[Swift-commit] r4004 - in usertools: . plotter plotter/src
Thu Jan 20 09:21:46 CST 2011
Author: wozniak
Date: 2011-01-20 09:21:46 -0600 (Thu, 20 Jan 2011)
New Revision: 4004
Added:
   usertools/plotter/
   usertools/plotter/build.xml
   usertools/plotter/classpath.zsh
   usertools/plotter/lines.zsh
   usertools/plotter/src/
   usertools/plotter/src/Bits.java
   usertools/plotter/src/LineReader.java
   usertools/plotter/src/Lines.java
   usertools/plotter/src/Util.java
Log:
Copy simple JFreeChart-based plotter from CDM
Added: usertools/plotter/build.xml
--- usertools/plotter/build.xml	                        (rev 0)
+++ usertools/plotter/build.xml	2011-01-20 15:21:46 UTC (rev 4004)
@@ -0,0 +1,25 @@
+<project name="plots"
+         default="all">
+  <fileset id="jars"
+           dir="lib"
+           includes="*.jar" />
+  <pathconvert refid="jars" property="jars" />
+  <property name="classpath" value="./src:${jars}" />
+  <target name="all"
+          depends="compile" />
+  <target name="compile">
+   <javac srcdir="src"
+          classpath="${classpath}"
+          listfiles="${lf}"
+          debug="true"
+          debuglevel="source,lines,vars">
+     <compilerarg value="-Xlint"/>
+   </javac>
+  </target>
+</project>
Added: usertools/plotter/classpath.zsh
--- usertools/plotter/classpath.zsh	                        (rev 0)
+++ usertools/plotter/classpath.zsh	2011-01-20 15:21:46 UTC (rev 4004)
@@ -0,0 +1,15 @@
+# Source this to set up classpath for plotter runs
+# classpath stored in ${CP}
+if [[ $( uname ) == CYGWIN* ]]
+then
+    typeset -T CP cp ";"
+    cp+=( ${classpath} )
+    cp+=${PLOTTERS}/src
+    cp+=( ${PLOTTERS}/lib/*.jar )
+else
+    typeset -T CP cp
+    CP=${CLASSPATH}:${PLOTTERS}/src
+fi
Added: usertools/plotter/lines.zsh
--- usertools/plotter/lines.zsh	                        (rev 0)
+++ usertools/plotter/lines.zsh	2011-01-20 15:21:46 UTC (rev 4004)
@@ -0,0 +1,14 @@
+#!/bin/zsh
+# LINES.ZSH
+# Arguments passed directly to Lines.java
+# usage: lines.zsh <properties> <output file> <data file>*
+PLOTTERS=$( dirname $0 )
+# declare -p PLOTDIR
+source ${PLOTTERS}/classpath.zsh
+[[ $? != 0 ]] && print "Could not build CLASSPATH!" && return 1
+java -ea -cp ${CP} Lines ${*}
Property changes on: usertools/plotter/lines.zsh
___________________________________________________________________
Added: usertools/plotter/src/Bits.java
--- usertools/plotter/src/Bits.java	                        (rev 0)
+++ usertools/plotter/src/Bits.java	2011-01-20 15:21:46 UTC (rev 4004)
@@ -0,0 +1,149 @@
+import java.math.BigInteger;
+import java.util.*;
+ * Provides random bits, statically.
+ * Kills VM exit code 2 on misuse.
+public class Bits
+  public static Random rng = null;
+  static boolean locked = false;
+  static boolean ready  = false;
+     If not locked, seed the generator with the clock.
+  public static void init()
+    init(System.currentTimeMillis());
+     If not locked, seed the generator with the clock mod 1000.
+     Useful for debugging.
+     @param print If true, print the seed.
+  public static long init(boolean print)
+    long seed = System.currentTimeMillis() % 1000;
+    init(seed);
+    if (print)
+      System.out.println("Bits.seed: " + seed);
+    return seed;
+     @param seed The seed.
+  public static void init(long seed)
+    assert (!locked) : "Bits locked!";
+    // System.out.println("Seeding RNG...");
+    rng = new Random(seed);
+    ready = true;
+     Lock the generator to prevent seeding
+  public static void lock()
+    locked = true;
+     Unlock the generator
+  public static void unlock()
+    locked = false;
+  public static double nextDouble()
+    if (! ready)
+      System.err.println("Bits not ready!");
+      System.exit(2);
+    return rng.nextDouble();
+  public static double nextDouble(double d)
+    return rng.nextDouble() * d;
+  public static int nextInt()
+    if (! ready)
+      System.exit(2);
+    return rng.nextInt();
+     Return a integer in [0..t).
