[Swift-commit] r4185 - in usertools/plotter/samples: . dual
Mon Mar 14 22:46:04 CDT 2011
Author: wozniak
Date: 2011-03-14 22:46:04 -0500 (Mon, 14 Mar 2011)
New Revision: 4185
Added:
   usertools/plotter/samples/dual/
   usertools/plotter/samples/dual/About.txt
   usertools/plotter/samples/dual/plot.cfg
   usertools/plotter/samples/dual/set1.data
   usertools/plotter/samples/dual/set2.data
Log:
Test case for dual Y axis plots
Copied: usertools/plotter/samples/dual (from rev 4180, usertools/plotter/samples/lines)
Copied: usertools/plotter/samples/dual/About.txt (from rev 4182, usertools/plotter/samples/lines/About.txt)
--- usertools/plotter/samples/dual/About.txt	                        (rev 0)
+++ usertools/plotter/samples/dual/About.txt	2011-03-15 03:46:04 UTC (rev 4185)
@@ -0,0 +1,5 @@
+To run:
+../../lines.zsh plot.cfg tmp.eps set*.data
Copied: usertools/plotter/samples/dual/plot.cfg (from rev 4183, usertools/plotter/samples/lines/plot.cfg)
--- usertools/plotter/samples/dual/plot.cfg	                        (rev 0)
+++ usertools/plotter/samples/dual/plot.cfg	2011-03-15 03:46:04 UTC (rev 4185)
@@ -0,0 +1,9 @@
+title = Sample
+xlabel = Input
+ylabel = Output
+label.set1.data = Set 1
+label.set2.data = Set 2
+legend.font = Lucida Sans Unicode Regular
Copied: usertools/plotter/samples/dual/set1.data (from rev 4182, usertools/plotter/samples/lines/set1.data)
--- usertools/plotter/samples/dual/set1.data	                        (rev 0)
+++ usertools/plotter/samples/dual/set1.data	2011-03-15 03:46:04 UTC (rev 4185)
@@ -0,0 +1,2 @@
+1 2
+2 4
Copied: usertools/plotter/samples/dual/set2.data (from rev 4182, usertools/plotter/samples/lines/set2.data)
--- usertools/plotter/samples/dual/set2.data	                        (rev 0)
+++ usertools/plotter/samples/dual/set2.data	2011-03-15 03:46:04 UTC (rev 4185)
@@ -0,0 +1,2 @@
+0 -1
+4 3
