67946.3	15
-67957.3	17
-67968.3	16
-67979.2	16
-67990.2	17
-68001.2	16
-68012.1	15
-68023.1	18
-68034.1	19
-68045	19
-68056	17
-68067	16
-68077.9	15
-68088.9	17
-68099.9	17
-68110.8	16
-68121.8	15
-68132.8	17
-68143.7	16
-68154.7	15
-68165.7	17
-68176.7	17
-68187.6	16
-68198.6	15
-68209.6	17
-68220.5	16
-68231.5	15
-68242.5	17
-68253.4	16
-68264.4	15
-68275.4	17
-68286.3	15
-68297.3	15
-68308.3	15
-68319.2	15
-68330.2	15
-68341.2	16
-68352.1	16
-68363.1	15
-68374.1	16
-68385	16
-68396	15
-68407	15
-68417.9	17
-68428.9	16
-68439.9	16
-68450.9	15
-68461.8	15
-68472.8	17
-68483.8	18
-68494.7	19
-68505.7	19
-68516.7	19
-68527.6	19
-68538.6	19
-68549.6	19
-68560.5	19
-68571.5	19
-68582.5	19
-68593.4	19
-68604.4	19
-68615.4	19
-68626.3	19
-68637.3	19
-68648.3	19
-68659.2	19
-68670.2	19
-68681.2	19
-68692.1	19
-68703.1	19
-68714.1	19
-68725	19
-68736	19
-68747	19
-68758	19
-68768.9	19
-68779.9	19
-68790.9	19
-68801.8	19
-68812.8	19
-68823.8	19
-68834.7	19
-68845.7	19
-68856.7	19
-68867.6	19
-68878.6	19
-68889.6	19
-68900.5	19
-68911.5	19
-68922.5	19
-68933.4	19
-68944.4	19
-68955.4	19
-68966.3	19
-68977.3	19
-68988.3	19
-68999.2	19
-69010.2	19
-69021.2	19
-69032.2	19
-69043.1	19
-69054.1	19
-69065.1	19
-69076	19
-69087	19
-69098	19
-69108.9	19
-69119.9	19
-69130.9	19
-69141.8	19
-69152.8	19
-69163.8	19
-69174.7	19
-69185.7	19
-69196.7	19
-69207.6	19
-69218.6	19
-69229.6	19
-69240.5	19
-69251.5	19
-69262.5	19
-69273.4	19
-69284.4	19
-69295.4	19
-69306.3	19
-69317.3	19
-69328.3	19
-69339.3	19
-69350.2	19
-69361.2	19
-69372.2	19
-69383.1	19
-69394.1	19
-69405.1	19
-69416	19
-69427	19
-69438	19
-69448.9	19
-69459.9	19
-69470.9	19
-69481.8	19
-69492.8	19
-69503.8	19
-69514.7	19
-69525.7	19
-69536.7	19
-69547.6	19
-69558.6	19
-69569.6	19
-69580.5	19
-69591.5	19
-69602.5	19
-69613.5	19
-69624.4	19
-69635.4	19
-69646.4	19
-69657.3	19
-69668.3	19
-69679.3	19
-69690.2	19
-69701.2	19
-69712.2	19
-69723.1	19
-69734.1	19
-69745.1	19
-69756	19
-69767	19
-69778	19
-69788.9	19
-69799.9	19
-69810.9	19
-69821.8	19
-69832.8	19
-69843.8	19
-69854.7	19
-69865.7	19
-69876.7	19
-69887.6	19
-69898.6	19
-69909.6	19
-69920.6	19
-69931.5	19
-69942.5	19
-69953.5	19
-69964.4	19
-69975.4	19
-69986.4	19
-69997.3	19
-70008.3	19
-70019.3	19
-70030.2	19
-70041.2	19
-70052.2	19
-70063.1	19
-70074.1	19
-70085.1	19
-70096	19
-70107	19
-70118	19
-70128.9	19
-70139.9	19
-70150.9	19
-70161.8	19
-70172.8	19
-70183.8	19
-70194.8	19
-70205.7	19
-70216.7	19
-70227.7	19
-70238.6	19
-70249.6	19
-70260.6	19
-70271.5	19
-70282.5	19
-70293.5	19
-70304.4	19
-70315.4	19
-70326.4	19
-70337.3	19
-70348.3	19
-70359.3	19
-70370.2	19
-70381.2	18
-70392.2	12
-70403.1	4
-70414.1	5
-70425.1	11
-70436	17
-70447	20
-70458	20
-70469	20
-70479.9	20
-70490.9	20
-70501.9	20
-70512.8	20
-70523.8	20
-70534.8	20
-70545.7	20
-70556.7	20
-70567.7	20
-70578.6	20
-70589.6	20
-70600.6	20
-70611.5	20
-70622.5	20
-70633.5	20
-70644.4	20
-70655.4	20
-70666.4	20
-70677.3	20
-70688.3	20
-70699.3	20
-70710.2	20
-70721.2	20
-70732.2	20
-70743.1	20
-70754.1	20
-70765.1	20
-70776.1	20
-70787	20
-70798	20
-70809	20
-70819.9	20
-70830.9	20
-70841.9	20
-70852.8	20
-70863.8	20
-70874.8	20
-70885.7	20
-70896.7	20
-70907.7	20
-70918.6	20
-70929.6	20
-70940.6	20
-70951.5	20
-70962.5	20
-70973.5	20
-70984.4	20
-70995.4	20
-71006.4	20
-71017.3	20
-71028.3	20
-71039.3	20
-71050.3	20
-71061.2	20
-71072.2	20
-71083.2	20
-71094.1	20
-71105.1	20
-71116.1	20
-71127	20
-71138	20
-71149	20
-71159.9	20
-71170.9	20
-71181.9	20
-71192.8	20
-71203.8	20
-71214.8	20
-71225.7	20
-71236.7	20
-71247.7	20
-71258.6	20
-71269.6	20
-71280.6	20
-71291.5	20
-71302.5	20
-71313.5	20
-71324.4	20
-71335.4	20
-71346.4	20
-71357.4	20
-71368.3	20
-71379.3	20
-71390.3	20
-71401.2	20
-71412.2	20
-71423.2	20
-71434.1	20
-71445.1	20
-71456.1	20
-71467	20
-71478	20
-71489	20
-71499.9	20
-71510.9	20
-71521.9	20
-71532.8	20
-71543.8	20
-71554.8	20
-71565.7	20
-71576.7	20
-71587.7	20
-71598.6	20
-71609.6	20
-71620.6	20
-71631.6	20
-71642.5	20
-71653.5	20
-71664.5	20
-71675.4	20
-71686.4	20
-71697.4	20
-71708.3	20
-71719.3	20
-71730.3	20
-71741.2	20
-71752.2	20
-71763.2	20
-71774.1	20
-71785.1	20
-71796.1	20
-71807	20
-71818	20
-71829	20
-71839.9	20
-71850.9	20
-71861.9	20
-71872.8	20
-71883.8	20
-71894.8	20
-71905.7	20
-71916.7	20
-71927.7	20
-71938.7	20
-71949.6	20
-71960.6	20
-71971.6	20
-71982.5	20
-71993.5	20
-72004.5	20
-72015.4	20
-72026.4	20
-72037.4	20
-72048.3	20
-72059.3	20
-72070.3	20
-72081.2	20
-72092.2	20
-72103.2	20
-72114.1	20
-72125.1	20
-72136.1	20
-72147	20
-72158	18
-72169	18
-72179.9	18
-72190.9	17
-72201.9	16
-72212.9	17
-72223.8	20
-72234.8	20
-72245.8	20
-72256.7	20
-72267.7	20
-72278.7	20
-72289.6	20
-72300.6	20
-72311.6	20
-72322.5	20
-72333.5	20
-72344.5	20
-72355.4	20
-72366.4	20
-72377.4	20
-72388.3	20
-72399.3	20
-72410.3	20
-72421.2	20
-72432.2	20
-72443.2	20
-72454.1	20
-72465.1	20
-72476.1	20
-72487	20
-72498	20
-72509	20
-72520	20
-72530.9	20
-72541.9	20
-72552.9	20
-72563.8	20
-72574.8	20
-72585.8	20
-72596.7	20
-72607.7	20
-72618.7	20
-72629.6	20
-72640.6	20
-72651.6	20
-72662.5	20
-72673.5	20
-72684.5	20
-72695.4	20
-72706.4	20
-72717.4	20
-72728.3	20
-72739.3	20
-72750.3	20
-72761.2	20
-72772.2	20
-72783.2	20
-72794.2	20
-72805.1	20
-72816.1	20
-72827.1	20
-72838	20
-72849	20
-72860	20
-72870.9	20
-72881.9	20
-72892.9	20
-72903.8	20
-72914.8	20
-72925.8	20
-72936.7	20
-72947.7	20
-72958.7	20
-72969.6	20
-72980.6	20
-72991.6	20
-73002.5	20
-73013.5	20
-73024.5	20
-73035.4	20
-73046.4	20
-73057.4	20
-73068.3	20
-73079.3	20
-73090.3	20
-73101.3	20
-73112.2	20
-73123.2	20
-73134.2	20
-73145.1	20
-73156.1	20
-73167.1	20
-73178	20
-73189	20
-73200	20
-73210.9	20
-73221.9	20
-73232.9	20
-73243.8	20
-73254.8	20
-73265.8	20
-73276.7	20
-73287.7	20
-73298.7	20
-73309.6	20
-73320.6	20
-73331.6	20
-73342.5	20
-73353.5	20
-73364.5	20
-73375.5	20
-73386.4	20
-73397.4	20
-73408.4	20
-73419.3	20
-73430.3	20
-73441.3	20
-73452.2	20
-73463.2	20
-73474.2	20
-73485.1	20
-73496.1	20
-73507.1	20
-73518	20
-73529	20
-73540	20
-73550.9	20
-73561.9	20
-73572.9	20
-73583.8	20
-73594.8	20
-73605.8	20
-73616.7	20
-73627.7	20
-73638.7	20
-73649.6	20
-73660.6	20
-73671.6	20
-73682.6	20
-73693.5	20
-73704.5	20
-73715.5	20
-73726.4	20
-73737.4	20
-73748.4	20
-73759.3	20
-73770.3	20
-73781.3	20
-73792.2	20
-73803.2	20
-73814.2	20
-73825.1	20
-73836.1	20
-73847.1	20
-73858	20
-73869	20
-73880	20
-73890.9	20
-73901.9	20
-73912.9	20
-73923.8	20
-73934.8	20
-73945.8	20
-73956.8	20
-73967.7	20
-73978.7	20
-73989.7	20
-74000.6	20
-74011.6	20
-74022.6	20
-74033.5	20
-74044.5	20
-74055.5	20
-74066.4	20
-74077.4	20
-74088.4	20
-74099.3	20
-74110.3	20
-74121.3	4
-74132.2	5
-74143.2	7
-74154.2	7
-74165.1	7
-74176.1	7
-74187.1	7
-74198	7
-74209	7
-74220	7
-74231	7
-74241.9	7
-74252.9	7
-74263.9	7
-74274.8	7
-74285.8	7
-74296.8	7
-74307.7	7
-74318.7	7
-74329.7	7
-74340.6	7
-74351.6	7
-74362.6	7
-74373.5	7
-74384.5	7
-74395.5	7
-74406.4	7
-74417.4	7
-74428.4	7
-74439.3	7
-74450.3	7
-74461.3	7
-74472.2	7
-74483.2	7
-74494.2	7
-74505.1	7
-74516.1	7
-74527.1	7
-74538.1	7
-74549	7
-74560	7
-74571	7
-74581.9	7
-74592.9	7
-74603.9	7
-74614.8	7
-74625.8	7
-74636.8	7
-74647.7	7
-74658.7	7
-74669.7	7
-74680.6	7
-74691.6	7
-74702.6	7
-74713.5	7
-74724.5	7
-74735.5	7
-74746.4	7
-74757.4	7
-74768.4	7
-74779.3	7
-74790.3	7
-74801.3	7
-74812.3	7
-74823.2	7
-74834.2	7
-74845.2	7
-74856.1	7
-74867.1	7
-74878.1	7
-74889	7
-74900	7
-74911	7
-74921.9	7
-74932.9	7
-74943.9	7
-74954.8	7
-74965.8	7
-74976.8	7
-74987.7	7
-74998.7	7
-75009.7	7
-75020.6	7
-75031.6	7
-75042.6	7
-75053.5	7
-75064.5	7
-75075.5	7
-75086.4	7
-75097.4	7
-75108.4	7
-75119.4	7
-75130.3	7
-75141.3	7
-75152.3	7
-75163.2	7
-75174.2	7
-75185.2	7
-75196.1	7
-75207.1	7
-75218.1	7
-75229	7
-75240	7
-75251	7
-75261.9	7
-75272.9	7
-75283.9	7
-75294.8	7
-75305.8	7
-75316.8	7
-75327.7	7
-75338.7	7
-75349.7	7
-75360.6	7
-75371.6	7
-75382.6	7
-75393.6	7
-75404.5	7
-75415.5	7
-75426.5	7
-75437.4	7
-75448.4	7
-75459.4	7
-75470.3	7
-75481.3	7
-75492.3	7
-75503.2	7
-75514.2	7
-75525.2	7
-75536.1	7
-75547.1	7
-75558.1	7
-75569	7
-75580	7
-75591	7
-75601.9	7
-75612.9	7
-75623.9	7
-75634.8	7
-75645.8	7
-75656.8	7
-75667.7	7
-75678.7	7
-75689.7	7
-75700.7	7
-75711.6	7
-75722.6	7
-75733.6	7
-75744.5	7
-75755.5	7
-75766.5	7
-75777.4	7
-75788.4	7
-75799.4	7
-75810.3	7
-75821.3	7
-75832.3	7
-75843.2	7
-75854.2	7
-75865.2	7
-75876.1	3
-75887.1	4
-75898.1	6
-75909	7
-75920	7
-75931	7
-75941.9	7
-75952.9	7
-75963.9	7
-75974.9	7
-75985.8	7
-75996.8	7
-76007.8	7
-76018.7	7
-76029.7	7
-76040.7	7
-76051.6	7
-76062.6	7
-76073.6	7
-76084.5	7
-76095.5	7
-76106.5	7
-76117.4	7
-76128.4	7
-76139.4	7
-76150.3	7
-76161.3	7
-76172.3	7
-76183.2	7
-76194.2	7
-76205.2	7
-76216.1	7
-76227.1	7
-76238.1	7
-76249	7
-76260	7
-76271	7
-76282	7
-76292.9	7
-76303.9	7
-76314.9	7
-76325.8	7
-76336.8	7
-76347.8	7
-76358.7	7
-76369.7	7
-76380.7	7
-76391.6	7
-76402.6	7
-76413.6	7
-76424.5	7
-76435.5	7
-76446.5	7
-76457.4	7
-76468.4	7
-76479.4	7
-76490.3	7
-76501.3	7
-76512.3	7
-76523.2	7
-76534.2	7
-76545.2	7
-76556.2	7
-76567.1	7
-76578.1	7
-76589.1	7
-76600	7
-76611	7
-76622	7
-76632.9	7
-76643.9	7
-76654.9	7
-76665.8	7
-76676.8	7
-76687.8	7
-76698.7	7
-76709.7	7
-76720.7	7
-76731.6	7
-76742.6	7
-76753.6	7
-76764.5	7
-76775.5	7
-76786.5	7
-76797.4	7
-76808.4	7
-76819.4	7
-76830.3	7
-76841.3	7
-76852.3	7
-76863.3	7
-76874.2	7
-76885.2	7
-76896.2	7
-76907.1	7
-76918.1	7
-76929.1	7
-76940	7
-76951	7
-76962	7
-76972.9	7
-76983.9	7
-76994.9	7
-77005.8	7
-77016.8	7
-77027.8	7
-77038.7	7
-77049.7	7
-77060.7	7
-77071.6	7
-77082.6	7
-77093.6	7
-77104.5	7
-77115.5	7
-77126.5	7
-77137.5	7
-77148.4	7
-77159.4	7
-77170.4	7
-77181.3	7
-77192.3	7
-77203.3	7
-77214.2	7
-77225.2	7
-77236.2	7
-77247.1	7
-77258.1	7
-77269.1	7
-77280	7
-77291	7
-77302	7
-77312.9	7
-77323.9	7
-77334.9	7
-77345.8	7
-77356.8	7
-77367.8	7
-77378.7	7
-77389.7	7
-77400.7	7
-77411.6	7
-77422.6	7
-77433.6	7
-77444.6	7
-77455.5	7
-77466.5	7
-77477.5	7
-77488.4	7
-77499.4	7
-77510.4	7
-77521.3	7
-77532.3	7
-77543.3	7
-77554.2	7
-77565.2	7
-77576.2	7
-77587.1	7
-77598.1	7
-77609.1	7
-77620	7
-77631	7
-77642	7
-77652.9	7
-77663.9	7
-77674.9	7
-77685.8	7
-77696.8	7
-77707.8	7
-77718.8	7
-77729.7	7
-77740.7	7
-77751.7	7
-77762.6	7
-77773.6	7
-77784.6	7
-77795.5	7
-77806.5	4
-77817.5	4
-77828.4	5
-77839.4	5
-77850.4	5
-77861.3	5
-77872.3	5
-77883.3	5
-77894.2	5
-77905.2	5
-77916.2	5
-77927.1	5
-77938.1	5
-77949.1	5
-77960	5
-77971	5
-77982	5
-77993	5
-78003.9	5
-78014.9	5
-78025.9	5
-78036.8	5
-78047.8	5
-78058.8	5
-78069.7	5
-78080.7	5
-78091.7	5
-78102.6	5
-78113.6	5
-78124.6	5
-78135.5	5
-78146.5	5
-78157.5	5
-78168.4	5
-78179.4	5
-78190.4	5
-78201.3	5
-78212.3	5
-78223.3	5
-78234.2	5
-78245.2	5
-78256.2	5
-78267.1	5
-78278.1	5
-78289.1	5
-78300.1	5
-78311	5
-78322	5
-78333	5
-78343.9	5
-78354.9	5
-78365.9	5
-78376.8	5
-78387.8	5
-78398.8	5
-78409.7	5
-78420.7	5
-78431.7	5
-78442.6	5
-78453.6	5
-78464.6	5
-78475.5	5
-78486.5	5
-78497.5	5
-78508.4	5
-78519.4	5
-78530.4	5
-78541.3	5
-78552.3	5
-78563.3	5
-78574.3	5
-78585.2	5
-78596.2	5
-78607.2	5
-78618.1	5
-78629.1	5
-78640.1	5
-78651	5
-78662	5
-78673	5
-78683.9	5
-78694.9	5
-78705.9	5
-78716.8	5
-78727.8	5
-78738.8	5
-78749.7	5
-78760.7	5
-78771.7	5
-78782.6	5
-78793.6	5
-78804.6	5
-78815.5	5
-78826.5	5
-78837.5	5
-78848.4	5
-78859.4	5
-78870.4	5
-78881.4	5
-78892.3	5
-78903.3	5
-78914.3	5
-78925.2	5
-78936.2	5
-78947.2	5
-78958.1	5
-78969.1	5
-78980.1	5
-78991	5
-79002	5
-79013	5
-79023.9	5
-79034.9	5
-79045.9	5
-79056.8	5
-79067.8	5
-79078.8	5
-79089.7	5
-79100.7	5
-79111.7	5
-79122.6	5
-79133.6	5
-79144.6	5
-79155.6	5
-79166.5	5
-79177.5	5
-79188.5	5
-79199.4	5
-79210.4	5
-79221.4	5
-79232.3	5
-79243.3	5
-79254.3	5
-79265.2	5
-79276.2	5
-79287.2	5
-79298.1	5
-79309.1	5
-79320.1	5
-79331	5
-79342	5
-79353	5
-79363.9	5
-79374.9	5
-79385.9	5
-79396.8	5
-79407.8	5
-79418.8	5
-79429.7	5
-79440.7	5
-79451.7	5
-79462.7	5
-79473.6	5
-79484.6	5
-79495.6	5
-79506.5	5
-79517.5	5
-79528.5	5
-79539.4	5
-79550.4	5
-79561.4	5
-79572.3	3
-79583.3	2
-79594.3	5
-79605.2	5
-79616.2	5
-79627.2	5
-79638.1	5
-79649.1	5
-79660.1	5
-79671	5
-79682	5
-79693	5
-79703.9	5
-79714.9	5
-79725.9	5
-79736.9	5
-79747.8	5
-79758.8	5
-79769.8	5
-79780.7	5
-79791.7	5
-79802.7	5
-79813.6	5
-79824.6	5
-79835.6	5
-79846.5	5
-79857.5	5
-79868.5	5
-79879.4	5
-79890.4	5
-79901.4	5
-79912.3	5
-79923.3	5
-79934.3	5
-79945.2	5
-79956.2	5
-79967.2	5
-79978.1	5
-79989.1	5
-80000.1	5
-80011	5
-80022	5
-80033	5
-80044	5
-80054.9	5
-80065.9	5
-80076.9	5
-80087.8	5
-80098.8	5
-80109.8	5
-80120.7	5
-80131.7	5
-80142.7	5
-80153.6	5
-80164.6	5
-80175.6	5
-80186.5	5
-80197.5	5
-80208.5	5
-80219.4	5
-80230.4	5
-80241.4	5
-80252.3	5
-80263.3	5
-80274.3	5
-80285.2	5
-80296.2	5
-80307.2	5
-80318.2	5
-80329.1	5
-80340.1	5
-80351.1	5
-80362	5
-80373	5
-80384	5
-80394.9	5
-80405.9	5
-80416.9	5
-80427.8	5
-80438.8	5
-80449.8	5
-80460.7	5
-80471.7	5
-80482.7	5
-80493.6	5
-80504.6	5
-80515.6	5
-80526.5	5
-80537.5	5
-80548.5	5
-80559.4	5
-80570.4	5
-80581.4	5
-80592.3	5
-80603.3	5
-80614.3	5
-80625.3	5
-80636.2	5
-80647.2	5
-80658.2	5
-80669.1	5
-80680.1	5
-80691.1	5
-80702	5
-80713	5
-80724	5
-80734.9	5
-80745.9	5
-80756.9	5
-80767.8	5
-80778.8	5
-80789.8	5
-80800.7	5
-80811.7	5
-80822.7	5
-80833.6	5
-80844.6	5
-80855.6	5
-80866.5	5
-80877.5	5
-80888.5	5
-80899.5	5
-80910.4	5
-80921.4	5
-80932.4	5
-80943.3	5
-80954.3	5
-80965.3	5
-80976.2	5
-80987.2	5
-80998.2	5
-81009.1	5
-81020.1	5
-81031.1	5
-81042	5
-81053	5
-81064	5
-81074.9	5
-81085.9	5
-81096.9	5
-81107.8	5
-81118.8	5
-81129.8	5
-81140.7	5
-81151.7	5
-81162.7	5
-81173.6	5
-81184.6	5
-81195.6	5
-81206.6	5
-81217.5	5
-81228.5	5
-81239.5	5
-81250.4	5
-81261.4	5
-81272.4	5
-81283.3	5
-81294.3	5
-81305.3	5
-81316.2	5
-81327.2	5
-81338.2	5
-81349.1	5
-81360.1	5
-81371.1	5
-81382	5
-81393	5
-81404	5
-81414.9	5
-81425.9	5
-81436.9	5
-81447.8	5
-81458.8	5
-81469.8	5
-81480.8	5
-81491.7	4
-81502.7	4
-81513.7	5
-81524.6	5
-81535.6	5
-81546.6	5
-81557.5	5
-81568.5	5
-81579.5	5
-81590.4	5
-81601.4	5
-81612.4	5
-81623.3	5
-81634.3	5
-81645.3	5
-81656.2	5
-81667.2	5
-81678.2	5
-81689.1	5
-81700.1	5
-81711.1	5
-81722	5
-81733	5
-81744	5
-81755	5
-81765.9	5
-81776.9	5
-81787.9	5
-81798.8	5
-81809.8	5
-81820.8	5
-81831.7	5
-81842.7	5
-81853.7	5
-81864.6	5
-81875.6	5
-81886.6	5
-81897.5	5
-81908.5	5
-81919.5	5
-81930.4	5
-81941.4	5
-81952.4	5
-81963.3	5
-81974.3	5
-81985.3	5
-81996.2	5
-82007.2	5
-82018.2	5
-82029.1	5
-82040.1	5
-82051.1	5
-82062.1	5
-82073	5
-82084	5
-82095	5
-82105.9	5
-82116.9	5
-82127.9	5
-82138.8	5
-82149.8	5
-82160.8	5
-82171.7	5
-82182.7	5
-82193.7	5
-82204.6	5
-82215.6	5
-82226.6	5
-82237.5	5
-82248.5	5
-82259.5	5
-82270.4	5
-82281.4	5
-82292.4	5
-82303.3	5
-82314.3	5
-82325.3	5
-82336.3	5
-82347.2	5
-82358.2	5
-82369.2	5
-82380.1	5
-82391.1	5
-82402.1	5
-82413	5
-82424	5
-82435	5
-82445.9	5
-82456.9	5
-82467.9	5
-82478.8	5
-82489.8	5
-82500.8	5
-82511.7	5
-82522.7	5
-82533.7	5
-82544.6	5
-82555.6	5
-82566.6	5
-82577.5	5
-82588.5	5
-82599.5	5
-82610.4	5
-82621.4	5
-82632.4	5
-82643.4	5
-82654.3	5
-82665.3	5
-82676.3	5
-82687.2	5
-82698.2	5
-82709.2	5
-82720.1	5
-82731.1	5
-82742.1	5
-82753	5
-82764	5
-82775	5
-82785.9	5
-82796.9	5
-82807.9	5
-82818.8	5
-82829.8	5
-82840.8	5
-82851.7	5
-82862.7	5
-82873.7	5
-82884.6	5
-82895.6	5
-82906.6	5
-82917.6	5
-82928.5	5
-82939.5	5
-82950.5	5
-82961.4	5
-82972.4	5
-82983.4	5
-82994.3	5
-83005.3	5
-83016.3	5
-83027.2	5
-83038.2	5
-83049.2	5
-83060.1	5
-83071.1	5
-83082.1	5
-83093	5
-83104	5
-83115	5
-83125.9	5
-83136.9	5
-83147.9	5
-83158.8	5
-83169.8	5
-83180.8	5
-83191.7	5
-83202.7	5
-83213.7	5
-83224.7	5
-83235.6	5
-83246.6	2
-83257.6	1
-83268.5	1
-83279.5	1
-83290.5	1
-83301.4	1
-83312.4	1
-83323.4	1
-83334.3	1
-83345.3	1
-83356.3	1
-83367.2	1
-83378.2	1
-83389.2	1
-83400.1	1
-83411.1	1
-83422.1	1
-83433	1
-83444	1
-83455	1
-83465.9	1
-83476.9	1
-83487.9	1
-83498.9	1
-83509.8	1
-83520.8	1
-83531.8	1
-83542.7	1
-83553.7	1
-83564.7	1
-83575.6	1
-83586.6	1
-83597.6	1
-83608.5	1
-83619.5	1
-83630.5	1
-83641.4	1
-83652.4	1
-83663.4	1
-83674.3	1
-83685.3	1
-83696.3	1
-83707.2	1
-83718.2	1
-83729.2	1
-83740.1	1
-83751.1	1
-83762.1	1
-83773	1
-83784	1
-83795	1
-83806	1
-83816.9	1
-83827.9	1
-83838.9	1
-83849.8	1
-83860.8	1
-83871.8	1
-83882.7	1
-83893.7	1
-83904.7	1
-83915.6	1
-83926.6	1
-83937.6	1
-83948.5	1
-83959.5	1
-83970.5	1
-83981.4	1
-83992.4	1
-84003.4	1
-84014.3	1
-84025.3	1
-84036.3	1
-84047.2	1
-84058.2	1
-84069.2	1
-84080.2	1
-84091.1	1
-84102.1	1
-84113.1	1
-84124	1
-84135	1
-84146	1
-84156.9	1
-84167.9	1
-84178.9	1
-84189.8	1
-84200.8	1
-84211.8	1
-84222.7	1
-84233.7	1
-84244.7	1
-84255.6	1
-84266.6	1
-84277.6	1
-84288.5	1
-84299.5	1
-84310.5	1
-84321.4	1
-84332.4	1
-84343.4	1
-84354.3	1
-84365.3	1
-84376.3	1
-84387.3	1
-84398.2	1
-84409.2	1
-84420.2	1
-84431.1	1
-84442.1	1
-84453.1	1
-84464	1
-84475	1
-84486	1
-84496.9	1
-84507.9	1
-84518.9	1
-84529.8	1
-84540.8	1
-84551.8	1
-84562.7	1
-84573.7	1
-84584.7	1
-84595.6	1
-84606.6	1
-84617.6	1
-84628.5	1
-84639.5	1
-84650.5	1
-84661.5	1
-84672.4	1
-84683.4	1
-84694.4	1
-84705.3	1
-84716.3	1
-84727.3	1
-84738.2	1
-84749.2	1
-84760.2	1
-84771.1	1
-84782.1	1
-84793.1	1
-84804	1
-84815	1
-84826	1
-84836.9	1
-84847.9	1
-84858.9	1
-84869.8	1
-84880.8	1
-84891.8	1
-84902.7	1
-84913.7	1
-84924.7	1
-84935.6	1
-84946.6	1
-84957.6	1
-84968.6	1
-84979.5	1
-84990.5	1
-85001.5	1
-85012.4	1
-85023.4	1
-85034.4	1
-85045.3	1
-85056.3	1
-85067.3	1
-85078.2	1
-85089.2	1
-85100.2	1
-85111.1	1
-85122.1	1
-85133.1	1
-85144	1
-85155	1
-85166	1
-85176.9
Deleted: SwiftApps/SciColSim/plot_cumulative.txt
--- SwiftApps/SciColSim/plot_cumulative.txt	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/plot_cumulative.txt	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,7989 +0,0 @@
-0	4
-10.6631	8
-21.3262	8
-31.9893	12
-42.6524	13
-53.3156	16
-63.9787	17
-74.6418	20
-85.3049	21
-95.968	24
-106.631	24
-117.294	28
-127.957	29
-138.62	32
-149.284	33
-159.947	35
-170.61	37
-181.273	40
-191.936	41
-202.599	43
-213.262	45
-223.925	47
-234.588	49
-245.252	51
-255.915	53
-266.578	55
-277.241	57
-287.904	57
-298.567	58
-309.23	61
-319.893	61
-330.556	63
-341.22	67
-351.883	74
-362.546	75
-373.209	79
-383.872	81
-394.535	83
-405.198	85
-415.861	89
-426.524	90
-437.188	93
-447.851	94
-458.514	98
-469.177	98
-479.84	101
-490.503	102
-501.166	103
-511.829	106
-522.492	107
-533.155	110
-543.819	114
-554.482	118
-565.145	118
-575.808	121
-586.471	122
-597.134	122
-607.797	125
-618.46	127
-629.123	127
-639.787	129
-650.45	132
-661.113	134
-671.776	136
-682.439	136
-693.102	139
-703.765	143
-714.428	147
-725.091	148
-735.755	150
-746.418	152
-757.081	153
-767.744	156
-778.407	160
-789.07	162
-799.733	164
-810.396	164
-821.059	164
-831.723	168
-842.386	169
-853.049	175
-863.712	175
-874.375	176
-885.038	179
-895.701	182
-906.364	186
-917.027	190
-927.691	190
-938.354	194
-949.017	195
-959.68	198
-970.343	199
-981.006	202
-991.669	203
-1002.33	206
-1013	207
-1023.66	210
-1034.32	210
-1044.98	211
-1055.65	213
-1066.31	215
-1076.97	217
-1087.64	219
-1098.3	222
-1108.96	224
-1119.63	224
-1130.29	227
-1140.95	228
-1151.62	231
-1162.28	233
-1172.94	236
-1183.61	241
-1194.27	242
-1204.93	243
-1215.59	246
-1226.26	247
-1236.92	250
-1247.58	252
-1258.25	254
-1268.91	256
-1279.57	259
-1290.24	260
-1300.9	263
-1311.56	264
-1322.23	266
-1332.89	267
-1343.55	269
-1354.21	271
-1364.88	273
-1375.54	275
-1386.2	276
-1396.87	278
-1407.53	281
-1418.19	285
-1428.86	285
-1439.52	288
-1450.18	290
-1460.85	290
-1471.51	291
-1482.17	294
-1492.84	297
-1503.5	298
-1514.16	301
-1524.82	302
-1535.49	306
-1546.15	307
-1556.81	310
-1567.48	312
-1578.14	313
-1588.8	315
-1599.47	317
-1610.13	317
-1620.79	319
-1631.46	321
-1642.12	324
-1652.78	327
-1663.45	328
-1674.11	331
-1684.77	333
-1695.43	333
-1706.1	335
-1716.76	338
-1727.42	340
-1738.09	342
-1748.75	344
-1759.41	346
-1770.08	347
-1780.74	351
-1791.4	351
-1802.07	352
-1812.73	355
-1823.39	355
-1834.05	356
-1844.72	361
-1855.38	362
-1866.04	362
-1876.71	365
-1887.37	366
-1898.03	370
-1908.7	371
-1919.36	373
-1930.02	375
-1940.69	376
-1951.35	379
-1962.01	380
-1972.68	383
-1983.34	386
-1994	387
-2004.66	389
-2015.33	391
-2025.99	393
-2036.65	396
-2047.32	398
-2057.98	401
-2068.64	402
-2079.31	405
-2089.97	405
-2100.63	407
-2111.3	409
-2121.96	411
-2132.62	413
-2143.29	415
-2153.95	415
-2164.61	417
-2175.27	419
-2185.94	421
-2196.6	424
-2207.26	425
-2217.93	427
-2228.59	428
-2239.25	430
-2249.92	432
-2260.58	433
-2271.24	435
-2281.91	439
-2292.57	443
-2303.23	444
-2313.89	445
-2324.56	448
-2335.22	449
-2345.88	453
-2356.55	453
-2367.21	456
-2377.87	457
-2388.54	461
-2399.2	461
-2409.86	464
-2420.53	465
-2431.19	468
-2441.85	470
-2452.52	472
-2463.18	474
-2473.84	474
-2484.5	477
-2495.17	479
-2505.83	481
-2516.49	484
-2527.16	486
-2537.82	488
-2548.48	490
-2559.15	492
-2569.81	493
-2580.47	496
-2591.14	497
-2601.8	500
-2612.46	501
-2623.13	501
-2633.79	504
-2644.45	505
-2655.11	508
-2665.78	509
-2676.44	512
-2687.1	513
-2697.77	514
-2708.43	516
-2719.09	518
-2729.76	520
-2740.42	522
-2751.08	524
-2761.75	526
-2772.41	526
-2783.07	529
-2793.73	531
-2804.4	534
-2815.06	536
-2825.72	538
-2836.39	540
-2847.05	542
-2857.71	545
-2868.38	545
-2879.04	545
-2889.7	549
-2900.37	551
-2911.03	553
-2921.69	553
-2932.36	558
-2943.02	560
-2953.68	563
-2964.34	567
-2975.01	568
-2985.67	569
-2996.33	571
-3007	572
-3017.66	575
-3028.32	576
-3038.99	576
-3049.65	579
-3060.31	581
-3070.98	583
-3081.64	585
-3092.3	586
-3102.97	586
-3113.63	589
-3124.29	590
-3134.95	594
-3145.62	595
-3156.28	597
-3166.94	598
-3177.61	599
-3188.27	602
-3198.93	605
-3209.6	606
-3220.26	607
-3230.92	609
-3241.59	612
-3252.25	613
-3262.91	615
-3273.57	617
-3284.24	618
-3294.9	622
-3305.56	622
-3316.23	625
-3326.89	626
-3337.55	630
-3348.22	634
-3358.88	638
-3369.54	639
-3380.21	642
-3390.87	643
-3401.53	646
-3412.2	647
-3422.86	650
-3433.52	652
-3444.18	653
-3454.85	658
-3465.51	661
-3476.17	665
-3486.84	668
-3497.5	672
-3508.16	673
-3518.83	673
-3529.49	676
-3540.15	677
-3550.82	679
-3561.48	680
-3572.14	681
-3582.8	684
-3593.47	685
-3604.13	688
-3614.79	689
-3625.46	693
-3636.12	694
-3646.78	696
-3657.45	697
-3668.11	698
-3678.77	701
-3689.44	702
-3700.1	706
-3710.76	706
-3721.43	709
-3732.09	710
-3742.75	712
-3753.41	714
-3764.08	715
-3774.74	717
-3785.4	719
-3796.07	722
-3806.73	722
-3817.39	724
-3828.06	726
-3838.72	729
-3849.38	732
-3860.05	736
-3870.71	737
-3881.37	737
-3892.04	739
-3902.7	741
-3913.36	744
-3924.02	745
-3934.69	749
-3945.35	749
-3956.01	752
-3966.68	753
-3977.34	756
-3988	757
-3998.67	760
-4009.33	762
-4019.99	764
-4030.66	768
-4041.32	768
-4051.98	770
-4062.64	771
-4073.31	776
-4083.97	778
-4094.63	778
-4105.3	780
-4115.96	782
-4126.62	784
-4137.29	784
-4147.95	787
-4158.61	788
-4169.28	790
-4179.94	792
-4190.6	795
-4201.27	796
-4211.93	797
-4222.59	800
-4233.25	804
-4243.92	804
-4254.58	806
-4265.24	808
-4275.91	810
-4286.57	813
-4297.23	815
-4307.9	817
-4318.56	818
-4329.22	820
-4339.89	824
-4350.55	824
-4361.21	829
-4371.88	834
-4382.54	838
-4393.2	842
-4403.86	846
-4414.53	846
-4425.19	848
-4435.85	850
-4446.52	852
-4457.18	856
-4467.84	858
-4478.51	861
-4489.17	863
-4499.83	865
-4510.5	867
-4521.16	868
-4531.82	869
-4542.48	871
-4553.15	872
-4563.81	873
-4574.47	876
-4585.14	877
-4595.8	878
-4606.46	880
-4617.13	880
-4627.79	884
-4638.45	884
-4649.12	886
-4659.78	889
-4670.44	889
-4681.11	891
-4691.77	893
-4702.43	895
-4713.09	898
-4723.76	900
-4734.42	902
-4745.08	904
-4755.75	906
-4766.41	908
-4777.07	912
-4787.74	913
-4798.4	914
-4809.06	918
-4819.73	920
-4830.39	922
-4841.05	924
-4851.72	926
-4862.38	928
-4873.04	930
-4883.7	933
-4894.37	935
-4905.03	938
-4915.69	940
-4926.36	942
-4937.02	944
-4947.68	946
-4958.35	948
-4969.01	951
-4979.67	953
-4990.34	955
-5001	957
-5011.66	957
-5022.32	960
-5032.99	962
-5043.65	963
-5054.31	966
-5064.98	968
-5075.64	971
-5086.3	971
-5096.97	973
-5107.63	975
-5118.29	977
-5128.96	979
-5139.62	981
-5150.28	983
-5160.95	984
-5171.61	984
-5182.27	987
-5192.93	987
-5203.6	991
-5214.26	996
-5224.92	997
-5235.59	1001
-5246.25	1005
-5256.91	1008
-5267.58	1010
-5278.24	1012
-5288.9	1014
-5299.57	1016
-5310.23	1018
-5320.89	1020
-5331.55	1022
-5342.22	1024
-5352.88	1026
-5363.54	1028
-5374.21	1028
-5384.87	1030
-5395.53	1032
-5406.2	1032
-5416.86	1035
-5427.52	1036
-5438.19	1040
-5448.85	1043
-5459.51	1047
-5470.18	1051
-5480.84	1054
-5491.5	1055
-5502.16	1058
-5512.83	1061
-5523.49	1065
-5534.15	1069
-5544.82	1073
-5555.48	1077
-5566.14	1079
-5576.81	1082
-5587.47	1084
-5598.13	1087
-5608.8	1088
-5619.46	1090
-5630.12	1092
-5640.79	1092
-5651.45	1095
-5662.11	1098
-5672.77	1099
-5683.44	1101
-5694.1	1103
-5704.76	1105
-5715.43	1107
-5726.09	1109
-5736.75	1111
-5747.42	1115
-5758.08	1117
-5768.74	1119
-5779.41	1121
-5790.07	1123
-5800.73	1124