+  public static int nextInt(int t)
+    double d = nextDouble();
+    int i = (new Double(d * t)).intValue();
+    return i;
+  public static boolean nextBoolean()
+    if (! ready)
+      System.exit(2);
+    return rng.nextBoolean();
+  public static long nextLong()
+    if (! ready)
+      System.exit(2);
+    return rng.nextLong();
+  public static long nextLong(long t)
+    long i = (new Double(d * t)).longValue();
+    return i;
+  public static BigInteger nextBigInteger(BigInteger i)
+    if (i.equals(BigInteger.ZERO))
+      return BigInteger.ZERO;
+    int b = i.bitLength()+1;
+    BigInteger result;
+    do
+      result = BigInteger.valueOf(b);
+    } while (result.compareTo(i) >= 0);
+    return result;
+  public static void nextBytes(byte[] bytes)
+    rng.nextBytes(bytes);
Added: usertools/plotter/src/LineReader.java
--- usertools/plotter/src/LineReader.java	                        (rev 0)
+++ usertools/plotter/src/LineReader.java	2011-01-20 15:21:46 UTC (rev 4004)
@@ -0,0 +1,147 @@
+public class LineReader
+  LineReader()
+  public static List<String> read(java.io.File file)
+    throws java.io.FileNotFoundException
+    java.io.BufferedReader reader =
+      new java.io.BufferedReader(new java.io.FileReader(file));
+    return read(reader);
+  public static List<String> read(String s)
+      new java.io.BufferedReader(new java.io.StringReader(s));
+  public static List<String> read(java.io.BufferedReader reader)
+    List<String> result = new ArrayList<String>();
+    try
+      String prevline = "";
+      String line = "";
+      while ((line = reader.readLine()) != null)
+        int hash = line.indexOf("#");
+        if (hash >= 0)
+          line = line.substring(0,hash);
+        line = spaces(line);
+        line = (prevline + " " + line).trim();
+        if (line.endsWith("\\"))
+          line = line.substring(0, line.length()-2);
+          prevline = line;
+          continue;
+        else
+          prevline = "";
+          line = line.trim();
+          if (line.length() > 0)
+            result.add(line);
+      reader.close();
+    catch (java.io.IOException e)
+      System.out.println("LineReader: I/O problem.");
+      return null;
+    return result;
+  public static List<String[]> tokens(List<String> lines)
+    List<String[]> result = new ArrayList<String[]>(lines.size());
+    for (String line : lines)
+      String[] tokens = tokenize(line);
+      result.add(tokens);
+    return result;
+  public static int maxTokens(List<String[]> tokens)
+    int result = 0;
+    for (String[] t : tokens)
+      if (t.length > result)
+        result = t.length;
+    return result;
+  public static double[][] array(List<String> lines)
+    List<String[]> tokens = tokens(lines);
+    int columns = maxTokens(tokens);
+    int rows = lines.size();
+    double[][] result = new double[rows][columns];
+    for (int i = 0; i < rows; i++)
+      for (int j = 0; j < columns; j++)
+        try
+          String v = tokens.get(i)[j];
+          double d = Double.parseDouble(v);
+          result[i][j] = d;
+        catch (NumberFormatException e)
+          throw new RuntimeException("Problem in row: " + i);
+    return result;
+  public static String spaces(String line)
+    String result = "";
+    for (int i = 0; i < line.length(); i++)
+      if (line.charAt(i)   == '=' &&
+          line.charAt(i+1) != '=' &&
+          line.charAt(i-1) != '=')
+        result += " = ";
+      else
+        result += line.substring(i,i+1);
+    return result;
+  public static String[] tokenize(String line)
+    if (line == null)
+      return null;
+    List<String> words = new ArrayList<String>();
+    String[] ws = line.split("\\s");
+    for (int i = 0; i < ws.length; i++)
+      if (ws[i].length() > 0)
+        words.add(ws[i]);
+    String[] result = new String[words.size()];
+    for (int i = 0; i < words.size(); i++)
+      result[i] = words.get(i);
+    return result;
+  public static List<String> list(String line)
+    for (int i = 0; i < tokens.length; i++)
+      result.add(tokens[i]);
+    return result;
Added: usertools/plotter/src/Lines.java
--- usertools/plotter/src/Lines.java	                        (rev 0)
+++ usertools/plotter/src/Lines.java	2011-01-20 15:21:46 UTC (rev 4004)
@@ -0,0 +1,327 @@
+import java.awt.Color;
+import java.awt.geom.Rectangle2D;
+import java.io.*;
+import gnu.getopt.Getopt;
+import org.apache.commons.io.IOUtils;
+import org.apache.xmlgraphics.java2d.ps.EPSDocumentGraphics2D;
+import org.jfree.chart.ChartFactory;
+import org.jfree.chart.JFreeChart;
+import org.jfree.chart.axis.NumberAxis;
+import org.jfree.chart.plot.PlotOrientation;
+import org.jfree.chart.plot.XYPlot;
+import org.jfree.chart.renderer.xy.XYLineAndShapeRenderer;
+import org.jfree.data.Range;
+import org.jfree.data.general.Series;
+import org.jfree.data.xy.XYSeriesCollection;
+public class Lines
+  static Properties properties;
+  public static boolean bw = false;
+  static int w = 400;
+  static int h = 400;
+  // null indicates the value was not set by the user
+  static Double xmin = null;
+  static Double xmax = null;
+  static Double ymin = null;
+  static Double ymax = null;
+     Generate simple plot.
