[Swift-commit] r5618 - provenancedb
lgadelha at ci.uchicago.edu lgadelha at ci.uchicago.edu
Wed Feb 15 07:34:47 CST 2012
Author: lgadelha
Date: 2012-02-15 07:34:46 -0600 (Wed, 15 Feb 2012)
New Revision: 5618
Modified:
   provenancedb/build_script_run_provenance_graph.sh
   provenancedb/list_script_runs.sh
Log:
Minor updates.
Modified: provenancedb/build_script_run_provenance_graph.sh
--- provenancedb/build_script_run_provenance_graph.sh	2012-02-14 22:04:22 UTC (rev 5617)
+++ provenancedb/build_script_run_provenance_graph.sh	2012-02-15 13:34:46 UTC (rev 5618)
@@ -14,21 +14,22 @@
 query="select pgraph_edge.* from proc,pgraph_edge where (proc.id=pgraph_edge.parent or proc.id=pgraph_edge.child) and proc.run_id='$1';"
 echo "digraph \"$1\" {" > $1.dot
-#$SQLCMD --tuples-only -c "$query" | sed -e '/^ *$/d' | awk '{print "\""$1"\"" " -> " "\""$3"\""}' >> $1.dot
+#$SQLCMD --tuples-only -c "$query" | sed -e '/^ *$/d' | sort | uniq | awk '{print "\""$1"\"" " -> " "\""$3"\""}' >> $1.dot
 $SQLCMD --tuples-only -c "$query" | sed -e '/^ *$/d' > /tmp/$1.tmp
 while read parent separator child; do
-	isfc=$(echo $parent | grep ^execute)
+	isfc=$(echo "$parent" | grep ^execute)
 	if [ "X" == "X$isfc" ]; then
-		variable=$parent
-		functioncall=$child
+		variable="$parent"
+		functioncall="$child"
 	else
-		variable=$child
-		functioncall=$parent
+		variable="$child"
+		functioncall="$parent"
 	fi
 	variabletype=$($SQLCMD --tuples-only -c "select type from variable where id='$variable'" | awk '{print $1}')
+	functioncalllabel="$functioncall"
+	variablelabel="$variable"
 	if [ "$variabletype" == "mapped" ]; then
 		variablelabel="variable:mapped:"$($SQLCMD --tuples-only -c "select filename from variable where id='$variable'" | awk '{print $1}')
 	fi
@@ -38,13 +39,19 @@
 	if [ "$variabletype" == "composite" ]; then
 		variablelabel="variable:composite"
 	fi
-	functioncalllabel="functioncall:"$($SQLCMD --tuples-only -c "select name from function_call where id='$functioncall'" | awk '{print $1}')
-	echo "\"$variable\" [ label=\"$variablelabel\" ];" >> /tmp/$1.header.dot
-	echo "\"$functioncall\" [ label=\"$functioncalllabel\"];" >> /tmp/$1.header.dot
-	echo "\"$parent\" -> \"$child\";" >> /tmp/$1.body.dot
+	functioncalllabel="function_call:"$($SQLCMD --tuples-only -c "select name from function_call where id='$functioncall'" | awk '{print $1}')
+	parameter=$($SQLCMD --tuples-only -c "select parameter from ds_use where function_call_id='$functioncall' and variable_id='$variable';" | awk '{print $1}')
+	echo "\"$variable\" [ label=\"$variablelabel\", style=filled, fillcolor=lightcyan ];" >> /tmp/$1.header.dot
+	echo "\"$functioncall\" [ label=\"$functioncalllabel\", shape=box, style=filled, fillcolor=lightcyan ];" >> /tmp/$1.header.dot
+	echo "\"$parent\" -> \"$child\" [ label=\"$parameter\" ];" >> /tmp/$1.body.dot
 done < /tmp/$1.tmp
 cat /tmp/$1.header.dot | sort | uniq >> $1.dot
 cat /tmp/$1.body.dot >> $1.dot
-echo "}" >> $1.dot
\ No newline at end of file
+rm  /tmp/$1.header.dot /tmp/$1.body.dot
+echo "}" >> $1.dot
+dot -Tsvg -o $1.svg $1.dot
Modified: provenancedb/list_script_runs.sh
--- provenancedb/list_script_runs.sh	2012-02-14 22:04:22 UTC (rev 5617)
+++ provenancedb/list_script_runs.sh	2012-02-15 13:34:46 UTC (rev 5618)
@@ -11,6 +11,6 @@
 source $PROVDIR/etc/provenance.config
 export PATH=$PROVDIR:$PATH
-query="select * from script_run;"
+query="select * from script_run order by start_time;"
 $SQLCMD -c "$query"
