[Swift-commit] r6108 - provenancedb
lgadelha at ci.uchicago.edu lgadelha at ci.uchicago.edu
Wed Dec 19 07:58:29 CST 2012
Author: lgadelha
Date: 2012-12-19 07:57:43 -0600 (Wed, 19 Dec 2012)
New Revision: 6108
Modified:
   provenancedb/README.asciidoc
   provenancedb/info-to-runtime
   provenancedb/prov-init.sql
   provenancedb/prov-to-sql.sh
Log:
Update to provenance extraction scripts to match new format of runtime information in wrapper logs.
Modified: provenancedb/README.asciidoc
--- provenancedb/README.asciidoc	2012-12-18 00:15:14 UTC (rev 6107)
+++ provenancedb/README.asciidoc	2012-12-19 13:57:43 UTC (rev 6108)
@@ -188,10 +188,15 @@
 === Example: MODIS
-Run MODIS.
+Run MODIS:
 swift modis.swift
+After running MODIS, one can import provenenace information into the database using:
 swift-prov-import-all-logs
@@ -213,8 +218,8 @@
  modis.swift     | 5483          | 3339        | SUCCESS     | 2012-10-26 11:44:59.909-02 |   85.050
+List the
 select * from ancestors('dataset:20121026-1146-jng6bir4:720000001604');
Modified: provenancedb/info-to-runtime
--- provenancedb/info-to-runtime	2012-12-18 00:15:14 UTC (rev 6107)
+++ provenancedb/info-to-runtime	2012-12-19 13:57:43 UTC (rev 6108)
@@ -10,7 +10,7 @@
     if [ "X$record" != "X" ] && [ -f $record ] ; then
-	grep '^RUNTIME_INFO=' $record | sed "s/^RUNTIME_INFO=\(.*\)$/$globalid \1/"
+	grep '^APP_RESOURCES=' $record | sed "s/^APP_RESOURCES=\(.*\)$/$globalid \1/"
     else
 	echo no wrapper log for $id >&2
Modified: provenancedb/prov-init.sql
--- provenancedb/prov-init.sql	2012-12-18 00:15:14 UTC (rev 6107)
+++ provenancedb/prov-init.sql	2012-12-19 13:57:43 UTC (rev 6108)
@@ -117,8 +117,31 @@
      start_time        numeric,
      duration          numeric,
      final_state       varchar(32),
-     site              varchar(256)
+     site              varchar(256),
+     real_secs	       numeric,
+     kernel_secs       numeric,
+     user_secs	       numeric,
+     percent_cpu       numeric,
+     max_rss	       numeric,
+     avg_rss	       numeric,
+     avg_tot_vm	       numeric,
+     avg_priv_data     numeric,
+     avg_priv_stack    numeric,
+     avg_shared_text   numeric,
+     page_size	       numeric,
+     major_pgfaults    numeric,
+     minor_pgfaults    numeric,
+     swaps	       numeric,
+     invol_context_switches	numeric,
+     vol_waits			numeric,
+     fs_reads			numeric,
+     fs_writes			numeric,
+     sock_recv			numeric,
+     sock_send			numeric,
+     signals			numeric,
+     exit_status		numeric
 --     maxrss            numeric,
 --     walltime          numeric,
 --     systime           numeric,
@@ -291,7 +314,13 @@
 create view provenance_graph_edge as
-       select function_call_id as parent, dataset_id as child from dataset_out
-    union all
-       select dataset_id as parent, function_call_id as child from dataset_in;
+       	    select function_call_id as parent, dataset_id as child
+       	    from dataset_out
+       union all
+       	    select dataset_id as parent, function_call_id as child
+	    from dataset_in;
+create view script_run_summary as
+       select id,swift_version,cog_version,final_state,
+       	      start_time,duration,script_filename
+       from script_run;
\ No newline at end of file
Modified: provenancedb/prov-to-sql.sh
--- provenancedb/prov-to-sql.sh	2012-12-18 00:15:14 UTC (rev 6107)
+++ provenancedb/prov-to-sql.sh	2012-12-19 13:57:43 UTC (rev 6108)
@@ -129,13 +129,31 @@
 echo "    - Wrapper log resource consumption info."
 if [ -f runtime.txt ]; then
     while read execute2_id runtime; do
-	timestamp=$(echo $runtime | awk -F "," '{print $1}' | awk -F ":" '{print $2}')
-	cpu_usage=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
-	max_phys_mem=$(echo $runtime | awk -F "," '{print $3}' | awk -F ":" '{print $2}')
-	max_virtual_mem=$(echo $runtime | awk -F "," '{print $4}' | awk -F ":" '{print $2}')
-	io_read_bytes=$(echo $runtime | awk -F "," '{print $5}' | awk -F ":" '{print $2}')
-	io_write_bytes=$(echo $runtime | awk -F "," '{print $6}' | awk -F ":" '{print $2}')
-	echo "INSERT INTO rt_info (app_exec_id, timestamp, cpu_usage, max_phys_mem, max_virt_mem, io_read, io_write) VALUES ('$execute2_id', $timestamp, $cpu_usage, $max_phys_mem, $max_virtual_mem, $io_read_bytes, $io_write_bytes);"  >> /tmp/$RUNID.sql
+	real_secs=$(echo $runtime | awk -F "," '{print $1}' | awk -F ":" '{print $2}')
+	kernel_secs=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	user_secs=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	percent_cpu=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	max_rss=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	avg_rss=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	avg_tot_vm=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	avg_priv_data=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	avg_priv_stack=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	avg_shared_text=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	page_size=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	major_pgfaults=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	minor_pgfaults=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	swaps=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	invol_context_switches=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	vol_waits=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	fs_reads=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	fs_writes=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	sock_recv=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	sock_send=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	signals=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	exit_status=$(echo $runtime | awk -F "," '{print $2}' | awk -F ":" '{print $2}')
+	echo "UPDATE app_exec SET real_secs='$real_secs', kernel_secs='$kernel_secs', user_secs='$user_secs', percent_cpu='$percent_cpu', max_rss='$max_rss', avg_rss='$avg_rss', avg_tot_vm='$avg_tot_vm', avg_priv_data='$avg_priv_data', avg_priv_stack='$avg_priv_stack', avg_priv_stack='$avg_priv_stack', avg_shared_text='$avg_shared_text', page_size='$page_size', major_pgfaults='$major_pgfaults', minor_pgfaults='$minor_pgfaults', swaps='$swaps', invol_context_switches='$invol_context_switches', vol_waits='$vol_waits', fs_reads='$fs_reads', fs_writes='$fs_writes', sock_recv='$sock_recv', sock_send='$sock_send', signals='$signals', exit_status='$exit_status' WHERE app_exec_id='$execute2_id';"
+	#echo "INSERT INTO rt_info (app_exec_id, timestamp, cpu_usage, max_phys_mem, max_virt_mem, io_read, io_write) VALUES ('$execute2_id', $timestamp, $cpu_usage, $max_phys_mem, $max_virtual_mem, $io_read_bytes, $io_write_bytes);"  >> /tmp/$RUNID.sql
 #	for key in $(echo maxrss walltime systime usertime cpu fsin fsout timesswapped socketrecv socketsent majorpagefaults minorpagefaults contextswitchesinv contextswitchesvol); do
 #	    value=$(echo $runtime | awk -F "," '{print $1}' | awk -F ":" '{print $2}')
