[Swift-commit] r4177 - in SwiftApps/SwiftR: . Swift Swift/R
Mon Mar 14 17:00:33 CDT 2011
Author: tga
Date: 2011-03-14 17:00:33 -0500 (Mon, 14 Mar 2011)
New Revision: 4177
Modified:
   SwiftApps/SwiftR/IMMEDIATE-TODO
   SwiftApps/SwiftR/Swift/NAMESPACE
   SwiftApps/SwiftR/Swift/R/Apply.R
   SwiftApps/SwiftR/Swift/R/Tests.R
Log:
Added in implementation of swiftSapply function.
Modified: SwiftApps/SwiftR/IMMEDIATE-TODO
--- SwiftApps/SwiftR/IMMEDIATE-TODO	2011-03-14 18:08:37 UTC (rev 4176)
+++ SwiftApps/SwiftR/IMMEDIATE-TODO	2011-03-14 22:00:33 UTC (rev 4177)
@@ -5,6 +5,8 @@
+VERY HIGH:
+-- get working on beagle.
 VERY HIGH:
 -- Benchmarks
@@ -18,8 +20,6 @@
 HIGH:
 -- Feedback from queue
-HIGH:
--- get working on beagle.
 HIGH:
 -- Test on Mac
@@ -44,22 +44,12 @@
 -- Add OpenMx tests to test suite
 HIGH:
-- tests
--- simple calibration tests (n args, arg sizes, durations, etc)
--- openmx tests
-  --- OmxParallelCI
-  --- OmxParallelBootstrap
-HIGH:
 - perf approach
  -- socket?
- -- swift fast branch?
  -- swift times?
  -- micro studies on provider staging etc.
 MID:
 - test on Ranger
 MID:
Modified: SwiftApps/SwiftR/Swift/NAMESPACE
--- SwiftApps/SwiftR/Swift/NAMESPACE	2011-03-14 18:08:37 UTC (rev 4176)
+++ SwiftApps/SwiftR/Swift/NAMESPACE	2011-03-14 22:00:33 UTC (rev 4177)
@@ -1,5 +1,6 @@
 export(swiftapply)
 export(swiftLapply)
+export(swiftSapply)
 export(swiftInit)
 export(getNodeList)
 export(swiftShutdown)
Modified: SwiftApps/SwiftR/Swift/R/Apply.R
--- SwiftApps/SwiftR/Swift/R/Apply.R	2011-03-14 18:08:37 UTC (rev 4176)
+++ SwiftApps/SwiftR/Swift/R/Apply.R	2011-03-14 22:00:33 UTC (rev 4177)
@@ -122,7 +122,49 @@
   swiftapply(func, arglists)
+swiftSapply <- function( tlist, func, ..., simplify=TRUE, USE.NAMES=TRUE) {
+    # replicate sapply behaviour:
+    # simplify to 1d vector or 2d matrix if possible
+    res <- swiftLapply(tlist, func, ...)
+    if (USE.NAMES) {
+        # same rules as sapply
+        if (is.null(names(res)) && is.character(tlist)) {
+            names(res) <- tlist
+    if (simplify && length(res) > 0) {
+        # Check to see if list is multidimensional
+        lens <- unique(lapply(res, length))
+        if (length(lens) != 1) {
+            # ragged list, can't simplify
+            return (res)
+        else {
+            if (lens == 1) {
+                # just a plain list
+                return (unlist(res, recursive=F))
+            else {
+                # multidimensional list: convert to 2d matrix
+                res <- unlist(res, recursive=F)
+                if (!(is.null(n1 <- names(res[[1]]))) &&
+                    !(is.null(n2 <- names(res)))) {
+                    # names of first and second dimnesion
+                    dimnames <- list(n1, n2)
+                else {
+                    dimnames <- NULL
+                res <- array(res, dim=c(lens, length(tlist)),
+                        dimnames=dimnames)
+                return(res)
+    return (res)
 setupRequestDir <- function (tmpdir) {
   # Initialize globals if first call in this invocation of R
   # Use the options mechanism so that setting is tied
Modified: SwiftApps/SwiftR/Swift/R/Tests.R
--- SwiftApps/SwiftR/Swift/R/Tests.R	2011-03-14 18:08:37 UTC (rev 4176)
+++ SwiftApps/SwiftR/Swift/R/Tests.R	2011-03-14 22:00:33 UTC (rev 4177)
@@ -586,8 +586,69 @@
       return (FALSE)
+swiftTest_6.1 <- function () {
+    # test sapply
+    args <- list(1,2,3,4,5,6,7)
+    parRes <- swiftSapply(args, log)
+    serRes <- sapply(args, log)
+    if (!all(parRes == serRes)) {
+        cat("\n!!!==> test 6.1 failed.\n")
+        cat(paste("actual: ", parRes, "\nexpected:", serRes, "\n"))
+        return (FALSE)
+    if (is.list(parRes)) {
+        cat("parRes is a list\n")
+        return (FALSE)
+    cat("\n!!!==> test 6.1 passed.\n")
+    return (TRUE)
+swiftTest_6.2 <- function () {
+    # test sapply
+    args <- list(list(1,2),list(3),list(4,5),list(6,7))
+    f <- function (x) {lapply(x, function(y) { y * 2 })}
+    serRes <- sapply(args, f)
+    parRes <- swiftSapply(args, f)
+    if (!identical(parRes, serRes)) {
+        cat("\n!!!==> test 6.2 failed.\n")
+        return (FALSE)
+    if (!is.list(parRes)) {
+        cat("parRes is not a list\n")
+        return (FALSE)
+    cat("\n!!!==> test 6.2 passed.\n")
+    return (TRUE)
+swiftTest_6.3 <- function () {
+    # test sapply forms matrix ok
+    args <- list(list(1,2),list(3, 5),list(4,5),list(6,7))
+    if (!identical(parRes, serRes) || (!is.matrix(parRes))) {
+        cat("\n!!!==> test 6.3 failed.\n")
+        return (FALSE)
+    cat("\n!!!==> test 6.3 passed.\n")
+    return (TRUE)
 runAllSwiftTests <- function(...) {
     startTime = proc.time()[["elapsed"]]
@@ -648,6 +709,11 @@
     name="5 - remote R service error ",
     tests = list(mkTest(swiftTest_5.1)))
+testGroup6 <- makeTestGroup(
+    name="6 - test apply variants",
+    tests = list(mkTest(swiftTest_6.1),
+            mkTest(swiftTest_6.2),
+            mkTest(swiftTest_6.3)))
 makeFullTestSuite <- function (...) {
     initArgs <- list(...)
@@ -657,6 +723,6 @@
                             options(swift.initialexpr="initVar1 <- 19; initVar2 <- sqrt(400)+3")
                             do.call(swiftInit, initArgs) }, # swiftInit controlled via options
         groups=list(testGroup1.1, testGroup2, testGroup1.2, testGroup1.3, testGroup3, testGroup4,
-            testGroup5),
+            testGroup5, testGroup6),
         teardown=function () { swiftShutdown() })
