[Swift-commit] r6111 - SwiftApps/SciColSim
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Fri Dec 28 18:38:49 CST 2012
Author: wilde
Date: 2012-12-28 18:38:49 -0600 (Fri, 28 Dec 2012)
New Revision: 6111
Added:
   SwiftApps/SciColSim/annealing.osg.swift
Log:
Save OSG-enabled version as a separate file for time being.
Added: SwiftApps/SciColSim/annealing.osg.swift
--- SwiftApps/SciColSim/annealing.osg.swift	                        (rev 0)
+++ SwiftApps/SciColSim/annealing.osg.swift	2012-12-29 00:38:49 UTC (rev 6111)
@@ -0,0 +1,460 @@
+import "math";
+import "colortext";
+ *TODO:
+type file;
+type Res
+    float loss;
+    float sdev;
+    float tavg;
+    float tsdev;
+global boolean FIX_VARIABLES = true;
+global int var_fixed[] = [0,0,0,0,0];
+global int Nworkers = @toint(@arg("nworkers","4"));
+global int rerunsPerApp= @toint(@arg("rerunsperapp", "100"));
+( float nx ) newx( float x, float dx )
+    float r = (random());
+    if (r > 0.5)
+      nx = x + (random())*dx; //Java already returns a float between [0-1]
+    else
+        nx = x - (random())*dx;
+    // tracef("newx(%f,%f)=%f\n",x,dx,nx);
+app (file outfile, file loss ) evolve_wget ( string args[], file graph )
+   bash "-c" @strcat("wget http://www.ci.uchicago.edu/~davidk/SciColSim/evolve-wrapper.sh; ",
+                     "chmod +x ./evolve-wrapper.sh; ./evolve-wrapper.sh ", @loss, " ",
+                     args[0], " ", args[1], " ", args[2], " ", args[3], " ", args[4], " ",
+                     args[5], " ", args[6], " ", args[7], " ", args[8], " ", args[9], " ",
+                     args[10], " ", args[11], " ", args[12], " ", args[13], " ", args[14],
+                     " ", args[15], " ", args[16], " ", args[17], " ", args[18], " ",
+                     args[19], " ", args[20], " ", args[21], " ", args[22], " ", args[23])
+   stdout=@outfile;
+app (file outfile, file loss ) evolve_wget_short ( string args[], file graph )
+   bash_short "-c" @strcat("wget http://www.ci.uchicago.edu/~davidk/SciColSim/evolve-wrapper.sh; ",
+   stdout=@outfile;
+app (file outfile, file loss ) evolve_wget_long ( string args[], file graph )
+   bash_long "-c" @strcat("wget http://www.ci.uchicago.edu/~davidk/SciColSim/evolve-wrapper.sh; ",
+   stdout=@outfile;
+app  (file outfile, file loss ) evolve ( string args[], file graph )
+    evolve @loss args stdout=@outfile;  // graph is passed implicitly
+app ( file x ) sumloss( file loss[] )
+    sumloss @filenames(loss) stdout=@x;
+  Program structure:
+  main
+    optimizer_sweep() - formerly, python script
+      multi_annealing()
+        multi_loss()
+         evolve()
+       sumloss()
+( file bestfile, file maxfile ) multi_annealing ( string some_out_filename,
+                                                  float T_start,
+                                                  float T_end,
+                                                  float Target_rejection,
+                                                  int evolve_reruns,
+                                                  float starting_jump,
+                                                  float params0[],
+                                                  float target_innov,
+                                                  int annealing_cycles )
+    int cycle      = 10;     // const
+    int NEVOPARAMS = 5;      // const - 5 params, alpha 1,m through delta, does not include target_innovation
+    float rejection[][];  // [i][j] where i is cycle and j is evolve-parameter (alpha_i, alpha_m, beta, gamma, delta)
+    float trejection[][];
+    float x[][], dx[][], curr_loss[], curr_sdev[];
+    Res mlres[][];
+    mlres[0][0] = multi_loss( T_start, T_end, annealing_cycles, Target_rejection, starting_jump, 0, 0, params0, target_innov, evolve_reruns ); // FIXME: serves for all evolve-params ???
