[Swift-commit] r4204 - in trunk: docs etc/sites etc/sites/cnari-abe etc/sites/cnari-queenbee etc/sites/cnari-ranger etc/sites/local-pbs-coasters etc/sites/pads-local-pbs-coasters etc/sites/pads-remote-pbs-coasters-ssh etc/sites/teraport-local-pbs-coasters etc/sites/teraport-remote-pbs-coasters-ssh libexec tests/cdm/ps tests/cdm/ps/pinned tests/mpi tests/providers/local-cobalt/intrepid tests/providers/local-cobalt/surveyor tests/providers/local-pbs-coasters tests/providers/local-sge-coasters tests/providers/ssh-pbs-coasters
Tue Mar 22 13:47:41 CDT 2011
Author: wozniak
Date: 2011-03-22 13:47:41 -0500 (Tue, 22 Mar 2011)
New Revision: 4204
Added:
   trunk/etc/sites/cnari-abe/
   trunk/etc/sites/cnari-queenbee/
   trunk/etc/sites/cnari-ranger/
   trunk/etc/sites/local-pbs-coasters/
   trunk/etc/sites/pads-local-pbs-coasters/
   trunk/etc/sites/pads-remote-pbs-coasters-ssh/
   trunk/etc/sites/teraport-local-pbs-coasters/
   trunk/etc/sites/teraport-remote-pbs-coasters-ssh/
Modified:
   trunk/docs/userguide.xml
   trunk/etc/sites/cnari-abe/sites.xml
   trunk/etc/sites/cnari-queenbee/sites.xml
   trunk/etc/sites/cnari-ranger/sites.xml
   trunk/etc/sites/intrepid
   trunk/etc/sites/local-pbs-coasters/sites.xml
   trunk/etc/sites/pads-local-pbs-coasters/sites.xml
   trunk/etc/sites/pads-remote-pbs-coasters-ssh/sites.xml
   trunk/etc/sites/ssh-pbs-coasters
   trunk/etc/sites/surveyor
   trunk/etc/sites/teraport-local-pbs-coasters/sites.xml
   trunk/etc/sites/teraport-remote-pbs-coasters-ssh/sites.xml
   trunk/libexec/vdl-sc.k
   trunk/tests/cdm/ps/pinned/sites.template.xml
   trunk/tests/cdm/ps/sites.template.xml
   trunk/tests/mpi/sites.template.xml
   trunk/tests/providers/local-cobalt/intrepid/sites.template.xml
   trunk/tests/providers/local-cobalt/surveyor/sites.template.xml
   trunk/tests/providers/local-pbs-coasters/sites.template.xml
   trunk/tests/providers/local-sge-coasters/sites.template.xml
   trunk/tests/providers/ssh-pbs-coasters/sites.template.xml
Log:
Rename workersPerNode to jobsPerNode
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/docs/userguide.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -3288,14 +3288,14 @@
 specifies the maximum number of jobs/blocks that the coaster scheduler will have running at any given time.
 The default is 20.
 			</para>
-			<para id="profile.workersPerNode"><literal>workersPerNode</literal>
+			<para id="profile.jobsPerNode"><literal>jobsPerNode</literal>
 This parameter determines how many coaster workers are
 started one each compute node. The default value is 1.
 			</para>
 			<para id="profile.nodeGranularity"><literal>nodeGranularity</literal>
 When allocating a coaster worker block, this parameter
 restricts the number of nodes in a block to a multiple of this value. The total number of workers will
-then be a multiple of workersPerNode * nodeGranularity. The default value is 1.
+then be a multiple of jobsPerNode * nodeGranularity. The default value is 1.
