[Swift-commit] r5890 - in SwiftApps/CMTS/rmsd: . docs/figures
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Fri Aug 3 15:26:46 CDT 2012
Author: davidk
Date: 2012-08-03 15:26:46 -0500 (Fri, 03 Aug 2012)
New Revision: 5890
Added:
   SwiftApps/CMTS/rmsd/docs/figures/fig-distrib.png
   SwiftApps/CMTS/rmsd/docs/figures/fig-local.png
   SwiftApps/CMTS/rmsd/docs/figures/fig-multilocal.png
Removed:
   SwiftApps/CMTS/rmsd/docs/figures/fig.distrib.png
   SwiftApps/CMTS/rmsd/docs/figures/fig.local.png
   SwiftApps/CMTS/rmsd/docs/figures/fig.multilocal.png
Modified:
   SwiftApps/CMTS/rmsd/README
Log:
Some updates to README for running across multiple sites
PDF generation was choking on image names in the format of first.second.png - renamed figures
Modified: SwiftApps/CMTS/rmsd/README
--- SwiftApps/CMTS/rmsd/README	2012-08-02 22:49:31 UTC (rev 5889)
+++ SwiftApps/CMTS/rmsd/README	2012-08-03 20:26:46 UTC (rev 5890)
@@ -4,12 +4,11 @@
 Prerequisites
 This README will assume that runs will be started from
-makena.uchicago.edu.
+makena.uchicago.edu or grotthuss.uchicago.edu
 Please ensure that namd2, vmd, and Swift are in your $PATH. These
 applications must be available from the Makena worker
-nodes (applications kept in /state do not seem to be
-available by the worker nodes).
+nodes.
 Add the following line to $HOME/.bashrc to set the PATH:
@@ -41,15 +40,20 @@
 svn update
-How to Run
+Running Single Site Jobs
+For single site jobs, it is assumed that you are connected to the head node
+where you will be doing the run.
+image:figures/fig-local.png["Local", height=390, width=664]
 The runrmsd.sh script is used to start a run. The options you pass to
 this script will determine how the rmsd script runs.
 Usage: runrmsd.sh [-s sitename]
-The sitename option determines where a run will take place. Currently, the
-only tested option is "makena".
+The sitename option determines where a run will take place. Currently,
+there are valid options here are "makena" and "grotthuss".
 Example:
@@ -72,3 +76,39 @@
 Within each run<NNN> directory is a subdirectory called logs. This directory contains
 the standard output and standard error logs from each namd task. If you notice a job
 is failing, reference these files for more detail about what went wrong.
+Running Remote and Multisite Jobs
+It is possible to run this script remotely across multiple sites at once. For example, a test
+configuration exists called "makgroth" which runs jobs on both Makena and Grotthuss at the same time.
+Here is an example of what a configuration might look like.
+image:figures/fig-distrib.png["Distributed Configuration", width=700]
+There are two requirements for this: SSH agent forwarding must be used, and a grid certificate
+must be in place on each of the machines involved.
+The easiest way to set up SSH agent forwarding is to use the "-A" option to ssh. In this
+example, let us assume that we will be running Swift on a machine called
+bridled.ci.uchicago.edu, and sending work to grotthuss and makena.
+My laptop is the machine that has the my SSH key. When I connect to bridled, I run this command:
+ssh -A bridled.ci.uchicago.edu
+This will enable me to bring my SSH key to the makena and grotthuss head nodes easily. You must also
+have $HOME/.ssh/authorized_keys setup correctly on makena/grotthuss to avoid getting prompted for a
+password.
+The second thing that will be needed is a grid certificate. You have have the environment variables
+X509_CERT_DIR and X509_USER_PROXY set up to point to your certificates directory and proxy.
+Once this is all set up, performing the run is very similar to how you run single site jobs.
+./runrmsd.sh -s makgroth
Copied: SwiftApps/CMTS/rmsd/docs/figures/fig-distrib.png (from rev 5889, SwiftApps/CMTS/rmsd/docs/figures/fig.distrib.png)
(Binary files differ)
Copied: SwiftApps/CMTS/rmsd/docs/figures/fig-local.png (from rev 5889, SwiftApps/CMTS/rmsd/docs/figures/fig.local.png)
Copied: SwiftApps/CMTS/rmsd/docs/figures/fig-multilocal.png (from rev 5889, SwiftApps/CMTS/rmsd/docs/figures/fig.multilocal.png)
Deleted: SwiftApps/CMTS/rmsd/docs/figures/fig.distrib.png
Deleted: SwiftApps/CMTS/rmsd/docs/figures/fig.local.png
Deleted: SwiftApps/CMTS/rmsd/docs/figures/fig.multilocal.png