-5811.39	1127
-5822.06	1128
-5832.72	1132
-5843.38	1134
-5854.05	1134
-5864.71	1136
-5875.37	1138
-5886.04	1138
-5896.7	1140
-5907.36	1141
-5918.03	1143
-5928.69	1144
-5939.35	1146
-5950.02	1148
-5960.68	1151
-5971.34	1153
-5982	1154
-5992.67	1155
-6003.33	1157
-6013.99	1160
-6024.66	1162
-6035.32	1164
-6045.98	1166
-6056.65	1166
-6067.31	1169
-6077.97	1171
-6088.64	1173
-6099.3	1175
-6109.96	1177
-6120.63	1179
-6131.29	1179
-6141.95	1182
-6152.61	1184
-6163.28	1186
-6173.94	1188
-6184.6	1191
-6195.27	1194
-6205.93	1195
-6216.59	1199
-6227.26	1203
-6237.92	1205
-6248.58	1207
-6259.25	1209
-6269.91	1212
-6280.57	1214
-6291.23	1216
-6301.9	1219
-6312.56	1221
-6323.22	1222
-6333.89	1223
-6344.55	1226
-6355.21	1227
-6365.88	1227
-6376.54	1230
-6387.2	1231
-6397.87	1231
-6408.53	1234
-6419.19	1235
-6429.86	1238
-6440.52	1239
-6451.18	1240
-6461.84	1243
-6472.51	1244
-6483.17	1245
-6493.83	1248
-6504.5	1249
-6515.16	1252
-6525.82	1256
-6536.49	1259
-6547.15	1260
-6557.81	1263
-6568.48	1264
-6579.14	1267
-6589.8	1268
-6600.47	1271
-6611.13	1272
-6621.79	1275
-6632.45	1276
-6643.12	1280
-6653.78	1280
-6664.44	1283
-6675.11	1285
-6685.77	1288
-6696.43	1289
-6707.1	1293
-6717.76	1294
-6728.42	1298
-6739.09	1299
-6749.75	1301
-6760.41	1306
-6771.07	1307
-6781.74	1308
-6792.4	1311
-6803.06	1313
-6813.73	1316
-6824.39	1317
-6835.05	1320
-6845.72	1321
-6856.38	1324
-6867.04	1325
-6877.71	1328
-6888.37	1329
-6899.03	1329
-6909.7	1332
-6920.36	1336
-6931.02	1338
-6941.68	1339
-6952.35	1342
-6963.01	1342
-6973.67	1343
-6984.34	1346
-6995	1347
-7005.66	1347
-7016.33	1350
-7026.99	1351
-7037.65	1353
-7048.32	1354
-7058.98	1356
-7069.64	1357
-7080.31	1358
-7090.97	1359
-7101.63	1362
-7112.29	1363
-7122.96	1366
-7133.62	1367
-7144.28	1370
-7154.95	1371
-7165.61	1374
-7176.27	1377
-7186.94	1378
-7197.6	1380
-7208.26	1385
-7218.93	1387
-7229.59	1391
-7240.25	1394
-7250.91	1395
-7261.58	1400
-7272.24	1400
-7282.9	1402
-7293.57	1404
-7304.23	1406
-7314.89	1408
-7325.56	1410
-7336.22	1412
-7346.88	1414
-7357.55	1418
-7368.21	1421
-7378.87	1422
-7389.54	1424
-7400.2	1426
-7410.86	1428
-7421.52	1430
-7432.19	1431
-7442.85	1436
-7453.51	1437
-7464.18	1439
-7474.84	1441
-7485.5	1441
-7496.17	1444
-7506.83	1449
-7517.49	1450
-7528.16	1450
-7538.82	1452
-7549.48	1454
-7560.14	1458
-7570.81	1461
-7581.47	1462
-7592.13	1465
-7602.8	1466
-7613.46	1469
-7624.12	1470
-7634.79	1473
-7645.45	1474
-7656.11	1477
-7666.78	1478
-7677.44	1481
-7688.1	1482
-7698.77	1485
-7709.43	1487
-7720.09	1490
-7730.75	1491
-7741.42	1492
-7752.08	1494
-7762.74	1495
-7773.41	1498
-7784.07	1499
-7794.73	1502
-7805.4	1502
-7816.06	1503
-7826.72	1506
-7837.39	1508
-7848.05	1515
-7858.71	1516
-7869.38	1520
-7880.04	1520
-7890.7	1524
-7901.36	1528
-7912.03	1529
-7922.69	1532
-7933.35	1533
-7944.02	1537
-7954.68	1541
-7965.34	1542
-7976.01	1545
-7986.67	1547
-7997.33	1550
-8008	1551
-8018.66	1553
-8029.32	1553
-8039.98	1555
-8050.65	1557
-8061.31	1559
-8071.97	1561
-8082.64	1562
-8093.3	1564
-8103.96	1565
-8114.63	1567
-8125.29	1569
-8135.95	1571
-8146.62	1573
-8157.28	1575
-8167.94	1575
-8178.61	1576
-8189.27	1579
-8199.93	1581
-8210.59	1583
-8221.26	1585
-8231.92	1587
-8242.58	1590
-8253.25	1593
-8263.91	1595
-8274.57	1597
-8285.24	1599
-8295.9	1601
-8306.56	1604
-8317.23	1606
-8327.89	1608
-8338.55	1610
-8349.22	1612
-8359.88	1614
-8370.54	1615
-8381.2	1617
-8391.87	1618
-8402.53	1621
-8413.19	1623
-8423.86	1623
-8434.52	1626
-8445.18	1629
-8455.85	1631
-8466.51	1633
-8477.17	1636
-8487.84	1638
-8498.5	1640
-8509.16	1643
-8519.82	1645
-8530.49	1647
-8541.15	1649
-8551.81	1651
-8562.48	1653
-8573.14	1655
-8583.8	1657
-8594.47	1657
-8605.13	1661
-8615.79	1661
-8626.46	1664
-8637.12	1665
-8647.78	1668
-8658.45	1669
-8669.11	1673
-8679.77	1673
-8690.43	1677
-8701.1	1678
-8711.76	1681
-8722.42	1682
-8733.09	1685
-8743.75	1690
-8754.41	1694
-8765.08	1698
-8775.74	1701
-8786.4	1704
-8797.07	1705
-8807.73	1709
-8818.39	1709
-8829.06	1713
-8839.72	1717
-8850.38	1721
-8861.04	1721
-8871.71	1725
-8882.37	1729
-8893.03	1731
-8903.7	1733
-8914.36	1735
-8925.02	1737
-8935.69	1739
-8946.35	1741
-8957.01	1743
-8967.68	1745
-8978.34	1747
-8989	1749
-8999.66	1751
-9010.33	1753
-9020.99	1757
-9031.65	1762
-9042.32	1768
-9052.98	1769
-9063.64	1772
-9074.31	1773
-9084.97	1777
-9095.63	1777
-9106.3	1781
-9116.96	1785
-9127.62	1785
-9138.29	1787
-9148.95	1789
-9159.61	1790
-9170.27	1793
-9180.94	1793
-9191.6	1794
-9202.26	1797
-9212.93	1798
-9223.59	1801
-9234.25	1802
-9244.92	1805
-9255.58	1806
-9266.24	1809
-9276.91	1811
-9287.57	1813
-9298.23	1815
-9308.9	1817
-9319.56	1819
-9330.22	1820
-9340.88	1822
-9351.55	1823
-9362.21	1825
-9372.87	1828
-9383.54	1831
-9394.2	1837
-9404.86	1837
-9415.53	1841
-9426.19	1841
-9436.85	1845
-9447.52	1849
-9458.18	1853
-9468.84	1857
-9479.5	1861
-9490.17	1861
-9500.83	1866
-9511.49	1866
-9522.16	1869
-9532.82	1870
-9543.48	1871
-9554.15	1874
-9564.81	1875
-9575.47	1879
-9586.14	1884
-9596.8	1888
-9607.46	1889
-9618.13	1892
-9628.79	1893
-9639.45	1893
-9650.11	1896
-9660.78	1897
-9671.44	1900
-9682.1	1901
-9692.77	1904
-9703.43	1905
-9714.09	1907
-9724.76	1909
-9735.42	1910
-9746.08	1913
-9756.75	1917
-9767.41	1918
-9778.07	1921
-9788.73	1923
-9799.4	1927
-9810.06	1927
-9820.72	1930
-9831.39	1932
-9842.05	1936
-9852.71	1937
-9863.38	1939
-9874.04	1941
-9884.7	1945
-9895.37	1948
-9906.03	1948
-9916.69	1950
-9927.36	1952
-9938.02	1954
-9948.68	1957
-9959.34	1958
-9970.01	1961
-9980.67	1962
-9991.33	1962
-10002	1965
-10012.7	1966
-10023.3	1969
-10034	1969
-10044.6	1970
-10055.3	1973
-10066	1974
-10076.6	1977
-10087.3	1978
-10098	1982
-10108.6	1983
-10119.3	1985
-10130	1988
-10140.6	1988
-10151.3	1991
-10161.9	1993
-10172.6	1997
-10183.3	1997
-10193.9	1998
-10204.6	2001
-10215.3	2004
-10225.9	2006
-10236.6	2008
-10247.2	2013
-10257.9	2014
-10268.6	2016
-10279.2	2018
-10289.9	2020
-10300.6	2022
-10311.2	2026
-10321.9	2026
-10332.6	2027
-10343.2	2029
-10353.9	2030
-10364.5	2031
-10375.2	2034
-10385.9	2035
-10396.5	2037
-10407.2	2040
-10417.9	2043
-10428.5	2046
-10439.2	2049
-10449.8	2050
-10460.5	2052
-10471.2	2054
-10481.8	2058
-10492.5	2059
-10503.2	2063
-10513.8	2067
-10524.5	2068
-10535.2	2070
-10545.8	2073
-10556.5	2073
-10567.1	2075
-10577.8	2077
-10588.5	2079
-10599.1	2081
-10609.8	2083
-10620.5	2086
-10631.1	2087
-10641.8	2089
-10652.4	2092
-10663.1	2094
-10673.8	2096
-10684.4	2098
-10695.1	2103
-10705.8	2104
-10716.4	2107
-10727.1	2108
-10737.8	2110
-10748.4	2112
-10759.1	2113
-10769.7	2116
-10780.4	2117
-10791.1	2118
-10801.7	2120
-10812.4	2122
-10823.1	2124
-10833.7	2126
-10844.4	2128
-10855	2130
-10865.7	2131
-10876.4	2133
-10887	2134
-10897.7	2136
-10908.4	2138
-10919	2139
-10929.7	2142
-10940.4	2144
-10951	2147
-10961.7	2149
-10972.3	2151
-10983	2153
-10993.7	2153
-11004.3	2154
-11015	2156
-11025.7	2160
-11036.3	2161
-11047	2162
-11057.6	2165
-11068.3	2167
-11079	2167
-11089.6	2171
-11100.3	2172
-11111	2175
-11121.6	2177
-11132.3	2180
-11142.9	2181
-11153.6	2183
-11164.3	2185
-11174.9	2188
-11185.6	2190
-11196.3	2192
-11206.9	2195
-11217.6	2198
-11228.3	2199
-11238.9	2201
-11249.6	2203
-11260.2	2205
-11270.9	2208
-11281.6	2210
-11292.2	2212
-11302.9	2215
-11313.6	2217
-11324.2	2219
-11334.9	2224
-11345.5	2225
-11356.2	2228
-11366.9	2229
-11377.5	2233
-11388.2	2235
-11398.9	2238
-11409.5	2239
-11420.2	2243
-11430.9	2243
-11441.5	2246
-11452.2	2251
-11462.8	2252
-11473.5	2254
-11484.2	2255
-11494.8	2257
-11505.5	2258
-11516.2	2259
-11526.8	2262
-11537.5	2264
-11548.1	2267
-11558.8	2268
-11569.5	2272
-11580.1	2272
-11590.8	2273
-11601.5	2276
-11612.1	2278
-11622.8	2281
-11633.5	2282
-11644.1	2285
-11654.8	2286
-11665.4	2290
-11676.1	2291
-11686.8	2294
-11697.4	2296
-11708.1	2298
-11718.8	2302
-11729.4	2307
-11740.1	2311
-11750.7	2315
-11761.4	2318
-11772.1	2319
-11782.7	2322
-11793.4	2324
-11804.1	2328
-11814.7	2330
-11825.4	2332
-11836.1	2333
-11846.7	2335
-11857.4	2336
-11868	2337
-11878.7	2339
-11889.4	2340
-11900	2341
-11910.7	2343
-11921.4	2344
-11932	2346
-11942.7	2349
-11953.3	2351
-11964	2353
-11974.7	2355
-11985.3	2357
-11996	2358
-12006.7	2362
-12017.3	2364
-12028	2367
-12038.7	2370
-12049.3	2371
-12060	2375
-12070.6	2376
-12081.3	2379
-12092	2380
-12102.6	2385
-12113.3	2385
-12124	2386
-12134.6	2389
-12145.3	2390
-12155.9	2393
-12166.6	2398
-12177.3	2398
-12187.9	2400
-12198.6	2402
-12209.3	2404
-12219.9	2406
-12230.6	2407
-12241.3	2409
-12251.9	2410
-12262.6	2411
-12273.2	2414
-12283.9	2418
-12294.6	2422
-12305.2	2426
-12315.9	2431
-12326.6	2433
-12337.2	2435
-12347.9	2437
-12358.5	2438
-12369.2	2441
-12379.9	2442
-12390.5	2445
-12401.2	2446
-12411.9	2450
-12422.5	2450
-12433.2	2454
-12443.8	2458
-12454.5	2462
-12465.2	2465
-12475.8	2467
-12486.5	2469
-12497.2	2472
-12507.8	2474
-12518.5	2476
-12529.2	2478
-12539.8	2480
-12550.5	2482
-12561.1	2483
-12571.8	2484
-12582.5	2487
-12593.1	2488
-12603.8	2492
-12614.5	2496
-12625.1	2500
-12635.8	2504
-12646.4	2507
-12657.1	2508
-12667.8	2512
-12678.4	2517
-12689.1	2517
-12699.8	2519
-12710.4	2521
-12721.1	2521
-12731.8	2523
-12742.4	2526
-12753.1	2526
-12763.7	2528
-12774.4	2530
-12785.1	2532
-12795.7	2534
-12806.4	2536
-12817.1	2538
-12827.7	2540
-12838.4	2542
-12849	2544
-12859.7	2547
-12870.4	2547
-12881	2549
-12891.7	2550
-12902.4	2552
-12913	2554
-12923.7	2555
-12934.4	2557
-12945	2559
-12955.7	2561
-12966.3	2564
-12977	2565
-12987.7	2567
-12998.3	2571
-13009	2572
-13019.7	2573
-13030.3	2577
-13041	2578
-13051.6	2580
-13062.3	2582
-13073	2584
-13083.6	2586
-13094.3	2588
-13105	2590
-13115.6	2592
-13126.3	2594
-13137	2596
-13147.6	2598
-13158.3	2601
-13168.9	2601
-13179.6	2604
-13190.3	2605
-13200.9	2607
-13211.6	2608
-13222.3	2610
-13232.9	2612
-13243.6	2615
-13254.2	2617
-13264.9	2620
-13275.6	2622
-13286.2	2624
-13296.9	2625
-13307.6	2628
-13318.2	2629
-13328.9	2632
-13339.6	2633
-13350.2	2636
-13360.9	2638
-13371.5	2639
-13382.2	2643
-13392.9	2643
-13403.5	2644
-13414.2	2647
-13424.9	2647
-13435.5	2649
-13446.2	2652
-13456.8	2652
-13467.5	2655
-13478.2	2658
-13488.8	2662
-13499.5	2663
-13510.2	2665
-13520.8	2667
-13531.5	2669
-13542.1	2671
-13552.8	2673
-13563.5	2675
-13574.1	2677
-13584.8	2679
-13595.5	2681
-13606.1	2681
-13616.8	2681
-13627.5	2681
-13638.1	2681
-13648.8	2681
-13659.4	2682
-13670.1	2685
-13680.8	2685
-13691.4	2685
-13702.1	2687
-13712.8	2689
-13723.4	2691
-13734.1	2694
-13744.7	2697
-13755.4	2700
-13766.1	2702
-13776.7	2705
-13787.4	2708
-13798.1	2710
-13808.7	2711
-13819.4	2713
-13830.1	2714
-13840.7	2718
-13851.4	2721
-13862	2721
-13872.7	2724
-13883.4	2724
-13894	2726
-13904.7	2728
-13915.4	2731
-13926	2732
-13936.7	2734
-13947.3	2735
-13958	2737
-13968.7	2738
-13979.3	2740
-13990	2742
-14000.7	2743
-14011.3	2745
-14022	2746
-14032.7	2746
-14043.3	2747
-14054	2750
-14064.6	2750
-14075.3	2751
-14086	2752
-14096.6	2754
-14107.3	2756
-14118	2758
-14128.6	2759
-14139.3	2760
-14149.9	2761
-14160.6	2763
-14171.3	2764
-14181.9	2766
-14192.6	2768
-14203.3	2772
-14213.9	2772
-14224.6	2776
-14235.3	2779
-14245.9	2782
-14256.6	2785
-14267.2	2786
-14277.9	2788
-14288.6	2790
-14299.2	2792
-14309.9	2794
-14320.6	2795
-14331.2	2797
-14341.9	2798
-14352.5	2800
-14363.2	2801
-14373.9	2803
-14384.5	2805
-14395.2	2806
-14405.9	2809
-14416.5	2810
-14427.2	2814
-14437.9	2814
-14448.5	2816
-14459.2	2818
-14469.8	2821
-14480.5	2823
-14491.2	2825
-14501.8	2828
-14512.5	2828
-14523.2	2831
-14533.8	2834
-14544.5	2835
-14555.1	2837
-14565.8	2840
-14576.5	2842
-14587.1	2844
-14597.8	2846
-14608.5	2848
-14619.1	2849
-14629.8	2851
-14640.5	2853
-14651.1	2854
-14661.8	2856
-14672.4	2858
-14683.1	2860
-14693.8	2862
-14704.4	2864
-14715.1	2866
-14725.8	2868
-14736.4	2870
-14747.1	2871
-14757.7	2873
-14768.4	2874
-14779.1	2875
-14789.7	2878
-14800.4	2880
-14811.1	2883
-14821.7	2884
-14832.4	2887
-14843	2890
-14853.7	2890
-14864.4	2891
-14875	2894
-14885.7	2895
-14896.4	2898
-14907	2899
-14917.7	2899
-14928.4	2902
-14939	2904
-14949.7	2909
-14960.3	2912
-14971	2914
-14981.7	2916
-14992.3	2920
-15003	2921
-15013.7	2923
-15024.3	2925
-15035	2927
-15045.6	2929
-15056.3	2931
-15067	2933
-15077.6	2935
-15088.3	2937
-15099	2939
-15109.6	2940
-15120.3	2941
-15131	2943
-15141.6	2944
-15152.3	2945
-15162.9	2948
-15173.6	2949
-15184.3	2951
-15194.9	2953
-15205.6	2955
-15216.3	2958
-15226.9	2961
-15237.6	2967
-15248.2	2968
-15258.9	2969
-15269.6	2972
-15280.2	2973
-15290.9	2973
-15301.6	2977
-15312.2	2981
-15322.9	2985
-15333.6	2990
-15344.2	2991
-15354.9	2996
-15365.5	2996
-15376.2	2998
-15386.9	3000
-15397.5	3001
-15408.2	3002
-15418.9	3005
-15429.5	3008
-15440.2	3008
-15450.8	3010
-15461.5	3012
-15472.2	3014
-15482.8	3015
-15493.5	3016
-15504.2	3018
-15514.8	3022
-15525.5	3023
-15536.2	3024
-15546.8	3027
-15557.5	3028
-15568.1	3031
-15578.8	3032
-15589.5	3033
-15600.1	3036
-15610.8	3039
-15621.5	3040
-15632.1	3040
-15642.8	3041
-15653.4	3042
-15664.1	3042
-15674.8	3042
-15685.4	3042
-15696.1	3042
-15706.8	3042
-15717.4	3042
-15728.1	3042
-15738.8	3042
-15749.4	3042
-15760.1	3042
-15770.7	3042
-15781.4	3042
-15792.1	3042
-15802.7	3042
-15813.4	3042
-15824.1	3042
-15834.7	3042
-15845.4	3042
-15856	3042
-15866.7	3042
-15877.4	3043
-15888	3044
-15898.7	3045
-15909.4	3046
-15920	3047
-15930.7	3047
-15941.3	3048
-15952	3049
-15962.7	3049
-15973.3	3050
-15984	3051
-15994.7	3052
-16005.3	3052
-16016	3053
-16026.7	3054
-16037.3	3055
-16048	3056
-16058.6	3058
-16069.3	3059
-16080	3060
-16090.6	3061
-16101.3	3062
-16112	3063
-16122.6	3064
-16133.3	3065
-16143.9	3066
-16154.6	3068
-16165.3	3070
-16175.9	3072
-16186.6	3073
-16197.3	3074
-16207.9	3074
-16218.6	3076
-16229.3	3078
-16239.9	3079
-16250.6	3080
-16261.2	3081
-16271.9	3082
-16282.6	3083
-16293.2	3084
-16303.9	3085
-16314.6	3086
-16325.2	3087
-16335.9	3088
-16346.5	3089
-16357.2	3090
-16367.9	3092
-16378.5	3093
-16389.2	3094
-16399.9	3095
-16410.5	3096
-16421.2	3097
-16431.9	3097
-16442.5	3098
-16453.2	3099
-16463.8	3100
-16474.5	3101
-16485.2	3102
-16495.8	3103
-16506.5	3104
-16517.2	3105
-16527.8	3106
-16538.5	3107
-16549.1	3108
-16559.8	3109
-16570.5	3110
-16581.1	3111
-16591.8	3112
-16602.5	3113
-16613.1	3114
-16623.8	3115
-16634.5	3116
-16645.1	3116
-16655.8	3117
-16666.4	3119
-16677.1	3121
-16687.8	3123
-16698.4	3123
-16709.1	3124
-16719.8	3125
-16730.4	3126
-16741.1	3127
-16751.7	3128
-16762.4	3129
-16773.1	3129
-16783.7	3130
-16794.4	3131
-16805.1	3132
-16815.7	3133
-16826.4	3134
-16837.1	3135
-16847.7	3136
-16858.4	3137
-16869	3138
-16879.7	3139
-16890.4	3139
-16901	3140
-16911.7	3142
-16922.4	3142
-16933	3144
-16943.7	3144
-16954.3	3145
-16965	3146
-16975.7	3147
-16986.3	3148
-16997	3150
-17007.7	3152
-17018.3	3155
-17029	3156
-17039.6	3156
-17050.3	3157
-17061	3158
-17071.6	3158
-17082.3	3158
-17093	3158
-17103.6	3158
-17114.3	3158
-17125	3159
-17135.6	3159
-17146.3	3159
-17156.9	3159
-17167.6	3159
-17178.3	3159
-17188.9	3160
-17199.6	3160
-17210.3	3160
-17220.9	3160
-17231.6	3160
-17242.2	3160
-17252.9	3160
-17263.6	3161
-17274.2	3161
-17284.9	3161
-17295.6	3161
-17306.2	3161
-17316.9	3161
-17327.6	3162
-17338.2	3162
-17348.9	3162
-17359.5	3162
-17370.2	3162
-17380.9	3162
-17391.5	3162
-17402.2	3163
-17412.9	3168
-17423.5	3168
-17434.2	3173
-17444.8	3177
-17455.5	3178
-17466.2	3181
-17476.8	3183
-17487.5	3186
-17498.2	3187
-17508.8	3188
-17519.5	3192
-17530.2	3194
-17540.8	3197
-17551.5	3199
-17562.1	3202
-17572.8	3204
-17583.5	3207
-17594.1	3213
-17604.8	3215
-17615.5	3217
-17626.1	3220
-17636.8	3222
-17647.4	3225
-17658.1	3227
-17668.8	3230
-17679.4	3232
-17690.1	3236
-17700.8	3238
-17711.4	3242
-17722.1	3244
-17732.8	3247
-17743.4	3250
-17754.1	3252
-17764.7	3253
-17775.4	3256
-17786.1	3259
-17796.7	3259
-17807.4	3262
-17818.1	3265
-17828.7	3268
-17839.4	3270
-17850	3270
-17860.7	3273
-17871.4	3276
-17882	3279
-17892.7	3282
-17903.4	3282
-17914	3284
-17924.7	3286
-17935.4	3287
-17946	3289
-17956.7	3292
-17967.3	3293
-17978	3294
-17988.7	3297
-17999.3	3299
-18010	3302
-18020.7	3304
-18031.3	3305
-18042	3308
-18052.6	3313
-18063.3	3314
-18074	3316
-18084.6	3317
-18095.3	3318
-18106	3318
-18116.6	3318
-18127.3	3318
-18138	3318
-18148.6	3318
-18159.3	3318
-18169.9	3318
-18180.6	3318
-18191.3	3318
-18201.9	3318
-18212.6	3318
-18223.3	3318
-18233.9	3318
-18244.6	3318
-18255.2	3318
-18265.9	3318
-18276.6	3318
-18287.2	3318
-18297.9	3318
-18308.6	3318
-18319.2	3318
-18329.9	3319
-18340.5	3320
-18351.2	3320
-18361.9	3321
-18372.5	3322
-18383.2	3322
-18393.9	3322
-18404.5	3322
-18415.2	3322
-18425.9	3322
-18436.5	3322
-18447.2	3322
-18457.8	3322
-18468.5	3322
-18479.2	3322
-18489.8	3322
-18500.5	3322
-18511.2	3322
-18521.8	3322
-18532.5	3322
-18543.1	3322
-18553.8	3322
-18564.5	3322
-18575.1	3322
-18585.8	3322
-18596.5	3322
-18607.1	3322
-18617.8	3322
-18628.5	3322
-18639.1	3322
-18649.8	3322
-18660.4	3322
-18671.1	3322
-18681.8	3322
-18692.4	3322
-18703.1	3322
-18713.8	3322
-18724.4	3322
-18735.1	3322
-18745.7	3322
-18756.4	3322
-18767.1	3322
-18777.7	3322
-18788.4	3322
-18799.1	3322
-18809.7	3322
-18820.4	3322
-18831.1	3322
-18841.7	3322
-18852.4	3322
-18863	3322
-18873.7	3322
-18884.4	3322
-18895	3322
-18905.7	3322
-18916.4	3322
-18927	3322
-18937.7	3322
-18948.3	3322
-18959	3322
-18969.7	3322
-18980.3	3322
-18991	3322
-19001.7	3322
-19012.3	3322
-19023	3322
-19033.7	3322
-19044.3	3324
-19055	3326
-19065.6	3328
-19076.3	3330
-19087	3333
-19097.6	3333
-19108.3	3334
-19119	3335
-19129.6	3336
-19140.3	3337
-19150.9	3339
-19161.6	3341
-19172.3	3342
-19182.9	3343
-19193.6	3344
-19204.3	3345
-19214.9	3347
-19225.6	3347
-19236.3	3348
-19246.9	3349
-19257.6	3350
-19268.2	3350
-19278.9	3351
-19289.6	3352
-19300.2	3353
-19310.9	3354
-19321.6	3355
-19332.2	3356
-19342.9	3357
-19353.5	3358
-19364.2	3359
-19374.9	3360
-19385.5	3361
-19396.2	3362
-19406.9	3363
-19417.5	3364
-19428.2	3365
-19438.8	3367
-19449.5	3368
-19460.2	3369
-19470.8	3370
-19481.5	3371
-19492.2	3372
-19502.8	3372
-19513.5	3375
-19524.2	3376
-19534.8	3377
-19545.5	3378
-19556.1	3380
-19566.8	3380
-19577.5	3382
-19588.1	3383
-19598.8	3384
-19609.5	3386
-19620.1	3387
-19630.8	3388
-19641.4	3389
-19652.1	3390
-19662.8	3391
-19673.4	3392
-19684.1	3393
-19694.8	3394
-19705.4	3395
-19716.1	3396
-19726.8	3397
-19737.4	3398
-19748.1	3399
-19758.7	3400
-19769.4	3401
-19780.1	3402
-19790.7	3403
-19801.4	3403
-19812.1	3404
-19822.7	3404
-19833.4	3405
-19844	3406
-19854.7	3407
-19865.4	3408
-19876	3409
-19886.7	3410
-19897.4	3411
-19908	3412
-19918.7	3413
-19929.4	3414
-19940	3415
-19950.7	3416
-19961.3	3417
-19972	3418
-19982.7	3419
-19993.3	3420
-20004	3420
-20014.7	3421
-20025.3	3422
-20036	3423
-20046.6	3424
-20057.3	3425
-20068	3427
-20078.6	3429
-20089.3	3432
-20100	3434
-20110.6	3435
-20121.3	3436
-20132	3437
-20142.6	3438
-20153.3	3438
-20163.9	3439
-20174.6	3440
-20185.3	3441
-20195.9	3442
-20206.6	3443
-20217.3	3444
-20227.9	3445
-20238.6	3446
-20249.2	3446
-20259.9	3446
-20270.6	3447
-20281.2	3447
-20291.9	3448
-20302.6	3448
-20313.2	3448
-20323.9	3449
-20334.6	3449
-20345.2	3450
-20355.9	3450
-20366.5	3451
-20377.2	3452
-20387.9	3453
-20398.5	3454
-20409.2	3455
-20419.9	3456
-20430.5	3457
-20441.2	3458
-20451.8	3459
-20462.5	3460
-20473.2	3461
-20483.8	3462
-20494.5	3463
-20505.2	3464
-20515.8	3465
-20526.5	3466
-20537.1	3467
-20547.8	3468
-20558.5	3469
-20569.1	3470
-20579.8	3471
-20590.5	3472
-20601.1	3473
-20611.8	3474
-20622.5	3475
-20633.1	3478
-20643.8	3478
-20654.4	3479
-20665.1	3480
-20675.8	3481
-20686.4	3481
-20697.1	3482
-20707.8	3483
-20718.4	3484
-20729.1	3487
-20739.7	3489
-20750.4	3489
-20761.1	3490
-20771.7	3491
-20782.4	3492
-20793.1	3493
-20803.7	3494
-20814.4	3495
-20825.1	3496
-20835.7	3497
-20846.4	3498
-20857	3499
-20867.7	3499
-20878.4	3501
-20889	3502
-20899.7	3504
-20910.4	3506
-20921	3508
-20931.7	3510
-20942.3	3512
-20953	3514
-20963.7	3515
-20974.3	3516
-20985	3517
-20995.7	3518
-21006.3	3520
-21017	3520
-21027.7	3522
-21038.3	3523
-21049	3523
-21059.6	3523
-21070.3	3523
-21081	3524
-21091.6	3526
-21102.3	3527
-21113	3528
-21123.6	3530
-21134.3	3531
-21144.9	3532
-21155.6	3533
-21166.3	3534
-21176.9	3535
-21187.6	3536
-21198.3	3537
-21208.9	3538
-21219.6	3539
-21230.3	3539
-21240.9	3540
-21251.6	3541
-21262.2	3542
-21272.9	3543
-21283.6	3544
-21294.2	3544
-21304.9	3545
-21315.6	3546
-21326.2	3548
-21336.9	3548
-21347.5	3549
-21358.2	3550
-21368.9	3551
-21379.5	3552
-21390.2	3553
-21400.9	3554
-21411.5	3554
-21422.2	3555
-21432.9	3556
-21443.5	3557
-21454.2	3558
-21464.8	3559
-21475.5	3561
-21486.2	3562
-21496.8	3562
-21507.5	3562
-21518.2	3562
-21528.8	3564
-21539.5	3565
-21550.1	3567
-21560.8	3567
-21571.5	3569
-21582.1	3572
-21592.8	3575
-21603.5	3577
-21614.1	3579
-21624.8	3580
-21635.5	3582
-21646.1	3584
-21656.8	3584
-21667.4	3586
-21678.1	3586
-21688.8	3588
-21699.4	3590
-21710.1	3592
-21720.8	3594
-21731.4	3596
-21742.1	3598
-21752.7	3600
-21763.4	3602
-21774.1	3604
-21784.7	3606
-21795.4	3608
-21806.1	3611
-21816.7	3613
-21827.4	3615
-21838	3616
-21848.7	3617
-21859.4	3618
-21870	3619
-21880.7	3621
-21891.4	3624
-21902	3626
-21912.7	3627
-21923.4	3628
-21934	3629
-21944.7	3631
-21955.3	3631
-21966	3633
-21976.7	3635
-21987.3	3635
-21998	3637
-22008.7	3639
-22019.3	3641
-22030	3643
-22040.6	3643
-22051.3	3645
-22062	3647
-22072.6	3647
-22083.3	3650
-22094	3652
-22104.6	3652
-22115.3	3654
-22126	3656
-22136.6	3658
-22147.3	3658
-22157.9	3659
-22168.6	3660
-22179.3	3661
-22189.9	3662
-22200.6	3663
-22211.3	3664
-22221.9	3664
-22232.6	3665
-22243.2	3665
-22253.9	3665
-22264.6	3665
-22275.2	3665
-22285.9	3665
-22296.6	3665
-22307.2	3666
-22317.9	3668
-22328.6	3669
-22339.2	3669
-22349.9	3670
-22360.5	3671
-22371.2	3672
-22381.9	3673
-22392.5	3674
-22403.2	3675
-22413.9	3676
-22424.5	3677
-22435.2	3679
-22445.8	3680
-22456.5	3680
-22467.2	3681
-22477.8	3682
-22488.5	3683
-22499.2	3684
-22509.8	3685
-22520.5	3688
-22531.2	3689
-22541.8	3690
-22552.5	3691
-22563.1	3692
-22573.8	3693
-22584.5	3693
-22595.1	3695
-22605.8	3696
-22616.5	3697
-22627.1	3698
-22637.8	3699
-22648.4	3700
-22659.1	3701
-22669.8	3701
-22680.4	3702
-22691.1	3703
-22701.8	3704
-22712.4	3704
-22723.1	3705
-22733.8	3707
-22744.4	3708
-22755.1	3709
-22765.7	3709
-22776.4	3710
-22787.1	3711
-22797.7	3712
-22808.4	3713
-22819.1	3715
-22829.7	3716
-22840.4	3717
-22851	3719
-22861.7	3721
-22872.4	3722
-22883	3724
-22893.7	3724
-22904.4	3725
-22915	3725
-22925.7	3725
-22936.3	3725
-22947	3725
-22957.7	3725
-22968.3	3726
-22979	3728
-22989.7	3729
-23000.3	3730
-23011	3731
-23021.7	3732
-23032.3	3733
-23043	3734
-23053.6	3735
-23064.3	3736
-23075	3737
-23085.6	3739
-23096.3	3741
-23107	3741
-23117.6	3743
-23128.3	3743
-23138.9	3745
-23149.6	3746
-23160.3	3749
-23170.9	3750
-23181.6	3750
-23192.3	3752
-23202.9	3753
-23213.6	3755
-23224.3	3756
-23234.9	3758
-23245.6	3759
-23256.2	3761
-23266.9	3762
-23277.6	3763
-23288.2	3764
-23298.9	3766
-23309.6	3768
-23320.2	3768
-23330.9	3770
-23341.5	3771
-23352.2	3773
-23362.9	3774
-23373.5	3775
-23384.2	3777
-23394.9	3778
-23405.5	3780
-23416.2	3781
-23426.9	3781
-23437.5	3783
-23448.2	3783
-23458.8	3783
-23469.5	3783
-23480.2	3783
-23490.8	3784
-23501.5	3784
-23512.2	3784
-23522.8	3784
-23533.5	3784
-23544.1	3784
-23554.8	3784
-23565.5	3784
-23576.1	3784
-23586.8	3784
-23597.5	3784
-23608.1	3784
-23618.8	3784
-23629.5	3784
-23640.1	3784
-23650.8	3784
-23661.4	3784
-23672.1	3784
-23682.8	3784
-23693.4	3784
-23704.1	3784
-23714.8	3784
-23725.4	3784
-23736.1	3784
-23746.7	3784
-23757.4	3784
-23768.1	3784
-23778.7	3784
-23789.4	3784
-23800.1	3784
-23810.7	3784
-23821.4	3784
-23832.1	3784
-23842.7	3784
-23853.4	3784
-23864	3784
-23874.7	3784
-23885.4	3784
-23896	3784
-23906.7	3784
-23917.4	3784
-23928	3784
-23938.7	3784
-23949.3	3784
-23960	3784
-23970.7	3784
-23981.3	3784
-23992	3784
-24002.7	3784
-24013.3	3785
-24024	3785
-24034.6	3786
-24045.3	3787
-24056	3788
-24066.6	3789
-24077.3	3791
-24088	3792
-24098.6	3793
-24109.3	3794
-24120	3795
-24130.6	3796
-24141.3	3798
-24151.9	3800
-24162.6	3802
-24173.3	3802
-24183.9	3802
-24194.6	3802
-24205.3	3802
-24215.9	3802
-24226.6	3802
-24237.2	3802
-24247.9	3802
-24258.6	3802
-24269.2	3802
-24279.9	3802
-24290.6	3802
-24301.2	3802
-24311.9	3802
-24322.6	3802
-24333.2	3802
-24343.9	3802
-24354.5	3802
-24365.2	3802
-24375.9	3802
-24386.5	3802
-24397.2	3802
-24407.9	3802
-24418.5	3802
-24429.2	3802
-24439.8	3802
-24450.5	3802
-24461.2	3802
-24471.8	3802
-24482.5	3802
-24493.2	3802
-24503.8	3802
-24514.5	3802
-24525.2	3802
-24535.8	3802
-24546.5	3802
-24557.1	3802
-24567.8	3802
-24578.5	3802
-24589.1	3802
-24599.8	3802
-24610.5	3802
-24621.1	3802
-24631.8	3802
-24642.4	3802
-24653.1	3802
-24663.8	3802
-24674.4	3802
-24685.1	3802
-24695.8	3802
-24706.4	3802
-24717.1	3802
-24727.8	3802
-24738.4	3802
-24749.1	3802
-24759.7	3802
-24770.4	3802
-24781.1	3802
-24791.7	3802
-24802.4	3802
-24813.1	3802
-24823.7	3802
-24834.4	3802
-24845	3802
-24855.7	3802
-24866.4	3802
-24877	3802
-24887.7	3802
-24898.4	3802
-24909	3802
-24919.7	3802
-24930.4	3802
