[Swift-commit] r6104 - trunk/src/org/griphyn/vdl/engine
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Thu Dec 13 17:38:53 CST 2012
Author: hategan
Date: 2012-12-13 17:38:53 -0600 (Thu, 13 Dec 2012)
New Revision: 6104
Modified:
   trunk/src/org/griphyn/vdl/engine/Karajan.java
Log:
escape "<", ">", and "&" in string literals when compiling
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java	2012-12-13 23:38:36 UTC (rev 6103)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java	2012-12-13 23:38:53 UTC (rev 6104)
@@ -1629,7 +1629,7 @@
 		for (String key : stringInternMap.keySet()) {
 			String variableName = stringInternMap.get(key);
 			StringTemplate st = template("sConst");
-			st.setAttribute("innervalue",escapeQuotes(key));
+			st.setAttribute("innervalue",escapeQuotesAndMarkup(key));
 			StringTemplate vt = template("globalConstant");
 			vt.setAttribute("name",variableName);
 			vt.setAttribute("expr",st);
@@ -1661,6 +1661,30 @@
 		return in.replaceAll("\"", """);
+	String escapeQuotesAndMarkup(String in) {
+	    StringBuilder sb = new StringBuilder();
+	    for (int i = 0; i < in.length(); i++) {
+	        char c = in.charAt(i);
+	        switch (c) {
+	            case '<':
+	                sb.append("<");
+	                break;
+	            case '>':
+	                sb.append(">");
+	                break;
+	            case '"':
+	                sb.append(""");
+	                break;
+	            case '&':
+	                sb.append("&");
+	                break;
+	            default:
+	                sb.append(c);
+        return sb.toString();
 	public static String normalize(String type) {
 	    return org.griphyn.vdl.type.Types.normalize(type);
