[Swift-commit] r5324 - in usertools/swift-vm-boot: . bin plan
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Tue Nov 29 15:20:57 CST 2011
Author: davidk
Date: 2011-11-29 15:20:57 -0600 (Tue, 29 Nov 2011)
New Revision: 5324
Added:
   usertools/swift-vm-boot/bin/
   usertools/swift-vm-boot/bin/bootit.sh
   usertools/swift-vm-boot/bin/handleoutput.py
   usertools/swift-vm-boot/bin/nimbus-register-key.py
   usertools/swift-vm-boot/bin/register_key.py
   usertools/swift-vm-boot/bin/virtualenv.py
   usertools/swift-vm-boot/env.sh
   usertools/swift-vm-boot/hosts.txt
   usertools/swift-vm-boot/install.sh
   usertools/swift-vm-boot/plan/
   usertools/swift-vm-boot/plan/test-level1.conf
   usertools/swift-vm-boot/plan/top.conf
Removed:
Log:
Fixes for registering futuregrid keys
Added: usertools/swift-vm-boot/bin/bootit.sh
--- usertools/swift-vm-boot/bin/bootit.sh	                        (rev 0)
+++ usertools/swift-vm-boot/bin/bootit.sh	2011-11-29 21:20:57 UTC (rev 5324)
@@ -0,0 +1,22 @@
+#!/bin/bash
+dir=`dirname $0`
+cd $dir
+cd ..
+source env.sh
+source ve/bin/activate
+output="output.json"
+cloudinitd -l debug -v -v -v boot plan/top.conf -o $output
+if [ $? -ne 0 ]; then
+    echo "The boot failed.  Check the logs"
+    exit 1
+fi
+echo "getting the hostnames..."
+python bin/handleoutput.py $output
+    echo "The output parse failed"
+    exit 1
+fi
Property changes on: usertools/swift-vm-boot/bin/bootit.sh
___________________________________________________________________
Added: svn:executable
Added: usertools/swift-vm-boot/bin/handleoutput.py
--- usertools/swift-vm-boot/bin/handleoutput.py	                        (rev 0)
+++ usertools/swift-vm-boot/bin/handleoutput.py	2011-11-29 21:20:57 UTC (rev 5324)
@@ -0,0 +1,16 @@
+#!/usr/bin/env python
+import os
+import sys
+import simplejson as json
+x = json.load(open(sys.argv[1], "r"))
+levels = x['levels']
+lvl1 = levels[0]
+services = lvl1['services']
+for svc in services:
+    print svc['hostname']
Property changes on: usertools/swift-vm-boot/bin/handleoutput.py
Added: usertools/swift-vm-boot/bin/nimbus-register-key.py
--- usertools/swift-vm-boot/bin/nimbus-register-key.py	                        (rev 0)
+++ usertools/swift-vm-boot/bin/nimbus-register-key.py	2011-11-29 21:20:57 UTC (rev 5324)
@@ -0,0 +1,39 @@
+import os
+import sys
+import base64
+import boto
+from boto.ec2.regioninfo import RegionInfo
+import urllib2
+def add_key(ec2conn, keyname, keytext):
+    pairs = ec2conn.get_all_key_pairs([keyname,])
+    if not pairs:
+        print "Adding a new key pair named %s" % (keyname)
+        ec2conn.import_key_pair(keyname, keytext)
+    else:
+        print "Keyname %s already exists" % (keyname)
+try:
+    access_id = os.environ['FUTUREGRID_IAAS_ACCESS_KEY']
+    access_secret = os.environ['FUTUREGRID_IAAS_SECRET_KEY']
+    iaas_url = os.environ['FUTUREGRID_IAAS_URL']
+except Exception, ex:
+    print "Make sure the envs CLOUDINITD_* are set %s" % (str(ex))
+    sys.exit(1)
+url_parts = urllib2.urlparse.urlparse(iaas_url)
+region = RegionInfo(name="nimbus", endpoint=url_parts.hostname)
+ec2conn = boto.connect_ec2(access_id, access_secret, region=region, port=url_parts.port)
+keyname = sys.argv[1]
+keylocation = sys.argv[2]
+keytext = open(keylocation).read()
+keytext = base64.b64encode(keytext)
+add_key(ec2conn, keyname, keytext)
+sys.exit(0)
Added: usertools/swift-vm-boot/bin/register_key.py
--- usertools/swift-vm-boot/bin/register_key.py	                        (rev 0)
+++ usertools/swift-vm-boot/bin/register_key.py	2011-11-29 21:20:57 UTC (rev 5324)
@@ -0,0 +1,37 @@
+import os
+import sys
+import base64
+import boto
+try:
+except:
+    print "Make sure the envs FUTUREGRID_IAAS_ACCESS_KEY and FUTUREGRID_IAAS_SECRET_KEY are set"
+    sys.exit(1)
+hostfile = sys.argv[1]
+keyname = "swiftkey"
+if len(sys.argv) > 2:
+    keylocation = sys.argv[2]
+else:
+    keylocation = os.path.expanduser("~/.ssh/id_rsa.pub")
+f = open(hostfile, "r")
+for line in f:
+    host = line.strip()
+    print "creating key %s on %s" % (keyname, host)
+    region = RegionInfo(name="nimbus", endpoint=host)
+    ec2conn = boto.connect_ec2(access_id, access_secret, region=region, port=8444)
+#    keytext = base64.b64encode(keytext)
+sys.exit(0)
Property changes on: usertools/swift-vm-boot/bin/register_key.py
Added: usertools/swift-vm-boot/bin/virtualenv.py
--- usertools/swift-vm-boot/bin/virtualenv.py	                        (rev 0)
+++ usertools/swift-vm-boot/bin/virtualenv.py	2011-11-29 21:20:57 UTC (rev 5324)
@@ -0,0 +1,1651 @@
+"""Create a "virtual" Python installation
+virtualenv_version = "1.5.1"
+import sys
+import os
+import optparse
+import re
+import shutil
+import logging
+import tempfile
+import distutils.sysconfig
+try:
+    import subprocess
+except ImportError, e:
+    if sys.version_info <= (2, 3):
+        print 'ERROR: %s' % e
+        print 'ERROR: this script requires Python 2.4 or greater; or at least the subprocess module.'
+        print 'If you copy subprocess.py from a newer version of Python this script will probably work'
+        sys.exit(101)
+    else:
+        raise
+try:
+    set
+except NameError:
+    from sets import Set as set
+join = os.path.join
+py_version = 'python%s.%s' % (sys.version_info[0], sys.version_info[1])
+is_jython = sys.platform.startswith('java')
+is_pypy = hasattr(sys, 'pypy_version_info')
+if is_pypy:
+    expected_exe = 'pypy-c'
+elif is_jython:
+    expected_exe = 'jython'
+else:
+    expected_exe = 'python'
+REQUIRED_MODULES = ['os', 'posix', 'posixpath', 'nt', 'ntpath', 'genericpath',
+                    'fnmatch', 'locale', 'encodings', 'codecs',
+                    'stat', 'UserDict', 'readline', 'copy_reg', 'types',
+                    're', 'sre', 'sre_parse', 'sre_constants', 'sre_compile',
+                    'zlib']
+REQUIRED_FILES = ['lib-dynload', 'config']
+if sys.version_info[:2] >= (2, 6):
+    REQUIRED_MODULES.extend(['warnings', 'linecache', '_abcoll', 'abc'])
+if sys.version_info[:2] >= (2, 7):
+    REQUIRED_MODULES.extend(['_weakrefset'])
+if sys.version_info[:2] <= (2, 3):
+    REQUIRED_MODULES.extend(['sets', '__future__'])
+if is_pypy:
+    # these are needed to correctly display the exceptions that may happen
+    # during the bootstrap
+    REQUIRED_MODULES.extend(['traceback', 'linecache'])
+class Logger(object):
+    Logging object for use in command-line script.  Allows ranges of
+    levels, to avoid some redundancy of displayed information.
+    DEBUG = logging.DEBUG
+    INFO = logging.INFO
+    NOTIFY = (logging.INFO+logging.WARN)/2
+    WARN = WARNING = logging.WARN
+    ERROR = logging.ERROR
+    FATAL = logging.FATAL
+    LEVELS = [DEBUG, INFO, NOTIFY, WARN, ERROR, FATAL]
+    def __init__(self, consumers):
+        self.consumers = consumers
+        self.indent = 0
+        self.in_progress = None
+        self.in_progress_hanging = False
+    def debug(self, msg, *args, **kw):
+        self.log(self.DEBUG, msg, *args, **kw)
+    def info(self, msg, *args, **kw):
+        self.log(self.INFO, msg, *args, **kw)
+    def notify(self, msg, *args, **kw):
+        self.log(self.NOTIFY, msg, *args, **kw)
+    def warn(self, msg, *args, **kw):
+        self.log(self.WARN, msg, *args, **kw)
+    def error(self, msg, *args, **kw):
+    def fatal(self, msg, *args, **kw):
+        self.log(self.FATAL, msg, *args, **kw)
+    def log(self, level, msg, *args, **kw):
+        if args:
+            if kw:
+                raise TypeError(
+                    "You may give positional or keyword arguments, not both")
+        args = args or kw
+        rendered = None
+        for consumer_level, consumer in self.consumers:
+            if self.level_matches(level, consumer_level):
+                if (self.in_progress_hanging
+                    and consumer in (sys.stdout, sys.stderr)):
+                    sys.stdout.write('\n')
+                    sys.stdout.flush()
+                if rendered is None:
+                    if args:
+                        rendered = msg % args
+                    else:
+                        rendered = msg
+                    rendered = ' '*self.indent + rendered
+                if hasattr(consumer, 'write'):
+                    consumer.write(rendered+'\n')
+                else:
+                    consumer(rendered)
+    def start_progress(self, msg):
+        assert not self.in_progress, (
+            "Tried to start_progress(%r) while in_progress %r"
+            % (msg, self.in_progress))
+        if self.level_matches(self.NOTIFY, self._stdout_level()):
+            sys.stdout.write(msg)
+            self.in_progress_hanging = True
+        else:
+        self.in_progress = msg
+    def end_progress(self, msg='done.'):
+        assert self.in_progress, (
+            "Tried to end_progress without start_progress")
+        if self.stdout_level_matches(self.NOTIFY):
+            if not self.in_progress_hanging:
+                # Some message has been printed out since start_progress
+                sys.stdout.write('...' + self.in_progress + msg + '\n')
+            else:
+                sys.stdout.write(msg + '\n')
+    def show_progress(self):
+        """If we are in a progress scope, and no log messages have been
+        shown, write out another '.'"""
+        if self.in_progress_hanging:
+            sys.stdout.write('.')
+    def stdout_level_matches(self, level):
+        """Returns true if a message at this level will go to stdout"""
+        return self.level_matches(level, self._stdout_level())
+    def _stdout_level(self):
+        """Returns the level that stdout runs at"""
+        for level, consumer in self.consumers:
+            if consumer is sys.stdout:
+                return level
+        return self.FATAL
+    def level_matches(self, level, consumer_level):
+        >>> l = Logger()
+        >>> l.level_matches(3, 4)
+        False
+        >>> l.level_matches(3, 2)
+        True
+        >>> l.level_matches(slice(None, 3), 3)
+        False
+        >>> l.level_matches(slice(None, 3), 2)
+        True
+        >>> l.level_matches(slice(1, 3), 1)
+        True
+        >>> l.level_matches(slice(2, 3), 1)
+        False
+        if isinstance(level, slice):
+            start, stop = level.start, level.stop
+            if start is not None and start > consumer_level:
+                return False
+            if stop is not None or stop <= consumer_level:
+                return False
+            return True
+        else:
+            return level >= consumer_level
+    #@classmethod
+    def level_for_integer(cls, level):
+        levels = cls.LEVELS
+        if level < 0:
+            return levels[0]
+        if level >= len(levels):
+            return levels[-1]
+        return levels[level]
+    level_for_integer = classmethod(level_for_integer)
+def mkdir(path):
+    if not os.path.exists(path):
+        logger.info('Creating %s', path)
+        os.makedirs(path)
+    else:
+        logger.info('Directory %s already exists', path)
+def copyfile(src, dest, symlink=True):
+    if not os.path.exists(src):
+        # Some bad symlink in the src
+        logger.warn('Cannot find file %s (bad symlink)', src)
+        return
+    if os.path.exists(dest):
+        logger.debug('File %s already exists', dest)
+        return
+    if not os.path.exists(os.path.dirname(dest)):
+        logger.info('Creating parent directories for %s' % os.path.dirname(dest))
+        os.makedirs(os.path.dirname(dest))
+    if symlink and hasattr(os, 'symlink'):
+        logger.info('Symlinking %s', dest)
+        os.symlink(os.path.abspath(src), dest)
+    else:
+        logger.info('Copying to %s', dest)
+        if os.path.isdir(src):
+            shutil.copytree(src, dest, True)
+        else:
+            shutil.copy2(src, dest)
+def writefile(dest, content, overwrite=True):
+    if not os.path.exists(dest):
+        logger.info('Writing %s', dest)
+        f = open(dest, 'wb')
+        f.write(content)
+        f.close()
+        return
+    else:
+        f = open(dest, 'rb')
+        c = f.read()
+        f.close()
+        if c != content:
+            if not overwrite:
+                logger.notify('File %s exists with different content; not overwriting', dest)
+                return
+            logger.notify('Overwriting %s with new content', dest)
+            f.write(content)
+            f.close()
+        else:
+            logger.info('Content %s already in place', dest)
+def rmtree(dir):
+    if os.path.exists(dir):
+        logger.notify('Deleting tree %s', dir)
+        shutil.rmtree(dir)
+    else:
+        logger.info('Do not need to delete %s; already gone', dir)
+def make_exe(fn):
+    if hasattr(os, 'chmod'):
+        oldmode = os.stat(fn).st_mode & 07777
+        newmode = (oldmode | 0555) & 07777
+        os.chmod(fn, newmode)
+        logger.info('Changed mode of %s to %s', fn, oct(newmode))
+def _find_file(filename, dirs):
+    for dir in dirs:
+        if os.path.exists(join(dir, filename)):
+            return join(dir, filename)
+    return filename
+def _install_req(py_executable, unzip=False, distribute=False):
+    if not distribute:
+        setup_fn = 'setuptools-0.6c11-py%s.egg' % sys.version[:3]
+        project_name = 'setuptools'
+        bootstrap_script = EZ_SETUP_PY
+        source = None
+    else:
+        setup_fn = None
+        source = 'distribute-0.6.14.tar.gz'
+        project_name = 'distribute'
+        bootstrap_script = DISTRIBUTE_SETUP_PY
+        try:
+            # check if the global Python has distribute installed or plain
+            # setuptools
+            import pkg_resources
+            if not hasattr(pkg_resources, '_distribute'):
+                location = os.path.dirname(pkg_resources.__file__)
+                logger.notify("A globally installed setuptools was found (in %s)" % location)
+                logger.notify("Use the --no-site-packages option to use distribute in "
+                              "the virtualenv.")
