[Swift-commit] r4012 - in usertools/plotter: . src
Thu Jan 20 10:07:44 CST 2011
Author: wozniak
Date: 2011-01-20 10:07:44 -0600 (Thu, 20 Jan 2011)
New Revision: 4012
Modified:
   usertools/plotter/lines.zsh
   usertools/plotter/src/LineReader.java
   usertools/plotter/src/Lines.java
Log:
Usage notes
Modified: usertools/plotter/lines.zsh
--- usertools/plotter/lines.zsh	2011-01-20 15:58:33 UTC (rev 4011)
+++ usertools/plotter/lines.zsh	2011-01-20 16:07:44 UTC (rev 4012)
@@ -1,7 +1,7 @@
 #!/bin/zsh
 # LINES.ZSH
-# Arguments passed directly to Lines.java
+# Arguments passed directly to Lines.java - see there for details
 # usage: lines.zsh <properties> <output file> <data file>*
 PLOTTERS=$( dirname $0 )
Modified: usertools/plotter/src/LineReader.java
--- usertools/plotter/src/LineReader.java	2011-01-20 15:58:33 UTC (rev 4011)
+++ usertools/plotter/src/LineReader.java	2011-01-20 16:07:44 UTC (rev 4012)
@@ -1,6 +1,12 @@
 import java.util.*;
+ * Utility to read a file into a List of String lines.
+ * Omits comments with #
+ * Wraps lines that end on backslash
 public class LineReader
   LineReader()
@@ -78,7 +84,10 @@
         result = t.length;
     return result;
+     Take line-oriented data and produce an array of doubles.
   public static double[][] array(List<String> lines)
     List<String[]> tokens = tokens(lines);
Modified: usertools/plotter/src/Lines.java
--- usertools/plotter/src/Lines.java	2011-01-20 15:58:33 UTC (rev 4011)
+++ usertools/plotter/src/Lines.java	2011-01-20 16:07:44 UTC (rev 4012)
@@ -20,6 +20,9 @@
 import org.jfree.data.general.Series;
 import org.jfree.data.xy.XYSeriesCollection;
+ * See main() for command-line arguments
 public class Lines
   static Properties properties;
@@ -145,18 +148,12 @@
       if (ymin != null) aymin = ymin;
       if (ymax != null) aymax = ymax;
       axis.setRange(aymin, aymax);
-     Debugging only.
      Args: Lines <properties> <output file> <data file>*
-     Reads title, xlabel, ylabel, and legend labels from properties:
-     e.g.:
-     title = Plot
-     xlabel = size
-     ylabel = speed
-     label.file.data = legend text
+     Reads settings from properties: see scanProperties()
   public static void main(String[] args)
@@ -251,6 +248,23 @@
+     Various plot properties.  All are currently optional
+     Example.
+     Assume you want to plot a two-column table in file.data.
+     The first column is the x values and the second column
+     is the y values.  See LineReader for details.
+     Your properties may include:
+     title = Plot
+     xlabel = size
+     ylabel = speed
+     label.file.data = legend text
+     width (output image width)
+     height (output image height)
+     xmin, xmax, ymin, ymax (auto-selected if not given)
   static void scanProperties()
     String tmp;
