[Swift-commit] r4745 - trunk/tests/language-behaviour/IO
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Jul 2 23:34:39 CDT 2011
Author: hategan
Date: 2011-07-02 23:34:39 -0500 (Sat, 02 Jul 2011)
New Revision: 4745
Added:
   trunk/tests/language-behaviour/IO/130-fmri.0001.h.input.in
   trunk/tests/language-behaviour/IO/130-fmri.0001.v.input.in
   trunk/tests/language-behaviour/IO/130-fmri.0002.h.input.in
   trunk/tests/language-behaviour/IO/130-fmri.0002.v.input.in
   trunk/tests/language-behaviour/IO/130-fmri.0003.h.input.in
   trunk/tests/language-behaviour/IO/130-fmri.0003.v.input.in
   trunk/tests/language-behaviour/IO/130-fmri.0004.h.input.in
   trunk/tests/language-behaviour/IO/130-fmri.0004.v.input.in
   trunk/tests/language-behaviour/IO/130-fmri.h.template.in
   trunk/tests/language-behaviour/IO/130-fmri.v.template.in
   trunk/tests/language-behaviour/IO/q22.setup.sh
   trunk/tests/language-behaviour/IO/q23.args
   trunk/tests/language-behaviour/IO/tc.template.mix.data
Removed:
   trunk/tests/language-behaviour/IO/0011-echo-20110603-1140-rr21aum3.log
   trunk/tests/language-behaviour/IO/0011-echo.kml
   trunk/tests/language-behaviour/IO/0011-echo.xml
   trunk/tests/language-behaviour/IO/0012-echo-map-20110603-1140-n9omdlcb.log
   trunk/tests/language-behaviour/IO/0012-echo-map.kml
   trunk/tests/language-behaviour/IO/0012-echo-map.xml
Modified:
   trunk/tests/language-behaviour/IO/130-fmri.swift
   trunk/tests/language-behaviour/IO/q22.swift
Log:
fixed io tests
Deleted: trunk/tests/language-behaviour/IO/0011-echo-20110603-1140-rr21aum3.log
--- trunk/tests/language-behaviour/IO/0011-echo-20110603-1140-rr21aum3.log	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/0011-echo-20110603-1140-rr21aum3.log	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1,111 +0,0 @@
-2011-06-03 11:40:08,649-0500 DEBUG Loader Max heap: 238616576
-2011-06-03 11:40:08,650-0500 DEBUG textfiles BEGIN SWIFTSCRIPT:
-type messagefile;
-app (messagefile t) greeting() {
-        echo "hello" stdout=@filename(t);
-messagefile outfile <"0011-echo.out">;
-outfile = greeting();
-2011-06-03 11:40:08,650-0500 DEBUG textfiles END SWIFTSCRIPT:
-2011-06-03 11:40:08,650-0500 INFO  Loader 0011-echo.swift: source file is new. Recompiling.
-2011-06-03 11:40:09,279-0500 INFO  Karajan Validation of XML intermediate file was successful
-2011-06-03 11:40:09,475-0500 DEBUG Loader setting: tc.file to: ./tc.data
-2011-06-03 11:40:09,475-0500 DEBUG textfiles using default sites file
-2011-06-03 11:40:09,493-0500 INFO  VDL2ExecutionContext Stack dump:
-Level 1
-[iA = 0, iB = 0, bA = false, bB = false]
-	vdl:instanceconfig = Swift configuration []
-	vdl:operation = run
-	PATH_SEPARATOR = /
-	swift.home = /home/Alberto/Swift/cog/modules/swift/dist/swift-svn/bin/..
