[Swift-commit] r5080 - branches/release-0.93/docs/siteguide
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Wed Sep 7 11:45:33 CDT 2011
Author: davidk
Date: 2011-09-07 11:45:33 -0500 (Wed, 07 Sep 2011)
New Revision: 5080
Modified:
   branches/release-0.93/docs/siteguide/intrepid
Log:
updated path to template
Modified: branches/release-0.93/docs/siteguide/intrepid
--- branches/release-0.93/docs/siteguide/intrepid	2011-09-07 16:32:23 UTC (rev 5079)
+++ branches/release-0.93/docs/siteguide/intrepid	2011-09-07 16:45:33 UTC (rev 5080)
@@ -125,7 +125,7 @@
 TODO: Update the rest below here
-include::../../tests/providers/intrepid/sites.template.xml[]
+include::../../tests/providers/local-cobalt/intrepid/sites.template.xml[]
 The values to note here are the ones that are listed between underscores. In the example above, they are \_QUEUE_, and \_WORK_. Queue is the PADS queue to use and WORK is the swift work directory. These are placeholder values you will need to modify to fit your needs. Copy and paste this template, replace the values, and call it sites.xml.
@@ -135,7 +135,7 @@
 Below is the tc.data file used by Swift's test suite for running on PADS.
-include::../../tests/providers/intrepid/tc.template.data[]
+include::../../tests/providers/local-cobalt/intrepid/tc.template.data[]
 Copy these commands and save it as tc.data.