-24941	3802
-24951.7	3802
-24962.3	3802
-24973	3803
-24983.7	3804
-24994.3	3805
-25005	3806
-25015.7	3808
-25026.3	3808
-25037	3809
-25047.6	3810
-25058.3	3811
-25069	3812
-25079.6	3813
-25090.3	3814
-25101	3815
-25111.6	3816
-25122.3	3817
-25133	3817
-25143.6	3819
-25154.3	3820
-25164.9	3821
-25175.6	3822
-25186.3	3823
-25196.9	3824
-25207.6	3825
-25218.3	3826
-25228.9	3827
-25239.6	3828
-25250.2	3829
-25260.9	3830
-25271.6	3831
-25282.2	3832
-25292.9	3833
-25303.6	3834
-25314.2	3835
-25324.9	3836
-25335.5	3837
-25346.2	3838
-25356.9	3839
-25367.5	3840
-25378.2	3841
-25388.9	3842
-25399.5	3843
-25410.2	3845
-25420.9	3846
-25431.5	3847
-25442.2	3847
-25452.8	3848
-25463.5	3849
-25474.2	3851
-25484.8	3852
-25495.5	3853
-25506.2	3854
-25516.8	3855
-25527.5	3857
-25538.1	3859
-25548.8	3861
-25559.5	3862
-25570.1	3863
-25580.8	3864
-25591.5	3865
-25602.1	3866
-25612.8	3868
-25623.5	3869
-25634.1	3870
-25644.8	3871
-25655.4	3872
-25666.1	3874
-25676.8	3875
-25687.4	3876
-25698.1	3877
-25708.8	3878
-25719.4	3879
-25730.1	3880
-25740.7	3881
-25751.4	3882
-25762.1	3883
-25772.7	3884
-25783.4	3885
-25794.1	3886
-25804.7	3887
-25815.4	3888
-25826.1	3889
-25836.7	3890
-25847.4	3891
-25858	3892
-25868.7	3893
-25879.4	3894
-25890	3895
-25900.7	3896
-25911.4	3897
-25922	3898
-25932.7	3899
-25943.3	3900
-25954	3900
-25964.7	3901
-25975.3	3902
-25986	3903
-25996.7	3905
-26007.3	3906
-26018	3906
-26028.7	3907
-26039.3	3908
-26050	3909
-26060.6	3911
-26071.3	3912
-26082	3912
-26092.6	3913
-26103.3	3914
-26114	3915
-26124.6	3917
-26135.3	3919
-26145.9	3920
-26156.6	3922
-26167.3	3923
-26177.9	3923
-26188.6	3924
-26199.3	3925
-26209.9	3926
-26220.6	3928
-26231.3	3929
-26241.9	3930
-26252.6	3931
-26263.2	3932
-26273.9	3932
-26284.6	3934
-26295.2	3935
-26305.9	3936
-26316.6	3937
-26327.2	3938
-26337.9	3939
-26348.5	3940
-26359.2	3941
-26369.9	3942
-26380.5	3943
-26391.2	3944
-26401.9	3945
-26412.5	3946
-26423.2	3947
-26433.8	3948
-26444.5	3949
-26455.2	3950
-26465.8	3951
-26476.5	3952
-26487.2	3953
-26497.8	3954
-26508.5	3955
-26519.2	3956
-26529.8	3957
-26540.5	3958
-26551.1	3959
-26561.8	3960
-26572.5	3961
-26583.1	3962
-26593.8	3963
-26604.5	3965
-26615.1	3965
-26625.8	3965
-26636.4	3965
-26647.1	3965
-26657.8	3965
-26668.4	3965
-26679.1	3965
-26689.8	3965
-26700.4	3965
-26711.1	3965
-26721.8	3965
-26732.4	3965
-26743.1	3965
-26753.7	3965
-26764.4	3965
-26775.1	3965
-26785.7	3965
-26796.4	3965
-26807.1	3965
-26817.7	3965
-26828.4	3965
-26839	3965
-26849.7	3965
-26860.4	3965
-26871	3965
-26881.7	3965
-26892.4	3965
-26903	3965
-26913.7	3965
-26924.4	3965
-26935	3965
-26945.7	3965
-26956.3	3965
-26967	3965
-26977.7	3965
-26988.3	3965
-26999	3965
-27009.7	3965
-27020.3	3965
-27031	3965
-27041.6	3965
-27052.3	3965
-27063	3965
-27073.6	3965
-27084.3	3965
-27095	3965
-27105.6	3965
-27116.3	3965
-27127	3965
-27137.6	3965
-27148.3	3965
-27158.9	3965
-27169.6	3967
-27180.3	3968
-27190.9	3969
-27201.6	3970
-27212.3	3971
-27222.9	3973
-27233.6	3975
-27244.2	3977
-27254.9	3978
-27265.6	3979
-27276.2	3979
-27286.9	3980
-27297.6	3981
-27308.2	3982
-27318.9	3983
-27329.6	3983
-27340.2	3983
-27350.9	3983
-27361.5	3983
-27372.2	3983
-27382.9	3984
-27393.5	3985
-27404.2	3985
-27414.9	3985
-27425.5	3986
-27436.2	3987
-27446.8	3987
-27457.5	3987
-27468.2	3987
-27478.8	3987
-27489.5	3987
-27500.2	3987
-27510.8	3987
-27521.5	3987
-27532.2	3987
-27542.8	3987
-27553.5	3987
-27564.1	3987
-27574.8	3987
-27585.5	3987
-27596.1	3987
-27606.8	3987
-27617.5	3987
-27628.1	3987
-27638.8	3987
-27649.4	3987
-27660.1	3987
-27670.8	3987
-27681.4	3987
-27692.1	3987
-27702.8	3987
-27713.4	3987
-27724.1	3987
-27734.7	3987
-27745.4	3987
-27756.1	3987
-27766.7	3987
-27777.4	3987
-27788.1	3987
-27798.7	3987
-27809.4	3987
-27820.1	3987
-27830.7	3987
-27841.4	3987
-27852	3987
-27862.7	3987
-27873.4	3987
-27884	3987
-27894.7	3987
-27905.4	3987
-27916	3987
-27926.7	3987
-27937.3	3987
-27948	3987
-27958.7	3987
-27969.3	3987
-27980	3987
-27990.7	3991
-28001.3	3991
-28012	3994
-28022.7	3997
-28033.3	4000
-28044	4003
-28054.6	4006
-28065.3	4006
-28076	4008
-28086.6	4009
-28097.3	4011
-28108	4012
-28118.6	4014
-28129.3	4014
-28139.9	4014
-28150.6	4016
-28161.3	4017
-28171.9	4018
-28182.6	4019
-28193.3	4019
-28203.9	4021
-28214.6	4022
-28225.3	4024
-28235.9	4025
-28246.6	4027
-28257.2	4028
-28267.9	4029
-28278.6	4032
-28289.2	4036
-28299.9	4036
-28310.6	4039
-28321.2	4041
-28331.9	4042
-28342.5	4045
-28353.2	4046
-28363.9	4047
-28374.5	4047
-28385.2	4048
-28395.9	4050
-28406.5	4051
-28417.2	4052
-28427.9	4053
-28438.5	4055
-28449.2	4057
-28459.8	4058
-28470.5	4060
-28481.2	4060
-28491.8	4063
-28502.5	4063
-28513.2	4066
-28523.8	4066
-28534.5	4067
-28545.1	4069
-28555.8	4070
-28566.5	4072
-28577.1	4072
-28587.8	4075
-28598.5	4075
-28609.1	4079
-28619.8	4083
-28630.5	4084
-28641.1	4084
-28651.8	4087
-28662.4	4087
-28673.1	4090
-28683.8	4093
-28694.4	4095
-28705.1	4096
-28715.8	4096
-28726.4	4097
-28737.1	4099
-28747.7	4099
-28758.4	4102
-28769.1	4102
-28779.7	4103
-28790.4	4104
-28801.1	4106
-28811.7	4107
-28822.4	4108
-28833	4111
-28843.7	4112
-28854.4	4113
-28865	4116
-28875.7	4117
-28886.4	4118
-28897	4120
-28907.7	4121
-28918.4	4122
-28929	4123
-28939.7	4125
-28950.3	4127
-28961	4128
-28971.7	4129
-28982.3	4131
-28993	4131
-29003.7	4132
-29014.3	4134
-29025	4137
-29035.6	4138
-29046.3	4139
-29057	4140
-29067.6	4142
-29078.3	4145
-29089	4148
-29099.6	4150
-29110.3	4151
-29121	4153
-29131.6	4154
-29142.3	4155
-29152.9	4156
-29163.6	4158
-29174.3	4159
-29184.9	4161
-29195.6	4162
-29206.3	4163
-29216.9	4165
-29227.6	4166
-29238.2	4169
-29248.9	4169
-29259.6	4172
-29270.2	4173
-29280.9	4175
-29291.6	4178
-29302.2	4178
-29312.9	4181
-29323.6	4181
-29334.2	4182
-29344.9	4184
-29355.5	4185
-29366.2	4187
-29376.9	4189
-29387.5	4191
-29398.2	4191
-29408.9	4194
-29419.5	4197
-29430.2	4200
-29440.8	4204
-29451.5	4204
-29462.2	4204
-29472.8	4204
-29483.5	4204
-29494.2	4206
-29504.8	4208
-29515.5	4208
-29526.2	4209
-29536.8	4210
-29547.5	4211
-29558.1	4212
-29568.8	4213
-29579.5	4213
-29590.1	4214
-29600.8	4215
-29611.5	4215
-29622.1	4216
-29632.8	4217
-29643.4	4217
-29654.1	4219
-29664.8	4220
-29675.4	4221
-29686.1	4222
-29696.8	4223
-29707.4	4224
-29718.1	4225
-29728.8	4226
-29739.4	4226
-29750.1	4227
-29760.7	4228
-29771.4	4229
-29782.1	4230
-29792.7	4230
-29803.4	4231
-29814.1	4232
-29824.7	4232
-29835.4	4233
-29846	4236
-29856.7	4239
-29867.4	4239
-29878	4242
-29888.7	4242
-29899.4	4243
-29910	4245
-29920.7	4246
-29931.3	4248
-29942	4250
-29952.7	4252
-29963.3	4253
-29974	4254
-29984.7	4256
-29995.3	4258
-30006	4261
-30016.7	4264
-30027.3	4266
-30038	4267
-30048.6	4268
-30059.3	4270
-30070	4271
-30080.6	4274
-30091.3	4275
-30102	4275
-30112.6	4277
-30123.3	4278
-30133.9	4279
-30144.6	4281
-30155.3	4281
-30165.9	4282
-30176.6	4284
-30187.3	4284
-30197.9	4287
-30208.6	4287
-30219.3	4288
-30229.9	4290
-30240.6	4290
-30251.2	4292
-30261.9	4293
-30272.6	4296
-30283.2	4299
-30293.9	4299
-30304.6	4302
-30315.2	4302
-30325.9	4307
-30336.5	4307
-30347.2	4310
-30357.9	4312
-30368.5	4316
-30379.2	4317
-30389.9	4320
-30400.5	4322
-30411.2	4322
-30421.9	4323
-30432.5	4325
-30443.2	4326
-30453.8	4328
-30464.5	4329
-30475.2	4331
-30485.8	4332
-30496.5	4332
-30507.2	4333
-30517.8	4335
-30528.5	4336
-30539.1	4337
-30549.8	4340
-30560.5	4341
-30571.1	4342
-30581.8	4343
-30592.5	4346
-30603.1	4347
-30613.8	4349
-30624.5	4351
-30635.1	4353
-30645.8	4356
-30656.4	4356
-30667.1	4359
-30677.8	4359
-30688.4	4361
-30699.1	4362
-30709.8	4365
-30720.4	4368
-30731.1	4371
-30741.7	4372
-30752.4	4375
-30763.1	4377
-30773.7	4378
-30784.4	4379
-30795.1	4381
-30805.7	4381
-30816.4	4384
-30827.1	4385
-30837.7	4386
-30848.4	4388
-30859	4389
-30869.7	4390
-30880.4	4393
-30891	4394
-30901.7	4394
-30912.4	4395
-30923	4397
-30933.7	4399
-30944.3	4400
-30955	4401
-30965.7	4402
-30976.3	4403
-30987	4404
-30997.7	4406
-31008.3	4407
-31019	4409
-31029.7	4409
-31040.3	4409
-31051	4409
-31061.6	4409
-31072.3	4409
-31083	4409
-31093.6	4409
-31104.3	4409
-31115	4409
-31125.6	4409
-31136.3	4409
-31146.9	4409
-31157.6	4409
-31168.3	4409
-31178.9	4409
-31189.6	4409
-31200.3	4409
-31210.9	4409
-31221.6	4409
-31232.2	4409
-31242.9	4409
-31253.6	4409
-31264.2	4409
-31274.9	4409
-31285.6	4409
-31296.2	4409
-31306.9	4409
-31317.6	4409
-31328.2	4409
-31338.9	4409
-31349.5	4409
-31360.2	4409
-31370.9	4409
-31381.5	4409
-31392.2	4409
-31402.9	4409
-31413.5	4410
-31424.2	4410
-31434.8	4410
-31445.5	4411
-31456.2	4411
-31466.8	4412
-31477.5	4412
-31488.2	4413
-31498.8	4414
-31509.5	4414
-31520.2	4415
-31530.8	4415
-31541.5	4416
-31552.1	4417
-31562.8	4418
-31573.5	4419
-31584.1	4419
-31594.8	4420
-31605.5	4421
-31616.1	4422
-31626.8	4426
-31637.4	4429
-31648.1	4429
-31658.8	4429
-31669.4	4429
-31680.1	4429
-31690.8	4429
-31701.4	4429
-31712.1	4429
-31722.8	4429
-31733.4	4429
-31744.1	4429
-31754.7	4429
-31765.4	4429
-31776.1	4429
-31786.7	4429
-31797.4	4429
-31808.1	4429
-31818.7	4429
-31829.4	4429
-31840	4429
-31850.7	4429
-31861.4	4429
-31872	4429
-31882.7	4429
-31893.4	4429
-31904	4429
-31914.7	4429
-31925.4	4429
-31936	4429
-31946.7	4429
-31957.3	4429
-31968	4429
-31978.7	4430
-31989.3	4430
-32000	4430
-32010.7	4430
-32021.3	4432
-32032	4433
-32042.6	4434
-32053.3	4434
-32064	4435
-32074.6	4436
-32085.3	4438
-32096	4439
-32106.6	4439
-32117.3	4440
-32128	4441
-32138.6	4441
-32149.3	4442
-32159.9	4443
-32170.6	4444
-32181.3	4445
-32191.9	4445
-32202.6	4446
-32213.3	4446
-32223.9	4447
-32234.6	4448
-32245.2	4449
-32255.9	4449
-32266.6	4450
-32277.2	4451
-32287.9	4452
-32298.6	4453
-32309.2	4454
-32319.9	4455
-32330.5	4456
-32341.2	4457
-32351.9	4458
-32362.5	4458
-32373.2	4459
-32383.9	4459
-32394.5	4460
-32405.2	4460
-32415.9	4460
-32426.5	4461
-32437.2	4461
-32447.8	4462
-32458.5	4462
-32469.2	4463
-32479.8	4464
-32490.5	4465
-32501.2	4465
-32511.8	4466
-32522.5	4466
-32533.1	4466
-32543.8	4468
-32554.5	4468
-32565.1	4468
-32575.8	4468
-32586.5	4468
-32597.1	4468
-32607.8	4468
-32618.5	4468
-32629.1	4468
-32639.8	4468
-32650.4	4468
-32661.1	4468
-32671.8	4468
-32682.4	4468
-32693.1	4468
-32703.8	4468
-32714.4	4468
-32725.1	4468
-32735.7	4468
-32746.4	4468
-32757.1	4468
-32767.7	4468
-32778.4	4468
-32789.1	4468
-32799.7	4468
-32810.4	4468
-32821.1	4468
-32831.7	4468
-32842.4	4468
-32853	4468
-32863.7	4468
-32874.4	4468
-32885	4468
-32895.7	4468
-32906.4	4468
-32917	4468
-32927.7	4468
-32938.3	4468
-32949	4468
-32959.7	4468
-32970.3	4468
-32981	4468
-32991.7	4468
-33002.3	4468
-33013	4468
-33023.7	4468
-33034.3	4468
-33045	4468
-33055.6	4468
-33066.3	4468
-33077	4468
-33087.6	4468
-33098.3	4468
-33109	4468
-33119.6	4468
-33130.3	4468
-33140.9	4468
-33151.6	4468
-33162.3	4468
-33172.9	4468
-33183.6	4468
-33194.3	4468
-33204.9	4468
-33215.6	4468
-33226.3	4468
-33236.9	4468
-33247.6	4468
-33258.2	4468
-33268.9	4468
-33279.6	4468
-33290.2	4468
-33300.9	4468
-33311.6	4468
-33322.2	4468
-33332.9	4468
-33343.5	4468
-33354.2	4468
-33364.9	4468
-33375.5	4468
-33386.2	4468
-33396.9	4468
-33407.5	4468
-33418.2	4468
-33428.8	4468
-33439.5	4468
-33450.2	4468
-33460.8	4468
-33471.5	4468
-33482.2	4468
-33492.8	4468
-33503.5	4468
-33514.2	4468
-33524.8	4468
-33535.5	4468
-33546.1	4468
-33556.8	4468
-33567.5	4468
-33578.1	4468
-33588.8	4468
-33599.5	4468
-33610.1	4468
-33620.8	4468
-33631.4	4468
-33642.1	4468
-33652.8	4468
-33663.4	4468
-33674.1	4468
-33684.8	4468
-33695.4	4468
-33706.1	4468
-33716.8	4468
-33727.4	4468
-33738.1	4468
-33748.7	4468
-33759.4	4468
-33770.1	4468
-33780.7	4468
-33791.4	4468
-33802.1	4468
-33812.7	4468
-33823.4	4468
-33834	4468
-33844.7	4468
-33855.4	4468
-33866	4468
-33876.7	4468
-33887.4	4468
-33898	4468
-33908.7	4468
-33919.4	4468
-33930	4468
-33940.7	4468
-33951.3	4468
-33962	4468
-33972.7	4468
-33983.3	4468
-33994	4468
-34004.7	4468
-34015.3	4468
-34026	4468
-34036.6	4468
-34047.3	4468
-34058	4468
-34068.6	4468
-34079.3	4468
-34090	4468
-34100.6	4468
-34111.3	4468
-34122	4468
-34132.6	4468
-34143.3	4468
-34153.9	4468
-34164.6	4468
-34175.3	4468
-34185.9	4468
-34196.6	4468
-34207.3	4468
-34217.9	4468
-34228.6	4468
-34239.2	4468
-34249.9	4468
-34260.6	4468
-34271.2	4468
-34281.9	4468
-34292.6	4468
-34303.2	4468
-34313.9	4468
-34324.6	4468
-34335.2	4468
-34345.9	4468
-34356.5	4468
-34367.2	4468
-34377.9	4468
-34388.5	4468
-34399.2	4468
-34409.9	4468
-34420.5	4468
-34431.2	4468
-34441.8	4468
-34452.5	4468
-34463.2	4468
-34473.8	4468
-34484.5	4468
-34495.2	4468
-34505.8	4468
-34516.5	4468
-34527.2	4468
-34537.8	4468
-34548.5	4468
-34559.1	4468
-34569.8	4468
-34580.5	4468
-34591.1	4468
-34601.8	4468
-34612.5	4468
-34623.1	4468
-34633.8	4468
-34644.4	4468
-34655.1	4468
-34665.8	4468
-34676.4	4468
-34687.1	4468
-34697.8	4468
-34708.4	4468
-34719.1	4468
-34729.7	4468
-34740.4	4468
-34751.1	4468
-34761.7	4468
-34772.4	4468
-34783.1	4468
-34793.7	4468
-34804.4	4468
-34815.1	4468
-34825.7	4468
-34836.4	4468
-34847	4468
-34857.7	4468
-34868.4	4468
-34879	4468
-34889.7	4468
-34900.4	4468
-34911	4468
-34921.7	4468
-34932.3	4468
-34943	4468
-34953.7	4468
-34964.3	4468
-34975	4468
-34985.7	4468
-34996.3	4468
-35007	4468
-35017.7	4468
-35028.3	4468
-35039	4468
-35049.6	4468
-35060.3	4468
-35071	4468
-35081.6	4468
-35092.3	4468
-35103	4468
-35113.6	4468
-35124.3	4468
-35134.9	4469
-35145.6	4471
-35156.3	4480
-35166.9	4481
-35177.6	4483
-35188.3	4484
-35198.9	4490
-35209.6	4490
-35220.3	4492
-35230.9	4495
-35241.6	4497
-35252.2	4499
-35262.9	4501
-35273.6	4502
-35284.2	4505
-35294.9	4507
-35305.6	4509
-35316.2	4513
-35326.9	4514
-35337.5	4515
-35348.2	4521
-35358.9	4522
-35369.5	4522
-35380.2	4529
-35390.9	4533
-35401.5	4535
-35412.2	4539
-35422.9	4541
-35433.5	4541
-35444.2	4545
-35454.8	4546
-35465.5	4549
-35476.2	4551
-35486.8	4552
-35497.5	4555
-35508.2	4557
-35518.8	4560
-35529.5	4561
-35540.1	4563
-35550.8	4565
-35561.5	4566
-35572.1	4570
-35582.8	4572
-35593.5	4574
-35604.1	4575
-35614.8	4576
-35625.5	4577
-35636.1	4578
-35646.8	4579
-35657.4	4579
-35668.1	4580
-35678.8	4581
-35689.4	4582
-35700.1	4583
-35710.8	4584
-35721.4	4586
-35732.1	4588
-35742.7	4589
-35753.4	4590
-35764.1	4591
-35774.7	4591
-35785.4	4592
-35796.1	4593
-35806.7	4594
-35817.4	4595
-35828	4596
-35838.7	4597
-35849.4	4598
-35860	4600
-35870.7	4602
-35881.4	4604
-35892	4605
-35902.7	4607
-35913.4	4608
-35924	4612
-35934.7	4615
-35945.3	4618
-35956	4620
-35966.7	4621
-35977.3	4624
-35988	4626
-35998.7	4627
-36009.3	4633
-36020	4634
-36030.6	4635
-36041.3	4639
-36052	4644
-36062.6	4644
-36073.3	4648
-36084	4651
-36094.6	4652
-36105.3	4658
-36116	4658
-36126.6	4660
-36137.3	4666
-36147.9	4667
-36158.6	4667
-36169.3	4672
-36179.9	4674
-36190.6	4679
-36201.3	4680
-36211.9	4685
-36222.6	4686
-36233.2	4692
-36243.9	4693
-36254.6	4695
-36265.2	4698
-36275.9	4702
-36286.6	4704
-36297.2	4706
-36307.9	4709
-36318.6	4710
-36329.2	4712
-36339.9	4716
-36350.5	4720
-36361.2	4722
-36371.9	4723
-36382.5	4727
-36393.2	4728
-36403.9	4730
-36414.5	4733
-36425.2	4733
-36435.8	4737
-36446.5	4739
-36457.2	4741
-36467.8	4742
-36478.5	4745
-36489.2	4749
-36499.8	4750
-36510.5	4752
-36521.2	4755
-36531.8	4761
-36542.5	4761
-36553.1	4764
-36563.8	4764
-36574.5	4765
-36585.1	4769
-36595.8	4769
-36606.5	4771
-36617.1	4775
-36627.8	4775
-36638.4	4778
-36649.1	4780
-36659.8	4784
-36670.4	4786
-36681.1	4788
-36691.8	4792
-36702.4	4795
-36713.1	4798
-36723.8	4801
-36734.4	4801
-36745.1	4803
-36755.7	4808
-36766.4	4811
-36777.1	4813
-36787.7	4817
-36798.4	4819
-36809.1	4822
-36819.7	4824
-36830.4	4828
-36841	4830
-36851.7	4834
-36862.4	4836
-36873	4838
-36883.7	4839
-36894.4	4844
-36905	4847
-36915.7	4848
-36926.3	4850
-36937	4853
-36947.7	4854
-36958.3	4856
-36969	4859
-36979.7	4862
-36990.3	4864
-37001	4868
-37011.7	4870
-37022.3	4872
-37033	4875
-37043.6	4879
-37054.3	4880
-37065	4882
-37075.6	4885
-37086.3	4887
-37097	4889
-37107.6	4893
-37118.3	4896
-37128.9	4898
-37139.6	4902
-37150.3	4903
-37160.9	4903
-37171.6	4906
-37182.3	4909
-37192.9	4910
-37203.6	4914
-37214.3	4918
-37224.9	4921
-37235.6	4923
-37246.2	4924
-37256.9	4928
-37267.6	4930
-37278.2	4933
-37288.9	4936
-37299.6	4939
-37310.2	4940
-37320.9	4943
-37331.5	4947
-37342.2	4947
-37352.9	4949
-37363.5	4953
-37374.2	4955
-37384.9	4955
-37395.5	4960
-37406.2	4961
-37416.9	4964
-37427.5	4968
-37438.2	4969
-37448.8	4973
-37459.5	4975
-37470.2	4978
-37480.8	4981
-37491.5	4983
-37502.2	4986
-37512.8	4988
-37523.5	4989
-37534.1	4993
-37544.8	4995
-37555.5	4998
-37566.1	5000
-37576.8	5001
-37587.5	5003
-37598.1	5006
-37608.8	5007
-37619.5	5011
-37630.1	5013
-37640.8	5018
-37651.4	5020
-37662.1	5022
-37672.8	5025
-37683.4	5026
-37694.1	5028
-37704.8	5031
-37715.4	5031
-37726.1	5032
-37736.7	5036
-37747.4	5038
-37758.1	5039
-37768.7	5042
-37779.4	5044
-37790.1	5047
-37800.7	5053
-37811.4	5055
-37822.1	5056
-37832.7	5058
-37843.4	5061
-37854	5062
-37864.7	5067
-37875.4	5069
-37886	5073
-37896.7	5074
-37907.4	5078
-37918	5080
-37928.7	5081
-37939.3	5084
-37950	5086
-37960.7	5088
-37971.3	5092
-37982	5096
-37992.7	5098
-38003.3	5102
-38014	5104
-38024.7	5109
-38035.3	5112
-38046	5114
-38056.6	5116
-38067.3	5119
-38078	5123
-38088.6	5126
-38099.3	5128
-38110	5132
-38120.6	5134
-38131.3	5134
-38141.9	5139
-38152.6	5141
-38163.3	5146
-38173.9	5147
-38184.6	5149
-38195.3	5153
-38205.9	5155
-38216.6	5158
-38227.2	5163
-38237.9	5166
-38248.6	5166
-38259.2	5167
-38269.9	5169
-38280.6	5170
-38291.2	5171
-38301.9	5172
-38312.6	5173
-38323.2	5174
-38333.9	5178
-38344.5	5180
-38355.2	5182
-38365.9	5185
-38376.5	5187
-38387.2	5191
-38397.9	5193
-38408.5	5196
-38419.2	5198
-38429.8	5203
-38440.5	5205
-38451.2	5206
-38461.8	5210
-38472.5	5212
-38483.2	5213
-38493.8	5215
-38504.5	5218
-38515.2	5219
-38525.8	5222
-38536.5	5227
-38547.1	5229
-38557.8	5231
-38568.5	5234
-38579.1	5234
-38589.8	5237
-38600.5	5241
-38611.1	5244
-38621.8	5247
-38632.4	5247
-38643.1	5250
-38653.8	5252
-38664.4	5255
-38675.1	5257
-38685.8	5258
-38696.4	5262
-38707.1	5265
-38717.8	5267
-38728.4	5269
-38739.1	5273
-38749.7	5276
-38760.4	5278
-38771.1	5281
-38781.7	5282
-38792.4	5286
-38803.1	5288
-38813.7	5290
-38824.4	5292
-38835	5295
-38845.7	5297
-38856.4	5299
-38867	5303
-38877.7	5305
-38888.4	5309
-38899	5312
-38909.7	5313
-38920.4	5315
-38931	5318
-38941.7	5321
-38952.3	5323
-38963	5327
-38973.7	5329
-38984.3	5331
-38995	5332
-39005.7	5335
-39016.3	5337
-39027	5339
-39037.6	5340
-39048.3	5344
-39059	5345
-39069.6	5347
-39080.3	5351
-39091	5351
-39101.6	5352
-39112.3	5357
-39123	5359
-39133.6	5359
-39144.3	5362
-39154.9	5366
-39165.6	5371
-39176.3	5372
-39186.9	5377
-39197.6	5380
-39208.3	5381
-39218.9	5386
-39229.6	5387
-39240.2	5388
-39250.9	5391
-39261.6	5393
-39272.2	5394
-39282.9	5397
-39293.6	5399
-39304.2	5400
-39314.9	5404
-39325.5	5405
-39336.2	5406
-39346.9	5408
-39357.5	5412
-39368.2	5417
-39378.9	5419
-39389.5	5420
-39400.2	5424
-39410.9	5425
-39421.5	5426
-39432.2	5431
-39442.8	5434
-39453.5	5435
-39464.2	5436
-39474.8	5441
-39485.5	5442
-39496.2	5443
-39506.8	5447
-39517.5	5450
-39528.1	5452
-39538.8	5454
-39549.5	5455
-39560.1	5458
-39570.8	5460
-39581.5	5462
-39592.1	5465
-39602.8	5469
-39613.5	5472
-39624.1	5476
-39634.8	5477
-39645.4	5478
-39656.1	5484
-39666.8	5485
-39677.4	5488
-39688.1	5491
-39698.8	5494
-39709.4	5498
-39720.1	5500
-39730.7	5504
-39741.4	5506
-39752.1	5509
-39762.7	5511
-39773.4	5513
-39784.1	5517
-39794.7	5518
-39805.4	5519
-39816.1	5525
-39826.7	5527
-39837.4	5529
-39848	5533
-39858.7	5534
-39869.4	5535
-39880	5539
-39890.7	5542
-39901.4	5544
-39912	5545
-39922.7	5548
-39933.3	5552
-39944	5552
-39954.7	5555
-39965.3	5559
-39976	5562
-39986.7	5563
-39997.3	5568
-40008	5569
-40018.7	5570
-40029.3	5576
-40040	5578
-40050.6	5579
-40061.3	5582
-40072	5585
-40082.6	5587
-40093.3	5593
-40104	5593
-40114.6	5598
-40125.3	5600
-40135.9	5601
-40146.6	5605
-40157.3	5608
-40167.9	5608
-40178.6	5611
-40189.3	5614
-40199.9	5615
-40210.6	5620
-40221.3	5623
-40231.9	5623
-40242.6	5625
-40253.2	5630
-40263.9	5632
-40274.6	5634
-40285.2	5638
-40295.9	5638
-40306.6	5640
-40317.2	5645
-40327.9	5645
-40338.5	5647
-40349.2	5651
-40359.9	5655
-40370.5	5658
-40381.2	5661
-40391.9	5662
-40402.5	5664
-40413.2	5668
-40423.9	5669
-40434.5	5673
-40445.2	5675
-40455.8	5677
-40466.5	5681
-40477.2	5683
-40487.8	5685
-40498.5	5690
-40509.2	5690
-40519.8	5693
-40530.5	5697
-40541.1	5697
-40551.8	5699
-40562.5	5704
-40573.1	5705
-40583.8	5710
-40594.5	5711
-40605.1	5712
-40615.8	5715
-40626.4	5719
-40637.1	5723
-40647.8	5727
-40658.4	5729
-40669.1	5733
-40679.8	5734
-40690.4	5736
-40701.1	5739
-40711.8	5740
-40722.4	5743
-40733.1	5747
-40743.7	5749
-40754.4	5752
-40765.1	5753
-40775.7	5756
-40786.4	5758
-40797.1	5761
-40807.7	5764
-40818.4	5765
-40829	5768
-40839.7	5768
-40850.4	5775
-40861	5779
-40871.7	5781
-40882.4	5782
-40893	5786
-40903.7	5788
-40914.4	5788
-40925	5793
-40935.7	5796
-40946.3	5797
-40957	5801
-40967.7	5802
-40978.3	5803
-40989	5805
-40999.7	5810
-41010.3	5810
-41021	5812
-41031.6	5817
-41042.3	5817
-41053	5819
-41063.6	5822
-41074.3	5824
-41085	5825
-41095.6	5828
-41106.3	5829
-41117	5832
-41127.6	5835
-41138.3	5837
-41148.9	5840
-41159.6	5843
-41170.3	5844
-41180.9	5847
-41191.6	5849
-41202.3	5853
-41212.9	5856
-41223.6	5860
-41234.2	5865
-41244.9	5866
-41255.6	5870
-41266.2	5872
-41276.9	5875
-41287.6	5879
-41298.2	5880
-41308.9	5883
-41319.6	5886
-41330.2	5891
-41340.9	5892
-41351.5	5898
-41362.2	5898
-41372.9	5903
-41383.5	5904
-41394.2	5907
-41404.9	5909
-41415.5	5911
-41426.2	5915
-41436.8	5917
-41447.5	5923
-41458.2	5925
-41468.8	5928
-41479.5	5931
-41490.2	5933
-41500.8	5938
-41511.5	5940
-41522.2	5942
-41532.8	5945
-41543.5	5947
-41554.1	5948
-41564.8	5955
-41575.5	5960
-41586.1	5962
-41596.8	5968
-41607.5	5970
-41618.1	5974
-41628.8	5977
-41639.4	5981
-41650.1	5983
-41660.8	5988
-41671.4	5990
-41682.1	5992
-41692.8	5995
-41703.4	5998
-41714.1	6000
-41724.7	6005
-41735.4	6006
-41746.1	6008
-41756.7	6009
-41767.4	6010
-41778.1	6012
-41788.7	6014
-41799.4	6017
-41810.1	6018
-41820.7	6020
-41831.4	6024
-41842	6026
-41852.7	6029
-41863.4	6031
-41874	6034
-41884.7	6037
-41895.4	6039
-41906	6041
-41916.7	6045
-41927.3	6045
-41938	6048
-41948.7	6052
-41959.3	6055
-41970	6058
-41980.7	6059
-41991.3	6062
-42002	6065
-42012.7	6068
-42023.3	6073
-42034	6075
-42044.6	6077
-42055.3	6080
-42066	6081
-42076.6	6084
-42087.3	6086
-42098	6087
-42108.6	6089
-42119.3	6093
-42129.9	6096
-42140.6	6097
-42151.3	6099
-42161.9	6103
-42172.6	6105
-42183.3	6106
-42193.9	6111
-42204.6	6113
-42215.3	6117
-42225.9	6119
-42236.6	6124
-42247.2	6126
-42257.9	6130
-42268.6	6132
-42279.2	6135
-42289.9	6136
-42300.6	6141
-42311.2	6143
-42321.9	6147
-42332.5	6151
-42343.2	6154
-42353.9	6156
-42364.5	6160
-42375.2	6162
-42385.9	6165
-42396.5	6168
-42407.2	6171
-42417.9	6171
-42428.5	6175
-42439.2	6178
-42449.8	6178
-42460.5	6182
-42471.2	6185
-42481.8	6188
-42492.5	6191
-42503.2	6193
-42513.8	6197
-42524.5	6200
-42535.1	6204
-42545.8	6205
-42556.5	6207
-42567.1	6214
-42577.8	6216
-42588.5	6216
-42599.1	6220
-42609.8	6222
-42620.5	6226
-42631.1	6228
-42641.8	6231
-42652.4	6234
-42663.1	6235
-42673.8	6236
-42684.4	6243
-42695.1	6244
-42705.8	6249
-42716.4	6250
-42727.1	6254
-42737.7	6256
-42748.4	6260
-42759.1	6264
-42769.7	6267
-42780.4	6270
-42791.1	6271
-42801.7	6275
-42812.4	6276
-42823	6278
-42833.7	6282
-42844.4	6282
-42855	6284
-42865.7	6288
-42876.4	6291
-42887	6295
-42897.7	6300
-42908.4	6301
-42919	6304
-42929.7	6306
-42940.3	6307
-42951	6310
-42961.7	6313
-42972.3	6317
-42983	6319
-42993.7	6323
-43004.3	6328
-43015	6331
-43025.6	6334
-43036.3	6336
-43047	6336
-43057.6	6339
-43068.3	6341
-43079	6341
-43089.6	6342
-43100.3	6344
-43111	6349
-43121.6	6352
-43132.3	6352
-43142.9	6355
-43153.6	6359
-43164.3	6360
-43174.9	6360
-43185.6	6367
-43196.3	6369
-43206.9	6374
-43217.6	6376
-43228.2	6376
-43238.9	6381
-43249.6	6383
-43260.2	6385
-43270.9	6388
-43281.6	6390
-43292.2	6394
-43302.9	6395
-43313.6	6398
-43324.2	6400
-43334.9	6402
-43345.5	6404
-43356.2	6408
-43366.9	6411
-43377.5	6414
-43388.2	6416
-43398.9	6419
-43409.5	6420
-43420.2	6425
-43430.8	6429
-43441.5	6431
-43452.2	6435
-43462.8	6437
-43473.5	6437
-43484.2	6438
-43494.8	6443
-43505.5	6443
-43516.2	6444
-43526.8	6448
-43537.5	6448
-43548.1	6454
-43558.8	6455
-43569.5	6456
-43580.1	6458
-43590.8	6461
-43601.5	6463
-43612.1	6467
-43622.8	6469
-43633.4	6472
-43644.1	6477
-43654.8	6477
-43665.4	6480
-43676.1	6484
-43686.8	6487
-43697.4	6490
-43708.1	6493
-43718.8	6497
-43729.4	6500
-43740.1	6503
-43750.7	6504
-43761.4	6507
-43772.1	6509
-43782.7	6512
-43793.4	6516
-43804.1	6518
-43814.7	6519
-43825.4	6524
-43836	6530
-43846.7	6530
-43857.4	6534
-43868	6536
-43878.7	6541
-43889.4	6546
-43900	6550
-43910.7	6551
-43921.4	6555
-43932	6556
-43942.7	6559
-43953.3	6561
-43964	6562
-43974.7	6565
-43985.3	6567
-43996	6568
-44006.7	6570
-44017.3	6574
-44028	6575
-44038.6	6576
-44049.3	6581
-44060	6582
-44070.6	6582
-44081.3	6587
-44092	6591
