[Swift-commit] cog r3444
swift at ci.uchicago.edu swift at ci.uchicago.edu
Thu Aug 2 01:50:03 CDT 2012
r3444 | hategan | 2012-08-02 01:46:31 -0500 (Thu, 02 Aug 2012) | 1 line
new security context stuff
Index: modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/ServiceNode.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/ServiceNode.java	(revision 3443)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/ServiceNode.java	(working copy)
@@ -12,6 +12,7 @@
 import org.apache.log4j.Logger;
 import org.globus.cog.abstraction.impl.common.AbstractionFactory;
 import org.globus.cog.abstraction.impl.common.AbstractionProperties;
+import org.globus.cog.abstraction.impl.common.InteractivePasswordSecurityContextImpl;
 import org.globus.cog.abstraction.impl.common.task.ExecutionServiceImpl;
 import org.globus.cog.abstraction.impl.common.task.ServiceContactImpl;
 import org.globus.cog.abstraction.impl.common.task.ServiceImpl;
@@ -88,6 +89,15 @@
 		if (A_PROJECT.isPresent(stack)) {
 			service.setAttribute("project", TypeUtil.toString(A_PROJECT.getValue(stack)));
+		String uri = null;
+		uri = TypeUtil.toString(A_URI.getValue(stack));
+		if (uri == null) {
+			uri = TypeUtil.toString(A_URL.getValue(stack));
+		if (uri != null) {
+			service.setServiceContact(new ServiceContactImpl(uri));
 		SecurityContext sc = (SecurityContext) A_SECURITY_CONTEXT.getValue(stack);
 		if (sc == null) {
@@ -101,7 +111,7 @@
 				if (sc == null) {
 					try {
-						sc = AbstractionFactory.newSecurityContext(provider);
+						sc = AbstractionFactory.getSecurityContext(provider, service.getServiceContact());
 						stack.setGlobal(scName, sc);
 					catch (Exception e1) {
@@ -112,16 +122,13 @@
+		else {
+			if (sc instanceof InteractivePasswordSecurityContextImpl) {
+				((InteractivePasswordSecurityContextImpl) sc).setHostName(uri);
 		service.setSecurityContext(sc);
 		service.setType(itype);
-		String uri = null;
-		uri = TypeUtil.toString(A_URI.getValue(stack));
-		if (uri == null) {
-			uri = TypeUtil.toString(A_URL.getValue(stack));
-		if (uri != null) {
-			service.setServiceContact(new ServiceContactImpl(uri));
 		return service;
\ No newline at end of file
Index: modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AbstractGridNode.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AbstractGridNode.java	(revision 3443)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AbstractGridNode.java	(working copy)
@@ -25,6 +25,7 @@
 import org.globus.cog.abstraction.interfaces.SecurityContext;
 import org.globus.cog.abstraction.interfaces.Service;
+import org.globus.cog.abstraction.interfaces.ServiceContact;
 import org.globus.cog.abstraction.interfaces.Status;
 import org.globus.cog.abstraction.interfaces.StatusListener;
 import org.globus.cog.abstraction.interfaces.Task;
@@ -118,22 +119,21 @@
 	private void addDefaultServices(BoundContact bc, String contact, String provider)
 			throws ExecutionException {
+	    ServiceContact serviceContact = new ServiceContactImpl(contact);
 		SecurityContext sc = null;
 		if (provider != null) {
 			try {
+				sc = AbstractionFactory.getSecurityContext(provider, serviceContact);
 			catch (Exception e) {
 				throw new ExecutionException("Could not get default security context for provider "
 						+ provider, e);
-		bc.addService(new ServiceImpl(provider, Service.EXECUTION, new ServiceContactImpl(contact),
-				sc));
-		bc.addService(new ServiceImpl(provider, Service.FILE_OPERATION, new ServiceContactImpl(
-				contact), sc));
-		bc.addService(new ServiceImpl(provider, Service.FILE_TRANSFER, new ServiceContactImpl(
-				contact), sc));
+		bc.addService(new ServiceImpl(provider, Service.EXECUTION, serviceContact, sc));
+		bc.addService(new ServiceImpl(provider, Service.FILE_OPERATION, serviceContact, sc));
+		bc.addService(new ServiceImpl(provider, Service.FILE_TRANSFER, serviceContact, sc));
 	public static final Arg A_SECURITY_CONTEXT = new Arg.TypedPositional("securityContext",
@@ -334,7 +334,7 @@
-	protected SecurityContext getSecurityContext(VariableStack stack, String provider)
+	protected SecurityContext getSecurityContext(VariableStack stack, String provider, ServiceContact serviceContact)
 			throws InvalidProviderException, ProviderMethodException, ExecutionException {
 		if (A_SECURITY_CONTEXT.isPresent(stack)) {
 			return (SecurityContext) A_SECURITY_CONTEXT.getValue(stack);
@@ -344,7 +344,7 @@
 					SecurityContext.class, "Security Context");
 		else {
-			return AbstractionFactory.newSecurityContext(provider);
+			return AbstractionFactory.getSecurityContext(provider, serviceContact);
Index: modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/SecurityContextNode.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/SecurityContextNode.java	(revision 3443)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/SecurityContextNode.java	(working copy)
@@ -32,7 +32,7 @@
 		if (context == null) {
 		    String provider = TypeUtil.toString(A_PROVIDER.getValue(stack));
 			try {
-				context = AbstractionFactory.newSecurityContext(provider);
+				context = AbstractionFactory.getSecurityContext(provider, null);
 				throw new ExecutionException("Unsupported security context type: " + provider, e);
Index: modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AbstractFileOperation.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AbstractFileOperation.java	(revision 3443)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AbstractFileOperation.java	(working copy)
@@ -56,8 +56,9 @@
 			if (scheduler == null) {
-				task.setService(0, getService((BoundContact) host, provider));
-				SecurityContext sc = getSecurityContext(stack, provider);
+			    Service service = getService((BoundContact) host, provider);
+				task.setService(0, service);
+				SecurityContext sc = getSecurityContext(stack, provider, service.getServiceContact());
 				setSecurityContextIfNotLocal(task.getService(0), sc);
 				synchronized (this.getClass()) {
 					if (handler == null) {
Index: modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/GridTransfer.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/GridTransfer.java	(revision 3443)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/GridTransfer.java	(working copy)
@@ -164,8 +164,8 @@
 									+ destinationContact);
-				setSecurityContextIfNotLocal(s, getSecurityContext(stack, s.getProvider()));
-				setSecurityContextIfNotLocal(d, getSecurityContext(stack, d.getProvider()));
+				setSecurityContextIfNotLocal(s, getSecurityContext(stack, s.getProvider(), s.getServiceContact()));
+				setSecurityContextIfNotLocal(d, getSecurityContext(stack, d.getProvider(), d.getServiceContact()));
 				task.setService(Service.FILE_TRANSFER_SOURCE_SERVICE, s);
 				task.setService(Service.FILE_TRANSFER_DESTINATION_SERVICE, d);
