[Swift-commit] cog r3528
swift at ci.uchicago.edu swift at ci.uchicago.edu
Mon Dec 3 22:40:06 CST 2012
r3528 | davidkelly999 | 2012-12-03 22:35:29 -0600 (Mon, 03 Dec 2012) | 2 lines
Fix compilation error
Index: modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/common/AbstractExecutor.java
--- modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/common/AbstractExecutor.java	(revision 3527)
+++ modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/common/AbstractExecutor.java	(working copy)
@@ -47,12 +47,12 @@
         TRIGGERS['<'] = true;
-    private File script;
-    private String stdout, stderr, exitcode, jobid;
-    private final JobSpecification spec;
-    private final Task task;
-    private final ProcessListener listener;
-    private Job job;
+    protected File script;
+    protected String stdout, stderr, exitcode, jobid;
+    protected final JobSpecification spec;
+    protected final Task task;
+    protected final ProcessListener listener;
+    protected Job job;
     protected AbstractExecutor(Task task, ProcessListener listener) {
         this.task = task;