-44102.6	6593
-44113.3	6593
-44123.9	6597
-44134.6	6602
-44145.3	6603
-44155.9	6608
-44166.6	6613
-44177.3	6615
-44187.9	6619
-44198.6	6621
-44209.3	6625
-44219.9	6627
-44230.6	6634
-44241.2	6634
-44251.9	6640
-44262.6	6641
-44273.2	6645
-44283.9	6647
-44294.6	6651
-44305.2	6655
-44315.9	6656
-44326.5	6659
-44337.2	6660
-44347.9	6662
-44358.5	6663
-44369.2	6666
-44379.9	6668
-44390.5	6671
-44401.2	6672
-44411.9	6676
-44422.5	6679
-44433.2	6683
-44443.8	6685
-44454.5	6687
-44465.2	6690
-44475.8	6693
-44486.5	6693
-44497.2	6694
-44507.8	6697
-44518.5	6699
-44529.1	6701
-44539.8	6702
-44550.5	6707
-44561.1	6709
-44571.8	6713
-44582.5	6715
-44593.1	6722
-44603.8	6723
-44614.5	6726
-44625.1	6730
-44635.8	6734
-44646.4	6736
-44657.1	6740
-44667.8	6744
-44678.4	6745
-44689.1	6750
-44699.8	6750
-44710.4	6752
-44721.1	6757
-44731.7	6758
-44742.4	6761
-44753.1	6765
-44763.7	6766
-44774.4	6768
-44785.1	6771
-44795.7	6779
-44806.4	6780
-44817.1	6785
-44827.7	6788
-44838.4	6789
-44849	6796
-44859.7	6798
-44870.4	6803
-44881	6806
-44891.7	6808
-44902.4	6814
-44913	6817
-44923.7	6820
-44934.3	6827
-44945	6831
-44955.7	6837
-44966.3	6841
-44977	6841
-44987.7	6845
-44998.3	6850
-45009	6852
-45019.7	6854
-45030.3	6863
-45041	6865
-45051.6	6870
-45062.3	6874
-45073	6875
-45083.6	6878
-45094.3	6887
-45105	6891
-45115.6	6894
-45126.3	6896
-45136.9	6901
-45147.6	6903
-45158.3	6906
-45168.9	6908
-45179.6	6913
-45190.3	6918
-45200.9	6921
-45211.6	6926
-45222.2	6930
-45232.9	6933
-45243.6	6938
-45254.2	6941
-45264.9	6943
-45275.6	6948
-45286.2	6954
-45296.9	6955
-45307.6	6957
-45318.2	6963
-45328.9	6966
-45339.5	6968
-45350.2	6972
-45360.9	6979
-45371.5	6981
-45382.2	6983
-45392.9	6985
-45403.5	6990
-45414.2	6994
-45424.8	6996
-45435.5	7001
-45446.2	7006
-45456.8	7010
-45467.5	7011
-45478.2	7016
-45488.8	7021
-45499.5	7023
-45510.2	7027
-45520.8	7031
-45531.5	7033
-45542.1	7038
-45552.8	7040
-45563.5	7046
-45574.1	7051
-45584.8	7054
-45595.5	7058
-45606.1	7064
-45616.8	7065
-45627.4	7070
-45638.1	7076
-45648.8	7077
-45659.4	7079
-45670.1	7085
-45680.8	7090
-45691.4	7091
-45702.1	7093
-45712.8	7101
-45723.4	7104
-45734.1	7105
-45744.7	7112
-45755.4	7118
-45766.1	7118
-45776.7	7124
-45787.4	7129
-45798.1	7133
-45808.7	7139
-45819.4	7140
-45830	7142
-45840.7	7147
-45851.4	7151
-45862	7154
-45872.7	7160
-45883.4	7164
-45894	7167
-45904.7	7170
-45915.4	7174
-45926	7178
-45936.7	7181
-45947.3	7184
-45958	7187
-45968.7	7191
-45979.3	7195
-45990	7197
-46000.7	7199
-46011.3	7203
-46022	7209
-46032.6	7211
-46043.3	7213
-46054	7219
-46064.6	7220
-46075.3	7224
-46086	7230
-46096.6	7230
-46107.3	7236
-46118	7242
-46128.6	7246
-46139.3	7250
-46149.9	7255
-46160.6	7257
-46171.3	7260
-46181.9	7265
-46192.6	7267
-46203.3	7271
-46213.9	7280
-46224.6	7284
-46235.2	7291
-46245.9	7293
-46256.6	7294
-46267.2	7301
-46277.9	7305
-46288.6	7309
-46299.2	7313
-46309.9	7318
-46320.5	7322
-46331.2	7324
-46341.9	7329
-46352.5	7334
-46363.2	7337
-46373.9	7339
-46384.5	7343
-46395.2	7347
-46405.9	7349
-46416.5	7354
-46427.2	7359
-46437.8	7363
-46448.5	7369
-46459.2	7373
-46469.8	7376
-46480.5	7379
-46491.2	7385
-46501.8	7386
-46512.5	7390
-46523.1	7396
-46533.8	7402
-46544.5	7405
-46555.1	7409
-46565.8	7414
-46576.5	7417
-46587.1	7419
-46597.8	7424
-46608.5	7429
-46619.1	7430
-46629.8	7434
-46640.4	7436
-46651.1	7439
-46661.8	7443
-46672.4	7449
-46683.1	7450
-46693.8	7453
-46704.4	7459
-46715.1	7465
-46725.7	7472
-46736.4	7478
-46747.1	7478
-46757.7	7481
-46768.4	7490
-46779.1	7490
-46789.7	7492
-46800.4	7501
-46811.1	7502
-46821.7	7505
-46832.4	7508
-46843	7515
-46853.7	7516
-46864.4	7518
-46875	7523
-46885.7	7529
-46896.4	7531
-46907	7535
-46917.7	7540
-46928.3	7543
-46939	7545
-46949.7	7551
-46960.3	7554
-46971	7555
-46981.7	7564
-46992.3	7569
-47003	7570
-47013.7	7575
-47024.3	7582
-47035	7582
-47045.6	7587
-47056.3	7592
-47067	7597
-47077.6	7604
-47088.3	7608
-47099	7613
-47109.6	7623
-47120.3	7624
-47130.9	7628
-47141.6	7634
-47152.3	7638
-47162.9	7641
-47173.6	7642
-47184.3	7646
-47194.9	7650
-47205.6	7655
-47216.3	7656
-47226.9	7661
-47237.6	7667
-47248.2	7670
-47258.9	7672
-47269.6	7677
-47280.2	7679
-47290.9	7683
-47301.6	7686
-47312.2	7689
-47322.9	7694
-47333.5	7697
-47344.2	7700
-47354.9	7704
-47365.5	7709
-47376.2	7713
-47386.9	7719
-47397.5	7721
-47408.2	7724
-47418.9	7725
-47429.5	7732
-47440.2	7736
-47450.8	7740
-47461.5	7744
-47472.2	7744
-47482.8	7753
-47493.5	7763
-47504.2	7765
-47514.8	7772
-47525.5	7776
-47536.1	7778
-47546.8	7786
-47557.5	7791
-47568.1	7793
-47578.8	7800
-47589.5	7807
-47600.1	7811
-47610.8	7819
-47621.4	7824
-47632.1	7826
-47642.8	7832
-47653.4	7839
-47664.1	7842
-47674.8	7847
-47685.4	7852
-47696.1	7858
-47706.8	7858
-47717.4	7866
-47728.1	7877
-47738.7	7880
-47749.4	7885
-47760.1	7887
-47770.7	7895
-47781.4	7904
-47792.1	7906
-47802.7	7909
-47813.4	7919
-47824	7924
-47834.7	7925
-47845.4	7933
-47856	7938
-47866.7	7942
-47877.4	7950
-47888	7956
-47898.7	7959
-47909.4	7966
-47920	7970
-47930.7	7978
-47941.3	7983
-47952	7989
-47962.7	7995
-47973.3	7997
-47984	8000
-47994.7	8000
-48005.3	8006
-48016	8016
-48026.6	8020
-48037.3	8028
-48048	8030
-48058.6	8034
-48069.3	8045
-48080	8049
-48090.6	8051
-48101.3	8061
-48112	8069
-48122.6	8074
-48133.3	8078
-48143.9	8084
-48154.6	8090
-48165.3	8094
-48175.9	8103
-48186.6	8108
-48197.3	8114
-48207.9	8117
-48218.6	8125
-48229.2	8128
-48239.9	8133
-48250.6	8138
-48261.2	8148
-48271.9	8149
-48282.6	8153
-48293.2	8159
-48303.9	8164
-48314.6	8166
-48325.2	8176
-48335.9	8179
-48346.5	8186
-48357.2	8193
-48367.9	8196
-48378.5	8196
-48389.2	8205
-48399.9	8211
-48410.5	8214
-48421.2	8221
-48431.8	8226
-48442.5	8229
-48453.2	8232
-48463.8	8237
-48474.5	8244
-48485.2	8249
-48495.8	8254
-48506.5	8259
-48517.2	8265
-48527.8	8268
-48538.5	8275
-48549.1	8279
-48559.8	8284
-48570.5	8285
-48581.1	8290
-48591.8	8296
-48602.5	8302
-48613.1	8306
-48623.8	8306
-48634.4	8311
-48645.1	8318
-48655.8	8318
-48666.4	8324
-48677.1	8326
-48687.8	8338
-48698.4	8342
-48709.1	8344
-48719.7	8348
-48730.4	8356
-48741.1	8363
-48751.7	8369
-48762.4	8374
-48773.1	8380
-48783.7	8386
-48794.4	8391
-48805.1	8396
-48815.7	8404
-48826.4	8412
-48837	8415
-48847.7	8417
-48858.4	8422
-48869	8431
-48879.7	8433
-48890.4	8441
-48901	8449
-48911.7	8450
-48922.3	8454
-48933	8459
-48943.7	8462
-48954.3	8469
-48965	8475
-48975.7	8477
-48986.3	8486
-48997	8492
-49007.7	8494
-49018.3	8501
-49029	8505
-49039.6	8512
-49050.3	8517
-49061	8523
-49071.6	8528
-49082.3	8536
-49093	8540
-49103.6	8546
-49114.3	8553
-49124.9	8561
-49135.6	8564
-49146.3	8571
-49156.9	8574
-49167.6	8574
-49178.3	8578
-49188.9	8591
-49199.6	8594
-49210.3	8600
-49220.9	8602
-49231.6	8607
-49242.2	8609
-49252.9	8619
-49263.6	8627
-49274.2	8631
-49284.9	8637
-49295.6	8644
-49306.2	8650
-49316.9	8659
-49327.5	8663
-49338.2	8668
-49348.9	8677
-49359.5	8687
-49370.2	8688
-49380.9	8696
-49391.5	8702
-49402.2	8703
-49412.9	8708
-49423.5	8713
-49434.2	8721
-49444.8	8730
-49455.5	8733
-49466.2	8740
-49476.8	8745
-49487.5	8749
-49498.2	8755
-49508.8	8758
-49519.5	8763
-49530.1	8770
-49540.8	8777
-49551.5	8783
-49562.1	8788
-49572.8	8793
-49583.5	8799
-49594.1	8811
-49604.8	8814
-49615.5	8818
-49626.1	8825
-49636.8	8835
-49647.4	8839
-49658.1	8847
-49668.8	8852
-49679.4	8858
-49690.1	8867
-49700.8	8875
-49711.4	8878
-49722.1	8878
-49732.7	8888
-49743.4	8896
-49754.1	8899
-49764.7	8901
-49775.4	8904
-49786.1	8913
-49796.7	8924
-49807.4	8925
-49818	8932
-49828.7	8937
-49839.4	8943
-49850	8946
-49860.7	8952
-49871.4	8958
-49882	8964
-49892.7	8969
-49903.4	8974
-49914	8983
-49924.7	8991
-49935.3	8997
-49946	8999
-49956.7	9009
-49967.3	9019
-49978	9023
-49988.7	9028
-49999.3	9033
-50010	9043
-50020.6	9048
-50031.3	9055
-50042	9061
-50052.6	9068
-50063.3	9072
-50074	9074
-50084.6	9076
-50095.3	9085
-50106	9093
-50116.6	9099
-50127.3	9101
-50137.9	9103
-50148.6	9109
-50159.3	9122
-50169.9	9126
-50180.6	9134
-50191.3	9140
-50201.9	9146
-50212.6	9151
-50223.2	9159
-50233.9	9160
-50244.6	9170
-50255.2	9178
-50265.9	9182
-50276.6	9187
-50287.2	9190
-50297.9	9195
-50308.6	9206
-50319.2	9211
-50329.9	9218
-50340.5	9219
-50351.2	9225
-50361.9	9233
-50372.5	9235
-50383.2	9244
-50393.9	9249
-50404.5	9254
-50415.2	9258
-50425.8	9263
-50436.5	9265
-50447.2	9270
-50457.8	9279
-50468.5	9287
-50479.2	9290
-50489.8	9298
-50500.5	9302
-50511.2	9306
-50521.8	9311
-50532.5	9317
-50543.1	9323
-50553.8	9331
-50564.5	9334
-50575.1	9340
-50585.8	9344
-50596.5	9356
-50607.1	9361
-50617.8	9368
-50628.4	9377
-50639.1	9378
-50649.8	9386
-50660.4	9386
-50671.1	9390
-50681.8	9394
-50692.4	9403
-50703.1	9410
-50713.8	9413
-50724.4	9421
-50735.1	9424
-50745.7	9434
-50756.4	9441
-50767.1	9445
-50777.7	9455
-50788.4	9458
-50799.1	9462
-50809.7	9465
-50820.4	9468
-50831	9482
-50841.7	9488
-50852.4	9491
-50863	9497
-50873.7	9502
-50884.4	9513
-50895	9513
-50905.7	9517
-50916.4	9532
-50927	9533
-50937.7	9538
-50948.3	9545
-50959	9549
-50969.7	9551
-50980.3	9557
-50991	9568
-51001.7	9573
-51012.3	9580
-51023	9583
-51033.6	9591
-51044.3	9598
-51055	9606
-51065.6	9613
-51076.3	9616
-51087	9622
-51097.6	9623
-51108.3	9633
-51118.9	9641
-51129.6	9643
-51140.3	9647
-51150.9	9656
-51161.6	9664
-51172.3	9669
-51182.9	9671
-51193.6	9674
-51204.3	9676
-51214.9	9683
-51225.6	9687
-51236.2	9693
-51246.9	9699
-51257.6	9708
-51268.2	9714
-51278.9	9719
-51289.6	9720
-51300.2	9729
-51310.9	9735
-51321.5	9740
-51332.2	9749
-51342.9	9752
-51353.5	9764
-51364.2	9764
-51374.9	9768
-51385.5	9771
-51396.2	9774
-51406.9	9784
-51417.5	9790
-51428.2	9791
-51438.8	9795
-51449.5	9800
-51460.2	9814
-51470.8	9821
-51481.5	9825
-51492.2	9834
-51502.8	9840
-51513.5	9847
-51524.1	9853
-51534.8	9860
-51545.5	9864
-51556.1	9872
-51566.8	9873
-51577.5	9880
-51588.1	9887
-51598.8	9897
-51609.5	9902
-51620.1	9905
-51630.8	9909
-51641.4	9912
-51652.1	9920
-51662.8	9922
-51673.4	9922
-51684.1	9933
-51694.8	9944
-51705.4	9947
-51716.1	9953
-51726.7	9959
-51737.4	9966
-51748.1	9974
-51758.7	9980
-51769.4	9984
-51780.1	9993
-51790.7	9993
-51801.4	10002
-51812.1	10009
-51822.7	10012
-51833.4	10019
-51844	10022
-51854.7	10024
-51865.4	10030
-51876	10047
-51886.7	10053
-51897.4	10058
-51908	10062
-51918.7	10065
-51929.3	10074
-51940	10080
-51950.7	10084
-51961.3	10087
-51972	10103
-51982.7	10107
-51993.3	10109
-52004	10111
-52014.7	10124
-52025.3	10134
-52036	10137
-52046.6	10143
-52057.3	10150
-52068	10154
-52078.6	10158
-52089.3	10162
-52100	10165
-52110.6	10174
-52121.3	10181
-52131.9	10188
-52142.6	10196
-52153.3	10204
-52163.9	10209
-52174.6	10217
-52185.3	10225
-52195.9	10230
-52206.6	10237
-52217.2	10241
-52227.9	10246
-52238.6	10254
-52249.2	10261
-52259.9	10263
-52270.6	10268
-52281.2	10279
-52291.9	10284
-52302.6	10289
-52313.2	10294
-52323.9	10296
-52334.5	10311
-52345.2	10316
-52355.9	10318
-52366.5	10322
-52377.2	10331
-52387.9	10341
-52398.5	10345
-52409.2	10349
-52419.8	10353
-52430.5	10359
-52441.2	10364
-52451.8	10369
-52462.5	10379
-52473.2	10383
-52483.8	10387
-52494.5	10394
-52505.2	10396
-52515.8	10401
-52526.5	10409
-52537.1	10411
-52547.8	10416
-52558.5	10421
-52569.1	10433
-52579.8	10437
-52590.5	10442
-52601.1	10444
-52611.8	10450
-52622.4	10462
-52633.1	10465
-52643.8	10465
-52654.4	10471
-52665.1	10479
-52675.8	10488
-52686.4	10491
-52697.1	10494
-52707.8	10498
-52718.4	10515
-52729.1	10518
-52739.7	10527
-52750.4	10528
-52761.1	10534
-52771.7	10543
-52782.4	10551
-52793.1	10554
-52803.7	10558
-52814.4	10565
-52825	10574
-52835.7	10576
-52846.4	10576
-52857	10585
-52867.7	10598
-52878.4	10602
-52889	10603
-52899.7	10604
-52910.4	10613
-52921	10627
-52931.7	10630
-52942.3	10630
-52953	10631
-52963.7	10635
-52974.3	10645
-52985	10652
-52995.7	10656
-53006.3	10663
-53017	10667
-53027.6	10670
-53038.3	10674
-53049	10682
-53059.6	10697
-53070.3	10698
-53081	10701
-53091.6	10702
-53102.3	10708
-53113	10712
-53123.6	10713
-53134.3	10717
-53144.9	10730
-53155.6	10741
-53166.3	10749
-53176.9	10753
-53187.6	10759
-53198.3	10766
-53208.9	10771
-53219.6	10774
-53230.2	10780
-53240.9	10788
-53251.6	10794
-53262.2	10800
-53272.9	10808
-53283.6	10812
-53294.2	10821
-53304.9	10824
-53315.5	10830
-53326.2	10836
-53336.9	10844
-53347.5	10852
-53358.2	10860
-53368.9	10862
-53379.5	10865
-53390.2	10873
-53400.9	10881
-53411.5	10886
-53422.2	10889
-53432.8	10895
-53443.5	10902
-53454.2	10907
-53464.8	10913
-53475.5	10919
-53486.2	10927
-53496.8	10932
-53507.5	10935
-53518.1	10936
-53528.8	10941
-53539.5	10948
-53550.1	10956
-53560.8	10962
-53571.5	10969
-53582.1	10973
-53592.8	10979
-53603.5	10987
-53614.1	10989
-53624.8	10994
-53635.4	10997
-53646.1	11002
-53656.8	11009
-53667.4	11011
-53678.1	11011
-53688.8	11027
-53699.4	11035
-53710.1	11039
-53720.7	11043
-53731.4	11050
-53742.1	11054
-53752.7	11060
-53763.4	11067
-53774.1	11074
-53784.7	11078
-53795.4	11083
-53806.1	11085
-53816.7	11090
-53827.4	11096
-53838	11101
-53848.7	11108
-53859.4	11113
-53870	11115
-53880.7	11127
-53891.4	11133
-53902	11135
-53912.7	11139
-53923.3	11146
-53934	11151
-53944.7	11161
-53955.3	11162
-53966	11165
-53976.7	11170
-53987.3	11178
-53998	11181
-54008.7	11181
-54019.3	11186
-54030	11191
-54040.6	11205
-54051.3	11210
-54062	11217
-54072.6	11219
-54083.3	11227
-54094	11236
-54104.6	11239
-54115.3	11242
-54125.9	11243
-54136.6	11250
-54147.3	11263
-54157.9	11270
-54168.6	11272
-54179.3	11284
-54189.9	11289
-54200.6	11294
-54211.3	11301
-54221.9	11308
-54232.6	11315
-54243.2	11318
-54253.9	11324
-54264.6	11333
-54275.2	11341
-54285.9	11342
-54296.6	11345
-54307.2	11355
-54317.9	11359
-54328.5	11363
-54339.2	11369
-54349.9	11379
-54360.5	11385
-54371.2	11387
-54381.9	11390
-54392.5	11394
-54403.2	11398
-54413.9	11405
-54424.5	11410
-54435.2	11416
-54445.8	11420
-54456.5	11424
-54467.2	11441
-54477.8	11443
-54488.5	11449
-54499.2	11451
-54509.8	11459
-54520.5	11471
-54531.1	11476
-54541.8	11481
-54552.5	11491
-54563.1	11493
-54573.8	11498
-54584.5	11500
-54595.1	11506
-54605.8	11514
-54616.4	11523
-54627.1	11529
-54637.8	11531
-54648.4	11535
-54659.1	11548
-54669.8	11552
-54680.4	11554
-54691.1	11559
-54701.8	11570
-54712.4	11574
-54723.1	11579
-54733.7	11588
-54744.4	11592
-54755.1	11602
-54765.7	11605
-54776.4	11610
-54787.1	11617
-54797.7	11623
-54808.4	11626
-54819	11629
-54829.7	11631
-54840.4	11634
-54851	11645
-54861.7	11648
-54872.4	11651
-54883	11658
-54893.7	11661
-54904.4	11672
-54915	11676
-54925.7	11683
-54936.3	11689
-54947	11695
-54957.7	11700
-54968.3	11706
-54979	11708
-54989.7	11716
-55000.3	11724
-55011	11730
-55021.6	11734
-55032.3	11744
-55043	11745
-55053.6	11756
-55064.3	11756
-55075	11763
-55085.6	11768
-55096.3	11769
-55107	11778
-55117.6	11781
-55128.3	11782
-55138.9	11791
-55149.6	11794
-55160.3	11798
-55170.9	11799
-55181.6	11806
-55192.3	11815
-55202.9	11820
-55213.6	11828
-55224.2	11829
-55234.9	11835
-55245.6	11840
-55256.2	11844
-55266.9	11850
-55277.6	11855
-55288.2	11865
-55298.9	11868
-55309.6	11875
-55320.2	11880
-55330.9	11890
-55341.5	11892
-55352.2	11896
-55362.9	11900
-55373.5	11907
-55384.2	11911
-55394.9	11918
-55405.5	11922
-55416.2	11930
-55426.8	11941
-55437.5	11946
-55448.2	11952
-55458.8	11959
-55469.5	11968
-55480.2	11972
-55490.8	11973
-55501.5	11985
-55512.2	11988
-55522.8	11997
-55533.5	11999
-55544.1	12004
-55554.8	12011
-55565.5	12019
-55576.1	12023
-55586.8	12032
-55597.5	12035
-55608.1	12044
-55618.8	12051
-55629.4	12057
-55640.1	12062
-55650.8	12067
-55661.4	12077
-55672.1	12081
-55682.8	12086
-55693.4	12091
-55704.1	12099
-55714.7	12105
-55725.4	12108
-55736.1	12116
-55746.7	12119
-55757.4	12127
-55768.1	12133
-55778.7	12137
-55789.4	12142
-55800.1	12146
-55810.7	12151
-55821.4	12152
-55832	12160
-55842.7	12163
-55853.4	12170
-55864	12175
-55874.7	12182
-55885.4	12191
-55896	12199
-55906.7	12201
-55917.3	12204
-55928	12210
-55938.7	12222
-55949.3	12228
-55960	12231
-55970.7	12235
-55981.3	12235
-55992	12246
-56002.7	12261
-56013.3	12263
-56024	12268
-56034.6	12268
-56045.3	12278
-56056	12279
-56066.6	12282
-56077.3	12290
-56088	12297
-56098.6	12308
-56109.3	12313
-56119.9	12316
-56130.6	12323
-56141.3	12337
-56151.9	12338
-56162.6	12341
-56173.3	12351
-56183.9	12362
-56194.6	12365
-56205.3	12368
-56215.9	12371
-56226.6	12376
-56237.2	12382
-56247.9	12383
-56258.6	12386
-56269.2	12393
-56279.9	12399
-56290.6	12402
-56301.2	12409
-56311.9	12415
-56322.5	12423
-56333.2	12431
-56343.9	12436
-56354.5	12439
-56365.2	12444
-56375.9	12448
-56386.5	12458
-56397.2	12461
-56407.9	12470
-56418.5	12475
-56429.2	12478
-56439.8	12485
-56450.5	12497
-56461.2	12503
-56471.8	12507
-56482.5	12509
-56493.2	12518
-56503.8	12523
-56514.5	12529
-56525.1	12534
-56535.8	12539
-56546.5	12539
-56557.1	12541
-56567.8	12555
-56578.5	12560
-56589.1	12562
-56599.8	12565
-56610.5	12579
-56621.1	12584
-56631.8	12590
-56642.4	12596
-56653.1	12600
-56663.8	12607
-56674.4	12609
-56685.1	12615
-56695.8	12618
-56706.4	12629
-56717.1	12633
-56727.7	12639
-56738.4	12644
-56749.1	12652
-56759.7	12661
-56770.4	12661
-56781.1	12665
-56791.7	12672
-56802.4	12682
-56813.1	12687
-56823.7	12690
-56834.4	12694
-56845	12702
-56855.7	12712
-56866.4	12715
-56877	12720
-56887.7	12725
-56898.4	12734
-56909	12745
-56919.7	12749
-56930.3	12758
-56941	12763
-56951.7	12772
-56962.3	12775
-56973	12779
-56983.7	12786
-56994.3	12793
-57005	12799
-57015.6	12806
-57026.3	12813
-57037	12816
-57047.6	12816
-57058.3	12832
-57069	12840
-57079.6	12849
-57090.3	12852
-57101	12856
-57111.6	12858
-57122.3	12863
-57132.9	12867
-57143.6	12875
-57154.3	12881
-57164.9	12887
-57175.6	12893
-57186.3	12904
-57196.9	12908
-57207.6	12914
-57218.2	12916
-57228.9	12918
-57239.6	12923
-57250.2	12936
-57260.9	12938
-57271.6	12943
-57282.2	12947
-57292.9	12960
-57303.6	12966
-57314.2	12973
-57324.9	12981
-57335.5	12986
-57346.2	12995
-57356.9	12996
-57367.5	12999
-57378.2	13005
-57388.9	13013
-57399.5	13021
-57410.2	13026
-57420.8	13030
-57431.5	13032
-57442.2	13042
-57452.8	13051
-57463.5	13052
-57474.2	13060
-57484.8	13068
-57495.5	13076
-57506.2	13079
-57516.8	13084
-57527.5	13089
-57538.1	13099
-57548.8	13103
-57559.5	13105
-57570.1	13110
-57580.8	13114
-57591.5	13120
-57602.1	13125
-57612.8	13129
-57623.4	13133
-57634.1	13142
-57644.8	13147
-57655.4	13153
-57666.1	13160
-57676.8	13165
-57687.4	13170
-57698.1	13174
-57708.8	13174
-57719.4	13181
-57730.1	13193
-57740.7	13198
-57751.4	13201
-57762.1	13205
-57772.7	13217
-57783.4	13226
-57794.1	13228
-57804.7	13233
-57815.4	13236
-57826	13247
-57836.7	13252
-57847.4	13255
-57858	13256
-57868.7	13260
-57879.4	13272
-57890	13278
-57900.7	13283
-57911.4	13296
-57922	13299
-57932.7	13305
-57943.3	13307
-57954	13317
-57964.7	13320
-57975.3	13327
-57986	13330
-57996.7	13332
-58007.3	13345
-58018	13347
-58028.6	13351
-58039.3	13357
-58050	13364
-58060.6	13375
-58071.3	13379
-58082	13385
-58092.6	13388
-58103.3	13394
-58113.9	13399
-58124.6	13402
-58135.3	13406
-58145.9	13418
-58156.6	13419
-58167.3	13425
-58177.9	13428
-58188.6	13433
-58199.3	13445
-58209.9	13450
-58220.6	13455
-58231.2	13458
-58241.9	13466
-58252.6	13474
-58263.2	13479
-58273.9	13482
-58284.6	13488
-58295.2	13500
-58305.9	13503
-58316.5	13509
-58327.2	13516
-58337.9	13521
-58348.5	13532
-58359.2	13537
-58369.9	13544
-58380.5	13551
-58391.2	13555
-58401.9	13563
-58412.5	13570
-58423.2	13574
-58433.8	13581
-58444.5	13586
-58455.2	13592
-58465.8	13593
-58476.5	13597
-58487.2	13606
-58497.8	13607
-58508.5	13616
-58519.1	13619
-58529.8	13628
-58540.5	13630
-58551.1	13636
-58561.8	13643
-58572.5	13646
-58583.1	13652
-58593.8	13658
-58604.5	13666
-58615.1	13678
-58625.8	13679
-58636.4	13683
-58647.1	13684
-58657.8	13689
-58668.4	13695
-58679.1	13704
-58689.8	13710
-58700.4	13712
-58711.1	13715
-58721.7	13722
-58732.4	13729
-58743.1	13734
-58753.7	13737
-58764.4	13741
-58775.1	13742
-58785.7	13743
-58796.4	13745
-58807.1	13760
-58817.7	13765
-58828.4	13769
-58839	13774
-58849.7	13782
-58860.4	13789
-58871	13795
-58881.7	13804
-58892.4	13806
-58903	13814
-58913.7	13822
-58924.3	13827
-58935	13829
-58945.7	13840
-58956.3	13848
-58967	13857
-58977.7	13862
-58988.3	13864
-58999	13869
-59009.7	13882
-59020.3	13884
-59031	13891
-59041.6	13897
-59052.3	13898
-59063	13899
-59073.6	13909
-59084.3	13916
-59095	13922
-59105.6	13925
-59116.3	13929
-59126.9	13936
-59137.6	13948
-59148.3	13951
-59158.9	13960
-59169.6	13968
-59180.3	13970
-59190.9	13977
-59201.6	13982
-59212.2	13987
-59222.9	13993
-59233.6	13999
-59244.2	14007
-59254.9	14014
-59265.6	14024
-59276.2	14030
-59286.9	14036
-59297.6	14043
-59308.2	14047
-59318.9	14057
-59329.5	14058
-59340.2	14061
-59350.9	14064
-59361.5	14069
-59372.2	14076
-59382.9	14084
-59393.5	14085
-59404.2	14087
-59414.8	14104
-59425.5	14108
-59436.2	14113
-59446.8	14119
-59457.5	14125
-59468.2	14132
-59478.8	14137
-59489.5	14143
-59500.2	14150
-59510.8	14152
-59521.5	14162
-59532.1	14167
-59542.8	14174
-59553.5	14176
-59564.1	14180
-59574.8	14191
-59585.5	14203
-59596.1	14205
-59606.8	14208
-59617.4	14213
-59628.1	14218
-59638.8	14223
-59649.4	14225
-59660.1	14231
-59670.8	14234
-59681.4	14241
-59692.1	14257
-59702.8	14259
-59713.4	14260
-59724.1	14264
-59734.7	14280
-59745.4	14281
-59756.1	14288
-59766.7	14291
-59777.4	14306
-59788.1	14308
-59798.7	14317
-59809.4	14323
-59820	14331
-59830.7	14336
-59841.4	14343
-59852	14347
-59862.7	14358
-59873.4	14361
-59884	14366
-59894.7	14370
-59905.4	14378
-59916	14385
-59926.7	14391
-59937.3	14397
-59948	14399
-59958.7	14409
-59969.3	14413
-59980	14417
-59990.7	14425
-60001.3	14427
-60012	14437
-60022.6	14442
-60033.3	14449
-60044	14450
-60054.6	14453
-60065.3	14462
-60076	14465
-60086.6	14473
-60097.3	14479
-60108	14489
-60118.6	14495
-60129.3	14499
-60139.9	14509
-60150.6	14519
-60161.3	14522
-60171.9	14525
-60182.6	14529
-60193.3	14537
-60203.9	14545
-60214.6	14550
-60225.2	14557
-60235.9	14559
-60246.6	14570
-60257.2	14574
-60267.9	14576
-60278.6	14588
-60289.2	14595
-60299.9	14601
-60310.6	14601
-60321.2	14611
-60331.9	14618
-60342.5	14622
-60353.2	14631
-60363.9	14637
-60374.5	14642
-60385.2	14650
-60395.9	14659
-60406.5	14665
-60417.2	14667
-60427.8	14669
-60438.5	14670
-60449.2	14679
-60459.8	14687
-60470.5	14688
-60481.2	14695
-60491.8	14700
-60502.5	14706
-60513.1	14712
-60523.8	14714
-60534.5	14721
-60545.1	14731
-60555.8	14736
-60566.5	14740
-60577.1	14752
-60587.8	14757
-60598.5	14765
-60609.1	14770
-60619.8	14780
-60630.4	14786
-60641.1	14793
-60651.8	14796
-60662.4	14804
-60673.1	14809
-60683.8	14815
-60694.4	14821
-60705.1	14833
-60715.7	14840
-60726.4	14840
-60737.1	14849
-60747.7	14855
-60758.4	14861
-60769.1	14870
-60779.7	14875
-60790.4	14882
-60801.1	14884
-60811.7	14893
-60822.4	14899
-60833	14904
-60843.7	14912
-60854.4	14918
-60865	14922
-60875.7	14928
-60886.4	14935
-60897	14943
-60907.7	14948
-60918.3	14952
-60929	14962
-60939.7	14971
-60950.3	14973
-60961	14979
-60971.7	14985
-60982.3	14994
-60993	14998
-61003.7	15004
-61014.3	15010
-61025	15016
-61035.6	15022
-61046.3	15027
-61057	15032
-61067.6	15037
-61078.3	15043
-61089	15044
-61099.6	15050
-61110.3	15064
-61120.9	15066
-61131.6	15071
-61142.3	15082
-61152.9	15086
-61163.6	15092
-61174.3	15098
-61184.9	15107
-61195.6	15113
-61206.3	15119
-61216.9	15126
-61227.6	15132
-61238.2	15141
-61248.9	15148
-61259.6	15151
-61270.2	15155
-61280.9	15170
-61291.6	15174
-61302.2	15176
-61312.9	15177
-61323.5	15180
-61334.2	15184
-61344.9	15188
-61355.5	15198
-61366.2	15203
-61376.9	15204
-61387.5	15207
-61398.2	15214
-61408.9	15220
-61419.5	15228
-61430.2	15238
-61440.8	15240
-61451.5	15243
-61462.2	15250
-61472.8	15255
-61483.5	15265
-61494.2	15267
-61504.8	15274
-61515.5	15281
-61526.1	15287
-61536.8	15292
-61547.5	15298
-61558.1	15303
-61568.8	15309
-61579.5	15315
-61590.1	15318
-61600.8	15330
-61611.4	15335
-61622.1	15339
-61632.8	15342
-61643.4	15348
-61654.1	15359
-61664.8	15365
-61675.4	15368
-61686.1	15371
-61696.8	15377
-61707.4	15390
-61718.1	15394
-61728.7	15399
-61739.4	15405
-61750.1	15411
-61760.7	15419
-61771.4	15425
-61782.1	15431
-61792.7	15435
-61803.4	15439
-61814	15446
-61824.7	15450
-61835.4	15459
-61846	15466
-61856.7	15473
-61867.4	15476
-61878	15482
-61888.7	15482
-61899.4	15490
-61910	15494
-61920.7	15497
-61931.3	15503
-61942	15511
-61952.7	15518
-61963.3	15523
-61974	15527
-61984.7	15529
-61995.3	15547
-62006	15548
-62016.6	15550
-62027.3	15551
-62038	15561
-62048.6	15568
-62059.3	15572
-62070	15576
-62080.6	15584
-62091.3	15593
-62102	15599
-62112.6	15603
-62123.3	15612
-62133.9	15619
-62144.6	15624
-62155.3	15627
-62165.9	15635
-62176.6	15646
-62187.3	15648
-62197.9	15652
-62208.6	15654
-62219.2	15658
-62229.9	15659
-62240.6	15674
-62251.2	15679
-62261.9	15686
-62272.6	15692
-62283.2	15697
-62293.9	15700
-62304.6	15713
-62315.2	15717
-62325.9	15722
-62336.5	15723
-62347.2	15729
-62357.9	15733
-62368.5	15746
-62379.2	15752
-62389.9	15754
-62400.5	15759
-62411.2	15762
-62421.8	15771
-62432.5	15772
-62443.2	15783
-62453.8	15788
-62464.5	15792