-	#vdl:futureWrapperMap = org.griphyn.vdl.karajan.WrapperMap at 171f189
-2011-06-03 11:40:10,075-0500 INFO  unknown Using sites file: /home/Alberto/Swift/cog/modules/swift/dist/swift-svn/bin/../etc/sites.xml
-2011-06-03 11:40:10,112-0500 INFO  unknown Using tc.data: ./tc.data
-2011-06-03 11:40:10,212-0500 INFO  AbstractScheduler Setting resources to: {localhost=localhost}
-2011-06-03 11:40:10,702-0500 INFO  unknown Swift svn swift-r4543 cog-r3143
-2011-06-03 11:40:10,703-0500 INFO  unknown RUNID id=run:20110603-1140-rr21aum3
-2011-06-03 11:40:10,767-0500 DEBUG greeting PROCEDURE line=3 thread=0-1 name=greeting
-2011-06-03 11:40:10,774-0500 INFO  vdl:execute START thread=0-1 tr=echo
-2011-06-03 11:40:10,798-0500 INFO  WeightedHostScoreScheduler CONTACT_SELECTED host=localhost, score=1.000
-2011-06-03 11:40:10,802-0500 INFO  GlobalSubmitQueue No global submit throttle set. Using default (1024)
-2011-06-03 11:40:10,805-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:10,873-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:10,876-0500 INFO  vdl:initshareddir START host=localhost - Initializing shared directory
-2011-06-03 11:40:10,880-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:10,899-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:10,902-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:10,904-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:10,908-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:10,912-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:10,914-0500 INFO  vdl:initshareddir END host=localhost - Done initializing shared directory
-2011-06-03 11:40:10,917-0500 DEBUG vdl:execute2 THREAD_ASSOCIATION jobid=echo-1geu42bk thread=0-1-1 host=localhost replicationGroup=0geu42bk
-2011-06-03 11:40:10,925-0500 INFO  vdl:createdirset START jobid=echo-1geu42bk host=localhost - Initializing directory structure
-2011-06-03 11:40:10,926-0500 INFO  vdl:createdirset END jobid=echo-1geu42bk - Done initializing directory structure
-2011-06-03 11:40:10,926-0500 INFO  vdl:dostagein START jobid=echo-1geu42bk - Staging in files
-2011-06-03 11:40:10,932-0500 INFO  vdl:dostagein END jobid=echo-1geu42bk - Staging in finished
-2011-06-03 11:40:10,934-0500 DEBUG vdl:execute2 JOB_START jobid=echo-1geu42bk tr=echo arguments=[?:string = hello - Closed] tmpdir=0011-echo-20110603-1140-rr21aum3/jobs/1/echo-1geu42bk host=localhost
-2011-06-03 11:40:10,937-0500 DEBUG textfiles BEGIN TC:
-#This is the transformation catalog.
-#It comes pre-configured with a number of simple transformations with
-#paths that are likely to work on a linux box. However, on some systems,
-#the paths to these executables will be different (for example, sometimes
-#some of these programs are found in /usr/bin rather than in /bin)
-#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
-#there must be no trailing whitespace at the end of each line.
-# sitename  transformation  path   INSTALLED  platform  profiles
-localhost 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
-localhost 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
-localhost 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
-localhost 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
-localhost 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
-localhost 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
-localhost 	cp 		/bin/cp         INSTALLED	INTEL32::LINUX	null
-localhost	wc		/usr/bin/wc	INSTALLED	INTEL32::LINUX	null
-localhost	touch	/bin/touch	INSTALLED	INTEL32::LINUX	null
-localhost	sleep	/bin/sleep	INSTALLED	INTEL32::LINUX	null
-localhost	delayedcat	/home/Alberto/Swift/cog/modules/swift/tests/language-behaviour/delayedcat.sh	INSTALLED	INTEL32::LINUX	null
-2011-06-03 11:40:10,937-0500 DEBUG textfiles END TC:
-2011-06-03 11:40:10,946-0500 INFO  GridExec TASK_DEFINITION: Task(type=JOB_SUBMISSION, identity=urn:0-1-1-1307119210103) is /bin/bash shared/_swiftwrap echo-1geu42bk -jobdir 1 -scratch  -e /bin/echo -out 0011-echo.out -err stderr.txt -i -d  -if  -of 0011-echo.out -k  -cdmfile  -status files -a hello
-2011-06-03 11:40:10,952-0500 INFO  JobSubmissionTaskHandler Submit: in: /var/tmp/0011-echo-20110603-1140-rr21aum3 command: /bin/bash /var/tmp/0011-echo-20110603-1140-rr21aum3/shared/_swiftwrap echo-1geu42bk -jobdir 1 -scratch  -e /bin/echo -out 0011-echo.out -err stderr.txt -i -d  -if  -of 0011-echo.out -k  -cdmfile  -status files -a hello
-2011-06-03 11:40:11,045-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:11,048-0500 DEBUG vdl:checkjobstatus START jobid=echo-1geu42bk
-2011-06-03 11:40:11,051-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:11,052-0500 INFO  vdl:checkjobstatus SUCCESS jobid=echo-1geu42bk - Success file found
-2011-06-03 11:40:11,053-0500 DEBUG vdl:execute2 STAGING_OUT jobid=echo-1geu42bk
-2011-06-03 11:40:11,055-0500 INFO  vdl:dostageout START jobid=echo-1geu42bk - Staging out files
-2011-06-03 11:40:11,056-0500 DEBUG vdl:dostageout stageouts: [[$, outfile:messagefile = ? - Open]]
-2011-06-03 11:40:11,064-0500 DEBUG vdl:dostageout FILE_STAGE_OUT_START srcname=0011-echo.out srcdir=0011-echo-20110603-1140-rr21aum3/shared/ srchost=localhost destdir= desthost=localhost provider=file
-2011-06-03 11:40:11,065-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:11,077-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:11,078-0500 DEBUG vdl:dostageout FILE_STAGE_OUT_END srcname=0011-echo.out srcdir=0011-echo-20110603-1140-rr21aum3/shared/ srchost=localhost destdir= desthost=localhost provider=file
-2011-06-03 11:40:11,083-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:11,092-0500 INFO  vdl:dostageout END jobid=echo-1geu42bk - Staging out finished
-2011-06-03 11:40:11,097-0500 DEBUG vdl:execute2 JOB_END jobid=echo-1geu42bk
-2011-06-03 11:40:11,098-0500 INFO  vdl:execute END_SUCCESS thread=0-1 tr=echo
-2011-06-03 11:40:11,100-0500 DEBUG greeting PROCEDURE_END line=3
-2011-06-03 11:40:11,113-0500 DEBUG vdl:mains Starting cleanups
-2011-06-03 11:40:11,116-0500 INFO  vdl:cleanups START cleanups=[[0011-echo-20110603-1140-rr21aum3, localhost]]
-2011-06-03 11:40:11,118-0500 INFO  vdl:cleanup START dir=0011-echo-20110603-1140-rr21aum3 host=localhost
-2011-06-03 11:40:11,119-0500 DEBUG vdl:cleanup cdmfile
-2011-06-03 11:40:11,123-0500 INFO  GridExec TASK_DEFINITION: Task(type=JOB_SUBMISSION, identity=urn:0-1-1307119210114) is /bin/rm -rf 0011-echo-20110603-1140-rr21aum3
-2011-06-03 11:40:11,123-0500 INFO  JobSubmissionTaskHandler Submit: in: /var/tmp command: /bin/rm -rf 0011-echo-20110603-1140-rr21aum3
-2011-06-03 11:40:11,123-0500 INFO  LateBindingScheduler JobQueue: 0
-2011-06-03 11:40:11,130-0500 INFO  vdl:cleanup END dir=0011-echo-20110603-1140-rr21aum3 host=localhost
-2011-06-03 11:40:11,131-0500 INFO  vdl:cleanups END cleanups=[[0011-echo-20110603-1140-rr21aum3, localhost]]
-2011-06-03 11:40:11,132-0500 DEBUG vdl:mains Ending cleanups
-2011-06-03 11:40:11,158-0500 INFO  Loader Swift finished with no errors
Deleted: trunk/tests/language-behaviour/IO/0011-echo.kml
--- trunk/tests/language-behaviour/IO/0011-echo.kml	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/0011-echo.kml	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1,70 +0,0 @@
-<project><!-- CACHE ID ee300c16-1a12-4e15-bc05-578b8e792831 -->
-  <import file="sys.xml"/>
-  <import file="scheduler.xml"/>
-  <import file="rlog.xml"/>
-  <import file="vdl.k"/>
-  <types>
-     <xs:schema targetNamespace="http://ci.uchicago.edu/swift/2009/02/swiftscript" xmlns="http://ci.uchicago.edu/swift/2009/02/swiftscript" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xs="http://www.w3.org/2001/XMLSchema">
-      	   <xs:simpleType name="messagefile">