+        except ImportError:
+            pass
+    search_dirs = file_search_dirs()
+    if setup_fn is not None:
+        setup_fn = _find_file(setup_fn, search_dirs)
+    if source is not None:
+        source = _find_file(source, search_dirs)
+    if is_jython and os._name == 'nt':
+        # Jython's .bat sys.executable can't handle a command line
+        # argument with newlines
+        fd, ez_setup = tempfile.mkstemp('.py')
+        os.write(fd, bootstrap_script)
+        os.close(fd)
+        cmd = [py_executable, ez_setup]
+    else:
+        cmd = [py_executable, '-c', bootstrap_script]
+    if unzip:
+        cmd.append('--always-unzip')
+    env = {}
+    remove_from_env = []
+    if logger.stdout_level_matches(logger.DEBUG):
+        cmd.append('-v')
+    old_chdir = os.getcwd()
+    if setup_fn is not None and os.path.exists(setup_fn):
+        logger.info('Using existing %s egg: %s' % (project_name, setup_fn))
+        cmd.append(setup_fn)
+        if os.environ.get('PYTHONPATH'):
+            env['PYTHONPATH'] = setup_fn + os.path.pathsep + os.environ['PYTHONPATH']
+        else:
+    else:
+        # the source is found, let's chdir
+        if source is not None and os.path.exists(source):
+            os.chdir(os.path.dirname(source))
+            # in this case, we want to be sure that PYTHONPATH is unset (not
+            # just empty, really unset), else CPython tries to import the
+            # site.py that it's in virtualenv_support
+            remove_from_env.append('PYTHONPATH')
+        else:
+            logger.info('No %s egg found; downloading' % project_name)
+        cmd.extend(['--always-copy', '-U', project_name])
+    logger.start_progress('Installing %s...' % project_name)
+    logger.indent += 2
+    cwd = None
+    if project_name == 'distribute':
+        env['DONT_PATCH_SETUPTOOLS'] = 'true'
+    def _filter_ez_setup(line):
+        return filter_ez_setup(line, project_name)
+    if not os.access(os.getcwd(), os.W_OK):
+        cwd = tempfile.mkdtemp()
+            # the current working dir is hostile, let's copy the
+            # tarball to a temp dir
+            target = os.path.join(cwd, os.path.split(source)[-1])
+            shutil.copy(source, target)
+    try:
+        call_subprocess(cmd, show_stdout=False,
+                        filter_stdout=_filter_ez_setup,
+                        extra_env=env,
+                        remove_from_env=remove_from_env,
+                        cwd=cwd)
+    finally:
+        logger.indent -= 2
+        logger.end_progress()
+        if os.getcwd() != old_chdir:
+            os.chdir(old_chdir)
+            os.remove(ez_setup)
+def file_search_dirs():
+    here = os.path.dirname(os.path.abspath(__file__))
+    dirs = ['.', here,
+            join(here, 'virtualenv_support')]
+    if os.path.splitext(os.path.dirname(__file__))[0] != 'virtualenv':
+        # Probably some boot script; just in case virtualenv is installed...
+        try:
+            import virtualenv
+            pass
+        else:
+            dirs.append(os.path.join(os.path.dirname(virtualenv.__file__), 'virtualenv_support'))
+    return [d for d in dirs if os.path.isdir(d)]
+def install_setuptools(py_executable, unzip=False):
+    _install_req(py_executable, unzip)
+def install_distribute(py_executable, unzip=False):
+    _install_req(py_executable, unzip, distribute=True)
+_pip_re = re.compile(r'^pip-.*(zip|tar.gz|tar.bz2|tgz|tbz)$', re.I)
+def install_pip(py_executable):
+    filenames = []
+    for dir in file_search_dirs():
+        filenames.extend([join(dir, fn) for fn in os.listdir(dir)
+                          if _pip_re.search(fn)])
+    filenames = [(os.path.basename(filename).lower(), i, filename) for i, filename in enumerate(filenames)]
+    filenames.sort()
+    filenames = [filename for basename, i, filename in filenames]
+    if not filenames:
+        filename = 'pip'
+    else:
+        filename = filenames[-1]
+    easy_install_script = 'easy_install'
+    if sys.platform == 'win32':
+        easy_install_script = 'easy_install-script.py'
+    cmd = [py_executable, join(os.path.dirname(py_executable), easy_install_script), filename]
+    if filename == 'pip':
+        logger.info('Installing pip from network...')
+    else:
+        logger.info('Installing %s' % os.path.basename(filename))
+    def _filter_setup(line):
+        return filter_ez_setup(line, 'pip')
+    try:
+                        filter_stdout=_filter_setup)
+    finally:
+def filter_ez_setup(line, project_name='setuptools'):
+    if not line.strip():
+        return Logger.DEBUG
+        for prefix in ('Extracting', 'Now working', 'Installing', 'Before',
+                       'Scanning', 'Setuptools', 'Egg', 'Already',
+                       'running', 'writing', 'reading', 'installing',
+                       'creating', 'copying', 'byte-compiling', 'removing',
+                       'Processing'):
+            if line.startswith(prefix):
+    for prefix in ['Reading ', 'Best match', 'Processing setuptools',
+                   'Copying setuptools', 'Adding setuptools',
+                   'Installing ', 'Installed ']:
+    return Logger.INFO
+def main():
+    parser = optparse.OptionParser(
+        version=virtualenv_version,
+        usage="%prog [OPTIONS] DEST_DIR")
+    parser.add_option(
+        '-v', '--verbose',
+        action='count',
+        dest='verbose',
+        default=0,
+        help="Increase verbosity")
+        '-q', '--quiet',
+        action='count',
+        dest='quiet',
+        default=0,
+        help='Decrease verbosity')
+        '-p', '--python',
+        dest='python',
+        metavar='PYTHON_EXE',
+        help='The Python interpreter to use, e.g., --python=python2.5 will use the python2.5 '
+        'interpreter to create the new environment.  The default is the interpreter that '
+        'virtualenv was installed with (%s)' % sys.executable)
+        '--clear',
+        dest='clear',
+        action='store_true',
+        help="Clear out the non-root install and start from scratch")
+        '--no-site-packages',
+        dest='no_site_packages',
+        help="Don't give access to the global site-packages dir to the "
+             "virtual environment")
+        '--unzip-setuptools',
+        dest='unzip_setuptools',
+        help="Unzip Setuptools or Distribute when installing it")
+        '--relocatable',
+        dest='relocatable',
+        help='Make an EXISTING virtualenv environment relocatable.  '
+        'This fixes up scripts and makes all .pth files relative')
+        '--distribute',
+        dest='use_distribute',
+        help='Use Distribute instead of Setuptools. Set environ variable '
+        'VIRTUALENV_USE_DISTRIBUTE to make it the default ')
+        '--prompt=',
+        dest='prompt',
+        help='Provides an alternative prompt prefix for this environment')
+    if 'extend_parser' in globals():
+        extend_parser(parser)
+    options, args = parser.parse_args()
+    global logger
+    if 'adjust_options' in globals():
+        adjust_options(options, args)
+    verbosity = options.verbose - options.quiet
+    logger = Logger([(Logger.level_for_integer(2-verbosity), sys.stdout)])
+    if options.python and not os.environ.get('VIRTUALENV_INTERPRETER_RUNNING'):
+        env = os.environ.copy()
+        interpreter = resolve_interpreter(options.python)
+        if interpreter == sys.executable:
+            logger.warn('Already using interpreter %s' % interpreter)
+        else:
+            logger.notify('Running virtualenv with interpreter %s' % interpreter)
+            env['VIRTUALENV_INTERPRETER_RUNNING'] = 'true'
+            file = __file__
+            if file.endswith('.pyc'):
+                file = file[:-1]
+            popen = subprocess.Popen([interpreter, file] + sys.argv[1:], env=env)
+            raise SystemExit(popen.wait())
+    if not args:
+        print 'You must provide a DEST_DIR'
+        parser.print_help()
+        sys.exit(2)
+    if len(args) > 1:
+        print 'There must be only one argument: DEST_DIR (you gave %s)' % (
+            ' '.join(args))
+        sys.exit(2)
+    home_dir = args[0]
+    if os.environ.get('WORKING_ENV'):
+        logger.fatal('ERROR: you cannot run virtualenv while in a workingenv')
+        logger.fatal('Please deactivate your workingenv, then re-run this script')
+        sys.exit(3)
+    if 'PYTHONHOME' in os.environ:
+        logger.warn('PYTHONHOME is set.  You *must* activate the virtualenv before using it')
+        del os.environ['PYTHONHOME']
+    if options.relocatable:
+        make_environment_relocatable(home_dir)
+        return
+    create_environment(home_dir, site_packages=not options.no_site_packages, clear=options.clear,
+                       unzip_setuptools=options.unzip_setuptools,
+                       use_distribute=options.use_distribute,
+                       prompt=options.prompt)
+    if 'after_install' in globals():
+        after_install(options, home_dir)
+def call_subprocess(cmd, show_stdout=True,
+                    filter_stdout=None, cwd=None,
+                    raise_on_returncode=True, extra_env=None,
+                    remove_from_env=None):
+    cmd_parts = []
+    for part in cmd:
+        if len(part) > 40:
+            part = part[:30]+"..."+part[-5:]
+        if ' ' in part or '\n' in part or '"' in part or "'" in part:
+            part = '"%s"' % part.replace('"', '\\"')
+        cmd_parts.append(part)
+    cmd_desc = ' '.join(cmd_parts)
+    if show_stdout:
+        stdout = None
+    else:
+        stdout = subprocess.PIPE
+    logger.debug("Running command %s" % cmd_desc)
+    if extra_env or remove_from_env:
+        if extra_env:
+            env.update(extra_env)
+        if remove_from_env:
+            for varname in remove_from_env:
+                env.pop(varname, None)
+    else:
+        env = None
+    try:
+        proc = subprocess.Popen(
+            cmd, stderr=subprocess.STDOUT, stdin=None, stdout=stdout,
+            cwd=cwd, env=env)
+    except Exception, e:
+        logger.fatal(
+            "Error %s while executing command %s" % (e, cmd_desc))
+        raise
+    all_output = []
+    if stdout is not None:
+        stdout = proc.stdout
+        while 1:
+            line = stdout.readline()
+            if not line:
+                break
+            line = line.rstrip()
+            all_output.append(line)
+            if filter_stdout:
+                level = filter_stdout(line)
+                if isinstance(level, tuple):
+                    level, line = level
+                logger.log(level, line)
+                if not logger.stdout_level_matches(level):
+                    logger.show_progress()
+            else:
+                logger.info(line)
+    else:
+        proc.communicate()
+    proc.wait()
+    if proc.returncode:
+        if raise_on_returncode:
+            if all_output:
+                logger.notify('Complete output from command %s:' % cmd_desc)
+                logger.notify('\n'.join(all_output) + '\n----------------------------------------')
+            raise OSError(
+                "Command %s failed with error code %s"
+                % (cmd_desc, proc.returncode))
+        else:
+            logger.warn(
+                "Command %s had error code %s"
+def create_environment(home_dir, site_packages=True, clear=False,
+                       unzip_setuptools=False, use_distribute=False,
+                       prompt=None):
+    Creates a new environment in ``home_dir``.
+    If ``site_packages`` is true (the default) then the global
+    ``site-packages/`` directory will be on the path.
+    If ``clear`` is true (default False) then the environment will
+    first be cleared.
+    home_dir, lib_dir, inc_dir, bin_dir = path_locations(home_dir)
+    py_executable = os.path.abspath(install_python(
+        home_dir, lib_dir, inc_dir, bin_dir,
+        site_packages=site_packages, clear=clear))
+    install_distutils(home_dir)
+    if use_distribute or os.environ.get('VIRTUALENV_USE_DISTRIBUTE'):
+        install_distribute(py_executable, unzip=unzip_setuptools)
+    else:
+        install_setuptools(py_executable, unzip=unzip_setuptools)
+    install_pip(py_executable)
+    install_activate(home_dir, bin_dir, prompt)
+def path_locations(home_dir):
+    """Return the path locations for the environment (where libraries are,
+    where scripts go, etc)"""
+    # XXX: We'd use distutils.sysconfig.get_python_inc/lib but its
+    # prefix arg is broken: http://bugs.python.org/issue3386
+        # Windows has lots of problems with executables with spaces in
+        # the name; this function will remove them (using the ~1
+        # format):
+        mkdir(home_dir)
+        if ' ' in home_dir:
+            try:
+                import win32api
+                print 'Error: the path "%s" has a space in it' % home_dir
+                print 'To handle these kinds of paths, the win32api module must be installed:'
+                print '  http://sourceforge.net/projects/pywin32/'
+                sys.exit(3)
+            home_dir = win32api.GetShortPathName(home_dir)
+        lib_dir = join(home_dir, 'Lib')
+        inc_dir = join(home_dir, 'Include')
+        bin_dir = join(home_dir, 'Scripts')
+    elif is_jython:
+        bin_dir = join(home_dir, 'bin')
+    elif is_pypy:
+        lib_dir = home_dir
+        inc_dir = join(home_dir, 'include')
+    else:
+        lib_dir = join(home_dir, 'lib', py_version)
+        inc_dir = join(home_dir, 'include', py_version)
+    return home_dir, lib_dir, inc_dir, bin_dir
+def change_prefix(filename, dst_prefix):
+    prefixes = [sys.prefix]
+    if hasattr(sys, 'real_prefix'):
+        prefixes.append(sys.real_prefix)
+    prefixes = map(os.path.abspath, prefixes)
+    filename = os.path.abspath(filename)
+    for src_prefix in prefixes:
+        if filename.startswith(src_prefix):
+            _, relpath = filename.split(src_prefix, 1)
+            assert relpath[0] == os.sep
+            relpath = relpath[1:]
+            return join(dst_prefix, relpath)
+    assert False, "Filename %s does not start with any of these prefixes: %s" % \
+        (filename, prefixes)
+def copy_required_modules(dst_prefix):
+    import imp
+    for modname in REQUIRED_MODULES:
+        if modname in sys.builtin_module_names:
+            logger.info("Ignoring built-in bootstrap module: %s" % modname)
+            continue
+        try:
+            f, filename, _ = imp.find_module(modname)
+            logger.info("Cannot import bootstrap module: %s" % modname)
+        else:
+            if f is not None:
+                f.close()
+            dst_filename = change_prefix(filename, dst_prefix)
+            copyfile(filename, dst_filename)
+            if filename.endswith('.pyc'):
+                pyfile = filename[:-1]
+                if os.path.exists(pyfile):
+                    copyfile(pyfile, dst_filename[:-1])
+def install_python(home_dir, lib_dir, inc_dir, bin_dir, site_packages, clear):
+    """Install just the base environment, no distutils patches etc"""
+    if sys.executable.startswith(bin_dir):
+        print 'Please use the *system* python to run this script'
+        return
+    if clear:
+        rmtree(lib_dir)
+        ## FIXME: why not delete it?
+        ## Maybe it should delete everything with #!/path/to/venv/python in it
+        logger.notify('Not deleting %s', bin_dir)
+        logger.notify('Using real prefix %r' % sys.real_prefix)
+        prefix = sys.real_prefix
+    else:
+        prefix = sys.prefix
+    mkdir(lib_dir)
+    fix_lib64(lib_dir)
+    stdlib_dirs = [os.path.dirname(os.__file__)]
+        stdlib_dirs.append(join(os.path.dirname(stdlib_dirs[0]), 'DLLs'))
+    elif sys.platform == 'darwin':
+        stdlib_dirs.append(join(stdlib_dirs[0], 'site-packages'))
+    if hasattr(os, 'symlink'):
+        logger.info('Symlinking Python bootstrap modules')
+    else:
+        logger.info('Copying Python bootstrap modules')
+    try:
+        # copy required files...
+        for stdlib_dir in stdlib_dirs:
+            if not os.path.isdir(stdlib_dir):
+                continue
+            for fn in os.listdir(stdlib_dir):
+                if fn != 'site-packages' and os.path.splitext(fn)[0] in REQUIRED_FILES:
+                    copyfile(join(stdlib_dir, fn), join(lib_dir, fn))
+        # ...and modules
+        copy_required_modules(home_dir)
+    finally:
+    mkdir(join(lib_dir, 'site-packages'))
+    import site
+    site_filename = site.__file__
+    if site_filename.endswith('.pyc'):
+        site_filename = site_filename[:-1]
+    elif site_filename.endswith('$py.class'):
+        site_filename = site_filename.replace('$py.class', '.py')
+    site_filename_dst = change_prefix(site_filename, home_dir)
+    site_dir = os.path.dirname(site_filename_dst)
+    writefile(site_filename_dst, SITE_PY)
+    writefile(join(site_dir, 'orig-prefix.txt'), prefix)
+    site_packages_filename = join(site_dir, 'no-global-site-packages.txt')
+    if not site_packages:
+        writefile(site_packages_filename, '')
+    else:
+        if os.path.exists(site_packages_filename):
+            logger.info('Deleting %s' % site_packages_filename)
+            os.unlink(site_packages_filename)
+    if is_pypy:
+        stdinc_dir = join(prefix, 'include')
+    else:
+        stdinc_dir = join(prefix, 'include', py_version)
+    if os.path.exists(stdinc_dir):
+        copyfile(stdinc_dir, inc_dir)
+    else:
+        logger.debug('No include dir %s' % stdinc_dir)
+    if sys.exec_prefix != prefix:
+            exec_dir = join(sys.exec_prefix, 'lib')
+        elif is_jython:
+            exec_dir = join(sys.exec_prefix, 'Lib')
+        else:
+            exec_dir = join(sys.exec_prefix, 'lib', py_version)
+        for fn in os.listdir(exec_dir):
+            copyfile(join(exec_dir, fn), join(lib_dir, fn))
+    if is_jython:
+        # Jython has either jython-dev.jar and javalib/ dir, or just
+        # jython.jar
+        for name in 'jython-dev.jar', 'javalib', 'jython.jar':
+            src = join(prefix, name)
+            if os.path.exists(src):
+                copyfile(src, join(home_dir, name))
+        # XXX: registry should always exist after Jython 2.5rc1
+        src = join(prefix, 'registry')
+            copyfile(src, join(home_dir, 'registry'), symlink=False)
+        copyfile(join(prefix, 'cachedir'), join(home_dir, 'cachedir'),
+                 symlink=False)
+    mkdir(bin_dir)
+    py_executable = join(bin_dir, os.path.basename(sys.executable))
+    if 'Python.framework' in prefix:
+        if re.search(r'/Python(?:-32|-64)*$', py_executable):
+            # The name of the python executable is not quite what
+            # we want, rename it.
+            py_executable = os.path.join(
+                    os.path.dirname(py_executable), 'python')
+    logger.notify('New %s executable in %s', expected_exe, py_executable)
+    if sys.executable != py_executable:
+        ## FIXME: could I just hard link?
+        executable = sys.executable
+        if sys.platform == 'cygwin' and os.path.exists(executable + '.exe'):
+            # Cygwin misreports sys.executable sometimes
+            executable += '.exe'
+            py_executable += '.exe'
+            logger.info('Executable actually exists in %s' % executable)
+        shutil.copyfile(executable, py_executable)
+        make_exe(py_executable)
+        if sys.platform == 'win32' or sys.platform == 'cygwin':
+            pythonw = os.path.join(os.path.dirname(sys.executable), 'pythonw.exe')
+            if os.path.exists(pythonw):
+                logger.info('Also created pythonw.exe')
+                shutil.copyfile(pythonw, os.path.join(os.path.dirname(py_executable), 'pythonw.exe'))
+        if is_pypy:
+            # make a symlink python --> pypy-c
+            python_executable = os.path.join(os.path.dirname(py_executable), 'python')
+            logger.info('Also created executable %s' % python_executable)
+            copyfile(py_executable, python_executable)
+    if os.path.splitext(os.path.basename(py_executable))[0] != expected_exe:
+        secondary_exe = os.path.join(os.path.dirname(py_executable),
+                                     expected_exe)
+        py_executable_ext = os.path.splitext(py_executable)[1]
+        if py_executable_ext == '.exe':
+            # python2.4 gives an extension of '.4' :P
+            secondary_exe += py_executable_ext
+        if os.path.exists(secondary_exe):
+            logger.warn('Not overwriting existing %s script %s (you must use %s)'
+                        % (expected_exe, secondary_exe, py_executable))
+        else:
+            logger.notify('Also creating executable in %s' % secondary_exe)
+            shutil.copyfile(sys.executable, secondary_exe)
+            make_exe(secondary_exe)
+        logger.debug('MacOSX Python framework detected')
+        # Make sure we use the the embedded interpreter inside
+        # the framework, even if sys.executable points to
+        # the stub executable in ${sys.prefix}/bin
+        # See http://groups.google.com/group/python-virtualenv/
+        #                              browse_thread/thread/17cab2f85da75951
+        original_python = os.path.join(
+            prefix, 'Resources/Python.app/Contents/MacOS/Python')
+        shutil.copy(original_python, py_executable)
+        # Copy the framework's dylib into the virtual
+        # environment
+        virtual_lib = os.path.join(home_dir, '.Python')
+        if os.path.exists(virtual_lib):
+            os.unlink(virtual_lib)
+        copyfile(
+            os.path.join(prefix, 'Python'),
+            virtual_lib)
+        # And then change the install_name of the copied python executable
+        try:
+            call_subprocess(
+                ["install_name_tool", "-change",
+                 '@executable_path/../.Python',
+                 py_executable])
+        except:
+            logger.fatal(
+                "Could not call install_name_tool -- you must have Apple's development tools installed")
+            raise
+        # Some tools depend on pythonX.Y being present
+        py_executable_version = '%s.%s' % (
+            sys.version_info[0], sys.version_info[1])
+        if not py_executable.endswith(py_executable_version):
+            # symlinking pythonX.Y > python
+            pth = py_executable + '%s.%s' % (
+            if os.path.exists(pth):
+                os.unlink(pth)
+            os.symlink('python', pth)
+        else:
+            # reverse symlinking python -> pythonX.Y (with --python)
+            pth = join(bin_dir, 'python')
+                os.unlink(pth)
+            os.symlink(os.path.basename(py_executable), pth)
+    if sys.platform == 'win32' and ' ' in py_executable:
+        # There's a bug with subprocess on Windows when using a first
+        # argument that has a space in it.  Instead we have to quote
+        # the value:
+        py_executable = '"%s"' % py_executable
+    cmd = [py_executable, '-c', 'import sys; print sys.prefix']
+    logger.info('Testing executable with %s %s "%s"' % tuple(cmd))
+    proc = subprocess.Popen(cmd,
+                            stdout=subprocess.PIPE)
+    proc_stdout, proc_stderr = proc.communicate()
+    proc_stdout = os.path.normcase(os.path.abspath(proc_stdout.strip()))
+    if proc_stdout != os.path.normcase(os.path.abspath(home_dir)):
+        logger.fatal(
+            'ERROR: The executable %s is not functioning' % py_executable)
+        logger.fatal(
+            'ERROR: It thinks sys.prefix is %r (should be %r)'
+            % (proc_stdout, os.path.normcase(os.path.abspath(home_dir))))
+        logger.fatal(
+            'ERROR: virtualenv is not compatible with this system or executable')
+            logger.fatal(
+                'Note: some Windows users have reported this error when they installed Python for "Only this user".  The problem may be resolvable if you install Python "For all users".  (See https://bugs.launchpad.net/virtualenv/+bug/352844)')
+        sys.exit(100)
+    else:
+        logger.info('Got sys.prefix result: %r' % proc_stdout)
+    pydistutils = os.path.expanduser('~/.pydistutils.cfg')
+    if os.path.exists(pydistutils):
+        logger.notify('Please make sure you remove any previous custom paths from '
+                      'your %s file.' % pydistutils)
+    ## FIXME: really this should be calculated earlier
+    return py_executable
+def install_activate(home_dir, bin_dir, prompt=None):
+    if sys.platform == 'win32' or is_jython and os._name == 'nt':
+        files = {'activate.bat': ACTIVATE_BAT,
+                 'deactivate.bat': DEACTIVATE_BAT}
+        if os.environ.get('OS') == 'Windows_NT' and os.environ.get('OSTYPE') == 'cygwin':
+            files['activate'] = ACTIVATE_SH
+    else:
+        files = {'activate': ACTIVATE_SH}
+        # suppling activate.fish in addition to, not instead of, the
+        # bash script support.
+        files['activate.fish'] = ACTIVATE_FISH
+        # same for csh/tcsh support...
+        files['activate.csh'] = ACTIVATE_CSH
+    files['activate_this.py'] = ACTIVATE_THIS
+    vname = os.path.basename(os.path.abspath(home_dir))
+    for name, content in files.items():
+        content = content.replace('__VIRTUAL_PROMPT__', prompt or '')
+        content = content.replace('__VIRTUAL_WINPROMPT__', prompt or '(%s)' % vname)
+        content = content.replace('__VIRTUAL_ENV__', os.path.abspath(home_dir))
+        content = content.replace('__VIRTUAL_NAME__', vname)
+        content = content.replace('__BIN_NAME__', os.path.basename(bin_dir))
+        writefile(os.path.join(bin_dir, name), content)
+def install_distutils(home_dir):
+    distutils_path = change_prefix(distutils.__path__[0], home_dir)
+    mkdir(distutils_path)
+    ## FIXME: maybe this prefix setting should only be put in place if
+    ## there's a local distutils.cfg with a prefix setting?
+    home_dir = os.path.abspath(home_dir)
+    ## FIXME: this is breaking things, removing for now:
+    #distutils_cfg = DISTUTILS_CFG + "\n[install]\nprefix=%s\n" % home_dir
+    writefile(os.path.join(distutils_path, '__init__.py'), DISTUTILS_INIT)
+    writefile(os.path.join(distutils_path, 'distutils.cfg'), DISTUTILS_CFG, overwrite=False)
+def fix_lib64(lib_dir):
+    Some platforms (particularly Gentoo on x64) put things in lib64/pythonX.Y
+    instead of lib/pythonX.Y.  If this is such a platform we'll just create a
+    symlink so lib64 points to lib
+    if [p for p in distutils.sysconfig.get_config_vars().values()
+        if isinstance(p, basestring) and 'lib64' in p]:
+        logger.debug('This system uses lib64; symlinking lib64 to lib')
+        assert os.path.basename(lib_dir) == 'python%s' % sys.version[:3], (
+            "Unexpected python lib dir: %r" % lib_dir)
+        lib_parent = os.path.dirname(lib_dir)
+        assert os.path.basename(lib_parent) == 'lib', (
+            "Unexpected parent dir: %r" % lib_parent)
+        copyfile(lib_parent, os.path.join(os.path.dirname(lib_parent), 'lib64'))
+def resolve_interpreter(exe):
+    If the executable given isn't an absolute path, search $PATH for the interpreter
+    if os.path.abspath(exe) != exe:
+        paths = os.environ.get('PATH', '').split(os.pathsep)
+        for path in paths:
+            if os.path.exists(os.path.join(path, exe)):
+                exe = os.path.join(path, exe)
+                break
+    if not os.path.exists(exe):
+        logger.fatal('The executable %s (from --python=%s) does not exist' % (exe, exe))
+        sys.exit(3)
+    return exe
+## Relocating the environment:
+def make_environment_relocatable(home_dir):
+    Makes the already-existing environment use relative paths, and takes out
+    the #!-based environment selection in scripts.
+    activate_this = os.path.join(bin_dir, 'activate_this.py')
+    if not os.path.exists(activate_this):
+        logger.fatal(
+            'The environment doesn\'t have a file %s -- please re-run virtualenv '
+            'on this environment to update it' % activate_this)
+    fixup_scripts(home_dir)
+    fixup_pth_and_egg_link(home_dir)
+    ## FIXME: need to fix up distutils.cfg
+OK_ABS_SCRIPTS = ['python', 'python%s' % sys.version[:3],
+                  'activate', 'activate.bat', 'activate_this.py']
+def fixup_scripts(home_dir):
+    # This is what we expect at the top of scripts:
+    shebang = '#!%s/bin/python' % os.path.normcase(os.path.abspath(home_dir))
+    # This is what we'll put:
+    new_shebang = '#!/usr/bin/env python%s' % sys.version[:3]
+    activate = "import os; activate_this=os.path.join(os.path.dirname(__file__), 'activate_this.py'); execfile(activate_this, dict(__file__=activate_this)); del os, activate_this"
+        bin_suffix = 'Scripts'
+    else:
+        bin_suffix = 'bin'
+    bin_dir = os.path.join(home_dir, bin_suffix)
+    for filename in os.listdir(bin_dir):
+        filename = os.path.join(bin_dir, filename)
+        if not os.path.isfile(filename):
+            # ignore subdirs, e.g. .svn ones.
+            continue
+        f = open(filename, 'rb')
+        lines = f.readlines()
+        f.close()
+        if not lines:
+            logger.warn('Script %s is an empty file' % filename)
+            continue
+        if not lines[0].strip().startswith(shebang):
+            if os.path.basename(filename) in OK_ABS_SCRIPTS:
+                logger.debug('Cannot make script %s relative' % filename)
+            elif lines[0].strip() == new_shebang:
+                logger.info('Script %s has already been made relative' % filename)
+            else:
+                logger.warn('Script %s cannot be made relative (it\'s not a normal script that starts with %s)'
+                            % (filename, shebang))
+            continue
+        logger.notify('Making script %s relative' % filename)
+        lines = [new_shebang+'\n', activate+'\n'] + lines[1:]
+        f = open(filename, 'wb')
+        f.writelines(lines)
+        f.close()
+def fixup_pth_and_egg_link(home_dir, sys_path=None):
+    """Makes .pth and .egg-link files use relative paths"""
+    home_dir = os.path.normcase(os.path.abspath(home_dir))
+    if sys_path is None:
+        sys_path = sys.path
+    for path in sys_path:
+        if not path:
+            path = '.'
