[Swift-commit] r5305 - trunk/src/org/griphyn/vdl/karajan/lib/swiftscript
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Wed Nov 16 09:17:43 CST 2011
Author: jonmon
Date: 2011-11-16 09:17:42 -0600 (Wed, 16 Nov 2011)
New Revision: 5305
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java
Log:
@java now selects to correct function based on parameter types and function name.
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java	2011-11-15 16:27:02 UTC (rev 5304)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java	2011-11-16 15:17:42 UTC (rev 5305)
@@ -1,6 +1,7 @@
 package org.griphyn.vdl.karajan.lib.swiftscript;
 import java.lang.reflect.Method;
+import java.util.Arrays;
 import org.globus.cog.karajan.arguments.Arg;
 import org.globus.cog.karajan.stack.VariableStack;
@@ -12,73 +13,93 @@
 import org.griphyn.vdl.type.Type;
 import org.griphyn.vdl.type.Types;
-public class Java extends VDLFunction {
+public class Java extends VDLFunction
-    static {
+    static
         setArguments(Java.class, new Arg[] { Arg.VARGS });
-    protected Object function(VariableStack stack) throws ExecutionException {
+    protected Object function(VariableStack stack) throws ExecutionException
         AbstractDataNode[] args = waitForAllVargs(stack);
-        Method method = getMethod(args);
+        Method method = getMethod(args);
         Object[] p = convertInputs(method, args);
         Type type = returnType(method);
         Object value = invoke(method, p);
         DSHandle result = swiftResult(type, value);
         return result;
        Given the user args, locate the Java Method.
-    Method getMethod(DSHandle[] args) {
-        Method result = null;
+    Method getMethod(DSHandle[] args)
+        Method result;
         Class<?> clazz;
         String lib = "unset";
         String name = "unset";
+        Class[] parameterTypes = new Class[args.length-2];
         if (args.length < 2)
             throw new RuntimeException
-            ("@java() requires at least two arguments");
-        try {
+                ("@java() requires at least two arguments");
+        try
             lib = (String) args[0].getValue();
             name = (String) args[1].getValue();
-            clazz = Class.forName(lib);
-            Method[] methods = clazz.getMethods();
-            result = null;
-            for (Method m : methods) {
-                if (m.getName().equals(name)) {
-                    result = m;
-                    break;
+            clazz = Class.forName(lib);
+            for (int i = 2; i < args.length; i++)
+                Class p = null;
+                Type  t = args[i].getType();
+                if (t.equals(Types.FLOAT))        p = double.class;
+                else if (t.equals(Types.INT))     p = int.class;
+                else if (t.equals(Types.BOOLEAN)) p = boolean.class;
+                else if (t.equals(Types.STRING))  p = String.class;
+                else                              throw new RuntimeException("Cannot use @java with non-primitive types");
+                parameterTypes[i-2] = p;
-        catch (Exception e) {
-            e.printStackTrace();
+            result = clazz.getMethod(name, parameterTypes);
+        catch (Exception e)
+            e.printStackTrace();
-            ("@java(): Error attempting to use: " + args[0]);
+                ("@java(): Error attempting to use: " + args[0].getValue());
-        if (result == null)
+        if (result == null)
-            ("No method: " + name + " in " + lib);
+                ("No method: " + name + " in " + lib + "with parameter types" + Arrays.toString(parameterTypes));
         return result;
-       Convert the user args to a Java Object array.
+       Convert the user args to a Java Object array.
-    Object[] convertInputs(Method method, DSHandle[] args) {
+    Object[] convertInputs(Method method, DSHandle[] args)
         Object[] result = new Object[args.length-2];
         Object a = null;
-        try {
-            for (int i = 2; i < args.length; i++) {
+        try
-                Object v = args[i].getValue();
+                Object v = args[i].getValue();
                     a = (Double) v;
@@ -87,25 +108,25 @@
                     a = (Boolean) v;
                     a = (String) v;
-                result[i-2] = a;
+                result[i-2] = a;
-            ("Error converting input arguments: \n" +
-                " to: " + method.getDeclaringClass() +
-                "." + method + " \n argument: " + a);
+                ("Error converting input arguments: \n" +
+                 " to: " + method.getDeclaringClass() +
+                 "." + method + " \n argument: " + a);
         return result;
     Type returnType(Method method) {
         Type result = null;
-        Class<?> rt = method.getReturnType();
+        Class<?> rt = method.getReturnType();
         if (rt.equals(Double.TYPE))
-            result = Types.FLOAT;
+            result = Types.FLOAT;
         else if (rt.equals(Integer.TYPE))
             result = Types.INT;
         else if (rt.equals(Boolean.TYPE))
@@ -114,22 +135,26 @@
             result = Types.STRING;
         return result;
-    Object invoke(Method method, Object[] p) {
-        Object result = null;
-        try {
+    Object invoke(Method method, Object[] p)
+        Object result = null;
+        try
             result = method.invoke(null, p);
-            ("Error attempting to invoke: " +
-                method.getDeclaringClass() + "." + method);
+                ("Error attempting to invoke: " +
+                 method.getDeclaringClass() + "." + method);
         return result;
-    DSHandle swiftResult(Type type, Object value) {
+    DSHandle swiftResult(Type type, Object value)
         DSHandle result = new RootDataNode(type);
         result.setValue(value);
         result.closeShallow();