-      	   <xs:restriction base="string"/>
-      	   </xs:simpleType>
-     </xs:schema>
-  </types>
-  <global name="swift#string#17000">
-    <vdl:new type="string" value="hello" />
-  </global>
-  <element name="greeting" arguments="t">
-    <parameterlog>
-    <string>output</string>
-    <string>t</string>
-    <vdl:getdatasetprovenanceid var="{t}" />
-    <string>{#thread}</string>
-    </parameterlog>
-    <log level="debug" message="PROCEDURE line=3 thread={#thread} name=greeting"/>
-    <vdl:execute>
-      <vdl:tr>echo</vdl:tr>
-      <vdl:stageout var="{t}"/>
-      <vdl:arguments>
-        <variable>swift#string#17000</variable>
-      </vdl:arguments>
-      <vdl:stdout>
-        <swiftscript:filename>
-         <variable>t</variable>
-        </swiftscript:filename>
-      </vdl:stdout>
-    </vdl:execute>
-    <vdl:closedataset var="{t}"/>
-    <log level="debug" message="PROCEDURE_END line=3"/></element>
-  <set name="outfile">
-        <vdl:new type="messagefile" dbgname="outfile" waitfor="88000">
-          <vdl:mapping descriptor="single_file_mapper">
-            <vdl:parameter name="file" value="0011-echo.out"/>
-          </vdl:mapping>
-        </vdl:new>
-  </set>
-  <parameterlog>
-  <string>intermediate</string>
-  <string>outfile</string>
-  <vdl:getdatasetprovenanceid var="{outfile}" />
-  </parameterlog>
-  <restartLog>
-  	<vdl:mains>
-		<vdl:startprogressticker />
-		<vdl:mainp>
-		    <sequentialWithID>
-		        <sequential>
-		          <greeting>
-		            <parallel>
-		              <variable>outfile</variable>
-		            </parallel>
-		          </greeting>
-		            <partialCloseDataset var="{outfile}" closeID="88000" />
-		        </sequential>
-		    </sequentialWithID>
-		</vdl:mainp>
-		<vdl:stopprogressticker />
-	</vdl:mains>
-  </restartLog>
-</project>
Deleted: trunk/tests/language-behaviour/IO/0011-echo.xml
--- trunk/tests/language-behaviour/IO/0011-echo.xml	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/0011-echo.xml	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1,29 +0,0 @@
-<program xmlns="http://ci.uchicago.edu/swift/2009/02/swiftscript"
-         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
-         xmlns:xs="http://www.w3.org/2001/XMLSchema">
-  <types>
-     	<type>
-     		<typename>messagefile</typename>
-     		<typealias>string</typealias>
-     		<typestructure></typestructure>
-     	</type>
-  </types>
-  <procedure name="greeting" src="line 3">
-      <output
-    name="t" type="messagefile"
-     xsi:nil="true" />
-    <binding>
-      <application src="line 3">
-        <executable>echo</executable>
-        <stdout><function name="filename">
-          <variableReference>t</variableReference></function></stdout><stringConstant>hello</stringConstant>  </application>
-    </binding>
-  </procedure>
-  <variable name="outfile" type="messagefile" isGlobal="false"><file name="0011-echo.out"/></variable>
-  <call proc="greeting" src="line 9">
-    <output><variableReference>outfile</variableReference></output>
-  </call>
-</program>
Deleted: trunk/tests/language-behaviour/IO/0012-echo-map-20110603-1140-n9omdlcb.log
--- trunk/tests/language-behaviour/IO/0012-echo-map-20110603-1140-n9omdlcb.log	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/0012-echo-map-20110603-1140-n9omdlcb.log	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1,33 +0,0 @@
-2011-06-03 11:40:12,099-0500 DEBUG Loader Max heap: 238616576
-2011-06-03 11:40:12,100-0500 DEBUG textfiles BEGIN SWIFTSCRIPT:
-type messagefile;
-(messagefile t) greeting() {
-    app {
-messagefile outfile <"0012-echo-map.out"> = greeting();
-2011-06-03 11:40:12,100-0500 DEBUG textfiles END SWIFTSCRIPT:
-2011-06-03 11:40:12,101-0500 INFO  Loader 0012-echo-map.swift: source file is new. Recompiling.
