[Swift-commit] r3953 - trunk/tests
Wed Jan 12 10:22:46 CST 2011
Author: wozniak
Date: 2011-01-12 10:22:46 -0600 (Wed, 12 Jan 2011)
New Revision: 3953
Modified:
   trunk/tests/nightly.sh
Log:
Allow nightly.sh to test shell scripts in addition to SwiftScripts
Modified: trunk/tests/nightly.sh
--- trunk/tests/nightly.sh	2011-01-12 15:51:20 UTC (rev 3952)
+++ trunk/tests/nightly.sh	2011-01-12 16:22:46 UTC (rev 3953)
@@ -85,6 +85,11 @@
 # providers/<provider description>/<site>
 # E.g., providers/local-pbs/PADS
+# WARNINGS
+# nightly.sh uses shopt
+shopt -s nullglob
 printhelp() {
   echo "nightly.sh <options> <output>"
   echo ""
@@ -163,7 +168,7 @@
   HTML_COMMENTS=1
 fi
-# Iterations
+# Iterations per test (may want to run each test multiple times?)
 ITERS_LOCAL=1
 LOGCOUNT=0
@@ -185,7 +190,7 @@
 SCRIPTDIR=$( cd $( dirname $0 ) ; /bin/pwd )
-SWIFTCOUNT=0
+TESTCOUNT=0
 echo "RUNNING_IN:  $RUNDIR"
 echo "HTML_OUTPUT: $HTML"
@@ -470,7 +475,7 @@
 start_row() {
   html_tr testline
   html_td align right width 50
-  html "<b>$SWIFTCOUNT</b>"
+  html "<b>$TESTCOUNT</b>"
   html " "
   html_~td
   html_td align right
@@ -651,7 +656,7 @@
   TIMEOUT=$2 # seconds
   OUTPUT=$3
-  V=$SWIFTCOUNT
+  V=$TESTCOUNT
   # Use background so kill/trap is immediate
   sleep $TIMEOUT > /dev/null 2>&1 &
@@ -756,7 +761,7 @@
   CDM=
   [ -r fs.data ] && CDM="-cdm.file fs.data"
-  (( SWIFTCOUNT++ ))
+  (( TESTCOUNT++ ))
   TIMEOUT=$( gettimeout $GROUP/$TIMEOUTFILE )
@@ -779,6 +784,40 @@
   fi
+# Execute shell test case w/ setup, check, clean
+script_test_case() {
+  SHELLSCRIPT=$1
+  SETUPSCRIPT=${SHELLSCRIPT%.test.sh}.setup.sh
+  CHECKSCRIPT=${SHELLSCRIPT%.test.sh}.check.sh
+  CLEANSCRIPT=${SHELLSCRIPT%.test.sh}.clean.sh
+  TIMEOUTFILE=${SHELLSCRIPT%.test.sh}.timeout
+  TEST_SHOULD_FAIL=0
+  if [ -x $GROUP/$SETUPSCRIPT ]; then
+    script_exec $GROUP/$SETUPSCRIPT "S"
+  fi
+  (( TESTCOUNT++ ))
+  # Not using background for script tests yet
+  # TIMEOUT=$( gettimeout $GROUP/$TIMEOUTFILE )
+  fi
+  if [ -x $GROUP/$SHELLSCRIPT ]; then
+    script_exec $SHELLSCRIPT "X"
+  fi
+  if [ -x $GROUP/$CHECKSCRIPT ]; then
+    script_exec $GROUP/$CHECKSCRIPT "√"
+  fi
+  if [ -x $GROUP/$CLEANSCRIPT ]; then
+    script_exec $GROUP/$CLEANSCRIPT "C"
+  fi
 # All timeouts in this script are in seconds
 gettimeout() {
   FILE=$1
@@ -832,12 +871,12 @@
 # Setup coasters variables
-if which ifconfig > /dev/null; then
+if which ifconfig > /dev/null 2>&1; then
   IFCONFIG=ifconfig
 else
   IFCONFIG=/sbin/ifconfig
 fi
-$IFCONFIG > /dev/null || crash "Cannot run ifconfig!"
+$IFCONFIG > /dev/null 2>&1 || crash "Cannot run ifconfig!"
 GLOBUS_HOSTNAME=$( $IFCONFIG | grep inet | head -1 | cut -d ':' -f 2 | \
                    awk '{print $1}' )
 [ $? != 0 ] && crash "Could not obtain GLOBUS_HOSTNAME!"
@@ -907,24 +946,42 @@
   group_fs_data
   group_swift_properties
-  SWIFTS=$( ls $GROUP/*.swift )
-  checkfail "Could not ls: $GROUP"
+  SWIFTS=$( echo $GROUP/*.swift )
+  checkfail "Could not list: $GROUP"
   for TEST in $SWIFTS; do
     (( SKIP_COUNTER++ < SKIP_TESTS )) && continue
-    TESTNAME=$( basename $TEST)
+    TESTNAME=$( basename $TEST )
     cp -v $GROUP/$TESTNAME .
     TESTLINK=$TESTNAME
     start_row
-    for ((i=0; $i<$ITERS_LOCAL; i=$i+1)); do
+    for (( i=0; $i<$ITERS_LOCAL; i=$i+1 )); do
       swift_test_case $TESTNAME
-      (( $SWIFTCOUNT >= $NUMBER_OF_TESTS )) && return
+      (( $TESTCOUNT >= $NUMBER_OF_TESTS )) && return
     done
     end_row
   done
+  SCRIPTS=$( echo $GROUP/*.test.sh )
+  for TEST in $SCRIPTS; do
+    (( SKIP_COUNTER++ < SKIP_TESTS )) && continue
+    cp -v $GROUP/$TESTNAME .
+    TESTLINK=$TESTNAME
+    start_row
+    for ((i=0; $i<$ITERS_LOCAL; i=$i+1)); do
+      script_test_case $TESTNAME
+    done
+    end_row
+  done
 if [[ $WORK == "" ]]
@@ -1004,7 +1061,7 @@
   start_part "Part $GROUPCOUNT: $TITLE"
   test_group
   (( GROUPCOUNT++ ))
-  (( $SWIFTCOUNT >= $NUMBER_OF_TESTS )) && break
+  (( $TESTCOUNT >= $NUMBER_OF_TESTS )) && break
 done
 if [ $GRID_TESTS == "0" ]; then
