[Swift-commit] r4182 - usertools/plotter/samples/lines
Mon Mar 14 21:56:57 CDT 2011
Author: wozniak
Date: 2011-03-14 21:56:57 -0500 (Mon, 14 Mar 2011)
New Revision: 4182
Added:
   usertools/plotter/samples/lines/About.txt
   usertools/plotter/samples/lines/plot.cfg
   usertools/plotter/samples/lines/set1.data
   usertools/plotter/samples/lines/set2.data
Log:
Sample case
Added: usertools/plotter/samples/lines/About.txt
--- usertools/plotter/samples/lines/About.txt	                        (rev 0)
+++ usertools/plotter/samples/lines/About.txt	2011-03-15 02:56:57 UTC (rev 4182)
@@ -0,0 +1,5 @@
+To run:
+../../lines.zsh plot.cfg tmp.eps set*.data
Added: usertools/plotter/samples/lines/plot.cfg
--- usertools/plotter/samples/lines/plot.cfg	                        (rev 0)
+++ usertools/plotter/samples/lines/plot.cfg	2011-03-15 02:56:57 UTC (rev 4182)
@@ -0,0 +1,7 @@
+title = Sample
+xlabel = Input
+ylabel = Output
+label.set1.data = Set 1
+label.set2.data = Set 2
Added: usertools/plotter/samples/lines/set1.data
--- usertools/plotter/samples/lines/set1.data	                        (rev 0)
+++ usertools/plotter/samples/lines/set1.data	2011-03-15 02:56:57 UTC (rev 4182)
@@ -0,0 +1,2 @@
+1 2
+2 4
Added: usertools/plotter/samples/lines/set2.data
--- usertools/plotter/samples/lines/set2.data	                        (rev 0)
+++ usertools/plotter/samples/lines/set2.data	2011-03-15 02:56:57 UTC (rev 4182)
@@ -0,0 +1,2 @@
+0 -1
+4 3