+        if not os.path.isdir(path):
+            continue
+        path = os.path.normcase(os.path.abspath(path))
+        if not path.startswith(home_dir):
+            logger.debug('Skipping system (non-environment) directory %s' % path)
+            continue
+        for filename in os.listdir(path):
+            filename = os.path.join(path, filename)
+            if filename.endswith('.pth'):
+                if not os.access(filename, os.W_OK):
+                    logger.warn('Cannot write .pth file %s, skipping' % filename)
+                else:
+                    fixup_pth_file(filename)
+            if filename.endswith('.egg-link'):
+                    logger.warn('Cannot write .egg-link file %s, skipping' % filename)
+                else:
+                    fixup_egg_link(filename)
+def fixup_pth_file(filename):
+    lines = []
+    prev_lines = []
+    f = open(filename)
+    prev_lines = f.readlines()
+    f.close()
+    for line in prev_lines:
+        line = line.strip()
+        if (not line or line.startswith('#') or line.startswith('import ')
+            or os.path.abspath(line) != line):
+            lines.append(line)
+        else:
+            new_value = make_relative_path(filename, line)
+            if line != new_value:
+                logger.debug('Rewriting path %s as %s (in %s)' % (line, new_value, filename))
+            lines.append(new_value)
+    if lines == prev_lines:
+        logger.info('No changes to .pth file %s' % filename)
+        return
+    logger.notify('Making paths in .pth file %s relative' % filename)
+    f = open(filename, 'w')
+    f.write('\n'.join(lines) + '\n')
+    f.close()
+def fixup_egg_link(filename):
+    link = f.read().strip()
+    f.close()
+    if os.path.abspath(link) != link:
+        logger.debug('Link in %s already relative' % filename)
+        return
+    new_link = make_relative_path(filename, link)
+    logger.notify('Rewriting link %s in %s as %s' % (link, filename, new_link))
+    f.write(new_link)
+    f.close()
+def make_relative_path(source, dest, dest_is_directory=True):
+    Make a filename relative, where the filename is dest, and it is
+    being referred to from the filename source.
+        >>> make_relative_path('/usr/share/something/a-file.pth',
+        ...                    '/usr/share/another-place/src/Directory')
+        '../another-place/src/Directory'
+        ...                    '/home/user/src/Directory')
+        '../../../home/user/src/Directory'
+        >>> make_relative_path('/usr/share/a-file.pth', '/usr/share/')
+    source = os.path.dirname(source)
+    if not dest_is_directory:
+        dest_filename = os.path.basename(dest)
+        dest = os.path.dirname(dest)
+    dest = os.path.normpath(os.path.abspath(dest))
+    source = os.path.normpath(os.path.abspath(source))
+    dest_parts = dest.strip(os.path.sep).split(os.path.sep)
+    source_parts = source.strip(os.path.sep).split(os.path.sep)
+    while dest_parts and source_parts and dest_parts[0] == source_parts[0]:
+        dest_parts.pop(0)
+        source_parts.pop(0)
+    full_parts = ['..']*len(source_parts) + dest_parts
+        full_parts.append(dest_filename)
+    if not full_parts:
+        # Special case for the current directory (otherwise it'd be '')
+        return './'
+    return os.path.sep.join(full_parts)
+## Bootstrap script creation:
+def create_bootstrap_script(extra_text, python_version=''):
+    Creates a bootstrap script, which is like this script but with
+    extend_parser, adjust_options, and after_install hooks.
+    This returns a string that (written to disk of course) can be used
+    as a bootstrap script with your own customizations.  The script
+    will be the standard virtualenv.py script, with your extra text
+    added (your extra text should be Python code).
+    If you include these functions, they will be called:
+    ``extend_parser(optparse_parser)``:
+        You can add or remove options from the parser here.
+    ``adjust_options(options, args)``:
+        You can change options here, or change the args (if you accept
+        different kinds of arguments, be sure you modify ``args`` so it is
+        only ``[DEST_DIR]``).
+    ``after_install(options, home_dir)``:
+        After everything is installed, this function is called.  This
+        is probably the function you are most likely to use.  An
+        example would be::
+            def after_install(options, home_dir):
+                subprocess.call([join(home_dir, 'bin', 'easy_install'),
+                                 'MyPackage'])
+                subprocess.call([join(home_dir, 'bin', 'my-package-script'),
+                                 'setup', home_dir])
+        This example immediately installs a package, and runs a setup
+        script from that package.
+    If you provide something like ``python_version='2.4'`` then the
+    script will start with ``#!/usr/bin/env python2.4`` instead of
+    ``#!/usr/bin/env python``.  You can use this when the script must
+    be run with a particular Python version.
+    filename = __file__
+        filename = filename[:-1]
+    content = f.read()
+    f.close()
+    py_exe = 'python%s' % python_version
+    content = (('#!/usr/bin/env %s\n' % py_exe)
+               + '## WARNING: This file is generated\n'
+               + content)
+    return content.replace('##EXT' 'END##', extra_text)
+##EXTEND##
+##file site.py
+SITE_PY = """
+eJzVPP1z2zaWv/OvQOXJUEplOh/dzo5T98ZJnNZ7buJt0mluXY+WkiCJNUWyBGlZe3P3t9/7AECA
+pGS77f5wmkwskcDDw8P7xgMGg8FpUchsLtb5vE6lUDIuZytRxNVKiUVeimqVlPPDIi6rLTyd3cRL
+qUSVC7VVEbaKguDpH/wET8WnVaIMCvAtrqt8HVfJLE7TrUjWRV5Wci7mdZlkS5FkSZXEafIvaJFn
+kXj6xzEIzjMBM08TWYpbWSqAq0S+EJfbapVnYlgXOOfn0V/il6OxULMyKSpoUGqcgSKruAoyKeeA
+JrSsFZAyqeShKuQsWSQz23CT1+lcFGk8k+Kf/+SpUdMwDFS+lpuVLKXIABmAKQFWgXjA16QUs3wu
+IyFey1mMA/DzhlgBQxvjmikkY5aLNM+WMKdMzqRScbkVw2ldESBCWcxzwCkBDKokTYNNXt6oESwp
+rccGHomY2cOfDLMHzBPH73IO4PghC37KkrsxwwbuQXDVitmmlIvkTsQIFn7KOzmb6GfDZCHmyWIB
+NMiqETYJGAEl0mR6VNByfKNX6NsjwspyZQxjSESZG/NL6hEF55WIUwVsWxdII0WYv5XTJM6AGtkt
+DAcQgaRB3zjzRFV2HJqdyAFAietYgZSslRiu4yQDZv0hnhHaPyfZPN+oEVEAVkuJX2tVufMf9hAA
+WjsEGAe4WGY16yxNbmS6HQECnwD7Uqo6rVAg5kkpZ1VeJlIRAEBtK+QdID0WcSk1CZkzjdyOif5E
+kyTDhUUBQ4HHl0iSRbKsS5IwsUiAc4Er3n34Ubw9e31++l7zmAHGMrtcA84AhRbawQkGEEe1Ko/S
+HAQ6Ci7wj4jncxSyJY4PeDUNju5d6WAIcy+idh9nwYHsenH1MDDHCpQJjRVQv/+GLmO1Avr8zz3r
+HQSnu6hCE+dvm1UOMpnFaylWMfMXckbwjYbzbVRUq1fADQrhVEAqhYuDCCYID0ji0myYZ1IUwGJp
+kslRABSaUlt/FYEV3ufZIa11ixMAQhlk8NJ5NqIRMwkT7cJ6hfrCNN7SzHSTwK7zOi9JcQD/ZzPS
+RWmc3RCOihiKv03lMskyRAh5IQgPQhpY3STAifNIXFAr0gumkQhZe3FLFIkaeAmZDnhS3sXrIpVj
+Fl/UrfvVCA0mK2HWOmWOg5YVqVdatWaqvbz3Ivrc4jpCs1qVEoDXU0/oFnk+FlPQ2YRNEa9ZvKpN
+TpwT9MgTdUKeoJbQF78DRU+VqtfSvkReAc1CDBUs8jTNN0Cy4yAQ4gAbGaPsMye8hXfwP8DF/1NZ
+zVZB4IxkAWtQiPwuUAgETILMNFdrJDxu06zcVjJJxpoiL+eypKEeRuwjRvyBjXGuwfu80kaNp4ur
+nK+TClXSVJvMhC1eFlasH1/xvGEaYLkV0cw0bei0xumlxSqeSuOSTOUCJUEv0iu77DBm0DMm2eJK
+rNnKwDsgi0zYgvQrFlQ6i0qSEwAwWPjiLCnqlBopZDARw0DrguCvYzTpuXaWgL3ZLAeokNh8z8D+
+AG7/AjHarBKgzwwggIZBLQXLN02qEh2ERh8FvtE3/Xl84NTzhbZNPOQiTlJt5eMsOKeHZ2VJ4juT
+BfYaa2IomGFWoWu3zICOKOaDwSAIjDu0VeZrbr9NJtM6QXs3mQRVuT0G7hAo5AFDF+9hojQcv1mU
++RpfW/Q+gj4AvYw9ggNxSYpCso/rMdMrpICrlQvTFM2vw5ECVUlw+ePZu/PPZx/FibhqtNK4rZKu
+YcyzLAbOJKUOfNEatlFH0BJ1V4LqS7wDC03rCiaJepMEyriqgf0A9U9lTa9hGjPvZXD2/vT1xdnk
+p49nP04+nn86AwTBVMjggKaMFq4Gn09FwN/AWHMVaRMZdHrQg9enH+2DYJKoSbEttvAAbB1wYTmE
++Y5FiA8n2oxOkmyRhyNq/Cv70SesGbTTdHX81bU4ORHhr/FtHAbguDRNeRF/IB7+tC0kdK3gzzBX
+oyCYywXw+41EqRg+JWd0xB2AiNAy18bx1zzJzHt67Q1BQjukHoDDZDJLY6Ww8WQSAmmpQ88HOkTs
