[Swift-commit] r5293 - branches/release-0.93/tests/cdm/absolute
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon Nov 14 14:31:32 CST 2011
Author: ketan
Date: 2011-11-14 14:31:32 -0600 (Mon, 14 Nov 2011)
New Revision: 5293
Modified:
   branches/release-0.93/tests/cdm/absolute/ff.kml
   branches/release-0.93/tests/cdm/absolute/fr.kml
   branches/release-0.93/tests/cdm/absolute/rf.kml
   branches/release-0.93/tests/cdm/absolute/rr.kml
   branches/release-0.93/tests/cdm/absolute/run.sh
Log:
added rule for out
Modified: branches/release-0.93/tests/cdm/absolute/ff.kml
--- branches/release-0.93/tests/cdm/absolute/ff.kml	2011-11-14 20:27:14 UTC (rev 5292)
+++ branches/release-0.93/tests/cdm/absolute/ff.kml	2011-11-14 20:31:32 UTC (rev 5293)
@@ -14,29 +14,29 @@
     <vdl:new type="string" value="1" />
   </global>
   <global name="swift#string#17004">
-    <vdl:new type="string" value="/home/ketan/cdm_tests/out2.data" />
+    <vdl:new type="string" value="/home/ketan/swift-install/0.93/cog/modules/swift/tests/cdm/absolute/outdir/out2.data" />
   </global>
-  <global name="swift#string#17008">
-    <vdl:new type="string" value="/home/ketan/cdm_tests/data1.txt" />
-  </global>
   <global name="swift#string#17000">
     <vdl:new type="string" value="s" />
   </global>
-  <global name="swift#string#17005">
-    <vdl:new type="string" value="/home/ketan/cdm_tests/out3.data" />
+  <global name="swift#string#17010">
+    <vdl:new type="string" value="/home/ketan/swift-install/0.93/cog/modules/swift/tests/cdm/absolute/indir/data4.txt" />
   </global>
   <global name="swift#string#17006">
-    <vdl:new type="string" value="/home/ketan/cdm_tests/out4.data" />
+    <vdl:new type="string" value="/home/ketan/swift-install/0.93/cog/modules/swift/tests/cdm/absolute/outdir/out4.data" />
   </global>
-  <global name="swift#string#17003">
-    <vdl:new type="string" value="/home/ketan/cdm_tests/out1.data" />
-  </global>
   <global name="swift#string#17009">
-    <vdl:new type="string" value="/home/ketan/cdm_tests/data2.txt" />
+    <vdl:new type="string" value="/home/ketan/swift-install/0.93/cog/modules/swift/tests/cdm/absolute/indir/data2.txt" />
   </global>
-  <global name="swift#string#17010">
-    <vdl:new type="string" value="/home/ketan/cdm_tests/data4.txt" />
+  <global name="swift#string#17008">
+    <vdl:new type="string" value="/home/ketan/swift-install/0.93/cog/modules/swift/tests/cdm/absolute/indir/data1.txt" />
   </global>
+  <global name="swift#string#17005">
+    <vdl:new type="string" value="/home/ketan/swift-install/0.93/cog/modules/swift/tests/cdm/absolute/outdir/out3.data" />
+  </global>
+  <global name="swift#string#17003">
+    <vdl:new type="string" value="/home/ketan/swift-install/0.93/cog/modules/swift/tests/cdm/absolute/outdir/out1.data" />
+  </global>
   <element name="catnap" arguments="o,_delay,i">
     <parameterlog>
     <string>input</string>
Modified: branches/release-0.93/tests/cdm/absolute/fr.kml
--- branches/release-0.93/tests/cdm/absolute/fr.kml	2011-11-14 20:27:14 UTC (rev 5292)
+++ branches/release-0.93/tests/cdm/absolute/fr.kml	2011-11-14 20:31:32 UTC (rev 5293)
@@ -13,35 +13,35 @@
   <global name="swift#string#17001">
   </global>
-  </global>
-    <vdl:new type="string" value="out1.data" />
-  </global>
   </global>
-  <global name="swift#string#17004">
-    <vdl:new type="string" value="out2.data" />
-  </global>
-  <global name="swift#string#17009">
-  </global>
   </global>
-    <vdl:new type="string" value="out4.data" />
+    <vdl:new type="string" value="./outdir/out4.data" />
   </global>
-    <vdl:new type="string" value="out3.data" />
+    <vdl:new type="string" value="./outdir/out3.data" />
   </global>
-  <element name="catnap" arguments="o,delay,i">
+  <global name="swift#string#17009">
+  </global>
+  </global>
+  <global name="swift#string#17004">
+    <vdl:new type="string" value="./outdir/out2.data" />
+  </global>
+    <vdl:new type="string" value="./outdir/out1.data" />
+  </global>
+  <element name="catnap" arguments="o,_delay,i">
     <parameterlog>
-    <string>delay</string>