 			</para>
 			<para id="profile.allocationStepSize"><literal>allocationStepSize</literal>
 Each time the coaster block scheduler computes a schedule, it will attempt to allocate a
@@ -3987,13 +3987,13 @@
   <thead><row><entry>profile key</entry><entry>brief description</entry></row></thead>
   <tbody>
    <row><entry>slots</entry><entry>How many maximum LRM jobs/worker blocks are allowed</entry></row>
-   <row><entry>workersPerNode</entry><entry>How many coaster workers to run per execution node</entry></row>
+   <row><entry>jobsPerNode</entry><entry>How many coaster workers to run per execution node</entry></row>
    <row><entry>nodeGranularity</entry><entry>Each worker block uses a number of nodes that is a multiple of this number</entry></row>
    <row><entry>lowOverallocation</entry><entry>How many times larger than the job walltime should a block's walltime be if all jobs are 1s long</entry></row>
    <row><entry>highOverallocation</entry><entry>How many times larger than the job walltime should a block's walltime be if all jobs are infinitely long</entry></row>
    <row><entry>overallocationDecayFactor</entry><entry>How quickly should the overallocation curve tend towards the highOverallocation as job walltimes get larger</entry></row>
    <row><entry>spread</entry><entry>By how much should worker blocks vary in worker size</entry></row>
    <row><entry>reserve</entry><entry>How many seconds to reserve in a block's walltime for starting/shutdown operations</entry></row>
    <row><entry>maxnodes</entry><entry>The maximum number of nodes allowed in a block</entry></row>
    <row><entry>maxtime</entry><entry>The maximum number of walltime allowed for a block</entry></row>
Copied: trunk/etc/sites/cnari-abe (from rev 4199, trunk/etc/sites/cnari-abe)
Modified: trunk/etc/sites/cnari-abe/sites.xml
--- trunk/etc/sites/cnari-abe/sites.xml	2011-03-18 19:08:14 UTC (rev 4199)
+++ trunk/etc/sites/cnari-abe/sites.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -5,14 +5,14 @@
     <profile namespace="globus" key="maxTime">172800</profile>
     <profile namespace="globus" key="slots">10</profile>
     <profile namespace="globus" key="maxNodes">8</profile>
-    <profile namespace="globus" key="workersPerNode">8</profile>
+    <profile namespace="globus" key="jobsPerNode">8</profile>
     <profile namespace="globus" key="nodeGranularity">8</profile>
     <profile namespace="globus" key="queue">normal</profile>
     <profile namespace="globus" key="project">TG-DBS080004N</profile>
     <profile namespace="globus" key="name">configtest</profile>
     <filesystem provider="gsiftp" url="gsiftp://gridftp-abe.ncsa.teragrid.org"/>
     <execution provider="coaster" jobManager="gt2:gt2:PBS" url="grid-abe.ncsa.teragrid.org"/>
     <workdirectory>/scratch/users/sidgrid/$USER</workdirectory>
 </pool>
Copied: trunk/etc/sites/cnari-queenbee (from rev 4199, trunk/etc/sites/cnari-queenbee)
Modified: trunk/etc/sites/cnari-queenbee/sites.xml
--- trunk/etc/sites/cnari-queenbee/sites.xml	2011-03-18 19:08:14 UTC (rev 4199)
+++ trunk/etc/sites/cnari-queenbee/sites.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -5,14 +5,14 @@
       <profile namespace="globus" key="queue">workq</profile>
       <filesystem provider="gsiftp" url="gridftp-qb.loni-lsu.teragrid.org:2811"/>
       <execution provider="coaster" jobManager="gt2:gt2:PBS" url="grid-qb.loni-lsu.teragrid.org:2120"/>
       <workdirectory>/work/scommuni/$USER</workdirectory>
 </pool>
Copied: trunk/etc/sites/cnari-ranger (from rev 4199, trunk/etc/sites/cnari-ranger)
Modified: trunk/etc/sites/cnari-ranger/sites.xml
--- trunk/etc/sites/cnari-ranger/sites.xml	2011-03-18 19:08:14 UTC (rev 4199)
+++ trunk/etc/sites/cnari-ranger/sites.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -5,12 +5,12 @@
-      <profile namespace="globus" key="workersPerNode">16</profile>
+      <profile namespace="globus" key="jobsPerNode">16</profile>
       <profile namespace="globus" key="nodeGranularity">16</profile>
       <profile namespace="globus" key="queue">long</profile>