+    tracef( "multi_annealing: AR: initial: %f +- %f\n", mlres[0][0].loss, mlres[0][0].sdev );
+    foreach j in [0:NEVOPARAMS-1]
+        x[0][j]         = params0[j];
+        dx[0][j]        = starting_jump;
+        rejection[0][j] = 0.0;
+        curr_loss[j]    = mlres[0][0].loss;
+        curr_sdev[j]    = mlres[0][0].sdev;
+    iterate iter_i   // number of annealing cycles
+        int i = iter_i + 1;  // i ranges [1:n] in the swift script so that [0] can be the initial condition
+        // set new temperature, rejection threshold, and dx values for this cycle
+        float temperature = T_start*exp( @tofloat( i-1 ) * ( jlog( T_end ) - jlog( T_start ) ) / @tofloat( annealing_cycles ) );
+        tracef( @strcat( "multi_annealing: AR: i=%i ....T = ", color( 3, "%f" ),"\n" ), i, temperature );
+        // On each new "major" cycle within the annealing_cycles (other than the first) set new rejection and dx values
+        if ( i %% cycle == 1 && i > 1 )
+            tracef( "multi_annealing: new cycle at i=%i\n", i );
+            tracef( color( Pink, "multi_annealing: AR: New cycle at %i: prev dx[0-4]=[%f %f %f %f %f]\n" ), i, dx[i-1][0], dx[i-1][1], dx[i-1][2], dx[i-1][3], dx[i-1][4] );
+            foreach k in [0:NEVOPARAMS-1]
+                float newrejection = rejection[i-1][k] / @tofloat( cycle );
+                if ( newrejection > 0.0 )
+                    dx[i][k] = dx[i-1][k] / ( newrejection / Target_rejection );
+                    // FIXME: re-enable: rejection[i][k]=0.0;
+                    trejection[i][k]=0.0;
+                else
+                    dx[i][k] = dx[i-1][k] * 2.0;
+                    // FIXME: re-enable: rejection[i][k]=rejection[i-1][k];
+                    trejection[i][k]=newrejection;
+                // FIXME: HANGS? : tracef(color(Red,"Recomputed rejection: i=%d k=%d dx[i][k]=%f\n"), i, k, dx[i][k]);
+            tracef( color( Blue, "multi_annealing: AR: New cycle at %i: dx[0-4]=[%f %f %f %f %f]\n" ), i, dx[i][0], dx[i][1], dx[i][2], dx[i][3], dx[i][4] );
+        else  // If not new cycle, set dx[i][*] from previous dx ([i-1]). rejection[i][j] is set later.
+                dx[i][k] = dx[i-1][k];
+        iterate j   // Try a new value for each non-fixed param; then write results and accept or reject
+            int curr = ( i * NEVOPARAMS ) + j;
+            int prev = curr-1;
+            if ( /* (!FIX_VARIABLES) || */ ( var_fixed[j] == 0 ) ) {  // Adjustable vars
+                // fixed=1,1,0,0,0: FIXME: FIX_VARIABLES flag has faulty logic but OK when TRUE
+                float try_x[];
+                foreach k in [0:NEVOPARAMS-1] // Select the evolve params to try
+                    if ( k < j )
+                        try_x[k] = x[i][k]; // already set x[i][k]
+                    else
+                        if ( k == j )
+                            try_x[k] = newx(x[i-1][j], dx[i-1][j]); // permute x[i-1][j]
+                        else // k > j
+                            try_x[k] = x[i-1][k]; // use x[i-1][k] (from prior cycle)
+                tracef( @strcat( "multi_annealing: AR: ", color( 10,"%f" ), " ", color( 9,"%i" ),"\n" ), try_x[j], j );
+                mlres[i][j] = multi_loss( T_start, T_end, annealing_cycles, Target_rejection, starting_jump, i, j, try_x, target_innov, evolve_reruns ); // do the N evolve()'s, N=evolve_rerusn
+                tracef( "multi_annealing: AR: %f +- %f\n", mlres[i][j].loss, mlres[i][j].sdev );
+                // Beyond this point, x[] and dx[] are being set for this i,j
+                float ALOT = 100000000000.0; // 100,000,000,000. = 10^11
+                if ( mlres[i][j].loss < ALOT )
+                    fprintf( some_out_filename, "N, %fs, %i, %i, %f, %f, |, %i, %f, [, %f, %f, %f, %f, %f, ], %f\n",
+                             mlres[i][j].tavg, i-1, j, dx[i][j], rejection[i][j], @toint(target_innov), mlres[i][j].loss, try_x[0], try_x[1], try_x[2], try_x[3], try_x[4], mlres[i][j].sdev );  // Note i-1 field: print that way to match with C++ output
+                    // fprintf( "max_dist_swift.txt", color( Red,"multi_annealing: AF: max_dist.txt - tbd\n" ) ); // FIXME: max_dist is global set in evolve()
+                else // does this ever occur? if so did we want to still do the ratio computation above???
+                    fprintf( some_out_filename, "A, %fs, %i, %i, %f, %f, |, %i, %f, [, %f, %f, %f, %f, %f, ], %f\n",
+                    //tracef( "multi_annealing: Loss %f > ALOT at [i][j] = [%d][%d]\n", mlres[i][j].loss, i ,j );
+                float ratio = min( 1.0, exp( -( mlres[i][j].loss - curr_loss[prev] ) / temperature ) );
+                float r     = (random()); //Java already returns a random float between [0.0-1.0]
+                tracef("multi_annealing: AR: %f vs %f\n", r, ratio);
+                if (r > ratio) // Reject new parameter
+                    x[i][j]         = x[i-1][j];
+                      rejection[i][j] = trejection[i][j] + 1.0;    // FIXME: triple-check this!
