[Swift-commit] r5074 - trunk/bin
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Tue Sep 6 10:16:00 CDT 2011
Author: wozniak
Date: 2011-09-06 10:16:00 -0500 (Tue, 06 Sep 2011)
New Revision: 5074
Modified:
   trunk/bin/chxml
   trunk/bin/swift
Log:
Better error handling in bin/chxml, bin/swift (ref #347)
Modified: trunk/bin/chxml
--- trunk/bin/chxml	2011-09-06 14:51:54 UTC (rev 5073)
+++ trunk/bin/chxml	2011-09-06 15:16:00 UTC (rev 5074)
@@ -14,22 +14,28 @@
         self.endTags=[]
         self.globusParams = 0
         self.execProvider = ""
         if len(argstr)<2:
             print "please specify a sites file"
-            sys.exit()
+            sys.exit(1)
         i = 0
         for o in argstr:
             if o == "'-sites.file'":
                 self.sites_file = argstr[i+1].split("'")[1]
             elif o == "'-config'":
-                config_file = open(argstr[i+1].split("'")[1],"r")
+                try:
+                    config_filename = argstr[i+1].split("'")[1]
+                    config_file = open(config_filename,"r")
+                except IOError as (errno, strerror):
+                    print strerror
+                    sys.exit("Could not read: " + config_filename)
                 for line in config_file.readlines():
                     if line.strip().startswith('#'):
                         continue
                     if line.find("sites.file")>-1:
                         self.sites_file = line.split("=")[1].strip()
-            i = i+1
+            i = i+1
         if (self.sites_file == ""):
             swift_loc = commands.getoutput("which swift")
             swift_home = swift_loc.split("bin")[0]
@@ -55,10 +61,11 @@
     def end_element(self, name):
         self.endTags.append(name)
 #------------------------main----------------------------------
 mysite = siteProps(sys.argv)
 try:
     mysite.parsefile()
 except Exception, e:
@@ -87,4 +94,4 @@
 if (config<1):
     print "Warning: Your site file, "+mysite.sites_file+" is missing a config entry"
     sys.exit()
Modified: trunk/bin/swift
--- trunk/bin/swift	2011-09-06 14:51:54 UTC (rev 5073)
+++ trunk/bin/swift	2011-09-06 15:16:00 UTC (rev 5074)
@@ -64,6 +64,10 @@
 # make sure sites.xml file is well-formed
 $SWIFT_HOME/bin/chxml $CMDLINE
+if [[ ${?} != 0 ]]; then
+	echo "Could not process input files!"
+	exit 1
+fi
 ### SETUP OTHER ENV VARIABLES ####
@@ -171,4 +175,5 @@
 # Local Variables:
 # tab-width: 4
+# indent-tabs-mode: t
 # End:
