[Swift-commit] r4791 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Thu Jul 7 11:44:04 CDT 2011
Author: jonmon
Date: 2011-07-07 11:44:04 -0500 (Thu, 07 Jul 2011)
New Revision: 4791
Modified:
   SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
o Now goswift creates unique run directories to execute in. Need to figure out how to purge these after awhile because they cannot be kept on the vm very long.
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	2011-07-07 16:38:23 UTC (rev 4790)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	2011-07-07 16:44:04 UTC (rev 4791)
@@ -166,22 +166,40 @@
     # get the swift input package
     ( tc, sites, config, script ) = parse_stdin()
-    # FIX: Must create a unique file. Multiple #
-    #      runs using this will clober files.  #
-    #      Multiple calls to goswift at the    #
-    #      same time will screw everything to  #
-    #      fail.                               #
+    # FIX: Must create a unique directory. Multiple #
+    #      runs using this will clober files.       #
+    #      Multiple calls to goswift at the         #
+    #      same time will screw everything to       #
+    #      fail.                                    #
     # write to appropriate files created in /home/jonmon/swift
     if not os.access( '/home/jonmon/swift', os.F_OK ):
         os.mkdir( '/home/jonmon/swift' )
-    tc_file = open( '/home/jonmon/swift/tc', 'w' )
-    sites_file = open( '/home/jonmon/swift/sites.xml', 'w' )
-    config_file = open( '/home/jonmon/swift/cf', 'w' )
-    script_file = open( '/home/jonmon/swift/script.swift', 'w' )
+    run_directory = 'run.0'
+    directories = os.listdir( '/home/jonmon/swift' )
+    # This might cause a performance problem(to even begin to start Swift)
+    # Need to figure out how maybe purge these run directories
+    # For now I can manually purge
+    directories.sort()
+    directories.reverse()
+    # if the directories list is not empty
+    if directories:
+        last_directory = directories[ 0 ]
+        ( run, sep, run_num ) = last_directory.partition( '.' )
+        run_directory = run + '.' + str( int ( run_num ) + 1 )
+    os.mkdir( '/home/jonmon/swift/'+run_directory )
+    # TODO: check for IOException and return error code for IOErrors
+    tc_file = open( '/home/jonmon/swift/'+run_directory+'/tc', 'w' )
+    sites_file = open( '/home/jonmon/swift/'+run_directory+'/sites.xml', 'w' )
+    config_file = open( '/home/jonmon/swift/'+run_directory+'/cf', 'w' )
+    script_file = open( '/home/jonmon/swift/'+run_directory+'/script.swift', 'w' )
     tc_file.write( tc )
     sites_file.write( sites )
     config_file.write( config )
@@ -192,11 +210,13 @@
     config_file.close()
     script_file.close()
-    # get a space seperated list of the sites to execute on
+    # get a space seperated String of the sites to execute on
     execution_sites=" ".join( map ( str, args ) )
     sys.stdout.write( "\nExecuting Swift on: " + execution_sites + "\n" )
+    sys.stdout.write( "Execution directory: swift/" + run_directory + "\n" )
-    # If I do not execute the script, just print out all pertatent information
+    # If I do not execute the script, just print out all important information
+    # useful to verify that the inputs to the Swift command line have been parsed correctly
     if options.do_not_execute:
         sys.stdout.write( "\nTC file: \n" + tc + "\n" )
         sys.stdout.write( "SITES file: \n" + sites + "\n" )
@@ -206,8 +226,8 @@
         return 0
     # Execute the script
-    os.chdir( '/home/jonmon/swift' )
-    ( status, output ) = commands.getstatusoutput( '/home/koa/swift-0.92/bin/swift -sites.file sites.xml -tc.file tc -config cf script.swift' )
+    os.chdir( '/home/jonmon/swift/'+run_directory )
+    ( status, output ) = commands.getstatusoutput( '/home/jonmon/swift-0.92/bin/swift -sites.file sites.xml -tc.file tc -config cf script.swift' )
     sys.stdout.write( "Swift output: " + output + "\n" )
     sys.stdout.write( "Swift exit status: " + str(status) + "\n" )
