[Swift-commit] r4006 - usertools/worker-profile
Thu Jan 20 09:35:55 CST 2011
Author: wozniak
Date: 2011-01-20 09:35:55 -0600 (Thu, 20 Jan 2011)
New Revision: 4006
Added:
   usertools/worker-profile/worker_jobs.zsh
   usertools/worker-profile/worker_jobs_duration.zsh
   usertools/worker-profile/worker_jobs_lib.zsh
   usertools/worker-profile/worker_profile_extract.zsh
   usertools/worker-profile/worker_profile_util.zsh
Log:
Import worker profile plot data tools
Added: usertools/worker-profile/worker_jobs.zsh
--- usertools/worker-profile/worker_jobs.zsh	                        (rev 0)
+++ usertools/worker-profile/worker_jobs.zsh	2011-01-20 15:35:55 UTC (rev 4006)
@@ -0,0 +1,22 @@
+#!/bin/zsh
+# Lists worker job counts
+# Uses worker_jobs_lib.zsh
+if [[ ${#*} == 0 ]]
+then
+  print "Lists worker job counts"
+  print "usage: worker_jobs.zsh <RESULT> <LOGS>"
+fi
+PLOTS=$( dirname $0 )
+TOOLS=${PLOTS}/../tools
+source ${TOOLS}/helpers.zsh
+[[ $? != 0 ]] && print "Could not source helpers.zsh!" && exit 1
+source ${PLOTS}/worker_jobs_lib.zsh
+worker_jobs ${*} > ${RESULT}
+return 0
Property changes on: usertools/worker-profile/worker_jobs.zsh
___________________________________________________________________
Added: usertools/worker-profile/worker_jobs_duration.zsh
--- usertools/worker-profile/worker_jobs_duration.zsh	                        (rev 0)
+++ usertools/worker-profile/worker_jobs_duration.zsh	2011-01-20 15:35:55 UTC (rev 4006)
@@ -0,0 +1,30 @@
+#!/bin/zsh
+# Lists worker job counts, sorted for plotting
+# usage: worker_jobs_spectrum.zsh <RESULT> <LOGS>
+# The result is a tabular file compatible with plotter/lines.zsh
+then
+  print "Lists worker job counts, sorted for plotting"
+  print "usage: worker_jobs_spectrum.zsh <RESULT> <LOGS>"
+  return 1
+fi
+RESULT=$1
+shift
+LOGS=${*}
+# Output: <index> <jobs> <ID> <logfile>
+worker_jobs ${LOGS} | sort -k 2 | nl -w1 | \
+  awk '{ print $1 " " $3 " # " $2 " " $4 }' > ${RESULT}
+return 0
Property changes on: usertools/worker-profile/worker_jobs_duration.zsh
Added: usertools/worker-profile/worker_jobs_lib.zsh
--- usertools/worker-profile/worker_jobs_lib.zsh	                        (rev 0)
+++ usertools/worker-profile/worker_jobs_lib.zsh	2011-01-20 15:35:55 UTC (rev 4006)
@@ -0,0 +1,23 @@
+# Lists worker job counts from all given worker logs
+# Should just require log level INFO
+worker_jobs()
+  if [[ ${#*} == 0 ]]
+  then
+  fi
+  RESULT=$1
+  shift
+  LOGS=${*}
+  for LOG in ${LOGS}
+  do
+    ID=$( sed -n '/.*ID.*/{s/.*ID=\(.*\)/\1/;p;q}' ${LOG} )
+    JOBS=$( sed -n '/.*Ran a total.*/{s/.*of \(.*\) jobs/\1/;p;q}' ${LOG} )
+    print ${ID} ${JOBS} ${LOG}
+  done
+  return 0
Added: usertools/worker-profile/worker_profile_extract.zsh
--- usertools/worker-profile/worker_profile_extract.zsh	                        (rev 0)
+++ usertools/worker-profile/worker_profile_extract.zsh	2011-01-20 15:35:55 UTC (rev 4006)
@@ -0,0 +1,19 @@
+#!/bin/zsh
+# Extract the PROFILE: lines from the end of the worker log
+# Requires you to set $PROFILE=1 in worker.pl
+LOG=$1
+PROFILE=$2
+checkvars LOG PROFILE
+grep "PROFILE:" ${LOG} | awk '{ print $5 " " $6 " " $7 }' > ${PROFILE}
+exit 0
Property changes on: usertools/worker-profile/worker_profile_extract.zsh
Added: usertools/worker-profile/worker_profile_util.zsh
--- usertools/worker-profile/worker_profile_util.zsh	                        (rev 0)
+++ usertools/worker-profile/worker_profile_util.zsh	2011-01-20 15:35:55 UTC (rev 4006)
@@ -0,0 +1,95 @@
+#!/bin/zsh
+# WORKER PROFILE UTILIZATION
+# Build a data file for plotting from a worker.pl profile log
+# 2-column output format: <time from 0> <load>
+# usage: worker_profile_util.zsh <LOG> <OUTPUT> <GRANULARITY>?
+# Output is compatible with plotter/lines.zsh
+LOG=$1
+DATA=$2
+# If given, set the output data time granularity in seconds
+GRANULARITY=${3:-0.1}
+CORES=1
+checkvars LOG DATA
+PROFILE=${LOG}.ptmp
+${PLOTS}/worker_profile_extract.zsh ${LOG} ${PROFILE}
+EVENTS=( $( < ${PROFILE} ) )
+local -F 3 LOAD=0
+local -F 3 TIMESTAMP TIME_PREV USAGE
+local -F 3 START=${EVENTS[3]}
+local -F 3 TIME=${START}
+TIME_PREV=${TIME}
+data()
+  local -F 5 T=$1
+  local LOAD=$2
+  local COMMENT=$3
+  print ${T} ${LOAD} ${COMMENT} >> ${DATA}
+eventFORK()
+  (( LOAD++ ))
+eventTERM()
+  (( LOAD-- ))
+eventSTOP()
+  RUNNING=0
+# Truncate DATA
+printf "" > ${DATA}
+data $(( TIME-START )) ${LOAD}
+i=4
+RUNNING=1
+while (( RUNNING ))
+ do
+ EVENT=${EVENTS[i]}
+ PID=${EVENTS[i+1]}
+ TIMESTAMP=${EVENTS[i+2]}
+ while (( TIME < TIMESTAMP ))
+  do
+  data $(( TIME-START )) ${LOAD}
+  (( TIME+=GRANULARITY ))
+ done
+ USAGE+=$(( (TIMESTAMP-TIME_PREV) * LOAD ))
+ event${EVENT}
+ data $(( TIMESTAMP-START )) ${LOAD} "#"
+ TIME_PREV=${TIMESTAMP}
+ (( i+=3 ))
+done
+typeset -F 3 TOTAL=$(( (TIMESTAMP-START) * CORES ))
+typeset -F 3 UTIL=$(( USAGE/TOTAL ))
+print "USAGE: ${USAGE}"
+print "TOTAL: ${TOTAL}"
+print "UTIL:  ${UTIL}"
+exit 0
Property changes on: usertools/worker-profile/worker_profile_util.zsh
