[Swift-commit] r5543 - SwiftApps/SciColSim
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Wed Feb 1 15:12:18 CST 2012
Author: jonmon
Date: 2012-02-01 15:12:18 -0600 (Wed, 01 Feb 2012)
New Revision: 5543
Modified:
   SwiftApps/SciColSim/README
   SwiftApps/SciColSim/TODO
Log:
Added to the README what are the command line arguments
Added a TODO item to document what each one does
Modified: SwiftApps/SciColSim/README
--- SwiftApps/SciColSim/README	2012-02-01 21:05:29 UTC (rev 5542)
+++ SwiftApps/SciColSim/README	2012-02-01 21:12:18 UTC (rev 5543)
@@ -136,8 +136,28 @@
 (currently, parameters are set in a few different places in annealing.swift)
 Sample output (w/ bugs remaining) is in sample.test-swift.output
+*** Parameter on the command line
+    The command line options are:
+        -nworkers=<int>
+	-minrange=<int>
+	-maxrange=<int>
+	-rangeinc=<int>
+	-tstart=<float>
+	-tend=<float>
+	-trejection=<float>
+	-erruns=<int>
+	-startingjump=<float>
+	-alphai=<float>
+	-alpham=<float>
+	-beta=<float>
+	-gamma=<float>
+	-delta=<float>
+	-annealingcycles=<int>
+	-rerunsperapp=<int>
 Optimizer output (both from C++ optimizer and Swift) generates text
 with escape sequences to display colored text. Some versions of more
 and less need special options set (eg in env var?) to display the
Modified: SwiftApps/SciColSim/TODO
--- SwiftApps/SciColSim/TODO	2012-02-01 21:05:29 UTC (rev 5542)
+++ SwiftApps/SciColSim/TODO	2012-02-01 21:12:18 UTC (rev 5543)
@@ -112,4 +112,6 @@
 [ ] Track negative number scenario
-[ ] create a lib directory of swift scripts to import in the swift release
\ No newline at end of file
+[ ] create a lib directory of swift scripts to import in the swift release
+[ ] Document each command line parameter for annealing.swift
