[Swift-commit] r5313 - trunk/src/org/griphyn/vdl/engine
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Sat Nov 19 19:28:25 CST 2011
Author: jonmon
Date: 2011-11-19 19:28:25 -0600 (Sat, 19 Nov 2011)
New Revision: 5313
Modified:
   trunk/src/org/griphyn/vdl/engine/Karajan.java
Log:
Fixed import compilation issue.
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java	2011-11-19 23:31:34 UTC (rev 5312)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java	2011-11-20 01:28:25 UTC (rev 5313)
@@ -196,18 +196,17 @@
 					File local = new File(swiftfilename);
 					if( !( lib_path == null || local.exists() ) )
-					    StringTokenizer st = new StringTokenizer(lib_path, ":");
-					    while(st.hasMoreTokens())
+					    String[] path = lib_path.split(":");
+					    for(String entry : path)
-					        String path = st.nextToken();
-					        String lib_script_location = path + "/" + swiftfilename;
-					        File tmp = new File(lib_script_location);
-					        if(tmp.exists())
+					        String lib_script_location = entry + "/" + swiftfilename;
+					        File file = new File(lib_script_location);
+					        if(file.exists())
-					            swiftfilename = path + "/" + swiftfilename;
-					            xmlfilename = path + "/" + xmlfilename;
-					            moduleToImport = path + "/" + moduleToImport;
+					            swiftfilename = entry + "/" + swiftfilename;
+					            moduleToImport = entry + "/" + moduleToImport;
 					            break;