+0SKrD6FjsXW7jjQq+CklLEWGXcb4Xw+K8ZT6IRqMotvFNAIZWc9iJbkVTR/6TSaoKCaToR4QJIh4
+HLwclv1QmCaoKMoEnEniFVQcU5Wn+BPho+iRyGA8g6oJF0nHK9FtnNZSDZ1JARGHwxYZUbslijgI
+/IIhmL9m6UajNjUNz0AzIF+ag+oqW5TDzwE4GaAjTOSE0RUHPEwzxPRv7N4TDuDnhahjlWpBYZUk
+Ls8uxctnLw7Rh4BAb26p4zVHs5hktbQPF7BaS1k5CHOvcEzCMHLpskDlhk+P98NcR3Zluqyw0Etc
+ynV+K+eALTKws8riR3oD4TDMYxbDKoIyJSPMSs84azEGfzx7kBY02EC9NUEx62+W/oAjcJkpUB0c
+zRKpdajN9qco89sELfx0q1+CgQL1hmbKeBOBs3Aek6EdAg0BrmeGlNrIEBRYWbOXSHgjSFTx80YV
+RgTuAnXrNX29yfJNNuHw8wTV5HBkWRcFSzMvNmiW4EC8A8MBSOYQTTVEYyjgZwuUrUNAHqYP0wXK
+kkMPgMC6KoqRHFgmvqIpcqiGwyKM0StBwltKNNK3ZgiKbwwxHEj0NrIPjJZASDA5q+CsatBMhrJm
+msHADkl8rruIOO7zAbSoGIGhG2po3MjQ7+oYlLO4cJWS0w9t6OfPn5lt1IqSGojYFCeNdntB5i0q
+tmAKE9AJxg3iFAmxwQY8SgBTK82a4vCjyAt2gWA9L7Vsg+WGkKqqiuOjo81mE+mQPi+XR2px9Je/
+fv31X5+xTpzPiX9gOo606PxWdETv0I2MvjEW6Fuzci1+TDKfGwnWUJIrRP4f4vddncxzcXw4svoT
+ubgxrPi/cT5AgUzMoExloO2gweiJOnwSvVQD8UQM3bbDEXsS2qRaK+ZbXehR5WC7wdOY5XVWhY4i
+VeJLsG4QFs/ltF6GdnDPRpofMFWU06HlgcPn14iBzxmGr4wpnqCWILZAi++Q/kdmm5j8Ga0hkLxo
+ojoh67Zfixnizh8u79Y7dITGzDBRyB0oEX6TBwugbdyVHPxoZxTtnuOMmo9nCIylDwzzaldwiIJD
+uOBajF2pc7gafVSQpg2rZlAwrmoEBQ1u3ZSprcGRjQwRJHo3JsLmhdUtgE6tdJ0Jys0qQAt3nI61
+a7OC4wkhD5yI5/REglN73Hn3jJe2TlPKorR41KMKA/YWGu10Dnw5NADGYlD+NOCWelnOP7QWhdeg
+B1jOiRdksEWHmfCN6wMODgY97NSx+rt6M437QOAiUfuHASeMT3iAUoEwFUOfcXdxuKUtJ5taCO82
+OMRTZpVIotUO2Wrrjl6Z2muXFkmGqtdZo2iW5uAUW6VIfNS8930FClzwcZ8t0wKoydCQw2l0Qs6e
+J3+hbocpq2WNwb2b+0CM1oki44ZkWsF/4FVQToESQEBLgmbBPFTI/In9CSJn56u/7GAPS2hkCLfp
+Li+kYzA0HPP+QCAZdQYEhCADEnZlkTxH1gYpcJizQJ5sw2u5U7gJRqRAzBwDQloGcKeXXnyDTyLc
+dSABRch3lZKF+FIMYPnakvow1f2ncqnJGgydBuQp6HTDiZuKcNIQJ620hM/QfkKC9ieKHDh4Ch6P
+m1x32dwwrc2SgK/u622LFChkSpwMRi6q14YwbgL3ixOnRUMsM4hhKG8gbxvFjDQK7HJr0LDgBoy3
+5u2x9GM3YYF9h2GuXsj1HYR/YZmoWa5CjG87qQv3o7miSxuL7UUyHcAfbwEGo2sPkkx1+gKTLL9j
+kNCDHvZB9yaLWZF5XG6SLCQFpul34i9NBw9LSs/GHX2kaOoIJopZxqN3JQgIbTcegTihJoCgXIZK
+e/1dsHunOLBwufvA85qvjl9ed4k73pXgsZ/+pTq7q8pY4WqlvGgsFLhaXfuNShcmF2dbvWGoN5Qx
+SihzBUGk+PDxs0BCcC51E28fN/WG4RGbe+fkfQzqoNfuJVdrdsQugAhqRWSUo/DxHPlwZB87uT0T
+ewSQRzHMnkUxkDSf/B44+xYKxjicbzNMo7VVBn7g9ddfTXoSoy6SX381uGeUFjH6xH7Y8gTtyLSR
+L3qnbbqUMk7J13A6UVIxa3jHtilGrNAp/NNMdt3jdOLHvDcmo4Hfad6JG83ngOgBUXY+/RViVaXT
+W7dxklJOHtA4PEQ9Z8Jszhz04+NB2o8ypqTAY3k27o2E1NUzWJiQ4/pRdzraLzo1qd+eeNR8ilh1
+UTnQW+jNDpC3Le7u/u2W/V5L/W/SWY8E5M1m0EPAB87B7E7+/58JKyuGppXVqKX1ldyv5w2wB6jD
+HW7OHjekOzRvZi2MM8Fyp8RTFNCnYkNb0pTKw40JgDJnP6MHDi6j3th8U5clb0+SnBeyPMT9urHA
+ahzjaVCRTxfM0XtZISa22YxSo07tRt6nOkOd7LQzCRs/tV9kV7lJkcjsNimhL2iVYfj9hx/Owi4D
+6GGwUz84dx0NlzzcTiHcRzBtqIkTPqYPU+gxXX6/VLVdZZ+gZsvYJCA12bqE7eQdTdzavwb3ZCC8
+/UHeh8WIcLaSs5uJpL1lZFPs6uRg3+BrxMRuOfs1PipeUKESzGSW1kgrdvSwwmxRZzNKx1cS7Lku
+B8XyENox5nTTIo2XYkid55jq0NxI2ZDbuNTeTlHmWIAo6mR+tEzmQv5WxymGkXKxAFxwr0S/inh4
+yniIt7zpzYVpSs7qMqm2QIJY5XqrifbHnYbTLU906CHJuwpMQNwxPxYfcdr4ngk3N+QywaifYMdJ
+YpyHHcxeIHIXPYf3WT7BUSdUxzlmpLrbwPQ4aI+QA4ABAIX5D0Y6U+S/kfTK3c+iNXeJilrSI6Ub
+2ebkcSCU4Qgja/5NP31GdHlrB5bL3Vgu92O5bGO57MVy6WO53I+lKxK4sDZJYiShL1HSzqL3FmS4
+OQ4e5iyerbgd1vdhHR9AFIUJ6IxMcZmrl0nh7SQCQmrb2d+kh02BRcKFg2XOKVcNErkf90x08GgK
+lJ3OVK6hO/NUjM+2q8jE73sURVQONKXuLG/zuIojTy6WaT4FsbXojhsAY9GuN+HcXHY7mXI2sWWp
+Bpf/9en7D++xOYIamN106oaLiIYFpzJ8GpdL1ZWmJtgogB2ppV/3Qd00wIMHZnJ4lAP+7y0VFCDj
+iA1tiOeiAA+Ayn5sM7c4Jgxbz3UVjX7OTM57GydikFWDZlI7iHR6efn29NPpgFJMg/8duAJjaOtL
+h4uPaWEbdP03t7mlOPYBoda5lMb4uXPyaN1wxP021oBtub3PrlsPXjzEYPeGpf4s/62UgiUBQkU6
+2fgYQj04+PlDYUKHPoYRO9Vh7k4OOyv2nSN7joviiH5fmrs9gL+3hjHGBAigXaihiQyaYKql9K15
+3UNRB+gDfb0/HIK1Q692JONT1E6ixwF0KGub7Xb/vH0BNnpKVq/Pvjt/f3H++vL00/eOC4iu3IeP
+Ry/E2Q+fBZUjoAFjnyjGnfgKC1/AsLiHWcQ8h381pjfmdcVJSej19uJC7wys8TgD1reizYngOVfN
+WGico+Gsp32oy10Qo1QHSM65EaoOoXMlGC+t+cyCynUNLB1HmaKzWuvQS58HMueGaBs1AumDxi4p
+GARXNMErqlSuTFRY8o6TPkvTg5S20bYOIaUcVGd32tlvMdl8LzFHneFJ01kr+qvQxTW8jlSRJhDJ
+vQqtLOluWI3RMI5+aDdUGa8+Deh0h5F1Q571TizQar0KeW66/6hhtN9qwLBhsLcw70xSNQLV6GIt
+lQixEe8chPIOvtql12ugYMFwY6nCRTRMl8DsYwiuxSqBAAJ4cgXWF+MEgNBaCT8BfexkB2SOxQDh
+m/X88O+hJojf+pdfeppXZXr4D1FAFCS4ciXsIabb+C0EPpGMxNmHd6OQkaNKUPH3GkvAwSGhLJ8j
+7VQuwzu2k6GS6UKXM/j6AF9oP4Fet7qXsih1937XOEQJeKKG5DU8UYZ+IVYXWdhjnMqoBRqr2y1m
+eErM3fY2nwPxcSXTVBdEn7+9OAPfEQvuUYJ4n+cMhuN8CW7Z6lovPsXWAoUbuvC6RDYu0YWlTf15
+5DXrzcyiyFFvrw7ArhNlP7u9OqnOMk6Ui/YQp82wnJLzCLkZlsOsLHN3txnS2W1GdEfJYcaYXJZU
+NelzBnA0PY05MIKICYv6TbKZ9y6TrDJlcmkyA20KihfU6hhEBUmMJ9eI//KM0715qcyBF3hYbMtk
+uaowpQ6dIyq2x+Y/nH6+OH9P1esvXja+dw+LjikeGHPpwgnWpWHOA764tWbIW5NJH+fqVwgDdRD8
+ab/imogTHqDTj9OL+Kf9ik8cnTjxIM8A1FRdtIUEwwCnW5/0NBLBuNpoGD9u3VmDmQ+GMpJ4wEGX
+F7jz6/KjbdkyKJT9MS8fsVexKDQNh6azWwfV/ug5LgrcXJkP+xvB2z4JM58pdL3pvNlVceV+OrKI
+hx8Bo25rfwxTk9RpqqfjMNsubqHgVlvaXzInY+q0m2UoykDEodt55DJZvyrWzZkDvdrdDjDxjUbX
+SGKvQh/8kg20n+FhYondiVZMRzo7QaYA8xlSHxGpwZNCuwAKhEpOh47kjkdPX3hzdGzC/XPUugss
+5PegCHUBKB0syEvgRPjyG7uP/IrQQlV6LELHX8lkltvqJPxsVuhbPvfn2CsDlMpEsSvjbCmHDGts
+YH7pE3tHIpa0rccxV0mrWkJzN3iodzsYvCsW/bsnBrMWH3Ta3chtWxv51MEGvccPfAhlvAHtXtTV
+kNdq52YBNtdbsMMQkyS/hTvodQ96Ghb6Xb/17OHgh4ll3Etrr1pHW0L7QvuVsxICpkrRZoljhY2H
+6BrmxgaeNFZ4YJ/qihH7u+e8kFPl6sJlFFyo3gwHukEr1B/wyRU+uZdQZXRzsEK/m8tbmebgFkHE
+hYXvv9rC91FkUx29NUF/BoKX28ttP3r0pkHu2BTno+OkCljIKJPVEWLUm5C5B7kGH1z2X3TQEGc3
+5Me++fl8LN68/xH+fy0/QOSD59fG4h+AiXiTlxAB8hlKOtyOpf0Vh3Z5rfCQG0GjzQS+BwBdqkuP
+2rhxoc8c+IcNrBYTWGdZrvnyCUCR50jnihsbbirp4bc56tN1Fo0j17c0A/0SybD7AAQeGjjSLaNV
+tU5RnTupjGZNrwYX52/O3n88i6o75Hbzc+CkOvwqHZyR3sgtcdNqLOyTWY1Prh2/9nuZFj1urY4M
+zWEKjAxFCMFDYaNBvtsgthFAXGJ4L4rtPJ9F2BJ4n89vVRvwc0dOEHivHfaMIMIajvRWV+Ns42Og
+hvilrZcG0JD66DlRT0IonuJBIn4cDfot5VhQ/hn+PL3ZzN30tT4RQhNsY9rMeuh3t6pxxXTW8Fxm
+ItRO7EqYc4JpEqv1dOaeH/uQCX07BSg92o+Qi7hOKyEzEGEKxumaAND97pEvlhPmFrY4dA6K0inp
+Jt4qpyImVmKAow7opDNunFBmD2LlH+IbthB4Fk3UfKgVoBOiFOHkTldVz1Ysxxy0EAF7CgQ2Sfby
+RdghMg/KkeyscTVhnujYMUZLWen584Ph6Op5Y+wpezzzDnzOCrCDLqccgA4tnj59OhD/cb9/wqhE
+aZ7fgOMEsPvCVnFBr3d4FnpydrW6vrd5EwFLzlbyCh5cU5bbPq8zSiHu6UoLIu1fAyPEtQktP5r2
+LUvNybWSN4S5BW8saRPyU5bQHTSYApKocvVVPpgeMgJFLAm6IYzVLElCTifAemzzGs9qYTpQ84u8
+A45PEMwY3+JOFgfDK/QBqbDSco9F50QMCPCACp14NDrsSqeVAM/J5VajOTnPkqo5Z/DM3eTUh7or
+e7WM5isRb1AyzDxaxHCO/Xms2vjA+V4W9WKKfHblJgZbs+TX9+EOrA2Sli8WBlN4aBZplstyZowq
+rlgySyoHjGmHcLgz3ahDBigKelAagIYnwzC3Em3ffmHXxcX0A+33HpqRdJlPZW8p4iROnLWq3aKo
+GZ/SRZaQlm/NlxGM8p7Sz9of8MYSX+jkJxaZe5cpuMfd6kxfksB1Fs3NCQCHLuaxCtKyo6cjnNug
+LHxmWh1uNHcqODXxGEQTbrdJWdVxOtEH+SfouU3sBrjG0x6T2nsA0Pos4Pbn4BAf6pJu8B1MNQzS
+EysyTcn+iVjoJELkHj3yT+kUOfp6Lzw9jqnpZ3wRgKPBseWX5vDKQ1S+OULROX3gYjmm2qNw1K6o
+7LTCfQ5TIm+d7HYc8KghW7B8h31WbPFOHpjWk3lE/0LfkaPLFHBj6tGDp8mUBgv7Co/v76srATH+
+W4OgLBI5P3yiEDvG+Y9C1VAMddxA4REzDOnuCQL5ZWsnzykv5NrfXds3HaBff7UPrKuCewufac/E
+V8v6aJtbidxs2uDnwHrEK3C6UW/MzWFkrZb43CbqEDaI9qy5qVdpH5mB1w+f8p4JP2BHNMTBNHe4
+8rqPVha/faRqGgW/i0q6Vz+t0AnGUtFVzG9QmdXFsQ0V+TBfRmn2oVtAhJ/qpre0Psa7j4jRq5tw
+3/S5/7656xaBnbnZP+vM3T9C49JA993NL300YAddE+JBVbkWo8mfI7pjvbXbn6LSn4W9hZEzVcSD
+GrWxZsl1PHO/Y4HBIV/i6B6HClyQZtVbc+qcD2uzc5eTu9zMm6n43J6QpB3yuWYvNud0pc+Ea64m
+crlUkxhvhJqQD0j1AR3jbryKd3QbkIzV1jgDeOcCgDCsoiu53GJNWHXwM/lmSt5edw7XCxqaitCc
+qjaVzDm2154HgIs4pqf+JnPEZWmDVGI2RtVlUYKzNtD3F/K+b1+pXAPUxJfrWN0Y1E2Psb7ODofg
+YgNzhIozCewAetQBQvDJCudmF67znEzsO+CXZ81R0WRsGUJm9VqWcdXckuDvLyXiW2cEOjiHC+xE
+kI3YtTjFRSyx/OEghTGc/f6ldo4832/P+dCRVWkPZyvqoZMTjzl66ki54ebkzt6S5N7OMadrMSle
+5Ns1hG3WcJ+9GQKWwlz5Q4pQh3T8Vl9DwvfTcc4Jq+ocPgK5d4+t+NWNVmexw2DRcJ65iqF77wSe
+fCRD23edVIcLuhdH+czQjO/rDcssnd2EHY0tFU+4Ra/iaUYbNYEOFiLdE+j4xaaPDHQ8+A8MdPTl
+X2BNND5aH/SWn94TEbGacG/SahgB+kyASLhh0rqHydjDoVvMCeFKcjewl1GyznROiBgzgRzZvWKF
+QPCNWcqtfPNutDHj9kUivnTR4+8uPrw+vSBaTC5P3/zn6Xe0zY9ZvZbNenAkmOWHTO1Dr6zQjQr1
+1mzf4A22PVfTcW28htB539nW6oHQfw6ib0Hbisx9vatDp5682wkQ3z/tFtRdKrsXcsf50rXL7oZs