-62475.2	15806
-62485.8	15807
-62496.5	15809
-62507.2	15815
-62517.8	15824
-62528.5	15832
-62539.1	15835
-62549.8	15841
-62560.5	15844
-62571.1	15853
-62581.8	15863
-62592.5	15864
-62603.1	15869
-62613.8	15886
-62624.4	15889
-62635.1	15895
-62645.8	15908
-62656.4	15912
-62667.1	15917
-62677.8	15920
-62688.4	15936
-62699.1	15938
-62709.7	15940
-62720.4	15941
-62731.1	15946
-62741.7	15952
-62752.4	15958
-62763.1	15963
-62773.7	15967
-62784.4	15977
-62795.1	15983
-62805.7	15987
-62816.4	15992
-62827	15996
-62837.7	16005
-62848.4	16007
-62859	16013
-62869.7	16017
-62880.4	16028
-62891	16035
-62901.7	16043
-62912.3	16047
-62923	16051
-62933.7	16058
-62944.3	16069
-62955	16074
-62965.7	16083
-62976.3	16092
-62987	16096
-62997.7	16099
-63008.3	16110
-63019	16116
-63029.6	16117
-63040.3	16119
-63051	16124
-63061.6	16130
-63072.3	16141
-63083	16148
-63093.6	16151
-63104.3	16160
-63114.9	16171
-63125.6	16173
-63136.3	16180
-63146.9	16187
-63157.6	16196
-63168.3	16200
-63178.9	16205
-63189.6	16208
-63200.3	16218
-63210.9	16225
-63221.6	16229
-63232.2	16232
-63242.9	16238
-63253.6	16242
-63264.2	16245
-63274.9	16254
-63285.6	16256
-63296.2	16259
-63306.9	16266
-63317.5	16269
-63328.2	16275
-63338.9	16279
-63349.5	16287
-63360.2	16299
-63370.9	16303
-63381.5	16310
-63392.2	16311
-63402.9	16326
-63413.5	16330
-63424.2	16337
-63434.8	16339
-63445.5	16340
-63456.2	16352
-63466.8	16360
-63477.5	16368
-63488.2	16376
-63498.8	16379
-63509.5	16389
-63520.1	16394
-63530.8	16400
-63541.5	16406
-63552.1	16415
-63562.8	16422
-63573.5	16427
-63584.1	16431
-63594.8	16433
-63605.5	16446
-63616.1	16449
-63626.8	16453
-63637.4	16457
-63648.1	16467
-63658.8	16472
-63669.4	16474
-63680.1	16477
-63690.8	16486
-63701.4	16494
-63712.1	16500
-63722.7	16503
-63733.4	16509
-63744.1	16517
-63754.7	16524
-63765.4	16528
-63776.1	16531
-63786.7	16539
-63797.4	16552
-63808.1	16556
-63818.7	16560
-63829.4	16564
-63840	16573
-63850.7	16577
-63861.4	16582
-63872	16585
-63882.7	16588
-63893.4	16599
-63904	16604
-63914.7	16609
-63925.3	16616
-63936	16621
-63946.7	16628
-63957.3	16638
-63968	16640
-63978.7	16650
-63989.3	16654
-64000	16661
-64010.6	16668
-64021.3	16672
-64032	16682
-64042.6	16689
-64053.3	16689
-64064	16695
-64074.6	16700
-64085.3	16710
-64096	16718
-64106.6	16723
-64117.3	16727
-64127.9	16738
-64138.6	16741
-64149.3	16747
-64159.9	16749
-64170.6	16754
-64181.3	16760
-64191.9	16764
-64202.6	16776
-64213.2	16781
-64223.9	16786
-64234.6	16792
-64245.2	16798
-64255.9	16806
-64266.6	16812
-64277.2	16818
-64287.9	16824
-64298.6	16830
-64309.2	16839
-64319.9	16847
-64330.5	16850
-64341.2	16857
-64351.9	16862
-64362.5	16872
-64373.2	16879
-64383.9	16882
-64394.5	16890
-64405.2	16899
-64415.8	16903
-64426.5	16909
-64437.2	16915
-64447.8	16918
-64458.5	16928
-64469.2	16934
-64479.8	16938
-64490.5	16945
-64501.2	16952
-64511.8	16958
-64522.5	16964
-64533.1	16971
-64543.8	16976
-64554.5	16981
-64565.1	16984
-64575.8	16991
-64586.5	16998
-64597.1	17001
-64607.8	17005
-64618.4	17014
-64629.1	17020
-64639.8	17025
-64650.4	17025
-64661.1	17033
-64671.8	17045
-64682.4	17050
-64693.1	17055
-64703.8	17061
-64714.4	17068
-64725.1	17073
-64735.7	17082
-64746.4	17088
-64757.1	17091
-64767.7	17092
-64778.4	17097
-64789.1	17104
-64799.7	17110
-64810.4	17120
-64821	17123
-64831.7	17124
-64842.4	17134
-64853	17139
-64863.7	17149
-64874.4	17153
-64885	17163
-64895.7	17164
-64906.4	17169
-64917	17174
-64927.7	17179
-64938.3	17188
-64949	17193
-64959.7	17200
-64970.3	17206
-64981	17210
-64991.7	17214
-65002.3	17218
-65013	17218
-65023.6	17229
-65034.3	17231
-65045	17237
-65055.6	17244
-65066.3	17248
-65077	17256
-65087.6	17260
-65098.3	17266
-65108.9	17270
-65119.6	17274
-65130.3	17279
-65140.9	17280
-65151.6	17285
-65162.3	17291
-65172.9	17297
-65183.6	17298
-65194.3	17304
-65204.9	17306
-65215.6	17310
-65226.2	17310
-65236.9	17315
-65247.6	17316
-65258.2	17321
-65268.9	17322
-65279.6	17322
-65290.2	17327
-65300.9	17328
-65311.5	17333
-65322.2	17334
-65332.9	17339
-65343.5	17340
-65354.2	17346
-65364.9	17346
-65375.5	17351
-65386.2	17352
-65396.9	17357
-65407.5	17358
-65418.2	17363
-65428.8	17364
-65439.5	17369
-65450.2	17370
-65460.8	17375
-65471.5	17376
-65482.2	17381
-65492.8	17382
-65503.5	17387
-65514.1	17388
-65524.8	17393
-65535.5	17394
-65546.1	17394
-65556.8	17394
-65567.5	17394
-65578.1	17394
-65588.8	17394
-65599.5	17394
-65610.1	17394
-65620.8	17394
-65631.4	17394
-65642.1	17394
-65652.8	17394
-65663.4	17395
-65674.1	17395
-65684.8	17396
-65695.4	17396
-65706.1	17396
-65716.7	17396
-65727.4	17397
-65738.1	17398
-65748.7	17398
-65759.4	17400
-65770.1	17403
-65780.7	17403
-65791.4	17405
-65802.1	17406
-65812.7	17406
-65823.4	17406
-65834	17406
-65844.7	17406
-65855.4	17406
-65866	17406
-65876.7	17406
-65887.4	17406
-65898	17406
-65908.7	17407
-65919.3	17408
-65930	17408
-65940.7	17409
-65951.3	17410
-65962	17410
-65972.7	17412
-65983.3	17412
-65994	17412
-66004.7	17412
-66015.3	17414
-66026	17415
-66036.6	17415
-66047.3	17416
-66058	17418
-66068.6	17421
-66079.3	17424
-66090	17424
-66100.6	17427
-66111.3	17429
-66121.9	17430
-66132.6	17430
-66143.3	17430
-66153.9	17432
-66164.6	17433
-66175.3	17435
-66185.9	17436
-66196.6	17439
-66207.2	17439
-66217.9	17441
-66228.6	17442
-66239.2	17445
-66249.9	17447
-66260.6	17448
-66271.2	17451
-66281.9	17451
-66292.6	17454
-66303.2	17454
-66313.9	17457
-66324.5	17460
-66335.2	17460
-66345.9	17463
-66356.5	17466
-66367.2	17466
-66377.9	17469
-66388.5	17469
-66399.2	17469
-66409.8	17469
-66420.5	17469
-66431.2	17469
-66441.8	17469
-66452.5	17472
-66463.2	17472
-66473.8	17474
-66484.5	17476
-66495.2	17478
-66505.8	17478
-66516.5	17478
-66527.1	17480
-66537.8	17482
-66548.5	17484
-66559.1	17484
-66569.8	17484
-66580.5	17484
-66591.1	17484
-66601.8	17484
-66612.4	17484
-66623.1	17484
-66633.8	17484
-66644.4	17484
-66655.1	17484
-66665.8	17484
-66676.4	17484
-66687.1	17484
-66697.8	17484
-66708.4	17484
-66719.1	17484
-66729.7	17484
-66740.4	17484
-66751.1	17484
-66761.7	17484
-66772.4	17484
-66783.1	17484
-66793.7	17484
-66804.4	17484
-66815	17484
-66825.7	17484
-66836.4	17484
-66847	17484
-66857.7	17484
-66868.4	17484
-66879	17484
-66889.7	17484
-66900.4	17484
-66911	17484
-66921.7	17484
-66932.3	17484
-66943	17484
-66953.7	17484
-66964.3	17484
-66975	17484
-66985.7	17484
-66996.3	17484
-67007	17484
-67017.6	17484
-67028.3	17484
-67039	17484
-67049.6	17484
-67060.3	17484
-67071	17484
-67081.6	17484
-67092.3	17484
-67103	17484
-67113.6	17484
-67124.3	17484
-67134.9	17484
-67145.6	17484
-67156.3	17484
-67166.9	17484
-67177.6	17484
-67188.3	17484
-67198.9	17484
-67209.6	17484
-67220.2	17484
-67230.9	17484
-67241.6	17484
-67252.2	17484
-67262.9	17484
-67273.6	17484
-67284.2	17484
-67294.9	17484
-67305.6	17484
-67316.2	17484
-67326.9	17484
-67337.5	17484
-67348.2	17484
-67358.9	17484
-67369.5	17484
-67380.2	17484
-67390.9	17484
-67401.5	17484
-67412.2	17484
-67422.8	17484
-67433.5	17484
-67444.2	17484
-67454.8	17484
-67465.5	17484
-67476.2	17484
-67486.8	17484
-67497.5	17484
-67508.1	17484
-67518.8	17484
-67529.5	17484
-67540.1	17484
-67550.8	17484
-67561.5	17484
-67572.1	17484
-67582.8	17484
-67593.5	17484
-67604.1	17484
-67614.8	17484
-67625.4	17484
-67636.1	17484
-67646.8	17484
-67657.4	17484
-67668.1	17484
-67678.8	17484
-67689.4	17484
-67700.1	17484
-67710.7	17484
-67721.4	17484
-67732.1	17484
-67742.7	17484
-67753.4	17484
-67764.1	17484
-67774.7	17484
-67785.4	17484
-67796.1	17484
-67806.7	17484
-67817.4	17484
-67828	17484
-67838.7	17484
-67849.4	17484
-67860	17484
-67870.7	17484
-67881.4	17484
-67892	17484
-67902.7	17484
-67913.3	17484
-67924	17484
-67934.7	17484
-67945.3	17484
-67956	17484
-67966.7	17484
-67977.3	17484
-67988	17484
-67998.7	17484
-68009.3	17484
-68020	17484
-68030.6	17484
-68041.3	17484
-68052	17484
-68062.6	17484
-68073.3	17484
-68084	17484
-68094.6	17484
-68105.3	17484
-68115.9	17484
-68126.6	17484
-68137.3	17484
-68147.9	17484
-68158.6	17484
-68169.3	17484
-68179.9	17484
-68190.6	17484
-68201.3	17484
-68211.9	17484
-68222.6	17484
-68233.2	17484
-68243.9	17484
-68254.6	17484
-68265.2	17484
-68275.9	17484
-68286.6	17484
-68297.2	17484
-68307.9	17484
-68318.5	17484
-68329.2	17484
-68339.9	17484
-68350.5	17484
-68361.2	17484
-68371.9	17484
-68382.5	17484
-68393.2	17484
-68403.9	17484
-68414.5	17484
-68425.2	17484
-68435.8	17484
-68446.5	17484
-68457.2	17484
-68467.8	17484
-68478.5	17484
-68489.2	17484
-68499.8	17484
-68510.5	17484
-68521.1	17484
-68531.8	17484
-68542.5	17484
-68553.1	17484
-68563.8	17484
-68574.5	17484
-68585.1	17484
-68595.8	17484
-68606.4	17484
-68617.1	17484
-68627.8	17484
-68638.4	17484
-68649.1	17484
-68659.8	17484
-68670.4	17484
-68681.1	17484
-68691.8	17484
-68702.4	17484
-68713.1	17484
-68723.7	17484
-68734.4	17484
-68745.1	17484
-68755.7	17484
-68766.4	17484
-68777.1	17484
-68787.7	17484
-68798.4	17484
-68809	17484
-68819.7	17484
-68830.4	17484
-68841	17484
-68851.7	17484
-68862.4	17484
-68873	17484
-68883.7	17484
-68894.4	17484
-68905	17484
-68915.7	17484
-68926.3	17484
-68937	17484
-68947.7	17484
-68958.3	17484
-68969	17484
-68979.7	17484
-68990.3	17484
-69001	17484
-69011.6	17484
-69022.3	17484
-69033	17484
-69043.6	17484
-69054.3	17484
-69065	17484
-69075.6	17484
-69086.3	17484
-69097	17484
-69107.6	17484
-69118.3	17484
-69128.9	17484
-69139.6	17484
-69150.3	17484
-69160.9	17484
-69171.6	17484
-69182.3	17484
-69192.9	17484
-69203.6	17484
-69214.2	17484
-69224.9	17484
-69235.6	17484
-69246.2	17484
-69256.9	17484
-69267.6	17484
-69278.2	17484
-69288.9	17484
-69299.6	17484
-69310.2	17484
-69320.9	17484
-69331.5	17484
-69342.2	17484
-69352.9	17484
-69363.5	17484
-69374.2	17484
-69384.9	17484
-69395.5	17484
-69406.2	17484
-69416.8	17484
-69427.5	17484
-69438.2	17484
-69448.8	17484
-69459.5	17484
-69470.2	17484
-69480.8	17484
-69491.5	17484
-69502.2	17484
-69512.8	17484
-69523.5	17484
-69534.1	17484
-69544.8	17484
-69555.5	17484
-69566.1	17484
-69576.8	17484
-69587.5	17484
-69598.1	17484
-69608.8	17484
-69619.4	17484
-69630.1	17484
-69640.8	17484
-69651.4	17484
-69662.1	17484
-69672.8	17484
-69683.4	17484
-69694.1	17484
-69704.8	17484
-69715.4	17484
-69726.1	17484
-69736.7	17484
-69747.4	17484
-69758.1	17484
-69768.7	17484
-69779.4	17484
-69790.1	17484
-69800.7	17484
-69811.4	17484
-69822	17484
-69832.7	17484
-69843.4	17484
-69854	17484
-69864.7	17484
-69875.4	17484
-69886	17484
-69896.7	17484
-69907.3	17484
-69918	17484
-69928.7	17484
-69939.3	17484
-69950	17484
-69960.7	17484
-69971.3	17484
-69982	17484
-69992.7	17484
-70003.3	17484
-70014	17484
-70024.6	17484
-70035.3	17484
-70046	17484
-70056.6	17484
-70067.3	17484
-70078	17484
-70088.6	17484
-70099.3	17484
-70109.9	17484
-70120.6	17484
-70131.3	17484
-70141.9	17484
-70152.6	17484
-70163.3	17484
-70173.9	17484
-70184.6	17484
-70195.3	17484
-70205.9	17484
-70216.6	17484
-70227.2	17484
-70237.9	17484
-70248.6	17484
-70259.2	17484
-70269.9	17484
-70280.6	17484
-70291.2	17484
-70301.9	17484
-70312.5	17484
-70323.2	17484
-70333.9	17484
-70344.5	17484
-70355.2	17484
-70365.9	17484
-70376.5	17484
-70387.2	17484
-70397.9	17484
-70408.5	17484
-70419.2	17484
-70429.8	17484
-70440.5	17484
-70451.2	17484
-70461.8	17484
-70472.5	17484
-70483.2	17484
-70493.8	17484
-70504.5	17484
-70515.1	17484
-70525.8	17484
-70536.5	17484
-70547.1	17484
-70557.8	17484
-70568.5	17484
-70579.1	17484
-70589.8	17484
-70600.5	17484
-70611.1	17484
-70621.8	17484
-70632.4	17484
-70643.1	17484
-70653.8	17484
-70664.4	17484
-70675.1	17484
-70685.8	17484
-70696.4	17484
-70707.1	17484
-70717.7	17484
-70728.4	17484
-70739.1	17484
-70749.7	17484
-70760.4	17484
-70771.1	17484
-70781.7	17484
-70792.4	17484
-70803.1	17484
-70813.7	17484
-70824.4	17484
-70835	17484
-70845.7	17484
-70856.4	17484
-70867	17484
-70877.7	17484
-70888.4	17484
-70899	17484
-70909.7	17484
-70920.3	17484
-70931	17484
-70941.7	17484
-70952.3	17484
-70963	17484
-70973.7	17484
-70984.3	17484
-70995	17484
-71005.6	17484
-71016.3	17484
-71027	17484
-71037.6	17484
-71048.3	17484
-71059	17484
-71069.6	17484
-71080.3	17484
-71091	17484
-71101.6	17484
-71112.3	17484
-71122.9	17484
-71133.6	17484
-71144.3	17484
-71154.9	17484
-71165.6	17484
-71176.3	17484
-71186.9	17484
-71197.6	17484
-71208.2	17484
-71218.9	17484
-71229.6	17484
-71240.2	17484
-71250.9	17484
-71261.6	17484
-71272.2	17484
-71282.9	17484
-71293.6	17484
-71304.2	17484
-71314.9	17484
-71325.5	17484
-71336.2	17484
-71346.9	17484
-71357.5	17484
-71368.2	17484
-71378.9	17484
-71389.5	17484
-71400.2	17484
-71410.8	17484
-71421.5	17484
-71432.2	17484
-71442.8	17484
-71453.5	17484
-71464.2	17484
-71474.8	17484
-71485.5	17484
-71496.2	17484
-71506.8	17484
-71517.5	17484
-71528.1	17484
-71538.8	17484
-71549.5	17484
-71560.1	17484
-71570.8	17484
-71581.5	17484
-71592.1	17484
-71602.8	17484
-71613.4	17484
-71624.1	17484
-71634.8	17484
-71645.4	17484
-71656.1	17484
-71666.8	17484
-71677.4	17484
-71688.1	17484
-71698.8	17484
-71709.4	17484
-71720.1	17484
-71730.7	17484
-71741.4	17484
-71752.1	17484
-71762.7	17484
-71773.4	17484
-71784.1	17484
-71794.7	17484
-71805.4	17484
-71816	17484
-71826.7	17484
-71837.4	17484
-71848	17484
-71858.7	17484
-71869.4	17484
-71880	17484
-71890.7	17484
-71901.4	17484
-71912	17484
-71922.7	17484
-71933.3	17484
-71944	17484
-71954.7	17484
-71965.3	17484
-71976	17484
-71986.7	17484
-71997.3	17484
-72008	17484
-72018.6	17484
-72029.3	17484
-72040	17484
-72050.6	17484
-72061.3	17484
-72072	17484
-72082.6	17484
-72093.3	17484
-72103.9	17484
-72114.6	17484
-72125.3	17484
-72135.9	17484
-72146.6	17484
-72157.3	17484
-72167.9	17484
-72178.6	17484
-72189.3	17484
-72199.9	17484
-72210.6	17484
-72221.2	17484
-72231.9	17484
-72242.6	17484
-72253.2	17484
-72263.9	17484
-72274.6	17484
-72285.2	17484
-72295.9	17484
-72306.5	17484
-72317.2	17484
-72327.9	17484
-72338.5	17484
-72349.2	17484
-72359.9	17484
-72370.5	17484
-72381.2	17484
-72391.9	17484
-72402.5	17484
-72413.2	17484
-72423.8	17484
-72434.5	17484
-72445.2	17484
-72455.8	17484
-72466.5	17484
-72477.2	17484
-72487.8	17484
-72498.5	17484
-72509.1	17484
-72519.8	17484
-72530.5	17484
-72541.1	17484
-72551.8	17484
-72562.5	17484
-72573.1	17484
-72583.8	17484
-72594.5	17484
-72605.1	17484
-72615.8	17484
-72626.4	17484
-72637.1	17484
-72647.8	17484
-72658.4	17484
-72669.1	17484
-72679.8	17484
-72690.4	17484
-72701.1	17484
-72711.7	17484
-72722.4	17484
-72733.1	17484
-72743.7	17484
-72754.4	17484
-72765.1	17484
-72775.7	17484
-72786.4	17484
-72797.1	17484
-72807.7	17484
-72818.4	17484
-72829	17484
-72839.7	17484
-72850.4	17484
-72861	17484
-72871.7	17484
-72882.4	17484
-72893	17484
-72903.7	17484
-72914.3	17484
-72925	17484
-72935.7	17484
-72946.3	17484
-72957	17484
-72967.7	17484
-72978.3	17484
-72989	17484
-72999.7	17484
-73010.3	17484
-73021	17484
-73031.6	17484
-73042.3	17484
-73053	17484
-73063.6	17484
-73074.3	17484
-73085	17484
-73095.6	17484
-73106.3	17484
-73116.9	17484
-73127.6	17484
-73138.3	17484
-73148.9	17484
-73159.6	17484
-73170.3	17484
-73180.9	17484
-73191.6	17484
-73202.3	17484
-73212.9	17484
-73223.6	17484
-73234.2	17484
-73244.9	17484
-73255.6	17484
-73266.2	17484
-73276.9	17484
-73287.6	17484
-73298.2	17484
-73308.9	17484
-73319.5	17484
-73330.2	17484
-73340.9	17484
-73351.5	17484
-73362.2	17484
-73372.9	17484
-73383.5	17484
-73394.2	17484
-73404.8	17484
-73415.5	17484
-73426.2	17484
-73436.8	17484
-73447.5	17484
-73458.2	17484
-73468.8	17484
-73479.5	17484
-73490.2	17484
-73500.8	17484
-73511.5	17484
-73522.1	17484
-73532.8	17484
-73543.5	17484
-73554.1	17484
-73564.8	17484
-73575.5	17484
-73586.1	17484
-73596.8	17484
-73607.4	17484
-73618.1	17484
-73628.8	17484
-73639.4	17484
-73650.1	17484
-73660.8	17484
-73671.4	17484
-73682.1	17484
-73692.8	17484
-73703.4	17484
-73714.1	17484
-73724.7	17484
-73735.4	17484
-73746.1	17484
-73756.7	17484
-73767.4	17484
-73778.1	17484
-73788.7	17484
-73799.4	17484
-73810	17484
-73820.7	17484
-73831.4	17484
-73842	17484
-73852.7	17484
-73863.4	17484
-73874	17484
-73884.7	17484
-73895.4	17484
-73906	17484
-73916.7	17484
-73927.3	17484
-73938	17484
-73948.7	17484
-73959.3	17484
-73970	17484
-73980.7	17484
-73991.3	17484
-74002	17484
-74012.6	17484
-74023.3	17484
-74034	17484
-74044.6	17484
-74055.3	17484
-74066	17484
-74076.6	17484
-74087.3	17484
-74098	17484
-74108.6	17484
-74119.3	17484
-74129.9	17484
-74140.6	17484
-74151.3	17484
-74161.9	17484
-74172.6	17484
-74183.3	17484
-74193.9	17484
-74204.6	17484
-74215.2	17484
-74225.9	17484
-74236.6	17484
-74247.2	17484
-74257.9	17484
-74268.6	17484
-74279.2	17484
-74289.9	17484
-74300.6	17484
-74311.2	17484
-74321.9	17484
-74332.5	17484
-74343.2	17484
-74353.9	17484
-74364.5	17484
-74375.2	17484
-74385.9	17484
-74396.5	17484
-74407.2	17484
-74417.8	17484
-74428.5	17484
-74439.2	17484
-74449.8	17484
-74460.5	17484
-74471.2	17484
-74481.8	17484
-74492.5	17484
-74503.1	17484
-74513.8	17484
-74524.5	17484
-74535.1	17484
-74545.8	17484
-74556.5	17484
-74567.1	17484
-74577.8	17484
-74588.5	17484
-74599.1	17484
-74609.8	17484
-74620.4	17484
-74631.1	17484
-74641.8	17484
-74652.4	17484
-74663.1	17484
-74673.8	17484
-74684.4	17484
-74695.1	17484
-74705.7	17484
-74716.4	17484
-74727.1	17484
-74737.7	17484
-74748.4	17484
-74759.1	17484
-74769.7	17484
-74780.4	17484
-74791.1	17484
-74801.7	17484
-74812.4	17484
-74823	17484
-74833.7	17484
-74844.4	17484
-74855	17484
-74865.7	17484
-74876.4	17484
-74887	17484
-74897.7	17484
-74908.3	17484
-74919	17484
-74929.7	17484
-74940.3	17484
-74951	17484
-74961.7	17484
-74972.3	17484
-74983	17484
-74993.7	17484
-75004.3	17484
-75015	17484
-75025.6	17484
-75036.3	17484
-75047	17484
-75057.6	17484
-75068.3	17484
-75079	17484
-75089.6	17484
-75100.3	17484
-75110.9	17484
-75121.6	17484
-75132.3	17484
-75142.9	17484
-75153.6	17484
-75164.3	17484
-75174.9	17484
-75185.6	17484
-75196.3	17484
-75206.9	17484
-75217.6	17484
-75228.2	17484
-75238.9	17484
-75249.6	17484
-75260.2	17484
-75270.9	17484
-75281.6	17484
-75292.2	17484
-75302.9	17484
-75313.5	17484
-75324.2	17484
-75334.9	17484
-75345.5	17484
-75356.2	17484
-75366.9	17484
-75377.5	17484
-75388.2	17484
-75398.9	17484
-75409.5	17484
-75420.2	17484
-75430.8	17484
-75441.5	17484
-75452.2	17484
-75462.8	17484
-75473.5	17484
-75484.2	17484
-75494.8	17484
-75505.5	17484
-75516.1	17484
-75526.8	17484
-75537.5	17484
-75548.1	17484
-75558.8	17484
-75569.5	17484
-75580.1	17484
-75590.8	17484
-75601.4	17484
-75612.1	17484
-75622.8	17484
-75633.4	17484
-75644.1	17484
-75654.8	17484
-75665.4	17484
-75676.1	17484
-75686.8	17484
-75697.4	17484
-75708.1	17484
-75718.7	17484
-75729.4	17484
-75740.1	17484
-75750.7	17484
-75761.4	17484
-75772.1	17484
-75782.7	17484
-75793.4	17484
-75804	17484
-75814.7	17484
-75825.4	17484
-75836	17484
-75846.7	17484
-75857.4	17484
-75868	17484
-75878.7	17484
-75889.4	17484
-75900	17484
-75910.7	17484
-75921.3	17484
-75932	17484
-75942.7	17484
-75953.3	17484
-75964	17484
-75974.7	17484
-75985.3	17484
-75996	17484
-76006.6	17484
-76017.3	17484
-76028	17484
-76038.6	17484
-76049.3	17484
-76060	17484
-76070.6	17484
-76081.3	17484
-76092	17484
-76102.6	17484
-76113.3	17484
-76123.9	17484
-76134.6	17484
-76145.3	17484
-76155.9	17484
-76166.6	17484
-76177.3	17484
-76187.9	17484
-76198.6	17484
-76209.2	17484
-76219.9	17484
-76230.6	17484
-76241.2	17484
-76251.9	17484
-76262.6	17484
-76273.2	17484
-76283.9	17484
-76294.6	17484
-76305.2	17484
-76315.9	17484
-76326.5	17484
-76337.2	17484
-76347.9	17484
-76358.5	17484
-76369.2	17484
-76379.9	17484
-76390.5	17484
-76401.2	17484
-76411.8	17484
-76422.5	17484
-76433.2	17484
-76443.8	17484
-76454.5	17484
-76465.2	17484
-76475.8	17484
-76486.5	17484
-76497.2	17484
-76507.8	17484
-76518.5	17484
-76529.1	17484
-76539.8	17484
-76550.5	17484
-76561.1	17484
-76571.8	17484
-76582.5	17484
-76593.1	17484
-76603.8	17484
-76614.4	17484
-76625.1	17484
-76635.8	17484
-76646.4	17484
-76657.1	17484
-76667.8	17484
-76678.4	17484
-76689.1	17484
-76699.8	17484
-76710.4	17484
-76721.1	17484
-76731.7	17484
-76742.4	17484
-76753.1	17484
-76763.7	17484
-76774.4	17484
-76785.1	17484
-76795.7	17484
-76806.4	17484
-76817	17484
-76827.7	17484
-76838.4	17484
-76849	17484
-76859.7	17484
-76870.4	17484
-76881	17484
-76891.7	17484
-76902.3	17484
-76913	17484
-76923.7	17484
-76934.3	17484
-76945	17484
-76955.7	17484
-76966.3	17484
-76977	17484
-76987.7	17484
-76998.3	17484
-77009	17484
-77019.6	17484
-77030.3	17484
-77041	17484
-77051.6	17484
-77062.3	17484
-77073	17484
-77083.6	17484
-77094.3	17484
-77104.9	17484
-77115.6	17484
-77126.3	17484
-77136.9	17484
-77147.6	17484
-77158.3	17484
-77168.9	17484
-77179.6	17484
-77190.3	17484
-77200.9	17484
-77211.6	17484
-77222.2	17484
-77232.9	17484
-77243.6	17484
-77254.2	17484
-77264.9	17484
-77275.6	17484
-77286.2	17484
-77296.9	17484
-77307.5	17484
-77318.2	17484
-77328.9	17484
-77339.5	17484
-77350.2	17484
-77360.9	17484
-77371.5	17484
-77382.2	17484
-77392.9	17484
-77403.5	17484
-77414.2	17484
-77424.8	17484
-77435.5	17484
-77446.2	17484
-77456.8	17484
-77467.5	17484
-77478.2	17484
-77488.8	17484
-77499.5	17484
-77510.1	17484
-77520.8	17484
-77531.5	17484
-77542.1	17484
-77552.8	17484
-77563.5	17484
-77574.1	17484
-77584.8	17484
-77595.5	17484
-77606.1	17484
-77616.8	17484
-77627.4	17484
-77638.1	17484
-77648.8	17484
-77659.4	17484
-77670.1	17484
-77680.8	17484
-77691.4	17484
-77702.1	17484
-77712.7	17484
-77723.4	17484
-77734.1	17484
-77744.7	17484
-77755.4	17484
-77766.1	17484
-77776.7	17484
-77787.4	17484
-77798.1	17484
-77808.7	17484
-77819.4	17484
-77830	17484
-77840.7	17484
-77851.4	17484
-77862	17484
-77872.7	17484
-77883.4	17484
-77894	17484
-77904.7	17484
-77915.3	17484
-77926	17484
-77936.7	17484
-77947.3	17484
-77958	17484
-77968.7	17484
-77979.3	17484
-77990	17484
-78000.6	17484
-78011.3	17484
-78022	17484
-78032.6	17484
-78043.3	17484
-78054	17484
-78064.6	17484
-78075.3	17484
-78086	17484
-78096.6	17484
-78107.3	17484
-78117.9	17484
-78128.6	17484
-78139.3	17484
-78149.9	17484
-78160.6	17484
-78171.3	17484
-78181.9	17484
-78192.6	17484
-78203.2	17484
-78213.9	17484
-78224.6	17484
-78235.2	17484
-78245.9	17484
-78256.6	17484
-78267.2	17484
-78277.9	17484
-78288.6	17484
-78299.2	17484
-78309.9	17484
-78320.5	17484
-78331.2	17484
-78341.9	17484
-78352.5	17484
-78363.2	17484
-78373.9	17484
-78384.5	17484
-78395.2	17484
-78405.8	17484
-78416.5	17484
-78427.2	17484
-78437.8	17484
-78448.5	17484
-78459.2	17484
-78469.8	17484
-78480.5	17484
-78491.2	17484
-78501.8	17484
-78512.5	17484
-78523.1	17484
-78533.8	17484
-78544.5	17484
-78555.1	17484
-78565.8	17484
-78576.5	17484
-78587.1	17484
-78597.8	17484
-78608.4	17484
-78619.1	17484
-78629.8	17484
-78640.4	17484
-78651.1	17484
-78661.8	17484
-78672.4	17484
-78683.1	17484
-78693.8	17484
-78704.4	17484
-78715.1	17484
-78725.7	17484
-78736.4	17484
-78747.1	17484
-78757.7	17484
-78768.4	17484
-78779.1	17484
-78789.7	17484
-78800.4	17484
-78811	17484
-78821.7	17484
-78832.4	17484
-78843	17484
-78853.7	17484
-78864.4	17484
-78875	17484
-78885.7	17484
-78896.4	17484
-78907	17484
-78917.7	17484
-78928.3	17484
-78939	17484
-78949.7	17484
-78960.3	17484
-78971	17484
-78981.7	17484
-78992.3	17484
-79003	17484
-79013.6	17484
-79024.3	17484
-79035	17484
-79045.6	17484
-79056.3	17484
-79067	17484
-79077.6	17484
-79088.3	17484
-79098.9	17484
-79109.6	17484
-79120.3	17484
-79130.9	17484
-79141.6	17484
-79152.3	17484
-79162.9	17484
-79173.6	17484
-79184.3	17484
-79194.9	17484
-79205.6	17484
-79216.2	17484
-79226.9	17484
-79237.6	17484
-79248.2	17484
-79258.9	17484
-79269.6	17484
-79280.2	17484
-79290.9	17484
-79301.5	17484
-79312.2	17484
-79322.9	17484
-79333.5	17484
-79344.2	17484
-79354.9	17484
-79365.5	17484
-79376.2	17484
-79386.9	17484
-79397.5	17484
-79408.2	17484
-79418.8	17484
-79429.5	17484
-79440.2	17484
-79450.8	17484
-79461.5	17484
-79472.2	17484
-79482.8	17484
-79493.5	17484
-79504.1	17484
-79514.8	17484
-79525.5	17484
-79536.1	17484
-79546.8	17484
-79557.5	17484
-79568.1	17484
-79578.8	17484
-79589.5	17484
-79600.1	17484
-79610.8	17484
-79621.4	17484
-79632.1	17484
-79642.8	17484
-79653.4	17484
-79664.1	17484
-79674.8	17484
-79685.4	17484
-79696.1	17484
-79706.7	17484
-79717.4	17484
-79728.1	17484
-79738.7	17484
-79749.4	17484
-79760.1	17484
-79770.7	17484
-79781.4	17484
-79792.1	17484
-79802.7	17484
-79813.4	17484
-79824	17484
-79834.7	17484
-79845.4	17484
-79856	17484
-79866.7	17484
-79877.4	17484
-79888	17484
-79898.7	17484
-79909.3	17484
-79920	17484
-79930.7	17484
-79941.3	17484
-79952	17484
-79962.7	17484
-79973.3	17484
-79984	17484
-79994.7	17484
-80005.3	17484
-80016	17484
-80026.6	17484
-80037.3	17484
-80048	17484
-80058.6	17484
-80069.3	17484
-80080	17484
-80090.6	17484
-80101.3	17484
-80111.9	17484
-80122.6	17484
-80133.3	17484
-80143.9	17484
-80154.6	17484
-80165.3	17484
-80175.9	17484
-80186.6	17484
-80197.3	17484
-80207.9	17484
-80218.6	17484
-80229.2	17484
-80239.9	17484
-80250.6	17484
-80261.2	17484
-80271.9	17484
-80282.6	17484
-80293.2	17484
-80303.9	17484
-80314.5	17484