-2011-06-03 11:40:12,683-0500 INFO  Karajan Validation of XML intermediate file was successful
-2011-06-03 11:40:12,882-0500 DEBUG Loader setting: tc.file to: ./tc.data
-2011-06-03 11:40:12,882-0500 DEBUG textfiles using default sites file
-2011-06-03 11:40:12,900-0500 INFO  VDL2ExecutionContext Stack dump:
-Level 1
-	#vdl:futureWrapperMap = org.griphyn.vdl.karajan.WrapperMap at d56b37
-2011-06-03 11:40:13,570-0500 INFO  unknown Using sites file: /home/Alberto/Swift/cog/modules/swift/dist/swift-svn/bin/../etc/sites.xml
-2011-06-03 11:40:13,609-0500 INFO  unknown Using tc.data: ./tc.data
-2011-06-03 11:40:13,715-0500 INFO  AbstractScheduler Setting resources to: {localhost=localhost}
Deleted: trunk/tests/language-behaviour/IO/0012-echo-map.kml
--- trunk/tests/language-behaviour/IO/0012-echo-map.kml	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/0012-echo-map.kml	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1,70 +0,0 @@
-  <types>
-      	   </xs:simpleType>
-     </xs:schema>
-  </types>
-  </global>
-    <parameterlog>
-    </parameterlog>
-    <vdl:execute>
-      <vdl:arguments>
-      </vdl:arguments>
-      <vdl:stdout>
-      </vdl:stdout>
-    </vdl:execute>
-            <vdl:parameter name="file" value="0012-echo-map.out"/>
-          </vdl:mapping>
-        </vdl:new>
-  </set>
-  <parameterlog>
-  </parameterlog>
-  <restartLog>
-  	<vdl:mains>
-		<vdl:mainp>
-		        <sequential>
-		          <greeting>
-		            <parallel>
-		            </parallel>
-		          </greeting>
-		        </sequential>
-		</vdl:mainp>
-	</vdl:mains>
-  </restartLog>
-</project>
Deleted: trunk/tests/language-behaviour/IO/0012-echo-map.xml
--- trunk/tests/language-behaviour/IO/0012-echo-map.xml	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/0012-echo-map.xml	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1,29 +0,0 @@
-  <types>
-     	<type>
-     	</type>
-  </types>
-      <output
-     xsi:nil="true" />
-    <binding>
-      <application src="line 4">
-    </binding>
-  </procedure>
-  <variable name="outfile" type="messagefile" isGlobal="false"><file name="0012-echo-map.out"/></variable>
-  </call>
-</program>
Deleted: trunk/tests/language-behaviour/IO/130-fmri.0001.h.in
--- trunk/tests/language-behaviour/IO/130-fmri.0001.h.in	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/130-fmri.0001.h.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1 +0,0 @@
-qux
Added: trunk/tests/language-behaviour/IO/130-fmri.0001.h.input.in
--- trunk/tests/language-behaviour/IO/130-fmri.0001.h.input.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/130-fmri.0001.h.input.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+qux
Deleted: trunk/tests/language-behaviour/IO/130-fmri.0001.v.in
--- trunk/tests/language-behaviour/IO/130-fmri.0001.v.in	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/130-fmri.0001.v.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1 +0,0 @@
-qux
Added: trunk/tests/language-behaviour/IO/130-fmri.0001.v.input.in
--- trunk/tests/language-behaviour/IO/130-fmri.0001.v.input.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/130-fmri.0001.v.input.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+qux
Deleted: trunk/tests/language-behaviour/IO/130-fmri.0002.h.in
--- trunk/tests/language-behaviour/IO/130-fmri.0002.h.in	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/130-fmri.0002.h.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1 +0,0 @@
-qux
Added: trunk/tests/language-behaviour/IO/130-fmri.0002.h.input.in
--- trunk/tests/language-behaviour/IO/130-fmri.0002.h.input.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/130-fmri.0002.h.input.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+qux
Deleted: trunk/tests/language-behaviour/IO/130-fmri.0002.v.in
--- trunk/tests/language-behaviour/IO/130-fmri.0002.v.in	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/130-fmri.0002.v.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1 +0,0 @@
-qux
Added: trunk/tests/language-behaviour/IO/130-fmri.0002.v.input.in
--- trunk/tests/language-behaviour/IO/130-fmri.0002.v.input.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/130-fmri.0002.v.input.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+qux
Deleted: trunk/tests/language-behaviour/IO/130-fmri.0003.h.in
--- trunk/tests/language-behaviour/IO/130-fmri.0003.h.in	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/130-fmri.0003.h.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1 +0,0 @@
-qux
Added: trunk/tests/language-behaviour/IO/130-fmri.0003.h.input.in
--- trunk/tests/language-behaviour/IO/130-fmri.0003.h.input.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/130-fmri.0003.h.input.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+qux
Deleted: trunk/tests/language-behaviour/IO/130-fmri.0003.v.in