+     @param collection The x,y data.
+     @param title Plot title.
+     @param xlabel X label text.
+     @param ylabel Y label text.
+     @param output EPS filename.
+  public static boolean plot(XYSeriesCollection collection,
+                             String title, String xlabel,
+                             String ylabel, String output)
+    EPSDocumentGraphics2D g2d = null;
+    Rectangle2D.Double rectangle = null;
+    OutputStream out = null;
+    try
+      out = new FileOutputStream(output);
+      out = new BufferedOutputStream(out);
+      g2d = new EPSDocumentGraphics2D(false);
+      g2d.setGraphicContext
+        (new org.apache.xmlgraphics.java2d.GraphicContext());
+      rectangle = new Rectangle2D.Double(0, 0, w, h);
+      g2d.setupDocument(out, w, h);
+    catch (IOException e)
+      System.out.println("Problem with file: " + output);
+      return false;
+    final boolean withLegend = true;
+    JFreeChart chart =
+      ChartFactory.createXYLineChart
+      (title, xlabel, ylabel, collection,
+       PlotOrientation.VERTICAL, withLegend, false, false);
+    setupPlot(chart, collection);
+    chart.draw(g2d, rectangle);
+    try
+      g2d.finish();
+    catch (Exception e)
+      System.out.println("Err!");
+    IOUtils.closeQuietly(out);
+    System.out.println("PLOTTED: " + output);
+    return true;
+  private static void setupPlot(JFreeChart chart,
+                                XYSeriesCollection collection)
+    XYPlot plot = chart.getXYPlot();
+    XYLineAndShapeRenderer renderer = new XYLineAndShapeRenderer();
+    if (bw)
+      for (int i = 0; i < plot.getSeriesCount(); i++)
+        renderer.setSeriesPaint(i, Color.BLACK);
+      Series series = collection.getSeries(i);
+      if (! showShape(series.getDescription()))
+        // System.out.println("invis");
+        renderer.setSeriesShapesVisible(i, false);
+    setAxes(plot);
+    plot.setRenderer(renderer);
+    plot.setBackgroundPaint(Color.WHITE);
+  static void setAxes(XYPlot plot)
+    // Actual values: modify if necessary
+    double axmin, axmax, aymin, aymax;
+    if (xmin != null || xmax != null)
+      NumberAxis axis = (NumberAxis) plot.getDomainAxis();
+      Range range = axis.getRange();
+      axmin = range.getLowerBound();
+      axmax = range.getUpperBound();
+      if (xmin != null) axmin = xmin;
+      if (xmax != null) axmax = xmax;
+      axis.setRange(axmin, axmax);
+    if (ymin != null || ymax != null)
+      NumberAxis axis = (NumberAxis) plot.getRangeAxis();
+      aymin = range.getLowerBound();
+      aymax = range.getUpperBound();
+      if (ymin != null) aymin = ymin;
+      if (ymax != null) aymax = ymax;
+      axis.setRange(aymin, aymax);
+     Debugging only.