-80325.2	17484
-80335.9	17484
-80346.5	17484
-80357.2	17484
-80367.9	17484
-80378.5	17484
-80389.2	17484
-80399.8	17484
-80410.5	17484
-80421.2	17484
-80431.8	17484
-80442.5	17484
-80453.2	17484
-80463.8	17484
-80474.5	17484
-80485.2	17484
-80495.8	17484
-80506.5	17484
-80517.1	17484
-80527.8	17484
-80538.5	17484
-80549.1	17484
-80559.8	17484
-80570.5	17484
-80581.1	17484
-80591.8	17484
-80602.4	17484
-80613.1	17484
-80623.8	17484
-80634.4	17484
-80645.1	17484
-80655.8	17484
-80666.4	17484
-80677.1	17484
-80687.8	17484
-80698.4	17484
-80709.1	17484
-80719.7	17484
-80730.4	17484
-80741.1	17484
-80751.7	17484
-80762.4	17484
-80773.1	17484
-80783.7	17484
-80794.4	17484
-80805	17484
-80815.7	17484
-80826.4	17484
-80837	17484
-80847.7	17484
-80858.4	17484
-80869	17484
-80879.7	17484
-80890.4	17484
-80901	17484
-80911.7	17484
-80922.3	17484
-80933	17484
-80943.7	17484
-80954.3	17484
-80965	17484
-80975.7	17484
-80986.3	17484
-80997	17484
-81007.6	17484
-81018.3	17484
-81029	17484
-81039.6	17484
-81050.3	17484
-81061	17484
-81071.6	17484
-81082.3	17484
-81093	17484
-81103.6	17484
-81114.3	17484
-81124.9	17484
-81135.6	17484
-81146.3	17484
-81156.9	17484
-81167.6	17484
-81178.3	17484
-81188.9	17484
-81199.6	17484
-81210.2	17484
-81220.9	17484
-81231.6	17484
-81242.2	17484
-81252.9	17484
-81263.6	17484
-81274.2	17484
-81284.9	17484
-81295.6	17484
-81306.2	17484
-81316.9	17484
-81327.5	17484
-81338.2	17484
-81348.9	17484
-81359.5	17484
-81370.2	17484
-81380.9	17484
-81391.5	17484
-81402.2	17484
-81412.8	17484
-81423.5	17484
-81434.2	17484
-81444.8	17484
-81455.5	17484
-81466.2	17484
-81476.8	17484
-81487.5	17484
-81498.1	17484
-81508.8	17484
-81519.5	17484
-81530.1	17484
-81540.8	17484
-81551.5	17484
-81562.1	17484
-81572.8	17484
-81583.5	17484
-81594.1	17484
-81604.8	17484
-81615.4	17484
-81626.1	17484
-81636.8	17484
-81647.4	17484
-81658.1	17484
-81668.8	17484
-81679.4	17484
-81690.1	17484
-81700.7	17484
-81711.4	17484
-81722.1	17484
-81732.7	17484
-81743.4	17484
-81754.1	17484
-81764.7	17484
-81775.4	17484
-81786.1	17484
-81796.7	17484
-81807.4	17484
-81818	17484
-81828.7	17484
-81839.4	17484
-81850	17484
-81860.7	17484
-81871.4	17484
-81882	17484
-81892.7	17484
-81903.3	17484
-81914	17484
-81924.7	17484
-81935.3	17484
-81946	17484
-81956.7	17484
-81967.3	17484
-81978	17484
-81988.7	17484
-81999.3	17484
-82010	17484
-82020.6	17484
-82031.3	17484
-82042	17484
-82052.6	17484
-82063.3	17484
-82074	17484
-82084.6	17484
-82095.3	17484
-82105.9	17484
-82116.6	17484
-82127.3	17484
-82137.9	17484
-82148.6	17484
-82159.3	17484
-82169.9	17484
-82180.6	17484
-82191.3	17484
-82201.9	17484
-82212.6	17484
-82223.2	17484
-82233.9	17484
-82244.6	17484
-82255.2	17484
-82265.9	17484
-82276.6	17484
-82287.2	17484
-82297.9	17484
-82308.5	17484
-82319.2	17484
-82329.9	17484
-82340.5	17484
-82351.2	17484
-82361.9	17484
-82372.5	17484
-82383.2	17484
-82393.9	17484
-82404.5	17484
-82415.2	17484
-82425.8	17484
-82436.5	17484
-82447.2	17484
-82457.8	17484
-82468.5	17484
-82479.2	17484
-82489.8	17484
-82500.5	17484
-82511.1	17484
-82521.8	17484
-82532.5	17484
-82543.1	17484
-82553.8	17484
-82564.5	17484
-82575.1	17484
-82585.8	17484
-82596.5	17484
-82607.1	17484
-82617.8	17484
-82628.4	17484
-82639.1	17484
-82649.8	17484
-82660.4	17484
-82671.1	17484
-82681.8	17484
-82692.4	17484
-82703.1	17484
-82713.7	17484
-82724.4	17484
-82735.1	17484
-82745.7	17484
-82756.4	17484
-82767.1	17484
-82777.7	17484
-82788.4	17484
-82799	17484
-82809.7	17484
-82820.4	17484
-82831	17484
-82841.7	17484
-82852.4	17484
-82863	17484
-82873.7	17484
-82884.4	17484
-82895	17484
-82905.7	17484
-82916.3	17484
-82927	17484
-82937.7	17484
-82948.3	17484
-82959	17484
-82969.7	17484
-82980.3	17484
-82991	17484
-83001.6	17484
-83012.3	17484
-83023	17484
-83033.6	17484
-83044.3	17484
-83055	17484
-83065.6	17484
-83076.3	17484
-83087	17484
-83097.6	17484
-83108.3	17484
-83118.9	17484
-83129.6	17484
-83140.3	17484
-83150.9	17484
-83161.6	17484
-83172.3	17484
-83182.9	17484
-83193.6	17484
-83204.2	17484
-83214.9	17484
-83225.6	17484
-83236.2	17484
-83246.9	17484
-83257.6	17484
-83268.2	17484
-83278.9	17484
-83289.6	17484
-83300.2	17484
-83310.9	17484
-83321.5	17484
-83332.2	17484
-83342.9	17484
-83353.5	17484
-83364.2	17484
-83374.9	17484
-83385.5	17484
-83396.2	17484
-83406.8	17484
-83417.5	17484
-83428.2	17484
-83438.8	17484
-83449.5	17484
-83460.2	17484
-83470.8	17484
-83481.5	17484
-83492.2	17484
-83502.8	17484
-83513.5	17484
-83524.1	17484
-83534.8	17484
-83545.5	17484
-83556.1	17484
-83566.8	17484
-83577.5	17484
-83588.1	17484
-83598.8	17484
-83609.4	17484
-83620.1	17484
-83630.8	17484
-83641.4	17484
-83652.1	17484
-83662.8	17484
-83673.4	17484
-83684.1	17484
-83694.8	17484
-83705.4	17484
-83716.1	17484
-83726.7	17484
-83737.4	17484
-83748.1	17484
-83758.7	17484
-83769.4	17484
-83780.1	17484
-83790.7	17484
-83801.4	17484
-83812	17484
-83822.7	17484
-83833.4	17484
-83844	17484
-83854.7	17484
-83865.4	17484
-83876	17484
-83886.7	17484
-83897.3	17484
-83908	17484
-83918.7	17484
-83929.3	17484
-83940	17484
-83950.7	17484
-83961.3	17484
-83972	17484
-83982.7	17484
-83993.3	17484
-84004	17484
-84014.6	17484
-84025.3	17484
-84036	17484
-84046.6	17484
-84057.3	17484
-84068	17484
-84078.6	17484
-84089.3	17484
-84099.9	17484
-84110.6	17484
-84121.3	17484
-84131.9	17484
-84142.6	17484
-84153.3	17484
-84163.9	17484
-84174.6	17484
-84185.3	17484
-84195.9	17484
-84206.6	17484
-84217.2	17484
-84227.9	17484
-84238.6	17484
-84249.2	17484
-84259.9	17484
-84270.6	17484
-84281.2	17484
-84291.9	17484
-84302.5	17484
-84313.2	17484
-84323.9	17484
-84334.5	17484
-84345.2	17484
-84355.9	17484
-84366.5	17484
-84377.2	17484
-84387.9	17484
-84398.5	17484
-84409.2	17484
-84419.8	17484
-84430.5	17484
-84441.2	17484
-84451.8	17484
-84462.5	17484
-84473.2	17484
-84483.8	17484
-84494.5	17484
-84505.1	17484
-84515.8	17484
-84526.5	17484
-84537.1	17484
-84547.8	17484
-84558.5	17484
-84569.1	17484
-84579.8	17484
-84590.5	17484
-84601.1	17484
-84611.8	17484
-84622.4	17484
-84633.1	17484
-84643.8	17484
-84654.4	17484
-84665.1	17484
-84675.8	17484
-84686.4	17484
-84697.1	17484
-84707.7	17484
-84718.4	17484
-84729.1	17484
-84739.7	17484
-84750.4	17484
-84761.1	17484
-84771.7	17484
-84782.4	17484
-84793.1	17484
-84803.7	17484
-84814.4	17484
-84825	17484
-84835.7	17484
-84846.4	17484
-84857	17484
-84867.7	17484
-84878.4	17484
-84889	17484
-84899.7	17484
-84910.3	17484
-84921	17484
-84931.7	17484
-84942.3	17484
-84953	17484
-84963.7	17484
-84974.3	17484
-84985	17484
-84995.6	17484
-85006.3	17484
-85017	17484
-85027.6	17484
-85038.3	17484
-85049	17484
-85059.6	17484
-85070.3	17484
-85081	17484
-85091.6	17484
-85102.3	17484
-85112.9	17484
-85123.6	17484
-85134.3	17484
-85144.9	17484
-85155.6	17484
-85166.3	17484
-85176.9
Deleted: SwiftApps/SciColSim/plot_ready_jobs.txt
--- SwiftApps/SciColSim/plot_ready_jobs.txt	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/plot_ready_jobs.txt	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,6239 +0,0 @@
-11
-19
-14
-19
-17
-13
-19
-19
-10
-2
-18
-19
-16
-12
-13
-12
-11
-2
-11
-15
-16
-11
-19
-2
-17
-11
-19
-18
-2
-13
-10
-9
-19
-19
-11
-19
-18
-12
-17
-11
-18
-17
-11
-12
-12
-11
-12
-14
-19
-2
-10
-10
-11
-19
-11
-17
-11
-11
-13
-11
-19
-19
-12
-18
-19
-17
-19
-2
-11
-12
-13
-19
-19
-18
-11
-12
-19
-15
-19
-11
-2
-12
-19
-19
-19
-11
-11
-11
-11
-19
-18
-11
-11
-19
-11
-10
-18
-11
-19
-11
-14
-18
-2
-11
-10
-11
-18
-11
-12
-11
-19
-11
-11
-11
-11
-18
-11
-11
-11
-11
-2
-11
-19
-19
-11
-19
-11
-19
-11
-19
-18
-19
-12
-17
-19
-2
-16
-15
-11
-11
-19
-12
-12
-11
-19
-16
-11
-10
-19
-19
-18
-11
-18
-2
-12
-11
-12
-19
-19
-10
-19
-19
-18
-12
-12
-11
-18
-12
-2
-19
-18
-11
-11
-19
-19
-19
-11
-11
-17
-11
-12
-2
-19
-11
-12
-11
-11
-19
-18
-9
-11
-18
-19
-12
-19
-2
-11
-11
-12
-11
-2
-11
-10
-14
-11
-19
-19
-12
-18
-19
-19
-11
-2
-18
-19
-10
-17
-18
-11
-11
-11
-19
-19
-11
-17
-11
-12
-12
-13
-11
-18
-11
-19
-19
-19
-19
-11
-18
-19
-17
-12
-12
-11
-19
-11
-11
-19
-12
-11
-19
-19
-15
-11
-17
-2
-13
-13
-11
-19
-19
-11
-12
-18
-19
-11
-17
-2
-19
-13
-13
-11
-19
-12
-10
-10
-11
-19
-11
-12
-19
-12
-19
-11
-18
-12
-9
-19
-13
-11
-16
-11
-11
-17
-19
-2
-12
-19
-19
-11
-11
-11
-14
-11
-16
-19
-16
-18
-19
-19
-12
-19
-12
-19
-17
-10
-10
-2
-11
-12
-13
-19
-10
-10
-19
-19
-19
-12
-11
-19
-19
-10
-2
-17
-19
-10
-12
-12
-19
-2
-19
-11
-12
-19
-19
-13
-16
-19
-18
-12
-19
-12
-12
-19
-18
-11
-11
-11
-19
-19
-11
-12
-18
-2
-19
-15
-11
-11
-18
-12
-14
-10
-11
-9
-16
-17
-12
-18
-19
-19
-11
-11
-18
-2
-17
-16
-19
-12
-11
-12
-11
-19
-11
-12
-11
-11
-17
-11
-11
-17
-19
-2
-17
-11
-13
-2
-12
-11
-12
-19
-11
-10
-11
-19
-19
-12
-11
-11
-19
-13
-12
-10
-19
-19
-11
-19
-19
-19
-12
-18
-13
-11
-18
-10
-17
-16
-11
-17
-18
-10
-19
-17
-11
-17
-16
-2
-11
-11
-13
-19
-19
-11
-11
-11
-11
-12
-19
-19
-18
-12
-11
-19
-18
-13
-11
-2
-2
-11
-10
-11
-11
-11
-19
-12
-17
-19
-2
-11
-11
-19
-15
-11
-2
-19
-11
-11
-19
-10
-19
-13
-13
-11
-19
-19
-19
-11
-12
-2
-19
-18
-2
-11
-10
-10
-11
-18
-19
-2
-11
-17
-11
-11
-19
-12
-11
-12
-2
-11
-11
-21
-22
-19
-12
-12
-19
-2
-13
-18
-19
-19
-12
-19
-2
-11
-12
-12
-19
-10
-11
-19
-2
-11
-12
-17
-12
-12
-11
-2
-2
-11
-18
-19
-11
-11
-11
-11
-19
-12
-19
-2
-17
-11
-19
-16
-11
-11
-16
-18
-11
-11
-11
-19
-11
-19
-13
-19
-12
-10
-11
-12
-17
-14
-18
-18
-19
-10
-14
-18
-19
-19
-10
-12
-2
-19
-9
-11
-15
-19
-19
-18
-10
-11
-11
-13
-11
-9
-12
-11
-19
-11
-10
-19
-19
-9
-11
-13
-19
-19
-14
-12
-19
-11
-12
-11
-11
-19
-19
-12
-12
-12
-11
-19
-10
-13
-19
-19
-19
-10
-12
-11
-19
-19
-17
-19
-18
-11
-13
-18
-19
-12
-18
-2
-19
-19
-12
-12
-11
-2
-16
-17
-11
-11
-12
-2
-12
-18
-12
-19
-19
-17
-10
-10
-19
-18
-10
-11
-2
-10
-2
-11
-19
-11
-11
-11
-2
-17
-11
-18
-11
-17
-11
-11
-2
-11
-19
-11
-18
-19
-2
-11
-19
-19
-18
-19
-11
-11
-19
-19
-19
-11
-11
-19
-11
-19
-19
-17
-19
-11
-11
-19
-11
-9
-19
-11
-11
-19
-19
-19
-18
-19
-19
-18
-19
-11
-11
-2
-19
-11
-19
-19
-19
-17
-11
-19
-19
-2
-11
-11
-19
-12
-11
-19
-14
-19
-17
-19
-18
-11
-2
-19
-19
-19
-2
-19
-19
-19
-2
-19
-11
-2
-19
-11
-19
-19
-19
-18
-19
-19
-2
-2
-19
-2
-19
-11
-19
-11
-11
-19
-2
-2
-11
-19
-19
-11
-11
-18
-19
-19
-19
-19
-11
-11
-2
-19
-19
-19
-19
-19
-11
-11
-2
-2
-2
-19
-19
-11
-11
-19
-2
-18
-11
-19
-19
-19
-19
-19
-10
-2
-19
-11
-11
-19
-19
-18
-18
-19
-2
-16
-19
-2
-19
-2
-12
-11
-19
-11
-11
-19
-19
-11
-11
-19
-16
-19
-19
-17
-19
-2
-19
-19
-11
-19
-11
-19
-2
-14
-19
-11
-19
-19
-19
-11
-19
-11
-2
-19
-19
-19
-19
-19
-2
-19
-19
-19
-19
-2
-18
-19
-19
-18
-19
-11
-12
-19
-17
-2
-11
-19
-19
-10
-18
-19
-11
-19
-2
-11
-19
-10
-19
-11
-19
-19
-19
-2
-19
-10
-2
-19
-2
-13
-19
-19
-19
-19
-19
-11
-19
-2
-19
-2
-19
-19
-19
-19
-19
-2
-19
-2
-10
-19
-19
-18
-11
-19
-17
-18
-2
-11
-18
-11
-2
-19
-11
-2
-11
-2
-11
-11
-19
-19
-19
-19
-19
-19
-13
-19
-11
-19
-2
-18
-11
-18
-2
-2
-2
-11
-19
-19
-12
-11
-19
-11
-19
-2
-2
-19
-19
-19
-18
-19
-2
-2
-19
-19
-18
-11
-19
-11
-2
-19
-11
-11
-19
-19
-19
-2
-19
-9
-11
-19
-11
-18
-2
-19
-19
-10
-19
-19
-11
-19
-2
-11
-19
-19
-19
-19
-19
-19
-10
-19
-19
-19
-19
-2
-19
-2
-11
-19
-2
-11
-11
-11
-19
-19
-11
-2
-19
-19
-2
-19
-19
-19
-19
-2
-2
-19
-2
-19
-19
-19
-2
-11
-19
-11
-11
-19
-19
-19
-2
-19
-2
-2
-19
-19
-11
-19
-2
-19
-11
-10
-18
-19
-19
-18
-19
-19
-11
-19
-2
-19
-12
-19
-19
-11
-11
-19
-10
-19
-2
-11
-19
-11
-19
-2
-11
-11
-11
-2
-19
-11
-19
-18
-11
-11
-19
-11
-2
-19
-11
-2
-19
-19
-19
-2
-19
-2
-19
-18
-19
-17
-2
-18
-19
-2
-19
-11
-11
-11
-11
-19
-18
-11
-2
-19
-19
-2
-19
-19
-19
-11
-19
-11
-2
-2
-19
-10
-11
-19
-16
-11
-11
-2
-19
-19
-18
-19
-18
-2
-18
-17
-19
-11
-19
-12
-19
-12
-19
-12
-19
-9
-11
-12
-2
-19
-19
-19
-11
-19
-19
-11
-19
-2
-11
-11
-19
-19
-11
-19
-2
-18
-19
-16
-19
-2
-19
-11
-19
-19
-10
-11
-13
-11
-19
-11
-18
-11
-2
-19
-2
-19
-18
-11
-2
-2
-11
-19
-10
-19
-16
-19
-11
-19
-11
-19
-11
-19
-19
-12
-12
-11
-19
-18
-11
-19
-2
-2
-2
-19
-18
-19
-19
-11
-19
-19
-19
-2
-19
-11
-11
-2
-11
-19
-18
-19
-2
-19
-11
-11
-19
-2
-11
-11
-19
-19
-18
-2
-19
-2
-19
-11
-12
-19
-19
-2
-19
-19
-19
-2
-19
-18
-2
-11
-19
-2
-17
-11
-2
-18
-19
-2
-19
-11
-19
-19
-19
-19
-2
-11
-19
-19
-19
-19
-19
-19
-19
-11
-18
-19
-2
-17
-19
-2
-11
-19
-19
-11
-11
-2
-17
-18
-11
-19
-11
-19
-19
-17
-11
-19
-19
-11
-11
-19
-11
-18
-11
-19
-19
-11
-19
-19
-18
-19
-11
-19
-2
-18
-19
-2
-19
-11
-2
-19
-19
-11
-19
-2
-19
-18
-19
-19
-2
-2
-19
-19
-11
-19
-2
-19
-11
-2
-18
-19
-11
-11
-11
-18
-19
-19
-2
-11
-2
-2
-18
-2
-19
-2
-2
-11
-18
-19
-2
-2
-11
-19
-13
-11
-19
-11
-19
-19
-2
-11
-19
-11
-11
-19
-16
-19
-2
-19
-18
-19
-19
-12
-11
-11
-19
-17
-11
-2
-19
-11
-19
-11
-2
-19
-2
-11
-19
-19
-19
-11
-19
-17
-12
-19
-19
-18
-19
-2
-18
-19
-2
-19
-19
-11
-19
-18
-19
-11
-18
-19
-16
-2
-19
-11
-19
-11
-19
-11
-19
-2
-19
-19
-17
-19
-11
-11
-19
-19
-11
-19
-19
-12
-12
-19
-2
-19
-17
-10
-19
-19
-11
-19
-19
-19
-18
-19
-2
-11
-11
-19
-2
-10
-11
-2
-19
-11
-19
-19
-11
-19
-2
-11
-19
-19
-19
-18
-19
-2
-19
-12
-10
-12
-2
-19
-19
-11
-19
-19
-18
-2
-19
-18
-17
-18
-12
-2
-19
-11
-10
-11
-2
-11
-12
-19
-19
-14
-2
-19
-11
-11
-19
-19
-11
-18
-19
-12
-12
-19
-18
-18
-2
-11
-11
-2
-19
-19
-11
-19
-10
-18
-18
-11
-11
-19
-12
-11
-18
-11
-11
-11
-2
-2
-19
-11
-12
-18
-19
-19
-14
-12
-18
-19
-11
-12
-19
-11
-11
-2
-19
-18
-13
-19
-11
-19
-16
-11
-17
-11
-19
-11
-19
-11
-18
-10
-10
-11
-11
-19
-17
-19
-17
-11
-2
-19
-19
-2
-12
-11
-19
-19
-19
-18
-16
-19
-12
-11
-10
-11
-11
-11
-17
-11
-19
-13
-2
-19
-11
-11
-11
-2
-16
-2
-19
-19
-17
-2
-18
-11
-12
-19
-2
-17
-11
-11
-11
-11
-11
-12
-19
-11
-19
-18
-10
-19
-11
-19
-11
-19
-11
-19
-11
-17
-11
-17
-12
-17
-11
-11
-18
-19
-19
-9
-11
-2
-19
-19
-16
-2
-19
-11
-14
-19
-12
-19
-19
-17
-13
-15
-19
-19
-12
-19
-2
-2
-16
-19
-19
-11
-12
-18
-12
-12
-19
-15
-16
-11
-2
-11
-11
-16
-11
-11
-17
-11
-18
-17
-2
-10
-12
-11
-19
-19
-2
-2
-2
-19
-13
-19
-2
-14
-13
-19
-19
-10
-19
-11
-19
-11
-2
-19
-11
-11
-19
-19
-9
-11
-11
-19
-12
-12
-11
-19
-11
-15
-2
-2
-18
-11
-19
-17
-19
-19
-10
-11
-19
-11
-10
-12
-2
-15
-13
-17
-18
-11
-13
-2
-11
-19
-11
-11
-11
-16
-12
-2
-2
-11
-11
-12
-11
-19
-12
-11
-11
-12
-11
-19
-2
-12
-17
-11
-11
-11
-16
-19
-12
-11
-19
-19
-12
-19
-19
-11
-16
-19
-19
-19
-12
-19
-12
-11
-11
-11
-14
-11
-2
-19
-11
-11
-11
-10
-11
-16
-11
-2
-10
-11
-17
-10
-19
-10
-11
-11
-17
-16
-19
-16
-11
-11
-17
-11
-11
-19
-10
-19
-19
-19
-19
-11
-12
-18
-19
-10
-19
-19
-11
-19
-19
-11
-2
-19
-19
-11
-19
-19
-17
-18
-18
-2
-11
-11
-11
-19
-13
-11
-11
-18
-10
-12
-17
-18
-11
-18
-11
-11
-19
-9
-17
-2
-2
-11
-11
-17
-2
-11
-18
-11
-13
-19
-19
-11
-10
-13
-17
-19
-19
-19
-19
-11
-10
-11
-11
-11
-19
-13
-16
-19
-12
-12
-19
-19
-11
-19
-19
-16
-17
-14
-19
-19
-15
-19
-2
-19
-19
-19
-18
-19
-2
-19
-19
-2
-2
-2
-19
-11
-19
-19
-11
-19
-2
-11
-11
-19
-19
-18
-19
-2
-2
-19
-19
-16
-19
-19
-19
-19
-2
-19
-19
-11
-19
-19
-2
-19
-19
-12
-12
-19
-19
-17
-11
-19
-19
-19
-19
-19
-19
-19
-11
-11
-19
-11
-2
-19
-2
-19
-19
-11
-11
-11
-11
-19
-2
-19
-11
-11
-2
-19
-19
-19
-19
-19
-2
-19
-11
-11
-11
-19
-19
-19
-19
-19
-19
-19
-18
-2
-11
-12
-12
-2
-19
-18
-2
-19
-19
-11
-19
-19
-19
-19
-19
-11
-19
-19
-19
-19
-19
-11
-19
-19
-19
-11
-12
-11
-2
-19
-11
-2
-19
-17
-19
-11
-2
-19
-17
-19
-11
-18
-19
-12
-2
-19
-18
-12
-19
-11
-2
-16
-19
-11
-11
-19
-19
-19
-11
-2
-19
-18
-19
-19
-19
-2
-11
-19
-19
-18
-19
-19
-19
-11
-11
-11
-11
-19
-19
-11
-2
-18
-19
-18
-19
-19
-11
-19
-19
-19
-11
-2
-19
-11
-11
-12
-2
-11
-19
-19
-11
-19
-19
-11
-19
-18
-11
-2
-19
-11
-19
-19
-2
-19
-10
-11
-11
-11
-19
-11
-2
-19
-19
-19
-19
-19
-2
-19
-18
-19
-19
-11
-19
-19
-18
-19
-17
-11
-19
-19
-2
-11
-19
-19
-19
-18
-10
-2
-19
-19
-2
-11
-19
-11
-19
-19
-19
-19
-2
-19
-19
-2
-19
-19
-19
-2
-10
-18
-2
-11
-19
-19
-11
-19
-19
-19
-11
-2
-11
-19
-19
-19
-19
-19
-11
-19
-19
-2
-19
-2
-19
-19
-19
-19
-11
-2
-2
-2
-11
-11
-19
-11
-17
-2
-19
-19
-18
-19
-16
-19
-19
-11
-11
-19
-19
-11
-11
-19
-11
-19
-11
-19
-11
-19
-11
-2
-11
-19
-19
-11
-19
-19
-11
-2
-19
-11
-19
-14
-13
-18
-18
-18
-18
-18
-18
-18
-18
-18
-18
-20
-21
-4
-4
-4
-4
-13
-21
-21
-12
-11
-19
-18
-17
-12
-19
-11
-19
-19
-11
-13
-18
-19
-10
-18
-11
-19
-11
-10
-11
-11
-16
-18
-10
-2
-19
-2
-10
-19
-11
-11
-2
-19
-14
-16
-19
-12
-11
-19
-19
-11
-11
-11
-19
-19
-19
-2
-2
-12
-18
-2
-19
-12
-18
-11
-11
-11
-19
-11
-11
-18
-19
-18
-11
-11
-18
-19
-18
-2
-2
-11
-2
-19
-2
-10
-19
-11
-19
-17
-12
-18
-2
-10
-11
-11
-19
-19
-11
-17
-19
-19
-19
-11
-12
-19
-12
-11
-19
-19
-11
-10
-19
-19
-19
-15
-18
-19
-11
-10
-17
-11
-19
-9
-12
-19
-13
-9
-19
-19
-11
-18
-2
-19
-19
-10
-19
-2
-2
-17
-16
-11
-2
-19
-11
-11
-11
-2
-2
-19
-11
-18
-19
-19
-19
-11
-11
-2
-19
-10
-13
-11
-19
-11
-18
-12
-18
-19
-2
-19
-11
-19
-2
-2
-11
-11
-11
-11
-18
-11
-11
-11
-2
-10
-19
-18
-18
-12
-19
-19
-10
-18
-19
-11
-19
-11
-11
-11
-11
-19
-19
-18
-11
-18
-19
-11
-19
-2
-13
-19
-19
-11
-10
-19
-11
-11
-11
-12
-18
-11
-19
-19
-11
-11
-2
-11
-19
-10
-11
-17
-12
-11
-18
-2
-19
-11
-11
-11
-19
-11
-10
-2
-18
-17
-16
-2
-11
-19
-18
-14
-12
-11
-2
-19
-2
-11
-11
-18
-19
-11
-11
-19
-2
-12
-11
-2
-18
-11
-19
-11
-2
-18
-2
-19
-2
-18
-19
-2
-19
-13
-9
-2
-19
-11
-16
-11
-19
-19
-11
-19
-19
-11
-18
-11
-2
-2
-11
-19
-11
-12
-18
-11
-16
-2
-12
-18
-17
-16
-11
-18
-2
-11
-10
-2
-10
-18
-19
-11
-11
-18
-2
-19
-11
-10
-11
-19
-13
-17
-11
-2
-2
-19
-18
-14
-19
-19
-19
-16
-12
-19
-2
-13
-15
-19
-19
-17
-11
-2
-19
-19
-19
-18
-11
-11
-19
-11
-11
-18
-11
-11
-10
-2
-19
-16
-18
-19
-19
-19
-12
-19
-2
-2
-19
-11
-19
-19
-19
-17
-19
-19
-11
-12
-11
-2
-19
-11
-11
-11
-11
-19
-2
-11
-19
-18
-2
-11
-2
-11
-11
-12
-11
-19
-11
-18
-11
-11
-11
-2
-11
-11
-11
-19
-19
-10
-11
-2
-19
-12
-12
-18
-2
-17
-11
-11
-11
-19
-19
-19
-16
-18
-11
-19
-19
-11
-16
-12
-19
-19
-17
-18
-19
-19
-11
-11
-11
-11
-17
-11
-18
-19
-11
-11
-10
-2
-19
-17
-18
-11
-19
-11
-11
-19
-19
-19
-10
-19
-11
-19
-11
-11
-19
-11
-11
-11
-12
-2
-19
-10
-11
-11
-10
-11
-19
-19
-19
-2
-19
-17
-17
-11
-19
-12
-11
-2
-19
-19
-11
-2
-19
-11
-11
-19
-2
-19
-12
-11
-19
-10
-11
-19
-11
-11
-19
-11
-12
-11
-19
-19
-11
-19
-16
-11
-10
-2
-11
-19
-17
-2
-2
-11
-19
-19
-19
-11
-11
-12
-11
-12
-18
-11
-11
-19
-19
-15
-19
-2
-17
-18
-19
-11
-11
-11
-11
-11
-11
-18
-12
-18
-19
-11
-19
-11
-19
-11
-2
-12
-19
-16
-11
-11
-11
-11
-11
-11
-12
-11
-11
-2
-11
-19
-11
-11
-10
-16
-11
-10
-11
-2
-11
-18
-11
-11
-19
-19
-19
-17
-2
-10
-11
-19
-19
-11
-18
-14
-18
-19
-11
-19
-18
-19
-19
-16
-11
-18
-19
-11
-17
-19
-18
-11
-12
-11
-18
-19
-2
-19
-19
-2
-17
-11
-11
-18
-18
-14
-11
-11
-18
-11
-16
-19
-16
-19
-7
-2
-19
-11
-11
-19
-11
-19
-19
-15
-19
-11
-19
-9
-19
-12
-19
-18
-11
-15
-13
-11
-12
-19
-11
-18
-11
-11
-11
-19
-18
-12
-19
-11
-11
-12
-10
-11
-11
-11
-12
-17
-11
-10
-19
-11
-2
-12
-12
-19
-19
-18
-17
-11
-11
-18
-11
-11
-11
-11
-10
-11
-19
-11
-19
-19
-2
-11
-2
-19
-11
-11
-11
-18
-2
-19
-10
-11
-19
-19
-19
-17
-2
-19
-19
-12
-11
-12
-11
-17
-13
-19
-18
-10
-11
-2
-11
-11
-19
-12
-19
-17
-2
-19
-18
-18
-11
-2
-18
-19
-2
-19
-11
-11
-11
-19
-11
-11
-19
-19
-19
-19
-19
-18
-19
-2
-19
-19
-11
-10
-19
-19
-18
-11
-11
-18
-18
-19
-17
-18
-11
-19
-17
-19
-19
-11
-19
-11
-14
-12
-11
-19
-18
-11
-17
-19
-17
-10
-11
-10
-11
-10
-16
-19
-18
-12
-19
-2
-12
-11
-12
-12
-15
-19
-19
-19
-18
-19
-19
-19
-19
-19
-19
-13
-13
-13
-18
-19
-18
-17
-11
-18
-19
-10
-19
-16
-19
-11
-12
-19
-19
-10
-19
-19
-17
-19
-19
-2
-19
-19
-19
-19
-19
-19
-2
-19
-2
-19
-2
-11
-11
-19
-19
-2
-17
-11
-19
-19
-11
-11
-11
-11
-19
-19
-19
-19
-11
-11
-19
-19
-18
-19
-11
-11
-19
-19
-11
-11
-19
-11
-19
-2
-19
-2
-11
-19
-19
-19
-11
-13
-10
-19
-19
-11
-2
-19
-18
-19
-19
-11
-19
-19
-12
-19
-19
-19
-19
-11
-2
-19
-11
-12
-19
-2
-19
-10
-19
-19
-18
-19
-19
-11
-19
-19
-11
-19
-2
-19
-11
-19
-19
-19
-18
-2
-11
-2
-2
-11
-19
-19
-2
-11
-19
-19
-19
-19
-11
-2
-18
-19
-11
-2
-19
-11
-18
-19
-17
-19
-11
-2
-19
-10
-2
-2
-2
-11
-11
-19
-19
-11
-2
-19
-19
-2
-18
-18
-19
-19
-11
-18
-19
-11
-11
-19
-19
-2
-19
-19
-19
-19
-18
-18
-10
-2
-19
-19
-16
-19
-11
-2
-11
-19
-19
-19
-19
-19
-19
-2
-18
-19
-19
-19
-11
-19
-11
-2
-19
-19
-19
-19
-11
-11
-12
-19
-12
-19
-19
-19
-11
-19
-10
-11
-19
-17
-19
-11
-11
-19
-19
-2
-19
-19
-2
-11
-19
-17
-19
-12
-11
-19
-19
-11
-19
-2
-19
-2
-2
-11
-11
-11
-19
-11
-17
-19
-17
-19
-19
-19
-11
-11
-19
-11
-11
-2
-19
-11
-2
-19
-17
-11
-2
-19
-19
-19
-19
-19
-18
-2
-11
-19
-19
-19
-19
-19
-19
-19
-19
-2
-2
-19
-19
-19
-19
-2
-19
-11
-19
-11
-12
-19
-19
-19
-19
-19
-2
-19
-19
-2
-19
-10
-19
-11
-19
-2
-17
-19
-19
-11
-10
-11
-19
-19
-18
-19
-2
-18
-19
-11
-19
-18
-19
-19
-18
-19
-18
-19
-19
-19
-19
-2
-19
-19
-19
-19
-19
-11
-11
-11
-19
-19
-19
-11
-2
-19
-19
-2
-19
-17
-2
-19
-18
-11
-19
-19
-18
-19
-2
-11
-19
-2
-2
-19
-18
-19
-11
-11
-2
-19
-11
-19
-18
-2
-19
-18
-19
-19
-11
-11
-19
-19
-19
-16
-2
-19
-11
-2
-2
-19
-19
-19
-11
-2
-19
-19
-19
-11
-19
-19
-2
-19
-2
-11
-19
-11
-2
-19
-19
-11
-19
-19
-2
-2
-19
-11
-2
-19
-19
-19
-19
-10
-11
-11
-19
-19
-2
-19
-19
-19
-19
-19
-11
-18
-19
-19
-18
-19
-19
-11
-19
-19
-11
-11
-11
-2
-11
-12
-19
-19
-19
-19
-19
-19
-19
-19
-19
-2
-17
-2
-19
-12
-2
-19
-17
-19
-11
-18
-19
-19
-17
-11
-11
-17
-19
-19
-19
-19
-19
-11
-19
-19
-19
-19
-18
-19
-19
-19
-19
-2
-19
-19
-19
-19
-19
-11
-19
-11
-11
-11
-19
-11
-19
-17
-2
-19
-11
-19
-11
-11
-19
-2
-18
-11
-19
-19
-18
-11
-19
-2
-2
-12
-12
-19
-11
-19
-19
-18
-19
-19
-19
-19
-19
-19
-19
-2
-17
-19
-11
-19
-2
-19
-2
-19
-11
-19
-11
-11
-12
-19
-19
-16
-2
-19
-2
-19
-2
-19
-18
-19
-19
-19
-19
-19
-11
-19
-18
-11
-19
-19
-11
-11
-18
-2
-19
-18
-19
-11
-11
-11
-19
-19
-19
-18
-11
-2
-19
-19
-19
-19
-2
-19
-2
-19
-19
-19
-11
-19
-11
-19
-19
-11
-2
-19
-19
-19
-11
-18
-19
-19
-19
-19
-19
-2
-19
-2
-19
-2
-19
-19
-17
-19
-19
-11
-11
-19
-19
-19
-11
-19
-11
-19
-11
-11
-18
-19
-19
-18
-11
-19
-19
-11
-19
-2
-11
-19
-19
-19
-19
-2
-19
-17
-19
-2
-11
-18
-11
-13
-11
-19
-19
-11
-11
-19
-16
-19
-2
-19
-2
-19
-19
-11
-19
-19
-11
-19
-11
-19
-2
-16
-11
-19
-11
-19
-19
-19
-11
-11
-19
-11
-19
-19
-11
-19
-19
-19
-19
-19
-11
-19
-19
-11
-2
-18
-19
-11
-11
-11
-19
-19
-18
-19
-19
-2
-19
-19
-11
-2
-19
-19
-19
-11
-11
-19
-19
-19
-11
-19
-2
-2
-11
-11
-19
-11
-11
-2
-19
-11
-11
-19
-11
-2
-16
-11
-19
-19
-2
-11
-2
-19
-11
-11
-19
-19
-2
-2
-19
-19
-2
-19
-11
-11
-18
-19
-19
-19
-19
-11
-19
-10
-19
-19
-19
-10
-11
-12
-11
-19
-11
-19
-18
-18
-19
-2
-2
-19
-19
-2
-11
-19
-19
-19
-11
-19
-17
-19
-11
-2
-19
-2
-2
-19
-19
-19
-19
-19
-11
-19
-19
-19
-19
-19
-11
-19
-2
-11
-2
-19
-19
-18
-19
-19
-11
-13
-2
-19
-11
-11
-19
-19
-2
-19
-11
-12
-19
-11
-18
-19
-10
-19
-19
-17
-2
-19
-19
-11
-11
-19
-11
-11
-19
-10
-2
-19
-17
-19
-2
-19
-19
-18
-2
-11
-2
-19
-19
-18
-19
-19
-19
-2
-19
-19
-19
-2
-11
-19
-19
-19
-2
-11
-2
-19
-19
-11
-11
-11
-19
-2
-19
-19
-11
-19
-19
-11
-19
-11
-11
-19
-19
-11
-2
-11
-13
-19
-18
-19
-18
-11
-11
-2
-19
-19
-19
-11
-19
-19
-2
-19
-19
-18
-18
-19
-19
-19
-11
-19
-19
-19
-11
-19
-19
-11
-11
-11
-10
-19
-19
-19
-18
-19
-12
-19
-19
-19
-17
-11
-19
-2
-19
-2
-10
-2
-2
-2
-2
-19
-19
-2
-19
-19
-11
-2
-19
-19
-19
-11
-2
-11
-18
-19
-19
-19
-11
-11
-19
-11
-19
-11
-19
-11
-10
-2
-19
-17
-2
-19
-11
-18
-19
-19
-11
-2
-19
-19
-19
-11
-18
-19
-19
-2
-11
-11
-2
-19
-19
-11
-2
-19
-19
-19
-11
-19
-19
-11
-2
-2
-19
-11
-19
-19
-19
-2
-19
-18
-18
-19
-19
-11
-18
-19
-19
-2
-2
-19
-2
-19
-11
-19
-11
-19
-19
-19
-18
-19
-19
-19
-19
-19
-2
-11
-19
-19
-19
-19
-19
-19
-19
-2
-10
-16
-19
-11
-11
-19
-19
-19
-19
-19
-19
-19
-19
-19
-2
-19
-19
-2
-11
-15
-19
-19
-2
-19
-19
-19
-2
-18
-19
-2
-11
-12
-19
-18
-19
-11
-11
-19
-11
-11
-2
-19
-18
-2
-19
-12
-2
-19
-13
-2
-19
-11
-2
-19
-18
-11
-19
-19
-19
-19
-18
-11
-19
-2
-10
-2
-19
-18
-11
-19
-11
-19
-19
-19
-9
-11
-11
-19
-19
-2
-17
-2
-19
-10
-19
-17
-19
-10
-19
-19
-19
-2
-11
-19
-19
-10
-10
-11
-19
-11
-19
-19
-19
-19
-19
-19
-2
-19
-11
-19
-2
-19
-11
-19
-2
-18
-11
-19
-19
-19
-12
-13
-12
-19
-16
-19
-17
-19
-19
-2
-19
-12
-2
-19
-2
-2
-19
-9
-19
-17
-2
-19
-12
-17
-19
-11
-11
-2
-19
-18
-11
-2
-19
-11
-2
-19
-19
-19
-19
-19
-11
-2
-11
-19
-11
-19
-11
-17
-19
-19
-18
-19
-2
-19
-19
-11
-13
-11
-19
-19
-11
-19
-19
-11
-11
-19
-11
-19
-2
-19
-19
-19
-18
-19
-19
-11
-18
-21
-13
-16
-18
-18
-18
-18
-18
-18
-0
-2
-6
-2
-2
-0
-4
-2
-2
-2
-2
-2
-10
-12
-3
-2
-8
-4
-3
-3
-3
-7
-3
-8
-3
-5
-3
-2
-30
-11
-9
-16
-19
-11
-10
-10
-17
-2
-11
-19
-12
-12
-10
-11
-11
-10
-18
-13
-11
-17
-12
-10
-17
-13
-2
-19
-11
-9
-14
-12
-11
-12
-15
-13
-16
-17
-12
-11
-12
-13
-11
-9
-11
-12
-12
-11
-13
-11
-12
-11
-12
-12
-10
-11
-11
-11
-17
-12
-12
-12
-12
-10
-12
-13
-12
-11
-10
-13
-10
-17
-11
-11
-18
-10
-12
-11
-12
-19
-12
-12
-15
-13
-11
-19
-11
-12
-10
-8
-16
-12
-11
-11
-13
-11
-10
-19
-12
-10
-17
-17
-13
-14
-11
-12
-10
-11
-12
-13
-16
-19
-19
-17
-11
-13
-11
-12
-10
-9
-11
-14
-19
-17
-12
-15
-12
-9
-13
-12
-12
-11
-13
-13
-11
-12
-12
-19
-10
-9
-17
-10
-11
-17
-11
-11
-11
-2
-17
-11
-11
-13
-11
-12
-10
-14
-17
-17
-19
-13
-12
-15
-11
-12
-12
-11
-11
-12
-11
-11
-19
-17
-10
-9
-13
-19
-10
-14
-11