+q/4v0E+5WMv8cvbWzCOTU2ZxaBLG5n2T49My2kmB7Fo4p2yqq060U6ovM9uRnhnZ4j1aAUztIX/Z
+zJ6pxLb5I3ZU2leEU8UhnmIxNwGAFM6kcyEV3UXFoCr/LvISlF2MOxTsMI7tvZ7UjrOYyl5Yi7sU
+MxkZgnjHSAbd+bnCPpfpDioEASs8fd0SI2L0n877272yJ0pcHdKBtUNUNtf2F66ZdnJ/TnBHrLL3
+liiz5Y27AdB4UafuLpft0+lAzh8lTfOFUyENmu8I6NyIpwL2Rp+JFeJ0K0KIEvVWDhZdER31nUMO
+8mg3HewNrZ6Jw13HmdzjPEI8391w3joxpHu84B7qnh6qNodGHAuMdT+7zimJbwkyZ90FXVTiOR+4
+26Ovx4Svt1fPj23KFvkdX7vXYCDtB45hv2pOBuy9GsvpTbxSjqn+A4uNRm3w1wOHNRdid4DTqXPe
+EQSZ7TiGNPDe99dGmB7enb2DNqKW745hQmL4RI1oUk5luMbdPhl1JtuorC4MLnK/H0ZH+wEohNLv
+m+CHb2MB9fxMx4PTmu4TtA4nHg115IEKHXxe4B7G62uwa3eno2kP6k4l//agADdo855ebxBr9hq4
+lZfo2G0L2jNveGCH7edDfv39nz+gf7ckxnZ/sc+htq1e9h4sYScWi6hw87pFIfM4AusCCnNIahrr
+b42E4+H9howONzVTQ65Ah4/qsvCuUAosyImdaMtvjUHwf71Zz9M=
+""".decode("base64").decode("zlib")
+##file ez_setup.py
+EZ_SETUP_PY = """
+eJzNWmuP28YV/a5fwShYSIJlLt8PGXKRJi5gIEiDPAoU9lY7zxVrilRJyhu1yH/vmeFDJLVU2iIf
+ysDZXXJ45z7PuXekL784nqt9ns3m8/kf87wqq4IcjVJUp2OV52lpJFlZkTQlVYJFs/fSOOcn45lk
+lVHlxqkUw7XqaWEcCftEnsSirB+ax/Pa+PuprLCApScujGqflDOZpEK9Uu0hhByEwZNCsCovzsZz
+Uu2NpFobJOMG4Vy/oDZUa6v8aOSy3qmVv9nMZgYuWeQHQ/xzp+8byeGYF5XScnfRUq8b3lquriwr
+xD9OUMcgRnkULJEJMz6LooQT1N6XV9fqd6zi+XOW5oTPDklR5MXayAvtHZIZJK1EkZFKdIsulq71
+pgyreG6UuUHPRnk6HtNzkj3NlLHkeCzyY5Go1/OjCoL2w+Pj2ILHR3M2+0m5SfuV6Y2VRGEUJ/xe
+KlNYkRy1eU1UtZbHp4LwfhxNlQyzxnnluZx98+5PX/387U+7v7z74cf3f/7O2BpzywyYbc+7Rz//
+8K3yq3q0r6rj5v7+eD4mZp1cZl483TdJUd7flff4r9vtfm7cqV3Mxr8fNu7DbHbg/o6TikDgv3TE
+Fpc3XmNzar8+nh3TNcXT02JjLKLIcRiRsWU7vsUjL6JxHNBQOj4LRMDIYn1DitdKoWFMIuJZrvB8
+y5GURr4QrrRjzw5dn9EJKc5QFz/ww9CPeUQCHknmeVZokZhboRM6PI5vS+l08WAAibgdxNyhIghs
+SVyHBMJ3hCcjZ8oid6gLpa7NLMlCN45J4PphHIc+IzyWPrECO7oppdPFjUjEcJcHgnHHcbxQ2mEs
+Q06CIJaETUjxhroEjuX5xPEE94QtKAtDKSw3JsQTgQyFf1PKxS+MOsSOfOgRccKkpA63oY/lUpfa
+zHtZChvlC3WlQ33fjXmAuIYy9AgPY9uBIBJb0YRFbJwvsIcLDk8GIXe4I6WwPcuK3cCTDvEmIs1s
+a6gMgzscQn3uEsvxA88PEB9mu5FlkdCKrdtiOm38kONFxCimkRWGDvNj4rsk8lyX+JxPeqYW47di
+uPACwiL4Mg5ZFPt+6AhfRD7SUdCIhbfFBJ02kUAlESGtAA5ymAg824M0B0bC4RPRBqgMfeNQIghq
+2HY53kcZOZEIKfGpT6ARF7fFXCLFAzeWMbUgzGOe48Wh5XpcMEcwizmTkbKHvgk8FnvSpTIkIbLQ
+FSxyhUUdhDv0YurcFtP5hkoSO7ZlUY4wcdQEJAnOXQQ+8KwomBAzwhlpWYFHZUCIQ0NuQS141kNi
+W5EdMmcqUCOcCezAjh0hmOtLLxSImh0wHhDbgVQnnJIywhlpRwAogC+XSBXi+DGLIUXaPKRhJCfQ
+io1wRliCh14QOSyOIyppCE9HFrLXQsxDeyrY7jBIhAppB5JzGOb7vu1Fns1C4BePozjwp6SM0Ipa
+NLZdmzBCXceCM4BzofQ85gMoQlvelNJZhCSR2DPgnqTSRUVRGXsBs+AqoJ6YShhvaFGk0BrA7zqM
+05iFDmXSA3w5gXQiIqfQyh9aJEQseWRBHRQkMla6ApjuhwAMHtnBVKT9oUVEAqu4BKvYoWULAeeG
+ICefMhAeCaZQxh/FKOKuDAAIHmOERKHtIXG4G1LGuMt9PiElGFqEgonA8pFtB2CiKPJCByLAmL4X
+o7SngDMYsRvzAyL9kMK/6B5QDYEFQzzPRYH5ZAobgqFF1JERCX0HZA/YpS5I2kKoufAlWgnfnZAS
+juDOQoxkTDhzSWD7wrdtH2WIliICBE7mSzhiAhLJ2PfAAhxYbkkahEza0kEY8MiZqoBwaJEHjiXA
+W4mWAQXouZ5t25KLyLXxL5zSJRp1Q5bqhZwYHok5+EOlIAA8ci3VWFm3pXQWMUrcCNiAnsOLXGap
+nEW2wdkMzDJJA9HQIjt07BAgh0DHnNm+5ccW8SPqCtR57E9FOh5aBN2ZZ6GZsZWHqRcHwmOSCiuC
+rcyainQ8QgYkGRo7cKsbRTwAOhEhrADgxQLXm+rvGimdRVIgtK7wiR1S22EIE/M9m4bgXjC/mGKS
+eMhHjKBsbKlQkziCA5js2AWzhdSPHfQ4kPLrrDcRYLwpZ1Vx3tQD156U+zSh7byF3n0mfmECo8Z7
+feedGomatXjYXzfjQhq7zyRN0O2LHW4todMuwzy4NtQAsNpoAxJptPfVzNiOB/VDdfEEs0WFcUGJ
+0C+ae/FLfRfzXbsMcpqVX2w7KR9a0Q8XeerC3IVp8O1bNZ2UFRcF5rrlYIW65sqkxoJmPrzDFEYw
+hvEvDGP5fV6WCU174x9GOvx9+MNqfiXsrjNz8Gg1+EvpI35JqqVT3y8Q3CLT7qodOhoO9aJmvNqO
+hrl1p9aOklJsewPdGpPiDqPqNi9NdirwW51M3QtcpOS8tf1ZEySMjV+dqvwAPzBMl2eMohm/78zu
+nRSouf5APiGWGJ4/w1VEOQjOU6YdSbWvx/nHRulHo9znp5SraZbUvu5Layfz7HSgojCqPakMDMKd
+YC1LTcCZ8q4hMfV2Sp0yrl8RxuPAEY+GGmmXz/uE7dvdBbRWRxO1PGNxv1iZULL20qPaUsnpHWPs
+RTE4IHlOMHPTSyYIvkZG1gmuVc5y+CMtBOHni/rY473sqafdrrdrzia0mKrRUkujQqvSOESfWLA8
+42Xtm1aNI0GiKKfCI6qskipB6LKn3nlGHfHG/jwT+jyhPhvhtV5wap4qH754PqK0bA4bRCNMn+UU
++Qk7iVqVus6IcRBlSZ5EfcBxKbrHR50vBUlKYfx4LitxePeL8ldWByIzSIV79ckGoQpalPEqBZUx
+9amH2Wao/vlMyl2NQrB/ayyOn552hSjzU8FEuVAIo7Y/5PyUilKdkvQAdPy4rglUHUceNG5bri5I
+olJueymaXl02HhuVYFt261GhXTCgLRITnhVFtbTWapMeyDVA3e30pn+6Q9tjvl0TmJ0G5q2SUQcI
+wD6WNXCQfvgCwncvtYDUd0jz6HqHgWizSa7l/KLx2+38VeOq1ZtGdl+FoYC/1Cu/zjOZJqyCazZ9
+9O9H/r9F+/lP+0v2T+T78u32rlx1tdzWsD7K/JgNAX/OSLaoVEl1JQLMUMd3ukaa4zpVLacsQyqb
+xvepQIa0y6/kqRpSpQwAErCl1VAmRQlHnEpVDgtIOLehN17/3FN+YY7kfcw+ZsuvT0UBaYDzWsBd
+MeKtFVjrksvCJMVT+cF6uM1ZOn5pKYYxQKIPw7nuV9qHUZ0+qFe+hLUayfNPA1Ev5eB01nyToCQS
+elIM/l1e/SkHL9zO55ppXyrr35tuVfGjPAc8+80LpKrLmFxIwUhzVrckGj5rG5KqPiHWLcb/KcnW
+EK0+A2hJ9rc4Vt1Tu14TbI37jxfOnODFvGbDlgwVqbDqRNKLEQ3JDImk/YihANdQB9m6RwqldZ61
+/erW6IHZ67sSvfddqVrveb9wRkfgda5Cbp87lM+MV8MWsSSfBbTfoiWvSeHveZItWwppl9biyoIp
+cbpP/g5s3rbWCqra11GkZVUua7GrjSqwrz7niUqgoyCKL1t1yq4+BniuLp2KHIKUN8rWS2n+NFil
+mnEVl+G76sJK85kU2VL5+fXvd9WfkDTA2iB5+VKW3+mUUJ+cLMVnkak/YM4Rys72Ij2qvu99nW29
+3qNLFTQnKv/VZztL5YoZKGFtAF1m6tYB5ZwJOBKvoA5V5wuEFs8KjwnG2bLUb/c5QCO4OWu2BHQ3
+Pc5lR6jM22w2Z7MlQExslIe1mANhe9Vu8VzUxLRHeKFE9ZwXn5pN18axZpecVqT5XE4hhUaJu3I2
+UygCDzDdtesFkHypxKZyCtGwVd8Ac/V7RhFJsb5KmR7oXjVUOsvWqpquXkNHoZO1StRk2TROqRDH
+N/WP5aj3GmZnC8OaF8u53mLEe7rkGnww8TM/imx5texL4wc0/ffPRVIBfBBj+Fe328DwT2v10eCz
+ip5qF1ihyhDQyPKiOOnkSMVImI57Pz1UF14Jvb7FxPZqPmabGsJhgKkGkuVqqHGNItqaGivW82c6
+hzvxwNR21GN49xKGQTUUbsYQgA02eheW5qVYrq4goqw2Wmj/ecNmLWhBwVT90sLW7D+5FH8fkOlL
+NCyf11OMfeHc97c+NNUc+w6tVbOqJYiXmunRh9G3Oul6eOiw+kriZc3tAUNP6tZ1SzYcIwZThI6Z
+Ko3e7MDywwGGmoMesj3OIc1A1l5NjLSLU3CB9vPqlTpteVjpNH0Wi0KntTAUjf9mqihLlZ9HXKXU
+vuYQLDplmAA/LTuzhg1n0m/czd2u8dZuZ2wxElqmZdqL/3pE+CsAXoOrmotpmacCtToxGrdNP8ik
+buyvGvpCHPLPGm91JOrvPOgJGMxRAXrT38DdUac+2ZI3RfWPYbPSm7z63c71MPgfDHT4eaP/Hk1t
+m+ls/59T8laZdYJ/U8pVNr9Ud225PQxndu1sa4XEh1WK/RE4pjNFPXk5Q9Uuv5MDOvW15jemsDrN
+5z9etUXzdYsoc4DgkyaiQh3/IgnRJF0Sev6CvMXyB7RT8/bbOebxPJw+5/X3bq6/mmKuFs2x5rHj
+p3aEKS/w/LN+aqgSoackrV7X58QQ+aSGu7NC5H4WF838o3qt9ly5E3txiO65L921+lOtWF66ai2k
+5UJNmouCLi7PumNm9e5Dc0QtW1J98ZhadmRXj4A1RX+Yqz/uig3+rYEVGB+aTrNuyNqNTJDvoVyu
+HrqXzRIWd9R5VEPFfF5PCjVJ9x2DCGCErNqJQX+faNveNZ9EVRetur/sT+c73THsdk3Wdy5pZKwN
+7ZY3TUvUOuDN2NgDqTANbqGnWQpSsP1y/jHrfx/oY7b88LdfH16tfp3r9mTVH2P02z0segGxQeT6
+G1mpIRQKfDG/LtIWEWtV8f8PGy3Y1K330l49YAzTjnyln9YPMbri0ebhZfMXz01OyKY96lTvOWAG
+M1o/breL3U4V7G636D4FSZVEqKlr+K2j6bD9+4P9gHdev4az6lLp0VevdrrlzubhJV7UGHGRqRbV
+178BYnMUkw==
+##file distribute_setup.py
+DISTRIBUTE_SETUP_PY = """
+eJztG2tz2zbyu34FTh4PqYSi7TT3GM+pM2nj9DzNJZnYaT8kHhoiIYk1X+XDsvrrb3cBkCAJyc61
+dzM3c7qrIxGLxWLfuwCP/lTs6k2eTabT6Xd5Xld1yQsWxfBvvGxqweKsqnmS8DoGoMnliu3yhm15
+VrM6Z00lWCXqpqjzPKkAFkdLVvDwjq+FU8lBv9h57JemqgEgTJpIsHoTV5NVnCB6+AFIeCpg1VKE
+dV7u2DauNyyuPcaziPEoogm4IMLWecHylVxJ4z8/n0wYfFZlnhrUBzTO4rTIyxqpDTpqCb7/yJ2N
+dliKXxsgi3FWFSKMV3HI7kVZATOQhm6qh98BKsq3WZLzaJLGZZmXHstL4hLPGE9qUWYceKqBuh17
+tGgIUFHOqpwtd6xqiiLZxdl6gpvmRVHmRRnj9LxAYRA/bm+HO7i99SeTa2QX8TekhRGjYGUD3yvc
+SljGBW1PSZeoLNYlj0x5+qgUE8W8vNLfql37tY5Tob+vspTX4aYdEmmBFLS/eUk/Wwk1dYwqI0eT
+fD2Z1OXuvJNiFaP2yeFPVxcfg6vL64uJeAgFkH5Jzy+QxXJKC8EW7F2eCQObJrtZAgtDUVVSVSKx
+YoFU/iBMI/cZL9fVTE7BD/4EZC5s1xcPImxqvkyEN2PPaaiFK4FfZWag90PgqEvY2GLBTid7iT4C
+RQfmg2hAihFbgRQkQeyF/80fSuQR+7XJa1AmfNykIquB9StYPgNd7MDgEWIqwNyBmBTJdwDmmxdO
+t6QmCxEK3OasP6bwOPA/MG4YHw8bbHOmx9XUYccIOIJTMMMhtenPHQXEOviiVqxuhtLJK78qOFid
+C98+BD+/urz22IBp7Jkps9cXb159ensd/HTx8ery/TtYb3rq/8U/ezlthz59fIuPN3VdnJ+cFLsi
+9qWo/LxcnygnWJ1U4KhCcRKddH7pZDq5urj+9OH6/fu3V8GbVz9evB4sFJ6dTScm0Icffwgu3715
+j+PT6ZfJP0XNI17z+U/SHZ2zM/908g786LlhwpN29LiaXDVpysEq2AN8Jv/IUzEvgEL6PXnVAOWl
++X0uUh4n8snbOBRZpUBfC+lACC8+AIJAgvt2NJlMSI2Vr3HBEyzh35m2AfEAMSck5ST3LodpsE4L
+cJGwZe1N/PQuwu/gqXEc3Ia/5WXmOhcdEtCB48rx1GQJmCdRsI0AEYh/LepwGykMrZcgKLDdDcxx
+zakExYkI6cL8vBBZu4sWJlD7UFvsTfbDJK8EhpfOINe5IhY33QaCFgD8idw6EFXweuP/AvCKMA8f
+JqBNBq2fT29m441ILN1Ax7B3+ZZt8/LO5JiGNqhUQsMwNMZx2Q6y161uOzPTnWR53XNgjo7YsJyj
+kDsDD9ItcAU6CqEf8G/BZbFtmcPXqCm1rpjJiW8sPMAiBEEL9LwsBRcNWs/4Mr8XetIqzgCPTRWk