+                    else
+                      rejection[i][j] = rejection[i-1][j] + 1.0;  // FIXME: AR: Is this correct? incr rejection?
+                    curr_loss[curr] = curr_loss[prev];
+                    curr_sdev[curr] = curr_sdev[prev];
+                    // FIXME: AR: the following prints seem to replicate values in the .cpp version - please clarify.
+                    tracef( "multi_annealing: AR: %i,%i %i Did not accept: %f (%i)\n", i, j, i, try_x[j], j );
+                    tracef( "multi_annealing: AR: %f %f %f %f %f\n", try_x[0],try_x[1],try_x[2],try_x[3],try_x[4] );
+                else // Accept new parameter
+                    tracef( "multi_annealing: Accepting try_x[j], i=%i j=%i\n",i,j );
+                    x[i][j]         = try_x[j];
+                      rejection[i][j] = trejection[i][j];    // FIXME: triple-check this!
+                    else
+                      rejection[i][j] = rejection[i-1][j];  // FIXME: AR: Is this correct? no incr of rejection?
+                    curr_loss[curr] = mlres[i][j].loss;
+                    curr_sdev[curr] = mlres[i][j].sdev;
+                    tracef( "multi_annealing: Accepting try_x[j], i=%i j=%i try_x[j]=%f\n", i, j, try_x[j] );
+                    float rj[];
+                        if (k <= j)
+                            rj[k] = rejection[i][k]; // Was either set from previous j or just set for this j
+                        else
+                            rj[k] = rejection[i-1][k]; // Not yet set, use previous
+                    tracef(@strcat("multi_annealing: AR: [%i][%i] ", color(8,"Rejection counts: "),
+                                   color(1,"%f"), " ", color(7,"%f"), " ", color(5,"%f"), " ", color(9,"%f"), " ", color(6,"%f"), "\n\n"),
+                           i, j, rj[0], rj[1], rj[2], rj[3], rj[4]);
+                    tracef(@strcat("multi_annealing: AR: %i ", color(8,"***** Did accept! "),
+                           i, try_x[0], try_x[1], try_x[2], try_x[3], try_x[4]);
+            else // Fixed Vars
+                // dx[i][j] not set for fixed vars
+        } until( j == (NEVOPARAMS-1) );
+    } until( iter_i == (annealing_cycles-1) );
+(Res r) multi_loss( float t_start, float t_end, int annealing_steps, float t_rejection, float starting_jump, int ci, int cj, float x[], float target_innov, int evolve_reruns )
+    tracef("%q\n", x);
+    file rfile[];
+    file ofile[]; // FIXME: to obtain timings and otehr stats
+    tracef( "multi_loss: entered: ci=%i cj=%i target_innov=%f evolve_reruns=%i x=%q\n",ci, cj, target_innov,evolve_reruns,x );
+    int appCalls = @toint(@tofloat(evolve_reruns) / @tofloat(rerunsPerApp));  // FIXME: handle fractional issues and rounding etc. For now must divide evenly
+    tracef("multi_loss appCalls=%i\n", appCalls);
+    foreach i in [1:appCalls]
+    {  // repeats of the evolove() - same as n_reruns
+        file outfile; // FIXME: map and save in future
+        string args[] = [ // FIXME: move this to a setargs() function
+            //    alpha_i           alpha_m        beta           gamma          delta          target_innov
+                 @strcat(x[0]),  @strcat(x[1]), @strcat(x[2]), @strcat(x[3]), @strcat(x[4]), @strcat(target_innov),
+            //     n_epochs n_steps   evolve_reruns           range
+            //    "40000",   "20",  @strcat(evolve_reruns),    "2",
+                  "40000",   "20",  @strcat(rerunsPerApp),     "2",
+            //    verbose_level
+                    "1",
+            //    T_start             T_end          Annealing_steps         Target_rejection         Starting_jump
+                 @strcat(t_start), @strcat(t_end), @strcat(annealing_steps), @strcat(t_rejection), @strcat(starting_jump),
+            //    FREEZE: alpha_i alpha_m beta gamma delta
+                            "0",    "0",  "0",  "0",  "0",
+            //   operation-code:(m,a)    Nworkers           seed
+                      "m",            @strcat(Nworkers), @arg("seed", "0" ) ];
+        file graph <"movie_graph.txt">;
+        if(@arg("wget") == "true") {
+           // Separate long runs from short runs when longruns option is set
+           if(@arg("longruns") == "true") {
+              float mean = @tofloat(@arg("minrange")) + @tofloat(@arg("maxrange")) / 2.0;
+              if(target_innov <= mean) {
+                 ( outfile, rfile[i] ) = evolve_wget_short( args, graph );
+              else {