-19
-17
-17
-11
-12
-10
-12
-10
-16
-11
-12
-19
-11
-11
-19
-12
-12
-12
-11
-16
-17
-10
-17
-19
-18
-17
-11
-11
-10
-12
-11
-2
-11
-11
-15
-14
-11
-17
-11
-2
-12
-10
-19
-17
-2
-19
-11
-11
-17
-11
-19
-11
-2
-16
-12
-9
-9
-11
-15
-17
-11
-11
-11
-12
-17
-10
-15
-12
-12
-11
-12
-14
-9
-17
-9
-19
-13
-11
-12
-9
-17
-11
-11
-19
-17
-10
-11
-17
-11
-10
-19
-10
-12
-12
-10
-14
-13
-11
-12
-7
-11
-16
-13
-10
-12
-10
-12
-11
-14
-17
-9
-11
-13
-11
-12
-12
-19
-12
-11
-11
-13
-9
-10
-11
-11
-16
-17
-17
-7
-10
-10
-11
-13
-13
-11
-2
-10
-19
-19
-12
-19
-19
-17
-19
-11
-17
-11
-10
-13
-12
-11
-10
-10
-13
-11
-11
-10
-13
-11
-17
-11
-11
-19
-17
-11
-11
-10
-19
-2
-17
-19
-12
-13
-7
-13
-14
-17
-11
-15
-19
-11
-11
-17
-18
-19
-12
-2
-18
-17
-19
-11
-18
-13
-15
-13
-12
-9
-10
-2
-18
-16
-11
-6
-11
-11
-11
-11
-16
-19
-19
-11
-19
-18
-10
-19
-19
-19
-12
-13
-12
-11
-12
-10
-11
-17
-15
-9
-15
-12
-14
-12
-11
-11
-14
-11
-10
-12
-11
-11
-10
-11
-11
-12
-19
-11
-10
-13
-11
-12
-14
-11
-13
-13
-11
-12
-14
-17
-11
-10
-11
-12
-11
-11
-11
-11
-2
-12
-12
-13
-13
-17
-14
-13
-12
-19
-11
-11
-11
-13
-13
-10
-13
-11
-11
-12
-13
-11
-11
-11
-2
-11
-18
-11
-11
-11
-11
-11
-19
-9
-18
-11
-13
-12
-13
-11
-9
-2
-19
-10
-18
-18
-11
-11
-11
-19
-19
-19
-18
-10
-11
-10
-12
-11
-10
-12
-10
-19
-2
-18
-11
-10
-10
-2
-11
-16
-15
-17
-19
-17
-11
-11
-17
-12
-8
-11
-19
-12
-14
-12
-14
-11
-12
-10
-19
-11
-19
-17
-10
-18
-19
-2
-18
-15
-19
-11
-19
-12
-15
-10
-13
-13
-12
-11
-13
-11
-11
-11
-11
-19
-11
-11
-16
-18
-11
-11
-2
-11
-18
-2
-11
-13
-7
-11
-9
-14
-13
-12
-15
-19
-19
-11
-15
-19
-19
-11
-10
-11
-17
-12
-13
-13
-13
-11
-17
-11
-12
-14
-15
-11
-11
-13
-11
-11
-12
-11
-11
-11
-19
-10
-17
-11
-11
-18
-11
-11
-10
-10
-15
-12
-11
-11
-13
-10
-13
-11
-10
-12
-12
-11
-10
-11
-10
-11
-16
-10
-15
-13
-18
-11
-11
-11
-10
-12
-14
-12
-12
-14
-12
-9
-13
-11
-10
-10
-11
-11
-11
-12
-14
-9
-10
-10
-18
-11
-14
-14
-9
-11
-10
-15
-9
-12
-11
-10
-16
-11
-10
-14
-12
-12
-13
-11
-11
-11
-2
-11
-17
-13
-11
-11
-15
-18
-18
-19
-19
-19
-13
-12
-17
-12
-12
-19
-12
-11
-17
-10
-11
-12
-18
-11
-12
-12
-12
-12
-18
-10
-19
-11
-18
-11
-12
-17
-11
-18
-11
-13
-12
-15
-14
-11
-10
-14
-10
-19
-19
-11
-13
-8
-2
-2
-16
-11
-11
-13
-10
-13
-13
-10
-14
-11
-11
-10
-18
-11
-11
-12
-13
-11
-11
-9
-13
-10
-11
-10
-11
-11
-19
-10
-12
-11
-10
-10
-13
-13
-11
-19
-11
-13
-12
-11
-12
-10
-12
-12
-17
-11
-9
-12
-16
-12
-12
-2
-12
-11
-16
-16
-11
-13
-11
-12
-2
-11
-14
-10
-11
-17
-16
-12
-19
-19
-17
-11
-11
-11
-9
-14
-11
-11
-11
-11
-11
-15
-11
-14
-12
-10
-16
-11
-12
-11
-11
-15
-12
-11
-16
-11
-11
-12
-12
-13
-8
-10
-19
-11
-17
-12
-13
-12
-8
-17
-13
-15
-17
-7
-9
-17
-10
-16
-6
-10
-12
-15
-16
-11
-5
-13
-9
-13
-5
-9
-9
-5
-9
-4
-3
-13
-7
-3
-3
-14
-4
-13
-4
-4
-14
-19
-19
-15
-14
-19
-11
-16
-15
-14
-18
-9
-5
-4
-13
-4
-12
-3
-13
-13
-2
-17
-13
-14
-19
-10
-12
-9
-6
-15
-5
-5
-15
-4
-13
-4
-13
-4
-4
-13
-4
-13
-3
-4
-13
-4
-13
-3
-2
-13
-4
-13
-4
-3
-4
-13
-3
-3
-13
-3
-3
-13
-4
-13
-3
-4
-13
-2
-4
-14
-13
-14
-19
-10
-15
-13
-14
-19
-10
-13
-11
-10
-15
-5
-6
-13
-4
-13
-4
-13
-3
-2
-13
-4
-13
-3
-2
-10
-3
-2
-13
-3
-2
-13
-4
-13
-3
-4
-13
-4
-13
-4
-2
-3
-13
-3
-3
-13
-3
-4
-13
-3
-2
-12
-3
-4
-13
-4
-13
-2
-2
-13
-14
-19
-19
-15
-13
-19
-19
-15
-12
-15
-5
-4
-13
-4
-13
-3
-13
-13
-19
-17
-13
-13
-19
-17
-11
-7
-7
-15
-5
-5
-15
-6
-15
-4
-13
-3
-4
-13
-4
-13
-3
-2
-13
-3
-2
-13
-3
-3
-13
-3
-12
-8
-3
-3
-13
-2
-2
-13
-4
-4
-13
-3
-13
-11
-3
-2
-13
-3
-12
-9
-14
-19
-15
-14
-19
-15
-13
-19
-15
-13
-19
-13
-12
-18
-8
-17
-8
-17
-8
-16
-6
-15
-6
-15
-6
-15
-6
-15
-4
-4
-14
-6
-15
-6
-15
-6
-16
-6
-15
-6
-15
-4
-4
-14
-6
-15
-6
-15
-6
-15
-5
-15
-6
-15
-4
-13
-10
-6
-15
-6
-15
-4
-6
-15
-6
-15
-6
-15
-4
-13
-9
-6
-15
-6
-15
-6
-15
-6
-15
-6
-15
-3
-4
-14
-13
-13
-19
-17
-13
-13
-19
-17
-12
-9
-6
-15
-5
-5
-15
-6
-13
-4
-13
-3
-3
-13
-4
-13
-3
-3
-13
-3
-2
-13
-3
-2
-13
-4
-13
-3
-4
-13
-3
-13
-3
-4
-13
-4
-2
-2
-2
-11
-5
-3
-0
-2
-11
-5
-4
-4
-3
-2
-2
-2
-11
-7
-5
-2
-2
-12
-11
-9
-5
-4
-4
-3
-2
-2
-11
-5
-2
-2
-12
-11
-9
-5
-4
-4
-3
-2
-2
-2
-11
-9
-2
-0
-0
-11
-7
-5
-4
-4
-4
-3
-2
-2
-12
-11
-9
-7
-3
-2
-2
-12
-11
-9
-5
-4
-4
-3
-2
-0
-12
-11
-8
-5
-2
-0
-12
-11
-9
-5
-4
-4
-3
-2
-2
-2
-11
-7
-5
-3
-2
-2
-11
-6
-4
-4
-3
-2
-2
-2
-11
-5
-3
-2
-2
-11
-7
-5
-4
-4
-3
-2
-2
-2
-12
-11
-9
-5
-2
-2
-11
-8
-4
-4
-3
-2
-2
-12
-11
-9
-5
-2
-2
-12
-11
-5
-4
-4
-3
-2
-12
-11
-9
-3
-2
-2
-11
-9
-7
-4
-4
-4
-3
-2
-2
-11
-9
-6
-3
-2
-2
-11
-7
-4
-4
-4
-3
-0
-0
-11
-9
-5
-2
-2
-2
-2
-11
-5
-4
-4
-3
-2
-2
-12
-11
-7
-3
-2
-2
-11
-10
-4
-4
-3
-2
-2
-11
-5
-3
-2
-2
-11
-7
-4
-4
-4
-3
-2
-2
-12
-11
-5
-3
-2
-2
-12
-11
-9
-5
-4
-4
-3
-2
-2
-11
-7
-3
-2
-2
-11
-5
-4
-4
-4
-3
-2
-2
-12
-11
-7
-3
-2
-2
-11
-9
-4
-4
-3
-2
-2
-11
-4
-3
-2
-2
-11
-9
-7
-4
-4
-4
-3
-2
-2
-11
-5
-3
-2
-2
-11
-7
-4
-4
-4
-3
-2
-2
-12
-11
-7
-3
-2
-2
-11
-9
-7
-5
-4
-4
-3
-2
-2
-12
-11
-8
-5
-3
-2
-2
-11
-7
-4
-4
-4
-3
-2
-2
-11
-7
-3
-2
-2
-2
-11
-5
-4
-4
-3
-2
-2
-11
-5
-2
-2
-2
-11
-8
-5
-4
-4
-4
-3
-2
-2
-11
-7
-3
-2
-2
-2
-11
-7
-4
-4
-3
-2
-2
-11
-7
-2
-2
-11
-6
-4
-4
-4
-3
-2
-2
-11
-5
-2
-2
-11
-5
-4
-4
-4
-3
-2
-2
-12
-11
-5
-3
-2
-0
-11
-4
-4
-4
-3
-2
-2
-11
-5
-3
-2
-2
-12
-11
-4
-4
-3
-2
-2
-2
-11
-7
-3
-2
-2
-11
-9
-4
-4
-3
-2
-2
-2
-12
-11
-5
-2
-2
-11
-9
-7
-4
-4
-3
-2
-2
-11
-3
-2
-2
-11
-7
-4
-4
-4
-2
-2
-11
-3
-2
-2
-11
-7
-4
-4
-3
-2
-2
-0
-11
-5
-2
-0
-12
-11
-7
-4
-4
-3
-2
-2
-11
-9
-5
-2
-2
-12
-11
-7
-5
-4
-4
-3
-2
-2
-2
-11
-7
-2
-0
-11
-6
-5
-4
-4
-4
-3
-2
-2
-11
-9
-5
-3
-2
-2
-11
-7
-4
-4
-4
-2
-2
-11
-9
-3
-2
-2
-11
-9
-4
-4
-3
-2
-2
-11
-9
-5
-2
-2
-11
-7
-4
-4
-4
-3
-2
-2
-11
-5
-3
-2
-2
-12
-11
-7
-5
-4
-4
-3
-2
-2
-12
-11
-5
-3
-2
-2
-12
-11
-5
-4
-4
-3
-2
-2
-12
-11
-7
-5
-3
-2
-2
-12
-11
-9
-5
-4
-4
-3
-2
-2
-12
-11
-5
-3
-2
-2
-11
-9
-4
-4
-3
-2
-2
-7
-12
-11
-5
-4
-2
-2
-2
-12
-11
-9
-4
-4
-3
-2
-2
-2
Deleted: SwiftApps/SciColSim/plotit
--- SwiftApps/SciColSim/plotit	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/plotit	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,42 +0,0 @@
-set terminal png enhanced
-#set term postscript eps enhanced
-#set terminal svg enhanced size 1000 1000
-#set style line 1 linecolor rgb "blue"
-set output "activeplot.png"
-set nokey
-set xlabel "Time in sec"
-set ylabel "number of active jobs"
-set title "Active jobs"
-plot "plot_active.txt" using 1:2 with line
-set output "cumulativeplot-openmp.png"
-set xlabel "Time in seconds"
-set ylabel "number of completed jobs"
-set title "Cumulative SciColSim-openMP jobs"
-plot "plot_cumulative.txt" using 1:($2*24) with lines
-set output "cumulativeplot.png"
-set title "Cumulative jobs"
-plot "plot_cumulative.txt" using 1:2 with lines
-set output "scs.png"
-set xlabel "Evolution"
-set ylabel "Value of T"
-set title "SciColSim evolution Results"
-plot "T.data" using 1 with lines
-set output "scs_loss.png"
-set title "SciColSim evolution loss Results"
-set ylabel "Value of loss(AR)"
-plot "anneal.data" using 1 with lines
-set output "multiloss.png"
-set key auto
-set yrange [0:200]
-set ylabel "loss"
-plot "multiloss.txt" using 3 with lines title "multiloss mean val",  "multiloss.txt" using ($3+$4) with lines title "+stddev", "multiloss.txt" using ($3-$4) with lines title "-stddev"
Deleted: SwiftApps/SciColSim/sample.swift.output
--- SwiftApps/SciColSim/sample.swift.output	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/sample.swift.output	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,528 +0,0 @@
-Swift 0.93 swift-r5483 cog-r3339
-RunID: 20120130-1217-63kot916
-Progress:  time: Mon, 30 Jan 2012 12:17:12 -0600
-multi_loss appCalls=1
-multi_loss: entered: ci=0 cj=0 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.0,50.0,-1.0]
-multi_annealing: AR: i=1 ....T = 2.0
-multi_loss: i=1 calling evolve, args=[0,0,4,50,-1,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:16 -0600  Checking status:1
-multi_annealing: AR: initial: 124.861101 +- 3.21017
-multi_loss: returning: ci=0 cj=0 r.loss=124.861101 r.sdev=3.21017
-multi_annealing: AR: 4.017889129124014 2
-multi_loss: entered: ci=1 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.017889129124014,50.0,-1.0]
-multi_loss: i=1 calling evolve, args=[0,0,4.017889129124014,50,-1,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:19 -0600  Checking status:1  Finished successfully:2
-multi_annealing: AR: 124.117401 +- 3.306
-multi_loss: returning: ci=1 cj=2 r.loss=124.117401 r.sdev=3.306
-multi_annealing: AF: best_opt_some.txt: 58.0,124.117401,0.0,0.0,4.017889129124014,50.0,-1.0,3.306
-multi_annealing: AR: 0.3916097778073887 vs 1.0
-math/min: result=1.0
-multi_annealing: AF: max_dist.txt - tbd
-multi_annealing: Accepting try_x[j], i=1 j=2
-multi_annealing: Accepting try_x[j], i=1 j=2 try_x[j]=4.017889129124014
-multi_annealing: AR: [1][2] Rejection counts: 0.0 0.0 0.0 0.0 0.0
-multi_annealing: AR: 1 ***** Did accept! 0.0 0.0 4.017889129124014 50.0 -1.0
-multi_annealing: AR: 48.711529653164106 3
-multi_loss: entered: ci=1 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.017889129124014,48.711529653164106,-1.0]
-multi_loss: i=1 calling evolve, args=[0,0,4.017889129124014,48.711529653164106,-1,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:22 -0600  Checking status:1  Finished successfully:4
-multi_annealing: AR: 125.18271 +- 3.599503
-multi_loss: returning: ci=1 cj=3 r.loss=125.18271 r.sdev=3.599503
-multi_annealing: AF: best_opt_some.txt: 58.0,125.18271,0.0,0.0,4.017889129124014,48.711529653164106,-1.0,3.599503
-multi_annealing: AR: 0.29338527075939624 vs 0.5870445897168992
-math/min: result=0.5870445897168992
-multi_annealing: Accepting try_x[j], i=1 j=3 try_x[j]=48.711529653164106
-multi_annealing: AR: 1 ***** Did accept! 0.0 0.0 4.017889129124014 48.711529653164106 -1.0
-multi_annealing: AR: [1][3] Rejection counts: 0.0 0.0 0.0 0.0 0.0
-multi_annealing: AR: -0.0033614536445253362 4
-multi_loss: entered: ci=1 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.017889129124014,48.711529653164106,-0.0033614536445253362]
-multi_loss: i=1 calling evolve, args=[0,0,4.017889129124014,48.711529653164106,-0.0033614536445253362,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:26 -0600  Checking status:1  Finished successfully:6
-multi_annealing: AR: 125.933179 +- 3.36805
-multi_loss: returning: ci=1 cj=4 r.loss=125.933179 r.sdev=3.36805
-multi_annealing: AF: best_opt_some.txt: 58.0,125.933179,0.0,0.0,4.017889129124014,48.711529653164106,-0.0033614536445253362,3.36805
-multi_annealing: AR: 0.6647548795660121 vs 0.6871281283507249
-math/min: result=0.6871281283507249
-multi_annealing: Accepting try_x[j], i=1 j=4
-multi_annealing: Accepting try_x[j], i=1 j=4 try_x[j]=-0.0033614536445253362
-multi_annealing: AR: 1 ***** Did accept! 0.0 0.0 4.017889129124014 48.711529653164106 -0.0033614536445253362
-multi_annealing: AR: [1][4] Rejection counts: 0.0 0.0 0.0 0.0 0.0
-multi_annealing: AR: i=2 ....T = 1.6762121943865207
-multi_annealing: AR: 5.284753614883805 2
-multi_loss: entered: ci=2 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.711529653164106,-0.0033614536445253362]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.711529653164106,-0.0033614536445253362,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:29 -0600  Checking status:1  Finished successfully:8
-multi_annealing: AR: 126.145367 +- 3.119133
-multi_loss: returning: ci=2 cj=2 r.loss=126.145367 r.sdev=3.119133
-multi_annealing: AF: best_opt_some.txt: 58.0,126.145367,0.0,0.0,5.284753614883805,48.711529653164106,-0.0033614536445253362,3.119133
-multi_annealing: AR: 0.8343453829181197 vs 0.8810967932193764
-math/min: result=0.8810967932193764
-multi_annealing: Accepting try_x[j], i=2 j=2 try_x[j]=5.284753614883805
-multi_annealing: AR: 2 ***** Did accept! 0.0 0.0 5.284753614883805 48.711529653164106 -0.0033614536445253362
-multi_annealing: AR: [2][2] Rejection counts: 0.0 0.0 0.0 0.0 0.0
-multi_annealing: AR: 47.49006278600924 3
-multi_loss: entered: ci=2 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,-0.0033614536445253362]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,-0.0033614536445253362,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:33 -0600  Checking status:1  Finished successfully:10
-multi_annealing: AR: 125.831434 +- 3.344003
-multi_loss: returning: ci=2 cj=3 r.loss=125.831434 r.sdev=3.344003
-multi_annealing: AF: best_opt_some.txt: 58.0,125.831434,0.0,0.0,5.284753614883805,47.49006278600924,-0.0033614536445253362,3.344003
-multi_annealing: AR: 0.7961447191161577 vs 1.0
-multi_annealing: Accepting try_x[j], i=2 j=3
-multi_annealing: Accepting try_x[j], i=2 j=3 try_x[j]=47.49006278600924
-multi_annealing: AR: 2 ***** Did accept! 0.0 0.0 5.284753614883805 47.49006278600924 -0.0033614536445253362
-multi_annealing: AR: [2][3] Rejection counts: 0.0 0.0 0.0 0.0 0.0
-multi_annealing: AR: 0.2830038287653472 4
-multi_loss: entered: ci=2 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,0.2830038287653472]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,0.2830038287653472,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:36 -0600  Checking status:1  Finished successfully:12
-multi_annealing: AR: 123.989674 +- 3.372759
-multi_loss: returning: ci=2 cj=4 r.loss=123.989674 r.sdev=3.372759
-multi_annealing: AF: best_opt_some.txt: 58.0,123.989674,0.0,0.0,5.284753614883805,47.49006278600924,0.2830038287653472,3.372759
-multi_annealing: AR: 0.19911890147442235 vs 1.0
-multi_annealing: Accepting try_x[j], i=2 j=4
-multi_annealing: Accepting try_x[j], i=2 j=4 try_x[j]=0.2830038287653472
-multi_annealing: AR: [2][4] Rejection counts: 0.0 0.0 0.0 0.0 0.0
-multi_annealing: AR: 2 ***** Did accept! 0.0 0.0 5.284753614883805 47.49006278600924 0.2830038287653472
-multi_annealing: AR: i=3 ....T = 1.4048436603050374
-multi_annealing: AR: 6.751519052449282 2
-multi_loss: entered: ci=3 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,6.751519052449282,47.49006278600924,0.2830038287653472]
-multi_loss: i=1 calling evolve, args=[0,0,6.751519052449282,47.49006278600924,0.2830038287653472,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:39 -0600  Checking status:1  Finished successfully:14
-multi_loss: returning: ci=3 cj=2 r.loss=125.83918 r.sdev=3.276288
-multi_annealing: AR: 125.83918 +- 3.276288
-multi_annealing: AF: best_opt_some.txt: 58.0,125.83918,0.0,0.0,6.751519052449282,47.49006278600924,0.2830038287653472,3.276288
-math/min: result=0.2680663186298088
-multi_annealing: AR: 3,2 3 Did not accept: 6.751519052449282 (2)
-multi_annealing: AR: 0.6852396383450929 vs 0.2680663186298088
-multi_annealing: AR: 0.0 0.0 6.751519052449282 47.49006278600924 0.2830038287653472
-multi_annealing: AR: 49.01109219848105 3
-multi_loss: entered: ci=3 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,49.01109219848105,0.2830038287653472]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,49.01109219848105,0.2830038287653472,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:42 -0600  Checking status:1  Finished successfully:16
-multi_loss: returning: ci=3 cj=3 r.loss=126.260409 r.sdev=3.474799
-multi_annealing: AF: best_opt_some.txt: 58.0,126.260409,0.0,0.0,5.284753614883805,49.01109219848105,0.2830038287653472,3.474799
-multi_annealing: AR: 126.260409 +- 3.474799
-math/min: result=0.1986200941793068
-multi_annealing: AR: 0.6989515725257741 vs 0.1986200941793068
-multi_annealing: AR: 3,3 3 Did not accept: 49.01109219848105 (3)
-multi_annealing: AR: 0.0 0.0 5.284753614883805 49.01109219848105 0.2830038287653472
-multi_annealing: AR: 0.7184988677898592 4
-multi_loss: entered: ci=3 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,0.7184988677898592]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:45 -0600  Checking status:1  Finished successfully:18
-multi_loss: returning: ci=3 cj=4 r.loss=123.593465 r.sdev=3.286319
-multi_annealing: AR: 123.593465 +- 3.286319
-multi_annealing: AF: best_opt_some.txt: 58.0,123.593465,0.0,0.0,5.284753614883805,47.49006278600924,0.7184988677898592,3.286319
-multi_annealing: AR: 0.10970841947076293 vs 1.0
-multi_annealing: Accepting try_x[j], i=3 j=4
-multi_annealing: Accepting try_x[j], i=3 j=4 try_x[j]=0.7184988677898592
-multi_annealing: AR: 3 ***** Did accept! 0.0 0.0 5.284753614883805 47.49006278600924 0.7184988677898592
-multi_annealing: AR: [3][4] Rejection counts: 0.0 0.0 1.0 1.0 0.0
-multi_annealing: AR: i=4 ....T = 1.1774080373049494
-multi_annealing: AR: 4.4255186274220115 2
-multi_loss: entered: ci=4 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.4255186274220115,47.49006278600924,0.7184988677898592]
-multi_loss: i=1 calling evolve, args=[0,0,4.4255186274220115,47.49006278600924,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:49 -0600  Checking status:1  Finished successfully:20
-multi_loss: returning: ci=4 cj=2 r.loss=126.444622 r.sdev=3.25147
-multi_annealing: AR: 126.444622 +- 3.25147
-multi_annealing: AF: best_opt_some.txt: 58.0,126.444622,0.0,0.0,4.4255186274220115,47.49006278600924,0.7184988677898592,3.25147
-multi_annealing: AR: 0.9535428038358379 vs 0.08878355131476454
-math/min: result=0.08878355131476454
-multi_annealing: AR: 4,2 4 Did not accept: 4.4255186274220115 (2)
-multi_annealing: AR: 0.0 0.0 4.4255186274220115 47.49006278600924 0.7184988677898592
-multi_annealing: AR: 46.92686166375319 3
-multi_loss: entered: ci=4 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,46.92686166375319,0.7184988677898592]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,46.92686166375319,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:52 -0600  Checking status:1  Finished successfully:22
-multi_annealing: AR: 124.963375 +- 3.41926
-multi_loss: returning: ci=4 cj=3 r.loss=124.963375 r.sdev=3.41926
-multi_annealing: AF: best_opt_some.txt: 58.0,124.963375,0.0,0.0,5.284753614883805,46.92686166375319,0.7184988677898592,3.41926
-multi_annealing: AR: 0.4500207377949753 vs 0.312392025102438
-math/min: result=0.312392025102438
-multi_annealing: AR: 4,3 4 Did not accept: 46.92686166375319 (3)
-multi_annealing: AR: 0.0 0.0 5.284753614883805 46.92686166375319 0.7184988677898592
-multi_annealing: AR: -0.3320316742658884 4
-multi_loss: entered: ci=4 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,-0.3320316742658884]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,-0.3320316742658884,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:55 -0600  Checking status:1  Finished successfully:24
-multi_annealing: AR: 125.407828 +- 3.018498
-multi_loss: returning: ci=4 cj=4 r.loss=125.407828 r.sdev=3.018498
-multi_annealing: AF: best_opt_some.txt: 58.0,125.407828,0.0,0.0,5.284753614883805,47.49006278600924,-0.3320316742658884,3.018498
-multi_annealing: AR: 0.8555641933973892 vs 0.21417097212905944
-math/min: result=0.21417097212905944
-multi_annealing: AR: 0.0 0.0 5.284753614883805 47.49006278600924 -0.3320316742658884
-multi_annealing: AR: 4,4 4 Did not accept: -0.3320316742658884 (4)
-multi_annealing: AR: i=5 ....T = 0.9867928549496278
-multi_annealing: AR: 6.833327620921641 2
-multi_loss: entered: ci=5 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,6.833327620921641,47.49006278600924,0.7184988677898592]
-multi_loss: i=1 calling evolve, args=[0,0,6.833327620921641,47.49006278600924,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:17:58 -0600  Checking status:1  Finished successfully:26
-multi_annealing: AR: 125.250487 +- 3.078819
-multi_loss: returning: ci=5 cj=2 r.loss=125.250487 r.sdev=3.078819
-multi_annealing: AF: best_opt_some.txt: 58.0,125.250487,0.0,0.0,6.833327620921641,47.49006278600924,0.7184988677898592,3.078819
-multi_annealing: AR: 0.44288167684075663 vs 0.18652324111077032
-math/min: result=0.18652324111077032
-multi_annealing: AR: 5,2 5 Did not accept: 6.833327620921641 (2)
-multi_annealing: AR: 0.0 0.0 6.833327620921641 47.49006278600924 0.7184988677898592
-multi_annealing: AR: 46.49027442733761 3
-multi_loss: entered: ci=5 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,46.49027442733761,0.7184988677898592]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,46.49027442733761,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:01 -0600  Checking status:1  Finished successfully:28
-multi_annealing: AR: 124.663101 +- 3.485893
-multi_loss: returning: ci=5 cj=3 r.loss=124.663101 r.sdev=3.485893
-multi_annealing: AF: best_opt_some.txt: 58.0,124.663101,0.0,0.0,5.284753614883805,46.49027442733761,0.7184988677898592,3.485893
-multi_annealing: AR: 0.42913823795768913 vs 0.33825612299835406
-math/min: result=0.33825612299835406
-multi_annealing: AR: 0.0 0.0 5.284753614883805 46.49027442733761 0.7184988677898592
-multi_annealing: AR: 5,3 5 Did not accept: 46.49027442733761 (3)
-multi_annealing: AR: 2.2333217492423234 4
-multi_loss: entered: ci=5 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,2.2333217492423234]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,2.2333217492423234,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:05 -0600  Checking status:1  Finished successfully:30
-multi_annealing: AR: 125.856136 +- 3.415745
-multi_loss: returning: ci=5 cj=4 r.loss=125.856136 r.sdev=3.415745
-multi_annealing: AF: best_opt_some.txt: 58.0,125.856136,0.0,0.0,5.284753614883805,47.49006278600924,2.2333217492423234,3.415745
-multi_annealing: AR: 0.5684553851797784 vs 0.10096772364295076
-math/min: result=0.10096772364295076
-multi_annealing: AR: 5,4 5 Did not accept: 2.2333217492423234 (4)
-multi_annealing: AR: 0.0 0.0 5.284753614883805 47.49006278600924 2.2333217492423234
-multi_annealing: AR: i=6 ....T = 0.8270371084000275
-multi_annealing: AR: 3.928981105935937 2
-multi_loss: entered: ci=6 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,3.928981105935937,47.49006278600924,0.7184988677898592]
-multi_loss: i=1 calling evolve, args=[0,0,3.928981105935937,47.49006278600924,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:08 -0600  Checking status:1  Finished successfully:32
-multi_annealing: AR: 125.944813 +- 3.343539
-multi_loss: returning: ci=6 cj=2 r.loss=125.944813 r.sdev=3.343539
-multi_annealing: AR: 0.0737231873586417 vs 0.05824491156028037
-multi_annealing: AF: best_opt_some.txt: 58.0,125.944813,0.0,0.0,3.928981105935937,47.49006278600924,0.7184988677898592,3.343539
-multi_annealing: AR: 6,2 6 Did not accept: 3.928981105935937 (2)
-math/min: result=0.05824491156028037
-multi_annealing: AR: 0.0 0.0 3.928981105935937 47.49006278600924 0.7184988677898592
-multi_annealing: AR: 47.456980868107266 3
-multi_loss: entered: ci=6 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.456980868107266,0.7184988677898592]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.456980868107266,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:11 -0600  Checking status:1  Finished successfully:34
-multi_annealing: AR: 126.604462 +- 3.183016
-multi_loss: returning: ci=6 cj=3 r.loss=126.604462 r.sdev=3.183016
-multi_annealing: AR: 0.5487345599809303 vs 0.02623387861162342
-math/min: result=0.02623387861162342
-multi_annealing: AF: best_opt_some.txt: 58.0,126.604462,0.0,0.0,5.284753614883805,47.456980868107266,0.7184988677898592,3.183016
-multi_annealing: AR: 6,3 6 Did not accept: 47.456980868107266 (3)
-multi_annealing: AR: 0.0 0.0 5.284753614883805 47.456980868107266 0.7184988677898592
-multi_loss: entered: ci=6 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,47.49006278600924,-1.5302000464747076]
-multi_annealing: AR: -1.5302000464747076 4
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,47.49006278600924,-1.5302000464747076,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:12 -0600  Active:1  Finished successfully:36
-Progress:  time: Mon, 30 Jan 2012 12:18:14 -0600  Checking status:1  Finished successfully:36
-multi_loss: returning: ci=6 cj=4 r.loss=125.062511 r.sdev=3.22833
-multi_annealing: AR: 125.062511 +- 3.22833
-multi_annealing: AF: best_opt_some.txt: 58.0,125.062511,0.0,0.0,5.284753614883805,47.49006278600924,-1.5302000464747076,3.22833
-multi_annealing: AR: 0.4295446121391554 vs 0.16926736066405584
-math/min: result=0.16926736066405584
-multi_annealing: AR: 6,4 6 Did not accept: -1.5302000464747076 (4)
-multi_annealing: AR: 0.0 0.0 5.284753614883805 47.49006278600924 -1.5302000464747076
-multi_annealing: AR: i=7 ....T = 0.6931448431551464
-multi_annealing: AR: 5.698890855198198 2
-multi_loss: entered: ci=7 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.698890855198198,47.49006278600924,0.7184988677898592]
-multi_loss: i=1 calling evolve, args=[0,0,5.698890855198198,47.49006278600924,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:17 -0600  Checking status:1  Finished successfully:38
-multi_annealing: AR: 124.92233 +- 3.519439
-multi_loss: returning: ci=7 cj=2 r.loss=124.92233 r.sdev=3.519439
-multi_annealing: AF: best_opt_some.txt: 58.0,124.92233,0.0,0.0,5.698890855198198,47.49006278600924,0.7184988677898592,3.519439
