[Swift-commit] r5899 - SwiftApps/CMTS/dimers
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Fri Aug 10 12:22:52 CDT 2012
Author: davidk
Date: 2012-08-10 12:22:52 -0500 (Fri, 10 Aug 2012)
New Revision: 5899
Modified:
   SwiftApps/CMTS/dimers/README
Log:
Added readme
Modified: SwiftApps/CMTS/dimers/README
--- SwiftApps/CMTS/dimers/README	2012-08-10 16:44:54 UTC (rev 5898)
+++ SwiftApps/CMTS/dimers/README	2012-08-10 17:22:52 UTC (rev 5899)
@@ -0,0 +1,70 @@
+Dimers Swift Scripts
+Prerequisites
+This README will assume that runs will be started from
+makena.uchicago.edu.
+Please ensure that Swift is in your $PATH.
+Add the following line to $HOME/.bashrc to set the PATH:
+export PATH=/scratch/davidk/swift-trunk/cog/modules/swift/dist/swift-svn/bin:/opt/torque/bin:$PATH
+You will need to create a directory called /scratch/<yourusername>:
+mkdir /scratch/yourusername
+cd /scratch/yourusername
+IMPORTANT: Please note that runs may fail if started from /home due to some
+potential NFS issues, so please make sure to always use /scratch.
+Checking out scripts from SVN
+From within your scratch directory, run the following command to get the
+dimers scripts:
+svn checkout https://svn.ci.uchicago.edu/svn/vdl2/SwiftApps/CMTS/dimers
+These scripts can periodically be updated by running an SVN update within
+the dimers directory:
+svn update
+How to Run
+The rundimers.sh script is used to start a run. The options you pass to
+this script will determine how the dimers script runs.
+Usage: rundimers.sh [-s sitename]
+The sitename option determines where a run will take place. Currently, the
+only tested options are "makena" and "grotthuss".
+Example:
+./rundimers.sh -s makena
+When your job has finished running for the first time, you will see that a directory
+has been created called run001. A new directory will be created each time you run
+the rundimers.sh script.
+Outputs
+Within each run<NNN> directory is a subdirectory called output. This directory will
+contain all relevent outputs created during the run.
+Logs
+Within each run<NNN> directory is a subdirectory called logs. This directory contains
+the standard output and standard error logs from each namd task. If you notice a job
+is failing, reference these files for more detail about what went wrong.