+                 ( outfile, rfile[i] ) = evolve_wget_long( args, graph );
+          ( outfile, rfile[i] ) = evolve_wget( args, graph );
+        else {
+           ( outfile, rfile[i] ) = evolve( args, graph );
+        tracef("multi_loss: i=%i calling evolve, args=%q\n", i, args);
+        // tracef("multi_loss: after evolve: i=%i %k %k\n", i, outfile, rfile[i]);
+    file sumfile = sumloss(rfile);
+    r            = readData(sumfile);
+    tracef("multi_loss: returning: ci=%i cj=%i r.loss=%f r.sdev=%f\n",ci,cj,r.loss,r.sdev);
+    // file statfile = sumstats(ofile);  FIXME: to obtain timings and otehr stats
+    // s = readStat(statsfile);          FIXME: to obtain timings and otehr stats
+optimizer_sweep() // Implements logic of python driver script
+    int minrange = @toint(@arg("minrange", "58"));
+    int maxrange = @toint(@arg("maxrange", "59"));
+    int rangeinc = @toint(@arg("rangeinc", "50"));
+    // FIXME: add provision for random priming and random param values when x[i] == -100 (see optimizer.cpp main())
+    int nreps = @toint(@arg("nreps", "1"));
+//    file bestfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".best_opt_some")>;
+//    file maxfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".max_dist")>;
+    foreach target_innov in [minrange:maxrange:rangeinc]
+        foreach rep in [1:nreps]
+            string some_out_filename = @strcat( "best.T", @strcat(target_innov), ".R", @strcat(rep), ".txt" );
+            file outfile;  // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".out")>;
+            file lossfile; // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".loss_data")>;
+            ( outfile,lossfile ) = multi_annealing(
+                                                    some_out_filename,
+						                            @tofloat(@arg("tstart", "2.0")),
+                                                    @tofloat(@arg("tend", "0.01")),
+                                                    @tofloat(@arg("trejection", "0.3")),
+                                                    @toint(@arg("evoreruns", "100")),
+                                                    @tofloat(@arg("startingjump", "2.3")),
+                                                    [@tofloat(@arg("alphai", "0.0")), @tofloat(@arg("alpham", "0.0")), @tofloat(@arg("beta", "4.0")), @tofloat(@arg("gamma", "50.0")), @tofloat(@arg("delta", "-1.0"))],
+                                                    @tofloat(target_innov),
+                                                    @toint(@arg("annealingcycles", "50")) );
+main()
+    optimizer_sweep();
+main();
+  main
+  optimizer_sweep()
+  multi_annealing()
+  multi_loss()
+  evolve()
+  sumloss()
+  Example parameter sets:
+  for target in range(58,59,50):
+  for i in range(1):
+  args="./toptimizer 0 0 4 50 -1 "+target+" 40000 20 75    2 1 2. 0.01 2 0.3 2.3 1 1 1 0 0 m // > out.T"+str(target)+".i"+str(i)
+  os.system(args);
+  string fastargs1[] = [
+  "0", "0", "4", "50", "-1", @strcat(target),
+  "40000", "20", "1000", "2",
+  "1",
+  "2.", "0.01", "100", "0.3", "2.3",
+  "1", "1", "0", "0", "0"];
+  string fastargs2[] = [
+  "1",
+  "2.", "0.01",  "5", "0.3", "2.3",
+  "1", "1", "0", "0", "0", "m"];
+  string fastargs3[] = [
+  "40000", "20", @strcat(repeats), "2",
+  "1",
+  "2.", "0.01",  "2", "0.3", "2.3",
+(string args[]) setargs()
+    // string longargs[] = @strcat("0 0 4 50 -1 ",target," 40000 20 1000 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0 m");
+    //  [alpha_i alpha_m beta gamma delta target_innov
+    //  [n_epochs n_steps n_reruns] [range]
+    //  [verbose_level]
+    //  [T_start T_end Annealing_steps Target_rejection Starting_jump]
+    //  [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta] [operation-code:(m,a) Nworkers]
+////////////////// HOLD JUNK
+//                    tracef(@strcat("multi_annealing: AR: %i ", color(8,"Rejection counts: "),
+//                                   color( /* 2 */ 1," %f"), "\n\n"),
+//                                   i, rejection[i][j] ); // , rejection[i][1], rejection[i][2], rejection[i][3], rejection[i][4]);
+// FIXME: determine correct rejection[] values to avoid hanging:
+//                                   color( /* 2 */ 1," %f"), color(7," %f"), color(5," %f"), color(9," %f"), color(6," %f"), "\n\n"),
+//                                   rejection[i][0], rejection[i][1], rejection[i][2], rejection[i][3], rejection[i][4]);
+// END FIXME