-multi_annealing: AR: 0.26061833782383614 vs 0.14702488652213752
-math/min: result=0.14702488652213752
-multi_annealing: AR: 7,2 7 Did not accept: 5.698890855198198 (2)
-multi_annealing: AR: 0.0 0.0 5.698890855198198 47.49006278600924 0.7184988677898592
-multi_annealing: AR: 48.00451051760781 3
-multi_loss: entered: ci=7 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,0.7184988677898592]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,0.7184988677898592,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:21 -0600  Checking status:1  Finished successfully:40
-multi_annealing: AR: 123.700997 +- 3.061641
-multi_loss: returning: ci=7 cj=3 r.loss=123.700997 r.sdev=3.061641
-multi_annealing: AF: best_opt_some.txt: 58.0,123.700997,0.0,0.0,5.284753614883805,48.00451051760781,0.7184988677898592,3.061641
-multi_annealing: AR: 0.04383216320955852 vs 0.8562983650405412
-math/min: result=0.8562983650405412
-multi_annealing: Accepting try_x[j], i=7 j=3
-multi_annealing: Accepting try_x[j], i=7 j=3 try_x[j]=48.00451051760781
-multi_annealing: AR: 7 ***** Did accept! 0.0 0.0 5.284753614883805 48.00451051760781 0.7184988677898592
-multi_annealing: AR: [7][3] Rejection counts: 0.0 0.0 5.0 4.0 3.0
-multi_annealing: AR: -0.41452399887346414 4
-multi_loss: entered: ci=7 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,-0.41452399887346414]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:24 -0600  Checking status:1  Finished successfully:42
-multi_annealing: AR: 122.427501 +- 3.484433
-multi_loss: returning: ci=7 cj=4 r.loss=122.427501 r.sdev=3.484433
-multi_annealing: AR: 0.6794911655574871 vs 1.0
-multi_annealing: AF: best_opt_some.txt: 58.0,122.427501,0.0,0.0,5.284753614883805,48.00451051760781,-0.41452399887346414,3.484433
-multi_annealing: Accepting try_x[j], i=7 j=4
-multi_annealing: Accepting try_x[j], i=7 j=4 try_x[j]=-0.41452399887346414
-multi_annealing: AR: [7][4] Rejection counts: 0.0 0.0 5.0 4.0 3.0
-multi_annealing: AR: 7 ***** Did accept! 0.0 0.0 5.284753614883805 48.00451051760781 -0.41452399887346414
-multi_annealing: AR: i=8 ....T = 0.5809289192863943
-multi_annealing: AR: 4.228373615739721 2
-multi_loss: entered: ci=8 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,4.228373615739721,48.00451051760781,-0.41452399887346414]
-multi_loss: i=1 calling evolve, args=[0,0,4.228373615739721,48.00451051760781,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:27 -0600  Checking status:1  Finished successfully:44
-multi_loss: returning: ci=8 cj=2 r.loss=125.825434 r.sdev=3.06081
-multi_annealing: AR: 125.825434 +- 3.06081
-multi_annealing: AF: best_opt_some.txt: 58.0,125.825434,0.0,0.0,4.228373615739721,48.00451051760781,-0.41452399887346414,3.06081
-multi_annealing: AR: 0.43307949429152304 vs 0.0028823847709179276
-math/min: result=0.0028823847709179276
-multi_annealing: AR: 0.0 0.0 4.228373615739721 48.00451051760781 -0.41452399887346414
-multi_annealing: AR: 8,2 8 Did not accept: 4.228373615739721 (2)
-multi_annealing: AR: 46.894163840589215 3
-multi_loss: entered: ci=8 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,46.894163840589215,-0.41452399887346414]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,46.894163840589215,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:30 -0600  Checking status:1  Finished successfully:46
-multi_annealing: AR: 124.871719 +- 3.122439
-multi_loss: returning: ci=8 cj=3 r.loss=124.871719 r.sdev=3.122439
-multi_annealing: AF: best_opt_some.txt: 58.0,124.871719,0.0,0.0,5.284753614883805,46.894163840589215,-0.41452399887346414,3.122439
-multi_annealing: AR: 0.34644774801935974 vs 0.014884566500466245
-math/min: result=0.014884566500466245
-multi_annealing: AR: 0.0 0.0 5.284753614883805 46.894163840589215 -0.41452399887346414
-multi_annealing: AR: 8,3 8 Did not accept: 46.894163840589215 (3)
-multi_annealing: AR: -2.2286308752011443 4
-multi_loss: entered: ci=8 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,-2.2286308752011443]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,-2.2286308752011443,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:33 -0600  Checking status:1  Finished successfully:48
-multi_annealing: AR: 125.200576 +- 3.137099
-multi_loss: returning: ci=8 cj=4 r.loss=125.200576 r.sdev=3.137099
-multi_annealing: AF: best_opt_some.txt: 58.0,125.200576,0.0,0.0,5.284753614883805,48.00451051760781,-2.2286308752011443,3.137099
-multi_annealing: AR: 0.47163119315783886 vs 0.008450593550370632
-math/min: result=0.008450593550370632
-multi_annealing: AR: 8,4 8 Did not accept: -2.2286308752011443 (4)
-multi_annealing: AR: 0.0 0.0 5.284753614883805 48.00451051760781 -2.2286308752011443
-multi_annealing: AR: i=9 ....T = 0.48688006928981853
-multi_annealing: AR: 5.695013169826046 2
-multi_loss: entered: ci=9 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.695013169826046,48.00451051760781,-0.41452399887346414]
-multi_loss: i=1 calling evolve, args=[0,0,5.695013169826046,48.00451051760781,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:37 -0600  Checking status:1  Finished successfully:50
-multi_annealing: AR: 125.017227 +- 3.237815
-multi_loss: returning: ci=9 cj=2 r.loss=125.017227 r.sdev=3.237815
-multi_annealing: AF: best_opt_some.txt: 58.0,125.017227,0.0,0.0,5.695013169826046,48.00451051760781,-0.41452399887346414,3.237815
-multi_annealing: AR: 0.17076495981302242 vs 0.004897539166396153
-math/min: result=0.004897539166396153
-multi_annealing: AR: 9,2 9 Did not accept: 5.695013169826046 (2)
-multi_annealing: AR: 0.0 0.0 5.695013169826046 48.00451051760781 -0.41452399887346414
-multi_annealing: AR: 48.00679484464189 3
-multi_loss: entered: ci=9 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00679484464189,-0.41452399887346414]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00679484464189,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:40 -0600  Checking status:1  Finished successfully:52
-multi_annealing: AR: 125.213924 +- 3.333561
-multi_loss: returning: ci=9 cj=3 r.loss=125.213924 r.sdev=3.333561
-multi_annealing: AF: best_opt_some.txt: 58.0,125.213924,0.0,0.0,5.284753614883805,48.00679484464189,-0.41452399887346414,3.333561
-multi_annealing: AR: 0.15928070563724706 vs 0.003269830345111401
-math/min: result=0.003269830345111401
-multi_annealing: AR: 0.0 0.0 5.284753614883805 48.00679484464189 -0.41452399887346414
-multi_annealing: AR: 9,3 9 Did not accept: 48.00679484464189 (3)
-multi_annealing: AR: -0.7507963173758503 4
-multi_loss: entered: ci=9 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,-0.7507963173758503]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,-0.7507963173758503,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:42 -0600  Active:1  Finished successfully:54
-multi_loss: returning: ci=9 cj=4 r.loss=125.856406 r.sdev=3.764608
-multi_annealing: AR: 125.856406 +- 3.764608
-multi_annealing: AF: best_opt_some.txt: 58.0,125.856406,0.0,0.0,5.284753614883805,48.00451051760781,-0.7507963173758503,3.764608
-math/min: result=8.738454465360378E-4
-multi_annealing: AR: 0.061628429129563234 vs 8.738454465360378E-4
-multi_annealing: AR: 9,4 9 Did not accept: -0.7507963173758503 (4)
-multi_annealing: AR: 0.0 0.0 5.284753614883805 48.00451051760781 -0.7507963173758503
-multi_annealing: AR: i=10 ....T = 0.408057154673674
-multi_annealing: AR: 3.29267604969456 2
-multi_loss: entered: ci=10 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,3.29267604969456,48.00451051760781,-0.41452399887346414]
-multi_loss: i=1 calling evolve, args=[0,0,3.29267604969456,48.00451051760781,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:46 -0600  Checking status:1  Finished successfully:56
-multi_annealing: AR: 125.360364 +- 3.317013
-multi_loss: returning: ci=10 cj=2 r.loss=125.360364 r.sdev=3.317013
-multi_annealing: AF: best_opt_some.txt: 58.0,125.360364,0.0,0.0,3.29267604969456,48.00451051760781,-0.41452399887346414,3.317013
-multi_annealing: AR: 0.27027335203696023 vs 7.56065260977875E-4
-math/min: result=7.56065260977875E-4
-multi_annealing: AR: 0.0 0.0 3.29267604969456 48.00451051760781 -0.41452399887346414
-multi_annealing: AR: 10,2 10 Did not accept: 3.29267604969456 (2)
-multi_annealing: AR: 46.275556353155956 3
-multi_loss: entered: ci=10 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,46.275556353155956,-0.41452399887346414]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,46.275556353155956,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:49 -0600  Checking status:1  Finished successfully:58
-multi_annealing: AR: 126.434478 +- 3.246686
-multi_loss: returning: ci=10 cj=3 r.loss=126.434478 r.sdev=3.246686
-multi_annealing: AF: best_opt_some.txt: 58.0,126.434478,0.0,0.0,5.284753614883805,46.275556353155956,-0.41452399887346414,3.246686
-multi_annealing: AR: 0.14920802306232583 vs 5.4372803009239825E-5
-math/min: result=5.4372803009239825E-5
-multi_annealing: AR: 10,3 10 Did not accept: 46.275556353155956 (3)
-multi_annealing: AR: 0.0 0.0 5.284753614883805 46.275556353155956 -0.41452399887346414
-multi_annealing: AR: 1.5046793086101826 4
-multi_loss: entered: ci=10 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,1.5046793086101826]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,1.5046793086101826,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:53 -0600  Checking status:1  Finished successfully:60
-multi_loss: returning: ci=10 cj=4 r.loss=125.785376 r.sdev=3.346594
-multi_annealing: AR: 125.785376 +- 3.346594
-multi_annealing: AF: best_opt_some.txt: 58.0,125.785376,0.0,0.0,5.284753614883805,48.00451051760781,1.5046793086101826,3.346594
-multi_annealing: AR: 0.6250655950503741 vs 2.668208671281028E-4
-math/min: result=2.668208671281028E-4
-multi_annealing: AR: 0.0 0.0 5.284753614883805 48.00451051760781 1.5046793086101826
-multi_annealing: AR: 10,4 10 Did not accept: 1.5046793086101826 (4)
-multi_annealing: new cycle at i=11
-multi_annealing: AR: New cycle at 11: prev dx[0-4]=[2.3 2.3 2.3 2.3 2.3]
-multi_annealing: AR: i=11 ....T = 0.34199518933533946
-multi_annealing: AR: New cycle at 11: dx[0-4]=[4.6 4.6 0.8624999999999998 0.9857142857142855 1.15]
-multi_annealing: AR: 3.791705563626845 2
-multi_loss: entered: ci=11 cj=2 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,3.791705563626845,48.00451051760781,-0.41452399887346414]
-multi_loss: i=1 calling evolve, args=[0,0,3.791705563626845,48.00451051760781,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:56 -0600  Checking status:1  Finished successfully:62
-multi_loss: returning: ci=11 cj=2 r.loss=124.596526 r.sdev=3.176561
-multi_annealing: AR: 124.596526 +- 3.176561
-multi_annealing: AF: best_opt_some.txt: 58.0,124.596526,0.0,0.0,3.791705563626845,48.00451051760781,-0.41452399887346414,3.176561
-multi_annealing: AR: 0.9715442940965933 vs 0.001760306082349071
-math/min: result=0.001760306082349071
-multi_annealing: AR: 0.0 0.0 3.791705563626845 48.00451051760781 -0.41452399887346414
-multi_annealing: AR: 11,2 11 Did not accept: 3.791705563626845 (2)
-multi_annealing: AR: 49.92607616034099 3
-multi_loss: entered: ci=11 cj=3 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,49.92607616034099,-0.41452399887346414]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,49.92607616034099,-0.41452399887346414,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:18:59 -0600  Checking status:1  Finished successfully:64
-multi_annealing: AR: 124.00716 +- 3.111738
-multi_loss: returning: ci=11 cj=3 r.loss=124.00716 r.sdev=3.111738
-multi_annealing: AF: best_opt_some.txt: 58.0,124.00716,0.0,0.0,5.284753614883805,49.92607616034099,-0.41452399887346414,3.111738
-multi_annealing: AR: 0.38818246796613753 vs 0.009863137695174688
-math/min: result=0.009863137695174688
-multi_annealing: AR: 11,3 11 Did not accept: 49.92607616034099 (3)
-multi_annealing: AR: 0.0 0.0 5.284753614883805 49.92607616034099 -0.41452399887346414
-multi_annealing: AR: -0.7771568808805009 4
-multi_loss: entered: ci=11 cj=4 target_innov=58.0 evolve_reruns=100 x=[0.0,0.0,5.284753614883805,48.00451051760781,-0.7771568808805009]
-multi_loss: i=1 calling evolve, args=[0,0,5.284753614883805,48.00451051760781,-0.7771568808805009,58,40000,20,100,2,1,2.,0.01,2,0.3,2.3,1,1,0,0,0,m,4,1234567]
-Progress:  time: Mon, 30 Jan 2012 12:19:02 -0600  Checking status:1  Finished successfully:66
-multi_annealing: AR: 123.567412 +- 3.66859
-multi_loss: returning: ci=11 cj=4 r.loss=123.567412 r.sdev=3.66859
-multi_annealing: AF: best_opt_some.txt: 58.0,123.567412,0.0,0.0,5.284753614883805,48.00451051760781,-0.7771568808805009,3.66859
-multi_annealing: AR: 0.5338319788181374 vs 0.03568160518248377
-math/min: result=0.03568160518248377
-multi_annealing: AR: 11,4 11 Did not accept: -0.7771568808805009 (4)
-multi_annealing: AR: 0.0 0.0 5.284753614883805 48.00451051760781 -0.7771568808805009
-Progress:  time: Mon, 30 Jan 2012 12:19:12 -0600  Finished successfully:68
-No events in 10s.
-Registered futures:
-string[] args  Closed, 24 elements, no listeners
-Waiting threads:
-No events in 10s.
-Waiting threads:
-No events in 10s.
-Waiting threads:
-Progress:  time: Mon, 30 Jan 2012 12:19:42 -0600  Finished successfully:68
Deleted: SwiftApps/SciColSim/sample.testopt.py.output
--- SwiftApps/SciColSim/sample.testopt.py.output	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/sample.testopt.py.output	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,243 +0,0 @@
-**** Calling optimizer: OMP_NUM_THREADS=4 ./openmp-optimizer 0 0 4 50 -1 58 40000 20 100 2 1 2. 0.01 5 0.3 2.3 1 1 0 0 0 n 4 1234567
-alpha_i: 0
-alpha_m: 0
-beta: 4
-gamma: 50
-delta: -1
-target: 58
-n_epochs: 40000
-n_steps: 20
-n_reruns: 100
-range: 2
-verbose level: 1
-T_start: 2
-T_end: 0.01
-Annealing_steps: 5
-Target_rejection: 0.3
-Starting_jump: 2.3
-FREEZE_alpha_i: 1
-FREEZE_alpha_m: 1
-FREEZE_beta: 0
-FREEZE_gamma: 0
-FREEZE_delta: 0
-Operation: n
-Nworkers: 4
-initSeed: 1234567
-0 | 1 (fixed)
-1 | 1 (fixed)
-2 | 0 (fixed)
-3 | 0 (fixed)
-4 | 0 (fixed)
-0.742788 0.631704 0.118309 0.922271 0.141282 0.80831 0.961468 0.363704 0.665483 0.683465 0.771216 0.267925 0.224677 0.153439 0.23455 0.816502 0.718347 0.371612 0.948727 0.404154 0.600908 0.766305 0.493219 0.82445 0.100233 0.672304 0.157299 0.53804 0.6794 0.57498 0.758357 0.422188 0.206684 0.876666 0.344459 0.347966 0.684976 0.305927 0.71167 0.350459 0.989392 0.482885 0.618384 0.214069 0.636325 0.852934 0.0305713 0.354672 0.224546 0.979299 0.758825 0.825454 0.745604 0.252044 0.649904 0.845837 0.924348 0.807203 0.383877 0.603748 0.382183 0.142234 0.0259353 0.588867 0.0189005 0.370394 0.936833 0.703877 0.676321 0.648502 0.0543356 0.665713 0.131387 0.672719 0.879782 0.767712 0.525653 0.910353 0.122384 0.750199 0.889652 0.881209 0.575653 0.635256 0.133253 0.225557 0.481092 0.0576008 0.0327595 0.864969 0.661348 0.414942 0.00720323 0.687284 0.00380882 0.0261037 0.0576777 0.940641 0.72998 0.733998
-multi_loss: Calling evolve_to_target_and_save i=0 N=100 step=25 istart=0 iend=25
-multi_loss: Calling evolve_to_target_and_save i=1 N=100 step=25 istart=25 iend=50
-multi_loss: Calling evolve_to_target_and_save i=2 N=100 step=25 istart=50 iend=75
-multi_loss: Calling evolve_to_target_and_save i=3 N=100 step=25 istart=75 iend=100
-multi_loss(N=100, target=58) elapsed time: 2.9134 seconds 0.0485567 minutes
-126.43 +- 3.11244
-....T = 2
-3.77342 2
-multi_loss(N=100, target=58) elapsed time: 2.90873 seconds 0.0484788 minutes
-126.523 +- 3.32417
-0.82704 vs 0.954153
-1 Rejection counts: 0 0 0 0 0
- 1,2 ***** Did accept! 0 0 3.77342 50 -1
-52.2335 3
-multi_loss(N=100, target=58) elapsed time: 2.93802 seconds 0.0489671 minutes
-130.173 +- 3.67201
-0.188468 vs 0.161259
- 1,3 1 Did not accept 52.2335(3)
-0 0 3.77342 52.2335 -1
--2.00667 4
-multi_loss(N=100, target=58) elapsed time: 2.95626 seconds 0.049271 minutes
-129.554 +- 3.1612
-0.88704 vs 0.219698
- 1,4 1 Did not accept -2.00667(4)
-0 0 3.77342 50 -2.00667
-....T = 0.693145
-4.07035 2
-multi_loss(N=100, target=58) elapsed time: 2.99097 seconds 0.0498495 minutes
-130.603 +- 3.25174
-0.0501227 vs 0.00277796
- 2,2 2 Did not accept 4.07035(2)
-0 0 4.07035 50 -1
-48.5261 3
-multi_loss(N=100, target=58) elapsed time: 2.94022 seconds 0.0490036 minutes
-128.508 +- 3.34913
-0.685387 vs 0.0571204
- 2,3 2 Did not accept 48.5261(3)
-0 0 3.77342 48.5261 -1
--2.2438 4
-multi_loss(N=100, target=58) elapsed time: 2.95557 seconds 0.0492594 minutes
-128.768 +- 3.41509
-0.579097 vs 0.0392132
- 2,4 2 Did not accept -2.2438(4)
-0 0 3.77342 50 -2.2438
-....T = 0.240225
-2.54662 2
-multi_loss(N=100, target=58) elapsed time: 3.02841 seconds 0.0504735 minutes
-127.262 +- 3.06273
-0.274094 vs 0.0462924
- 3,2 3 Did not accept 2.54662(2)
-0 0 2.54662 50 -1
-51.7319 3
-multi_loss(N=100, target=58) elapsed time: 3.00121 seconds 0.0500201 minutes
-128.927 +- 3.75415
-0.00641465 vs 4.52253e-05
- 3,3 3 Did not accept 51.7319(3)
-0 0 3.77342 51.7319 -1
-0.232896 4
-multi_loss(N=100, target=58) elapsed time: 2.98499 seconds 0.0497499 minutes
-128.55 +- 3.56206
-0.941162 vs 0.000216463
- 3,4 3 Did not accept 0.232896(4)
-0 0 3.77342 50 0.232896
-....T = 0.0832553
-4.37082 2
-multi_loss(N=100, target=58) elapsed time: 2.95775 seconds 0.0492958 minutes
-128.816 +- 3.45615
-0.803355 vs 1.09972e-12
- 4,2 4 Did not accept 4.37082(2)
-0 0 4.37082 50 -1
-49.3468 3
-multi_loss(N=100, target=58) elapsed time: 2.9872 seconds 0.0497866 minutes
-128.915 +- 3.17434
-0.126163 vs 3.35758e-13
- 4,3 4 Did not accept 49.3468(3)
-0 0 3.77342 49.3468 -1
--0.0551126 4
-multi_loss(N=100, target=58) elapsed time: 2.93849 seconds 0.0489748 minutes
-125.1 +- 3.35383
-0.17234 vs 1
-4 Rejection counts: 0 0 3 4 3
- 4,4 ***** Did accept! 0 0 3.77342 50 -0.0551126
-....T = 0.028854
-5.90757 2
-multi_loss(N=100, target=58) elapsed time: 3.04963 seconds 0.0508272 minutes
-131.481 +- 3.49648
-0.318332 vs 9.27549e-97
- 5,2 5 Did not accept 5.90757(2)
-0 0 5.90757 50 -0.0551126
-49.5818 3
-multi_loss(N=100, target=58) elapsed time: 3.0051 seconds 0.050085 minutes
-131.054 +- 3.3899
-0.854774 vs 2.47481e-90
- 5,3 5 Did not accept 49.5818(3)
-0 0 3.77342 49.5818 -0.0551126
--1.93165 4
-multi_loss(N=100, target=58) elapsed time: 2.95204 seconds 0.0492006 minutes
-127.676 +- 3.04749
-0.356781 vs 1.74605e-39
- 5,4 5 Did not accept -1.93165(4)
-0 0 3.77342 50 -1.93165
-*** optimizer completed, elapsed time=47.6158 seconds 0.793596 minutes)
-./mw.py Done!
Deleted: SwiftApps/SciColSim/showbest.sh
--- SwiftApps/SciColSim/showbest.sh	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/showbest.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,8 +0,0 @@
-#! /bin/sh
-awk '{
-  printf( "N %2d %2d %10.5f %5.2f | %5.2f %10.5f [ %5.2f %5.2f %10.5f %10.5f %10.5f ] %10.5f\n",
-  $2, $3, $4, $5, $7, $8, $10, $11, $12, $13, $14, $16);
Deleted: SwiftApps/SciColSim/sites.beagle.quick.xml
--- SwiftApps/SciColSim/sites.beagle.quick.xml	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/sites.beagle.quick.xml	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,25 +0,0 @@
-<config>
-  <pool handle="beagle">
-    <execution provider="coaster" jobmanager="local:pbs"/>
-    <profile namespace="globus" key="project">CI-MCB000119</profile>
-    <profile namespace="env" key="SWIFT_GEN_SCRIPTS">KEEP</profile>
-    <profile namespace="globus" key="jobsPerNode">1</profile>
-    <profile namespace="env" key="OMP_NUM_THREADS">24</profile>
-    <profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
-    <profile namespace="globus" key="lowOverAllocation">100</profile>
-    <profile namespace="globus" key="highOverAllocation">100</profile>
-    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
-    <profile namespace="globus" key="maxTime">10000</profile>
-    <profile namespace="globus" key="maxWallTime">01:30:00</profile>
-    <profile namespace="globus" key="slots">50</profile>
-    <profile namespace="globus" key="nodeGranularity">2</profile>
-    <profile namespace="globus" key="maxNodes">2</profile>
-    <profile namespace="globus" key="queue">route</profile>
-    <profile namespace="karajan" key="jobThrottle">9.59</profile>
-    <profile namespace="karajan" key="initialScore">10000</profile>
-    <filesystem provider="local"/>
-    <workdirectory >/lustre/beagle/ketan/labs/SciColSim-Bgl/swift.workdir</workdirectory>
-  </pool>
-</config>
Deleted: SwiftApps/SciColSim/sites.beagle.xml
--- SwiftApps/SciColSim/sites.beagle.xml	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/sites.beagle.xml	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,24 +0,0 @@
-<config>
-    <!--<profile namespace="globus" key="jobsPerNode">24</profile>-->
-    <profile namespace="globus" key="maxTime">37000</profile>
-    <profile namespace="globus" key="maxWallTime">10:00:00</profile>
-    <profile namespace="globus" key="slots">20</profile>
-  </pool>
-</config>
Deleted: SwiftApps/SciColSim/t1.py
--- SwiftApps/SciColSim/t1.py	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/t1.py	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,22 +0,0 @@
-#! /usr/bin/env python
-import os
-# FULL for target in range(58,1009,50):
-# FAST for target in range(58,209,50):
-for target in range(58,59,50):
-	s = ("%d" % target)
-	print s
-# FULL	for i in range(15):
-# FAST	for i in range(2):
-	for i in range(1):
-		args="./toptimizer 0 0 4 50 -1 "+s+" 40000 20 1000 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0 # > out.T"+str(target)+".i"+str(i)
-		args="OMP_NUM_THREADS=24 ./toptimizer 0 0 4 50 -1 "+s+" 40000 20 100 2 1 2. 0.01 2 0.3 2.3 1 1 0 0 0 # > out.T"+str(target)+".i"+str(i)
-		args="OMP_NUM_THREADS=24 ./toptimizer 0 0 4 50 -1 "+s+" 40000 20 100 2 1 2. 0.01 2 0.3 2.3 1 1 1 0 0 # > out.T"+str(target)+".i"+str(i)
-		print("\n\n **** CALLING APP: "+args+"\n\n\n")
-	        os.system(args);
-#		print("\n\n **** CALLING APP: ./optimizer 0 0 4 50 -1 "+s+" 40000 20 10 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0\n\n\n")
-#		FAST: os.system("./optimizer 0 0 4 50 -1 "+s+" 40000 20 10 2 1 2. 0.01 2 0.3 2.3 1 1 0 0 0")
-print "Done!"
Deleted: SwiftApps/SciColSim/t2.py
--- SwiftApps/SciColSim/t2.py	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/t2.py	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,23 +0,0 @@
-import os
-	print s
-		args="./toptimizer 0 0 4 50 -1 "+s+" 40000 20 75    2 1 2. 0.01 2 0.3 2.3 1 1 1 0 0 m # > out.T"+str(target)+".i"+str(i)
-		args="OMP_NUM_THREADS=24 ./toptimizer 0 0 4 50 -1 "+s+" 40000 20 96    2 1 2. 0.01 2 0.3 2.3 1 1 0 0 0 m 24 # > out.T"+str(target)+".i"+str(i)
-	        os.system(args);
-print "Done!"
Deleted: SwiftApps/SciColSim/t3.py
--- SwiftApps/SciColSim/t3.py	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/t3.py	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,22 +0,0 @@
-import os
-	print s
-		args="./toptimizer 0 0 4 50 -1 "+s+" 40000 20 75    2 1 2. 0.01 2 0.3 2.3 1 1 1 0 0 a # > out.T"+str(target)+".i"+str(i)
-	        os.system(args);
-print "Done!"
Deleted: SwiftApps/SciColSim/tc
--- SwiftApps/SciColSim/tc	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/tc	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,15 +0,0 @@
-localhost sh /bin/sh null null null
-localhost cat /bin/cat null null null
-pbs cat /bin/cat null null null
-mcs cat /bin/cat null null null
-localhost catnap /home/wilde/swift/lab/catnap.sh null null GLOBUS::maxwalltime="00:01:00"
-beagle optimizer /home/wilde/AndreysOptimizer/src/Optimizer null null null
-beagle optimizersh /home/wilde/AndreysOptimizer/src/optimizer.sh null null null
-beagle evolve /home/wilde/AndreysOptimizer/src/evolve.sh null null null
-localhost evolve /home/wilde/AndreysOptimizer/src/evolve.sh null null GLOBUS::maxwalltime="02:00:00"
-beagle sumloss /home/wilde/AndreysOptimizer/src/sumloss.sh null null null
-localhost sumloss /home/wilde/AndreysOptimizer/src/sumloss.sh null null GLOBUS::maxwalltime="02:00:00"
Deleted: SwiftApps/SciColSim/test-orig.sh
--- SwiftApps/SciColSim/test-orig.sh	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/test-orig.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,21 +0,0 @@
-#! /bin/bash
-python <<END
-import os
-target = 58
-s = ("%d" % target)
-args="0 0 4 50 -1 "+s+" 40000 20 1000 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0 "
-args="0 0 4 50 -1 "+s+" 40000 20  100 2 1 2. 0.01   2 0.3 2.3 1 1 0 0 0 "
-print("\n\n **** CALLING APP: "+args+"\n\n\n")
-os.system("./optimizer "+args+" >out.o.T"+s);
-os.system("./Optimizer "+args+" >out.O.T"+s);
-print "Done!"
-END
Deleted: SwiftApps/SciColSim/test-swift.sh
--- SwiftApps/SciColSim/test-swift.sh	2012-02-16 20:22:37 UTC (rev 5638)
+++ SwiftApps/SciColSim/test-swift.sh	2012-02-16 20:59:48 UTC (rev 5639)
@@ -1,7 +0,0 @@
-escapecode=$(echo -n -e '\033')
-swift -config cf -tc.file tc -sites.file local.xml annealing.swift \
-  -e33="$escapecode"
-#  -evolveReruns=20  \
-#  -annealingCycles=10