       <filesystem provider="gsiftp" url="gsiftp://gridftp.ranger.tacc.teragrid.org"/>
       <execution provider="coaster" jobManager="gt2:gt2:SGE" url="gatekeeper.ranger.tacc.teragrid.org"/>
       <workdirectory>/work/00926/tg459516/sidgrid_out/$USER</workdirectory>
 </pool>
Modified: trunk/etc/sites/intrepid
--- trunk/etc/sites/intrepid	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/etc/sites/intrepid	2011-03-22 18:47:41 UTC (rev 4204)
@@ -20,7 +20,7 @@
     <profile namespace="globus"  key="alcfbgpnat">true</profile>
     <profile namespace="karajan" key="jobthrottle">21</profile>
     <profile namespace="karajan" key="initialScore">10000</profile>
-    <profile namespace="globus"  key="workersPerNode">1</profile>
+    <profile namespace="globus"  key="jobsPerNode">1</profile>
     <profile namespace="globus"  key="workerLoggingLevel">DEBUG</profile>
     <profile namespace="globus"  key="slots">1</profile>
     <profile namespace="globus"  key="maxTime">900</profile> <!-- seconds -->
Copied: trunk/etc/sites/local-pbs-coasters (from rev 4199, trunk/etc/sites/local-pbs-coasters)
Modified: trunk/etc/sites/local-pbs-coasters/sites.xml
--- trunk/etc/sites/local-pbs-coasters/sites.xml	2011-03-18 19:08:14 UTC (rev 4199)
+++ trunk/etc/sites/local-pbs-coasters/sites.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -3,7 +3,7 @@
     <execution provider="coaster" url="none" jobmanager="local:pbs" />
     <workdirectory>$HOME/swiftwork</workdirectory>
     <profile namespace="globus" key="maxtime">3000</profile>
     <profile namespace="globus" key="nodeGranularity">1</profile>
     <profile namespace="globus" key="maxNodes">10</profile>
Copied: trunk/etc/sites/pads-local-pbs-coasters (from rev 4199, trunk/etc/sites/pads-local-pbs-coasters)
Modified: trunk/etc/sites/pads-local-pbs-coasters/sites.xml
--- trunk/etc/sites/pads-local-pbs-coasters/sites.xml	2011-03-18 19:08:14 UTC (rev 4199)
+++ trunk/etc/sites/pads-local-pbs-coasters/sites.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -3,7 +3,7 @@
Copied: trunk/etc/sites/pads-remote-pbs-coasters-ssh (from rev 4199, trunk/etc/sites/pads-remote-pbs-coasters-ssh)
Modified: trunk/etc/sites/pads-remote-pbs-coasters-ssh/sites.xml
--- trunk/etc/sites/pads-remote-pbs-coasters-ssh/sites.xml	2011-03-18 19:08:14 UTC (rev 4199)
+++ trunk/etc/sites/pads-remote-pbs-coasters-ssh/sites.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -1,7 +1,7 @@
 <pool handle="pads-remote-pbs-coasters-ssh">
    <execution provider="coaster" url="login1.pads.ci.uchicago.edu" jobmanager="ssh:pbs" />
Modified: trunk/etc/sites/ssh-pbs-coasters
--- trunk/etc/sites/ssh-pbs-coasters	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/etc/sites/ssh-pbs-coasters	2011-03-22 18:47:41 UTC (rev 4204)
@@ -3,7 +3,7 @@
   <execution jobmanager="ssh:pbs" provider="coaster" url="login1.pads.ci.uchicago.edu" />
   <filesystem provider="ssh" url="login1.pads.ci.uchicago.edu" />
   <profile key="maxtime" namespace="globus">3000</profile>
-  <profile key="workersPerNode" namespace="globus">8</profile>
+  <profile key="jobsPerNode" namespace="globus">8</profile>
   <profile key="slots" namespace="globus">1</profile>
   <profile key="nodeGranularity" namespace="globus">1</profile>
   <profile key="maxNodes" namespace="globus">10</profile>
Modified: trunk/etc/sites/surveyor
--- trunk/etc/sites/surveyor	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/etc/sites/surveyor	2011-03-22 18:47:41 UTC (rev 4204)
@@ -10,7 +10,7 @@
Copied: trunk/etc/sites/teraport-local-pbs-coasters (from rev 4199, trunk/etc/sites/teraport-local-pbs-coasters)
Modified: trunk/etc/sites/teraport-local-pbs-coasters/sites.xml
--- trunk/etc/sites/teraport-local-pbs-coasters/sites.xml	2011-03-18 19:08:14 UTC (rev 4199)
+++ trunk/etc/sites/teraport-local-pbs-coasters/sites.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -3,7 +3,7 @@
Copied: trunk/etc/sites/teraport-remote-pbs-coasters-ssh (from rev 4199, trunk/etc/sites/teraport-remote-pbs-coasters-ssh)
Modified: trunk/etc/sites/teraport-remote-pbs-coasters-ssh/sites.xml
