[Swift-commit] r4187 - in usertools/plotter: samples/dual src/plotter
Mon Mar 14 23:48:23 CDT 2011
Author: wozniak
Date: 2011-03-14 23:48:23 -0500 (Mon, 14 Mar 2011)
New Revision: 4187
Modified:
   usertools/plotter/samples/dual/plot.cfg
   usertools/plotter/samples/dual/set2.data
   usertools/plotter/src/plotter/Dual.java
Log:
Two data sets, two axes
Modified: usertools/plotter/samples/dual/plot.cfg
--- usertools/plotter/samples/dual/plot.cfg	2011-03-15 03:57:11 UTC (rev 4186)
+++ usertools/plotter/samples/dual/plot.cfg	2011-03-15 04:48:23 UTC (rev 4187)
@@ -1,3 +1,4 @@
 title = Sample
 xlabel = Input
@@ -4,6 +5,11 @@
 ylabel1 = Output
 ylabel2 = Secondary
+ymin1 = -10
+ymax1 = 30
+ymin2 = -10
+ymax2 = 300
 label.set1.data = Set 1
 label.set2.data = Set 2
Modified: usertools/plotter/samples/dual/set2.data
--- usertools/plotter/samples/dual/set2.data	2011-03-15 03:57:11 UTC (rev 4186)
+++ usertools/plotter/samples/dual/set2.data	2011-03-15 04:48:23 UTC (rev 4187)
@@ -1,2 +1,2 @@
 0 -1
-4 3
+4 300
Modified: usertools/plotter/src/plotter/Dual.java
--- usertools/plotter/src/plotter/Dual.java	2011-03-15 03:57:11 UTC (rev 4186)
+++ usertools/plotter/src/plotter/Dual.java	2011-03-15 04:48:23 UTC (rev 4187)
@@ -18,6 +18,7 @@
 import org.jfree.chart.renderer.xy.XYLineAndShapeRenderer;
 import org.jfree.data.Range;
 import org.jfree.data.general.Series;
+import org.jfree.data.xy.XYSeries;
 import org.jfree.data.xy.XYSeriesCollection;
@@ -36,9 +37,12 @@
   // null indicates the value was not set by the user
   static Double xmin = null;
   static Double xmax = null;
-  static Double ymin = null;
-  static Double ymax = null;
+  static Double ymin1 = null;
+  static Double ymax1 = null;
+  static Double ymin2 = null;
+  static Double ymax2 = null;
      Generate simple plot
      @param collection The x,y data
@@ -48,7 +52,7 @@
      @param ylabel2 Y label text
      @param output EPS filename
-  public static boolean plot(XYSeriesCollection collection,
+  public static boolean plot(XYSeriesCollection[] collections,
                              String title, String xlabel,
                              String ylabel1, String ylabel2,
                              String output)
@@ -82,10 +86,10 @@
     JFreeChart chart =
       ChartFactory.createXYLineChart
-      (title, xlabel, ylabel1, collection,
+      (title, xlabel, ylabel1, collections[0],
        PlotOrientation.VERTICAL, withLegend, false, false);
-    setupPlot(chart, collection, ylabel2);
+    setupPlot(chart, collections, ylabel1, ylabel2);
     chart.draw(g2d, rectangle);
     try
@@ -104,34 +108,41 @@
   private static void setupPlot(JFreeChart chart,
-                                XYSeriesCollection collection,
-                                String ylabel2)
+                                XYSeriesCollection[] collections,
+                                String ylabel1, String ylabel2)
     XYPlot plot = chart.getXYPlot();
-    XYLineAndShapeRenderer renderer = new XYLineAndShapeRenderer();
+    XYLineAndShapeRenderer renderer1 = new XYLineAndShapeRenderer();
+    XYLineAndShapeRenderer renderer2 = new XYLineAndShapeRenderer();
     int count = plot.getSeriesCount();
-    if (count != 2)
-      Util.fatal("dual plot must have two data sets!");
     if (bw)
       for (int i = 0; i < count; i++)
-        renderer.setSeriesPaint(i, Color.BLACK);
-    Series series1 = collection.getSeries(0);
+        renderer1.setSeriesPaint(i, Color.BLACK);
+        renderer2.setSeriesPaint(i, Color.BLACK);
+    Series series1 = collections[0].getSeries(0);
     if (! showShape(series1.getDescription()))
-      renderer.setSeriesShapesVisible(0, false);
-    Series series2 = collection.getSeries(1);
+      renderer1.setSeriesShapesVisible(0, false);
+    Series series2 = collections[1].getSeries(0);
     if (! showShape(series2.getDescription()))
-      renderer.setSeriesShapesVisible(1, false);
+      renderer2.setSeriesShapesVisible(1, false);
     Plots.setupLegend(chart, properties);
-    setAxes(plot, ylabel2);
-    plot.setRenderer(renderer);
+    setAxes(plot, ylabel1, ylabel2, collections[1]);
+    plot.setRenderer(0, renderer1);
+    plot.setRenderer(1, renderer2);
     plot.setBackgroundPaint(Color.WHITE);
-  static void setAxes(XYPlot plot, String ylabel2)
+  static void setAxes(XYPlot plot, String ylabel1, String ylabel2,
+                      XYSeriesCollection collection)
+    plot.setDataset(1, collection);
     // Actual values: modify if necessary
-    double axmin, axmax, aymin, aymax;
+    double axmin, axmax, aymin1, aymax1, aymin2, aymax2;
     if (xmin != null || xmax != null)
@@ -146,23 +157,38 @@
     // Left Y axis
-    if (ymin != null || ymax != null)
+    if (ymin1 != null || ymax1 != null)
-      NumberAxis axis = new NumberAxis();
+      NumberAxis axis = new NumberAxis(ylabel1);
       plot.setRangeAxis(0, axis);
       Range range = axis.getRange();
-      aymin = range.getLowerBound();
-      aymax = range.getUpperBound();
-      if (ymin != null) aymin = ymin;
-      if (ymax != null) aymax = ymax;
-      axis.setRange(aymin, aymax);
+      aymin1 = range.getLowerBound();
+      aymax1 = range.getUpperBound();
+      if (ymin1 != null) aymin1 = ymin1;
+      if (ymax1 != null) aymax1 = ymax1;
+      axis.setRange(aymin1, aymax1);
-    // Right Y axis
+    // Right Y axis setup
     Font font = plot.getRangeAxis().getLabelFont();
     final NumberAxis rightAxis = new NumberAxis(ylabel2);
     rightAxis.setLabelFont(font);
     plot.setRangeAxis(1, rightAxis);
+    // Right Y axis
+    if (ymin2 != null || ymax2 != null)
+      Range range = rightAxis.getRange();
+      aymin2 = range.getLowerBound();
+      aymax2 = range.getUpperBound();
+      if (ymin2 != null) aymin2 = ymin2;
+      if (ymax2 != null) aymax2 = ymax2;
+      rightAxis.setRange(aymin2, aymax2);
+    plot.mapDatasetToRangeAxis(0, 0);
+    plot.mapDatasetToRangeAxis(1, 1);
+    plot.configureRangeAxes();
@@ -240,12 +266,45 @@
       Util.verbose("array:\n" + toString(array));
-    XYSeriesCollection collection = Util.collection(data, labels,
-                                                    names);
+    XYSeriesCollection[] collections =
+      collections(data, labels, names);
-    plot(collection, title, xlabel, ylabel1, ylabel2, output);
+    plot(collections, title, xlabel, ylabel1, ylabel2, output);
+  static XYSeriesCollection[] collections(List<double[][]> data,
+                                          List<String> labels,
+                                          List<String> names)
+    final XYSeriesCollection[] result = new XYSeriesCollection[2];
+    result[0] = new XYSeriesCollection();
+    result[1] = new XYSeriesCollection();
+    int count = 0;
+    for (int i = 0; i < 2; i++)
+      double[][] d = data.get(i);
+      String label = "data: " + count;
+      try
+        label = labels.get(count);
+      catch (IndexOutOfBoundsException e)
+      XYSeries series = new XYSeries(label);
+      for (int j = 0; j < d.length; j++)
+        series.add(d[j][0], d[j][1]);
+      series.setDescription(names.get(count));
+      result[i].addSeries(series);
+      count++;
+    return result;
   static void load(String propFile)
     try
@@ -282,7 +341,8 @@
      label.file.data = legend text
      width (output image width)
      height (output image height)
-     xmin, xmax, ymin, ymax (auto-selected if not given)
+     xmin, xmax, ymin1, ymax1, ymin2, ymax2
+         (auto-selected if not given)
      bw (Black and white, true/false, default false)
   static void scanProperties()
@@ -300,12 +360,19 @@
     tmp = properties.getProperty("xmax");
     if (tmp != null)
       xmax = Double.parseDouble(tmp);
-    tmp = properties.getProperty("ymin");
+    tmp = properties.getProperty("ymin1");
     if (tmp != null)
-      ymin = Double.parseDouble(tmp);
-    tmp = properties.getProperty("ymax");
+      ymin1 = Double.parseDouble(tmp);
+    tmp = properties.getProperty("ymax1");
     if (tmp != null)
-      ymax = Double.parseDouble(tmp);
+      ymax1 = Double.parseDouble(tmp);
+    tmp = properties.getProperty("ymin2");
+    if (tmp != null)
+      ymin2 = Double.parseDouble(tmp);
+    tmp = properties.getProperty("ymax2");
+    if (tmp != null)
+      ymax2 = Double.parseDouble(tmp);
     tmp = properties.getProperty("bw");
     if (tmp != null)
       bw = Boolean.parseBoolean(tmp);