-    <vdl:getdatasetprovenanceid var="{delay}" />
+    <string>_delay</string>
+    <vdl:getdatasetprovenanceid var="{_delay}" />
     <string>{#thread}</string>
     </parameterlog>
     <parameterlog>
@@ -59,11 +59,11 @@
     <log level="debug" message="PROCEDURE line=4 thread={#thread} name=catnap"/>
     <vdl:execute>
       <vdl:tr>catnap</vdl:tr>
-      <vdl:stagein var="{delay}"/>
+      <vdl:stagein var="{_delay}"/>
       <vdl:stagein var="{i}"/>
       <vdl:stageout var="{o}"/>
       <vdl:arguments>
-        <variable>delay</variable>
+        <variable>_delay</variable>
         <swiftscript:filename>
          <variable>i</variable>
         </swiftscript:filename>
Modified: branches/release-0.93/tests/cdm/absolute/rf.kml
--- branches/release-0.93/tests/cdm/absolute/rf.kml	2011-11-14 20:27:14 UTC (rev 5292)
+++ branches/release-0.93/tests/cdm/absolute/rf.kml	2011-11-14 20:31:32 UTC (rev 5293)
@@ -11,37 +11,37 @@
      </xs:schema>
   </types>
-    <vdl:new type="string" value="data1.txt" />
+    <vdl:new type="string" value="./indir/data1.txt" />
   </global>
   </global>
   </global>
   </global>
+    <vdl:new type="string" value="./indir/data4.txt" />
   </global>
-    <vdl:new type="string" value="data2.txt" />
+    <vdl:new type="string" value="./indir/data2.txt" />
   </global>
   </global>
+  </global>
   </global>
-    <vdl:new type="string" value="data4.txt" />
-  </global>
     <parameterlog>
     </parameterlog>
     <parameterlog>
@@ -59,11 +59,11 @@
     <vdl:execute>
       <vdl:arguments>
Modified: branches/release-0.93/tests/cdm/absolute/rr.kml
--- branches/release-0.93/tests/cdm/absolute/rr.kml	2011-11-14 20:27:14 UTC (rev 5292)
+++ branches/release-0.93/tests/cdm/absolute/rr.kml	2011-11-14 20:31:32 UTC (rev 5293)
@@ -11,37 +11,37 @@
      </xs:schema>
   </types>
   </global>
   </global>
-  </global>
   </global>
   </global>
-  </global>
   </global>
   </global>
   </global>
+  </global>
+  </global>
     <parameterlog>
     </parameterlog>
     <parameterlog>
@@ -59,11 +59,11 @@
     <vdl:execute>
       <vdl:arguments>
Modified: branches/release-0.93/tests/cdm/absolute/run.sh
--- branches/release-0.93/tests/cdm/absolute/run.sh	2011-11-14 20:27:14 UTC (rev 5292)
+++ branches/release-0.93/tests/cdm/absolute/run.sh	2011-11-14 20:31:32 UTC (rev 5293)
@@ -1,16 +1,16 @@
-swift -config cf.absolute -sites.file sites.xml -tc.file tc -cdm.file fs.ff -runid ff_config_abs  ff.swift
+swift -config cf.absolute -sites.file sites.xml -tc.file tc -cdm.file fs.data -runid ff_config_abs  ff.swift
-swift -config cf.absolute -sites.file sites.xml -tc.file tc -cdm.file fs.ff -runid fr_config_abs  fr.swift
+swift -config cf.absolute -sites.file sites.xml -tc.file tc -cdm.file fs.data -runid fr_config_abs  fr.swift
-swift -config cf.absolute -sites.file sites.xml -tc.file tc -cdm.file fs.ff -runid rf_config_abs rf.swift
+swift -config cf.absolute -sites.file sites.xml -tc.file tc -cdm.file fs.data -runid rf_config_abs rf.swift
-swift -config cf.absolute -sites.file sites.xml -tc.file tc -cdm.file fs.ff -runid rr_config_abs rr.swift
+swift -config cf.absolute -sites.file sites.xml -tc.file tc -cdm.file fs.data -runid rr_config_abs rr.swift
-swift -config cf.relative -sites.file sites.xml -tc.file tc -cdm.file fs.ff -runid ff_config_rel ff.swift
+swift -config cf.relative -sites.file sites.xml -tc.file tc -cdm.file fs.data -runid ff_config_rel ff.swift
-swift -config cf.relative -sites.file sites.xml -tc.file tc -cdm.file fs.ff -runid fr_config_rel fr.swift
+swift -config cf.relative -sites.file sites.xml -tc.file tc -cdm.file fs.data -runid fr_config_rel fr.swift
-swift -config cf.relative -sites.file sites.xml -tc.file tc -cdm.file fs.ff -runid rf_config_rel rf.swift
+swift -config cf.relative -sites.file sites.xml -tc.file tc -cdm.file fs.data -runid rf_config_rel rf.swift
-swift -config cf.relative -sites.file sites.xml -tc.file tc -cdm.file fs.ff -runid rr_config_rel rr.swift
+swift -config cf.relative -sites.file sites.xml -tc.file tc -cdm.file fs.data -runid rr_config_rel rr.swift