--- trunk/tests/language-behaviour/IO/130-fmri.0003.v.in	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/130-fmri.0003.v.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1 +0,0 @@
-qux
Added: trunk/tests/language-behaviour/IO/130-fmri.0003.v.input.in
--- trunk/tests/language-behaviour/IO/130-fmri.0003.v.input.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/130-fmri.0003.v.input.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+qux
Deleted: trunk/tests/language-behaviour/IO/130-fmri.0004.h.in
--- trunk/tests/language-behaviour/IO/130-fmri.0004.h.in	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/130-fmri.0004.h.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1 +0,0 @@
-qux
Added: trunk/tests/language-behaviour/IO/130-fmri.0004.h.input.in
--- trunk/tests/language-behaviour/IO/130-fmri.0004.h.input.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/130-fmri.0004.h.input.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+qux
Deleted: trunk/tests/language-behaviour/IO/130-fmri.0004.v.in
--- trunk/tests/language-behaviour/IO/130-fmri.0004.v.in	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/130-fmri.0004.v.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1 +0,0 @@
-qux
Added: trunk/tests/language-behaviour/IO/130-fmri.0004.v.input.in
--- trunk/tests/language-behaviour/IO/130-fmri.0004.v.input.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/130-fmri.0004.v.input.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+qux
Deleted: trunk/tests/language-behaviour/IO/130-fmri.h.template
--- trunk/tests/language-behaviour/IO/130-fmri.h.template	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/130-fmri.h.template	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1 +0,0 @@
-foo
Added: trunk/tests/language-behaviour/IO/130-fmri.h.template.in
--- trunk/tests/language-behaviour/IO/130-fmri.h.template.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/130-fmri.h.template.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+foo
Modified: trunk/tests/language-behaviour/IO/130-fmri.swift
--- trunk/tests/language-behaviour/IO/130-fmri.swift	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/130-fmri.swift	2011-07-03 04:34:39 UTC (rev 4745)
@@ -16,8 +16,8 @@
 // inputs: 4 volumes and a reference volume
-volume inputs[] <simple_mapper;prefix="130-fmri.",suffix=".in">;
-volume template <simple_mapper;prefix="130-fmri.",suffix=".template">;
+volume inputs[] <simple_mapper;prefix="130-fmri.",suffix=".input.in">;
+volume template <simple_mapper;prefix="130-fmri.",suffix=".template.in">;
 // align 4 volumes to reference volume
Deleted: trunk/tests/language-behaviour/IO/130-fmri.v.template
--- trunk/tests/language-behaviour/IO/130-fmri.v.template	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/130-fmri.v.template	2011-07-03 04:34:39 UTC (rev 4745)
@@ -1 +0,0 @@
-foo
Added: trunk/tests/language-behaviour/IO/130-fmri.v.template.in
--- trunk/tests/language-behaviour/IO/130-fmri.v.template.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/130-fmri.v.template.in	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+foo
Added: trunk/tests/language-behaviour/IO/q22.setup.sh
--- trunk/tests/language-behaviour/IO/q22.setup.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/q22.setup.sh	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1,5 @@
+#!/bin/bash
+echo "eye" > one.txt
+echo "eye bee" > two.txt
+echo "eye bee see" > three.txt
\ No newline at end of file
Property changes on: trunk/tests/language-behaviour/IO/q22.setup.sh
___________________________________________________________________
Added: svn:executable
Modified: trunk/tests/language-behaviour/IO/q22.swift
--- trunk/tests/language-behaviour/IO/q22.swift	2011-07-03 04:16:46 UTC (rev 4744)
+++ trunk/tests/language-behaviour/IO/q22.swift	2011-07-03 04:34:39 UTC (rev 4745)
@@ -5,8 +5,8 @@
         wc "-w" @filename(f) stdout=@filename(t);
-string inputNames = "one.txt two.txt three.txt";
-string outputNames = "one.count two.count three.count";
+string inputNames[] = ["one.txt", "two.txt", "three.txt"];
+string outputNames[] = ["one.count", "two.count", "three.count"];
 messagefile inputfiles[] <array_mapper;files=inputNames>;
 countfile outputfiles[] <array_mapper;files=outputNames>;
Added: trunk/tests/language-behaviour/IO/q23.args
--- trunk/tests/language-behaviour/IO/q23.args	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/q23.args	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+-text=Hello
Added: trunk/tests/language-behaviour/IO/tc.template.mix.data
--- trunk/tests/language-behaviour/IO/tc.template.mix.data	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/tc.template.mix.data	2011-07-03 04:34:39 UTC (rev 4745)
@@ -0,0 +1 @@
+localhost	touch				/usr/bin/touch         INSTALLED	INTEL32::LINUX	null