--- trunk/etc/sites/teraport-remote-pbs-coasters-ssh/sites.xml	2011-03-18 19:08:14 UTC (rev 4199)
+++ trunk/etc/sites/teraport-remote-pbs-coasters-ssh/sites.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -1,7 +1,7 @@
 <pool handle="teraport-remote-pbs-coasters-ssh">
    <execution provider="coaster" url="tp-login2.ci.uchicago.edu" jobmanager="ssh:pbs" />
Modified: trunk/libexec/vdl-sc.k
--- trunk/libexec/vdl-sc.k	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/libexec/vdl-sc.k	2011-03-22 18:47:41 UTC (rev 4204)
@@ -72,7 +72,7 @@
 			element(intrepidCoasterParams, [optional(averageJobTime, blockSize)]
 				print("Setting Intrepid coaster params:")
 				p("scratch", "/scratch")
-				p("workersPerNode", "4")
+				p("jobsPerNode", "4")
 				p("kernelprofile", "zeptoos")
 				p("alcfbgpnat", "true")
 				maybe(
@@ -91,7 +91,7 @@
 			element(surveyorCoasterParams, [optional(averageJobTime, blockSize)]
 				print("Setting Surveyor coaster params:")
 				maybe(
Modified: trunk/tests/cdm/ps/pinned/sites.template.xml
--- trunk/tests/cdm/ps/pinned/sites.template.xml	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/tests/cdm/ps/pinned/sites.template.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -13,7 +13,7 @@
     <profile namespace="globus"   key="internalHostname">_HOST_</profile>
     <profile namespace="karajan"  key="jobthrottle">2.55</profile>
-    <profile namespace="globus"   key="workersPerNode">4</profile>
+    <profile namespace="globus"   key="jobsPerNode">4</profile>
     <profile namespace="globus"   key="slots">8</profile>
     <profile namespace="globus"   key="maxTime">1000</profile>
Modified: trunk/tests/cdm/ps/sites.template.xml
--- trunk/tests/cdm/ps/sites.template.xml	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/tests/cdm/ps/sites.template.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -13,7 +13,7 @@
Modified: trunk/tests/mpi/sites.template.xml
--- trunk/tests/mpi/sites.template.xml	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/tests/mpi/sites.template.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -13,7 +13,7 @@
Modified: trunk/tests/providers/local-cobalt/intrepid/sites.template.xml
--- trunk/tests/providers/local-cobalt/intrepid/sites.template.xml	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/tests/providers/local-cobalt/intrepid/sites.template.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -20,7 +20,7 @@
Modified: trunk/tests/providers/local-cobalt/surveyor/sites.template.xml
--- trunk/tests/providers/local-cobalt/surveyor/sites.template.xml	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/tests/providers/local-cobalt/surveyor/sites.template.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -10,7 +10,7 @@
Modified: trunk/tests/providers/local-pbs-coasters/sites.template.xml
--- trunk/tests/providers/local-pbs-coasters/sites.template.xml	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/tests/providers/local-pbs-coasters/sites.template.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -4,7 +4,7 @@
   <filesystem provider="local" url="none" />
   <profile namespace="globus" key="maxWallTime">1</profile>
   <profile namespace="globus" key="maxTime">7200</profile>
-  <profile key="workersPerNode" namespace="globus">1</profile>
+  <profile key="jobsPerNode" namespace="globus">1</profile>
   <profile key="maxNodes" namespace="globus">1</profile>
Modified: trunk/tests/providers/local-sge-coasters/sites.template.xml
--- trunk/tests/providers/local-sge-coasters/sites.template.xml	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/tests/providers/local-sge-coasters/sites.template.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -4,7 +4,7 @@
   <profile key="nodeGranularity" namespace="globus">16</profile>
   <profile key="maxNodes" namespace="globus">16</profile>
Modified: trunk/tests/providers/ssh-pbs-coasters/sites.template.xml
--- trunk/tests/providers/ssh-pbs-coasters/sites.template.xml	2011-03-21 21:24:01 UTC (rev 4203)
+++ trunk/tests/providers/ssh-pbs-coasters/sites.template.xml	2011-03-22 18:47:41 UTC (rev 4204)
@@ -3,7 +3,7 @@