+5sy0Ei+bGB6I9dqF/zytrPAlD5B1/9fp/wGdJhlSLMwYSNGC6LsWwlBshO0EIeXdcWqfjs9/xb9L
+9P2oNvRojr/gT2kgeqIayh3IqKa1qxRVk9R95YGlJLCyQc1x8QBLVzTcrVLyGFLUy/eUmrjO93mT
+RDSLOCVtZ71GW1FWEAHRKod1VTrstVltsOSV0BszHkci4Tu1KrJyqAYK3unC5Py4mhe748iH/yPv
+rIkEfI5ZRwUGdfUDIs4qBx2yPDy7mT2dPcosgOB2L0bGvWf/+2gdfPZwqdOrRxwOAVLOhuSDPxRl
+7Z56rJO/yn77dY+R5C911acDdEDp94JMQ8p7UGOoHS8GKdKAAwsjTbJyQ+5ggSrelBYmLM7+7IFw
+ghW/E4vrshGtd005mXjVQGG2peSZdJQvqzxBQ0VeTLolDE0DEPzXNbm35VUguSTQmzrF3ToAk6Ks
+raIkFvmb5lGTiAorpS/tbpyOK0PAsSfu/TBE01uvDyCVc8MrXtel2wMEQwkiI+hak3CcrThoz8Jp
+qF8BD0GUc+hqlxZiX1nTzpS59+/xFvuZ12OGr8p0d9qx5NvF9LlabWYha7iLPj6VNn+fZ6skDuv+
+0gK0RNYOIXkTdwb+ZCg4U6vGvMfpEOogI/G3JRS67ghiek2enbYVmT0Hozfjfrs4hoIFan0UNL+H
+dJ0qmS/ZdIwPWykhz5wa601l6oB5u8E2AfVXVFsAvpVNhtHFZx8SAeKx4tOtA87SvERSQ0zRNKGr
+uKxqD0wT0FinO4B4p10Om38y9uX4Fvgv2ZfM/b4pS1gl2UnE7LicAfKe/xc+VnGYOYxVWQotrt0X
+/TGRVBb7AA1kA5Mz7PvzwE/c4BSMzNTYye/2FbNfYw1PiiH7LMaq1202A6u+y+s3eZNFv9toHyXT
+RuIo1TnkroKwFLwWQ28V4ObIAtssCsPVgSj9e2MWfSyBS8Ur5YWhHn7dtfhac6W42jYSwfaSPKTS
+hdqcivFxLTt3GVTyMim8VbTfsmpDmdkS25H3PIl72LXlZU26FCVYNCdTbr0C4cL2HyW91DFp+5Cg
+BTRFsNseP24Z9jhc8BHhRq8uskiGTezRcuacODOf3Uqe3OKKvdwf/IsohU4h236XXkVEvtwjcbCd
+rvZAHdYwzyLqdRYcA/1SrNDdYFszrBuedB1X2l+NlVTtazH8RxKGXiwioTYlVMFLikIC29yq31wm
+WFZNDGu0xkoDxQvb3Hr9W4DqgK2fXnLsYxm2/g0doJK+bGqXvVwVBcmet1hk/sfvBbB0TwquQVV2
+WYaIDvalWquGtQ7yZol2do48f3Wfx6jVBVpu1JLTZTijkN4WL631kI+vph5uqe+yJVGKS+5o+Ih9
+FDw6odjKMMBAcgaksyWY3J2HHfYtKiFGQ+laQJPDvCzBXZD1DZDBbkmrtb3EeNZRC4LXKqw/2JTD
+BKEMQR94NMioJBuJaMksj023y+kISKUFiKwbG/lMJQlYy5JiAAG6RB/AA35LuINFTfiuc0oShr0k
+ZAlKxqoSBHddgfda5g/uqslC9GbKCdKwOU7tVY89e3a3nR3IimXzv6tP1HRtGK+1Z7mSzw8lzENY
+zJmhkLYly0jtfZzLVtKozW5+Cl5Vo4HhSj6uA4IeP28XeQKOFhYw7Z9X4LELlS5YJD0hsekmvOEA
+8OR8fjhvvwyV7miN6In+UW1Wy4zpPswgqwisSZ0d0lR6U2+VohNVAfoGF83AA3cBHiCru5D/M8U2
+Ht41BXmLlUysRSZ3BJFdByTyluDbAoVDewREPDO9BnBjDLvQS3ccOgIfh9N2mnmWntarPoTZLlW7
+7rShm/UBobEU8PUEyCYxNgTkDIhimc+ZmwBD2zq2YKncmuadPRNc2fwQ6fbEEAOsZ3oXY0T7JjxU
+1myzCk27uCHvDR4rVKM9SwSZ2OrIjE8hyjr++7ev/eMKj7TwdNTHP6PO7kdEJ4MbBpJc9hQliRqn
+avJibYs/Xduo2oB+2BKb5veQLINpBGaH3C0SHooNKLvQnepBGI8r7DWOwfrUf8ruIBD2mu+QeKk9
+GHP369cK646e/8F0VF8IMBrBdlKAanXa7Kt/XZzrmf2YZ9gxnGNxMHT3evGRt1yC9O9Mtqz65VHH
+ga5DSim8eWhurjtgwGSkBSAn1AKRCHkkmzc1Jr3oPbZ819mcrnOGCZvBHo9J1VfkDySq5huc6Jy5
+shwgO+jBSlfViyCjSdIfqhkes5xXqs624ujIt3fcAFPgQxflsT41VmU6AsxblojaqRgqfut8h/xs
+FU3xG3XNNVt43qD5p1r4eBMBvxrc0xgOyUPB9I7Dhn1mBTKodk1vM8Iyjuk2vQSnKhv3wFZNrOLE
+nja6c9Vd5ImMNoEz2EnfH+/zNUPvvA9O+2q+gnS6PSLG9RVTjACGIO2NlbZt3dpIx3ssVwADnoqB
+/09TICLIl7+43YGjr3vdBZSEUHfJyPZYl6Hn3CTdXzOl53JNckElLcXUY27YImzNHN1YGLsg4tTu
+nngEJqcilfvkUxNZEXYbVZHYsCJ1aFN1fhAW+NLTOXffVQFP0vYVTm9Aysj/aV6OHaDV80jwA35n
+6MO/R/nLSD6a1aVErYM8nBZZ3ScB7E+RJKvqNifazypDRj5McIZJyWAr9cbgaLcV9fixrfTIMDpl
+Q3k9vr/HTGzoaR4Bn/Xy+TbodTndkQolEIHCO1SlGH/Z8uu9Cioz4IsffpijCDGEgDjl969Q0HiU
+wh6Ms/tiwlPjquHbu9i6J9kH4tO7lm/9RwdZMXvEtB/l3H/FpgxW9MoOpS32ykMNav2Sfco2oo2i
+2Xeyj7k3nFlO5hRmatYGRSlW8YOrPX0XXNogR6FBHUpC/X1vnPcbe8Pf6kKdBvysv0CUjMSDETaf
+n53ftFkUDXr62p3ImlSUXF7IM3snCCpvrMp8az4vYa/yHoTcxDBBh00ADh/WLOsK28yoxAsMIxKP
+pTFT54WSDM0skrh2HVxn4cw+zwencwYLNPvMxRSu4RGRpApLQ0mF9cA1Ac2Utwi/lfyx95B65Faf
+CfK5hcqvpbSjEZjbVKJ06GihuxyrjgqxjWvt2NhWaWdbDENq5EhVh8p+FXI6UDTOHfX1SJvt7j0Y
+P9ShOmJb4YBFhUCCJcgb2S0opHGrJ8qFZEolRIrnDObx6LhLQj+3aC79UkHdO0I2jDdkxCFMTGHy
+tvIxa+uf6fsf5XkvJtvgFUtwRr3yxJ64D7SFYj5iWJAbVx5Xce56V4gR37BVaRwkvfpw+QcTPuuK
+wCFCUMi+Mpq3ucx3C8ySRBbmdtEcsUjUQt2aw+CNJ/FtBERNjYY5bHsMtxiS5+uhoT6b7zwYRY9c
+GrRbt0Msqyhe0KGC9IWokOQL4wcitijz+zgSkXz9IV4pePNFi8poPkTqwl3qdYcauuNoVhz9wGGj
+zC4FhQ0Y6g0JBkTyLMR2D3SsrfJGONCygfpjf43SS8PAKqUcK/O6ntqSZRO+yCIVNOjO2J5NZXN5
+m68TXo8OtO/9fTSrVPVkRRrgsHlYS1PFuPC5n6R9GZOFlMMJlCLR3Zd/os71uxFfkYPuTUIPNJ8H
+vOnPG7efTd1oj+7QrOl8Wbo/Ous1/H0mhqLtZ/+/V54Deum0MxNGwzzhTRZuuhSuezKMlB/VSG/P
+GNrYhmNrC99IkhBU8Os3WiRUERcs5eUdnuXnjNMBLO8mLJvWeNpU7/ybG0wXPjvz0LyRTdkZXrFJ
+xFy1AObigd5fgpx5nvIMYnfk3BghTmM8vWn7Adg0MxPMz/03Lm7Y83baROOg+znWl2la7hmXkiuR
+rGTjfDH1px5LBV4cqBYYU7qTGXWRmg6CFYQ8ZqRLACVwW7IWf4byipG+R6z3111oQJ+M73rl2wyr
+6jSP8K0w6f+x2U8AhSjTuKroNa3uyE4jiUEJqeEFMo8qn93iBpz2Ygi+ogVIV4IIGV2jBkIVB+Ar
+TFY7ctATy9SUJ0REiq/c0WUR4CeRTA1AjQd77EqLQWOXO7YWtcLlzvo3KFRCFubFzvwNhRhk/OpG
+oGSovE6uARTju2uDJgdAH27avECLZZQP6AGMzclq0lYfsBL5Q4goCqRXOath1f8e+KUjTViPHnWh
+peIrgVIVg2P9DtLnBVSgkavW6LsyTdeCuOXjn4OAeJ8M+zYvX/6NcpcwTkF8VDQBfad/PT01krFk
+5SvRa5xS+duc4qNAaxWsQu6bJJuGb/b02N+Z+8JjLw0OoY3hfFG6gOHMQzwvZtZyIUwLgvGxSSAB
+/e50asg2ROpKzHaAUlLv2o4eRojuxG6hFdDH435QX6TZQQKcmccUNnl1WDMIMje66AG4WgturRZV
+l8SBqdyQeQOlM8Z7RNI5oLWtoQXeZ9Do7JykHG6AuE7GCu9sDNjQ+eITAMMN7OwAoCoQTIv9N269
+ShXFyQlwP4Eq+GxcAdON4kF1bbunQMiCaLl2QQmnyrXgm2x44UnocJDymGrue4/tueTXBYLLQ6+7
+kgpc8GqnoLTzO3z9X8X44cttQFxM918weQqoIg8CJDUI1LuURHcbNc/Ob2aTfwH3muVf
+##file activate.sh
+ACTIVATE_SH = """
+eJytVU1v4jAQPW9+xTT0ANVS1GsrDlRFAqmFqmG72m0rY5IJsRRslDiktNr/vuMQ8tFQpNU2B4I9
+H36eeW/SglkgYvBFiLBKYg0LhCRGD1KhA7BjlUQuwkLIHne12HCNNpz5kVrBgsfBmdWCrUrA5VIq
+DVEiQWjwRISuDreW5eE+CtodeLeAnhZEGKMGFXqAciMiJVcoNWx4JPgixDjzEj48QVeCfcqmtzfs
+cfww+zG4ZfeD2ciGF7gCHaDMPM1jtvuHXAsPfF2rSGeOxV4iDY5GUGb3xVEYv2aj6WQ0vRseAlMY
+G5DKsAawwnQUXt2LQOYlzZoYByqhonqoqfxZf4BLD97i4DukgXADCPgGgdOLTK5arYxZB1xnrc9T
+EQFcHoZEAa1gSQioo/TPV5FZrDlxJA+NzwF+Ek1UonOzFnKZp6k5mgLBqSkuuAGXS4whJb5xz/xs
+wXCHjiVerAk5eh9Kfz1wqOldtVv9dkbscfjgjKeTA8XPrtaNauX5rInOxaHuOReNtpFjo1/OxdFG
+5eY9hJ3L3jqcPJbATggXAemDLZX0MNZRYjSDH7C1wMHQh73DyYfTu8a0F9v+6D8W6XNnF1GEIXW/
+JrSKPOtnW1YFat9mrLJkzLbyIlTvYzV0RGXcaTBfVLx7jF2PJ2wyuBsydpm7VSVa4C4Zb6pFO2TR
+huypCEPwuQjNftUrNl6GsYZzuFrrLdC9iJjQ3omAPBbcI2lsU77tUD43kw1NPZhTrnZWzuQKLomx
+Rd4OXM1ByExVVkmoTwfBJ7Lt10Iq1Kgo23Bmd8Ib1KrGbsbO4Pp2yO4fpnf3s6MnZiwuiJuls1/L
+Pu4yUCvhpA+vZaJvWWDTr0yFYYyVnHMqCEq+QniuYX225xmnzRENjbXACF3wkCYNVZ1mBwxoR9Iw
+WAo3/36oSOTfgjwEEQKt15e9Xpqm52+oaXxszmnE9GLl65RH2OMmS6+u5acKxDmlPgj2eT5/gQOX
+LLK0j1y0Uwbmn438VZkVpqlfNKa/YET/53j+99G8H8tUhr9ZSXs2
+##file activate.fish
+ACTIVATE_FISH = """
+eJydVm1v4jgQ/s6vmA1wBxUE7X2stJVYlVWR2lK13d6d9laRk0yIr8HmbIe0++tvnIQQB9pbXT5A
+Ys/LM55nZtyHx5RrSHiGsMm1gRAh1xhDwU0Kng8hFzMWGb5jBv2E69SDs0TJDdj3MxilxmzPZzP7
+pVPMMl+q9bjXh1eZQ8SEkAZULoAbiLnCyGSvvV6SC7IoBcS4Nw0wjcFbvJDcjiuTswzFDpiIQaHJ
+lQAjQUi1YRmUboC2uZJig8J4PaCnT5IaDcgsbm/CjinOwgx1KcUTMEhhTgV4g2B1fRk8Le8fv86v
+g7v545UHpZB9rKnp+gXsMhxLunIIpwVQxP/l9c/Hq9Xt1epm4R27bva6AJqN92G4YhbMG2i+LB+u
+grv71c3dY7B6WtzfLy9bePbp0taDTXSwJQJszUnnp0y57mvpPcrF7ZODyhswtd59+/jdgw+fwBNS
+xLSscksUPIDqwwNmCez3PpxGeyBYg6HE0YdcWBxcKczYzuVJi5Wu915vn5oWePCCoPUZBN5B7IgV
+MCi54ZDLG7TUZ0HweXkb3M5vFmSpFm/gthhBx0UrveoPpv9AJ9unIbQYdUoe21bKg2q48sPFGVwu
+H+afrxd1qvclaNlRFyh1EQ2sSccEuNAGWQwysfVpz1tPajUqbqJUnEcIJkWo6OXDaodK8ZiLdbmM
+L1wb+9H0D+pcyPSrX5u5kgWSygRYXCnJUi/KKcuU4cqsAyTKZBiissLc7NFwizvjxtieKBVCIdWz
+fzilzPaYyljZN0cGN1v7NnaIPNCGmVy3GKuJaQ6iVjE1Qfm+36hglErwmnAD8hu0dDy4uICBA8ZV
+pQr/q/+O0KFW2kjelu9Dgb9SDBsWV4F4x5CswgS0zBVlk5tDMP5bVtUGpslbm81Lu2sdKq7uNMGh
+MVQ4fy9xhogC1lS5guhISa0DlBWv0O8odT6/LP+4WZzDV6FzIkEqC0uolGZSZoMnlpxplmD2euaT
+O4hkTpPnbztDccey0bhjDaBIqaWQa0uwEtQEwtyU56i4fq54F9IE3ORR6mKriODM4XOYZwaVYLYz
+7SPbKkz4i7VkB6/Ot1upDE3znNqYKpM8raa0Bx8vfvntJ32UENsM4aI6gJL+jJwhxhh3jVIDOcpi
+m0r2hmEtS8XXXNBk71QCDXTBNhhPiHX2LtHkrVIlhoEshH/EZgdq53Eirqs5iFKMnkOmqZTtr3Xq
+djvPTWZT4S3NT5aVLgurMPUWI07BRVYqkQrmtCKohNY8qu9EdACoT6ki0a66XxVF4f9AQ3W38yO5
+mWmZmIIpnDFrbXakvKWeZhLwhvrbUH8fahhqD0YUcBDJjEBMQwiznE4y5QbHrbhHBOnUAYzb2tVN
+jJa65e+eE2Ya30E2GurxUP8ssA6e/wOnvo3V78d3vTcvMB3n7l3iX1JXWqk=
+##file activate.csh
+ACTIVATE_CSH = """
+eJx9U11vmzAUffevOCVRu+UB9pws29Kl0iq1aVWllaZlcgxciiViItsQdb9+xiQp+dh4QOB7Pu49
+XHqY59IgkwVhVRmLmFAZSrGRNkdgykonhFiqSCRW1sJSmJg8wCDT5QrucRCyHn6WFRKhVGmhKwVp
+kUpNiS3emup3TY6XIn7DVNQyJUwlrgthJD6n/iCNv72uhCzCpFx9CRkThRQGKe08cWXJ9db/yh/u