+     Args: Lines <properties> <output file> <data file>*
+     Reads title, xlabel, ylabel, and legend labels from properties:
+     e.g.:
+     title = Plot
+     xlabel = size
+     ylabel = speed
+     label.file.data = legend text
+  public static void main(String[] args)
+    // Settings:
+    boolean verbose = false;
+    Getopt g = new Getopt("testprog", args, "v");
+    int c = -1;
+    while ((c = g.getopt()) != -1)
+      switch (c)
+      case 'v':
+        verbose = true;
+    if (args.length < 3)
+      ("usage: [<options>] <properties> <output> <data>*");
+      System.exit(2);
+    Bits.init();
+    Util.verbose(verbose);
+    String propFile = args[0];
+    String output = args[1];
+    List<String> names = new ArrayList<String>();
+    for (int i = 2; i < args.length; i++)
+      names.add(args[i]);
+    String title = null;
+    String xlabel = null;
+    String ylabel = null;
+    List<double[][]> data = new ArrayList<double[][]>();
+    List<String> labels = new ArrayList<String>();
+    properties = new Properties();
+    load(propFile);
+    title = properties.getProperty("title");
+    xlabel = properties.getProperty("xlabel");
+    ylabel = properties.getProperty("ylabel");
+    scanProperties();
+    for (String name : names)
+      File file = new File(name);
+      Util.verbose("open: " + file);
+      List<String> lines = null;
+      try
+        lines = LineReader.read(file);
+      catch (FileNotFoundException e)
+        System.out.println("not found: " + file);
+        System.exit(1);
+      double[][] array = LineReader.array(lines);
+      data.add(array);
+      addLabel(name, labels);
+      Util.verbose("array:\n" + toString(array));
+    XYSeriesCollection collection = Util.collection(data, labels,
+                                                    names);
+    plot(collection, title, xlabel, ylabel, output);
+  static void load(String propFile)
+    try
+      if (propFile.equals("-"))
+        properties.load(System.in);
+      else
+        properties.load(new FileInputStream(propFile));
+      System.out.println(e);
+      System.exit(1);
+      e.printStackTrace();
+      System.exit(1);
+  static void scanProperties()
+    String tmp;
+    tmp = properties.getProperty("width");
+    if (tmp != null)
+      w = Integer.parseInt(tmp.trim());
+    tmp = properties.getProperty("height");
+    if (tmp != null)
+      h = Integer.parseInt(tmp.trim());
+    tmp = properties.getProperty("xmin");
+    if (tmp != null)
+      xmin = Double.parseDouble(tmp);
+    tmp = properties.getProperty("xmax");
+    if (tmp != null)
+      xmax = Double.parseDouble(tmp);
+    tmp = properties.getProperty("ymin");
+    if (tmp != null)
+      ymin = Double.parseDouble(tmp);
+    tmp = properties.getProperty("ymax");
+    if (tmp != null)
+      ymax = Double.parseDouble(tmp);
+     Arrays.copyOfRange is a Java 1.6 feature.
+     This has the same signature.
+  static String[] select(String[] s, int p, int q)
+    String[] result = new String[q-p];
+    int j = 0;
+    for (int i = p; i < q; i++)
+      result[j++] = s[i];
+    return result;
+  static void addLabel(String name,
+                       List<String> labels)
+    String label = properties.getProperty("label."+name);
+    if (label == null)
+      label = "";
+    labels.add(label);
+  static boolean showShape(String name)
+    // System.out.println(name);
+    String mode = properties.getProperty("shape."+name);
+    // System.out.println(mode);
+    if ("none".equals(mode))
+      return false;
+    return true;
+  static String toString(double[][] array)
+    StringBuilder sb = new StringBuilder();
+    for (int i = 0; i < array.length; i++)
+      double[] row = array[i];
+      for (int j = 0; j < row.length; j++)
+        sb.append(array[i][j]);
+        if (j < row.length-1)
+          sb.append(" ");
+      sb.append("\n");
+    return sb.toString();
Added: usertools/plotter/src/Util.java
--- usertools/plotter/src/Util.java	                        (rev 0)
+++ usertools/plotter/src/Util.java	2011-01-20 15:21:46 UTC (rev 4004)
@@ -0,0 +1,57 @@
+ * Plot data helpers.
+import java.util.List;
+import org.jfree.data.xy.XYSeries;
+public class Util
+  static boolean v = false;
+     Stores the label as the Series key.
+     Stores the filename as the Series description.
+  static XYSeriesCollection collection(List<double[][]> data,
+                                       List<String> labels,
+                                       List<String> names)
+    final XYSeriesCollection collection = new XYSeriesCollection();
+    int count = 0;
+    for (double[][] d : data)
+      String label = "data: " + count;
+      try
+        label = labels.get(count);
+      catch (IndexOutOfBoundsException e)
+      XYSeries series = new XYSeries(label);
+      for (int i = 0; i < d.length; i++)
+        series.add(d[i][0], d[i][1]);
+      series.setDescription(names.get(count));
+      collection.addSeries(series);
+      count++;
+    return collection;
+  public static void verbose(String s)
+    if (v)
+      System.out.println(s);
+  public static void verbose(boolean status)
+    v = status;
