[Swift-commit] r4175 - SwiftApps/SwiftR/Swift/tests/OpenMx
Wed Mar 9 15:40:32 CST 2011
Author: tga
Date: 2011-03-09 15:40:32 -0600 (Wed, 09 Mar 2011)
New Revision: 4175
Modified:
   SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R
Log:
Missing source statement in openmx test.
Modified: SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R
--- SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R	2011-03-09 20:57:14 UTC (rev 4174)
+++ SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R	2011-03-09 21:40:32 UTC (rev 4175)
@@ -1,6 +1,6 @@
 # Program: RAM-3Factor-12Indicators.R
-#  Author: Steven M. Boker
+#  Author: Steven M. Boker, Timothy G. Armstrong
 #    Date: Fri Jul 30 13:45:12 EDT 2010
 # This program is a factor model using standard RAM.
@@ -9,14 +9,24 @@
 # Revision History
 #    -- Fri Jul 30 13:45:12 EDT 2010
 #      Created RAM-3Factor-12Indicators.R.
+#    -- Wed Mar 9               2011
+#       Copied to SwiftR codebase, refactored to use with SwiftR
+#       performance testing tools
+# This file is meant to be opened using the source command from an R instance
+#   with working directory of either
+#  a) the root of the R library directory in which is
+#  b) the root of the SwiftR source trunk
+#  ie.
+# > source("Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R")
 # Read libraries and set options.
 library(OpenMx)
 library(Swift)
+source("Swift/tests/perf_tests.R")
 # Data for factor model.