+pvzl9mn+PLnjj5P5D1yM8QmXlzBkSdXwZ0H/BBc0mEo5FE5qI2jKhclHOOvy9HD/OO/6YO1mX9vx
+sY0H/tPIV0dtqel0V7iZvWyNg8XFcBA0ToEqVeqOdNUEQFvN41SumAv32VtJrakQNSmLWmgp4oJM
+yDoBHgoydtoEAs47r5wHHnUal5vbJ8oOI+9wI86vb2d8Nrm/4Xy4RZ8R85E4uTZPB5EZPnTaaAGu
+E59J8BE2J8XgrkbLeXMlVoQxznEYFYY8uFFdxsKQRx90Giwx9vSueHP1YNaUSFG4vTaErNSYuBOF
+lXiVyXa9Sy3JdClEyK1dD6Nos9mEf8iKlOpmqSNTZnYjNEWiUYn2pKNB3ttcLJ3HmYYXy6Un76f7
+r8rRsC1TpTJj7f19m5sUf/V3Ir+x/yjtLu8KjLX/CmN/AcVGUUo=
+##file activate.bat
+ACTIVATE_BAT = """
+eJyFUkEKgzAQvAfyhz0YaL9QEWpRqlSjWGspFPZQTevFHOr/adQaU1GaUzI7Mzu7ZF89XhKkEJS8
+qxaKMMsvboQ+LxxE44VICSW1gEa2UFaibqoS0iyJ0xw2lIA6nX5AHCu1jpRsv5KRjknkac9VLVug
+sX9mtzxIeJDE/mg4OGp47qoLo3NHX2jsMB3AiDht5hryAUOEifoTdCXbSh7V0My2NMq/Xbh5MEjU
+ZT63gpgNT9lKOJ/CtHsvT99re3pX303kydn4HeyOeAg5cjf2EW1D6HOPkg9NGKhu
+##file deactivate.bat
+DEACTIVATE_BAT = """
+eJxzSE3OyFfIT0vj4spMU0hJTcvMS01RiPf3cYkP8wwKCXX0iQ8I8vcNCFHQ4FIAguLUEgWIgK0q
+FlWqXJpcICVYpGzx2BAZ4uHv5+Hv6wq1BWINXBTdKriEKkI1DhW2QAfhttcxxANiFZCBbglQSJUL
+i2dASrm4rFz9XLgAwJNbyQ==
+##file distutils-init.py
+DISTUTILS_INIT = """
+eJytV92L4zYQf9dfMU0ottuse/TeFkKh3MvC0Ydy0IdlMVpbTtR1JCMpm+T++s5Y/pBs53oPZ1hQ
+pPnSb34zo5WnVhsH2jLpV/Y2Li/cKKkOFoYN3Za6ErAdFtKC0g44vEvjzrwR6h1Oujo3YgdWw0VA
+yRWcLUo6cBpqqSpwRwHWVY18ZRB9W3jq3HDlfoIvqK7NG2gF7a297VANvZ3O1sGrQI/eDe5yB0ZY
+WQkLUpHxhVX09NDe3FGr31BL1lJUD9f8ln+FShpROm1ujOFS8ZOAPUKRt9wd836Hjqw7O9nYgvYD
+iX+1VOlMPPXQ5EVRy0YURbaDZDSQZEzWo7rS5kSLNHaQwX4RRLrQGe1nj92Fh1zltEhHDDZfEO0g
+O6MraHn5xg8IpYOfLfC2FdxYShLC64EES4A0uuROYhq49Zs368RpMvTHJmOiscKHUXRXKIpcKiuM
+Sz/sYHa7TkxcRYkkEhN8HZaxKCJXFFJJh+baW5JluRG8SjM20JHEA9qWWtXywBjbbvF2rjzC61k2
+VSGuDibTUGlhVeLgTekLHPEP73wQrrscUsUGrPCGjkTCC1JXXyw8EJWP3FSUZY8IiSCCRp97dnfO
+RUUx5a0RtbxSzLX/3XBXYxIpyQka/fh74pGrjQ5QzUt9OnFV5dMV+otOG5gQjctxozNTNtzaSSiN
+JHqu0FeJmsqRN/KrKHRLGbaQWtHUgRB9FDfu5giN4eZWIDqWCv8vrcTjrNZgRXQPzy+RmGjQpLRI
+EKz0UqQLlR28ciusM8jn7PtcLPZy2zbSDeyyos0iO+ybBgPyRvSk/CEFm8IndQebz8iXTRbbjhDP
+5xh7iJfBrKd/Nenjj6Jvgp2B+W7AnP102BXH5IZWPV3tI2MUOvXowpdS12IIXhLLP0lKyeuZrpEv
+pFhPqHg3JFTd1cceVp0EsPgGU0wFO2u4iyYRoFYfEm9kG/RZcUUBm87t9mFtx9iCtC9kx4Rt4R8a
+OdgzSt40vtyFecAZZ8BfCOhCrC8djMGPFaz2Vlt5TSZCk053+37wbLDLRXfZ+F45NtdVpVWdudSC
+xgODI8EsiLoTl5aO0lhoigX7GHZDHAY4LxoMIu1gXPYPksmFquxF4uRKZhEnKzXu82HESb+LlNQz
+Fh/RvFJVuhK+Ee5slBdj30FcRGdJ5rhKxtkyKxWcGoV/WOCYKqkNDYJ5fNQVx3g400tpJBS2FSU+
+Tco9ss8nZ08dtscGQfSby87b73fOw+4UgrEMNnY6uMzYvSDxPVPpsij6+l0/ZPfuH0Iz010giY34
+HpL0ZLyLJB4ukaQRU+GwptO7yIZCQE33B0K9iCqO6X+AR4n7wAeH68DPkJzpTsD3x+/cj9LIVHC2
+An1wmv7CzWHoqR02vb0VL73siP+3nkX0YbQ0l9f6WDyOm24cj3rxO2MMip6kpcu6VCefn/789PR3
+0v0fg21sFIp70rj9PCi8YDRDXFucym/43qN+iENh1Jy/dIIIqF3OIkDvBMsdx+huWv8Kz73vl8g5
+WQ3JOGqwu3lb4dfKKbvLigXDQsb8B/xt39Q=
+##file distutils.cfg
+DISTUTILS_CFG = """
+eJxNj00KwkAMhfc9xYNuxe4Ft57AjYiUtDO1wXSmNJnK3N5pdSEEAu8nH6lxHVlRhtDHMPATA4uH
+xJ4EFmGbvfJiicSHFRzUSISMY6hq3GLCRLnIvSTnEefN0FIjw5tF0Hkk9Q5dRunBsVoyFi24aaLg
+9FDOlL0FPGluf4QjcInLlxd6f6rqkgPu/5nHLg0cXCscXoozRrP51DRT3j9QNl99AP53T2Q=
+##file activate_this.py
+ACTIVATE_THIS = """
+eJyNUlGL2zAMfvevEBlHEujSsXsL9GGDvW1jD3sZpQQ3Ua7aJXawnbT595Ocpe0dO5ghseVP+vRJ
+VpIkn2cYPZknwAvWLXWYhRP5Sk4baKgOWRWNqtpdgTyH2Y5wpq5Tug406YAgKEzkwqg7NBPwR86a
+Hk0olPopaK0NHJHzYQPnE5rI0o8+yBUwiBfyQcT8mMPJGiAT0A0O+b8BY4MKJ7zPcSSzHaKrSpJE
+qeDmUgGvVbPCS41DgO+6xy/OWbfAThMn/OQ9ukDWRCSLiKzk1yrLjWapq6NnvHUoHXQ4bYPdrsVX
+4lQMc/q6ZW975nmSK+oH6wL42a9H65U6aha342Mh0UVDzrD87C1bH73s16R5zsStkBZDp0NrXQ+7
+HaRnMo8f06UBnljKoOtn/YT+LtdvSyaT/BtIv9KR60nF9f3qmuYKO4//T9ItJMsjPfgUHqKwCZ3n
+xu/Lx8M/UvCLTxW7VULHxB1PRRbrYfvWNY5S8it008jOjcleaMqVBDnUXcWULV2YK9JEQ92OfC96
+1Tv4ZicZZZ7GpuEpZbbeQ7DxquVx5hdqoyFSSmXwfC90f1Dc7hjFs/tK99I0fpkI8zSLy4tSy+sI
+3vMWehjQNJmE5VePlZbL61nzX3S93ZcfDqznnkb9AZ3GWJU=
+if __name__ == '__main__':
+    main()
+## TODO:
+## Copy python.exe.manifest
+## Monkeypatch distutils.sysconfig
Property changes on: usertools/swift-vm-boot/bin/virtualenv.py
___________________________________________________________________
Added: svn:executable
Deleted: usertools/swift-vm-boot/env.sh
--- usertools/swift-vm-boot/env.sh	2011-11-29 17:26:03 UTC (rev 5323)
+++ usertools/swift-vm-boot/env.sh	2011-11-29 21:20:57 UTC (rev 5324)
@@ -1,5 +0,0 @@
-export FUTUREGRID_IAAS_ACCESS_KEY=<replace this>
-export FUTUREGRID_IAAS_SECRET_KEY=<and this>
-export FUTUREGRID_HOTEL_NODES=2
-export FUTUREGRID_SIERRA_NODES=2
Added: usertools/swift-vm-boot/env.sh
--- usertools/swift-vm-boot/env.sh	                        (rev 0)
@@ -0,0 +1,9 @@
+export FUTUREGRID_IAAS_ACCESS_KEY=XXXX
+export FUTUREGRID_IAAS_SECRET_KEY=XXXXXXXXX
+export EC2_ACCESS_KEY=$FUTUREGRID_IAAS_ACCESS_KEY
+export EC2_SECRET_KEY=$FUTUREGRID_IAAS_SECRET_KEY
+export EC2_URL=https://s83r.idp.sdsc.futuregrid.org:8444
+export FUTUREGRID_SIERRA_NODES=2
Deleted: usertools/swift-vm-boot/hosts.txt
--- usertools/swift-vm-boot/hosts.txt	2011-11-29 17:26:03 UTC (rev 5323)
+++ usertools/swift-vm-boot/hosts.txt	2011-11-29 21:20:57 UTC (rev 5324)
@@ -1,2 +0,0 @@
-svc.uc.futuregrid.org
-s83r.idp.sdsc.futuregrid.org
Added: usertools/swift-vm-boot/hosts.txt
--- usertools/swift-vm-boot/hosts.txt	                        (rev 0)
@@ -0,0 +1 @@
+s83r.idp.sdsc.futuregrid.org
Deleted: usertools/swift-vm-boot/install.sh
--- usertools/swift-vm-boot/install.sh	2011-11-29 17:26:03 UTC (rev 5323)
+++ usertools/swift-vm-boot/install.sh	2011-11-29 21:20:57 UTC (rev 5324)
@@ -1,28 +0,0 @@
-#!/bin/bash
-cd `dirname $0`
-source env.sh
-python bin/virtualenv.py ve
-if [ $? -ne 0 ]; then
-    echo "Failed to created the needed python virtual environment"
-    exit 1
-fi
-source ve/bin/activate
-easy_install cloudinitd
-    echo "Failed to install cloudinitd"
-    exit 1
-fi
-echo "Registering the key names in all the clouds"
-python bin/register_key.py hosts.txt
-    echo "Failed to register the key names"
-    exit 1
-fi
-echo "Success!"
-echo ""
-echo 0
Added: usertools/swift-vm-boot/install.sh
--- usertools/swift-vm-boot/install.sh	                        (rev 0)
@@ -0,0 +1,28 @@
+#!/bin/bash
+cd `dirname $0`
+source env.sh
+python bin/virtualenv.py ve
+if [ $? -ne 0 ]; then
+    echo "Failed to created the needed python virtual environment"
+    exit 1
+fi
+source ve/bin/activate
+easy_install cloudinitd
+    echo "Failed to install cloudinitd"
+    exit 1
+fi
+echo "Registering the key names in all the clouds"
+python bin/register_key.py hosts.txt
+    echo "Failed to register the key names"
+    exit 1
+fi
+echo "Success!"
+echo ""
+echo 0
Property changes on: usertools/swift-vm-boot/install.sh
Added: usertools/swift-vm-boot/plan/test-level1.conf
--- usertools/swift-vm-boot/plan/test-level1.conf	                        (rev 0)
+++ usertools/swift-vm-boot/plan/test-level1.conf	2011-11-29 21:20:57 UTC (rev 5324)
@@ -0,0 +1,12 @@
+[svc-sierra]
+replica_count: env.FUTUREGRID_SIERRA_NODES
+iaas_key: env.FUTUREGRID_IAAS_ACCESS_KEY
+iaas_secret: env.FUTUREGRID_IAAS_SECRET_KEY
+sshkeyname: swiftkey
+localsshkeypath: ~/.ssh/id_rsa.pub
+iaas_url: https://s83r.idp.sdsc.futuregrid.org:8444
+image: debian-lenny.gz
+iaas: nimbus
+ssh_username: root
Added: usertools/swift-vm-boot/plan/top.conf
--- usertools/swift-vm-boot/plan/top.conf	                        (rev 0)
+++ usertools/swift-vm-boot/plan/top.conf	2011-11-29 21:20:57 UTC (rev 5324)
@@ -0,0 +1,10 @@
+# This is a sample top level configuration file.  Each entry under runlevels
+# is a file with a single runlevel description.  All of the services in that
+# file are run at the same time but the next level is not begun until
+# all of these services in the previous successfully complete.
+[defaults]
+[runlevels]
+level1: test-level1.conf
